[cgma-dev] r2747 - cgm/trunk/test
    jiangtao_ma at yahoo.com
    Wed Mar 25 14:06:25 CDT 2009
Author: janehu
Date: 2009-03-25 14:06:23 -0500 (Wed, 25 Mar 2009)
New Revision: 2747
Modified:
   cgm/trunk/test/modify.cpp
Log:
Added tests on fillet/chamfer on vertices. Fillet on sheet body hasn't passed test yet.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp	2009-03-25 19:05:39 UTC (rev 2746)
+++ cgm/trunk/test/modify.cpp	2009-03-25 19:06:23 UTC (rev 2747)
@@ -135,9 +135,31 @@
   DLIList<Body*> new_bodies;
   int isize=ref_edges.size();
   //isize = 12
+  for(int i = 2; i < isize; i++)
+    ref_edges.pop();
+  DLIList<RefVertex*> ref_vertices, ref_vertices2;
+  body->ref_vertices(ref_vertices);
+  RefVertex* vtx1 ;
+  ref_vertices2.append(ref_vertices.pop());
+  CubitStatus status = gmti->tweak_fillet(ref_vertices2, 1, new_bodies);
+  //status = failure
+  //make a sheet surfaces to do fillet on vertices
+  DLIList<RefFace*> ref_faces;
+  body->ref_faces(ref_faces);
+  RefFace* face = gmti->make_RefFace(ref_faces.get());
+  ref_vertices2.clean_out();
+  face->ref_vertices(ref_vertices2);
+  isize=ref_vertices2.size();
-    ref_edges.pop();
+    ref_vertices2.pop();
+  //status = gmti->tweak_fillet(ref_vertices2, 1, new_bodies);
+  new_bodies.clean_out();
   gmti->tweak_fillet(ref_edges, 1, new_bodies, CUBIT_FALSE, CUBIT_FALSE);
   ref_edges.clean_out();
@@ -146,7 +168,8 @@
   //isize = 21
-  new_bodies.clean_out();
   body2->ref_edges(ref_edges);
   //isize = 12
@@ -160,6 +183,38 @@
   //isize = 17
+  ref_vertices.clean_out();
+  body2->ref_vertices(ref_vertices);
+  for(int i = 0; i < 3; i++)
+    vtx1 = ref_vertices.pop();
+    ref_vertices2.append(vtx1);
+  ref_edges.clean_out();
+  ref_vertices2.get()->ref_edges(ref_edges);
+  status = gmti->tweak_chamfer(ref_vertices2, 1, new_bodies, ref_edges.pop(),
+                         0.7, ref_edges.pop(), 0.5, ref_edges.pop());
+  //status = failure.
+  ref_vertices.append(ref_vertices2.pop());
+  gmti->tweak_chamfer(ref_vertices2, 2, new_bodies, ref_edges.pop(), 1,
+                      ref_edges.pop(), 0.5, ref_edges.pop());
+  gmti->tweak_chamfer(ref_vertices, 1, new_bodies);
+  new_bodies.get()->ref_edges(ref_edges);
+  isize=ref_edges.size();
+  //isize = 26
   CubitStatus rsl = CUBIT_SUCCESS;
   DLIList<RefEntity*> ref_entity_list;
   int num_ents_exported=0;
@@ -224,7 +279,7 @@
   BodySM* bodysm = body->get_body_sm_ptr();
   DLIList<OCCSurface*> occ_surfaces;
   CAST_TO(bodysm, OCCBody)->get_all_surfaces(occ_surfaces);
-  DLIList<RefFace*> ref_faces;
+  ref_faces.clean_out();
@@ -298,7 +353,7 @@
   // Read in the geometry from files specified on the command line
   const char *argv = "stitch.occ";
-  CubitStatus status = read_geometry(1, &argv, true);
+  status = read_geometry(1, &argv, true);
   if (status == CUBIT_FAILURE) exit(1);
   //Read in 1 volume.
@@ -928,7 +983,6 @@
   CubitVector pt3(-1,0,15);
   RefVertex* vt1 = gmti->make_RefVertex(pt1);
   RefVertex* vt2 = gmti->make_RefVertex(pt2);
-  RefVertex* vt3 = gmti->make_RefVertex(pt3);
   RefEdge* edge1 = gmti->make_RefEdge(ARC_CURVE_TYPE, vt1, vt2, &pt3,
                   CUBIT_FORWARD );
   CubitVector apoint(0,-0.5,15);
More information about the cgma-dev
