[cgma-dev] r2816 - cgm/trunk/test
jiangtao_ma at yahoo.com
Mon Apr 13 13:20:51 CDT 2009
Author: janehu
Date: 2009-04-13 13:20:51 -0500 (Mon, 13 Apr 2009)
New Revision: 2816
Modified:
cgm/trunk/test/hollow_acis.cpp
cgm/trunk/test/modify.cpp
cgm/trunk/test/r_w.cpp
Log:
Added asserts for testcases to detect possible test failures.
Modified: cgm/trunk/test/hollow_acis.cpp
--- cgm/trunk/test/hollow_acis.cpp 2009-04-13 15:09:21 UTC (rev 2815)
+++ cgm/trunk/test/hollow_acis.cpp 2009-04-13 18:20:51 UTC (rev 2816)
@@ -127,6 +127,9 @@
gti->bodies(new_bodies);
double d = new_bodies.get()->measure(); //d = 518.3627
int n = new_bodies.get()->num_ref_faces(); //n = 5
+ assert(n == 5);
+ assert(d-518.3627 < 0.0001);
//find the top most surface as the opening of the thick body.
DLIList<RefFace*> ref_faces;
new_bodies.get()->ref_faces(ref_faces);
@@ -147,6 +150,8 @@
//Destroyed volume(s): 1
n = new_bodies.get()->num_ref_faces(); //n = 9
d = new_bodies.get()->measure(); //d = 72.4074
+ assert(n == 9);
+ assert(d - 72.4074 < 0.0001);
return stat ;
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2009-04-13 15:09:21 UTC (rev 2815)
+++ cgm/trunk/test/modify.cpp 2009-04-13 18:20:51 UTC (rev 2816)
@@ -145,7 +145,7 @@
ref_vertices2.append(ref_vertices.pop());
CubitStatus status = gmti->tweak_fillet(ref_vertices2, 1, new_bodies);
- //status = failure
+ assert(status == CUBIT_FAILURE);
//make a sheet surfaces to do fillet on vertices
@@ -170,13 +170,13 @@
DLIList<RefEdge*> ref_edges_check;
new_bodies.get()->ref_edges(ref_edges_check);
isize=ref_edges_check.size();
- //isize = 6
+ assert(isize == 6);
status = gmti->tweak_chamfer(ref_vertices, 1, new_bodies);
ref_edges_check.clean_out();
- //isize = 8
+ assert(isize == 8);
ref_vertices.clean_out();
face2->ref_vertices(ref_vertices);
@@ -191,7 +191,7 @@
- //isize = 5
+ assert(isize == 5);
new_bodies.clean_out();
gmti->tweak_fillet(ref_edges, 1, new_bodies, CUBIT_FALSE, CUBIT_FALSE);
@@ -199,14 +199,14 @@
ref_edges.clean_out();
new_bodies.get()->ref_edges(ref_edges);
isize=ref_edges.size();
- //isize = 21
+ assert(isize == 21);
body2->ref_edges(ref_edges);
- //isize = 12
+ assert(isize == 12);
for(int i = 2; i < isize; i++)
ref_edges.pop();
@@ -215,7 +215,7 @@
- //isize = 17
+ assert(isize == 17);
ref_vertices2.clean_out();
@@ -232,7 +232,7 @@
ref_vertices2.get()->ref_edges(ref_edges);
status = gmti->tweak_chamfer(ref_vertices2, 1, new_bodies, ref_edges.pop(),
0.7, ref_edges.pop(), 0.5, ref_edges.pop());
- //status = failure.
ref_vertices.append(ref_vertices2.pop());
@@ -247,7 +247,7 @@
- //isize = 26
+ assert(isize == 26);
CubitStatus rsl = CUBIT_SUCCESS;
DLIList<RefEntity*> ref_entity_list;
@@ -258,6 +258,7 @@
rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
num_ents_exported, cubit_version);
+ assert(num_ents_exported == 4);
DLIList<Body*> bodies;
DLIList<RefEntity*> free_entities;
@@ -275,6 +276,8 @@
CubitVector v3(0, 8.0, 0.0);
RefEdge* edge6 = gmti->make_RefEdge(ARC_CURVE_TYPE, vert1, vert2, &v3, CUBIT_FORWARD );
double d = edge6->measure();
+ assert(d - 22.14297 < 0.00001);
DLIList<RefEntity*> listVertexEdge;
edge6->get_child_ref_entities(listVertexEdge);
int numVertexEdge = listVertexEdge.size();
@@ -330,10 +333,12 @@
test_face = gmti->make_RefFace(ref_faces.get());
surface_list.append(test_face->get_surface_ptr());
CubitVector v_test(-5,0,0);
- CubitVector normal;
+ CubitVector normal, test_normal(-1,0,0);
normal = test_face->normal_at(v_test); //(-1,0,0)
+ assert(normal == test_normal);
ome->flip_normals(surface_list);
normal = test_face->normal_at(v_test); //(1,0, 0)
+ assert(normal == -test_normal);
bodies.clean_out();
test_face->bodies(bodies);
gti->delete_Body(bodies);
@@ -364,8 +369,8 @@
//GeometryModifyEngine *gme = gmti->get_engine(occ_surfaces.get());
gmti->create_solid_bodies_from_surfs(face_list, new_bodies);
- //Created volume(s): 12
- //Destroyed volume(s): 5 to 10
+ //Created volume(s): 13
+ //Destroyed volume(s): 6 to 11
ref_entity_list.clean_out();
num_ents_exported=0;
@@ -373,6 +378,7 @@
+ assert(num_ents_exported == 1);
gti->bodies(bodies);
free_entities.clean_out();
@@ -409,29 +415,33 @@
Body* from_body2 = gmti->cylinder(8, 4, 2, 0);
Body* tool_body = gmti->cylinder(10, 1, 1, 1);
d = from_body->measure(); //d = 219.91
+ assert(d - 219.91 < 0.01);
bodysm = from_body->get_body_sm_ptr();
CubitVector center1;
CAST_TO(bodysm, OCCBody)->mass_properties(center1, d);
d = from_body2->measure();//d = 67.02
+ assert(d - 67.02 < 0.01);
d = tool_body->measure(); //d = 31.41
+ assert(d - 31.41 < 0.01);
// test for sphere making
Body* test_body = gmti->sphere(5);
d = test_body->measure(); //d = 523.598
+ assert(d - 523.598 < 0.01);
//test for prism making
test_body = gmti->prism(10, 4, 4,2);
d = test_body->measure(); //d = 320
+ assert(-d + 320 < 0.1);
//test for pyramid making
test_body = gmti->pyramid(10, 4, 5, 2, 3);
- d = test_body->measure(); //d = 320
+ d = test_body->measure(); //d = 130.6666
+ assert(d - 130.666 < 0.001);
//test for torus making
test_body = gmti->torus(10,5);
d = test_body->measure(); //d = 4934.8
+ assert(d - 4934.8 < 0.1);
//test for planar_sheet making
CubitVector p1(0, 0, 0);
CubitVector p2(0, 0, 1);
@@ -439,7 +449,7 @@
CubitVector p4(0, 1, 0);
test_body = gmti->planar_sheet(p1, p2, p3, p4);
+ assert(1-d < 0.001);
bodies.clean_out();
//delete all entities
@@ -461,21 +471,26 @@
rsl = gmti->subtract(from_body2, from_bodies, new_bodies,
CUBIT_TRUE, CUBIT_FALSE);
- //Updated volume(s): 22
- //Destroyed volume(s): 23
+ //Updated volume(s): 23
+ //Destroyed volume(s): 24
//new bodies has one body, new body has 10 ref-faces, 5 of them are remaining
//with old id, 5 of them are new faces.
+ assert(new_bodies.size() == 1);
+ assert(new_bodies.get()->num_ref_faces() == 10);
from_bodies=new_bodies;
rsl = gmti->subtract(tool_body,from_bodies, new_bodies,
- //Created volume(s): 25, 26
- //Destroyed volume(s): 22, 24
+ //Created volume(s): 26, 27
+ //Destroyed volume(s): 23, 25
d = new_bodies.step_and_get()->measure(); //d = 50
v = new_bodies.get()->center_point(); //v = (7.5, 5, .05)
- // n = 6
+ assert( n == 6);
+ assert (50 -d < 0.0001);
+ CubitVector test_v(7.5, 5, .5);
+ assert (v == test_v);
//new bodies has 2 bodies, one has a volume = 10 and the other has a
//volume = 50; each of them has 6 ref_faces, of which 3 are new and 3 are
//remaining (unchanged or modified).
@@ -506,7 +521,8 @@
from_bodies.append(cp_from_body);
CubitStatus stat = gmti->imprint(from_bodies, ref_edges, new_bodies, CUBIT_FALSE, CUBIT_TRUE );
- //Updated volume(s): 29
+ //Updated volume(s): 30
+ //assert(new_bodies.get()->num_ref_faces() == 6);
//test edge imprint on surface
CubitVector vv(5,1,4.0);
@@ -524,8 +540,9 @@
assert(face_list.size() == 1);
ref_edges.step_and_get()->ref_vertices(vertices);
+ new_bodies.clean_out();
stat = gmti->imprint(unimprint_faces, ref_edges, new_bodies, CUBIT_FALSE);
- //Updated volume(s): 30
+ //Updated volume(s): 31
face_list.clean_out();
@@ -551,15 +568,16 @@
from_bodies.append(cp_from_body2);
stat = gmti->imprint(from_bodies, vectors, new_bodies, CUBIT_FALSE);
n = new_bodies.get()->num_ref_edges();//n = 17
+ assert( n == 17);
stat = gmti->imprint(face_list, ref_edges, new_bodies, CUBIT_FALSE);
n = new_bodies.get()->num_ref_edges();//n = 21
+ assert( n == 21);
//test for multi-cut imprint for subtract.
from_bodies.clean_out();
@@ -567,13 +585,13 @@
rsl = gmti->subtract(tool_body, from_bodies, new_bodies,
- //Updated volume(s): 27
- //Destroyed volume(s): 28
+ //Updated volume(s): 28
+ //Destroyed volume(s): 29
- //n = 8
+ assert(n == 8);
- //n = 18
+ assert(n == 18);
bodies.clean_out();
@@ -614,7 +632,8 @@
//test stitch surfaces operation
ome->stitch_surfs(body_list, bodysm);
+ assert(bodysm != NULL);
bodies.clean_out();
bodies.append(tool_body);
@@ -625,12 +644,18 @@
ref_faces.clean_out();
test_body->ref_faces(ref_faces);
normal = ref_faces.get()->normal_at(v1); //(1,0,0)
+ CubitVector test_normal0(1,0,0);
+ assert(normal == test_normal0);
normal = ref_faces.step_and_get()->normal_at(v2); //(0,0,1)
+ CubitVector test_normal2(0,0,1);
+ assert(normal == test_normal2);
surfaces.clean_out();
surfaces.append(ref_faces.step_and_get()->get_surface_ptr());
ome->flip_normals(surfaces);
normal = ref_faces.get()->normal_at(v1); //(-1,0,0)
gti->delete_Body(test_body);
@@ -646,7 +671,7 @@
from_bodies.append(copy_tool_body);
from_bodies.append(from_body2);
stat = gmti->imprint(from_bodies, new_bodies, CUBIT_FALSE);
- //Updated volume(s): 35 one body gets cut once with 7 faces, the other is not
+ //Updated volume(s): 35 no cuts performed
//test body imprinted by curves.
@@ -655,7 +680,7 @@
from_bodies.append(copy_tool_body2);
- //Updated volume(s): 36, no cuts performed
+ //Updated volume(s): 37, 1 cut performed
//test body cutting a shell, one surface got cut as the result.
CubitVector v_move6(1,-1,0);
@@ -665,12 +690,15 @@
CUBIT_TRUE, CUBIT_TRUE);
- //Created volume(s): 37
+ //Created volume(s): 38
- // n = 1
+ assert( n == 1);
+ assert(1-d<0.00001);
+ CubitVector test_v1(0.5,0.5,1);
+ assert(v == test_v1);
from_bodies.append(tool_body);
@@ -680,6 +708,7 @@
//WARNING: Surfaces or Shells can't be used to cut a body.
//ERROR: Subtract FAILED
+ assert (rsl == CUBIT_FAILURE);
//test solid solid imprint
tool_body = gmti->brick(4, 4, 4);
@@ -692,7 +721,7 @@
from_bodies.append(from_body);
- //Updated volume(s): 38, 39
+ //Updated volume(s): 39, 40
//one body gets 4 cuts, the other 3.
//one body gets 10 faces, the other 9.
Modified: cgm/trunk/test/r_w.cpp
--- cgm/trunk/test/r_w.cpp 2009-04-13 15:09:21 UTC (rev 2815)
+++ cgm/trunk/test/r_w.cpp 2009-04-13 18:20:51 UTC (rev 2816)
@@ -125,7 +125,8 @@
if (type.empty()) // just guess OCC
type = "OCC";
std::string filename( local ? "./" : SRCPATH );
- filename += argv[i];
+ char const* local_name = argv[i];
+ filename += local_name;
status = gti->import_solid_model(filename.c_str(), type.c_str());
if (status != CUBIT_SUCCESS) {
PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str());
@@ -164,6 +165,7 @@
//Exported: 18 OCC Curves to ex3.occ
+ assert(num_ents_exported == 18);
filetype = "IGES";
filename = "ex3export.iges";
@@ -172,6 +174,7 @@
//Exported: 18 OCC Curves to ex3export.iges
filetype = "STEP";
filename = "ex3export.step";
@@ -179,6 +182,7 @@
//Exported: 18 OCC Curves to ex3export.step
@@ -207,6 +211,7 @@
//Exported: 7 OCC Bodies to diffuser.occ
+ assert(num_ents_exported == 7);
@@ -234,6 +239,7 @@
//Exported: 12 OCC Bodies to proe.occ
+ assert(num_ents_exported == 12);
filetype = "IGES";
filename = "proeexport.iges";
@@ -241,6 +247,7 @@
//Exported: 12 OCC Bodies to proeexport.iges
filetype = "STEP";
filename = "proeexport.step";
@@ -248,6 +255,7 @@
//Exported: 12 OCC Bodies to proeexport.step
@@ -275,6 +283,8 @@
+ assert(num_ents_exported == 2);
@@ -300,6 +310,7 @@
bodies.clean_out();
DLIList<Body*> new_bodies;
@@ -313,6 +324,10 @@
double d = new_bodies.step_and_get()->measure();
CubitVector v = new_bodies.get()->center_point();
+ assert (n == 6);
+ CubitVector test_v(7.5, 5,0.5);
+ assert (50-d < 0.000000001);
// n = 6
@@ -324,6 +339,7 @@
bodies.clean_out();
@@ -350,6 +366,7 @@
bodies.clean_out();
@@ -379,6 +396,7 @@
num_ents_exported = 0;
bodies.clean_out();
@@ -406,6 +424,7 @@
bodies.clean_out();
@@ -434,7 +453,8 @@
bodies.clean_out();
More information about the cgma-dev
