[cgma-dev] r2854 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Fri Apr 24 12:16:46 CDT 2009
Author: janehu
Date: 2009-04-24 12:16:44 -0500 (Fri, 24 Apr 2009)
New Revision: 2854
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCSurface.cpp
   cgm/trunk/geom/OCC/OCCSurface.hpp
Log:
Added tweak_move surface function; fixed bugs;as usuall, unite operation is not creating one smooth surface even they are geometrically smooth.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-04-21 20:57:45 UTC (rev 2853)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-04-24 17:16:44 UTC (rev 2854)
@@ -3063,23 +3063,14 @@
       shape_list.append(topo_face);
     else
-      //int size = shape_list.size();
-      OCCQueryEngine* oqe = OCCQueryEngine::instance();
-      DLIList <OCCBody* > *bodies = oqe->BodyList;
-      TopTools_IndexedDataMapOfShapeListOfShape M;
-      OCCBody * body = NULL;
-      for(int j = 0; j <  bodies->size(); j++)
+      DLIList<OCCBody*> bodies;
+      surface->get_bodies(bodies);
+      if(bodies.size() != 1)
-        body = bodies->get_and_step();
-        TopExp_Explorer Ex;
-        TopoDS_Face the_face;
-        TopoDS_Shape ashape = *(body->get_TopoDS_Shape());
-        M.Clear();
-        TopExp::MapShapesAndAncestors(ashape, TopAbs_FACE, TopAbs_COMPSOLID, M);
-        if(!M.Contains(*topo_face))
-          continue;
-        shape_list.append_unique(body->get_TopoDS_Shape());
+        PRINT_ERROR("Can't find the corresponding manifold solid body.\n");
+        return CUBIT_FAILURE;
+      shape_list.append_unique(bodies.get()->get_TopoDS_Shape());
@@ -3746,28 +3737,23 @@
   //find a non-sheet body to be the first shape
   TopoDS_Shape* first_shape;
+  TopoDS_Shape* second_shape;
   CubitBoolean first_is_volume;
+  int index = 0;
   if((first_is_volume = is_volume.move_to(CUBIT_TRUE)))
-    int index = is_volume.get_index();
-    first_shape = shape_list[index];
-    shape_list.remove(first_shape);
-    is_volume.step(index);
-    is_volume.remove();
-    bodies.step(index);
-    bodies.remove();
-  else
-    first_shape = shape_list.pop();
-    bodies.pop();
+    index = is_volume.get_index();
+  first_shape = shape_list[index];
+  shape_list.remove(first_shape);
+  is_volume.step(index);
+  is_volume.remove();
+  bodies.step(index);
+  BodySM* removed_body = bodies.remove();
   for(int i = 0; i < size; i++)
-    TopoDS_Shape* second_shape = shape_list.get_and_step();
+    second_shape = shape_list.get_and_step();
     BRepAlgoAPI_Fuse fuser(*first_shape, *second_shape);
     TopoDS_Shape new_shape = fuser.Shape();
@@ -3802,6 +3788,7 @@
+  bodies.append(removed_body);
   return CUBIT_SUCCESS;
@@ -4202,6 +4189,8 @@
         PRINT_ERROR("Sweeping direction should not be on the surface.\n");
+      else
+        ref_ent = (GeometryEntity *)surface;
     else
@@ -6387,19 +6376,10 @@
     else
       solid_points.append(point);
-      DLIList <OCCBody* > *occ_bodies = oqe->BodyList;
-      for(int i = 0; i < occ_bodies->size(); i++)
-        DLIList<OCCSurface*> surfaces;
-        OCCBody* occ_body = occ_bodies->get_and_step();
-        occ_body->get_all_surfaces(surfaces);
-        if(surfaces.is_in_list(s))
-          bodies.append(occ_body);
-          break;
+      DLIList<OCCBody*> solid_bodies;
+      s->get_bodies(solid_bodies);
+      assert(solid_bodies.size() == 1);
+      bodies += solid_bodies;
@@ -6855,25 +6835,113 @@
 // Function   : tweak_move
 // Member Type: PUBLIC
 // Description: Tweak specified faces of a volume or volumes along a vector.
-// Author     :
-// Date       :
+// Author     : Jane Hu
+// Date       : 04/09
-CubitStatus OCCModifyEngine::tweak_move( DLIList<Surface*> & /*surface_list*/,
-                                           const CubitVector & /*delta*/,
-                                           DLIList<BodySM*> & /*new_bodysm_list*/,
-                                           CubitBoolean /*keep_old_body*/ ,
-                                           CubitBoolean show_preview) const
+CubitStatus OCCModifyEngine::tweak_move( DLIList<Surface*> & surface_list,
+                                         const CubitVector & delta,
+                                         DLIList<BodySM*> & new_bodysm_list,
+                                         CubitBoolean keep_old_body ,
+                                         CubitBoolean preview) const
-  PRINT_ERROR("Option not supported for OCC based geometry.\n");
-  return CUBIT_FAILURE;
+  CubitStatus stat;
+  for(int i = 0 ; i < surface_list.size(); i++)
+    Surface* surf = surface_list.get_and_step();
+    OCCSurface* occ_surf = CAST_TO(surf, OCCSurface);
+    if(!occ_surf)
+      continue;
+    //check to make sure that the surf is not on a sheet body.
+    OCCLump* lump = occ_surf->my_lump();
+    if(lump != NULL && (lump->my_sheet_surface() || lump->my_shell()))
+      PRINT_ERROR( "Cannot tweak move surfaces that are not in a solid\n");
+    DLIList<GeometryEntity*> ref_ent_list;
+    ref_ent_list.append(occ_surf);
+    DLIList<BodySM*> result_bodies;
+    stat = sweep_translational(ref_ent_list, result_bodies, delta, 0.0, 1,
+                               false, true);
+    if(stat == CUBIT_FAILURE)
+      PRINT_ERROR( "Cannot tweak move the surface. \n");
+    assert(result_bodies.size() == 1);
+    //determine if the delta is to trim the existing body or extend it.
+    CubitVector center_point;
+    center_point = occ_surf->center_point();
+    center_point += ~delta;
+    BodySM* original_body = occ_surf->my_body();
+    if(original_body == NULL)
+      DLIList<OCCBody*> original_bodies;
+      occ_surf->get_bodies(original_bodies);
+      if(original_bodies.size() > 1)
+        PRINT_ERROR( "Cannot tweak move the surface in non-mainfold solids. \n");
+      else if(original_bodies.size() == 0)
+        PRINT_ERROR( "Interal error: Can't find associated solid. \n");
+      original_body = original_bodies.get();
+      assert(original_body != NULL);
+    CubitBoolean trim = CUBIT_FALSE;
+    if(original_body->point_containment(center_point) == CUBIT_PNT_INSIDE)
+       trim = CUBIT_TRUE;
+    //subtract or unite the two bodies
+    if(!trim)
+      result_bodies.insert_first(original_body);
+      stat = unite(result_bodies, new_bodysm_list, keep_old_body);
+    else
+      DLIList<BodySM*> from_bodies;
+      from_bodies.append(original_body);
+      stat = subtract(result_bodies, from_bodies, new_bodysm_list, CUBIT_FALSE,
+                      keep_old_body);
+    if(stat = CUBIT_FAILURE)
+  if(preview)
+    GfxPreview::clear();
+    for(int i = 0; i < new_bodysm_list.size(); i++)
+      BodySM* new_bodysm = new_bodysm_list.get_and_step();
+      TopoDS_Shape* modified_shape =
+          CAST_TO(new_bodysm, OCCBody)->get_TopoDS_Shape();
+      TopExp_Explorer Ex;
+      Ex.Init(*modified_shape, TopAbs_FACE);
+      for( ; Ex.More(); Ex.Next() )
+        TopoDS_Face face = TopoDS::Face(Ex.Current());
+        // Draw this face
+        OCCDrawTool::instance()->draw_FACE( &face, CUBIT_BLUE, CUBIT_TRUE );
+    GfxPreview::flush();
+    OCCQueryEngine::instance()->delete_solid_model_entities(new_bodysm_list);
+    new_bodysm_list.clean_out();
+  return CUBIT_SUCCESS;
 // Description: Tweak specified curves of a sheet body along a vector.
-// Author     :
-// Date       :
+// Date       : 04/09
 CubitStatus OCCModifyEngine::tweak_move( DLIList<Curve*> & curves,
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2009-04-21 20:57:45 UTC (rev 2853)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2009-04-24 17:16:44 UTC (rev 2854)
@@ -1419,6 +1419,21 @@
     if(!face)
       continue;
     OCCSurface *occ_surface = CAST_TO(face, OCCSurface);
+    //check if surface was a sheet surface, delete it if so
+    if(occ_surface->my_shell() != NULL && occ_surface->my_shell() != shell)
+       //if Sheet_body, delete this sheet body
+       if(occ_surface->my_body() != NULL)
+          delete_solid_model_entities(occ_surface->my_body());
+          face =
+            populate_topology_bridge(topo_face, CUBIT_FALSE);
+          if(!face)
+            continue;
+          occ_surface = CAST_TO(face, OCCSurface);
     CubitBoolean exist = CUBIT_FALSE;
     OCCCoFace * coface = NULL;
     int size = cofaces_old.size();
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp	2009-04-21 20:57:45 UTC (rev 2853)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp	2009-04-24 17:16:44 UTC (rev 2854)
@@ -1009,6 +1009,7 @@
      if (!wire.IsSame(shape))
        OCCQueryEngine::instance()->update_OCC_map(wire, shape);
+  double dTOL = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
   if (!old_surface.IsSame(new_surface))
     TopAbs_ShapeEnum shapetype =  TopAbs_SHAPE;
@@ -1021,17 +1022,54 @@
       TopTools_IndexedMapOfShape M;
       TopExp::MapShapes(new_surface, TopAbs_FACE, M);
       TopoDS_Shape new_shape;
-      if(M.Extent() > 0)
+      if(M.Extent() == 1)
         new_shape = M(1);
-      else
-        new_shape = new_surface;
+      else if(M.Extent() > 1)
+        for(int i = 1; i <= M.Extent(); i++)
+          GProp_GProps myProps;
+          BRepGProp::SurfaceProperties(old_surface, myProps);
+          double orig_mass = myProps.Mass();
+          gp_Pnt orig_pnt = myProps.CentreOfMass();
+          BRepGProp::SurfaceProperties(M(i), myProps);
+          double after_mass = myProps.Mass();
+          gp_Pnt after_pnt = myProps.CentreOfMass();
+          if(fabs(-after_mass + orig_mass) <= dTOL &&
+             orig_pnt.IsEqual(after_pnt, dTOL))
+            new_shape = M(i);
+            break;
       OCCQueryEngine::instance()->update_OCC_map(old_surface, new_shape);
+CubitStatus OCCSurface::get_bodies(DLIList<OCCBody*>& bodies)
+   TopoDS_Face* topo_face = this->get_TopoDS_Face();
+   OCCQueryEngine* oqe = OCCQueryEngine::instance();
+   DLIList <OCCBody* > *all_bodies = oqe->BodyList;
+   TopTools_IndexedDataMapOfShapeListOfShape M;
+   OCCBody * body = NULL;
+   for(int j = 0; j <  all_bodies->size(); j++)
+     body = all_bodies->get_and_step();
+     TopoDS_Face the_face;
+     TopoDS_Shape ashape = *(body->get_TopoDS_Shape());
+     M.Clear();
+     TopExp::MapShapesAndAncestors(ashape, TopAbs_FACE, TopAbs_COMPSOLID, M);
+     if(!M.Contains(*topo_face))
+       continue;
+     bodies.append_unique(body);
 // ********** END PUBLIC FUNCTIONS         **********
 // ********** BEGIN PROTECTED FUNCTIONS    **********
Modified: cgm/trunk/geom/OCC/OCCSurface.hpp
--- cgm/trunk/geom/OCC/OCCSurface.hpp	2009-04-21 20:57:45 UTC (rev 2853)
+++ cgm/trunk/geom/OCC/OCCSurface.hpp	2009-04-24 17:16:44 UTC (rev 2854)
@@ -335,6 +335,8 @@
   OCCBody* my_body() {return myBody;}
+  CubitStatus get_bodies(DLIList<OCCBody*> &bodies);
   virtual CubitBoolean is_parametric();
     //R CubitBoolean
     //R- CUBIT_TRUE/CUBIT_FALSE
More information about the cgma-dev mailing list
