[cgma-dev] r2811 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Apr 10 13:58:26 CDT 2009
Author: janehu
Date: 2009-04-10 13:58:17 -0500 (Fri, 10 Apr 2009)
New Revision: 2811
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Fixed memory error for modify testcase.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-04-10 16:07:48 UTC (rev 2810)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-04-10 18:58:17 UTC (rev 2811)
@@ -2002,185 +2002,189 @@
//list of face on from_shape that has been imprinted
DLIList<TopoDS_Face*> from_faces;
while( more_face)
- TopoDS_Face from_face,tool_face;
- TopoDS_Edge* common_edge = NULL;
- DLIList<TopoDS_Shape*> tool_faces_edges;
- TopTools_ListOfShape list_of_edges;
- BRepFeat_SplitShape splitor(*from_shape);
- CubitBoolean qualified = CUBIT_TRUE;
- if (tool_shape->TShape()->ShapeType() == TopAbs_EDGE)
- if(count == 1)
- break;
+ TopoDS_Face from_face,tool_face;
+ TopoDS_Edge* common_edge = NULL;
+ DLIList<TopoDS_Shape*> tool_faces_edges;
+ TopTools_ListOfShape list_of_edges;
+ BRepFeat_SplitShape splitor(*from_shape);
+ CubitBoolean qualified = CUBIT_TRUE;
+ if (tool_shape->TShape()->ShapeType() == TopAbs_EDGE)
+ if(count == 1)
+ break;
- DLIList<TopoDS_Face*> faces;
- //need to delete TopoDS_Face* in faces
- common_edge = find_imprinting_edge(*from_shape, TopoDS::Edge(*tool_shape),faces);
- if (common_edge)
- if (on_faces)
- qualified = CUBIT_FALSE;
- for(int j = 0; j < faces.size(); j++)
- from_face = *faces.get();
- for (int i = 0; on_faces && i < on_faces->size(); i++)
- if (from_face.IsSame(*(on_faces->get_and_step())))
- qualified = CUBIT_TRUE;
- break;
- faces.get()->Nullify();
- delete faces.get();
- faces.step();
- if (qualified && (from_faces.size() == 0 || (from_faces.size() && !from_face.IsSame(*from_faces.get()))) )
- list_of_edges.Append(*common_edge);
- else
- from_face.Nullify();
- common_edge->Nullify();
- delete common_edge;
- else
- TopOpeBRep_ShapeIntersector intersector;
- intersector.InitIntersection(*from_shape, *tool_shape);
- //find the intersecting edges and faces.
- int max_edge = 0;
- for(; intersector.MoreIntersection(); intersector.NextIntersection())
+ DLIList<TopoDS_Face*> faces;
+ //need to delete TopoDS_Face* in faces
+ common_edge = find_imprinting_edge(*from_shape, TopoDS::Edge(*tool_shape),faces);
+ if (common_edge)
+ if (on_faces)
+ qualified = CUBIT_FALSE;
+ for(int j = 0; j < faces.size(); j++)
+ from_face = *faces.get();
+ for (int i = 0; on_faces && i < on_faces->size(); i++)
+ if (from_face.IsSame(*(on_faces->get_and_step())))
+ qualified = CUBIT_TRUE;
+ break;
+ faces.get()->Nullify();
+ delete faces.get();
+ faces.step();
+ if (qualified && (from_faces.size() == 0 || (from_faces.size() && !from_face.IsSame(*from_faces.get()))) )
+ list_of_edges.Append(*common_edge);
+ else
+ from_face.Nullify();
+ common_edge->Nullify();
+ delete common_edge;
+ else
- TopoDS_Shape face1;
- face1 = intersector.ChangeFacesIntersector().Face(1);
- CubitBoolean has_imprinted = CUBIT_FALSE;
- for (int j = 0; j < from_faces.size(); j++)
- TopoDS_Face* topo_face = from_faces.get_and_step();
- if(face1.IsSame(*topo_face))
- has_imprinted = CUBIT_TRUE;
- break;
+ TopOpeBRep_ShapeIntersector intersector;
+ intersector.InitIntersection(*from_shape, *tool_shape);
- if (has_imprinted)
- continue;
+ //find the intersecting edges and faces.
+ int max_edge = 0;
+ for(; intersector.MoreIntersection(); )
+ TopoDS_Shape face1;
+ face1 = intersector.ChangeFacesIntersector().Face(1);
+ CubitBoolean has_imprinted = CUBIT_FALSE;
+ for (int j = 0; j < from_faces.size(); j++)
+ TopoDS_Face* topo_face = from_faces.get_and_step();
+ if(face1.IsSame(*topo_face))
+ has_imprinted = CUBIT_TRUE;
+ break;
- TopoDS_Shape edge_face;
+ if (has_imprinted == CUBIT_TRUE)
+ intersector.NextIntersection();
+ continue;
+ TopoDS_Shape edge_face;
- edge_face = intersector.ChangeFacesIntersector().Face(2);
- BRepAlgoAPI_Section section(face1, edge_face);
+ edge_face = intersector.ChangeFacesIntersector().Face(2);
+ BRepAlgoAPI_Section section(face1, edge_face);
- //intersection edges between face1 and edge_face
- TopTools_ListOfShape temp_list_of_edges;
- temp_list_of_edges.Assign(section.SectionEdges());
- int num_edges = temp_list_of_edges.Extent();
+ //intersection edges between face1 and edge_face
+ TopTools_ListOfShape temp_list_of_edges;
+ temp_list_of_edges.Assign(section.SectionEdges());
+ int num_edges = temp_list_of_edges.Extent();
- CubitBoolean is_same = face1.IsSame(from_face);
- CubitBoolean is_same_tool = CUBIT_FALSE;
- for (int j = 0; j < tool_faces_edges.size(); j++)
- TopoDS_Shape* topo_face_edge = tool_faces_edges.get_and_step();
- if(edge_face.IsSame(*topo_face_edge))
- is_same_tool = CUBIT_TRUE;
- break;
+ CubitBoolean is_same = face1.IsSame(from_face);
+ CubitBoolean is_same_tool = CUBIT_FALSE;
+ for (int j = 0; j < tool_faces_edges.size(); j++)
+ TopoDS_Shape* topo_face_edge = tool_faces_edges.get_and_step();
+ if(edge_face.IsSame(*topo_face_edge))
+ is_same_tool = CUBIT_TRUE;
+ break;
+ if (max_edge < num_edges )
+ list_of_edges.Assign(temp_list_of_edges);
+ max_edge = num_edges ;
+ from_face = TopoDS::Face(face1);
+ TopoDS_Shape* topo_shape = new TopoDS_Shape(edge_face);
+ DLIList<TopoDS_Shape*> shape_list;
+ for(int iii = 0; iii < tool_faces_edges.size(); iii++)
+ int size = shape_list.size();
+ shape_list.append_unique(tool_faces_edges.get_and_step());
+ if (size < shape_list.size())
+ shape_list.last();
+ shape_list.get()->Nullify();
+ delete shape_list.get();
+ tool_faces_edges.clean_out();
+ for(int i = 0 ; i < num_edges; i++)
+ //later has to use it num_edges times
+ tool_faces_edges.append(topo_shape);
+ else if(num_edges == max_edge && is_same && !is_same_tool)
+ //multi tool faces cut the same face
+ TopTools_ListIteratorOfListOfShape Itor, temp_Itor;
+ temp_Itor.Initialize(temp_list_of_edges);
+ for(; temp_Itor.More(); temp_Itor.Next())
+ TopoDS_Edge temp_edge = TopoDS::Edge(temp_Itor.Value());
+ Itor.Initialize(list_of_edges);
+ CubitBoolean same_edge = CUBIT_FALSE;
+ GProp_GProps myProps1;
+ BRepGProp::LinearProperties(temp_edge, myProps1);
+ gp_Pnt center1 = myProps1.CentreOfMass();
+ for(; Itor.More(); Itor.Next())
+ TopoDS_Edge edge = TopoDS::Edge(Itor.Value());
+ GProp_GProps myProps2;
+ BRepGProp::LinearProperties(edge, myProps2);
+ gp_Pnt center2 = myProps2.CentreOfMass();
+ if(center1.IsEqual(center2, TOL))
+ same_edge = CUBIT_TRUE;
+ break;
+ if(!same_edge)
+ list_of_edges.Append(temp_edge);
+ }//end 'for'
+ }//end 'else if'
+ } //end 'for'
+ }//end 'else'
+ if (from_face.IsNull())
+ more_face = CUBIT_FALSE;
- if (max_edge < num_edges )
+ for (int iii=0; iii < from_faces.size(); iii++)
- list_of_edges.Assign(temp_list_of_edges);
- max_edge = num_edges ;
- from_face = TopoDS::Face(face1);
- TopoDS_Shape* topo_shape = new TopoDS_Shape(edge_face);
- DLIList<TopoDS_Shape*> shape_list;
- for(int iii = 0; iii < tool_faces_edges.size(); iii++)
- int size = shape_list.size();
- shape_list.append_unique(tool_faces_edges.get_and_step());
- if (size < shape_list.size())
- shape_list.last();
- shape_list.get()->Nullify();
- delete shape_list.get();
- tool_faces_edges.clean_out();
- for(int i = 0 ; i < num_edges; i++)
- //later has to use it num_edges times
- tool_faces_edges.append(topo_shape);
+ topo_face->Nullify();
+ delete topo_face;
- else if(num_edges == max_edge && is_same && !is_same_tool)
- //multi tool faces cut the same face
- TopTools_ListIteratorOfListOfShape Itor, temp_Itor;
- temp_Itor.Initialize(temp_list_of_edges);
- for(; temp_Itor.More(); temp_Itor.Next())
- TopoDS_Edge temp_edge = TopoDS::Edge(temp_Itor.Value());
- Itor.Initialize(list_of_edges);
- CubitBoolean same_edge = CUBIT_FALSE;
- GProp_GProps myProps1;
- BRepGProp::LinearProperties(temp_edge, myProps1);
- gp_Pnt center1 = myProps1.CentreOfMass();
- for(; Itor.More(); Itor.Next())
- TopoDS_Edge edge = TopoDS::Edge(Itor.Value());
- GProp_GProps myProps2;
- BRepGProp::LinearProperties(edge, myProps2);
- gp_Pnt center2 = myProps2.CentreOfMass();
- if(center1.IsEqual(center2, TOL))
- same_edge = CUBIT_TRUE;
- break;
- if(!same_edge)
- list_of_edges.Append(temp_edge);
+ for (int iii=0; iii < list_for_delete.size(); iii++)
+ TopoDS_Face* topo_face = list_for_delete.get_and_step();
+ delete topo_face;
+ continue;
- if (from_face.IsNull())
- more_face = CUBIT_FALSE;
- for (int iii=0; iii < from_faces.size(); iii++)
- topo_face->Nullify();
- delete topo_face;
- for (int iii=0; iii < list_for_delete.size(); iii++)
- TopoDS_Face* topo_face = list_for_delete.get_and_step();
- delete topo_face;
- continue;
TopTools_ListIteratorOfListOfShape Itor;
@@ -2199,298 +2203,298 @@
Surface* face = NULL;
if (OCCQueryEngine::instance()->OCCMap->IsBound(from_face))
- int i = OCCQueryEngine::instance()->OCCMap->Find(from_face);
- face = (OCCSurface*)(OCCQueryEngine::instance()->OccToCGM->find(i))->second;
+ int i = OCCQueryEngine::instance()->OCCMap->Find(from_face);
+ face = (OCCSurface*)(OCCQueryEngine::instance()->OccToCGM->find(i))->second;
else
face = OCCQueryEngine::instance()->populate_topology_bridge(from_face);
OCCSurface* occ_face = CAST_TO(face, OCCSurface);
DLIList<Curve*> common_curves;
- //copy the edge for imprinting.
- BRepBuilderAPI_Copy api_copy(edge);
- TopoDS_Shape newShape = api_copy.ModifiedShape(edge);
- edge = TopoDS::Edge(newShape);
- Curve* curve = NULL;
- curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
- if(curve)
- common_curves.append(curve);
+ //copy the edge for imprinting.
+ BRepBuilderAPI_Copy api_copy(edge);
+ TopoDS_Shape newShape = api_copy.ModifiedShape(edge);
+ edge = TopoDS::Edge(newShape);
+ Curve* curve = NULL;
+ curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
+ if(curve)
+ common_curves.append(curve);
DLIList<DLIList<TopoDS_Edge*>*> temp_edge_lists;
list_of_edges.Clear();
if (common_curves.size() >= 1)
- sort_curves(common_curves, temp_edge_lists);
- DLIList<TopoDS_Edge*>* edge_list;
- int size = temp_edge_lists.size();
- for(int i = 0; i < size; i++)
- edge_list = temp_edge_lists.pop();
- //make sure the copied edges are sharing vertices.
- BRepBuilderAPI_MakeWire myWire;
- edge_list->reset();
- for(int i = 0; i < edge_list->size(); i++)
- TopoDS_Edge e = *(edge_list->get_and_step());
- myWire.Add(e);
- TopoDS_Wire wire = myWire.Wire();
- BRepTools_WireExplorer Ex(wire);
- for(; Ex.More(); Ex.Next())
- list_of_edges.Append(Ex.Current());
+ sort_curves(common_curves, temp_edge_lists);
+ DLIList<TopoDS_Edge*>* edge_list;
+ int size = temp_edge_lists.size();
+ for(int i = 0; i < size; i++)
+ edge_list = temp_edge_lists.pop();
+ //make sure the copied edges are sharing vertices.
+ BRepBuilderAPI_MakeWire myWire;
+ edge_list->reset();
+ for(int i = 0; i < edge_list->size(); i++)
+ TopoDS_Edge e = *(edge_list->get_and_step());
+ myWire.Add(e);
+ TopoDS_Wire wire = myWire.Wire();
+ BRepTools_WireExplorer Ex(wire);
+ for(; Ex.More(); Ex.Next())
+ list_of_edges.Append(Ex.Current());
for(Itor.Initialize(list_of_edges); Itor.More(); Itor.Next())
- //check to see if the intersection edge is on from_face
- TopExp_Explorer Ex;
- CubitBoolean added = CUBIT_FALSE;
- CubitBoolean skipped = CUBIT_FALSE;
- BRepGProp::LinearProperties(edge, myProps1);
- double d1 = myProps1.Mass();
- gp_Pnt pt = myProps1.CentreOfMass();
- CubitVector p(pt.X(), pt.Y(), pt.Z());
+ //check to see if the intersection edge is on from_face
+ TopExp_Explorer Ex;
+ CubitBoolean added = CUBIT_FALSE;
+ CubitBoolean skipped = CUBIT_FALSE;
+ BRepGProp::LinearProperties(edge, myProps1);
+ double d1 = myProps1.Mass();
+ gp_Pnt pt = myProps1.CentreOfMass();
+ CubitVector p(pt.X(), pt.Y(), pt.Z());
- CubitVector point_on_surf;
- occ_face->closest_point_trimmed(p, point_on_surf);
- if(p.distance_between(point_on_surf) > TOL) //edge not on from_face
- skipped = CUBIT_TRUE;
- total_edges--;
+ CubitVector point_on_surf;
+ occ_face->closest_point_trimmed(p, point_on_surf);
+ if(p.distance_between(point_on_surf) > TOL) //edge not on from_face
+ skipped = CUBIT_TRUE;
+ total_edges--;
- else
- for (Ex.Init(from_face, TopAbs_EDGE); Ex.More(); Ex.Next())
- //check if the edge is on from_face edges, add such edge on existing
- //edge to split it.
- TopoDS_Edge from_edge = TopoDS::Edge(Ex.Current());
+ else
+ for (Ex.Init(from_face, TopAbs_EDGE); Ex.More(); Ex.Next())
+ //check if the edge is on from_face edges, add such edge on existing
+ //edge to split it.
+ TopoDS_Edge from_edge = TopoDS::Edge(Ex.Current());
- BRepGProp::LinearProperties(from_edge, myProps2);
- double d2 = myProps2.Mass();
- if (OCCQueryEngine::instance()->OCCMap->IsBound(from_edge))
- int i = OCCQueryEngine::instance()->OCCMap->Find(from_edge);
- curve = (OCCCurve*)(OCCQueryEngine::instance()->OccToCGM->find(i))->second;
- else
- curve = OCCQueryEngine::instance()->populate_topology_bridge(from_edge);
- OCCCurve* occ_curve = CAST_TO(curve, OCCCurve);
+ BRepGProp::LinearProperties(from_edge, myProps2);
+ double d2 = myProps2.Mass();
+ if (OCCQueryEngine::instance()->OCCMap->IsBound(from_edge))
+ int i = OCCQueryEngine::instance()->OCCMap->Find(from_edge);
+ curve = (OCCCurve*)(OCCQueryEngine::instance()->OccToCGM->find(i))->second;
+ else
+ curve = OCCQueryEngine::instance()->populate_topology_bridge(from_edge);
+ OCCCurve* occ_curve = CAST_TO(curve, OCCCurve);
- CubitPointContainment pc = CUBIT_PNT_OFF;
- if(occ_curve->geometry_type() == STRAIGHT_CURVE_TYPE)
- pc = occ_curve->point_containment(p);
+ CubitPointContainment pc = CUBIT_PNT_OFF;
+ if(occ_curve->geometry_type() == STRAIGHT_CURVE_TYPE)
+ pc = occ_curve->point_containment(p);
- if(pc == CUBIT_PNT_ON) //overlap
- //check if they are the same edge, so don't need to be split
- //the overlapped edges are considered the same if they have the
- //same length
- if((d2 - d1) > TOL)
- added = CUBIT_TRUE;
- splitor.Add(edge, from_edge);
- else
- total_edges--;
- break;
+ if(pc == CUBIT_PNT_ON) //overlap
+ //check if they are the same edge, so don't need to be split
+ //the overlapped edges are considered the same if they have the
+ //same length
+ if((d2 - d1) > TOL)
+ added = CUBIT_TRUE;
+ splitor.Add(edge, from_edge);
+ else
+ total_edges--;
+ break;
+ else if(list_of_edges.Extent() == 1 && (d2 - d1) <= TOL)
+ if(list_of_edges.Extent() == 1 && !skipped)
+ Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
+ curve_list.append(curve);
+ if(added)
+ topo_changed = CUBIT_TRUE;
+ continue;
- else if(list_of_edges.Extent() == 1 && (d2 - d1) <= TOL)
- if(list_of_edges.Extent() == 1 && !skipped)
- Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
- curve_list.append(curve);
- if(added)
- topo_changed = CUBIT_TRUE;
- continue;
- if (!skipped)
- //check if edge's inside from_face by checking bounding boxes
- BRepAdaptor_Curve acurve(edge);
- BRepAdaptor_Surface asurface( from_face);
- Bnd_Box aBox_edge, aBox_face;
- BndLib_Add3dCurve::Add(acurve, Precision::Approximation(), aBox_edge);
- BndLib_AddSurface::Add(asurface, Precision::Approximation(), aBox_face);
- double min[3], max[3];
- aBox_edge.Get( min[0], min[1], min[2], max[0], max[1], max[2]);
- CubitBox aBox_e(min, max);
- aBox_face.Get( min[0], min[1], min[2], max[0], max[1], max[2]);
- CubitBox aBox_f(min, max);
- if (aBox_e <= aBox_f)
+ if (!skipped)
+ //check if edge's inside from_face by checking bounding boxes
+ BRepAdaptor_Curve acurve(edge);
+ BRepAdaptor_Surface asurface( from_face);
+ Bnd_Box aBox_edge, aBox_face;
+ BndLib_Add3dCurve::Add(acurve, Precision::Approximation(), aBox_edge);
+ BndLib_AddSurface::Add(asurface, Precision::Approximation(), aBox_face);
+ double min[3], max[3];
+ aBox_edge.Get( min[0], min[1], min[2], max[0], max[1], max[2]);
+ CubitBox aBox_e(min, max);
+ aBox_face.Get( min[0], min[1], min[2], max[0], max[1], max[2]);
+ CubitBox aBox_f(min, max);
+ if (aBox_e <= aBox_f)
DLIList<DLIList<TopoDS_Edge*>*> edge_lists;
if (total_edges >= 1)
CubitStatus stat = CUBIT_SUCCESS;
if(curve_list.size() > 0)
- stat = sort_curves(curve_list, edge_lists);
+ stat = sort_curves(curve_list, edge_lists);
else
- TopoDS_Face* topo_face = new TopoDS_Face(from_face);
- from_faces.append(topo_face);
- continue;
+ TopoDS_Face* topo_face = new TopoDS_Face(from_face);
+ from_faces.append(topo_face);
+ continue;
int size = edge_lists.size();
for (int iii = 0; iii < size; iii++)
- edge_list = edge_lists.pop();
+ edge_list = edge_lists.pop();
- //check if the edges make a split of the surface, error out if it's
- //just a scar on the surface
- int count_intersection = 0;
- if (stat == CUBIT_FAILURE) //Open wire
- count_intersection = check_intersection(edge_list, from_face);
+ //check if the edges make a split of the surface, error out if it's
+ //just a scar on the surface
+ int count_intersection = 0;
+ if (stat == CUBIT_FAILURE) //Open wire
+ count_intersection = check_intersection(edge_list, from_face);
- if (count_intersection == 1 )
- PRINT_WARNING("Cant make a scar on existing face without splitting it. \n");
- if (stat)
- myWire.Add(e);
- splitor.Add(myWire.Wire(),from_face);
- break;
- for(int iii = 0; iii < edge_list->size(); iii++)
- edge_list->pop();
- delete edge_list;
+ if (count_intersection == 1 )
+ PRINT_WARNING("Cant make a scar on existing face without splitting it. \n");
+ if (stat)
+ myWire.Add(e);
+ splitor.Add(myWire.Wire(),from_face);
+ break;
+ for(int iii = 0; iii < edge_list->size(); iii++)
+ edge_list->pop();
+ delete edge_list;
if(topo_changed)
- splitor.Build();
- topo_changed = CUBIT_FALSE;
- if(splitor.IsDone())
- //take care of on_faces list first:after operation, the on_faces
- // will have at least one face changed, update the pointer.
- if (on_faces)
- for(int k = 0; k < on_faces->size(); k++)
- TopoDS_Face* compare_face = on_faces->get_and_step();
- if(from_face.IsSame(*compare_face))
- on_faces->remove(compare_face);
- TopTools_ListOfShape shapes;
- shapes.Assign(splitor.Modified(from_face));
- while(shapes.Extent() > 0)
- TopoDS_Face* face =
- new TopoDS_Face(TopoDS::Face(shapes.First()));
- shapes.RemoveFirst();
- on_faces->append(face);
- list_for_delete.append(face);
+ splitor.Build();
+ topo_changed = CUBIT_FALSE;
+ if(splitor.IsDone())
+ //take care of on_faces list first:after operation, the on_faces
+ // will have at least one face changed, update the pointer.
+ if (on_faces)
+ for(int k = 0; k < on_faces->size(); k++)
+ TopoDS_Face* compare_face = on_faces->get_and_step();
+ if(from_face.IsSame(*compare_face))
+ on_faces->remove(compare_face);
+ TopTools_ListOfShape shapes;
+ shapes.Assign(splitor.Modified(from_face));
+ while(shapes.Extent() > 0)
+ TopoDS_Face* face =
+ new TopoDS_Face(TopoDS::Face(shapes.First()));
+ shapes.RemoveFirst();
+ on_faces->append(face);
+ list_for_delete.append(face);
- TopoDS_Shape new_from_shape = splitor.Shape();
- if(from_shape->TShape()->ShapeType() == TopAbs_COMPSOLID)
- TopoDS_CompSolid old_csolid = TopoDS::CompSolid(*from_shape);
- OCCBody::update_OCC_entity(old_csolid, new_from_shape, &splitor);
- from_shape->Nullify();
- delete from_shape;
- from_shape = new TopoDS_Shape(new_from_shape);
+ TopoDS_Shape new_from_shape = splitor.Shape();
+ if(from_shape->TShape()->ShapeType() == TopAbs_COMPSOLID)
+ TopoDS_CompSolid old_csolid = TopoDS::CompSolid(*from_shape);
+ OCCBody::update_OCC_entity(old_csolid, new_from_shape, &splitor);
+ from_shape->Nullify();
+ delete from_shape;
+ from_shape = new TopoDS_Shape(new_from_shape);
- else if(from_shape->TShape()->ShapeType() == TopAbs_SOLID)
- TopoDS_Solid old_solid = TopoDS::Solid(*from_shape);
- OCCLump::update_OCC_entity(old_solid, new_from_shape, &splitor);
- else if(from_shape->TShape()->ShapeType() == TopAbs_SHELL)
- TopoDS_Shell old_shell = TopoDS::Shell(*from_shape);
- OCCShell::update_OCC_entity(old_shell,new_from_shape, &splitor);
- else if(from_shape->TShape()->ShapeType() == TopAbs_FACE)
- TopoDS_Face old_face = TopoDS::Face(*from_shape);
- OCCSurface::update_OCC_entity(old_face,new_from_shape, &splitor);
+ else if(from_shape->TShape()->ShapeType() == TopAbs_SOLID)
+ TopoDS_Solid old_solid = TopoDS::Solid(*from_shape);
+ OCCLump::update_OCC_entity(old_solid, new_from_shape, &splitor);
+ else if(from_shape->TShape()->ShapeType() == TopAbs_SHELL)
+ TopoDS_Shell old_shell = TopoDS::Shell(*from_shape);
+ OCCShell::update_OCC_entity(old_shell,new_from_shape, &splitor);
+ else if(from_shape->TShape()->ShapeType() == TopAbs_FACE)
+ TopoDS_Face old_face = TopoDS::Face(*from_shape);
+ OCCSurface::update_OCC_entity(old_face,new_from_shape, &splitor);
- for(int i = 0; i < from_faces.size(); i++)
- TopoDS_Face* topo_face = from_faces.get();
- shapes.Assign(splitor.Modified(*topo_face));
- topo_face = new TopoDS_Face(TopoDS::Face(shapes.First()));
- from_faces.get()->Nullify();
- delete from_faces.get();
- from_faces.change_to(topo_face);
- from_faces.step();
- count++;
+ for(int i = 0; i < from_faces.size(); i++)
+ TopoDS_Face* topo_face = from_faces.get();
+ shapes.Assign(splitor.Modified(*topo_face));
+ topo_face = new TopoDS_Face(TopoDS::Face(shapes.First()));
+ from_faces.get()->Nullify();
+ delete from_faces.get();
+ from_faces.change_to(topo_face);
+ from_faces.step();
+ count++;
else
TopExp_Explorer Ex;
int num_face = 0;
for (Ex.Init(*from_shape, TopAbs_FACE); Ex.More(); Ex.Next())
- TopoDS_Face face = TopoDS::Face(Ex.Current());
- num_face++;
+ TopoDS_Face face = TopoDS::Face(Ex.Current());
+ num_face++;
#ifdef DEBUG
PRINT_INFO("Total %d cuts performed, with from_shape having %d faces.\n", count, num_face);
#endif
if (count > 0)
- return CUBIT_SUCCESS;
+ return CUBIT_SUCCESS;
return CUBIT_FAILURE;
@@ -2548,7 +2552,8 @@
if (edge_list->size() == 1)
double_check = CUBIT_TRUE;
- gp_Pnt intsec_pnt[2];
+ gp_Pnt pt1(0,0,0), pt2(0,0,0);
+ gp_Pnt intsec_pnt[2] = {pt1, pt2} ;
for(int j = 0; j < edge_list->size(); j++)
TopoDS_Edge* edge = edge_list->get_and_step();
@@ -2556,7 +2561,8 @@
double lower_bound = acurve.FirstParameter();
double upper_bound = acurve.LastParameter();
TopExp_Explorer Ex;
- gp_Pnt newP[2];
+ gp_Pnt p1(0,0,0), p2(0,0,0);
+ gp_Pnt newP[2] = {p1, p2 };
@@ -2610,7 +2616,7 @@
- for(int k = 0; k < distShapeShape.NbSolution(); k++)
+ for(int k = 0; count_intersection < 3, k < distShapeShape.NbSolution(); k++)
if (qualified[k])
count_intersection++;
@@ -4274,7 +4280,8 @@
gp_Lin line = gp_Lin(axis);
TopoDS_Edge edge = BRepBuilderAPI_MakeEdge(line);
- OCCCurve* acurve = new OCCCurve(&edge);
+ TopoDS_Edge* p_edge = new TopoDS_Edge(edge);
+ OCCCurve* acurve = new OCCCurve(p_edge);
assert(acurve);
CubitVector start;
More information about the cgma-dev
