[cgma-dev] Minor issue in configure.ac
Paul Wilson wilsonp at engr.wisc.edu
Fri Aug 21 13:09:38 CDT 2009
Hi there,
The current configure.ac in CGM invokes
    AC_PROG_SED
instead of
  AC_CHECK_PROG( [SED], [sed], [sed], [true] )
It turns out that the former does not work on my system, but the latter
does.  Is there a reason to use one over the other?  I notice that MOAB
uses the latter.
Paul
Paul P H Wilson                  UW-Madison Engineering Physics
Associate Professor               419 Engineering Research Bldg
wilsonp at engr.wisc.edu                       1500 Engineering Dr
608/263-0807 fax:608/263-4499                 Madison, WI 53706
http://www.cae.wisc.edu/~wilsonp    http://www.engr.wisc.edu/ep
                       My calendar
http://www.google.com/calendar/embed?src=paul@nagus-wilson.net
          Contributing to the joy and improvement
                  of all those around me
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20090821/de7aa20c/attachment.bin>
More information about the cgma-dev mailing list
