[cgma-dev] CGMA check for *64-acis* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Fri Mar 13 02:11:19 CDT 2009
Making check in compat
make[1]: Entering directory `/home/jason/cgm/test/64-acis/compat'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/compat'
Making check in util
make[1]: Entering directory `/home/jason/cgm/test/64-acis/util'
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/util'
Making check in geom
make[1]: Entering directory `/home/jason/cgm/test/64-acis/geom'
Making check in .
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom'
make[2]: Nothing to be done for `check-am'.
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom'
Making check in Cholla
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/Cholla'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/Cholla'
Making check in facetbool
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/facetbool'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/facetbool'
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/facet'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/facet'
Making check in virtual
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/virtual'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/virtual'
Making check in ACIS
make[2]: Entering directory `/home/jason/cgm/test/64-acis/geom/ACIS'
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/geom/ACIS'
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/geom'
Making check in init
make[1]: Entering directory `/home/jason/cgm/test/64-acis/init'
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/init'
Making check in .
make[1]: Entering directory `/home/jason/cgm/test/64-acis'
make[1]: Leaving directory `/home/jason/cgm/test/64-acis'
Making check in itaps
make[1]: Entering directory `/home/jason/cgm/test/64-acis/itaps'
make  check-recursive
make[2]: Entering directory `/home/jason/cgm/test/64-acis/itaps'
Making check in .
make[3]: Entering directory `/home/jason/cgm/test/64-acis/itaps'
make  testgeom
make[4]: Entering directory `/home/jason/cgm/test/64-acis/itaps'
c++ -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -I. -I../../trunk/itaps -I.. -I../../trunk/util -I../../trunk/geom -I../../trunk/init -I. -isystem /opt/acis16.7/include -DSRCDIR=../../trunk/itaps -isystem /opt/acis16.7/include  -Wall -pipe -pedantic -g -MT testgeom-testgeom.o -MD -MP -MF .deps/testgeom-testgeom.Tpo -c -o testgeom-testgeom.o `test -f 'testgeom.cc' || echo '../../trunk/itaps/'`testgeom.cc
../../trunk/itaps/testgeom.cc: In function âbool construct_test(iGeom_Instance_Private*)â:
../../trunk/itaps/testgeom.cc:952: error: invalid conversion from âint*â to âintâ
../../trunk/itaps/testgeom.cc: In function âbool primitives_test(iGeom_Instance_Private*)â:
../../trunk/itaps/testgeom.cc:1023: error: invalid conversion from âint*â to âintâ
make[4]: *** [testgeom-testgeom.o] Error 1
make[4]: Leaving directory `/home/jason/cgm/test/64-acis/itaps'
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/home/jason/cgm/test/64-acis/itaps'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/64-acis/itaps'
make[1]: *** [check] Error 2
make[1]: Leaving directory `/home/jason/cgm/test/64-acis/itaps'
make: *** [check-recursive] Error 1
More information about the cgma-dev
