[cgma-dev] r2741 - in cgm/trunk: geom/ACIS itaps test
    jiangtao_ma at yahoo.com
    Mon Mar 23 09:44:49 CDT 2009
Author: janehu
Date: 2009-03-23 09:44:48 -0500 (Mon, 23 Mar 2009)
New Revision: 2741
Added:
   cgm/trunk/itaps/iGeom.h_2617
Modified:
   cgm/trunk/geom/ACIS/Makefile.am
   cgm/trunk/test/Makefile.am
Log:
Remove fillet.occ from make clean and making tarball.
Modified: cgm/trunk/geom/ACIS/Makefile.am
--- cgm/trunk/geom/ACIS/Makefile.am	2009-03-20 22:09:31 UTC (rev 2740)
+++ cgm/trunk/geom/ACIS/Makefile.am	2009-03-23 14:44:48 UTC (rev 2741)
@@ -0,0 +1,84 @@
+# Don't require GNU-standard files (Changelog, README, etc.)
+AUTOMAKE_OPTIONS = foreign
+# Override default defines with the ones we want from the configure script
+DEFS = $(TEMPLATE_DEFS_INCLUDED) \
+       $(LITTLE_ENDIAN) $(ACIS_STEP_TRANSLATOR) $(ACIS_IGES_TRANSLATOR) \
+       -DCUBIT_ACIS_VERSION=$(ACIS_VERSION) -DACIS_VERSION=$(ACIS_VERSION) \
+       -D$(ACIS_PLATFORM) -DACIS_LOCAL_OPS -DACIS_VER=$(ACIS_VERSION)
+INCLUDES = -I$(top_srcdir)/util \
+           -I$(top_srcdir)/geom \
+           -I$(srcdir)/gtcAttrib/incl \
+           $(ACIS_INCLUDES)
+# The name of the library to build
+noinst_LTLIBRARIES = libcubit_ACIS.la
+# The directory where headers will be installed
+libcubit_ACIS_la_includedir = $(includedir)
+# The non-template sources
+libcubit_ACIS_la_SOURCES = \
+    AcisBridge.cpp \
+    AcisEdgeTool.cpp \
+    AcisFacetManager.cpp \
+    AcisFeatureEngine.cpp \
+    AcisHealerTool.cpp \
+    AcisModifyEngine.cpp \
+    AcisQueryEngine.cpp \
+    AcisSurfaceTool.cpp \
+    AcisToolUtil.cpp \
+    AcisTweakTool.cpp \
+    AcisDrawTool.cpp \
+    attrib_cubit_owner.cpp \
+    attrib_snl.cpp \
+    attrib_snl_simple.cpp \
+    BodyACIS.cpp \
+    CoEdgeACIS.cpp \
+    CurveACIS.cpp \
+    LoopACIS.cpp \
+    LumpACIS.cpp \
+    PointACIS.cpp \
+    ShellACIS.cpp \
+    SurfaceACIS.cpp \
+    gtcAttrib/src/attrib_edge_parametric_length.C \
+    gtcAttrib/src/attrib_gtc.C \
+    gtcAttrib/src/attrib_mark.C \
+    gtcAttrib/src/attrib_name.C
+# Headers to be installed.  If any file in this list should
+# not be installed, move it to the _SOURCES list above.
+libcubit_ACIS_la_include_HEADERS = \
+    AcisBridge.hpp \
+    AcisDrawTool.hpp \
+    AcisEdgeTool.hpp \
+    AcisFacetManager.hpp \
+    AcisFeatureEngine.hpp \
+    AcisHealerTool.hpp \
+    AcisModifyEngine.hpp \
+    AcisQueryEngine.hpp \
+    AcisSurfaceTool.hpp \
+    AcisToolUtil.hpp \
+    AcisTweakTool.hpp \
+    AcisTypes.h \
+    BodyACIS.hpp \
+    CoEdgeACIS.hpp \
+    CurveACIS.hpp \
+    LoopACIS.hpp \
+    LumpACIS.hpp \
+    PointACIS.hpp \
+    ShellACIS.hpp \
+    SurfaceACIS.hpp \
+    attrib_cubit_owner.hpp \
+    attrib_snl.hpp \
+    attrib_snl_simple.hpp \
+    decl_none.h \
+    gtcAttrib/incl/attrib_edge_parametric_length.h \
+    gtcAttrib/incl/attrib_gtc.h \
+    gtcAttrib/incl/attrib_gtc_export.h \
+    gtcAttrib/incl/attrib_mark.h \
+    gtcAttrib/incl/attrib_name.h \
+    gtcAttrib/incl/gtcAttrib_exConst.h
+libcubit_ACIS_la_LIBADD = -L$(ACIS_LIB_DIR) $(ACIS_LIBS)
Copied: cgm/trunk/itaps/iGeom.h_2617 (from rev 2617, cgm/trunk/itaps/iGeom.h)
--- cgm/trunk/itaps/iGeom.h_2617	                        (rev 0)
+++ cgm/trunk/itaps/iGeom.h_2617	2009-03-23 14:44:48 UTC (rev 2741)
@@ -0,0 +1,3247 @@
+#ifndef IGEOM_CBIND_H__
+#define IGEOM_CBIND_H__
+  /** \mainpage The ITAPS Geometry Interface iGeom
+   * The ITAPS Geometry Interface iGeom provides a common interface for
+   * accessing geometry and data associated with a mesh.  Applications written
+   * to use this interface can use a variety of implementations, choosing
+   * the one that best meets its needs.  They can also use tools written
+   * to this interface.
+   * \section ITAPS Data Model
+   * The ITAPS interfaces use a data model composed of four basic data types:\n
+   * \em Entity: basic topological entities in a model, e.g. vertices,
+   * edges, faces, regions. \n
+   * \em Entity \em Set: arbitrary grouping of other entities and sets.
+   * Entity sets also support parent/child relations with other sets which
+   * are distinct from entities contained in those sets.  Parent/child links
+   * can be used to embed graph relationships between sets, e.g. to
+   * represent topological relationships between the sets. \n
+   * \em Interface: the object with which model is associated and on which
+   * functions in iGeom are called. \n
+   * \em Tag: application data associated with objects of any of the other
+   * data types.  Each tag has a designated name, size, and data type.
+   * \section JTAPS Entity Type
+   * Each entity has a specific Entity Type.  The Entity
+   * Type is one of VERTEX, EDGE, FACE, and REGION, and is synonymous with
+   * the topological dimension of the entity.  Entity Type is an enumerated
+   * type in the iBase_EntityType enumeration.
+   * \section KTAPS Entity-, Array-, and Iterator-Based Access
+   * The iGeom interface provides functions for accessing entities
+   * individually, as arrays of entities, or using iterators.  These access
+   * methods have different memory versus execution time tradeoffs,
+   * depending on the implementation.
+   * \section LTAPS Lists Passed Through Interface
+   * Many of the functions in iGeom have arguments corresponding to lists of
+   * objects.  In-type arguments for lists consist of a pointer to an array and
+   * a list size.  Lists returned from functions are passed in three arguments,
+   * a pointer to the array representing the list, and pointers to the
+   * allocated and occupied lengths of the array.  These three arguments are
+   * inout-type arguments, because they can be allocated by the application and
+   * passed into the interface to hold the results of the function.  Lists
+   * which are pre-allocated must be large enough to hold the results of the
+   * function; if this is not the case, an error is generated.  Otherwise, the
+   * occupied size is changed to the size output from the function.  If a list
+   * argument is unallocated (the list pointer points to a NULL value) or if
+   * the incoming value of the allocated size is zero, the list storage will be
+   * allocated by the implementation.  IN ALL CASES, MEMORY ALLOCATED BY ITAPS
+   * INTERFACE IMPLEMENTATIONS IS DONE USING THE C MALLOC FUNCTION, AND CAN BE
+   * DE-ALLOCATED USING THE C FREE FUNCTION.
+#ifndef ITAPS
+#define ITAPS
+#endif
+#include "iBase.h"
+#include "iGeom_protos.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
+    /**\brief  Type used to store iGeom interface handle
+     * Type used to store iGeom interface handle
+  typedef struct iGeom_Instance_Private* iGeom_Instance;
+    /**\brief  Type used to store an iterator returned by iGeom
+     * Type used to store an iterator returned by iGeom
+  typedef struct iGeom_EntityIterator_Private* iGeom_EntityIterator;
+    /**\brief  Type used to store an array iterator returned by iGeom
+     * Type used to store an array iterator returned by iGeom
+  typedef struct iGeom_EntityArrIterator_Private* iGeom_EntityArrIterator;
+    /**\brief  Get a description of the error returned from the last iGeom function
+     * Get a description of the error returned from the last iGeom function
+     * \param instance iGeom instance handle
+     * \param descr Pointer to a character string to be filled with a
+     *        description of the error from the last iGeom function
+     * \param *err Pointer to error type returned from function
+     * \param descr_len Length of the character string pointed to by descr
+  void iGeom_getDescription( iGeom_Instance instance,
+                             char* descr,
+                             int* err,
+                             int descr_len );
+    /**\brief  Get the error type returned from the last iGeom function
+     * Get the error type returned from the last iGeom function.  Value
+     * returned is a member of the iBase_ErrorType enumeration.
+     * \param *error_type Error type returned from last iGeom function
+  void iGeom_getErrorType(iGeom_Instance instance,
+                          /*out*/ int *error_type,
+                          int *err);
+    /**\brief  Construct a new iGeom instance
+     * Construct a new iGeom instance, using implementation-specific
+     * options
+     * \param options Pointer to implementation-specific options string
+     * \param instance Pointer to iGeom instance handle returned from function
+     * \param options_len Length of the character string pointed to by options
+  void iGeom_newGeom( char const* options,
+                      iGeom_Instance* instance_out,
+                      int* err,
+                      int options_len );
+    /**\brief  Destroy an iGeom instance
+     * Destroy an iGeom instance
+     * \param instance iGeom instance to be destroyed
+  void iGeom_dtor( iGeom_Instance instance, int* err );
+    /**\brief  Load a geom from a file
+     * Load a geom from a file.  If entity set is specified, loaded geom
+     * is added to that set; specify zero if that is not desired.
+     * \param entity_set_handle Set to which loaded geom will be added, zero
+     *        if not desired
+     * \param name File name from which geom is to be loaded
+     * \param name_len Length of the file name character string
+     * \param options_len Length of the options character string
+  void iGeom_load( iGeom_Instance,
+                   char const* name,
+                   char const* options,
+                   int* err,
+                   int name_len,
+    /**\brief  Save a geom to a file
+     * Save a geom to a file.  If entity set is specified, save only the
+     * geom contained in that set.
+     * \param entity_set_handle Entity set being saved
+     * \param name File name to which geom is to be saved
+  void iGeom_save( iGeom_Instance,
+                   char const* name,
+                   int* err,
+                   int name_len,
+    /**\brief  Get handle of the root set for this instance
+     * Get handle of the root set for this instance.  All geom in
+     * this instance can be accessed from this set.
+     * \param root_set Pointer to set handle returned from function
+  void iGeom_getRootSet( iGeom_Instance,
+                         iBase_EntitySetHandle* root_set,
+                         int* err );
+/**\brief Get the bounding box of the entire model
+ * Get the bounding box of the entire model
+ * \param min_x Minimum coordinate of bounding box
+ * \param min_y Minimum coordinate of bounding box
+ * \param min_z Minimum coordinate of bounding box
+ * \param max_x Maximum coordinate of bounding box
+ * \param max_y Maximum coordinate of bounding box
+ * \param max_z Maximum coordinate of bounding box
+  void iGeom_getBoundBox( iGeom_Instance,
+                          double* min_x,
+                          double* min_y,
+                          double* min_z,
+                          double* max_x,
+                          double* max_y,
+                          double* max_z,
+                          int* err );
+    /**\brief  Get entities of specific type and/or topology in set or instance
+     * Get entities of specific type and/or topology in set or instance.  All
+     * entities of a given type or topology are requested by specifying
+     * iBase_ALL_TOPOLOGIES or iBase_ALL_TYPES, respectively.  Specified type
+     * or topology must be a value in the iBase_EntityType or iBase_EntityTopology
+     * enumeration, respectively.
+     * \param entity_set_handle Entity set being queried
+     * \param entity_type Type of entities being requested
+     * \param entity_topology Topology of entities being requested
+     * \param *entity_handles Pointer to array of entity handles returned
+     *        from function
+     * \param *entity_handles_allocated Pointer to allocated size of
+     *        entity_handles array
+     * \param *entity_handles_size Pointer to occupied size of entity_handles array
+  void iGeom_getEntities( iGeom_Instance instance,
+                          iBase_EntitySetHandle set_handle,
+                          int entity_type,
+                          iBase_EntityHandle** entity_handles,
+                          int* entity_handles_allococated,
+                          int* entity_handles_size,
+                          int* err );
+    /**\brief  Get the number of entities with the specified type in the instance or set
+     * Get the number of entities with the specified type in the instance
+     * or set.  If entity set handle is zero, return information for instance,
+     * otherwise for set.  Value of entity type must be from the
+     * iBase_EntityType enumeration.  If iBase_ALL_TYPES is specified,
+     * total number of entities (excluding entity sets) is returned.
+     * \param entity_type Type of entity requested
+     * \param num_type Pointer to number of entities, returned from function
+  void iGeom_getNumOfType( iGeom_Instance instance,
+                           int entity_type,
+                           int* num_out,
+                           int* err );
+    /**\brief  Get the entity type for the specified entity
+     * Get the entity type for the specified entity.  Types
+     * returned are values in the iBase_EntityType enumeration.
+     * \param entity_handle entity handle being queried
+     * \param *type Pointer to location at which to store the returned type
+  void iGeom_getEntType( iGeom_Instance instance,
+                         iBase_EntityHandle entity_handle,
+                         int* type,
+                         int* err );
+    /**\brief  Get the entity type for the specified entities
+     * Get the entity type for the specified entities.  Types
+     * \param entity_handles Array of entity handles being queried
+     * \param entity_handles_size Number of entities in entity_handles array
+     * \param *type Pointer to array of types returned from function
+     * \param *type_allocated Pointer to allocated size of type array
+     * \param *type_size Pointer to occupied size of type array
+  void iGeom_getArrType( iGeom_Instance instance,
+                         iBase_EntityHandle const* entity_handles,
+                         int entity_handles_size,
+                         int** type,
+                         int* type_allocated,
+                         int* type_size,
+                         int* err );
+    /**\brief  Get entities of specified type adjacent to an entity
+     * Get entities of specified type adjacent to an entity.  Specified type
+     * must be value in the iBase_EntityType enumeration.
+     * \param entity_handle Entity handle being queried
+     * \param entity_type_requested Type of adjacent entities requested
+     * \param *adj_entity_handles Pointer to array of adjacent entities
+     *        returned from function
+     * \param *adj_entity_handles_allocated Pointer to allocated size of
+     *        adj_entity_handles array
+     * \param *adj_entity_handles_size Pointer to occupied size of
+  void iGeom_getEntAdj( iGeom_Instance instance,
+                        int to_dimension,
+                        iBase_EntityHandle** adj_entities,
+                        int* adj_entities_allocated,
+                        int* adj_entities_size,
+                        int* err );
+    /**\brief  Get entities of specified type adjacent to entities
+     * Get entities of specified type adjacent to entities.  Specified type
+     * must be value in the iBase_EntityType enumeration.  \em offset(i) is
+     * index of first entity in adjacentEntityHandles array adjacent to
+     * entity_handles[i].
+     * \param *adjacentEntityHandles Pointer to array of adjacentEntityHandles
+     * \param *adjacentEntityHandles_allocated Pointer to allocated size of
+     *        adjacentEntityHandles array
+     * \param *offset Pointer to array of offsets returned from function
+     * \param *offset_allocated Pointer to allocated size of offset array
+     * \param *offset_size Pointer to occupied size of offset array
+  void iGeom_getArrAdj( iGeom_Instance instance,
+                        int requested_entity_type,
+                        iBase_EntityHandle** adj_entity_handles,
+                        int* adj_entity_handles_allocated,
+                        int* adj_entity_handles_size,
+                        int** offset,
+                        int* offset_allocated,
+                        int* offset_size,
+                        int* err );
+/**\brief Get "2nd order" adjacencies to an entity
+ * Get "2nd order" adjacencies to an entity, that is, from an entity, through
+ * other entities of a specified "bridge" dimension, to other entities of another
+ * specified "to" dimension.
+ * \param entity_handle Entity from which adjacencies are requested
+ * \param bridge_dimension Bridge dimension for 2nd order adjacencies
+ * \param to_dimension Dimension of adjacent entities returned
+ * \param adjacent_entities Adjacent entities
+ * \param adjacent_entities_allocated Allocated size of returned array
+ * \param adjacent_entities_size Occupied size of returned array
+ * \param err
+  void iGeom_getEnt2ndAdj( iGeom_Instance instance,
+                           int bridge_dimension,
+                           int to_dimension,
+                           iBase_EntityHandle** adjacent_entities,
+                           int* adjacent_entities_allocated,
+                           int* adjacent_entities_size,
+                           int* err );
+/**\brief Get "2nd order" adjacencies to an array of entities
+ * Get "2nd order" adjacencies to an array of entities, that is, from each entity, through
+ * \param entity_handles Entities from which adjacencies are requested
+ * \param entity_handles_size Number of entities whose adjacencies are requested
+ * \param adj_entity_handles Adjacent entities
+ * \param adj_entity_handles_allocated Allocated size of returned array
+ * \param adj_entity_handles_size Occupied size of returned array
+ * \param offset Offset[i] is offset into adj_entity_handles of 2nd order
+ *        adjacencies of ith entity in entity_handles
+ * \param offset_allocated Allocated size of offset array
+ * \param offset_size Occupied size of offset array
+ * \param err
+  void iGeom_getArr2ndAdj( iGeom_Instance instance,
+                           int order_adjacent_key,
+                           int** offset,
+                           int* offset_size,
+                           int* err );
+/**\brief Return whether two entities are adjacent
+ * Return whether two entities are adjacent.
+ * \param entity_handle1 First entity queried
+ * \param entity_handle2 Second entity queried
+ * \param are_adjacent If returned non-zero, entities are adjacent, otherwise
+ *        they are not
+ * \param err
+  void iGeom_isEntAdj( iGeom_Instance instance,
+                       iBase_EntityHandle entity_handle1,
+                       iBase_EntityHandle entity_handle2,
+                       int* are_adjacent,
+                       int* err );
+/**\brief Return whether entity pairs are adjacent
+ * Return whether entity pairs are adjacent, i.e. if entity_handles_1[i] is
+ * adjacent to entity_handles_2[i].  This function requires entity_handles_1_size
+ * and entity_handles_2_size to be equal.
+ * \param entity_handles_1 First array of entities
+ * \param entity_handles_1_size Number of entities in first array
+ * \param entity_handles_2 Second array of entities
+ * \param entity_handles_2_size Number of entities in second array
+ * \param is_adjacent_info Array of flags returned from function
+ * \param is_adjacent_info_allocated Allocated size of flags array
+ * \param is_adjacent_info_size Occupied size of flags array
+  void iGeom_isArrAdj( iGeom_Instance instance,
+                       iBase_EntityHandle const* entity_handles_1,
+                       int entity_handles_1_size,
+                       iBase_EntityHandle const* entity_handles_2,
+                       int entity_handles_2_size,
+                       int** is_adjacent_info,
+                       int* is_adjacent_info_allocated,
+                       int* is_adjacent_info_size,
+                       int* err );
+/**\brief DON'T KNOW WHAT THIS FUNCTION IS
+ * \param topo_level_out
+  void iGeom_getTopoLevel( iGeom_Instance instance,
+                           int* topo_level_out,
+                           int* err );
+/**\brief Get closest point to an entity
+ * Get closest point to a specified position on an entity
+ * \param entity_handle Entity being queried
+ * \param near_x Coordinates of starting point
+ * \param near_y Coordinates of starting point
+ * \param near_z Coordinates of starting point
+ * \param on_x Closest point on entity
+ * \param on_y Closest point on entity
+ * \param on_z Closest point on entity
+  void iGeom_getEntClosestPt( iGeom_Instance instance,
+                              double near_x,
+                              double near_y,
+                              double near_z,
+                              double* on_x,
+                              double* on_y,
+                              double* on_z,
+                              int* err );
+/**\brief Get closest point for an array of entities and points
+ * Get closest point for an array of entities and points.  If either the number
+ * of entities or number of coordinate triples is unity, then all points or
+ * entities are queried for that entity or point, respectively, otherwise each
+ * point corresponds to each entity.  storage_order should be a value in
+ * the iBase_StorageOrder enum; if input as iBase_UNKNOWN, order is in native order
+ * with respect to implementation.
+ * \param entity_handles Entity(ies) being queried
+ * \param entity_handles_size Number of entities being queried
+ * \param storage_order Storage order of input points
+ * \param near_coordinates Coordinates of starting point(s)
+ * \param near_coordinates_size Number of values in near_coordinates array
+ * \param on_coordinates Coordinates of closest points
+ * \param on_coordinates_allocated Allocated size of closest point array
+ * \param on_coordinates_size Occupied size of closest point array
+  void iGeom_getArrClosestPt( iGeom_Instance instance,
+                              int storage_order,
+                              double const* near_coordinates,
+                              int near_coordinates_size,
+                              double** on_coordinates,
+                              int* on_coordinates_allocated,
+                              int* on_coordinates_size,
+                              int* err );
+/**\brief Get the normal vector on an entity at the given position
+ * Get the normal vector on an entity at the given position.
+ * \param x Coordinates of starting point
+ * \param y Coordinates of starting point
+ * \param z Coordinates of starting point
+ * \param nrml_i Normal vector at starting point
+ * \param nrml_j Normal vector at starting point
+ * \param nrml_k Normal vector at starting point
+  void iGeom_getEntNrmlXYZ( iGeom_Instance,
+                            double x,
+                            double y,
+                            double z,
+                            double* nrml_i,
+                            double* nrml_j,
+                            double* nrml_k,
+                            int* err );
+/**\brief Get the normal vector on an entity(ies) at given position(s)
+ * Get the normal vector on an entity(ies) at given position(s).  If either the
+ * number of entities or number of coordinate triples is unity, then all points or
+ * \param storage_order Storage order of coordinates
+ * \param coordinates Starting coordinates
+ * \param coordinates_size Number of values in coordinates array
+ * \param normals Normal coordinates
+ * \param normals_allocated Allocated size of normals array
+ * \param normals_size Occupied size of normals array
+  void iGeom_getArrNrmlXYZ( iGeom_Instance,
+                            double const* coordinates,
+                            int coordinates_size,
+                            double** normals,
+                            int* normals_allocated,
+                            int* normals_size,
+                            int* err );
+/**\brief Get the normal vector AND closest point on an entity at given position
+ * Get the normal vector AND closest point on an entity at a given position.
+ * \param x Starting coordinates
+ * \param y Starting coordinates
+ * \param z Starting coordinates
+ * \param pt_x Closest point
+ * \param pt_y Closest point
+ * \param pt_z Closest point
+ * \param nrml_i Normal at closest point
+ * \param nrml_j Normal at closest point
+ * \param nrml_k Normal at closest point
+  void iGeom_getEntNrmlPlXYZ( iGeom_Instance,
+                              double x,
+                              double y,
+                              double z,
+                              double* pt_x,
+                              double* pt_y,
+                              double* pt_z,
+                              double* nrml_i,
+                              double* nrml_j,
+                              double* nrml_k,
+                              int* err );
+/**\brief Get the normal vector AND closest point on an entity(ies) at given position(s)
+ * Get the normal vector AND closest point on an entity(ies) at given position(s).  If either the
+ * \param entity_handles_size Number of entity(ies) being queried
+ * \param storage_order Storage order in near_coordinates array
+ * \param near_coordinates Starting coordinates
+ * \param on_coordinates Closest point array
+ * \param normals Normal array
+ * \param normals_allocated Allocated size of normal array
+ * \param normals_size Occupied size of normal array
+  void iGeom_getArrNrmlPlXYZ( iGeom_Instance,
+                              double** normals,
+                              int* err );
+/**\brief Get the tangent vector on an entity at given position
+ * Get the tangent vector on an entity at a given position.
+ * \param tgnt_i Tangent at closest point
+ * \param tgnt_j Tangent at closest point
+ * \param tgnt_k Tangent at closest point
+  void iGeom_getEntTgntXYZ( iGeom_Instance,
+                            double x,
+                            double y,
+                            double z,
+                            double* tgnt_i,
+                            double* tgnt_j,
+                            double* tgnt_k,
+                            int* err );
+/**\brief Get the tangent vector on an entity(ies) at given position(s)
+ * Get the tangent vector on an entity(ies) at given position(s).  If either the
+ * \param tangents Tangent coordinates
+ * \param tangents_allocated Allocated size of tangents array
+ * \param tangents_size Occupied size of tangents array
+  void iGeom_getArrTgntXYZ( iGeom_Instance,
+                            double** tangents,
+                            int* tangents_allocated,
+                            int* tangents_size,
+                            int* err );
+/**\brief Get the two principle curvature vectors for a face at a point
+ * Get the two principle curvature vectors for a face at a point.  Magnitudes of
+ * vectors are curvature, directions are directions of principal curvatures.
+ * \param face_handle Face being queried
+ * \param x Position being queried
+ * \param y Position being queried
+ * \param z Position being queried
+ * \param cvtr1_i Maximum curvature vector
+ * \param cvtr1_j Maximum curvature vector
+ * \param cvtr1_k Maximum curvature vector
+ * \param cvtr2_i Minimum curvature vector
+ * \param cvtr2_j Minimum curvature vector
+ * \param cvtr2_k Minimum curvature vector
+  void iGeom_getFcCvtrXYZ( iGeom_Instance,
+                           iBase_EntityHandle face_handle,
+                           double x,
+                           double y,
+                           double z,
+                           double* cvtr1_i,
+                           double* cvtr1_j,
+                           double* cvtr1_k,
+                           double* cvtr2_i,
+                           double* cvtr2_j,
+                           double* cvtr2_k,
+                           int* err );
+/**\brief Get the principle curvature vector for an edge at a point
+ * Get the principle curvature vector for an edge at a point.  Magnitude of
+ * vector is the curvature, direction is direction of principal curvature.
+ * \param edge_handle Edge being queried
+ * \param cvtr_i Maximum curvature vector
+ * \param cvtr_j Maximum curvature vector
+ * \param cvtr_k Maximum curvature vector
+  void iGeom_getEgCvtrXYZ( iGeom_Instance,
+                           iBase_EntityHandle edge_handle,
+                           double x,
+                           double y,
+                           double z,
+                           double* cvtr_i,
+                           double* cvtr_j,
+                           double* cvtr_k,
+                           int* err );
+/**\brief Get the curvature(s) on an entity(ies) at given position(s)
+ * Get the curvature(s) on an entity(ies) at given position(s).  If either the
+ * \param coords Starting coordinates
+ * \param coords_size Number of values in coordinates array
+ * \param cvtr_1 First principal curvatures
+ * \param cvtr_1_allocated Allocated size of first curvature array
+ * \param cvtr_1_size Occupied size of first curvature array
+ * \param cvtr_2 Second principal curvatures
+ * \param cvtr_2_allocated Allocated size of second curvature array
+ * \param cvtr_2_size Occupied size of second curvature array
+  void iGeom_getEntArrCvtrXYZ( iGeom_Instance,
+                               double const* coords,
+                               int coords_size,
+                               double** cvtr_1,
+                               int* cvtr_1_allocated,
+                               int* cvtr_1_size,
+                               double** cvtr_2,
+                               int* cvtr_2_allocated,
+                               int* cvtr_2_size,
+                               int* err );
+/**\brief Get closest point, tangent, and curvature of edge
+ * Get closest point, tangent, and curvature of edge.
+ * \param x Point at which entity is being queried
+ * \param y Point at which entity is being queried
+ * \param z Point at which entity is being queried
+ * \param on_x Closest point at point being queried
+ * \param on_y Closest point at point being queried
+ * \param on_z Closest point at point being queried
+ * \param tgnt_i Tangent at point being queried
+ * \param tgnt_j Tangent at point being queried
+ * \param tgnt_k Tangent at point being queried
+ * \param cvtr_i Curvature at point being queried
+ * \param cvtr_j Curvature at point being queried
+ * \param cvtr_k Curvature at point being queried
+  void iGeom_getEgEvalXYZ( iGeom_Instance,
+                           double x,
+                           double y,
+                           double z,
+                           double* on_x,
+                           double* on_y,
+                           double* on_z,
+                           double* tgnt_i,
+                           double* tgnt_j,
+                           double* tgnt_k,
+                           double* cvtr_i,
+                           double* cvtr_j,
+                           double* cvtr_k,
+                           int* err );
+/**\brief Get closest point, tangent, and curvature of face
+ * Get closest point, tangent, and curvature of face.  If any of input
+ * coordinate pointers are NULL, that value is not returned.
+ * \param nrml_i Normal at point being queried
+ * \param nrml_j Normal at point being queried
+ * \param nrml_k Normal at point being queried
+ * \param cvtr1_i First principal curvature at point being queried
+ * \param cvtr1_j First principal curvature at point being queried
+ * \param cvtr1_k First principal curvature at point being queried
+ * \param cvtr2_i Second principal curvature at point being queried
+ * \param cvtr2_j Second principal curvature at point being queried
+ * \param cvtr2_k Second principal curvature at point being queried
+  void iGeom_getFcEvalXYZ( iGeom_Instance,
+                           double x,
+                           double y,
+                           double z,
+                           double* on_x,
+                           double* on_y,
+                           double* on_z,
+                           double* nrml_i,
+                           double* nrml_j,
+                           double* nrml_k,
+                           double* cvtr1_i,
+                           double* cvtr1_j,
+                           double* cvtr1_k,
+                           double* cvtr2_i,
+                           double* cvtr2_j,
+                           double* cvtr2_k,
+                           int* err );
+/**\brief Get the closest point(s), tangent(s), and curvature(s) on an entity(ies) at given position(s)
+ * Get the closest point(s), tangent(s), and curvature(s) on an entity(ies) at given position(s).
+ * If either the number of entities or number of coordinate triples is unity, then all points or
+ * \param edge_handles Edge(s) being queried
+ * \param edge_handles_size Number of edges being queried
+ * \param on_coords Closest point array
+ * \param on_coords_allocated Allocated size of closest point array
+ * \param on_coords_size Occupied size of closest point array
+ * \param tangent Tangent array
+ * \param tangent_allocated Allocated size of tangent array
+ * \param tangent_size Occupied size of tangent array
+ * \param cvtr First principal curvatures
+ * \param cvtr_allocated Allocated size of first curvature array
+ * \param cvtr_size Occupied size of first curvature array
+  void iGeom_getArrEgEvalXYZ( iGeom_Instance,
+                              iBase_EntityHandle const* edge_handles,
+                              int edge_handles_size,
+                              int coords_size,
+                              double** on_coords,
+                              int* on_coords_allocated,
+                              int* on_coords_size,
+                              double** tangent,
+                              int* tangent_allocated,
+                              int* tangent_size,
+                              double** cvtr,
+                              int* cvtr_allocated,
+                              int* cvtr_size,
+                              int* err );
+ * \param normal Normal array
+ * \param normal_allocated Allocated size of normal array
+ * \param normal_size Occupied size of normal array
+  void iGeom_getArrFcEvalXYZ( iGeom_Instance,
+                              iBase_EntityHandle const* face_handles,
+                              int face_handles_size,
+                              int coords_size,
+                              double** normal,
+                              int* normal_allocated,
+                              int* normal_size,
+                              double** cvtr1,
+                              int* cvtr1_allocated,
+                              int* cvtr1_size,
+                              double** cvtr2,
+                              int* cvtr2_allocated,
+                              int* cvtr2_size,
+                              int* err );
+/**\brief Get the bounding box of the specified entity
+ * Get the bounding box of the specified entity
+  void iGeom_getEntBoundBox( iGeom_Instance,
+                             double* min_x,
+                             double* min_y,
+                             double* min_z,
+                             double* max_x,
+                             double* max_y,
+                             double* max_z,
+                             int* err );
+/**\brief Get the bounding box of the specified entities
+ * Get the bounding box of the specified entities.  Storage order passed back
+ * will be member of iBase_StorageOrder enum.
+ * \param entity_handles Entity handles being queried
+ * \param enttiy_handles_size Number of entities being queried
+ * \param storage_order Storage order of coordinates passed back
+ * \param min_corner Minimum coordinates of bounding boxes
+ * \param min_corner_allocated Allocated size of minimum coordinates array
+ * \param min_corner_size Occupied size of minimum coordinates array
+ * \param max_corner Maximum coordinates of bounding boxes
+ * \param max_corner_allocated Allocated size of maximum coordinates array
+ * \param max_corner_size Occupied size of maximum coordinates array
+  void iGeom_getArrBoundBox( iGeom_Instance,
+                             int* storage_order,
+                             double** min_corner,
+                             int* min_corner_allocated,
+                             int* min_corner_size,
+                             double** max_corner,
+                             int* max_corner_allocated,
+                             int* max_corner_size,
+                             int* err );
+    /**\brief  Get coordinates of specified vertex
+     * Get coordinates of specified vertex.
+     * \param vertex_handle Geom vertex being queried
+     * \param *x Pointer to x coordinate returned from function
+     * \param *y Pointer to y coordinate returned from function
+     * \param *z Pointer to z coordinate returned from function
+  void iGeom_getVtxCoord( iGeom_Instance,
+                          iBase_EntityHandle vertex_handle,
+                          double* x,
+                          double* y,
+                          double* z,
+                          int* err );
+    /**\brief  Get coordinates of specified vertices
+     * Get coordinates of specified vertices.  If storage order is passed in
+     * with a value other than iBase_UNDETERMINED, coordinates are returned
+     * in the specified storage order, otherwise storage order is that native
+     * to the implementation.  Storage order of returned coordinates is also
+     * returned.
+     * \param vertex_handles Array of geom vertex handles whose coordinates are
+     *        being requested
+     * \param vertex_handles_size Number of vertices in vertex_handles array
+     * \param storage_order Pointer to storage order requested/returned from
+     *        function
+     * \param *coords Pointer to array of coordinates returned from function
+     * \param *coords_allocated Pointer to allocated size of coords array
+     * \param *coords_size Pointer to occupied size of coords array
+  void iGeom_getVtxArrCoords( iGeom_Instance,
+                              double** coordinates,
+                              int* coordinates_allocated,
+                              int* coordinates_size,
+                              int* err );
+/**\brief Intersect a ray with the model
+ * Intersect a ray with the model.  Storage orders passed back are members of the
+ * iBase_StorageOrder enumeration; if output is iBase_UNKNOWN, order is in native order
+ * \param x Point from which ray is fired
+ * \param y Point from which ray is fired
+ * \param z Point from which ray is fired
+ * \param dir_x Direction in which ray is fired
+ * \param dir_y Direction in which ray is fired
+ * \param dir_z Direction in which ray is fired
+ * \param intersect_entity_handles Entities intersected by ray
+ * \param intersect_entity_handles_allocated Allocated size of intersections array
+ * \param intersect_entity_hangles_size Occupied size of intersections array
+ * \param intersect_coords Coordinates of intersections
+ * \param intersect_coords_allocated Allocated size of coordinates array
+ * \param intersect_coords_size Occupied size of coordinates array
+ * \param param_coords Distances along ray of intersections
+ * \param param_coords_allocated Allocated size of param_coords array
+ * \param param_coords_size Occupied size of param_coords array
+  void iGeom_getPntRayIntsct( iGeom_Instance,
+                              double x,
+                              double y,
+                              double z,
+                              double dir_x,
+                              double dir_y,
+                              double dir_z,
+                              iBase_EntityHandle** intersect_entity_handles,
+                              int* intersect_entity_handles_allocated,
+                              int* intersect_entity_hangles_size,
+                              double** intersect_coords,
+                              int* intersect_coords_allocated,
+                              int* intersect_coords_size,
+                              double** param_coords,
+                              int* param_coords_allocated,
+                              int* param_coords_size,
+                              int* err );
+/**\brief Intersect an array of rays with the model
+ * Intersect an array of rays with the model.  Storage orders passed back are members of the
+ * iBase_StorageOrder enumeration; if input/output is iBase_UNKNOWN, order is in native order
+ * \param storage_order Storage order of input coordinates
+ * \param coords Points from which rays are fired
+ * \param coords_size Number of points from which rays are fired
+ * \param directions Directions in which rays are fired
+ * \param directions_size Number of coordinates in directions array
+ * \param offset Offset[i] is offset into intersect_entity_handles of ith ray
+  void iGeom_getPntArrRayIntsct( iGeom_Instance,
+                                 const double* coords,
+                                 int coords_size,
+                                 const double* directions,
+                                 int directions_size,
+                                 int** offset,
+                                 int* offset_size,
+                                 int* err );
+/**\brief Get the entity on which a point is located
+ * Get the entity on which a point is located
+ * \param x Point being queried
+ * \param y Point being queried
+ * \param z Point being queried
+ * \param entity_handle Entity on which point is located
+  void iGeom_getPntClsf( iGeom_Instance,
+                         double x,
+                         double y,
+                         double z,
+                         iBase_EntityHandle* entity_handle,
+                         int* err );
+/**\brief Get the entities on which points are located
+ * Get the entities on which points are located.   Storage orders should be members of the
+ * iBase_StorageOrder enumeration; if input is iBase_UNKNOWN, order is in native order
+ * \param storage_order Storage order of coordinates in coords
+ * \param coords Points being queried
+ * \param coords_size Number of entries in coords array
+ * \param entity_handles Entities on which points are located
+ * \param entity_handles_allocated Allocated size of entity_handles array
+ * \param entity_handles_size Occupied size of entity_handles array
+  void iGeom_getPntArrClsf( iGeom_Instance,
+                            int coords_size,
+                            int* entity_handles_allocated,
+                            int* err );
+/**\brief Get the sense of a face with respect to a region
+ * Get the sense of a face with respect to a region.  Sense returned is -1, 0, or 1,
+ * representing "reversed", "both", or "forward".  "both" sense indicates that face bounds
+ * the region once with each sense.
+ * \param face Face being queried
+ * \param region Region being queried
+ * \param sense_out Sense of face with respect to region
+  void iGeom_getEntNrmlSense( iGeom_Instance,
+                              iBase_EntityHandle face,
+                              iBase_EntityHandle region,
+                              int* sense_out,
+                              int* err );
+/**\brief Get the senses of an array of faces with respect to an array of regions
+ * Get the senses of an array of faces with respect to an array of regions.  Sense returned
+ * is -1, 0, or 1, representing "reversed", "both", or "forward".  "both" sense indicates
+ * that face bounds the region once with each sense.
+ * \param face_handles Faces being queried
+ * \param face_handles_size Size of face handles array
+ * \param region_handles Regions being queried
+ * \param region_handles_size Size of region handles array
+ * \param sense Senses of faces with respect to regions
+ * \param sense_allocated Allocated size of senses array
+ * \param sense_size Occupied size of senses array
+  void iGeom_getArrNrmlSense( iGeom_Instance,
+                              iBase_EntityHandle const* region_handles,
+                              int region_handles_size,
+                              int** sense,
+                              int* sense_allocated,
+                              int* sense_size,
+                              int* err );
+/**\brief Get the sense of an edge with respect to a face
+ * Get the sense of an edge with respect to a face.  Sense returned is -1, 0, or 1,
+ * representing "reversed", "both", or "forward".  "both" sense indicates that edge bounds
+ * the face once with each sense.
+ * \param edge Edge being queried
+ * \param sense_out Sense of edge with respect to face
+  void iGeom_getEgFcSense( iGeom_Instance,
+                           iBase_EntityHandle edge,
+                           int* sense_out,
+                           int* err );
+/**\brief Get the senses of an array of edges with respect to an array of faces
+ * Get the senses of an array of edges with respect to an array of faces.  Sense returned
+ * that edge bounds the face once with each sense.
+ * \param edge_handles Edges being queried
+ * \param edge_handles_size Size of edge handles array
+  void iGeom_getEgFcArrSense( iGeom_Instance,
+                              int** sense,
+                              int* sense_size,
+                              int* err );
+/**\brief Get the sense of a vertex pair with respect to an edge
+ * Get the sense of a vertex pair with respect to an edge.  Sense returned is -1, 0, or 1,
+ * representing "reversed", "both", or "forward".  "both" sense indicates that vertices
+ * are identical and that vertex bounds both sides of the edge
+ * \param vertex1 First vertex being queried
+ * \param vertex2 Second vertex being queried
+ * \param sense_out Sense of vertex pair with respect to edge
+  void iGeom_getEgVtxSense( iGeom_Instance,
+                            iBase_EntityHandle vertex1,
+                            iBase_EntityHandle vertex2,
+                            int* sense_out,
+                            int* err );
+/**\brief Get the senses of vertex pair with respect to a edges
+ * Get the senses of vertex pairs with respect to edges.  Sense returned is -1, 0, or 1,
+ * representing "reversed", "both", or "forward".  "both" sense indicates that both vertices
+ * in pair are identical and that vertex bounds both sides of the edge
+ * \param vertex_handles_1 First vertex being queried
+ * \param vertex_handles_1_size Number of vertices in vertices array
+ * \param vertex_handles_2 Second vertex being queried
+ * \param vertex_handles_2_size Number of vertices in vertices array
+ * \param sense Sense of vertex pair with respect to edge
+ * \param sense_allocated Allocated size of sense array
+ * \param sense_size Occupied size of sense array
+  void iGeom_getEgVtxArrSense( iGeom_Instance,
+                               iBase_EntityHandle const* vertex_handles_1,
+                               int veretx_handles_1_size,
+                               iBase_EntityHandle const* vertex_handles_2,
+                               int vertex_handles_2_size,
+                               int** sense,
+                               int* sense_size,
+                               int* err );
+/**\brief Return the measure (length, area, volume) of entities
+ * Return the measure (length, area, volume) of entities
+ * \param entity_handles Array of entities being queried
+ * \param entity_handles_size Number of entities in entity array
+ * \param measures Measures of entities being queried
+ * \param measures_allocated Allocated size of measures array
+ * \param measures_size Occupied size of measures array
+  void iGeom_measure( iGeom_Instance,
+                      double** measures,
+                      int* measures_allocated,
+                      int* measures_size,
+                      int* err );
+/**\brief Get the geometric type of an entity
+ * Get the geometric type of an entity.  Specific types depend on implementation.
+ * \param face_type Face type
+ * \param face_type_length Length of face type string
+  void iGeom_getFaceType( iGeom_Instance,
+                          char* face_type,
+                          int* err,
+                          int* face_type_length);
+/**\brief Return whether interface has information about parameterization
+ * Return whether an interface has information about parameterization (!=0) or not (0)
+ * \param is_parametric If non-zero, interface has information about parameterization
+  void iGeom_getParametric( iGeom_Instance,
+                            int* is_parametric,
+                            int* err );
+/**\brief Return whether an entity has a parameterization
+ * Return whether an entity has a parameterization (!= 0) or not (=0)
+ * \param is_parametric Entity has a parameterization (!= 0) or not (=0)
+  void iGeom_isEntParametric( iGeom_Instance,
+                              int* parametric,
+                              int* err );
+/**\brief Return whether entities have parameterizations
+ * Return whether entities have parameterizations (!= 0) or not (=0)
+ * \param entity_handles Entities being queried
+ * \param is_parametric entity_handles[i] has a parameterization (!= 0) or not (=0)
+ * \param is_parametric_allocated Allocated size of is_parametric array
+ * \param is_parametric_size Occupied size of is_parametric array
+  void iGeom_isArrParametric( iGeom_Instance,
+                              int** is_parametric,
+                              int* is_parametric_allocated,
+                              int* is_parametric_size,
+                              int* err );
+/**\brief Return coordinate position at specified parametric position on entity
+ * Return coordinate position at specified parametric position on entity.
+ * \param u Parametric coordinate being queried
+ * \param v Parametric coordinate being queried
+ * \param x Spatial coordinate at parametric position being queried
+ * \param y Spatial coordinate at parametric position being queried
+ * \param z Spatial coordinate at parametric position being queried
+  void iGeom_getEntUVtoXYZ( iGeom_Instance,
+                            double u,
+                            double v,
+                            double* x,
+                            double* y,
+                            double* z,
+                            int* err );
+/**\brief Return coordinate positions at specified parametric position(s) on entity(ies)
+ * Return coordinate positions at specified parametric position(s) on entity(ies).
+ * If either the number of entities or number of parametric coordinate pairs is unity, then
+ * all points or entities are queried for that entity or point, respectively, otherwise each
+ * \param storage_order Storage order of uv coordinates input
+ * \param uv Coordinates being queried
+ * \param uv_size Number of coordinates in array
+ * \param coordinates Coordinates of parametric positions
+ * \param coordinates_allocated Allocated size of coordinates array
+ * \param coordinates_size Occupied size of coordinates array
+  void iGeom_getArrUVtoXYZ( iGeom_Instance,
+                            double const* uv,
+                            int uv_size,
+                            int* err );
+  void iGeom_getEntUtoXYZ( iGeom_Instance,
+                           double u,
+                           double* x,
+                           double* y,
+                           double* z,
+                           int* err );
+  void iGeom_getArrUtoXYZ( iGeom_Instance,
+                           double const* u,
+                           int u_size,
+                           int* err );
+/**\brief Return parametric position at specified spatial position on entity
+ * Return parametric position at specified spatial position on entity
+ * \param x Spatial coordinate being queried
+ * \param y Spatial coordinate being queried
+ * \param z Spatial coordinate being queried
+ * \param u Parametric coordinate at spatial position being queried
+ * \param v Parametric coordinate at spatial position being queried
+  void iGeom_getEntXYZtoUV( iGeom_Instance,
+                            double x,
+                            double y,
+                            double z,
+                            double* u,
+                            double* v,
+                            int* err );
+  void iGeom_getEntXYZtoU( iGeom_Instance,
+                           double x,
+                           double y,
+                           double z,
+                           double* u,
+                           int* err );
+/**\brief Return parametric positions at specified spatial position(s) on entity(ies)
+ * Return parametric positions at specified spatial position(s) on entity(ies).
+ * If either the number of entities or number of spatial coordinate triples is unity, then
+ * \param storage_order Storage order of spatial coordinates input
+ * \param coordinates Coordinates being queried
+ * \param coordinates_size Number of coordinates in array
+ * \param uv Coordinates of parametric positions
+ * \param uv_allocated Allocated size of coordinates array
+ * \param uv_size Occupied size of coordinates array
+  void iGeom_getArrXYZtoUV( iGeom_Instance,
+                            double** uv,
+                            int* uv_allocated,
+                            int* uv_size,
+                            int* err );
+/**\brief Return spatial positions at specified parametric position(s) on entity(ies)
+ * Return spatial positions at specified parametric position(s) on entity(ies).
+ * \param u Coordinates of parametric positions
+ * \param u_allocated Allocated size of coordinates array
+ * \param u_size Occupied size of coordinates array
+  void iGeom_getArrXYZtoU( iGeom_Instance,
+                           double** u,
+                           int* u_allocated,
+                           int* u_size,
+                           int* err );
+/**\brief Return parametric position at specified spatial position on entity, based on parametric position hint
+ * Return parametric position at specified spatial position on entity, based on parametric
+ * position hint.  For this function, u and v are input with parameters from which to start search.
+ * Typically this will reduce the search time for new parametric coordinates.
+  void iGeom_getEntXYZtoUVHint( iGeom_Instance,
+                                double x,
+                                double y,
+                                double z,
+                                double* u,
+                                double* v,
+                                int* err );
+/**\brief Return parametric positions at specified spatial position(s) on entity(ies), based on parametric position hints
+ * Return parametric positions at specified spatial position(s) on entity(ies), based on
+ * parametric position hints.  If either the number of entities or number of spatial
+ * coordinate triples is unity, then all points or entities are queried for that entity
+ * or point, respectively, otherwise each point corresponds to each entity.  storage_order
+ * should be a value in the iBase_StorageOrder enum; if input as iBase_UNKNOWN, order is in
+ * native order with respect to implementation.
+  void iGeom_getArrXYZtoUVHint( iGeom_Instance,
+                                int coords_size,
+                                double** uv,
+                                int* uv_size,
+                                int* err );
+/**\brief Get parametric range of entity
+ * Get parametric range of entity
+ * \param u_min Minimum parametric coordinate for entity
+ * \param v_min Minimum parametric coordinate for entity
+ * \param u_max Maximum parametric coordinate for entity
+ * \param v_max Maximum parametric coordinate for entity
+  void iGeom_getEntUVRange( iGeom_Instance,
+                            double* u_min,
+                            double* v_min,
+                            double* u_max,
+                            double* v_max,
+                            int* err );
+  void iGeom_getEntURange( iGeom_Instance,
+                           double* u_min,
+                           double* u_max,
+                           int* err );
+/**\brief Get parametric range of entities
+ * Get parametric range of entities
+ * \param storage_order Storage order of parametric coordinates being returned
+ * \param uv_min Minimum parametric coordinate for entities
+ * \param uv_min_allocated Allocated size of minimum parametric coordinate array
+ * \param uv_min_size Occupied size of minimum parametric coordinate array
+ * \param uv_max Maximum parametric coordinate for entities
+ * \param uv_max_allocated Allocated size of maximum parametric coordinate array
+ * \param uv_max_size Occupied size of maximum parametric coordinate array
+  void iGeom_getArrUVRange( iGeom_Instance,
+                            double** uv_min,
+                            int* uv_min_allocated,
+                            int* uv_min_size,
+                            double** uv_max,
+                            int* uv_max_allocated,
+                            int* uv_max_size,
+                            int* err );
+ * \param u_min Minimum parametric coordinate for entities
+ * \param u_min_allocated Allocated size of minimum parametric coordinate array
+ * \param u_min_size Occupied size of minimum parametric coordinate array
+ * \param u_max Maximum parametric coordinate for entities
+ * \param u_max_allocated Allocated size of maximum parametric coordinate array
+ * \param u_max_size Occupied size of maximum parametric coordinate array
+  void iGeom_getArrURange( iGeom_Instance,
+                           double** u_min,
+                           int* u_min_allocated,
+                           int* u_min_size,
+                           double** u_max,
+                           int* u_max_allocated,
+                           int* u_max_size,
+                           int* err );
+/**\brief Return the face parametric coordinates for a parametric position on a bounding edge
+ * Return the face parametric coordinates for a parametric position on a bounding edge
+ * \param in_u Parametric position on edge
+ * \param u Corresponding parametric position on face
+ * \param v Corresponding parametric position on face
+  void iGeom_getEntUtoUV( iGeom_Instance,
+                          double in_u,
+                          double* u,
+                          double* v,
+                          int* err );
+/**\brief Return parametric coordinates on face of vertex position
+ * Return parametric coordinates on face of vertex position
+ * \param vertex_handle Vertex being queried
+  void iGeom_getVtxToUV( iGeom_Instance,
+                         double* u,
+                         double* v,
+                         int* err );
+/**\brief Return parametric coordinates on edge of vertex position
+ * Return parametric coordinates on edge of vertex position
+  void iGeom_getVtxToU( iGeom_Instance,
+                        double* u,
+                        int* err );
+/**\brief Return the face parametric coordinates for a parametric position on bounding edges
+ * Return the face parametric coordinates for a parametric position on bounding edges
+ * \param face_handles_size Number of faces being queried
+ * \param u_in Parametric positions on edges
+ * \param u_in_size Number of parametric positions on edges
+ * \param storage_order Storage order of coordinates returned
+ * \param uv Corresponding parametric positions on faces
+ * \param uv_allocated Allocated size of parameter array
+ * \param uv_size Occupied size of parameter array
+  void iGeom_getArrUtoUV( iGeom_Instance,
+                          double const* u_in,
+                          int u_in_size,
+                          double** uv,
+                          int* uv_size,
+                          int* err );
+/**\brief Return parametric coordinates on faces of vertex positions
+ * Return parametric coordinates on faces of vertex positions
+ * \param vertex_handles Vertices being queried
+ * \param vertex_handles_size Number of vertices being queried
+ * \param uv_allocated Allocated size of positions array
+ * \param uv_size Occupied size of positions array
+  void iGeom_getVtxArrToUV( iGeom_Instance,
+                            iBase_EntityHandle const* vertex_handles,
+                            int vertex_handles_size,
+                            double** uv,
+                            int* uv_size,
+                            int* err );
+/**\brief Return parametric coordinates on edges of vertex positions
+ * Return parametric coordinates on edges of vertex positions
+ * \param u Corresponding parametric positions on faces
+ * \param u_allocated Allocated size of positions array
+ * \param u_size Occupied size of positions array
+  void iGeom_getVtxArrToU( iGeom_Instance,
+                           double** u,
+                           int* u_allocated,
+                           int* u_size,
+                           int* err );
+/**\brief Return the normal at a specified parametric position
+ * Return the normal at a specified parametric position
+ * \param u Parametric position being queried
+ * \param v Parametric position being queried
+ * \param nrml_i Normal at specified position
+ * \param nrml_j Normal at specified position
+ * \param nrml_k Normal at specified position
+  void iGeom_getEntNrmlUV( iGeom_Instance,
+                           double u,
+                           double v,
+                           double* nrml_i,
+                           double* nrml_j,
+                           double* nrml_k,
+                           int* err );
+/**\brief Return the normals at a specified parametric positions
+ * Return the normals at a specified parametric positions.  If either the number of
+ * entities or number of spatial
+  void iGeom_getArrNrmlUV( iGeom_Instance,
+                           double const* parameters,
+                           int parameters_size,
+                           double** normals,
+                           int* err );
+/**\brief
+  void iGeom_getEntTgntU( iGeom_Instance,
+                          double u,
+                          double* tgnt_i,
+                          double* tgnt_j,
+                          double* tgnt_k,
+                          int* err );
+/**\brief
+  void iGeom_getArrTgntU( iGeom_Instance,
+                          int* err );
+/**\brief
+  void iGeom_getEnt1stDrvt( iGeom_Instance,
+                            double u,
+                            double v,
+                            double** drvt_u,
+                            int* drvt_u_allocated,
+                            int* drvt_u_size,
+                            double** drvt_v,
+                            int* dvrt_v_allocated,
+                            int* dvrt_v_size,
+                            int* err );
+/**\brief
+  void iGeom_getArr1stDrvt( iGeom_Instance,
+                            double const* uv,
+                            int uv_size,
+                            double** dvtr_u,
+                            int* dvrt_u_allocated,
+                            int* dvrt_u_size,
+                            int** u_offset,
+                            int* u_offset_allocated,
+                            int* u_offset_size,
+                            double** dvrt_v,
+                            int* dvrt_v_size,
+                            int** v_offset,
+                            int* v_offset_allocated,
+                            int* v_offset_size,
+                            int* err );
+/**\brief
+  void iGeom_getEnt2ndDrvt( iGeom_Instance,
+                            double u,
+                            double v,
+                            double** drvt_uu,
+                            int* drvt_uu_allocated,
+                            int* drvt_uu_size,
+                            double** drvt_vv,
+                            int* dvrt_vv_allocated,
+                            int* dvrt_vv_size,
+                            double** drvt_uv,
+                            int* dvrt_uv_allocated,
+                            int* dvrt_uv_size,
+                            int* err );
+/**\brief
+  void iGeom_getArr2ndDrvt( iGeom_Instance,
+                            double const* uv,
+                            int uv_size,
+                            double** dvtr_uu,
+                            int* dvrt_uu_allocated,
+                            int* dvrt_uu_size,
+                            int** uu_offset,
+                            int* uu_offset_allocated,
+                            int* uu_offset_size,
+                            double** dvtr_vv,
+                            int** vv_offset,
+                            int* vv_offset_allocated,
+                            int* vv_offset_size,
+                            double** dvrt_uv,
+                            int** uv_offset,
+                            int* uv_offset_allocated,
+                            int* uv_offset_size,
+                            int* err );
+/**\brief
+  void iGeom_getFcCvtrUV( iGeom_Instance,
+                          double u,
+                          double v,
+                          double* cvtr1_i,
+                          double* cvtr1_j,
+                          double* cvtr1_k,
+                          double* cvtr2_i,
+                          double* cvtr2_j,
+                          double* cvtr2_k,
+                          int* err );
+/**\brief
+  void iGeom_getFcArrCvtrUV( iGeom_Instance,
+                             double const* uv,
+                             int uv_size,
+                             double** cvtr_1,
+                             int* cvtr_1_size,
+                             double** cvtr_2,
+                             int* cvtr_2_size,
+                             int* err );
+/**\brief
+  void iGeom_isEntPeriodic( iGeom_Instance,
+                            int* in_u,
+                            int* in_v,
+                            int* err );
+/**\brief
+  void iGeom_isArrPeriodic( iGeom_Instance,
+                            int** in_uv,
+                            int* in_uv_allocated,
+                            int* in_uv_size,
+                            int* err );
+/**\brief
+  void iGeom_isFcDegenerate( iGeom_Instance,
+                             int* is_degenerate,
+                             int* err );
+/**\brief
+  void iGeom_isFcArrDegenerate( iGeom_Instance,
+                                int** degenerate,
+                                int* degenerate_allocated,
+                                int* degenerate_size,
+                                int* err );
+/**\brief
+  void iGeom_getTolerance( iGeom_Instance,
+                           int* type,
+                           double* tolerance,
+                           int* err );
+/**\brief
+  void iGeom_getEntTolerance( iGeom_Instance,
+                              int* err );
+/**\brief
+  void iGeom_getArrTolerance( iGeom_Instance,
+                              double** tolerances,
+                              int* tolerances_allocated,
+                              int* tolerances_size,
+                              int* err );
+    /**\brief  Initialize an iterator over specified entity type, topology, and size
+     * Initialize an iterator over specified entity type, topology, and size,
+     * for a specified set or instance.  Iterator returned can be used as input
+     * to functions returning the entity for the iterator.  If all entities of
+     * a specified type and/or topology are to be iterated, specify
+     * iBase_ALL_TYPES or iGeom_ALL_TOPOLOGIES, respectively.  Specified type
+     * iGeom_EntityTopology enumerations, respectively.
+     * \param entity_set_handle Entity set being iterated
+     * \param requested_entity_type Type of entity to iterate
+     * \param requested_entity_topology Topology of entity to iterate
+     * \param entity_iterator Pointer to iterator returned from function
+  void iGeom_initEntIter( iGeom_Instance,
+                          iBase_EntitySetHandle entity_set_handle,
+                          int entity_dimension,
+                          iGeom_EntityIterator* entity_iterator,
+                          int* err );
+    /**\brief Initialize an array iterator over specified entity type, topology, and
+     *        size
+     * Initialize an array iterator over specified entity type, topology, and
+     * size, for a specified set or instance.  Iterator returned can be used
+     * as input to functions returning entities for the iterator.  If all
+     * entities of a specified type and/or topology are to be iterated,
+     * specify iBase_ALL_TYPES or iGeom_ALL_TOPOLOGIES, respectively.
+     * Specified type or topology must be a value in the iBase_EntityType or
+     * \param requested_array_size Size of chunks of handles returned for each
+     *        value of the iterator
+     * \param entArr_iterator Pointer to iterator returned from function
+  void iGeom_initEntArrIter( iGeom_Instance,
+                             int requested_array_size,
+                             iGeom_EntityArrIterator* entArr_iterator,
+                             int* err );
+    /**\brief  Get entity corresponding to an iterator and increment iterator
+     * Get the entity corresponding to an array iterator, and increment the
+     * iterator.  Also return whether the next value of the iterator has
+     * an entity (if non-zero, next iterator value is the end of the
+     * iteration).
+     * \param entity_iterator Iterator being queried
+     * \param entity_handle Pointer to an entity handle corresponding to the
+     *        current value of iterator
+     * \param has_data Pointer to flag; if returned non-zero, next iterator
+     *        has an entity
+  void iGeom_getNextEntIter( iGeom_Instance,
+                             iGeom_EntityIterator,
+                             int* has_data,
+                             int* err );
+    /**\brief  Get entities contained in array iterator and increment iterator
+     * Get the entities contained in an array iterator, and increment the
+     * any entities (if non-zero, next iterator value is the end of the
+     * iteration).
+     * \param entArr_iterator Iterator being queried
+     * \param *entity_handles Pointer to array of entity handles contained in
+     *        array
+     *        has a non-zero number of entities
+  void iGeom_getNextEntArrIter( iGeom_Instance,
+                                iGeom_EntityArrIterator,
+                                int* has_data,
+                                int* err );
+    /**\brief  Reset the iterator
+     * Reset the iterator
+     * \param entity_iterator Iterator to reset
+  void iGeom_resetEntIter( iGeom_Instance,
+                           int* err );
+    /**\brief  Reset the array iterator
+     * Reset the array iterator
+     * \param entArr_iterator Iterator to reset
+  void iGeom_resetEntArrIter( iGeom_Instance,
+                              int* err );
+    /**\brief  Destroy the specified iterator
+     * Destroy the specified iterator
+     * \param entity_iterator Iterator which gets destroyed
+  void iGeom_endEntIter( iGeom_Instance, iGeom_EntityIterator, int* err );
+    /**\brief  Destroy the specified array iterator
+     * Destroy the specified array iterator
+     * \param entArr_iterator Iterator which gets destroyed
+  void iGeom_endEntArrIter( iGeom_Instance, iGeom_EntityArrIterator, int* err );
+/**\brief
+  void iGeom_copyEnt( iGeom_Instance,
+                      iBase_EntityHandle source,
+                      iBase_EntityHandle* copy,
+                      int* err );
+/**\brief
+  void iGeom_sweepEntAboutAxis( iGeom_Instance,
+                                iBase_EntityHandle geom_entity,
+                                double angle,
+                                double axis_normal_x,
+                                double axis_normal_y,
+                                double axis_normal_z,
+                                iBase_EntityHandle* geom_entity2,
+                                int* err );
+  /**\brief Delete all entities and sets
+  void iGeom_deleteAll( iGeom_Instance, int* err );
+    /**\brief  Delete specified entity
+     * Delete specified entity
+     * \param entity_handle Entity to be deleted
+  void iGeom_deleteEnt( iGeom_Instance,
+                        iBase_EntityHandle,
+                        int* err );
+    /**\brief Create a sphere centered on the origin
+  void iGeom_createSphere( iGeom_Instance,
+                           double radius,
+                           iBase_EntityHandle* sphere_handle_out,
+                           int* err );
+/**\brief Create a prism centered on the origin
+void iGeom_createPrism( iGeom_Instance,
+                   double height,
+		   int n_sides,
+		   double major_rad,
+	           double minor_rad,
+	           iBase_EntityHandle* prism_handle_out,									          int* err );
+/**\brief
+  void iGeom_createBrick( iGeom_Instance,
+                          double x,
+                          double y,
+                          double z,
+                          iBase_EntityHandle* geom_entity,
+                          int* err );
+/**\brief
+  void iGeom_createCylinder( iGeom_Instance,
+                             double height,
+                             double major_rad,
+                             double minor_rad,
+                             int* err );
+/**\brief
+  void iGeom_createTorus( iGeom_Instance,
+                          double major_rad,
+                          double minor_rad,
+                          int* err );
+/**\brief
+  void iGeom_moveEnt( iGeom_Instance,
+                      double x,
+                      double y,
+                      double z,
+                      int* err );
+/**\brief
+  void iGeom_rotateEnt( iGeom_Instance,
+                        double angle,
+                        int* err );
+/**\brief
+  void iGeom_reflectEnt( iGeom_Instance,
+                         double plane_normal_x,
+                         double plane_normal_y,
+                         double plane_normal_z,
+                         int* err );
+/**\brief
+  void iGeom_scaleEnt( iGeom_Instance,
+                       double scale_x,
+                       double scale_y,
+                       double scale_z,
+                       int* err );
+/**\brief
+  void iGeom_uniteEnts( iGeom_Instance,
+                        iBase_EntityHandle const* geom_entities,
+                        int geom_entities_size,
+                        int* err );
+/**\brief
+  void iGeom_subtractEnts( iGeom_Instance,
+                           iBase_EntityHandle blank,
+                           iBase_EntityHandle tool,
+                           int* err );
+/**\brief
+  void iGeom_intersectEnts( iGeom_Instance,
+                            iBase_EntityHandle entity2,
+			    iBase_EntityHandle entity1,
+			    int* err );
+/**\brief
+  void iGeom_sectionEnt( iGeom_Instance,
+                         double offset,
+                         int reverse,
+                         int* err );
+/**\brief
+  void iGeom_imprintEnts( iGeom_Instance,
+                          int* err );
+/**\brief
+  void iGeom_mergeEnts( iGeom_Instance,
+                        double tolerance,
+                        int* err );
+    /**\brief  Create an entity set
+     * Create an entity set, either ordered (isList=1) or unordered
+     * (isList=0).  Unordered entity sets can contain a given entity or
+     * set only once.
+     * \param isList If non-zero, an ordered list is created, otherwise an
+     *        unordered set is created.
+     * \param entity_set_created Entity set created by function
+  void iGeom_createEntSet(iGeom_Instance instance,
+                          int isList,
+                          iBase_EntitySetHandle* entity_set_created,
+                          int *err);
+    /**\brief  Destroy an entity set
+     * Destroy an entity set
+     * \param entity_set Entity set to be destroyed
+  void iGeom_destroyEntSet(iGeom_Instance instance,
+                           iBase_EntitySetHandle entity_set,
+                           int *err);
+    /**\brief  Return whether a specified set is ordered or unordered
+     * Return whether a specified set is ordered (*is_list=1) or
+     * unordered (*is_list=0)
+     * \param entity_set Entity set being queried
+     * \param is_list Pointer to flag returned from function
+  void iGeom_isList(iGeom_Instance instance,
+                    int *is_list,
+                    int *err);
+    /**\brief  Get the number of entity sets contained in a set or interface
+     * Get the number of entity sets contained in a set or interface.  If
+     * a set is input which is not the root set, num_hops indicates the
+     * maximum number of contained sets from entity_set_handle to one of the
+     * contained sets, inclusive of the contained set.
+     * \param num_hops Maximum hops from entity_set_handle to contained set,
+     *        inclusive of the contained set
+     * \param num_sets Pointer to the number of sets returned from function
+  void iGeom_getNumEntSets(iGeom_Instance instance,
+                           int num_hops,
+                           int *num_sets,
+                           int *err);
+    /**\brief  Get the entity sets contained in a set or interface
+     * Get the entity sets contained in a set or interface.  If
+     * \param *contained_set_handles Pointer to array of set handles returned
+     *        from function
+     * \param contained_set_handles_allocated Pointer to allocated length of
+     *        contained_set_handles array
+     * \param contained_set_handles_size Pointer to occupied length of
+  void iGeom_getEntSets(iGeom_Instance instance,
+                        int num_hops,
+                        iBase_EntitySetHandle** contained_set_handles,
+                        int* contained_set_handles_allocated,
+                        int* contained_set_handles_size,
+                        int *err);
+    /**\brief  Add an entity to a set
+     * Add an entity to a set
+     * \param entity_handle The entity being added
+     * \param entity_set Pointer to the set being added to
+  void iGeom_addEntToSet(iGeom_Instance instance,
+                         int *err);
+    /**\brief  Remove an entity from a set
+     * Remove an entity from a set
+     * \param entity_handle The entity being removed
+     * \param entity_set Pointer to the set being removed from
+  void iGeom_rmvEntFromSet(iGeom_Instance instance,
+                           int *err);
+    /**\brief  Add an array of entities to a set
+     * Add an array of entities to a set
+     * \param entity_handles Array of entities being added
+  void iGeom_addEntArrToSet(iGeom_Instance instance,
+                            const iBase_EntityHandle* entity_handles,
+                            int *err);
+    /**\brief  Remove an array of entities from a set
+     * Remove an array of entities from a set
+     * \param entity_handles Array of entities being remove
+  void iGeom_rmvEntArrFromSet(iGeom_Instance instance,
+                              int *err);
+    /**\brief  Add an entity set to a set
+     * Add an entity set to a set
+     * \param entity_set_to_add The entity set being added
+     * \param entity_set_handle Pointer to the set being added to
+  void iGeom_addEntSet(iGeom_Instance instance,
+                       iBase_EntitySetHandle entity_set_to_add,
+                       int *err);
+    /**\brief  Remove an entity set from a set
+     * Remove an entity set from a set
+     * \param entity_set_to_remove The entity set being removed
+     * \param entity_set_handle Pointer to the set being removed from
+  void iGeom_rmvEntSet(iGeom_Instance instance,
+                       iBase_EntitySetHandle entity_set_to_remove,
+                       int *err);
+    /**\brief  Return whether an entity is contained in another set
+     * Return whether an entity is contained (*is_contained=1) or not
+     * contained (*is_contained=0) in another set
+     * \param containing_entity_set Entity set being queried
+     * \param contained_entity Entity potentially contained in
+     *        containing_entity_set
+     * \param is_contained Pointer to flag returned from function
+  void iGeom_isEntContained(iGeom_Instance instance,
+                            iBase_EntitySetHandle containing_entity_set,
+                            iBase_EntityHandle contained_entity,
+                            int *is_contained,
+                            int *err);
+    /**\brief  Return whether entities are contained in a set
+     * Return whether each entity is contained in the set.
+     * \param instance iMesh instance handle
+     * \param entity_handles List of entities for which to check containment.
+     * \param is_contained One value for each input entity, 1 if contained
+     *          in set, zero otherwise.
+  void iGeom_isEntArrContained( iGeom_Instance instance,
+                         /*in*/ iBase_EntitySetHandle containing_set,
+                         /*in*/ const iBase_EntityHandle* entity_handles,
+                         /*in*/ int num_entity_handles,
+                      /*inout*/ int** is_contained,
+                      /*inout*/ int* is_contained_allocated,
+                        /*out*/ int* is_contained_size,
+                        /*out*/ int* err );
+    /**\brief  Return whether an entity set is contained in another set
+     * Return whether a set is contained (*is_contained=1) or not contained
+     * (*is_contained=0) in another set
+     * \param contained_entity_set Entity set potentially contained in
+  void iGeom_isEntSetContained(iGeom_Instance instance,
+                               iBase_EntitySetHandle contained_entity_set,
+                               int *err);
+    /**\brief  Add parent/child links between two sets
+     * Add parent/child links between two sets.  Makes parent point to child
+     * and child point to parent.
+     * \param parent_entity_set Pointer to parent set
+     * \param child_entity_set Pointer to child set
+  void iGeom_addPrntChld(iGeom_Instance instance,
+                         iBase_EntitySetHandle parent_entity_set,
+                         iBase_EntitySetHandle child_entity_set,
+                         int *err);
+    /**\brief  Remove parent/child links between two sets
+     * Remove parent/child links between two sets.
+  void iGeom_rmvPrntChld(iGeom_Instance instance,
+                         int *err);
+    /**\brief  Return whether two sets are related by parent/child links
+     * Return whether two sets are related (*is_child=1) or not (*is_child=0)
+     * by parent/child links
+     * \param is_child Pointer to flag returned from function
+  void iGeom_isChildOf(iGeom_Instance instance,
+                       int *is_child,
+                       int *err);
+    /**\brief  Get the number of child sets linked from a specified set
+     * Get the number of child sets linked from a specified set.  If num_hops
+     * is non-zero, this represents the maximum hops from entity_set to any
+     * child in the count.
+     * \param num_hops Maximum hops from entity_set_handle to child set,
+     *        inclusive of the child set
+     * \param num_child Pointer to number of children returned from function
+  void iGeom_getNumChld(iGeom_Instance instance,
+                        int num_hops,
+                        int *num_child,
+                        int *err);
+    /**\brief  Get the number of parent sets linked from a specified set
+     * Get the number of parent sets linked from a specified set.  If num_hops
+     * parent in the count.
+     * \param num_hops Maximum hops from entity_set_handle to parent set,
+     *        inclusive of the parent set
+     * \param num_parent Pointer to number of parents returned from function
+  void iGeom_getNumPrnt(iGeom_Instance instance,
+                        int num_hops,
+                        int *num_parent,
+                        int *err);
+    /**\brief  Get the child sets linked from a specified set
+     * Get the child sets linked from a specified set.  If num_hops
+     * child.
+     * \param instance iGeom instance handle
+     * \param from_entity_set Entity set being queried
+     * \param *entity_set_handles Pointer to array of child sets
+     * \param *entity_set_handles_allocated Pointer to allocated size of
+     *        entity_set_handles array
+     * \param *entity_set_handles_size Pointer to occupied size of
+     * \param *err Pointer to error type returned from function
+  void iGeom_getChldn(iGeom_Instance instance,
+                      iBase_EntitySetHandle from_entity_set,
+                      int num_hops,
+                      iBase_EntitySetHandle** entity_set_handles,
+                      int* entity_set_handles_allocated,
+                      int* entity_set_handles_size,
+                      int *err);
+    /**\brief  Get the parent sets linked from a specified set
+     * Get the parent sets linked from a specified set.  If num_hops
+     * parent.
+     * \param *entity_set_handles Pointer to array of parent sets
+  void iGeom_getPrnts(iGeom_Instance instance,
+                      int num_hops,
+                      int *err);
+    /**\brief  Create a tag with specified name, size, and type
+     * Create a tag with specified name, size, and type.  Tag size is in
+     * units of size of tag_type data types.  Value input for tag type must be
+     * value in iBase_TagType enumeration.
+     * \param tag_name Character string indicating tag name
+     * \param tag_size Size of each tag value, in units of number of tag_type
+     *        entities
+     * \param tag_type Data type for data stored in this tag
+     * \param tag_handle Pointer to tag handle returned from function
+     * \param tag_name_len Length of tag name string
+  void iGeom_createTag(iGeom_Instance instance,
+                       const char* tag_name,
+                       int tag_size,
+                       int tag_type,
+                       iBase_TagHandle* tag_handle,
+                       int *err,
+                       int tag_name_len );
+    /**\brief  Destroy a tag
+     * Destroy a tag.  If forced is non-zero and entities still have values
+     * set for this tag, tag is deleted anyway and those values disappear,
+     * otherwise tag is not deleted.
+     * \param tag_handle Handle of tag to be deleted
+     * \param forced If non-zero, delete the tag even if entities have values
+     *        set for that tag
+  void iGeom_destroyTag(iGeom_Instance instance,
+                        iBase_TagHandle tag_handle,
+                        int forced,
+                        int *err);
+    /**\brief  Get the name for a given tag handle
+     * Get the name for a given tag handle
+     * \param tag_handle Tag handle being queried
+     * \param name Pointer to character string to store name returned from
+     *        function
+     * \param name_len Length of character string input to function
+  void iGeom_getTagName(iGeom_Instance instance,
+                        char *name,
+                        int* err,
+                        int name_len);
+    /**\brief  Get size of a tag in units of numbers of tag data type
+     * Get size of a tag in units of numbers of tag data type
+     * \param tag_handle Handle of tag being queried
+     * \param tag_size Pointer to tag size returned from function
+  void iGeom_getTagSizeValues(iGeom_Instance instance,
+                              int *tag_size,
+                              int *err);
+    /**\brief  Get size of a tag in units of bytes
+     * Get size of a tag in units of bytes
+  void iGeom_getTagSizeBytes(iGeom_Instance instance,
+                             int *tag_size,
+                             int *err);
+    /**\brief  Get a the handle of an existing tag with the specified name
+     * Get a the handle of an existing tag with the specified name
+     * \param tag_name Name of tag being queried
+  void iGeom_getTagHandle(iGeom_Instance instance,
+                          iBase_TagHandle *tag_handle,
+                          int *err,
+                          int tag_name_len);
+    /**\brief  Get the data type of the specified tag handle
+     * Get the data type of the specified tag handle.  Tag type is a value in
+     * the iBase_TagType enumeration.
+     * \param tag_handle Handle for the tag being queried
+     * \param tag_type Pointer to tag type returned from function
+  void iGeom_getTagType(iGeom_Instance instance,
+                        int *tag_type,
+                        int *err);
+    /**\brief  Set a tag value of arbitrary type on an entity set
+     * Set a tag value of arbitrary type on an entity set.  Tag data is
+     * passed as char* type,
+     * but really represents pointer to arbitrary data.
+     * \param entity_set_handle Entity set on which tag is being set
+     * \param tag_handle Tag being set on an entity set
+     * \param tag_value Pointer to tag data being set on entity set
+     * \param tag_value_size Size in bytes of tag data
+  void iGeom_setEntSetData(iGeom_Instance instance,
+                           const char* tag_value,
+                           int tag_value_size,
+                           int *err);
+    /**\brief  Set a tag value of integer type on an entity set
+     * Set a tag value of integer type on an entity set.
+     * \param entity_set Entity set on which tag is being set
+     * \param tag_value Tag value being set on entity set
+  void iGeom_setEntSetIntData(iGeom_Instance instance,
+                              int tag_value,
+                              int *err);
+    /**\brief  Set a tag value of double type on an entity set
+     * Set a tag value of double type on an entity set.
+  void iGeom_setEntSetDblData(iGeom_Instance instance,
+                              double tag_value,
+                              int *err);
+    /**\brief  Set a tag value of entity handle type on an entity set
+     * Set a tag value of entity handle type on an entity set.
+  void iGeom_setEntSetEHData(iGeom_Instance instance,
+                             iBase_EntityHandle tag_value,
+                             int *err);
+    /**\brief  Get the value of a tag of arbitrary type on an entity set
+     * Get the value of a tag of arbitrary type on an entity set.  Tag data
+     * is passed back as char* type, but really represents arbitrary data.
+     * \param *tag_value Pointer to tag data array being queried
+     * \param *tag_value_allocated Pointer to tag data array allocated size
+     * \param *tag_value_size Pointer to tag data array occupied size
+  void iGeom_getEntSetData(iGeom_Instance instance,
+                           char** tag_value,
+                           int* tag_value_allocated,
+                           int* tag_value_size,
+                           int *err);
+    /**\brief  Get the value of a tag of integer type on an entity set
+     * Get the value of a tag of integer type on an entity set.
+     * \param *out_data Pointer to tag value returned from function
+  void iGeom_getEntSetIntData(iGeom_Instance instance,
+                              int *out_data,
+                              int *err);
+    /**\brief  Get the value of a tag of double type on an entity set
+     * Get the value of a tag of double type on an entity set.
+  void iGeom_getEntSetDblData(iGeom_Instance instance,
+                              double *out_data,
+                              int *err);
+    /**\brief  Get the value of a tag of entity handle type on an entity set
+     * Get the value of a tag of entity handle type on an entity set.
+  void iGeom_getEntSetEHData(iGeom_Instance instance,
+                             iBase_EntityHandle *out_data,
+                             int *err);
+    /**\brief  Get all the tags associated with a specified entity set
+     * Get all the tags associated with a specified entity set
+     * \param entity_set_handle Entity being queried
+     * \param *tag_handles Pointer to array of tag_handles returned from
+     *        function
+     * \param *tag_handles_allocated Pointer to allocated size of tag_handles
+     *        array
+     * \param *tag_handles_size Pointer to occupied size of tag_handles array
+  void iGeom_getAllEntSetTags(iGeom_Instance instance,
+                              iBase_TagHandle** tag_handles,
+                              int* tag_handles_allocated,
+                              int* tag_handles_size,
+                              int *err);
+    /**\brief  Remove a tag value from an entity set
+     * Remove a tag value from an entity set
+     * \param entity_set_handle Entity set from which tag is being removed
+     * \param tag_handle Tag handle of tag being removed
+  void iGeom_rmvEntSetTag(iGeom_Instance instance,
+                          int *err);
+    /**\brief  Get tag values of arbitrary type for an array of entities
+     * Get tag values of arbitrary type for an array of entities.  Tag data
+     * is returned as char* type, but really represents arbitrary data.
+     * \param entity_handles Entity array on which tag is being set
+     * \param entity_handles_size Number of entities in array
+     * \param *tag_values Pointer to tag data array being returned from
+     *        function
+     * \param tag_values_allocated Pointer to allocated size of tag data array
+     * \param tag_values_size Pointer to occupied size of tag data array
+  void iGeom_getArrData(iGeom_Instance instance,
+                        int entity_handles_size,
+                        char** tag_values,
+                        int* tag_values_allocated,
+                        int* tag_values_size,
+                        int *err);
+    /**\brief  Get tag values of integer type for an array of entities
+     * Get tag values of integer type for an array of entities.
+     *        function
+  void iGeom_getIntArrData(iGeom_Instance instance,
+                           int** tag_values,
+                           int *err);
+    /**\brief  Get tag values of double type for an array of entities
+     * Get tag values of double type for an array of entities.
+     *        function
+  void iGeom_getDblArrData(iGeom_Instance instance,
+                           double** tag_values,
+                           int *err);
+    /**\brief  Get tag values of entity handle type for an array of entities
+     * Get tag values of entity handle type for an array of entities.
+     * \param *tag_value Pointer to tag data array being returned from
+     *        function
+     * \param tag_value_allocated Pointer to allocated size of tag data array
+     * \param tag_value_size Pointer to occupied size of tag data array
+  void iGeom_getEHArrData(iGeom_Instance instance,
+                          iBase_EntityHandle** tag_value,
+                          int *err);
+    /**\brief  Set tag values of arbitrary type on an array of entities
+     * Set tag values of arbitrary type on an array of entities.  Tag data is
+     * passed as char* type, but really represents pointer to arbitrary data.
+     * \param tag_values Pointer to tag data being set on entity
+     * \param tag_values_size Size in total bytes of tag data
+  void iGeom_setArrData(iGeom_Instance instance,
+                        const char* tag_values,
+                        int tag_values_size,
+                        int *err);
+    /**\brief  Set tag values of integer type on an array of entities
+     * Set tag values of integer type on an array of entities.
+     * \param tag_values Pointer to tag data being set on entities
+     * \param tag_values_size Size in total number of integers of tag data
+  void iGeom_setIntArrData(iGeom_Instance instance,
+                           const int* tag_values,
+                           int *err);
+    /**\brief  Set tag values of double type on an array of entities
+     * Set tag values of double type on an array of entities.
+     * \param tag_values_size Size in total number of doubles of tag data
+  void iGeom_setDblArrData(iGeom_Instance instance,
+                           const double* tag_values,
+                           const int tag_values_size,
+                           int *err);
+    /**\brief  Set tag values of entity handle type on an array of entities
+     * Set tag values of entity handle type on an array of entities.
+     * \param tag_values_size Size in total number of entity handles of tag
+     *        data
+  void iGeom_setEHArrData(iGeom_Instance instance,
+                          const iBase_EntityHandle* tag_values,
+                          int *err);
+    /**\brief  Remove a tag value from an array of entities
+     * Remove a tag value from an array of entities
+     * \param entity_handles Entity from which tag is being removed
+  void iGeom_rmvArrTag(iGeom_Instance instance,
+                       int *err);
+     * Get the value of a tag of arbitrary type on an entity.  Tag data
+     * \param entity_handle Entity on which tag is being set
+  void iGeom_getData(iGeom_Instance instance,
+                     iBase_EntityHandle entity_handle,
+                     char** tag_value,
+                     int *tag_value_allocated,
+                     int *tag_value_size,
+                     int *err);
+     * Get the value of a tag of integer type on an entity.
+  void iGeom_getIntData(iGeom_Instance instance,
+                        int *out_data,
+                        int *err);
+     * Get the value of a tag of double type on an entity.
+  void iGeom_getDblData(iGeom_Instance instance,
+                        /*in*/ const iBase_EntityHandle entity_handle,
+                        /*in*/ const iBase_TagHandle tag_handle,
+                        double *out_data, int *err);
+     * Get the value of a tag of entity handle type on an entity.
+  void iGeom_getEHData(iGeom_Instance instance,
+                       int *err);
+     * Set a tag value of arbitrary type on an entity.  Tag data is
+  void iGeom_setData(iGeom_Instance instance,
+                     int *err);
+     * Set a tag value of integer type on an entity.
+  void iGeom_setIntData(iGeom_Instance instance,
+                        int tag_value,
+                        int *err);
+     * Set a tag value of double type on an entity.
+  void iGeom_setDblData(iGeom_Instance instance,
+                        double tag_value,
+                        int *err);
+     * Set a tag value of entity handle type on an entity.
+  void iGeom_setEHData(iGeom_Instance instance,
+                       int *err);
+    /**\brief  Get all the tags associated with a specified entity handle
+     * Get all the tags associated with a specified entity handle
+     * \param entity_handle Entity being queried
+     *        function
+     *        array
+  void iGeom_getAllTags(iGeom_Instance instance,
+                        int *err);
+     * \param entity_handle Entity from which tag is being removed
+  void iGeom_rmvTag(iGeom_Instance instance,
+                    int *err);
+    /**\brief  Subtract contents of one entity set from another
+     * Subtract contents of one entity set from another
+     * \param entity_set_1 Entity set from which other set is being subtracted
+     * \param entity_set_2 Entity set being subtracted from other set
+     * \param result_entity_set Pointer to entity set returned from function
+  void iGeom_subtract(iGeom_Instance instance,
+                      iBase_EntitySetHandle entity_set_1,
+                      iBase_EntitySetHandle entity_set_2,
+                      iBase_EntitySetHandle* result_entity_set,
+                      int *err);
+    /**\brief  Intersect contents of one entity set with another
+     * Intersect contents of one entity set with another
+     * \param entity_set_1 Entity set being intersected with another
+     * \param entity_set_2 Entity set being intersected with another
+  void iGeom_intersect(iGeom_Instance instance,
+                       int *err);
+    /**\brief  Unite contents of one entity set with another
+     * Unite contents of one entity set with another
+     * \param entity_set_1 Entity set being united with another
+     * \param entity_set_2 Entity set being united with another
+  void iGeom_unite(iGeom_Instance instance,
+                   int *err);
+#ifdef __cplusplus
+} // extern "C"
+#endif
+#endif
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am	2009-03-20 22:09:31 UTC (rev 2740)
+++ cgm/trunk/test/Makefile.am	2009-03-23 14:44:48 UTC (rev 2741)
@@ -106,6 +106,7 @@
 	ex3.occ \
 	ex3export.iges \
         prism.occ \
-        pyramid.occ
+        pyramid.occ \
+        fillet.occ
More information about the cgma-dev
