[cgma-dev] r2851 - cgm/trunk/test
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Tue Apr 21 15:55:23 CDT 2009
Author: janehu
Date: 2009-04-21 15:55:23 -0500 (Tue, 21 Apr 2009)
New Revision: 2851
Modified:
   cgm/trunk/test/makept.cpp
   cgm/trunk/test/modify.cpp
Log:
Added a test for tweak_move curves.
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp	2009-04-21 01:29:48 UTC (rev 2850)
+++ cgm/trunk/test/makept.cpp	2009-04-21 20:55:23 UTC (rev 2851)
@@ -325,8 +325,8 @@
   filename = "point.occ";
   filetype = "OCC";
-  rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
-                                num_ents_exported, cubit_version);
+  //rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
+  //                              num_ents_exported, cubit_version);
   //check for vertex
   bodies.clean_out();
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp	2009-04-21 01:29:48 UTC (rev 2850)
+++ cgm/trunk/test/modify.cpp	2009-04-21 20:55:23 UTC (rev 2851)
@@ -152,6 +152,20 @@
   body->ref_faces(ref_faces);
   RefFace* face = gmti->make_RefFace(ref_faces.get());
   RefFace* face2 = gmti->make_RefFace(ref_faces.get());
+  RefFace* tweak_face = gmti->make_RefFace(ref_faces.get());
+  DLIList<RefEdge*> tweak_edges;
+  tweak_face->ref_edges(tweak_edges);
+  tweak_edges.pop();
+  Body* tweak_body = tweak_face->body();
+  away *= 3;
+  gti->translate(tweak_body, away);
+  away /= 3;
+  CubitVector delta(0,0,1);
+  DLIList<Body*> tweak_bodies;
+  gmti->tweak_move( tweak_edges, delta, tweak_bodies, CUBIT_FALSE,
+                    CUBIT_FALSE);
   Body* sheet_body = face->body();
   Body* sheet_body2 = face2->body();
   away *= 5;
@@ -258,7 +272,7 @@
-  assert(num_ents_exported == 4);
+  assert(num_ents_exported == 5);
   DLIList<Body*> bodies;
   DLIList<RefEntity*>  free_entities;
@@ -987,6 +1001,7 @@
   RefFace* draft_face = gmti->make_RefFace(sweep_face);
   RefFace* perp_face = gmti->make_RefFace(sweep_face);
   RefFace* rotate_face = gmti->make_RefFace(sweep_face);
   gmti->sweep_translational(refentities, v_move8, 0, 1, CUBIT_FALSE, CUBIT_FALSE);
   body = CAST_TO(refentities.get(), Body);
   d = body->measure();
More information about the cgma-dev mailing list
