[cgma-dev] r2764 - cgm/trunk/test
jiangtao_ma at yahoo.com jiangtao_ma at yahoo.com
Fri Mar 27 11:37:37 CDT 2009
Author: janehu
Date: 2009-03-27 11:37:36 -0500 (Fri, 27 Mar 2009)
New Revision: 2764
Modified:
   cgm/trunk/test/modify.cpp
Log:
fixed the nightly build problem.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp	2009-03-26 22:44:39 UTC (rev 2763)
+++ cgm/trunk/test/modify.cpp	2009-03-27 16:37:36 UTC (rev 2764)
@@ -149,10 +149,11 @@
   //make a sheet surfaces to do fillet on vertices
   DLIList<RefFace*> ref_faces;
-  body2->ref_faces(ref_faces);
+  body->ref_faces(ref_faces);
   RefFace* face = gmti->make_RefFace(ref_faces.get());
+  Body* sheet_body = face->body();
   away *= 5;
-  gti->translate(face, away);
+  gti->translate(sheet_body, away);
   ref_vertices2.clean_out();
   ref_vertices.clean_out();
   face->ref_vertices(ref_vertices2);
@@ -161,15 +162,15 @@
     ref_vertices.append(ref_vertices2.pop());
   status = gmti->tweak_fillet(ref_vertices2, 1, new_bodies);
-  ref_edges.clean_out();
-  new_bodies.get()->ref_edges(ref_edges);
-  isize=ref_edges.size();
+  DLIList<RefEdge*> ref_edges_check;
+  new_bodies.get()->ref_edges(ref_edges_check);
+  isize=ref_edges_check.size();
   //isize = 6
   status = gmti->tweak_chamfer(ref_vertices, 1, new_bodies);
+  ref_edges_check.clean_out();
   //isize = 8
   new_bodies.clean_out();
More information about the cgma-dev mailing list
