[cgma-dev] r2758 - cgm/trunk/test
jiangtao_ma at yahoo.com
Thu Mar 26 13:35:29 CDT 2009
Author: janehu
Date: 2009-03-26 13:35:28 -0500 (Thu, 26 Mar 2009)
New Revision: 2758
Modified:
cgm/trunk/test/modify.cpp
Log:
Added testing on fillet/chamfer sheet body.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2009-03-26 18:34:57 UTC (rev 2757)
+++ cgm/trunk/test/modify.cpp 2009-03-26 18:35:28 UTC (rev 2758)
@@ -149,16 +149,29 @@
//make a sheet surfaces to do fillet on vertices
DLIList<RefFace*> ref_faces;
- body->ref_faces(ref_faces);
+ body2->ref_faces(ref_faces);
RefFace* face = gmti->make_RefFace(ref_faces.get());
+ away *= 5;
+ gti->translate(face, away);
ref_vertices2.clean_out();
+ ref_vertices.clean_out();
face->ref_vertices(ref_vertices2);
isize=ref_vertices2.size();
for(int i = 2; i < isize; i++)
- ref_vertices2.pop();
+ ref_vertices.append(ref_vertices2.pop());
- //status = gmti->tweak_fillet(ref_vertices2, 1, new_bodies);
+ status = gmti->tweak_fillet(ref_vertices2, 1, new_bodies);
+ ref_edges.clean_out();
+ new_bodies.get()->ref_edges(ref_edges);
+ isize=ref_edges.size();
+ //isize = 6
+ status = gmti->tweak_chamfer(ref_vertices, 1, new_bodies);
+ //isize = 8
new_bodies.clean_out();
gmti->tweak_fillet(ref_edges, 1, new_bodies, CUBIT_FALSE, CUBIT_FALSE);
More information about the cgma-dev
