[cgma-dev] r3113 - cgm/trunk/itaps
hongjun at mcs.anl.gov hongjun at mcs.anl.gov
Thu Aug 20 16:32:24 CDT 2009
Author: hongjun
Date: 2009-08-20 16:32:24 -0500 (Thu, 20 Aug 2009)
New Revision: 3113
Modified:
   cgm/trunk/itaps/iGeom_CGMA.cc
Log:
o Nightly distribution test error is fixed.
o FileOption is not used and removed.
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc	2009-08-20 21:23:30 UTC (rev 3112)
+++ cgm/trunk/itaps/iGeom_CGMA.cc	2009-08-20 21:32:24 UTC (rev 3113)
@@ -313,18 +313,22 @@
    // make sure we have a null-terminated string for file name
   std::string file_name( name, name_len );
   name = file_name.c_str();
   // check if work in parallel
   bool parallel = false;
-  FileOptions opts(options);
   std::string parallel_opt;
-  FOErrorCode rval = opts.get_option("PARALLEL", parallel_opt);
-  if (FO_SUCCESS == rval) parallel = true;
+  std::vector<std::string> opts;
+  std::string tmp_options(options, options_size);
+  tmp_options.insert(0, ";");
+  tokenize(tmp_options, opts );
+  for (std::vector<std::string>::iterator i = opts.begin(); i != opts.end(); ++i)
+    if (match_option( *i, "PARALLEL", parallel_opt )) parallel = true;
   // parallel
   if (parallel) {
 #ifdef USE_MPI
-    //CubitStatus status = ParallelGeomTool::instance()->load_file(name, options);
     ParallelGeomTool pgt(reinterpret_cast<CGMTagManager*> (instance), NULL);
     CubitStatus status = pgt.load_file(name, options);
     if (CUBIT_SUCCESS != status) {
More information about the cgma-dev mailing list
