[cgma-dev] CGMA check for *32-occ* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Fri Mar 27 02:22:39 CDT 2009
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/32-occ/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/32-occ/util'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/32-occ/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/virtual'
Making check in OCC
make[2]: Entering directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/geom/OCC'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/32-occ/init'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/init'
Making check in .
make[1]: Entering directory `/home/jason/cgm/test/32-occ'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ'
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make  check-recursive
make[2]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
Making check in .
make[3]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make    testgeom_occ
make[4]: Entering directory `/home/jason/cgm/test/32-occ/itaps'
make[4]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make  check-TESTS
Using default input file: ../../trunk/itaps/../test/LeverArm.brep
Geometry engine set to: OCC Geometry Engine version 6.2.0
ITAPS GEOMETRY INTERFACE TEST PROGRAM:
   gLoad:
Constructed 1 Volume: 1
Model contents:
vertices: 99
edges: 159
faces: 63
regions: 1
Success
   tags: Tags defined on model: GLOBAL_ID, NAME
Success
   gentity sets: Success
   topology adjacencies: Success
   construct: Created swept volume 4
Success
   primitives: Success
   transforms: Success
   booleans: Updated volume(s): 11
Destroyed volume(s): 12
Updated volume(s): 13
Destroyed volume(s): 14
Success
   shutdown: Success
TSTT TEST SUMMARY:
   Number Tests:           9
   Number Successful:      9
   Number Not Implemented: 0
   Number Failed:          0
PASS: testgeom_occ
All 1 tests passed
make[3]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/itaps'
Making check in test
make[1]: Entering directory `/home/jason/cgm/test/32-occ/test'
make  sheet   modify makept r_w test_occ operation
make[2]: Entering directory `/home/jason/cgm/test/32-occ/test'
make[2]: `sheet' is up to date.
make[2]: `modify' is up to date.
make[2]: `makept' is up to date.
make[2]: `r_w' is up to date.
make[2]: `test_occ' is up to date.
make[2]: `operation' is up to date.
make[2]: Leaving directory `/home/jason/cgm/test/32-occ/test'
make  check-TESTS
PASS: sheet
ERROR: Fillet on vertex can only be done on sheet body.
ERROR: Cannot transform Surface 13 (Surface 13) : not a free Surface
Updated volume(s): 3
ERROR: Cannot fillet curves on sheet bodies
WARNING: Attempted get of empty DLIList
/bin/sh: line 4: 19445 Segmentation fault      /home/jason/bin/timeout 600 ${dir}$tst
FAIL: modify
Exported:   4 OCC Bodies to prism.occ
Exported:   6 OCC Bodies to pyramid.occ
Constructed 1 Volume: 12
Constructed 1 Volume: 13
Constructed 2 Volumes: 14, 15
Created volume(s): 16 to 20
Exported:   6 OCC Bodies to point.occ
            3 OCC Points to point.occ
Exported:   2 OCC Bodies to point.occ
PASS: makept
Total number of loaded entities : 109.
Constructed 18 Free Curves: 1 to 18
Exported:  18 OCC Curves to ex3.occ
Exported:  18 OCC Curves to ex3export.iges
******        Statistics on Transfer (Write)                 ******
******        Transfer Mode = 0  I.E.  As Is       ******
******        Transferring Shape, ShapeType = 0                      ******
** WorkSession : Sending all data
 Step File Name : ex3export.step(578 ents)  Write  Done
Exported:  18 OCC Curves to ex3export.step
Total number of loaded entities : 58.
Constructed 7 Volumes: 1 to 7
Exported:   7 OCC Bodies to diffuser.occ
      ...    Step File Reading : ../../trunk/test/proe.stp
      ...    STEP File   Read    ...
Elapsed time: 0 Hours   0 Minutes   0.001624 Seconds
CPU user time: 0 seconds
CPU system time: 0 seconds
      ... Step File loaded  ...
Elapsed time: 0 Hours   0 Minutes   0.002994 Seconds
   1393 records (entities,sub-lists,scopes), 3595 parameters
      ... Parameters prepared ... Elapsed time: 0 Hours   0 Minutes   0.00471 Seconds
      ...   Objets analysed  ...
Elapsed time: 0 Hours   0 Minutes   0.007682 Seconds
CPU user time: 0.01 seconds
  STEP Loading done : 815 Entities
Constructed 12 Volumes: 8 to 19
Exported:  12 OCC Bodies to proe.occ
Exported:  12 OCC Bodies to proeexport.iges
 Step File Name : proeexport.step(1348 ents)  Write  Done
Exported:  12 OCC Bodies to proeexport.step
Constructed 2 Volumes: 20, 21
Exported:   2 OCC Bodies to beforesub.occ
Constructed 2 Volumes: 22, 23
Exported:   2 OCC Bodies to beforesub2.occ
Created volume(s): 24, 25
Destroyed volume(s): 22, 23
Exported:   2 OCC Bodies to aftersub.occ
Constructed 2 Volumes: 26, 27
Updated volume(s): 26
Destroyed volume(s): 27
Exported:   1 OCC Body to unite2.occ
Constructed 2 Volumes: 28, 29
Updated volume(s): 29
Destroyed volume(s): 28
Exported:   1 OCC Body to unite3.occ
Constructed 2 Volumes: 30, 31
Updated volume(s): 30
Destroyed volume(s): 31
Exported:   1 OCC Body to unite5.occ
Constructed 2 Volumes: 32, 33
Updated volume(s): 33
Destroyed volume(s): 32
Exported:   1 OCC Body to unite6.occ
PASS: r_w
done...
PASS: test_occ
Constructed 2 Volumes: 1, 2
Total 0 cuts performed, with from_shape having 8 faces.
Created volume(s): 7
PASS: operation
1 of 6 tests failed
make[2]: *** [check-TESTS] Error 1
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/32-occ/test'
make: *** [check-recursive] Error 1
More information about the cgma-dev
