[cgma-dev] r2769 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Mar 27 13:32:03 CDT 2009
Author: janehu
Date: 2009-03-27 13:32:02 -0500 (Fri, 27 Mar 2009)
New Revision: 2769
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added remove_sliver_curve function, not tested yet.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-27 17:08:54 UTC (rev 2768)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-03-27 18:32:02 UTC (rev 2769)
@@ -73,6 +73,7 @@
#include "BRepBuilderAPI_MakeEdge.hxx"
#include "BRepAdaptor_Surface.hxx"
#include "BRepBuilderAPI_MakeFace.hxx"
+#include "ShapeExtend_Status.hxx"
#include "BRepOffsetAPI_MakeThickSolid.hxx"
#include "BRepBuilderAPI_Sewing.hxx"
#include "BRepBuilderAPI_Copy.hxx"
@@ -82,6 +83,7 @@
#include "GProp_GProps.hxx"
#include "BRepGProp.hxx"
#include "TopoDS.hxx"
+#include "ShapeFix.hxx"
#include "TopologyBridge.hpp"
#include "ProgressTool.hpp"
#include "BRepAlgoAPI_Fuse.hxx"
@@ -93,6 +95,8 @@
#include "BRepPrimAPI_MakeWedge.hxx"
#include "BRepTools_WireExplorer.hxx"
#include "Handle_Geom_TrimmedCurve.hxx"
+#include "Handle_ShapeBuild_ReShape.hxx"
+#include "ShapeBuild_ReShape.hxx"
#include "Handle_Geom_RectangularTrimmedSurface.hxx"
#include "BndLib_Add3dCurve.hxx"
#include "TopOpeBRep_EdgesIntersector.hxx"
@@ -6950,11 +6954,39 @@
return CUBIT_FAILURE;
-CubitStatus OCCModifyEngine::remove_curve_slivers( BodySM* /*body*/,
- double /*lengthlimit*/ ) const
+CubitStatus OCCModifyEngine::remove_curve_slivers( BodySM* body,
+ double lengthlimit ) const
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return CUBIT_FAILURE;
+ DLIList<CubitBoolean> is_volume;
+ DLIList<BodySM*> bodies;
+ DLIList<TopoDS_Shape*> shapes;
+ bodies.append(body);
+ CubitStatus status = get_shape_list(bodies, shapes, is_volume, CUBIT_FALSE);
+ if(!status)
+ PRINT_ERROR("Can't find underlying TopoDS_Shape for this body.\n");
+ return CUBIT_FAILURE;
+ Handle(ShapeBuild_ReShape) context;
+ TopoDS_Shape new_shape = ShapeFix::RemoveSmallEdges(*shapes.get(),
+ lengthlimit, context);
+ new_shape = context->Apply(new_shape, TopAbs_COMPSOLID);
+ if(context->Status(ShapeExtend_OK))
+ PRINT_INFO("There's no small edges on this body.\n");
+ return CUBIT_SUCCESS;
+ else if(context->Status(ShapeExtend_FAIL))
+ PRINT_ERROR("Small edges can't be removed from this body.\n");
+ OCCQueryEngine::instance()->delete_solid_model_entities(body);
+ DLIList<TopologyBridge*>tbs = OCCQueryEngine::instance()->populate_topology_bridge(new_shape);
More information about the cgma-dev
