[cgma-dev] r2729 - cgm/trunk/geom/OCC
    jiangtao_ma at yahoo.com
    Thu Mar 19 14:38:56 CDT 2009
Author: janehu
Date: 2009-03-19 14:38:56 -0500 (Thu, 19 Mar 2009)
New Revision: 2729
Modified:
   cgm/trunk/geom/OCC/OCCLoop.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Passed test for fillet/chamfer on edges.
Modified: cgm/trunk/geom/OCC/OCCLoop.cpp
--- cgm/trunk/geom/OCC/OCCLoop.cpp	2009-03-19 19:37:37 UTC (rev 2728)
+++ cgm/trunk/geom/OCC/OCCLoop.cpp	2009-03-19 19:38:56 UTC (rev 2729)
@@ -177,7 +177,7 @@
            TopoDS_Face Face = TopoDS::Face(it.Value());
            int k = oqe->OCCMap->Find(Face);
-           parents.append((OCCSurface*)(oqe->OccToCGM->find(k))->second);
+           parents.append_unique((OCCSurface*)(oqe->OccToCGM->find(k))->second);
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-03-19 19:37:37 UTC (rev 2728)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-03-19 19:38:56 UTC (rev 2729)
@@ -5975,6 +5975,8 @@
       new_bodysm_list.append_unique(new_bodysm_ptr);
       count = new_bodysm_list.size();
+    else
+      break;
   if(count == 0)
@@ -6058,6 +6060,8 @@
+    else
+      break;
   if(count == 0)
@@ -6125,18 +6129,41 @@
                                            CubitBoolean preview,
                                            CubitBoolean if_fillet ) const
+  //check if this id is valid
+  OCCQueryEngine* oqe = OCCQueryEngine::instance();
+  DLIList <OCCBody* > *bodies = oqe->BodyList;
+  DLIList<OCCCurve*> curves;
+  for(int j = 0; j <  bodies->size(); j++)
+    OCCBody* body = bodies->get_and_step();
+    body->get_all_curves(curves);
+  bool curve_alive = false;
+  for(int j = 0; j <  curves.size(); j++)
+    if(curve_ptr == curves.get_and_step())
+      curve_alive = true;
+      break;
+  if(!curve_alive)
+    PRINT_ERROR("This curve is not valid in the current model.\n");
+    return CUBIT_FAILURE;
   OCCCurve *occ_curve = CAST_TO(curve_ptr, OCCCurve);
   TopoDS_Edge* topo_edge = occ_curve->get_TopoDS_Edge();
-  OCCQueryEngine* oqe = OCCQueryEngine::instance();
-  DLIList <OCCBody* > *bodies = oqe->BodyList;
   TopTools_IndexedDataMapOfShapeListOfShape M;
   DLIList<TopoDS_CompSolid*> shape_list;
-  OCCBody * body = NULL;
   TopoDS_Face* s;
-    body = bodies->get_and_step();
     TopExp_Explorer Ex;
     TopoDS_Shape ashape = *(body->get_TopoDS_Shape());
     M.Clear();
More information about the cgma-dev
