[cgma-dev] r2833 - cgm/trunk/geom
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Fri Apr 17 09:49:59 CDT 2009
Author: janehu
Date: 2009-04-17 09:49:59 -0500 (Fri, 17 Apr 2009)
New Revision: 2833
Modified:
   cgm/trunk/geom/RefFace.cpp
   cgm/trunk/geom/RefFace.hpp
Log:
Added the code for is_closed_in_ V or U direction for RefFaces.
Modified: cgm/trunk/geom/RefFace.cpp
--- cgm/trunk/geom/RefFace.cpp	2009-04-17 13:49:20 UTC (rev 2832)
+++ cgm/trunk/geom/RefFace.cpp	2009-04-17 14:49:59 UTC (rev 2833)
@@ -1640,6 +1640,14 @@
       normal_tolerance, distance_tolerance, longest_edge );
+CubitBoolean RefFace::is_closed_in_U()
+  Surface* surface_ptr = get_surface_ptr();
+  return surface_ptr->is_closed_in_U();
+CubitBoolean RefFace::is_closed_in_V()
+  return surface_ptr->is_closed_in_V();
Modified: cgm/trunk/geom/RefFace.hpp
--- cgm/trunk/geom/RefFace.hpp	2009-04-17 13:49:20 UTC (rev 2832)
+++ cgm/trunk/geom/RefFace.hpp	2009-04-17 14:49:59 UTC (rev 2833)
@@ -417,8 +417,8 @@
     //- Determines if the surface is singular in a given direction
     //- at a given parameter value.
-  CubitBoolean is_closed_in_U(){};
-  CubitBoolean is_closed_in_V(){};
+  CubitBoolean is_closed_in_U();
+  CubitBoolean is_closed_in_V();
     //R CubitBoolean
     //R- CUBIT_TRUE/CUBIT_FALSE
     //- Determines if the surface is closed, smoothly or not in the
More information about the cgma-dev mailing list
