[cgma-dev] r3108 - in cgm/trunk: . cgm_apps/cgm_cubit_acis geom	geom/OCC geom/facet geom/parallel geom/virtual itaps
    tautges at mcs.anl.gov
    Wed Aug 19 15:44:42 CDT 2009
Cool. I'm assuming Jasons on board with these changes, check with him
to make sure if you haven't corresponded already.
- tim
On Aug 19, 2009, at 3:06 PM, hongjun at mcs.anl.gov wrote:
> Author: hongjun
> Date: 2009-08-19 15:05:46 -0500 (Wed, 19 Aug 2009)
> New Revision: 3108
> Added:
>   cgm/trunk/geom/parallel/AcisMemFile.hpp
>   cgm/trunk/geom/parallel/CGMParallelComm.cpp
>   cgm/trunk/geom/parallel/CGMParallelComm.hpp
>   cgm/trunk/geom/parallel/CGMProcConfig.cpp
>   cgm/trunk/geom/parallel/CGMProcConfig.hpp
>   cgm/trunk/geom/parallel/FileOptions.cpp
>   cgm/trunk/geom/parallel/FileOptions.hpp
>   cgm/trunk/itaps/partest.cpp
> Removed:
> Modified:
>   cgm/trunk/cgm_apps/cgm_cubit_acis/Makefile
>   cgm/trunk/configure.ac
>   cgm/trunk/geom/GeometryQueryEngine.hpp
>   cgm/trunk/geom/GeometryQueryTool.cpp
>   cgm/trunk/geom/GeometryQueryTool.hpp
>   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
>   cgm/trunk/geom/OCC/OCCQueryEngine.hpp
>   cgm/trunk/geom/facet/FacetQueryEngine.cpp
>   cgm/trunk/geom/facet/FacetQueryEngine.hpp
>   cgm/trunk/geom/parallel/Makefile.am
>   cgm/trunk/geom/parallel/ParallelGeomTool.cpp
>   cgm/trunk/geom/parallel/ParallelGeomTool.hpp
>   cgm/trunk/geom/virtual/VirtualQueryEngine.cpp
>   cgm/trunk/geom/virtual/VirtualQueryEngine.hpp
>   cgm/trunk/itaps/CATag.hpp
>   cgm/trunk/itaps/Makefile.am
>   cgm/trunk/itaps/iGeom_CGMA.cc
> Log:
> o Parallel iGeom codes are added and modified.
> o CGMParallelComm.*pp, FileOptions.*pp, ParallelGeomTool.*pp,
> CGMProcConfig.*pp are added in geom/parallel directory.
> o Binary read and write functions are added in OCCQueryEngine.
> o GeometryQueryTool, GeometryQueryEngine are modified by changing of
> OCCQueryEngine.
> o partest is test file of parallel iGeom
> Modified: cgm/trunk/cgm_apps/cgm_cubit_acis/Makefile
> --- cgm/trunk/cgm_apps/cgm_cubit_acis/Makefile    2009-08-19
> 18:39:01 UTC (rev 3107)
> +++ cgm/trunk/cgm_apps/cgm_cubit_acis/Makefile    2009-08-19
> 20:05:46 UTC (rev 3108)
> @@ -1,22 +1,21 @@
> # CGM_BASE_DIR: base directory below which are geom/ and util/, the
> cgm source
> -CGM_BASE_DIR = ${HOME}/cubit/CGM-10.1
> +CGM_BASE_DIR = ${HOME}/lib/CGM
> # CUBIT_INSTALL_DIR: the installation directory of your cubit
> executable, below
> -# which should be bin/ and libs/ containing libcubiti19.so (in
> bin/) and the acis
> +# which should be bin/ containing libcubiti19.so (in bin/) and other
> # shared libs (in libs/).
> -CUBIT_INSTALL_DIR = /cubit
> +CUBIT_INSTALL_DIR = ${HOME}/cubit-10.2-amd64
> -LFLAGS = -Wl,--unresolved-symbols=ignore-all -Wl,--allow-shlib-
> undefined -Wl,-rpath,${CUBIT_INSTALL_DIR}/bin -Wl,-rpath,$
> {CUBIT_INSTALL_DIR}/libs
> +LFLAGS = -Wl,--unresolved-symbols=ignore-all -Wl,--allow-shlib-
> undefined -Wl,-rpath,${CUBIT_INSTALL_DIR}/bin -Wl,-rpath,${HOME}/lib/
> OpenCASCADE6.3.0/lib
> +include ${CGM_BASE_DIR}/lib/cgm.make
> cgm_cubit_acis_app: main_cubit_acis.o Makefile snippet.o
> -    ${CXX} -o cgm_cubit_acis ${LFLAGS} main_cubit_acis.o snippet.o -
> L${CUBIT_INSTALL_DIR}/bin -L${CUBIT_INSTALL_DIR}/libs \
> -    -lcubiti19 -lacisstep -lxstep -lacisiges -lxiges -
> lSPAXAssemblyRep -lSPAXInterop -lSPAXAcisBase -
> lSPAXDefaultGeometryRep -lSPAXBase -lxacis2k -lxcore2k -lSpaAVis -
> lSpaAWarp -lSpaASurf -lSpaALops -lSpaABlend -lSpaACIS -lSpaBase -
> lcubiti19 -lacisstep -lxstep -lacisiges -lxiges -lSPAXAssemblyRep -
> lSPAXInterop -lSPAXAcisBase -lSPAXDefaultGeometryRep -lSPAXBase -
> lxacis2k -lxcore2k -lSpaAVis -lSpaAWarp -lSpaASurf -lSpaALops -
> +    ${CXX} ${CGM_INCLUDES} -o cgm_cubit_acis ${LFLAGS}
> main_cubit_acis.o snippet.o ${CGM_LIBS_LINK}
> -include ${CGM_BASE_DIR}/include/config.make
> main_cubit_acis.o : Makefile NoAcisQueryEngine.hpp
> NoAcisModifyEngine.hpp
> mcnp_converter.o : mcnp_converter.cpp Makefile NoAcisQueryEngine.hpp
> @@ -25,8 +24,8 @@
>    $(CXX) ${CGM_CXXFLAGS} -g -I. ${CGM_INCLUDES} -o $@ -c $<
> test:
> -    ./cgm_cubit_acis geom.sat
> +    ./cgm_cubit_acis ${HOME}/source/CGM/itaps/testgeom.sat
> .cpp.o:
> -    $(CXX) ${CGM_CXXFLAGS} -g -I. -I${CGM_BASE_DIR}/include -o $@ -
> c $<
> +    $(CXX) ${CGM_CXXFLAGS} -g -I. ${CGM_INCLUDES} -o $@ -c $<
> Modified: cgm/trunk/configure.ac
> --- cgm/trunk/configure.ac    2009-08-19 18:39:01 UTC (rev 3107)
> +++ cgm/trunk/configure.ac    2009-08-19 20:05:46 UTC (rev 3108)
> @@ -281,7 +281,7 @@
> CUBIT_OCC_LIB=
> HAVE_OCC_DEF=
> if test "x$occ_DIR" != "xno"; then
> -  OCC_LIBS="-lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -
> lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -
> lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -
> lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -
> lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF"
> +  OCC_LIBS="-lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -
> lTKSTL -lTKTopAlgo -lTKXSBase -lTKLCAF -lTKBin"
>   CUBIT_OCC_LIB="-lcubit_OCC"
>   # Set OCC_INC_FLAG and OCC_LIB_FLAG based on --with-occ option
> Modified: cgm/trunk/geom/GeometryQueryEngine.hpp
> --- cgm/trunk/geom/GeometryQueryEngine.hpp    2009-08-19 18:39:01
> UTC (rev 3107)
> +++ cgm/trunk/geom/GeometryQueryEngine.hpp    2009-08-19 20:05:46
> UTC (rev 3108)
> @@ -49,6 +49,13 @@
>                                    const char* file_type,
>                                    const CubitString &cubit_version,
>                                    const char* logfile_name = NULL )
> = 0;
> +      virtual CubitStatus export_solid_model(
> +                                   DLIList<TopologyBridge*>&
> bridge_list,
> +                   char*& p_buffer,
> +                   int& n_buffer_size,
> +                   bool b_export_buffer) = 0;
>      //R CubitStatus
>      //R- CUBIT_SUCCESS/CUBIT_FAILURE
>      //I ref_entity_list
> @@ -101,6 +108,11 @@
>                                 bool import_vertices = true,
>                                 bool free_surfaces = true
>                                          ) = 0;
> +     virtual CubitStatus import_solid_model
> (DLIList<TopologyBridge*> &imported_entities,
> +                        const char* pBuffer,
> +                        const int n_buffer_size) = 0;
>      //R CubitStatus
>      //I file_ptr
> Modified: cgm/trunk/geom/GeometryQueryTool.cpp
> --- cgm/trunk/geom/GeometryQueryTool.cpp    2009-08-19 18:39:01 UTC
> (rev 3107)
> +++ cgm/trunk/geom/GeometryQueryTool.cpp    2009-08-19 20:05:46 UTC
> (rev 3108)
> @@ -507,6 +507,32 @@
>   return result;
> +CubitStatus GeometryQueryTool::export_solid_model
> (DLIList<RefEntity*>& ref_entity_list,
> +                          char*& p_buffer,
> +  // Get TopologyBridges from RefEntities.
> +  DLIList<TopologyBridge*> bridge_list(ref_entity_list.size()),
> ref_ent_bridges;
> +  ref_entity_list.reset();
> +  for( int i = ref_entity_list.size(); i--; )
> +    ref_ent_bridges.clean_out();
> +    TopologyEntity* topo_ptr = dynamic_cast<TopologyEntity*>
> (ref_entity_list.get_and_step());
> +    if( topo_ptr )
> +      topo_ptr->bridge_manager()->get_bridge_list( ref_ent_bridges );
> +    bridge_list += ref_ent_bridges;
> +  bridge_list.reset();
> +  GeometryQueryEngine *gqe = bridge_list.get()-
> >get_geometry_query_engine();
> +  CubitStatus result = gqe->export_solid_model(bridge_list, p_buffer,
> +                           n_buffer_size, b_export_buffer);
> +  return result;
> // Purpose       : Fire a ray and see which entities it hits
> @@ -642,6 +668,35 @@
>   return status;
> +CubitStatus GeometryQueryTool::import_solid_model
> (DLIList<RefEntity*> *imported_entities,
> +  if (0 == gqeList.size()) {
> +    PRINT_WARNING("No active geometry engine.\n");
> +    return CUBIT_FAILURE;
> +  // Use the default MQE to import a list of ToplogyBridges from
> the file.
> +  gqeList.reset();
> +  DLIList<TopologyBridge*> bridge_list;
> +  CubitStatus status;
> +  for (int i = 0; i < gqeList.size(); i++)
> +    status = gqeList.get_and_step()->import_solid_model
> ( bridge_list, pBuffer, n_buffer_size );
> +    if (bridge_list.size() > 0) break;
> +  if (bridge_list.size() == 0) return status;
> +  status = construct_refentities(bridge_list, imported_entities);
> +  // now return
> +  return status;
> CubitStatus GeometryQueryTool::construct_refentities
> (DLIList<TopologyBridge*> &bridge_list,
> DLIList<RefEntity*> *imported_entities)
> Modified: cgm/trunk/geom/GeometryQueryTool.hpp
> --- cgm/trunk/geom/GeometryQueryTool.hpp    2009-08-19 18:39:01 UTC
> (rev 3107)
> +++ cgm/trunk/geom/GeometryQueryTool.hpp    2009-08-19 20:05:46 UTC
> (rev 3108)
> @@ -254,6 +254,11 @@
> +  CubitStatus export_solid_model(DLIList<RefEntity*>&
> ref_entity_list,
> +                 char*& p_buffer,
> +                 bool b_export_buffer);
>   CubitStatus import_solid_model(const char* file_name,
>                                  const char* logfile_name = NULL,
> @@ -264,6 +269,7 @@
>                                  CubitBoolean import_vertices =
> CUBIT_TRUE,
>                                  CubitBoolean free_surfaces =
> CUBIT_TRUE,
>                 DLIList<RefEntity*> *imported_entities = NULL);
>    * Import all or specified entities in a solid model file.
>     *  \arg file_ptr
> @@ -294,6 +300,11 @@
>     *  CUBIT_SUCCESS if everything goes well.
> +  // import entities in a solid model buffer
> +  CubitStatus import_solid_model(DLIList<RefEntity*>
> *imported_entities,
> +                 const int n_buffer_size);
>   CubitStatus construct_refentities(DLIList<TopologyBridge*>
> &topology_bridges,
>                                     DLIList<RefEntity*>
>     //- given a list of TB's, construct ref entities for them; if
> the 2nd list pointer is
> Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
> --- cgm/trunk/geom/OCC/OCCQueryEngine.cpp    2009-08-19 18:39:01 UTC
> (rev 3107)
> +++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp    2009-08-19 20:05:46 UTC
> (rev 3108)
> @@ -14,6 +14,9 @@
> #include <Standard_Stream.hxx>
> +//#include <Standard_SStream.hxx>
> +//#include <Standard_String.hxx>
> +//#include <stringbuf>
> #include "BRep_Tool.hxx"
> #include "gp_Pnt.hxx"
> #include "gp_Ax1.hxx"
> @@ -24,6 +27,7 @@
> #include "BRepBuilderAPI_Transform.hxx"
> #include "BRepBuilderAPI_MakeSolid.hxx"
> #include "OCCShapeAttributeSet.hpp"
> +//#include "OCCBinToolsShapeSet.hpp"
> #include "BRepBuilderAPI_MakeShell.hxx"
> #include "GProp_GProps.hxx"
> #include "BRepGProp.hxx"
> @@ -110,6 +114,7 @@
> #include <BRepAdaptor_Surface.hxx>
> #include <TDataStd_Shape.hxx>
> #include <TDF_ChildIterator.hxx>
> +#include <BinTools_ShapeSet.hxx>
> #include "Standard_Boolean.hxx"
> #include "TDF_Label.hxx"
> @@ -975,6 +980,123 @@
>   return CUBIT_SUCCESS;
> +CubitStatus OCCQueryEngine::export_solid_model
> ( DLIList<TopologyBridge*>& ref_entity_list,
> +                        char*& p_buffer,
> +  DLIList<OCCBody*>    OCC_bodies;
> +  DLIList<OCCSurface*> OCC_surfaces;
> +  DLIList<OCCCurve*>   OCC_curves;
> +  DLIList<OCCPoint*>   OCC_points;
> +  DLIList<TopologyBridge*> ref_entities_handled;
> +  int i;
> +  //Collect all free entities (bodies, curves, vertices )
> +  for(i=ref_entity_list.size(); i>0; i--)
> +      TopologyBridge* ref_entity_ptr = ref_entity_list.get();
> +      CubitBoolean handled = CUBIT_TRUE;
> +      //if it is a Vertex
> +      if( OCCPoint* pt = CAST_TO( ref_entity_ptr, OCCPoint) )
> +    OCC_points.append( pt );
> +      //if it is a Curve
> +      else if( OCCCurve* curve = CAST_TO( ref_entity_ptr, OCCCurve) )
> +    OCC_curves.append( curve );
> +      //if it is a surface
> +      else if( OCCSurface* surf = CAST_TO( ref_entity_ptr,
> OCCSurface) )
> +    OCC_surfaces.append( surf );
> +      //if it is a Body
> +      else if( OCCBody* body = CAST_TO( ref_entity_ptr, OCCBody ) )
> +    OCC_bodies.append( body );
> +      else
> +    handled = CUBIT_FALSE;
> +      if( handled == CUBIT_TRUE )
> +      ref_entities_handled.append( ref_entity_ptr );
> +      ref_entity_list.change_to(NULL);
> +      ref_entity_list.step();
> +  ref_entity_list.remove_all_with_value(NULL);
> +  int free_body_count = OCC_bodies.size();
> +  int free_curve_count = OCC_curves.size();
> +  int free_point_count = OCC_points.size();
> +  int free_surface_count = OCC_surfaces.size();
> +  //if nothing to write out...return
> +  if( free_body_count == 0 && free_surface_count == 0 &&
> +      free_curve_count == 0 && free_point_count == 0)
> +    return CUBIT_SUCCESS;
> +  //save the facets (geometry info )
> +  //write out topology and attributes
> +  status = write_topology( p_buffer, n_buffer_size,
> +               b_export_buffer,
> +               OCC_bodies, OCC_surfaces,
> +               OCC_curves, OCC_points);
> +  if( status == CUBIT_FAILURE ) return CUBIT_FAILURE;
> +  if( free_body_count || free_surface_count ||
> +      free_curve_count || free_point_count )
> +    if (b_export_buffer) PRINT_INFO( "\nExported:" );
> +    else PRINT_INFO( "\nSize checked:" );
> +  int flg = 0;
> +  if( free_body_count )
> +      if( flg )PRINT_INFO( "         " );else flg=1;
> +      if( free_body_count == 1 )
> +         PRINT_INFO( "%4d OCC Body to buffer\n", free_body_count );
> +      else
> +         PRINT_INFO( "%4d OCC Bodies to buffer\n", free_body_count );
> +  if( free_surface_count )
> +      if( free_surface_count == 1 )
> +    PRINT_INFO( "%4d OCC Surface to buffer\n", free_surface_count );
> +      else
> +  if( free_curve_count )
> +      if( free_curve_count == 1 )
> +    PRINT_INFO( "%4d OCC Curve to buffer\n", free_curve_count );
> +      else
> +    PRINT_INFO( "%4d OCC Curves to buffer\n", free_curve_count );
> +  if( free_point_count )
> +      if( free_point_count == 1 )
> +    PRINT_INFO( "%4d OCC Point to buffer\n", free_point_count );
> +      else
> +    PRINT_INFO( "%4d OCC Points to buffer\n", free_point_count );
> +  PRINT_INFO( "\n" );
> //Function Name:export_solid_model
> //Member Type:  PUBLIC
> @@ -1101,7 +1223,288 @@
> +CubitStatus
> +OCCQueryEngine::write_topology( //const unsigned char* p_buffer,
> +                   //char* p_buffer,
> +                   ofstream& os,
> +                DLIList<OCCBody*> &OCC_bodies,
> +                DLIList<OCCSurface*> &OCC_surfaces,
> +                DLIList<OCCCurve*> &OCC_curves,
> +                DLIList<OCCPoint*> &OCC_points)
> +  int i;
> +  //Create a compound shape to export
> +  BRep_Builder B;
> +  TopoDS_Compound Co;
> +  B.MakeCompound(Co);
> +  //Add every shape to the compound
> +  for (i = 0; i < OCC_bodies.size(); i++)
> +      OCCBody* body = OCC_bodies.get_and_step();
> +      TopoDS_CompSolid *shape = body->get_TopoDS_Shape();
> +      if (shape == NULL) //sheet body or shell body
> +         OCCSurface* surface = body->my_sheet_surface();
> +         OCCShell* shell = body->shell();
> +         if (surface == NULL && shell == NULL)
> +       PRINT_ERROR( "Wrong body structure. Internal ERROR\n" );
> +       continue;
> +         if(surface)
> +           B.Add(Co,*(surface->get_TopoDS_Face()));
> +         else
> +           B.Add(Co,*(shell->get_TopoDS_Shell()));
> +         continue;
> +      //check if this body is build backwards from lump. if so,
> +      //the body and its CompSolid doesn't have bounded relationship
> +      //established. In this case, each individual lump of the body
> +      // will be exported as TopoDS_Solid without a CompSolid
> +      if(OCCMap->IsBound(*shape))
> +    B.Add(Co, *shape);
> +      else
> +      DLIList<Lump*> lumps = body->lumps();
> +      for(int i = 0; i < lumps.size(); i++)
> +          OCCLump *occ_lump = (OCCLump *) lumps.get_and_step();
> +              TopoDS_Solid solid = *(occ_lump->get_TopoDS_Solid());
> +          B.Add(Co, solid);
> +  for (i = 0; i < OCC_surfaces.size(); i++)
> +      TopoDS_Face *face = OCC_surfaces.get_and_step()-
> >get_TopoDS_Face();
> +      B.Add(Co, *face);
> +  //Add standalone wires to the export BRep file
> +  for (i = 0; i < WireList->size(); i++)
> +      TopoDS_Wire *wire = WireList->get_and_step()->get_TopoDS_Wire
> +      B.Add(Co, *wire);
> +  for (i = 0; i < OCC_curves.size(); i++)
> +      TopoDS_Edge *edge = OCC_curves.get_and_step()->get_TopoDS_Edge
> +      B.Add(Co, *edge);
> +  for (i = 0; i < OCC_points.size(); i++)
> +      TopoDS_Vertex *vertex = OCC_points.get_and_step()-
> >get_TopoDS_Vertex();
> +      B.Add(Co, *vertex);
> +  //if(strcmp(file_type, "OCC") == 0)
> +    TDF_Label label;
> +    if(EXPORT_ATTRIB)
> +      label = mainLabel;
> +    if(!Write(Co, os))
> +CubitStatus
> +                   std::ostringstream& os,
> +  int i;
> +  BRep_Builder B;
> +       continue;
> +         if(surface)
> +         else
> +         continue;
> +      else
> +          B.Add(Co, solid);
> >get_TopoDS_Face();
> +      B.Add(Co, *face);
> +      B.Add(Co, *wire);
> +      B.Add(Co, *edge);
> +    TDF_Label label;
> +    if(EXPORT_ATTRIB)
> +CubitStatus
> +OCCQueryEngine::write_topology( char*& p_buffer,
> +                bool b_export_buffer,
> +  int i;
> +  BRep_Builder B;
> +       continue;
> +         if(surface)
> +         else
> +         continue;
> +      else
> +          B.Add(Co, solid);
> >get_TopoDS_Face();
> +      B.Add(Co, *face);
> +      B.Add(Co, *wire);
> +      B.Add(Co, *edge);
> +    TDF_Label label;
> +    if(EXPORT_ATTRIB)
> +    if(!Write(Co, p_buffer, n_buffer_size, b_export_buffer))
> CubitBoolean OCCQueryEngine::Write(const TopoDS_Shape& Sh,
>                                    const Standard_CString File,
>                                    TDF_Label label)
> @@ -1129,7 +1532,200 @@
>   return isGood;
> +CubitBoolean OCCQueryEngine::Write(const TopoDS_Shape& Sh,
> +                   //const unsigned char* pbuffer,
> +                   //streambuf* rpsbuf)
> +                   //char* pbuffer,
> +                   //TDF_Label label)
> +                   std::ofstream& os)
> +  os.open("test.txt", std::ios::out);
> +  std::filebuf* pbuf_os = os.rdbuf();
> +  if (!pbuf_os->is_open()) return Standard_False;
> +  CubitBoolean isGood = (os.good() && !os.eof());
> +  if (!isGood) return isGood;
> +  long os_size1 = pbuf_os->pubseekoff(0, std::ios_base::end,
> std::ios::out);
> +  std::cout << "size os1 = " << os_size1 << std::endl;
> +  BinTools_ShapeSet SS;
> +  SS.Add(Sh);
> +  isGood = os.good();
> +  SS.Write(os);
> +  //std::streamsize size = pbuf->in_avail();
> +  long os_size = pbuf_os->pubseekoff(0, std::ios_base::end,
> std::ios::out);
> +  std::cout << "size os2 = " << os_size << std::endl;
> +  char* buffer = new char[os_size];
> +  //os.write(buffer, os_size);
> +  //pbuf_os->sputn(buffer, os_size);
> +  //memcpy(buffer, pbuf_os, os_size);
> +  return CUBIT_TRUE;
> +                   std::ostringstream& os)
> +  std::stringbuf* pbuf = os.rdbuf();
> +  std::streamsize ssize = pbuf->in_avail();
> +  long size = pbuf->pubseekoff(0, std::ios_base::end, std::ios::out);
> +  std::cout << "size os1 = " << size << " " << ssize << std::endl;
> +  SS.Add(Sh);
> +  SS.Write(os);
> +  ssize = pbuf->in_avail();
> +  size = pbuf->pubseekoff(0, std::ios_base::end, std::ios::out);
> +  std::cout << "size os2 = " << size << " " << ssize << std::endl;
> +  char* buffer = new char[size];
> +  pbuf->sputn(buffer, size);
> +  std::istringstream is;
> +  pbuf = is.rdbuf();
> +  size = pbuf->pubseekoff(0, std::ios_base::end, std::ios::in);
> +  std::cout << "size io1 = " << size << " " << ssize << std::endl;
> +  //is.tie(&os);
> +  //is.read(buffer, size1);
> +  pbuf->pubseekpos(0, std::ios::in);
> +  pbuf->sgetn(buffer, size);
> +  size = is.rdbuf()->pubseekoff(0, std::ios_base::end, std::ios::in);
> +  std::cout << "size io2 = " << size << " " << ssize << std::endl;
> +  pbuf->pubsetbuf(buffer, size);
> +  std::cout << "size io3 = " << size << " " << ssize << std::endl;
> +  BinTools_ShapeSet SS2;
> +  SS2.Read(is);
> +  int nShape = SS2.NbShapes();
> +  std::cout << "nShpae = %d" << nShape << std::endl;
> +  // test
> +  std::ostringstream oss("test");
> +  pbuf = oss.rdbuf();
> +  std::cout << "test size os1 = " << size << " " << ssize <<
> std::endl;
> +  char* tbuffer = new char[size];
> +  //pbuf->sputn(tbuffer, size);
> +  ssize = pbuf->sgetn(tbuffer, size);
> +  std::istringstream iss;
> +  pbuf = iss.rdbuf();
> +  //ssize = pbuf->in_avail();
> +  std::cout << "test size io1 = " << size << " " << ssize <<
> std::endl;
> +  //is.tie(&os);
> +  //pbuf->sgetn(tbuffer, size);
> +  //ssize = pbuf->sputn(tbuffer, size);
> +  pbuf->pubsetbuf(tbuffer, size);
> +  size = iss.rdbuf()->pubseekoff(0, std::ios_base::end,
> std::ios::in);
> +  std::cout << "test size io2 = " << size << " " << ssize <<
> std::endl;
> std::ios::in);
> +  std::cout << "test size io3 = " << size << " " << ssize <<
> std::endl;
> +  std::stringstream ssos("test2");
> +  ssize = ssos.rdbuf()->in_avail();
> +  size = ssos.rdbuf()->pubseekoff(0, std::ios_base::end,
> std::ios::in);
> +  std::cout << "test size os4 = " << size << " " << ssize <<
> std::endl;
> +  std::string mystr = ssos.rdbuf()->str();
> +  std::stringstream ssis(mystr);
> +  ssize = ssis.rdbuf()->in_avail();
> +  size = ssis.rdbuf()->pubseekoff(0, std::ios_base::end,
> std::ios::in);
> +  std::cout << "test size is4 = " << size << " " << ssize <<
> std::endl;
> +  std::stringbuf sbos;
> +  std::stringbuf sbis;
> +  std::iostream tos(&sbos);
> +  std::iostream tis(&sbis);
> +  BinTools_ShapeSet tSS1;
> +  tSS1.Add(Sh);
> +  isGood = tos.good();
> +  std::cout << "isGood=" << isGood << std::endl;
> +  tSS1.Write(tos);
> +  size = tos.rdbuf()->pubseekoff(0, std::ios_base::end,
> std::ios::out);
> +  std::cout << "test fos size = " << size << std::endl;
> +  char* tbuffer1 = new char[size];
> +  tos.read(tbuffer1, size);
> +  tis.write(tbuffer1, size);
> +  BinTools_ShapeSet tSS2;
> +  tSS2.Read(tis);
> +  isGood = tis.good();
> +  nShape = tSS2.NbShapes();
> +  std::cout << "test nShpae = " << nShape << std::endl;
> +                   char*& pBuffer,
> +                   bool b_write_buffer)
> +  std::stringbuf sb;
> +  std::iostream os(&sb);
> +  SS.Add(Sh);
> +  CubitBoolean isGood = os.good();
> +  //std::cout << "isGood=" << isGood << std::endl;
> +  SS.Write(os);
> +  n_buffer_size = os.rdbuf()->pubseekoff(0, std::ios_base::end,
> std::ios::out);
> +  //std::cout << "test fos size = " << n_buffer_size
> +  //  << " nShape= " << SS.NbShapes() << std::endl;
> +  if (b_write_buffer) {
> +    //delete pBuffer;
> +    //pBuffer = new char[n_buffer_size];
> +    os.read(pBuffer, n_buffer_size);
> CubitBoolean OCCQueryEngine::Read(TopoDS_Shape& Sh,
> @@ -1150,7 +1746,65 @@
>   SS.Read(Sh,in,nbshapes, &label);
>   return CUBIT_TRUE;
> +CubitBoolean OCCQueryEngine::Read(TopoDS_Shape& Sh,
> +  std::iostream is(&sb);
> +  is.write(pBuffer, n_buffer_size);
> +  SS.Read(is);
> +  CubitBoolean isGood = is.good();
> +  int nShape = SS.NbShapes();
> +  if (!nShape) return CUBIT_FALSE;
> +  //Sh = SS.TopoDS_Shape();
> +  //SS.Read(Sh, is, nShape);
> +  //TDF_Label label;
> +  //CubitBoolean print_results = false;
> +  //OCCBinToolsShapeSet SS;
> +  SS.Read(is);
> +  int nbshapes = SS.NbShapes();
> +  if (!nbshapes) return CUBIT_FALSE;
> +  //TopoDS_Shape fs = SS.Shape(1);
> +  //TopoDS_Shape ls = SS.Shape(nbshapes);
> +  /* for (int i = 1; i <= nbshapes; i++) {
> +    TopoDS_Shape s = SS.Shape(i);
> +    std::cout << "shape type" << i << "=" << s.ShapeType() <<
> std::endl;
> +  //SS.Read(Sh, is, nbshapes);
> +  Sh = SS.Shape(nbshapes);
> +  //is.seekg (0, std::ios::beg);
> +  //do {
> +    //if (!Sh.IsNull()) {
> +      //AddShapes(S,SS);
> +      //break;
> +  //} while(!Sh.IsNull());
> +  BRep_Builder B;
> +  for (int i = 1; i <= nShape; i++) {
> +    B.Add(Co, SS.Shape(i));
> +  Sh = Co;
> CubitStatus
> OCCQueryEngine::import_temp_geom_file(FILE* file_ptr,
> @@ -1224,6 +1878,18 @@
> +CubitStatus OCCQueryEngine::import_solid_model
> +  TopoDS_Shape *aShape = new TopoDS_Shape;
> +  Standard_Boolean result = Read(*aShape, pBuffer, n_buffer_size);
> +  if (result==0) return CUBIT_FAILURE;
> +  imported_entities = populate_topology_bridge(*aShape);
> //Function Name:populate_topology_bridge
> Modified: cgm/trunk/geom/OCC/OCCQueryEngine.hpp
> --- cgm/trunk/geom/OCC/OCCQueryEngine.hpp    2009-08-19 18:39:01 UTC
> (rev 3107)
> +++ cgm/trunk/geom/OCC/OCCQueryEngine.hpp    2009-08-19 20:05:46 UTC
> (rev 3108)
> @@ -231,6 +231,12 @@
>                                           const CubitString
> &cubit_version,
> NULL );
> +  // write shapes to buffer as binary format
> +  virtual CubitStatus export_solid_model( DLIList<TopologyBridge*>&
> ref_entity_list,
> +                      char*& p_buffer,
>   virtual CubitStatus save_temp_geom_file( DLIList<TopologyBridge*>&
> ref_entity_list,
>                                           const char *file_name,
>                                           const CubitString
> &cubit_version,
> @@ -254,6 +260,10 @@
>                                          CubitBoolean
> import_vertices = CUBIT_TRUE,
> = CUBIT_TRUE );
> +  virtual CubitStatus import_solid_model(DLIList<TopologyBridge*>
> &imported_entities,
>   CubitStatus unhook_BodySM_from_OCC( BodySM* bodysm)const;
>   CubitStatus unhook_Surface_from_OCC( Surface* surface) const;
>   CubitStatus unhook_Curve_from_OCC( Curve* curve) const;
> @@ -387,15 +397,32 @@
>                               DLIList<OCCCurve*> &facet_curves,
>                               DLIList<OCCPoint*> &facet_points );
> +  CubitStatus write_topology( char*& p_buffer,
> +                  DLIList<OCCPoint*> &OCC_points);
>   CubitBoolean Write(const TopoDS_Shape& Sh,
>                      TDF_Label label);
> +  CubitBoolean Write(const TopoDS_Shape& Sh,
> +             char*& p_buffer,
>   CubitBoolean Read(TopoDS_Shape& Sh,
>                     TDF_Label label,
>                     bool print_results);
> +  CubitBoolean Read(TopoDS_Shape& Sh,
>   static OCCQueryEngine* instance_;
>     //- static pointer to unique instance of this class
> Modified: cgm/trunk/geom/facet/FacetQueryEngine.cpp
> --- cgm/trunk/geom/facet/FacetQueryEngine.cpp    2009-08-19 18:39:01
> UTC (rev 3107)
> +++ cgm/trunk/geom/facet/FacetQueryEngine.cpp    2009-08-19 20:05:46
> UTC (rev 3108)
> @@ -849,6 +849,14 @@
> +CubitStatus FacetQueryEngine::export_solid_model
> ( DLIList<TopologyBridge*>& bridge_list,
> +                          char*& p_buffer,
> CubitStatus
> FacetQueryEngine::gather_all_facet_entities( DLIList<FacetBody*>
> &facet_bodies,
>                                              DLIList<FacetLump*>
> &facet_lumps,
> @@ -1790,13 +1798,13 @@
>     PRINT_ERROR("Trouble reading in file type for MBG\n");
>   if( strncmp( fileType, "MESH_BASED_GEOMETRY", 19 ) )
>     PRINT_ERROR("Not MESH_BASED_GEOMETRY file type\n");
>   // read in the endian value
>   NCubitFile::CIOWrapper file_reader(file_ptr, 19, 0);
> @@ -1838,6 +1846,12 @@
> +CubitStatus FacetQueryEngine::import_solid_model
> // Function   : restore_facets
> Modified: cgm/trunk/geom/facet/FacetQueryEngine.hpp
> --- cgm/trunk/geom/facet/FacetQueryEngine.hpp    2009-08-19 18:39:01
> UTC (rev 3107)
> +++ cgm/trunk/geom/facet/FacetQueryEngine.hpp    2009-08-19 20:05:46
> UTC (rev 3108)
> @@ -270,6 +270,11 @@
>                                           const CubitString
> &cubit_version,
> NULL );
> bridge_list,
> +                      char*& p_buffer,
> ref_entity_list,
>                                           const CubitString
> &cubit_version,
> @@ -292,7 +297,11 @@
>                                          CubitBoolean import_curves
> = CUBIT_TRUE,
>                                          CubitBoolean
> = CUBIT_TRUE );
> -private:
> &imported_entities,
> +    private:
>   CubitStatus import_solid_model(FILE *file_ptr,
>                                  const char* /*file_type*/,
> &imported_entities,
> Deleted: cgm/trunk/geom/parallel/AcisMemFile.hpp
> --- cgm/trunk/geom/parallel/AcisMemFile.hpp    2009-08-19 18:39:01
> UTC (rev 3107)
> +++ cgm/trunk/geom/parallel/AcisMemFile.hpp    2009-08-19 20:05:46
> UTC (rev 3108)
> @@ -1,144 +0,0 @@
> -#ifndef ACISMEMFILE
> -#define ACISMEMFILE
> -// Define the AcisMemFile class for doing ACIS save and restore to
> a memory
> -// buffer.  This file is intended as an example of how to create a
> new
> -// ACIS FileInterface object.
> -// This class is used to store ACIS-specific geometry in a memory
> file;
> -// generic memory file functions are implemented in CGMMemFile;
> ACIS-specific
> -// functions for gathering ACIS geometry and putting it in a memory
> buffer
> -// is implemented in AcisMemFile and in the ACIS BinaryFile class.
> -// There is also a FileSizeComputer class.  This can be used to
> determine
> -// how many bytes a list of entities will use when saved.
> -#if CUBIT_ACIS_VERSION < 1100
> -#include "kernel/kernutil/fileio/binfile.hxx"
> -#else
> -#include "binfile.hxx"
> -#endif
> -#include "CGMMemFile.hpp"
> -#include "DLIList.hpp"
> -class AcisQueryEngine;
> -class RefEntity;
> -class ENTITY_LIST;
> -class AcisMemFile : public BinaryFile,
> -                    public CGMMemFile
> -public:
> -  AcisMemFile(AcisQueryEngine *aqe) {acisQueryEngine = aqe;};
> -    //- (empty) constructor
> -  virtual ~AcisMemFile() {};
> -    //- (empty) destructor
> -  virtual FilePosition set_mark();
> -    //- The methods for positioning the file pointer must also be
> -    //- implemented for each derived class.  These are not normally
> -    //- used.
> -  virtual FilePosition goto_mark(FilePosition);
> -    //- used.
> -  size_t BytesWritten() { return (size_t)m_currentPosition; }
> -    //- Get the number of bytes written
> -protected:
> -  CubitStatus read_refentity_list(DLIList<RefEntity*>
> &ref_entity_list);
> -    //- read a RefEntity list from the buffer into ref_entity_list;
> relies on engine-
> -    //- specific implementation
> -  CubitStatus write_refentity_list(DLIList<RefEntity*>
> &ref_entity_list);
> -    //- write a RefEntity list to the buffer from ref_entity_list;
> relies on engine-
> -  CubitStatus append_refentity_list(DLIList<RefEntity*>
> &ref_entity_list,
> -                                    int &buffer_size);
> -  CubitStatus get_refentity_list(DLIList<RefEntity*>
> &ref_entity_list);
> -  virtual int get_refentity_list_size(DLIList<RefEntity*>
> ref_entity_list);
> -  //- get a the size of entities
> -  virtual size_t read(void* buf, size_t length, logical swap);
> -    //- ACIS-dependent function to read data from a buffer
> -  virtual void write(const void* data, size_t len, logical swap);
> -    //- ACIS-dependent function to write data to a buffer
> -private:
> -  size_t write_memory_buffer(ENTITY_LIST &entity_list);
> -    //- write ACIS entity list to memory buffer
> -  size_t append_memory_buffer(ENTITY_LIST &entity_list,
> -  //unsigned char* get_memory_buffer(ENTITY_LIST &entity_list);
> -  int get_memory_buffer_size(ENTITY_LIST entity_list);
> -    //- get a the size of entities in memory buffer
> -  size_t read_memory_buffer(ENTITY_LIST &entity_list);
> -    // read ACIS entity list from memory buffer
> -  size_t scatter_memory_buffer(ENTITY_LIST &entity_list,
> -                                          int *buffer_sizes);
> -  AcisQueryEngine *acisQueryEngine;
> -    //- for convenience
> -// This class can be used to compute how many bytes will be required
> -// to save a list of entities in binary format.  The following
> example
> -// shows how it can be used:
> -// ENTITY_LIST elist;
> -// ... add entities you want saved to the list
> -// FileSizeComputer fsc;
> -// outcome result = api_save_entity_list_file(&fsc, elist);
> -// if(result.ok()) {
> -//    unsigned long bytesNeeded = sc.GetSize();
> -class FileSizeComputer : public BinaryFile {
> -private:
> -  size_t m_bytesNeeded;
> -  int num_writes; // number of calls to write function
> -protected:
> -    // These are the virtual methods which actually do the reading
> -    // and writing of the data.
> -    // Read doesn't really do anything.
> -public:
> -    // The methods for positioning the file pointer must also be
> -    // implemented for each derived class.  These do not do
> -    // anything in this class
> -public:
> -  FileSizeComputer();
> -  virtual ~FileSizeComputer();
> -  size_t GetSize();
> -  int GetWrites();
> -#endif
> Added: cgm/trunk/geom/parallel/AcisMemFile.hpp
> AcisMemFile.hpp                            (rev 0)
> UTC (rev 3108)
> @@ -0,0 +1,144 @@
> +#ifndef ACISMEMFILE
> +#define ACISMEMFILE
> +// Define the AcisMemFile class for doing ACIS save and restore to
> a memory
> +// buffer.  This file is intended as an example of how to create a
> new
> +// ACIS FileInterface object.
> +// This class is used to store ACIS-specific geometry in a memory
> file;
> +// generic memory file functions are implemented in CGMMemFile;
> ACIS-specific
> +// functions for gathering ACIS geometry and putting it in a memory
> buffer
> +// is implemented in AcisMemFile and in the ACIS BinaryFile class.
> +// There is also a FileSizeComputer class.  This can be used to
> determine
> +// how many bytes a list of entities will use when saved.
> +#if CUBIT_ACIS_VERSION < 1100
> +#include "kernel/kernutil/fileio/binfile.hxx"
> +#else
> +#include "binfile.hxx"
> +#endif
> +#include "CGMMemFile.hpp"
> +#include "DLIList.hpp"
> +class AcisQueryEngine;
> +class RefEntity;
> +class ENTITY_LIST;
> +class AcisMemFile : public BinaryFile,
> +                    public CGMMemFile
> +public:
> +  AcisMemFile(AcisQueryEngine *aqe) {acisQueryEngine = aqe;};
> +    //- (empty) constructor
> +  virtual ~AcisMemFile() {};
> +    //- (empty) destructor
> +  virtual FilePosition set_mark();
> +    //- The methods for positioning the file pointer must also be
> +    //- implemented for each derived class.  These are not normally
> +    //- used.
> +  virtual FilePosition goto_mark(FilePosition);
> +    //- used.
> +  size_t BytesWritten() { return (size_t)m_currentPosition; }
> +    //- Get the number of bytes written
> +protected:
> +  CubitStatus read_refentity_list(DLIList<RefEntity*>
> &ref_entity_list);
> +    //- read a RefEntity list from the buffer into ref_entity_list;
> relies on engine-
> +    //- specific implementation
> +  CubitStatus write_refentity_list(DLIList<RefEntity*>
> &ref_entity_list);
> +    //- write a RefEntity list to the buffer from ref_entity_list;
> relies on engine-
> +  CubitStatus append_refentity_list(DLIList<RefEntity*>
> &ref_entity_list,
> +                                    int &buffer_size);
> +  CubitStatus get_refentity_list(DLIList<RefEntity*>
> &ref_entity_list);
> +  virtual int get_refentity_list_size(DLIList<RefEntity*>
> ref_entity_list);
> +  //- get a the size of entities
> +  virtual size_t read(void* buf, size_t length, logical swap);
> +    //- ACIS-dependent function to read data from a buffer
> +  virtual void write(const void* data, size_t len, logical swap);
> +    //- ACIS-dependent function to write data to a buffer
> +private:
> +  size_t write_memory_buffer(ENTITY_LIST &entity_list);
> +    //- write ACIS entity list to memory buffer
> +  size_t append_memory_buffer(ENTITY_LIST &entity_list,
> +  //unsigned char* get_memory_buffer(ENTITY_LIST &entity_list);
> +  int get_memory_buffer_size(ENTITY_LIST entity_list);
> +    //- get a the size of entities in memory buffer
> +  size_t read_memory_buffer(ENTITY_LIST &entity_list);
> +    // read ACIS entity list from memory buffer
> +  size_t scatter_memory_buffer(ENTITY_LIST &entity_list,
> +                                          int *buffer_sizes);
> +  AcisQueryEngine *acisQueryEngine;
> +    //- for convenience
> +// This class can be used to compute how many bytes will be required
> +// to save a list of entities in binary format.  The following
> example
> +// shows how it can be used:
> +// ENTITY_LIST elist;
> +// ... add entities you want saved to the list
> +// FileSizeComputer fsc;
> +// outcome result = api_save_entity_list_file(&fsc, elist);
> +// if(result.ok()) {
> +//    unsigned long bytesNeeded = sc.GetSize();
> +class FileSizeComputer : public BinaryFile {
> +private:
> +  size_t m_bytesNeeded;
> +  int num_writes; // number of calls to write function
> +protected:
> +    // These are the virtual methods which actually do the reading
> +    // and writing of the data.
> +    // Read doesn't really do anything.
> +public:
> +    // The methods for positioning the file pointer must also be
> +    // implemented for each derived class.  These do not do
> +    // anything in this class
> +public:
> +  FileSizeComputer();
> +  virtual ~FileSizeComputer();
> +  size_t GetSize();
> +  int GetWrites();
> +#endif
> Property changes on: cgm/trunk/geom/parallel/AcisMemFile.hpp
> ___________________________________________________________________
> Added: svn:executable
> Added: cgm/trunk/geom/parallel/CGMParallelComm.cpp
> CGMParallelComm.cpp                            (rev 0)
> +++ cgm/trunk/geom/parallel/CGMParallelComm.cpp    2009-08-19
> @@ -0,0 +1,421 @@
> +#include "CGMParallelComm.hpp"
> +//#include "CubitAttrib.hpp"
> +//#include "OCCQueryEngine.hpp"
> +#include "TopologyEntity.hpp"
> +#include "GeometryQueryEngine.hpp"
> +#include "RefEntity.hpp"
> +//#include <iostream>
> +#include <sstream>
> +#ifdef USE_MPI
> +#include "mpi.h"
> +#endif
> +#define INITIAL_BUFF_SIZE 1024
> +#define RRA(a) if (CUBIT_SUCCESS != result) {    \
> +    std::string tmp_str;            \
> +    tmp_str.append("\n"); tmp_str.append(a);    \
> +    PRINT_ERROR(tmp_str.c_str());        \
> +    return result;}
> +CGMParallelComm::CGMParallelComm(CGMTagManager *impl,
> +                 MPI_Comm comm, int* id )
> +  : cgmImpl(impl), procConfig(comm)
> +  myBuffer.resize(INITIAL_BUFF_SIZE);
> +  int flag = 1;
> +  int retval = MPI_Initialized(&flag);
> +  if (MPI_SUCCESS != retval || !flag) {
> +    int argc = 0;
> +    char **argv = NULL;
> +    // mpi not initialized yet - initialize here
> +    retval = MPI_Init(&argc, &argv);
> +  pcommID = add_pcomm(this);
> +  if (id)
> +    *id = pcommID;
> +  m_pBuffer = NULL;
> +  m_nBufferSize = 0;
> +  m_currentPosition = 0;
> +                 std::vector<unsigned char> &tmp_buff,
> +                 MPI_Comm comm,
> +                 int* id)
> +  myBuffer.swap(tmp_buff);
> +  int flag = 1;
> +    int argc = 0;
> +  if (id)
> +    *id = pcommID;
> +  m_pBuffer = NULL;
> +CGMParallelComm::~CGMParallelComm()
> +  remove_pcomm(this);
> +  delete m_pBuffer;
> +int CGMParallelComm::add_pcomm(CGMParallelComm *pc)
> +  // add this pcomm to instance tag
> +  std::vector<CGMParallelComm *> pc_array;
> +  pc_array = cgmImpl->get_pc_array();
> +  pc_array.push_back(pc);
> +  return pc_array.size() - 1;
> +void CGMParallelComm::remove_pcomm(CGMParallelComm *pc)
> +  // remove this pcomm from instance tag
> +  std::vector<CGMParallelComm*>::iterator pc_it =
> +    std::find(pc_array.begin(), pc_array.end(), pc);
> +  assert(pc_it != pc_array.end());
> +  pc_array.erase(pc_it);
> +//! get the indexed pcomm object from the interface
> +CGMParallelComm *CGMParallelComm::get_pcomm(CGMTagManager *impl,
> +                        const int index)
> +  pc_array = impl->get_pc_array();
> +  if (pc_array.size() < (unsigned int) (index + 1)) return NULL;
> +  else return pc_array[index];
> +CubitStatus CGMParallelComm::get_all_pcomm(CGMTagManager *impl,
> +                       std::vector<CGMParallelComm*>& list )
> +  list = impl->get_pc_array();
> +                        //MBEntityHandle prtn,
> +                        const MPI_Comm* comm )
> +  //MBErrorCode rval;
> +  CGMParallelComm* result = 0;
> +  //MBTag prtn_tag;
> +  //rval = impl->tag_create( PARTITIONING_PCOMM_TAG_NAME,
> +  //                       sizeof(int),
> +  //                       MB_TAG_SPARSE,
> +  //                       MB_TYPE_INTEGER,
> +  //                       prtn_tag,
> +  //                       0, true );
> +  //if (MB_SUCCESS != rval)
> +  //return 0;
> +  int pcomm_id;
> +  //rval = impl->tag_get_data( prtn_tag, &prtn, 1, &pcomm_id );
> +  //if (MB_SUCCESS == rval) {
> +    result= get_pcomm(impl,
> +              pcomm_id );
> +  else if (MB_TAG_NOT_FOUND == rval && comm) {
> +    result = new MBParallelComm( impl, *comm, &pcomm_id );
> +    if (!result)
> +      return 0;
> +    result->set_partitioning( prtn );
> +    rval = impl->tag_set_data( prtn_tag, &prtn, 1, &pcomm_id );
> +    if (MB_SUCCESS != rval) {
> +      delete result;
> +      result = 0;
> +  return result;
> +CubitStatus CGMParallelComm::bcast_buffer(const unsigned int
> from_proc)
> +  //- broadcasts the buffer contained in this object
> +  if ((int)procConfig.proc_rank() == from_proc) {
> +    PRINT_DEBUG_100("Broadcasting buffer size from %d.\n",
> from_proc);
> +    MPI_Bcast(&m_nBufferSize, 1, MPI_INT, from_proc, MPI_COMM_WORLD);
> +    PRINT_DEBUG_100("Broadcasting buffer from %d, %d bytes.\n",
> from_proc,
> +            m_nBufferSize);
> +    MPI_Bcast(m_pBuffer, m_nBufferSize, MPI_BYTE, from_proc,
> +              MPI_COMM_WORLD);
> +  else {
> +    int this_size;
> +    PRINT_DEBUG_100("Broadcasting buffer size from proc %d.\n",
> +            procConfig.proc_rank());
> +    MPI_Bcast(&this_size, 1, MPI_INT, from_proc,
> +              MPI_COMM_WORLD);
> +    PRINT_DEBUG_100("Processor %d: received size of %d.\n",
> procConfig.proc_rank(), this_size);
> +    check_size(this_size);
> +    PRINT_DEBUG_100("Broadcasting buffer from proc %d, %d bytes.\n",
> +                    procConfig.proc_rank(), this_size);
> +    MPI_Bcast(m_pBuffer, this_size, MPI_BYTE, from_proc,
> +              MPI_COMM_WORLD);
> +CubitStatus CGMParallelComm::broadcast_entities(const unsigned int
> from_proc,
> +                        DLIList<RefEntity*> &ref_entity_list)
> +#ifndef USE_MPI
> +#else
> +  CubitStatus result = CUBIT_SUCCESS;
> +    int nBufferSize = 0;
> +    result = write_buffer(ref_entity_list, m_pBuffer, nBufferSize,
> false);
> +    RRA("Failed to write ref entity list to buffer.");
> +    result = check_size(nBufferSize);
> true);
> +    //m_currentPosition = m_nBufferSize;
> +  result = bcast_buffer(from_proc);
> +  RRA("Failed to broadcast buffer to processors.");
> +  if ((int)procConfig.proc_rank() != from_proc) {
> +    result = read_buffer(ref_entity_list, m_pBuffer, m_nBufferSize);
> +    RRA("Failed to read ref entity list from buffer.");
> +#endif
> +// scatter exact amount of geometry information to each processors
> +CubitStatus CGMParallelComm::scatter_entities(const unsigned int
> from_proc,
> +#ifndef USE_MPI
> +#else
> +  double tScatter;
> +  int mySendCount;
> +  int nEntity;
> +  DLIList<RefEntity*> temp_list, temp_ref_list;
> +  int nProcs = procConfig.proc_size();
> +  int *sendCounts = new int[nProcs];
> +  int *displacements = new int[nProcs];
> +  int nBarEntity;
> +  int restEntity;
> +  int nEndEntity;
> +  displacements[0] = 0;
> +  if (procConfig.proc_rank() == from_proc) {
> +    int curPosition = 0;
> +    nEntity = ref_entity_list.size();
> +    nBarEntity = nEntity/nProcs;
> +    restEntity = nEntity%nProcs;
> +    nEndEntity = nBarEntity + restEntity;
> +    int sum = 0;
> +    // make temporary lists to contain geometry information for
> each processors
> +    for (int i = 0; i < nProcs; i++) {
> +      if (i == from_proc) {
> +    ref_entity_list.step(nBarEntity);
> +    if (i < restEntity) ref_entity_list.step();
> +    sendCounts[i] = 0;
> +      else {
> +    for ( int j = 0; j < nBarEntity; j++) {
> +      RefEntity* body_ptr = ref_entity_list.get_and_step();
> +      temp_list.append(body_ptr);
> +    if (i < restEntity) {
> +    //sendCounts[i] = get_ref_list_buffer_size(temp_list);
> +    result = write_buffer(temp_list, m_pBuffer, sendCounts[i],
> false);
> +    sum += sendCounts[i];
> +    temp_list.clean_out();
> +    // check the size of the buffer and resize if necessary
> +    check_size(sum);
> +    // now append the real information
> +      else {
> +      temp_list.append(ref_entity_list.get_and_step());
> +    append_to_buffer(temp_list, sendCounts[i]);
> +  // broadcast buffer size array
> +  PRINT_DEBUG_100("Broadcasting buffer size array from master.\n");
> +  MPI_Bcast(sendCounts, nProcs, MPI_INT, from_proc, MPI_COMM_WORLD);
> +  for (int i = 1; i < nProcs; i++) {
> +    displacements[i] = displacements[i-1] + sendCounts[i-1];
> +  mySendCount = sendCounts[procConfig.proc_rank()];
> +  if (procConfig.proc_rank() != from_proc) check_size(mySendCount);
> +  PRINT_DEBUG_100("Scattering buffer from master.\n");
> +  // scatter geometry
> +  MPI_Scatterv(m_pBuffer, sendCounts, displacements, MPI_BYTE,
> m_pBuffer,
> +           mySendCount, MPI_BYTE, from_proc, MPI_COMM_WORLD);
> +  if (procConfig.proc_rank() != from_proc) {
> +    result = read_buffer(ref_entity_list, m_pBuffer, mySendCount);
> +#endif
> +CubitStatus CGMParallelComm::write_buffer(DLIList<RefEntity*>
> &ref_entity_list,
> +#ifndef USE_MPI
> +#else
> +  //ofstream os;
> +  //CubitStatus result = GeometryQueryTool::instance()-
> >export_solid_model(ref_entity_list, p_buffer);
> +  CubitStatus result = GeometryQueryTool::instance()-
> >export_solid_model(ref_entity_list, os);
> +  RRA("Failed to compute buffer size in broadcast_entities.");
> +#endif
> &ref_entity_list,
> +#ifndef USE_MPI
> +#else
> +#endif
> &ref_entity_list,
> +                      char* pBuffer,
> +#ifndef USE_MPI
> +#else
> >export_solid_model(ref_entity_list, pBuffer,
> +                                     n_buffer_size, b_write_buffer);
> +  RRA("Failed to write ref entities to buffer.");
> +  if (b_write_buffer) m_currentPosition += n_buffer_size;
> +#endif
> +CubitStatus CGMParallelComm::read_buffer(DLIList<RefEntity*>
> &ref_entity_list,
> +#ifndef USE_MPI
> +#else
> >import_solid_model(&ref_entity_list, pBuffer,
> +                                     n_buffer_size);
> +  RRA("Failed to read ref entities from buffer.");
> +#endif
> +CubitStatus CGMParallelComm::check_size(int& target_size, const
> CubitBoolean keep)
> +  PRINT_DEBUG_100("Checking buffer size on proc %d, target size %d.
> \n",
> +                  procConfig.proc_rank(), target_size);
> +  if (m_nBufferSize < target_size) {
> +    PRINT_DEBUG_100("Increasing buffer size on proc %d.\n",
> +    void *temp_buffer = malloc(target_size);
> +    if (keep && 0 != m_currentPosition) memcpy(temp_buffer,
> m_pBuffer, m_currentPosition);
> +    delete m_pBuffer;
> +    m_pBuffer = (char *) temp_buffer;
> +    m_nBufferSize = target_size;
> +CubitStatus CGMParallelComm::append_to_buffer(DLIList<RefEntity*>
> &ref_entity_list,
> +                          int add_size)
> +  if (m_currentPosition + add_size > m_nBufferSize) return
> CUBIT_FAILURE;
> +  CubitStatus result = write_buffer(ref_entity_list, m_pBuffer +
> m_currentPosition, add_size, true);
> +  RRA("Failed to append ref entity list to buffer.");
> +  //m_currentPosition += add_size;
> Added: cgm/trunk/geom/parallel/CGMParallelComm.hpp
> CGMParallelComm.hpp                            (rev 0)
> +++ cgm/trunk/geom/parallel/CGMParallelComm.hpp    2009-08-19
> @@ -0,0 +1,225 @@
> + * \class CGMParallelComm
> + * \brief Parallel communications in CGM
> + * \author Hong-Jun Kim, copied from MBParallelComm.hpp
> + *  This class implements methods to communicate geometry between
> processors
> +#ifndef CGM_PARALLEL_COMM_HPP
> +#define CGM_PARALLEL_COMM_HPP
> +//#include "CGMForward.hpp"
> +#include "GeometryQueryTool.hpp"
> +//#include "CGMRange.hpp"
> +#include "CGMProcConfig.hpp"
> +#include "CATag.hpp"
> +#include <map>
> +#include <set>
> +#include <vector>
> +#include "math.h"
> +#ifdef SEEK_SET
> +#  define SEEK_SET_OLD SEEK_SET
> +#  undef SEEK_SET
> +#endif
> +#ifdef SEEK_CUR
> +#  define SEEK_CUR_OLD SEEK_CUR
> +#  undef SEEK_CUR
> +#endif
> +#ifdef SEEK_END
> +#  define SEEK_END_OLD SEEK_END
> +#  undef SEEK_END
> +#endif
> +#include "mpi.h"
> +#ifdef SEEK_SET_OLD
> +#  undef SEEK_SET
> +#  define SEEK_SET SEEK_SET_OLD
> +#  undef SEEK_SET_OLD
> +#endif
> +#ifdef SEEK_CUR_OLD
> +#  undef SEEK_CUR
> +#  define SEEK_CUR SEEK_CUR_OLD
> +#  undef SEEK_CUR_OLD
> +#endif
> +#ifdef SEEK_END_OLD
> +#  undef SEEK_END
> +#  define SEEK_END SEEK_END_OLD
> +#  undef SEEK_END_OLD
> +#endif
> +extern "C" {
> +  struct tuple_list;
> +//class TagServer;
> +//class SequenceManager;
> +//template <typename KeyType, typename ValType, ValType NullVal>
> class RangeMap;
> +//typedef RangeMap<CGMEntityHandle, CGMEntityHandle, 0> HandleMap;
> +#define MAX_SHARING_PROCS 64
> +class CGMParallelComm
> +public:
> +    //! constructor
> +  CGMParallelComm(CGMTagManager *impl,
> +          MPI_Comm comm = MPI_COMM_WORLD,
> +          int* pcomm_id_out = 0);
> +  //! constructor taking buffer, for testing
> +    //! Get ID used to reference this PCOMM instance
> +  int get_id() const { return pcommID; }
> +    //! get the indexed pcomm object from the interface
> +  static CGMParallelComm *get_pcomm(CGMTagManager *impl,
> +                    const int index);
> +    //! Get CGMParallelComm instance associated with partition handle
> +    //! Will create CGMParallelComm instance if a) one does not
> already
> +    //! exist and b) a valid value for MPI_Comm is passed.
> +                                    //CGMEntityHandle partitioning,
> +                                    const MPI_Comm* comm = 0 );
> +  static CubitStatus get_all_pcomm(CGMTagManager *impl,
> +                   std::vector<CGMParallelComm*>& list );
> +  //! destructor
> +  ~CGMParallelComm();
> +  //static unsigned char PROC_SHARED, PROC_OWNER;
> +    //! assign a global id space, for largest-dimension or all
> entities (and
> +    //! in either case for vertices too)
> +  CGMErrorCode assign_global_ids(CGMEntityHandle this_set,
> +                                const int dimension,
> +                                const int start_id = 1,
> +                                const bool largest_dim_only = true,
> +                                const bool parallel = true);
> +    //! check for global ids; based only on tag handle being there
> or not;
> +    //! if it's not there, create them for the specified dimensions
> +  CGMErrorCode check_global_ids(CGMEntityHandle this_set,
> +  //! return partition ref entity list
> +  DLIList<RefEntity*> &partition_surf_list() {return
> partitioningSurfList;}
> +  const DLIList<RefEntity*> &partition_surf_list() const {return
> +  DLIList<RefEntity*> &partition_body_list() {return
> partitioningBodyList;}
> +  const DLIList<RefEntity*> &partition_body_list() const {return
> +  //! Get proc config for this communication object
> +  const CGMProcConfig &proc_config() const {return procConfig;}
> +  CGMProcConfig &proc_config() {return procConfig;}
> +  CubitStatus broadcast_entities(const unsigned int from_proc,
> +                 DLIList<RefEntity*> &ref_entity_list);
> +  CubitStatus scatter_entities(const unsigned int from_proc,
> +  CubitStatus write_buffer(DLIList<RefEntity*> &ref_entity_list,
> +              //const unsigned char* p_buffer);
> +              //char* p_buffer);
> +              std::ofstream& os);
> +              std::ostringstream& os);
> +              char* pBuffer,
> +  CubitStatus read_buffer(DLIList<RefEntity*> &ref_entity_list,
> +  CubitStatus bcast_buffer(const unsigned int from_proc);
> +  CubitStatus append_to_buffer(DLIList<RefEntity*> &ref_entity_list,
> +                   int add_size);
> +private:
> +    //! add a pc to the iface instance tag PARALLEL_COMM
> +  int add_pcomm(CGMParallelComm *pc);
> +    //! remove a pc from the iface instance tag PARALLEL_COMM
> +  void remove_pcomm(CGMParallelComm *pc);
> +  CubitStatus check_size(int& target_size, const CubitBoolean keep
> = CUBIT_FALSE);
> +    //! CGM query tool interface associated with this writer
> +  GeometryQueryTool *gqt;
> +    //! CGM tag manager interface associated with this writer
> +  CGMTagManager *cgmImpl;
> +    //! Proc config object, keeps info on parallel stuff
> +  CGMProcConfig procConfig;
> +    //! Tag server, so we can get more info about tags
> +  //TagServer *tagServer;
> +    //! Sequence manager, to get more efficient access to entities
> +  //SequenceManager *sequenceManager;
> +    //! data buffer used to communicate
> +  std::vector<unsigned char> myBuffer;
> +  char* m_pBuffer;
> +  int m_nBufferSize;
> +  int m_currentPosition;
> +  //std::ofstream mOfstream;
> +    //! more data buffers, proc-specific
> +  //std::vector<unsigned char> ownerRBuffs[MAX_SHARING_PROCS],
> +  //ownerSBuffs[MAX_SHARING_PROCS], ghostRBuffs[MAX_SHARING_PROCS],
> +  // ghostSBuffs[MAX_SHARING_PROCS];
> +    //! request objects, may be used if store_remote_handles is used
> +  //MPI_Request sendReqs[2*MAX_SHARING_PROCS];
> +    //! processor rank for each buffer index
> +  //std::vector<int> buffProcs;
> +    //! the partition, interface sets for this comm'n instance
> +  //CGMRange partitionSets, interfaceSets;
> +    //! local entities ghosted to other procs
> +  //std::map<unsigned int, CGMRange> ghostedEnts;
> +    //! tags used to save sharing procs and handles
> +  //CGMTag sharedpTag, sharedpsTag, sharedhTag, sharedhsTag,
> pstatusTag,
> +  //ifaceSetsTag, partitionTag;
> +  //int globalPartCount; //!< Cache of global part count
> +  //CGMEntityHandle partitioningSet; //!< entity set containing all
> parts
> +  DLIList<RefEntity*> partitioningSurfList; // ref entity list
> containing all parts
> +  DLIList<RefEntity*> partitioningBodyList; // ref entity list
> +  int pcommID;
> +#endif
> Added: cgm/trunk/geom/parallel/CGMProcConfig.cpp
> CGMProcConfig.cpp                            (rev 0)
> +++ cgm/trunk/geom/parallel/CGMProcConfig.cpp    2009-08-19 20:05:46
> UTC (rev 3108)
> @@ -0,0 +1,23 @@
> +//! Constructor
> +CGMProcConfig::CGMProcConfig(MPI_Comm proc_comm)
> +  : procComm(proc_comm),
> +    crystalInit(false)
> +#ifdef USE_MPI
> +  int rank, size;
> +  MPI_Comm_rank(procComm, &rank);
> +  procRank = (unsigned int) rank;
> +  MPI_Comm_size(procComm, &size);
> +  procSize = (unsigned int) size;
> +#else
> +  procRank = 0;
> +  procSize = 1;
> +#endif
> +CGMProcConfig::~CGMProcConfig()
> Added: cgm/trunk/geom/parallel/CGMProcConfig.hpp
> CGMProcConfig.hpp                            (rev 0)
> +++ cgm/trunk/geom/parallel/CGMProcConfig.hpp    2009-08-19 20:05:46
> UTC (rev 3108)
> @@ -0,0 +1,89 @@
> +#ifndef CGM_PROC_CONFIG_HPP
> +#define CGM_PROC_CONFIG_HPP
> +//#include "MBTypes.h"
> +//#include "MBRange.hpp"
> +//class MBInterface;
> +#ifdef USE_MPI
> +/* MPICH2 will fail if SEEK_* macros are defined
> + * because they are also C++ enums. Undefine them
> + * when including mpi.h and then redefine them
> + * for sanity.
> +#  ifdef SEEK_SET
> +#    define CGM_SEEK_SET SEEK_SET
> +#    define CGM_SEEK_CUR SEEK_CUR
> +#    define CGM_SEEK_END SEEK_END
> +#    undef SEEK_SET
> +#    undef SEEK_CUR
> +#    undef SEEK_END
> +#  endif
> +#include "mpi.h"
> +#  ifdef CGM_SEEK_SET
> +#    define SEEK_SET CGM_SEEK_SET
> +#    define SEEK_CUR CGM_SEEK_CUR
> +#    define SEEK_END CGM_SEEK_END
> +#    undef CGM_SEEK_SET
> +#    undef CGM_SEEK_CUR
> +#    undef CGM_SEEK_END
> +#  endif
> +//extern "C"
> +  //#include "types.h"
> +  //#include "errmem.h"
> +//#include "crystal.h"
> +#else
> +typedef int MPI_Comm;
> +#define MPI_COMM_WORLD 0
> +//typedef void* crystal_data;
> +#endif
> +/**\brief Multi-CPU information for parallel CGM */
> +class CGMProcConfig {
> +public:
> +  CGMProcConfig(MPI_Comm proc_comm = MPI_COMM_WORLD);
> +  ~CGMProcConfig();
> +    //! Get the current processor number
> +  unsigned proc_rank() const
> +    { return procRank; }
> +    //! Get the number of processors
> +  unsigned proc_size() const
> +    { return procSize; }
> +    //! get a crystal router for this parallel job
> +  //crystal_data *crystal_router(bool construct_if_missing = true);
> +    //! get/set the communicator for this proc config
> +  const MPI_Comm proc_comm() const {return procComm;}
> +  void proc_comm(MPI_Comm this_comm) {procComm = this_comm;}
> +private:
> +    //! MPI communicator set for this instance
> +  MPI_Comm procComm;
> +    //! rank of this processor
> +  unsigned procRank;
> +    //! number of processors
> +  unsigned procSize;
> +    //! whether the crystal router's been initialized or not
> +  bool crystalInit;
> +    //! crystal router for this parallel job
> +  //crystal_data crystalData;
> +#endif
> Added: cgm/trunk/geom/parallel/FileOptions.cpp
> FileOptions.cpp                            (rev 0)
> +++ cgm/trunk/geom/parallel/FileOptions.cpp    2009-08-19 20:05:46
> UTC (rev 3108)
> @@ -0,0 +1,463 @@
> +/**\file FileOptions.cpp
> + *\ copied from MOAB
> + *\date 2009-06-11
> +#include "FileOptions.hpp"
> +#include <ctype.h>
> +#include <stdlib.h>
> +#include <string.h>
> +const char DEFAULT_SEPARATOR = ';';
> +static inline bool strempty( const char* s ) { return !*s; }
> +FileOptions::FileOptions( const char* str )
> +  : mData(0)
> +    // if option string is null, just return
> +  if (!str)
> +    return;
> +    // check if alternate separator is specified
> +  char separator[2] = { DEFAULT_SEPARATOR, '\0' };
> +  if (*str == DEFAULT_SEPARATOR) {
> +    ++str;
> +    if (strempty(str))
> +      return;
> +    separator[0] = *str;
> +    ++str;
> +    // don't bother allocating copy of input string if
> +    // input string is empty.
> +  if (!strempty(str))
> +       // tokenize at separator character
> +    mData = strdup( str );
> +    for (char* i = strtok( mData, separator ); i; i = strtok( 0,
> separator ))
> +      if (!strempty(i)) // skip empty strings
> +        mOptions.push_back( i );
> +FileOptions::FileOptions( const FileOptions& copy ) :
> +  mData(0), mOptions( copy.mOptions.size() )
> +  if (!copy.mOptions.empty()) {
> +    const char* last = copy.mOptions.back();
> +    const char* endptr = last + strlen(last) + 1;
> +    size_t len = endptr - copy.mData;
> +    mData = (char*)malloc( len );
> +    memcpy( mData, copy.mData, len );
> +    for (size_t i = 0; i < mOptions.size(); ++i)
> +      mOptions[i] = mData + (copy.mOptions[i] - copy.mData);
> +FileOptions& FileOptions::operator=( const FileOptions& copy )
> +  free( mData );
> +  mData = 0;
> +  mOptions.resize( copy.mOptions.size() );
> +  return *this;
> +FileOptions::~FileOptions()
> +  free( mData );
> +FOErrorCode FileOptions::get_null_option( const char* name ) const
> +  const char* s;
> +  FOErrorCode rval = get_option( name, s );
> +  if (FO_SUCCESS != rval)
> +    return rval;
> +  return strempty(s) ? FO_SUCCESS : FO_TYPE_OUT_OF_RANGE;
> +FOErrorCode FileOptions::get_int_option( const char* name, int&
> value ) const
> +  const char* s;
> +    return rval;
> +    // empty string
> +  if (strempty(s))
> +    return FO_TYPE_OUT_OF_RANGE;
> +    // parse value
> +  char* endptr;
> +  long int pval = strtol( s, &endptr, 0 );
> +  if (!strempty(endptr)) // syntax error
> +    // check for overflow (parsing long int, returning int)
> +  value = pval;
> +  if (pval != (long int)value)
> +  return FO_SUCCESS;
> +FOErrorCode FileOptions::get_ints_option( const char* name,
> +                                          std::vector<int>& values)
> const
> +  const char* s;
> +    return rval;
> +    // empty string
> +  if (strempty(s))
> +    // parse values
> +  while (!strempty(s)) {
> +    char* endptr;
> +    long int sval = strtol( s, &endptr, 0 );
> +#define EATSPACE(a) while ((!strncmp(a, " ", 1) ||    \
> +                !strncmp(a, ",", 1)) && !strempty(a)) a++;
> +    //EATSPACE(endptr);
> +    while ((!strncmp(endptr, " ", 1) ||
> +        !strncmp(endptr, ",", 1)) && !strempty(endptr)) {
> +      endptr++;
> +    long int eval = sval;
> +    if (!strcmp(endptr, "-")) {
> +      endptr++;
> +      s = endptr;
> +      eval = strtol(s, &endptr, 0);
> +      EATSPACE(endptr);
> +    int value = sval;
> +    if (sval != (long int)value)
> +    value = eval;
> +    if (eval != (long int)value)
> +    for (int i = sval; i <= eval; i++)
> +      values.push_back(i);
> +    s = endptr;
> +FOErrorCode FileOptions::get_real_option ( const char* name,
> double& value ) const
> +  const char* s;
> +    return rval;
> +    // empty string
> +  if (strempty(s))
> +    // parse value
> +  char* endptr;
> +  value = strtod( s, &endptr );
> +FOErrorCode FileOptions::get_str_option( const char* name,
> std::string& value ) const
> +  const char* s;
> +    return rval;
> +  if (strempty(s))
> +  value = s;
> +FOErrorCode FileOptions::get_option( const char* name, std::string&
> value ) const
> +  const char* s;
> +    return rval;
> +  value = s;
> +FOErrorCode FileOptions::get_option( const char* name, const char*&
> value ) const
> +  std::vector<const char*>::const_iterator i;
> +  for (i = mOptions.begin(); i != mOptions.end(); ++i) {
> +    const char* opt = *i;
> +    if (compare( name, opt )) {
> +      value = opt + strlen(name);
> +        // if compare returned true, next char after option
> +        // name must be either the null char or an equals symbol.
> +      if (*value == '=')
> +        ++value;
> +  return FO_ENTITY_NOT_FOUND;
> +FOErrorCode FileOptions::match_option( const char* name,
> +                                       const char* value ) const
> +  int idx;
> +  const char* array[] = { value, NULL };
> +  return match_option( name, array, idx );
> +                                       const char* const* values,
> +                                       int& index ) const
> +  const char* optval;
> +  FOErrorCode rval = get_option( name, optval );
> +    return rval;
> +  for (index = 0; values[index]; ++index)
> +    if (compare( optval, values[index] ))
> +  index = -1;
> +  return FO_FAILURE;
> +bool FileOptions::compare( const char* name, const char* option )
> +  while (!strempty(name) && toupper(*name) == toupper(*option)) {
> +    ++name;
> +    ++option;
> +   // match if name matched option for length of name,
> +   // and option either matched entirely or matches up to
> +   // and equals sign.
> +  return strempty(name) && (strempty(option) || *option == '=');
> +void FileOptions::get_options( std::vector<std::string>& list ) const
> +  list.clear();
> +  list.resize( mOptions.size() );
> +  std::copy( mOptions.begin(), mOptions.end(), list.begin() );
> +#ifdef TEST
> +#include <iostream>
> +#define CHECK(A) \
> +  if (FO_SUCCESS != (A)) { \
> +    std::cerr << "Failure at line " << __LINE__ << ": error code "
> << (A) << std::endl; \
> +    return 1; \
> +#define EQUAL(A,B) \
> +  if (A != B) { \
> +    std::cerr << "Failure at line " << __LINE__ << ": expected " <<
> (B) << " but got " << (A) << std::endl; \
> +    return 2; \
> +int main()
> +  FileOptions tool
> INT1=
> 1;N
> UL1;
> STR1=
> ABC;DBL1=1.0;dbl2=2.0;DBL3=3.0;INT2=2;nul2;NUL3;INT3=3;str2=once
> upon a time;str3==fubar=;;" );
> +  std::string s;
> +  int i;
> +  double d;
> +  FOErrorCodeyy rval;
> +    // test basic get_option method without deleting entry
> +  rval = tool.get_option( "STR1", s );
> +  CHECK(rval);
> +  EQUAL( s, "ABC" );
> +    // test basic get_option method again, this time deleting the
> entry
> +  CHECK(rval);
> +    // test basig get_option method with a null option
> +  rval = tool.get_option( "NUL2", s );
> +  CHECK( rval );
> +  EQUAL( s.empty(), true );
> +    // test null option
> +  rval = tool.get_null_option( "nul1" );
> +  CHECK( rval );
> +    // try null option method on non-null value
> +  rval = tool.get_null_option( "INT1" ) ;
> +  EQUAL( rval, FO_TYPE_OUT_OF_RANGE) ;
> +    // test integer option
> +  rval = tool.get_int_option( "int1", i );
> +  CHECK( rval );
> +  EQUAL( i, 1 );
> +  rval = tool.get_int_option( "int2", i );
> +  CHECK( rval );
> +  EQUAL( i, 2 );
> +    // test integer option on non-integer value
> +  rval = tool.get_int_option( "dbl2", i );
> +  EQUAL( rval, FO_TYPE_OUT_OF_RANGE );
> +    // test integer option on null value
> +  rval = tool.get_int_option( "NUL3", i);
> +    // test double option
> +  rval = tool.get_real_option( "dbl1", d );
> +  CHECK( rval );
> +  EQUAL( d, 1.0 );
> +  rval = tool.get_real_option( "dbl2", d );
> +  CHECK( rval );
> +  EQUAL( d, 2.0 );
> +  rval = tool.get_real_option( "int3", d );
> +  CHECK( rval );
> +  EQUAL( d, 3.0 );
> +    // test real option on non-real value
> +  rval = tool.get_real_option( "str2", d );
> +    // test real option on null value
> +  rval = tool.get_real_option( "NUL3", d );
> +    // test get a simple string option
> +  rval = tool.get_str_option( "DBL3", s );
> +  CHECK( rval );
> +  EQUAL( s, "3.0" );
> +    // test get a string with spaces
> +  rval = tool.get_str_option("STR2", s );
> +  CHECK( rval );
> +  EQUAL( s, "once upon a time" );
> +    // try to get a string value for a null option
> +  rval = tool.get_str_option( "nul3", s );
> +    // test options using generic get_option method
> +  rval = tool.get_option( "NUL3", s );
> +  CHECK( rval );
> +  rval = tool.get_option( "STR3", s );
> +  CHECK( rval );
> +  EQUAL( s, "=fubar=" );
> +    // test size of options string
> +  unsigned l = tool.size();
> +  EQUAL( l, 12u );
> +    // test alternate separator
> +  FileOptions tool2( ";+OPT1=ABC+OPT2=" );
> +  l = tool2.size();
> +  EQUAL( l, 2 );
> +  rval = tool2.get_option( "opt1", s );
> +  CHECK( rval );
> +  rval = tool2.get_option( "opt2", s );
> +  CHECK( rval );
> +  bool e = s.empty();
> +  EQUAL( e, true );
> +  l = tool2.size();
> +  EQUAL( l, 2 );
> +    // test empty options string
> +  FileOptions tool3( ";;;;" );
> +  e = tool3.empty();
> +  EQUAL( e, true );
> +  l = tool3.size();
> +  EQUAL( l, 0 );
> +  FileOptions tool4(NULL);
> +  e = tool4.empty();
> +  EQUAL( e, true );
> +  l = tool4.size();
> +  EQUAL( l, 0 );
> +  FileOptions tool5(";+");
> +  e = tool5.empty();
> +  EQUAL( e, true );
> +  l = tool5.size();
> +  EQUAL( l, 0 );
> +    // test copy constructor
> +  FileOptions tool6( tool2 );
> +  rval = tool6.get_option( "opt1", s );
> +  CHECK( rval );
> +  rval = tool6.get_option( "opt2", s );
> +  CHECK( rval );
> +  e = s.empty();
> +  EQUAL( e, true );
> +  l = tool6.size();
> +  EQUAL( l, 2 );
> +  FileOptions tool7( tool5 );
> +  e = tool7.empty();
> +  EQUAL( e, true );
> +  l = tool7.size();
> +  EQUAL( l, 0 );
> +    // test assignment operator
> +  FileOptions tool8( tool2 );
> +  tool8 = tool;
> +  EQUAL( tool8.size(), tool.size() );
> +  return 0;
> +#endif
> Added: cgm/trunk/geom/parallel/FileOptions.hpp
> FileOptions.hpp                            (rev 0)
> +++ cgm/trunk/geom/parallel/FileOptions.hpp    2009-08-19 20:05:46
> UTC (rev 3108)
> @@ -0,0 +1,165 @@
> +/**\file FileOptions.hpp
> + *\copied from MOAB
> + *\date 2009-06-11
> +#ifndef FILE_OPTIONS_HPP
> +#define FILE_OPTIONS_HPP
> +#include <string>
> +#include <vector>
> +#include "CubitDefines.h"
> +/* file option type */
> +enum FOErrorCode
> +  FO_SUCCESS = 0,
> +  FO_TYPE_OUT_OF_RANGE,
> +  FO_ENTITY_NOT_FOUND,
> +  FO_FAILURE
> +/**\brief Parse options string passed to file IO routines
> + * This is a utility class used by file-IO-related code to
> + * parse the options string passed to ParallelMeshTool::load_file
> +class FileOptions {
> +public:
> +  /*\param options_string The concatenation of a list of
> +   *          options, separated either by the default separator
> +   *          (semicolon) with a custom separator specified at
> +   *          the beginning of the string (semicolon followed by
> +   *          destired separator character.)
> +  FileOptions( const char* option_string );
> +  FileOptions( const FileOptions& copy );
> +  FileOptions& operator=( const FileOptions& copy );
> +  ~FileOptions();
> +  /**\brief Check for option with no value
> +   * Check for an option w/out a value.
> +   *\param name The option name
> +   *\return - CUBIT_SUCCESS if option is found
> +   *        - CUBIT_TYPE_OUT_OF_RANGE if options is found, but has
> value
> +   *        - CUBIT_ENTITY_NOT_FOUND if option is not found.
> +  FOErrorCode get_null_option( const char* name ) const;
> +  /**\brief Check for option with an integer value.
> +   * Check for an option with an integer value
> +   *\param value Output. The value.
> +   *        - CUBIT_TYPE_OUT_OF_RANGE if options is found, but does
> not have an integer value
> +  FOErrorCode get_int_option( const char* name, int& value ) const;
> +  /**\brief Check for option with a double value.
> +   * Check for an option with a double value
> not have a double value
> +  FOErrorCode get_real_option( const char* name, double& value )
> const;
> +  /**\brief Check for option with any value.
> +   * Check for an option with any value.
> not have a value
> +  FOErrorCode get_str_option( const char* name, std::string&
> value ) const;
> +   *\param value The option value, or an empty string if no value.
> +   *\return CUBIT_SUCCESS or CUBIT_ENTITY_NOT_FOUND
> +  FOErrorCode get_option( const char* name, std::string& value )
> const;
> +  /**\brief Check the string value of an option
> +   * Check which of a list of possible values a string option
> contains.
> +   *\param values A NULL-terminated array of C-style strings
> enumerating
> +   *              the possible option values.
> +   *\param index  Output: The index into <code>values</code> for the
> +   *              option value.
> +   *\return CUBIT_SUCCESS if matched name and value.
> +   *        CUBIT_ENTITY_NOT_FOUND if the option was not specified
> +   *        CUBIT_FAILURE if the option value is not in the input
> <code>values</code> array.
> +  FOErrorCode match_option( const char* name, const char* const*
> values, int& index ) const;
> +  /**\brief Check if an option matches a string value
> +   * Check if the value for an option is the passed string.
> +   *\param value The expected value.
> +   *        CUBIT_FAILURE if the option value doesn't match the
> passed string/
> +  FOErrorCode match_option( const char* name, const char* value )
> const;
> +  /**\brief Check for option for which the value is a list of ints
> +   * Check for an option which is an int list.  The value is
> expected to
> +   * be a comma-separated list of int ranges, where an int range
> can be
> +   * either a single integer value or a range of integer values
> separated
> +   * by a dash ('-').
> +   *\param values Output. The list of integer values.
> not contain an ID list
> +  FOErrorCode get_ints_option( const char* name, std::vector<int>&
> values) const;
> +  /** number of options */
> +  inline unsigned size() const
> +    { return mOptions.size(); }
> +  /** true if no options */
> +  inline bool empty() const
> +    { return mOptions.empty(); }
> +  /** Get list of options */
> +  void get_options( std::vector<std::string>& list ) const;
> +private:
> +  FOErrorCode get_option( const char* name, const char*& value)
> const;
> +  char* mData;
> +  std::vector<const char*> mOptions;
> +    /** Case-insensitive compare of name with option value. */
> +  static bool compare( const char* name, const char* option );
> +#endif
> Modified: cgm/trunk/geom/parallel/Makefile.am
> --- cgm/trunk/geom/parallel/Makefile.am    2009-08-19 18:39:01 UTC
> (rev 3107)
> +++ cgm/trunk/geom/parallel/Makefile.am    2009-08-19 20:05:46 UTC
> (rev 3108)
> @@ -1,17 +1,28 @@
> # Don't require GNU-standard files (Changelog, README, etc.)
> AUTOMAKE_OPTIONS = foreign
> # Override default defines with the ones we want from the configure
> script
> -# Override default defines with the ones we want from the configure
> script
> -DEFS = $(TEMPLATE_DEFS_INCLUDED) \
> -       $(LITTLE_ENDIAN) $(ACIS_STEP_TRANSLATOR) $
> (ACIS_IGES_TRANSLATOR) \
> -       -DCUBIT_ACIS_VERSION=$(ACIS_VERSION) -DACIS_VERSION=$
> (ACIS_VERSION) \
> -       -D$(ACIS_PLATFORM)
> +if build_OCC
> +#  DEFS = $(TEMPLATE_DEFS_INCLUDED) $(HAVE_OCC_DEF)
> +   DEFS += $(HAVE_OCC_DEF)
> +else
> +   DEFS = $(TEMPLATE_DEFS_INCLUDED) \
> +         $(LITTLE_ENDIAN) $(ACIS_STEP_TRANSLATOR) $
> +         -DCUBIT_ACIS_VERSION=$(ACIS_VERSION) -DACIS_VERSION=$
> (ACIS_VERSION) \
> +         -D$(ACIS_PLATFORM)
> +#   DEFS += $(ACIS_STEP_TRANSLATOR) $(ACIS_IGES_TRANSLATOR) \
> (ACIS_VERSION) \
> +endif
> +# because "ISO C++ does not support ���long long"
> +CXXFLAGS += -Wno-long-long
> INCLUDES = -I$(top_srcdir)/util \
>            -I$(top_srcdir)/geom \
>            -I$(top_srcdir)/geom/ACIS \
> -           -I$(ACIS_DIR)/include \
> +       -I$(ACIS_DIR)/include \
>            $(MPI_INCLUDE)
> # The name of the library to build
> @@ -25,21 +36,17 @@
> # The non-template sources
> libcubit_parallel_la_SOURCES = \
> -    AcisMemFile.cpp \
> -    CABodies.cpp \
> -    CGMMemFile.cpp \
> -    ParallelGeomTool.cpp \
> -    ProcData.cpp \
> -    TDParallel.cpp
> +    CGMProcConfig.cpp \
> +    CGMParallelComm.cpp \
> +    FileOptions.cpp \
> +    ParallelGeomTool.cpp
> # The non-template headers
> # If any of these do not need to be installed, move them
> # to the _SOURCES list above.
> libcubit_parallel_la_include_HEADERS = \
> -    AcisMemFile.hpp \
> -    CABodies.cpp \
> -    CGMMemFile.hpp \
> -    ParallelGeomTool.hpp \
> -    ProcData.hpp \
> -    TDParallel.hpp
> +    CGMProcConfig.hpp \
> +    CGMParallelComm.hpp \
> +    FileOptions.hpp \
> +    ParallelGeomTool.hpp
> Modified: cgm/trunk/geom/parallel/ParallelGeomTool.cpp
> --- cgm/trunk/geom/parallel/ParallelGeomTool.cpp    2009-08-19
> +++ cgm/trunk/geom/parallel/ParallelGeomTool.cpp    2009-08-19
> @@ -1,51 +1,539 @@
> +#include <cstdio>
> +#include "CubitString.hpp"
> +#include "CubitMessage.hpp"
> +#include "DLList.hpp"
> +#include "CubitEntity.hpp"
> +#include "CastTo.hpp"
> +#include "CubitUtil.hpp"
> +#include "TopologyBridge.hpp"
> #include "ParallelGeomTool.hpp"
> -#include "AcisMemFile.hpp"
> -#include "AcisQueryEngine.hpp"
> -#include "TSTTG_CGM.h"
> -#include "ProcData.hpp"
> +#include "CGMParallelConventions.h"
> -ParallelGeomTool *ParallelGeomTool::instance_ = NULL;
> +const bool debug = true;
> -int ParallelGeomTool::load_parallel(TSTTG_Instance geom,
> -                                    const char *name,
> -                                    int par_load_option)
> +enum CGMParallelActions {PA_READ=0, PA_BROADCAST, PA_DELETE_NONLOCAL,
> +             PA_SCATTER,
> +             PA_CHECK_GIDS_SERIAL, PA_GET_ENTS,
> +             PA_RESOLVE_SHARED_ENTS,
> +             PA_EXCHANGE_GHOSTS};
> +enum CGMPartitionActions {PT_GEOM_DIM=0, PT_PAR_PART};
> +const char *CGMParallelActionsNames[] = {
> +  "PARALLEL READ",
> +  "PARALLEL BROADCAST",
> +  "PARALLEL DELETE NONLOCAL",
> +  "PARALLEL SCATTER",
> +  "PARALLEL CHECK_GIDS_SERIAL",
> +  "PARALLEL GET_FILESET_ENTS",
> +  "PARALLEL RESOLVE_SHARED_ENTS",
> +  "PARALLEL EXCHANGE_GHOSTS"
> +const char* ParallelGeomTool::CGMparallelOptsNames[] = { "NONE",
> "READ", "READ_DELETE", "BCAST",
> +                             "BCAST_DELETE", "SCATTER",
> "SCATTER_DELETE",
> +                             "READ_PARALLEL", "FORMAT", "", 0 };
> +const char* ParallelGeomTool::CGMpartitionOptsNames[] = { "NONE",
> "GEOM_DIMENSION",
> +                              "PARARELL_PARTITION", "", 0 };
> +//ParallelGeomTool *ParallelGeomTool::instance_ = NULL;
> +ParallelGeomTool::ParallelGeomTool(CGMTagManager* impl,
> +  : cgmImpl(impl), myPcomm(pc)
> -    // declare an acismemfile object
> -  AcisMemFile amf(AcisQueryEngine::instance());
> +  if (!myPcomm) {
> +    myPcomm = CGMParallelComm::get_pcomm(impl, 0);
> +    if (NULL == myPcomm) myPcomm = new CGMParallelComm(cgmImpl);
> +  //gqt = GeometryQueryTool::instfance();
> -  DLIList<RefEntity*> ref_ents, ref_ents_master;
> +CubitStatus ParallelGeomTool::load_file(const char *file_name,
> +                    const char *options,
> +                    const char* set_tag_name,
> +                    const int* set_tag_values,
> +                    int num_set_tag_values)
> +  FileOptions opts(options);
> -    // if I'm the master, load the file and get the entities
> -  int result;
> -  if (ProcData::instance()->is_master()) {
> -    result = TSTTG_load(geom, name, NULL, 0);
> -    if (TSTTB_SUCCESS != result) return result;
> +  // Get parallel settings
> +  int parallel_mode;
> +  FOErrorCode result = opts.match_option("PARALLEL",
> CGMparallelOptsNames,
> +                     parallel_mode);
> +  if (FO_FAILURE == result) {
> +    PRINT_ERROR( "Unexpected value for 'PARALLEL' option\n" );
> +  else if (FO_ENTITY_NOT_FOUND == result) {
> +    parallel_mode = 0;
> -      // get all the volumes
> -    TSTTG_EntityHandle *ents = NULL;
> -    int ents_alloc = 0, ents_size;
> -    result = TSTTG_getEntities(geom, 0, TSTTG_REGION,
> -                               &ents, &ents_alloc, &ents_size);
> +  bool distrib = false;
> +  bool surf_partition = false;
> +  bool body_partition = false;
> +  std::string partition_tag_name;
> +  std::vector<int> partition_tag_vals;
> -      // make this the storage for the ent list
> -    ref_ents.copy_from((RefEntity**)ents, ents_size);
> +  // Get partition tag value(s), if any, and whether they're to be
> +  result = opts.get_ints_option("PARTITION_VAL", partition_tag_vals);
> +  // Get partition setting
> +  result = opts.get_option("PARTITION", partition_tag_name);
> +  if (FO_ENTITY_NOT_FOUND == result || partition_tag_name.empty()) {
> +    partition_tag_name = PARALLEL_PARTITION_TAG_NAME;
> +    distrib = true;
> +  else {
> +    if (partition_tag_name == "GEOM_DIMENSION") {
> +      int geom_dim = 0;
> +      for (std::vector<int>::iterator pit = partition_tag_vals.begin
> +       pit != partition_tag_vals.end(); pit++) {
> +    geom_dim = *pit;
> +    if (geom_dim == 2) surf_partition = true; // body & surface
> distribution
> +    else if (geom_dim == 3) body_partition = true; // body only
> distribution
> +      if (!surf_partition && !body_partition) {
> +    PRINT_ERROR("Geometry dimension %d is not supported.\n",
> geom_dim);
> +    return CUBIT_FAILURE;
> +    else if (partition_tag_name == "PARALLEL_PARTITION") {
> -    // now communicate the entities
> -  if (BCAST == par_load_option) {
> -      // broadcast
> -    result = amf.bcast_entity_list(ref_ents);
> +    // distributed or assigned
> +    result = opts.get_null_option("PARTITION_DISTRIBUTE");
> +    if (FO_SUCCESS == result) {
> +      distrib = true;
> +      body_partition = true;
> -  else if (BCAST_AND_DELETE == par_load_option) {
> -      // bcast and delete
> -    result = amf.bcast_and_delete_entity_list(ref_ents,
> ref_ents_master);
> +  // get MPI IO processor rank
> +  int reader_rank;
> +  result = opts.get_int_option("MPI_IO_RANK", reader_rank);
> +  if (FO_ENTITY_NOT_FOUND == result)
> +    reader_rank = 0;
> +  else if (FO_SUCCESS != result) {
> +    PRINT_ERROR( "Unexpected value for 'MPI_IO_RANK' option\n" );
> -  else if (SCATTER == par_load_option) {
> -      // scatter
> -    result = amf.scatter_entity_list(ref_ents);
> +  // now that we've parsed all the parallel options, make an
> instruction
> +  // queue
> +  std::vector<int> pa_vec;
> +  bool is_reader = (reader_rank == (int) myPcomm->proc_config
> ().proc_rank());
> +  switch (parallel_mode) {
> +  case POPT_READ:
> +    pa_vec.push_back(PA_READ);
> +    //pa_vec.push_back(PA_CHECK_GIDS_SERIAL);
> +    pa_vec.push_back(PA_GET_ENTS);
> +    break;
> +  case POPT_DEFAULT:
> +  case POPT_READ_DELETE:
> +    pa_vec.push_back(PA_DELETE_NONLOCAL);
> +    break;
> +  case POPT_BCAST:
> +    if (is_reader) {
> +    pa_vec.push_back(PA_BROADCAST);
> +    if (!is_reader) pa_vec.push_back(PA_GET_ENTS);
> +    break;
> +  case POPT_BCAST_DELETE:
> +    if (is_reader) {
> +    //if (!is_reader) pa_vec.push_back(PA_GET_FILESET_ENTS);
> +    break;
> +  case PORT_SCATTER:
> +    if (is_reader) {
> +    pa_vec.push_back(PA_SCATTER);
> +    break;
> +  case PORT_SCATTER_DELETE:
> +    if (is_reader) {
> +    if (is_reader) pa_vec.push_back(PA_DELETE_NONLOCAL);
> +    else pa_vec.push_back(PA_GET_ENTS);
> +    break;
> +  case POPT_FORMAT:
> +    PRINT_ERROR( "Access to format-specific parallel read not
> implemented.\n");
> +  case POPT_READ_PARALLEL:
> +    PRINT_ERROR( "Partitioning for PARALLEL=READ_PARALLEL not
> supported yet.\n");
> +  default:
> +  return load_file(file_name, parallel_mode,
> +                   partition_tag_name,
> +                   partition_tag_vals, distrib, pa_vec, opts,
> +                   set_tag_name, set_tag_values,
> +           num_set_tag_values,
> +                   reader_rank, surf_partition, body_partition
> +                                int parallel_mode,
> +                                std::string &partition_tag_name,
> +                    std::vector<int> &partition_tag_vals,
> +                    bool distrib,
> +                    std::vector<int> &pa_vec,
> +                    const FileOptions &opts,
> +                    const int num_set_tag_values,
> +                    const int reader_rank,
> +                    const bool surf_partition,
> +                    const bool body_partition
> +  // check file type
> +  CubitString file_type;
> +  //if (strstr(file_name, ".sab")) file_type = "ACIS_SAB";
> +  //else if (strstr(file_name, ".sat")) file_type = "ACIS_SAT";
> +  if (strstr(file_name, ".stp")) file_type = "STEP";
> +  else if (strstr(file_name, ".igs")) file_type = "IGES";
> +  else if (strstr(file_name, ".occ") || strstr(file_name, ".brep"))
> file_type = "OCC";
> +  else {
> +    PRINT_ERROR("File type not known for file %s; skipping.\n",
> file_name);
> -  return result;
> +  // do the work by options
> +  bool i_read = false;
> +  std::vector<int>::iterator vit;
> +  int i;
> +  DLIList<RefEntity*> surf_entity_list, body_entity_list;
> +  for (i = 1, vit = pa_vec.begin(); vit != pa_vec.end(); vit++, i+
> +    CubitStatus tmp_result = CUBIT_SUCCESS;
> +    switch (*vit) {
> +    case PA_READ:
> +      i_read = true;
> +      double tStart, tEnd;
> +      if (debug) {
> +    std::cout << "Reading file " << file_name << std::endl;
> +    tStart = MPI_Wtime();
> +      tmp_result = GeometryQueryTool::instance()->import_solid_model
> (file_name, file_type.c_str());
> +      if (CUBIT_SUCCESS != tmp_result) {
> +    PRINT_ERROR("Reading file %s failed.\n", file_name);
> +      else if (debug) {
> +    tEnd = MPI_Wtime();
> +    PRINT_INFO("Read time in proc %d is %f.\n", myPcomm->proc_config
> ().proc_size(),
> +           tEnd - tStart);
> +    PRINT_INFO("Read done.\n");
> +      break;
> +    case PA_GET_ENTS:
> +      if (debug) std::cout << "Getting entities." << std::endl;
> +      // get entities
> +      if (body_partition) {
> +    tmp_result = GeometryQueryTool::instance()->ref_entity_list
> ("body", body_entity_list, CUBIT_FALSE);
> +      PRINT_ERROR("Getting body entities failed.\n");
> +      if (surf_partition) {
> ("surface", surf_entity_list, CUBIT_FALSE);
> +      PRINT_ERROR("Getting surf entities failed.\n");
> +      if (debug) PRINT_INFO("Getting entities done.\n");
> +      break;
> +    case PA_DELETE_NONLOCAL:
> +      if (debug) {
> +    PRINT_INFO("Deleting nonlocal entities.\n");
> +      tmp_result = delete_nonlocal_entities(partition_tag_name,
> +                        surf_entity_list,
> +                        body_entity_list,
> +                        distrib);
> +    PRINT_ERROR("Delete failed.\n");
> +      else if (debug) {
> +    PRINT_INFO("Delete done.\n");
> +    PRINT_INFO("Delete time in proc %d is %f.\n", myPcomm-
> >proc_config().proc_size(),
> +           tEnd - tStart);
> +      break;
> +    case PA_BROADCAST:
> +      // do the actual broadcast; if single-processor, ignore error
> +      if (myPcomm->proc_config().proc_size() > 1) {
> +      if (debug) {
> +        PRINT_INFO("Broadcasting body entities.\n");
> +      tmp_result = myPcomm->broadcast_entities(reader_rank,
> body_entity_list);
> +        PRINT_ERROR("Broadcasting body entities failed.\n");
> +      else if (debug) {
> +        PRINT_INFO("Bcast bodies done.\n");
> +        PRINT_INFO("Broadcast bodies time in proc %d is %f.\n",
> myPcomm->proc_config().proc_size(),
> +               tEnd - tStart);
> +      if (debug) {
> +        PRINT_INFO("Broadcasting surface entities.\n");
> surf_entity_list);
> +        PRINT_ERROR("Broadcasting surface entities failed.\n");
> +      else if (debug) {
> +        PRINT_INFO("Bcast surface done.\n");
> +        PRINT_INFO("Broadcast surfaces time in proc %d is %f.\n",
> +               tEnd - tStart);
> +      break;
> +    case PA_SCATTER:
> +      // do the actual scatter
> +      if (debug) {
> +        PRINT_INFO("Scattering body entities.\n");
> +      tmp_result = myPcomm->scatter_entities(reader_rank,
> body_entity_list);
> +        PRINT_ERROR("Scattering body entities failed.\n");
> +      else if (debug) {
> +        PRINT_INFO("Scatter bodies done.\n");
> +        PRINT_INFO("Scatter bodies time in proc %d is %f.\n",
> +               tEnd - tStart);
> +      if (debug) {
> +        PRINT_INFO("Scattering surface entities.\n");
> surf_entity_list);
> +        PRINT_ERROR("Scattering surf entities failed.\n");
> +      else if (debug) {
> +        PRINT_INFO("Scatter surfaces done;\n");
> +        PRINT_INFO("Scatter surfaces time in proc %d is %f.\n",
> +               tEnd - tStart);
> +      if (debug) PRINT_INFO("Scatter done.\n");
> +      break;
> +    default:
> +  return CUBIT_SUCCESS;
> +CubitStatus ParallelGeomTool::delete_nonlocal_entities(std::string
> &ptag_name,
> +                               std::vector<int> &ptag_vals,
> +                               DLIList<RefEntity*> body_entity_list,
> +                               const bool distribute)
> +  unsigned int i;
> +  CubitStatus result;
> +  int proc_sz = myPcomm->proc_config().proc_size();
> +  int proc_rk = myPcomm->proc_config().proc_rank();
> +  if (distribute) { // Round-Robin
> +    // for now, require that number of partition sets be greater
> +    // than number of procs
> +    if (body_entity_list.size() < proc_sz &&
> +    surf_entity_list.size() < proc_sz) {
> +      result = CUBIT_FAILURE;
> +      PRINT_ERROR("Number of procs greater than number of
> partitions.");
> +    // delete unneeded surf entities
> +    unsigned int tot_entity = surf_entity_list.size();
> +    unsigned int n_entity = tot_entity / proc_sz;
> +    unsigned int n_entity_leftover = tot_entity % proc_sz;
> +    unsigned int begin_entity = 0;
> +    if (proc_rk < (int) n_entity_leftover) {
> +      n_entity++;
> +      begin_entity = n_entity * proc_rk;
> +    else
> +      begin_entity = proc_rk * n_entity + n_entity_leftover;
> +    DLIList<RefEntity*> tmp_entity_list, delete_surf_list,
> delete_body_list;
> +    unsigned int end_entity = begin_entity + n_entity;
> +    for (i = 0; i < tot_entity; i++) {
> +      if (i >= begin_entity && i < end_entity)
> tmp_entity_list.append(surf_entity_list[i]);
> +      else {
> +    delete_surf_list.append(surf_entity_list[i]);
> +    //GeometryQueryTool::instance()->delete_RefEntity
> +    // change partition surf ref entity list
> +    myPcomm->partition_surf_list().clean_out();
> +    myPcomm->partition_surf_list() += tmp_entity_list;
> +    // delete unneeded body entities
> +    tot_entity = body_entity_list.size();
> +    n_entity = tot_entity / proc_sz;
> +    n_entity_leftover = tot_entity % proc_sz;
> +      n_entity++;
> +    else
> +    end_entity = begin_entity + n_entity;
> tmp_entity_list.append(body_entity_list[i]);
> +      else {
> +    delete_body_list.append(body_entity_list[i]);
> +    char pre_surf[100], pre_body[100];
> +    DLIList<CubitEntity*> tmp_surf_list, tmp_body_list;
> +    if (debug) {
> +      CAST_LIST_TO_PARENT(delete_surf_list, tmp_surf_list);
> +      sprintf( pre_surf, "Deleted %d Surfaces: ", tmp_surf_list.size
> +      CAST_LIST_TO_PARENT(delete_body_list, tmp_body_list);
> +      sprintf( pre_body, "Deleted %d Bodies: ", tmp_body_list.size
> +      CubitUtil::list_entity_ids( pre_surf, tmp_surf_list );
> +    unsigned int nDelete = delete_surf_list.size();
> +    for (i = 0; i < nDelete; i++) {
> +      GeometryQueryTool::instance()->delete_RefEntity
> +    if (debug) CubitUtil::list_entity_ids( pre_body, tmp_body_list );
> +    nDelete = delete_body_list.size();
> +    myPcomm->partition_body_list().clean_out();
> +    myPcomm->partition_body_list() += tmp_entity_list;
> +  else {
> +    myPcomm->partition_surf_list() += surf_entity_list;
> +    myPcomm->partition_body_list() += body_entity_list;
> +  if (debug) {
> +    surf_entity_list.clean_out();
> +    GeometryQueryTool::instance()->ref_entity_list("surface",
> +    body_entity_list.clean_out();
> +    GeometryQueryTool::instance()->ref_entity_list("body",
> +    std::cerr << "My partition surf/body ref entity list size1: "
> +    << surf_entity_list.size() << " "
> +          << body_entity_list.size() << std::endl;*/
> +    std::cerr << "My partition surf/body ref entity list size: "
> +          << myPcomm->partition_surf_list().size() << " "
> +          << myPcomm->partition_body_list().size() << std::endl;
> Modified: cgm/trunk/geom/parallel/ParallelGeomTool.hpp
> --- cgm/trunk/geom/parallel/ParallelGeomTool.hpp    2009-08-19
> 18:39:01 UTC (rev 3107)
> +++ cgm/trunk/geom/parallel/ParallelGeomTool.hpp    2009-08-19
> 20:05:46 UTC (rev 3108)
> @@ -1,32 +1,88 @@
> #ifndef PARALLELGEOMTOOL_HPP
> #define PARALLELGEOMTOOL_HPP
> +#include <vector>
> +//#include "ProcData.hpp"
> +//#include "CATag.hpp"
> +//#include "CGMParallelComm.hpp"
> +//class CGMTagManager;
> +//class CGMParallelComm;
> class ParallelGeomTool
> public:
> -  static ParallelGeomTool *instance();
> +  ParallelGeomTool(CGMTagManager* impl = NULL, CGMParallelComm *pc
> = NULL);
> +  //static ParallelGeomTool *instance();
>   enum ParallelLoadOption {BCAST, BCAST_AND_DELETE, SCATTER};
> -    // load geometry to parallel processors, using ParallelLoadOption
> -    // to determine how
> -  int load_parallel(TSTTG_Instance geom,
> -                    const char *name,
> -                    int par_load_option);
> +  // load a file
> +  CubitStatus load_file(const char *file_names, const char *options,
> +            const char* set_tag_name = 0,
> +            const int* set_tag_values = 0,
> +            int num_set_tag_values = 0);
> +  CubitStatus load_file(const char *file_name,
> +                        bool distrib,
> +            const bool body_partition);
> +  static const char *CGMparallelOptsNames[];
> +  static const char *CGMpartitionOptsNames[];
> +  enum CGMParallelOpts {POPT_NONE=0, POPT_READ, POPT_READ_DELETE,
> POPT_BCAST,
> +            POPT_BCAST_DELETE, PORT_SCATTER,
> +            PORT_SCATTER_DELETE, POPT_READ_PARALLEL,
> +            POPT_FORMAT, POPT_DEFAULT};
> private:
> -  ParallelGeomTool() {}
> -  static ParallelGeomTool *instance_;
> +  // surf ref entity list to be partitioned
> +  DLIList<RefEntity*> msurf_entity_list;
> +  // body ref entity list to be partitioned
> +  DLIList<RefEntity*> mbody_entity_list;
> +  CubitStatus delete_nonlocal_entities(std::string &ptag_name,
> +                       bool distribute);
> +  //CubitStatus delete_nonlocal_entities(MBEntityHandle file_set);
> +  //static ParallelGeomTool *instance_;
> +  // each reader can keep track of its own pcomm
> +  CGMParallelComm *myPcomm;
> +  //GeometryQueryTool *gqt;
> inline ParallelGeomTool *ParallelGeomTool::instance()
>   if (!instance_) instance_ = new ParallelGeomTool();
>   return instance_;
> #endif
> Modified: cgm/trunk/geom/virtual/VirtualQueryEngine.cpp
> --- cgm/trunk/geom/virtual/VirtualQueryEngine.cpp    2009-08-19
> +++ cgm/trunk/geom/virtual/VirtualQueryEngine.cpp    2009-08-19
> @@ -1526,6 +1526,14 @@
> +CubitStatus VirtualQueryEngine::export_solid_model
> +                            char*& p_Buffer,
> +                            int& n_buffer_size,
> +                            bool b_export_buffer)
> CubitStatus VirtualQueryEngine::save_temp_geom_file
> ( DLIList<TopologyBridge*>& ,
>                                         const char* ,
>                                         const CubitString &,
> @@ -1560,6 +1568,16 @@
> +CubitStatus VirtualQueryEngine::import_solid_model
> (DLIList<TopologyBridge*> &imported_entities,
> +                           const char* pBuffer,
> +                           const int n_buffer_size)
> +  PRINT_INFO("VirtualQueryEngine::import_solid_model\n");
> +  default_error_message( "import_solid_model()");
> void VirtualQueryEngine::delete_solid_model_entities
> (DLIList<BodySM*>& list) const
>   for ( int i = list.size(); i--; )
> Modified: cgm/trunk/geom/virtual/VirtualQueryEngine.hpp
> --- cgm/trunk/geom/virtual/VirtualQueryEngine.hpp    2009-08-19
> +++ cgm/trunk/geom/virtual/VirtualQueryEngine.hpp    2009-08-19
> @@ -357,6 +357,11 @@
>                                           const CubitString
> &cubit_version,
>                                           const char* logfile_name =
> NULL );
> bridge_list,
> +                      char*& p_buffer,
> +                      bool b_export_buffer);
>   virtual CubitStatus save_temp_geom_file(DLIList<TopologyBridge*>&
> bridge_list,
>                                           const CubitString
> &cubit_version,
> @@ -381,6 +386,10 @@
>                              CubitBoolean import_vertices =
> CUBIT_TRUE,
>                              CubitBoolean free_surfaces =
> CUBIT_TRUE );
> &imported_entities,
> +                     const int n_buffer_size);
>   virtual void delete_solid_model_entities(DLIList<BodySM*>&) const;
>   virtual CubitStatus delete_solid_model_entities( BodySM*
> body_ptr ) const;
>   virtual CubitStatus delete_solid_model_entities(Surface*
> surf_ptr ) const;
> Modified: cgm/trunk/itaps/CATag.hpp
> --- cgm/trunk/itaps/CATag.hpp    2009-08-19 18:39:01 UTC (rev 3107)
> +++ cgm/trunk/itaps/CATag.hpp    2009-08-19 20:05:46 UTC (rev 3108)
> @@ -42,6 +42,7 @@
> class RefEntity;
> class RefGroup;
> class CATag;
> +class CGMParallelComm;
> class CGMTagManager
> @@ -116,6 +117,8 @@
>     return static_instance;
> +  inline std::vector<CGMParallelComm*>& get_pc_array() { return
> pc_array; }
> private:
>   CGMTagManager();
> @@ -129,6 +132,9 @@
>   static const char *CATag_NAME_INTERNAL;
>   RefGroup *interfaceGroup;
> +  // list of parallel comm
> +  std::vector<CGMParallelComm*> pc_array;
>   bool getPresetTagData(const RefEntity *entity, const long tag_num,
>                         char *tag_value, int &tag_size);
> Modified: cgm/trunk/itaps/Makefile.am
> --- cgm/trunk/itaps/Makefile.am    2009-08-19 18:39:01 UTC (rev 3107)
> +++ cgm/trunk/itaps/Makefile.am    2009-08-19 20:05:46 UTC (rev 3108)
> @@ -3,6 +3,10 @@
> DEFS = $(TEMPLATE_DEFS_INCLUDED) $(HAVE_ACIS_DEF) $(HAVE_OCC_DEF)
> +#CXXFLAGS = -Wall -pipe -pedantic -g -DDEBUG -Wno-long-long -DUSE_MPI
> if USE_BABEL
>   SIDL_DIR = SIDL
> else
> @@ -20,6 +24,9 @@
> if build_OCC
>   TESTS += testgeom_occ
> endif
> +if build_parallel
> +  TESTS += partest testgeomParallel
> +endif
> SUBDIRS = . $(SIDL_DIR)
> @@ -67,6 +74,19 @@
> chaman_CPPFLAGS = $(CPPFLAGS) -DSRCDIR=$(srcdir)
> chaman_LDFLAGS = $(CGM_EXT_LTFLAGS) $(CGM_EXT_LDFLAGS)
> +if build_parallel
> +  partest_SOURCES = partest.cpp
> +  partest_LDADD = $(testgeom_LDADD)
> +  partest_CPPFLAGS = $(testgeom_CPPFLAGS) -DFORCE_OCC
> +  partest_LDFLAGS = $(testgeom_LDFLAGS)
> +  testgeomParallel_SOURCES = testgeomParallel.cpp
> +  testgeomParallel_LDADD = $(testgeom_LDADD)
> +  testgeomParallel_CPPFLAGS = $(testgeom_CPPFLAGS) -DFORCE_OCC
> +  testgeomParallel_LDFLAGS = $(testgeom_LDFLAGS)
> +  INCLUDES += -I$(top_srcdir)/geom/parallel
> +endif
> # Automake doesn't seem to have a directory defined for
> # platform-dependent data (or include) files. So put
> # in $(libdir).  Define a $(cfgdir) to get around automake's
> Modified: cgm/trunk/itaps/iGeom_CGMA.cc
> --- cgm/trunk/itaps/iGeom_CGMA.cc    2009-08-19 18:39:01 UTC (rev
> 3107)
> +++ cgm/trunk/itaps/iGeom_CGMA.cc    2009-08-19 20:05:46 UTC (rev
> 3108)
> @@ -314,32 +314,19 @@
>   std::string file_name( name, name_len );
>   name = file_name.c_str();
> -    // process options
> +  // check if work in parallel
>   bool parallel = false;
> -  int par_load_option = -1;
> -  std::vector<std::string> opts;
> -  tokenize( std::string(options, options_size), opts );
> -  for (size_t i = 0; i < opts.size(); ++i) {
> -    if (opts[i] == "PARALLEL"
> -     || opts[i] == "parallel")
> -      parallel = true;
> -    if (opts[i] == "GEOM_BCAST"
> -     || opts[i] == "geom_bcast");
> -      par_load_option = 0;
> -    if (opts[i] == "GEOM_BCAST_AND_DELETE"
> -     || opts[i] == "geom_bcast_and_delete")
> -      par_load_option = 1;
> -    if (opts[i] == "GEOM_SCATTER"
> -     || opts[i] == "geom_scatter")
> -      par_load_option = 2;
> +  std::string parallel_opt;
> +  FOErrorCode rval = opts.get_option("PARALLEL", parallel_opt);
> +  if (FO_SUCCESS == rval) parallel = true;
> +  // parallel
>   if (parallel) {
> #ifdef USE_MPI
> -    CubitStatus status = ParallelGeomTool::instance()->load_parallel
> (name, par_load_option);
> +    //CubitStatus status = ParallelGeomTool::instance()->load_file
> (name, options);
> +    ParallelGeomTool pgt(reinterpret_cast<CGMTagManager*>
> (instance), NULL);
> +    CubitStatus status = pgt.load_file(name, options);
>     if (CUBIT_SUCCESS != status) {
>       ERROR(iBase_FAILURE, "Trouble loading geometry file in
> parallel.");
> @@ -347,27 +334,28 @@
>     ERROR(iBase_NOT_SUPPORTED, "Parallel not enabled in this
> version.");
> #endif
> -  iBase_ErrorType result;
> -  CubitStatus status = CUBIT_SUCCESS;
> -  if (strstr(name, ".cub") != NULL) {
> -    iGeom_load_cub_geometry(name, err);
> -    if (iBase_SUCCESS != *err) {
> -      return;
>   else {
> -    if (strstr(name, ".brep") != NULL || strstr(name, ".occ") !=
> NULL)
> -      status = gqt->read_geometry_file(name, NULL, "OCC");
> -    else
> -      status = gqt->read_geometry_file(name);
> -    if (CUBIT_SUCCESS != status) {
> -      ERROR(iBase_FILE_NOT_FOUND, "Trouble loading geometry file.");
> +    CubitStatus status = CUBIT_SUCCESS;
> +    if (strstr(name, ".cub") != NULL) {
> +      iGeom_load_cub_geometry(name, err);
> +      if (iBase_SUCCESS != *err) {
> +    return;
> +    else {
> +      if (strstr(name, ".brep") != NULL || strstr(name, ".occ") !=
> NULL)
> +    status = gqt->read_geometry_file(name, NULL, "OCC");
> +      else
> +    status = gqt->read_geometry_file(name);
> +      if (CUBIT_SUCCESS != status) {
> +    ERROR(iBase_FILE_NOT_FOUND, "Trouble loading geometry file.");
>     // now process uncaught/unregistered attributes
> +  iBase_ErrorType result;
>   result = process_attribs(instance);
>   RETURN(result);
> @@ -5882,7 +5870,8 @@
>   if (NULL == cubfile) RETURN(iBase_FILE_NOT_FOUND);
>     // first get the length
> -  int result = fseek(cubfile, 0, SEEK_END);
> +  //int result = fseek(cubfile, 0, SEEK_END);
> +  int result = fseek(cubfile, 0, 2);
>   if (result) {
>     ERROR(iBase_FAILURE, "Couldn't seek to end of .cub file.");
> @@ -5896,7 +5885,8 @@
>     // get the model header
> -  result = fseek(cubfile, 4, SEEK_SET);
> +  //result = fseek(cubfile, 4, SEEK_SET);
> +  result = fseek(cubfile, 4, 0);
>   if (result) {
>     ERROR(iBase_FAILURE, "Seek failed reading cub file header.");
> @@ -5916,7 +5906,8 @@
>     ERROR(iBase_FAILURE, "Reading model table will go past end of
> file.");
> -  result = fseek(cubfile, model_table_offset, SEEK_SET);
> +  //result = fseek(cubfile, model_table_offset, SEEK_SET);
> +  result = fseek(cubfile, model_table_offset, 0);
>   if (result) {
>     ERROR(iBase_FAILURE, "Seek failed seeking to model table.");
> Added: cgm/trunk/itaps/partest.cpp
> --- cgm/trunk/itaps/partest.cpp                            (rev 0)
> +++ cgm/trunk/itaps/partest.cpp    2009-08-19 20:05:46 UTC (rev 3108)
> @@ -0,0 +1,88 @@
> +// Test parallel iGeom
> +#include <stdio.h>
> +#  ifdef SEEK_SET
> +#    define PTEST_SEEK_SET SEEK_SET
> +#    define PTEST_SEEK_CUR SEEK_CUR
> +#    define PTEST_SEEK_END SEEK_END
> +#    undef SEEK_SET
> +#    undef SEEK_CUR
> +#    undef SEEK_END
> +#  endif
> +#include "mpi.h"
> +#  ifdef PTEST_SEEK_SET
> +#    define SEEK_SET PTEST_SEEK_SET
> +#    define SEEK_CUR PTEST_SEEK_CUR
> +#    define SEEK_END PTEST_SEEK_END
> +#    undef PTEST_SEEK_SET
> +#    undef PTEST_SEEK_CUR
> +#    undef PTEST_SEEK_END
> +#  endif
> +#include "iGeom.h"
> +#define IGEOM_ASSERT(ierr) if (ierr!=0) printf("igeom assert\n");
> +#define IGEOM_NULL 0
> +int main(int argc, char* argv[]){
> +  int rank, size;
> +  MPI_Init(&argc, &argv);
> +  MPI_Comm_rank( MPI_COMM_WORLD, &rank );
> +  MPI_Comm_size( MPI_COMM_WORLD, &size );
> +  printf("Hello\n");
> +  iGeom_Instance igeom;
> +  int ierr;
> +  igeom = IGEOM_NULL;
> +  iGeom_newGeom("PARALLEL", &igeom, &ierr, 8);
> +  IGEOM_ASSERT(ierr);
> +  // check command line arg
> +  const char* filename = 0;
> +  int nMethod = 1;
> +  std::string options;
> +  if (argc == 3) {
> +    filename = argv[1];
> +    nMethod = atoi(argv[2]);
> +  else {
> +    if (rank == 0) printf("Usage: %s [<filename>] [<send_methond>]
> \n", argv[0]);
> +    if (argc != 1 || argc != 2) return 1;
> +    if (rank == 0) {
> +      printf("  No file specified.  Defaulting to: %s\n",
> "Moto.brep");
> +      printf("  No send method specified.  Defaulting to:
> read_delete\n");
> +    filename = "../../../test_files/Moto.brep";
> +  // set geometry send method
> +  if (nMethod == 0) options += "PARALLEL=READ;";
> +  else if (nMethod == 1) options += "PARALLEL=READ_DELETE;";
> +  else if (nMethod == 2) options += "PARALLEL=BCAST;";
> +  else if (nMethod == 3) options += "PARALLEL=BCAST_DELETE;";
> +  else if (nMethod == 4) options += "PARALLEL=SCATTER;";
> +  else if (nMethod == 5) options += "PARALLEL=SCATTER_DELETE;";
> +  else if (nMethod == 6) options += "PARALLEL=READ_PARALLEL;";
> +  else {
> +    printf("Send method %d is not supported. Defaulting to:
> read_delete\n", nMethod);
> +    options = "READ_DELETE;";
> +  // do body partitioning with round robin distribution
> +  options +=
> "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;";
> +  double tStart = MPI_Wtime();
> +  iGeom_load(igeom, filename, options.c_str(), &ierr, strlen
> (filename), options.length());
> +  MPI_Barrier(MPI_COMM_WORLD);
> +  double tEnd = MPI_Wtime();
> +  printf("Done. Geometry load time is %f\n", tEnd - tStart);
> +  MPI_Finalize();
More information about the cgma-dev
