[cgma-dev] r2706 - in cgm/trunk/itaps: . SIDL SIDL/gserver
    kraftche at cae.wisc.edu
    Thu Mar 12 16:25:27 CDT 2009
Author: kraftche
Date: 2009-03-12 16:25:26 -0500 (Thu, 12 Mar 2009)
New Revision: 2706
Modified:
   cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc
   cgm/trunk/itaps/SIDL/iBase.sidl
   cgm/trunk/itaps/SIDL/iGeom.sidl
   cgm/trunk/itaps/iBase.h
   cgm/trunk/itaps/iGeom.h
   cgm/trunk/itaps/iGeom_CGMA.cc
Log:
iGeom changes
Modified: cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc
--- cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc	2009-03-12 17:54:50 UTC (rev 2705)
+++ cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc	2009-03-12 21:25:26 UTC (rev 2706)
@@ -2348,7 +2348,7 @@
 iGeom_SIDL::GeomSidl_impl::getArrBoundBox (
   /* in */ ::sidl::array<void*> gentity_handles,
   /* in */ int32_t gentity_handles_size,
-  /* inout */ ::iBase::StorageOrder& storage_order,
+  /* in */ ::iBase::StorageOrder storage_order,
   /* inout */ ::sidl::array<double>& min_corner,
   /* inout */ int32_t& min_corner_size,
   /* inout */ ::sidl::array<double>& max_corner,
@@ -2361,10 +2361,9 @@
   CREATE_TEMP_ARRAY(double, max_corner);
   CREATE_TEMP_ARRAY(double, min_corner);
-  int order = storage_order;
   iGeom_getArrBoundBox (igeomInstance,
                             TEMP_TYPED_ARRAY_IN(iBase_EntityHandle,gentity_handles),
-                            &order,
+                            storage_order,
                             TEMP_ARRAY_INOUT(min_corner),
                             TEMP_ARRAY_INOUT(max_corner),
                             &igeomError);
@@ -2372,7 +2371,6 @@
   ASSIGN_TYPED_ARRAY(double, min_corner);
   ASSIGN_TYPED_ARRAY(double, max_corner);
-  storage_order = (::iBase::StorageOrder)order;
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getArrBoundBox)
@@ -2406,7 +2404,7 @@
 iGeom_SIDL::GeomSidl_impl::getVtxArrCoords (
   /* inout */ ::sidl::array<double>& coordinates,
   /* inout */ int32_t& coordinates_size )
 throw (
@@ -2416,16 +2414,14 @@
   // Insert-Code-Here {iGeom_SIDL.GeomSidl.getVtxArrCoords} (getVtxArrCoords method)
   CREATE_TEMP_ARRAY(double, coordinates);
   iGeom_getVtxArrCoords (igeomInstance,
-                               &order,
+                               storage_order,
                                TEMP_ARRAY_INOUT(coordinates),
                                &igeomError);
   PROCESS_ERROR;
   ASSIGN_TYPED_ARRAY(double, coordinates);
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getVtxArrCoords)
@@ -2442,7 +2438,7 @@
   /* in */ double dir_z,
   /* inout */ ::sidl::array<void*>& intersect_entity_handles,
   /* inout */ int32_t& intersect_entity_handles_size,
+  /* inout */ ::iBase::StorageOrder storage_order,
   /* inout */ ::sidl::array<double>& intersect_coords,
   /* inout */ int32_t& intersect_coords_size,
   /* inout */ ::sidl::array<double>& param_coords,
@@ -2456,16 +2452,14 @@
   CREATE_TEMP_ARRAY(double, intersect_coords);
   CREATE_TEMP_ARRAY(double, param_coords);
-  int storage_order_tmp;
   iGeom_getPntRayIntsct (igeomInstance, x, y, z, dir_x, dir_y, dir_z,
                       TEMP_ARRAY_INOUT( intersect_entity_handles ),
-                      &storage_order_tmp,
+                      storage_order,
                       TEMP_ARRAY_INOUT( intersect_coords ),
                       TEMP_ARRAY_INOUT( param_coords ),
                       &igeomError );
   PROCESS_ERROR;
-  storage_order = static_cast< ::iBase::StorageOrder >(storage_order_tmp);
   ASSIGN_TYPED_ARRAY(void*, intersect_entity_handles);
   ASSIGN_TYPED_ARRAY(double, intersect_coords);
   ASSIGN_TYPED_ARRAY(double, param_coords);
@@ -2499,7 +2493,6 @@
   CREATE_TEMP_ARRAY(int32_t, offset);
   iGeom_getPntArrRayIntsct (igeomInstance,
                       storage_order,
                       TEMP_ARRAY_IN( coords ),
@@ -2515,7 +2508,6 @@
   ASSIGN_TYPED_ARRAY(int32_t, offset);
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getPntArrRayIntsct)
@@ -2891,7 +2883,7 @@
   /* in */ int32_t entity_handles_size,
   /* in */ ::sidl::array<double> u,
   /* in */ int32_t u_size,
   /* inout */ ::sidl::array<double>& on_coords,
   /* inout */ int32_t& on_coords_size )
 throw (
@@ -2900,15 +2892,13 @@
   // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl.getArrUtoXYZ)
   // Insert-Code-Here {iGeom_SIDL.GeomSidl.getArrUtoXYZ} (getArrUtoXYZ method)
   CREATE_TEMP_ARRAY(double, on_coords);
   iGeom_getArrUtoXYZ (igeomInstance,
                         TEMP_TYPED_ARRAY_IN(iBase_EntityHandle,entity_handles),
                         TEMP_TYPED_ARRAY_IN(double,u),
-                        &order,
+                        storage_order,
                         TEMP_ARRAY_INOUT(on_coords),
                         &igeomError);
   PROCESS_ERROR;
   ASSIGN_TYPED_ARRAY(double, on_coords);
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getArrUtoXYZ)
@@ -2979,7 +2969,6 @@
   // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl.getArrXYZtoUV)
   // Insert-Code-Here {iGeom_SIDL.GeomSidl.getArrXYZtoUV} (getArrXYZtoUV method)
   CREATE_TEMP_ARRAY(double, uv);
   iGeom_getArrXYZtoUV (igeomInstance,
                         storage_order,
@@ -2988,7 +2977,6 @@
                         &igeomError);
   PROCESS_ERROR;
   ASSIGN_TYPED_ARRAY(double, uv);
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getArrXYZtoUV)
@@ -3011,7 +2999,6 @@
   // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl.getArrXYZtoU)
   // Insert-Code-Here {iGeom_SIDL.GeomSidl.getArrXYZtoU} (getArrXYZtoU method)
   CREATE_TEMP_ARRAY(double, u);
   iGeom_getArrXYZtoU (igeomInstance,
                         storage_order,
@@ -3020,7 +3007,6 @@
                         &igeomError);
   PROCESS_ERROR;
   ASSIGN_TYPED_ARRAY(double, u);
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getArrXYZtoU)
@@ -3065,7 +3051,6 @@
   // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl.getArrXYZtoUVHint)
   // Insert-Code-Here {iGeom_SIDL.GeomSidl.getArrXYZtoUVHint} (getArrXYZtoUVHint method)
   iGeom_getArrXYZtoUVHint (igeomInstance,
                         storage_order,
@@ -3073,8 +3058,6 @@
                         TEMP_ARRAY_INOUT(uv),
                         &igeomError);
   PROCESS_ERROR;
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getArrXYZtoUVHint)
@@ -3134,7 +3117,7 @@
 iGeom_SIDL::GeomSidl_impl::getArrUVRange (
   /* inout */ ::sidl::array<double>& uv_min,
   /* inout */ int32_t& uv_min_size,
   /* inout */ ::sidl::array<double>& uv_max,
@@ -3146,16 +3129,13 @@
   // Insert-Code-Here {iGeom_SIDL.GeomSidl.getArrUVRange} (getArrUVRange method)
   CREATE_TEMP_ARRAY(double, uv_max);
   CREATE_TEMP_ARRAY(double, uv_min);
   iGeom_getArrUVRange (igeomInstance,
-                        &order,
+                        storage_order,
                         TEMP_ARRAY_INOUT(uv_min),
                         TEMP_ARRAY_INOUT(uv_max),
                         &igeomError);
   PROCESS_ERROR;
   ASSIGN_TYPED_ARRAY(double, uv_max);
   ASSIGN_TYPED_ARRAY(double, uv_min);
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getArrUVRange)
@@ -3272,7 +3252,7 @@
   /* in */ int32_t face_handles_size,
   /* in */ ::sidl::array<double> u_in,
   /* in */ int32_t u_in_size,
   /* inout */ ::sidl::array<double>& uv,
   /* inout */ int32_t& uv_size )
 throw (
@@ -3281,16 +3261,14 @@
   // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl.getArrUtoUV)
   // Insert-Code-Here {iGeom_SIDL.GeomSidl.getArrUtoUV} (getArrUtoUV method)
   iGeom_getArrUtoUV (igeomInstance,
                      TEMP_TYPED_ARRAY_IN(iBase_EntityHandle,edge_handles),
                      TEMP_TYPED_ARRAY_IN(iBase_EntityHandle,face_handles),
                      TEMP_ARRAY_IN(u_in),
+                     storage_order,
                      &igeomError);
   PROCESS_ERROR;
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getArrUtoUV)
@@ -3304,7 +3282,7 @@
   /* in */ int32_t vertex_handles_size,
   /* in */ ::sidl::array<void*> face_handles,
 throw (
@@ -3313,15 +3291,13 @@
   // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl.getVtxArrToUV)
   // Insert-Code-Here {iGeom_SIDL.GeomSidl.getVtxArrToUV} (getVtxArrToUV method)
   iGeom_getVtxArrToUV (igeomInstance,
                        TEMP_TYPED_ARRAY_IN(iBase_EntityHandle,vertex_handles),
+                       storage_order,
                        &igeomError);
   PROCESS_ERROR;
   // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.getVtxArrToUV)
Modified: cgm/trunk/itaps/SIDL/iBase.sidl
--- cgm/trunk/itaps/SIDL/iBase.sidl	2009-03-12 17:54:50 UTC (rev 2705)
+++ cgm/trunk/itaps/SIDL/iBase.sidl	2009-03-12 21:25:26 UTC (rev 2706)
@@ -28,8 +28,7 @@
    enum StorageOrder {
       BLOCKED,
-      INTERLEAVED,
-      UNDETERMINED
+      INTERLEAVED
    enum CreationStatus {
Modified: cgm/trunk/itaps/SIDL/iGeom.sidl
--- cgm/trunk/itaps/SIDL/iGeom.sidl	2009-03-12 17:54:50 UTC (rev 2705)
+++ cgm/trunk/itaps/SIDL/iGeom.sidl	2009-03-12 21:25:26 UTC (rev 2706)
@@ -382,7 +382,7 @@
     void getArrBoundBox(in array<opaque> gentity_handles,
                         in int gentity_handles_size,
-                        inout iBase.StorageOrder storage_order,
+                        in iBase.StorageOrder storage_order,
                         inout array <double> min_corner,
                         out int min_corner_size,
                         inout array <double> max_corner,
@@ -403,7 +403,7 @@
     void getVtxArrCoords(in array<opaque> gentity_handles,
                          inout array <double> coordinates,
                          out int coordinates_size)
       throws iBase.Error;
@@ -413,7 +413,7 @@
                        in double dir_x, in double dir_y, in double dir_z,
                        inout array<opaque> intersect_entity_handles,
                        out int intersect_entity_handles_size,
                        inout array<double> intersect_coords,
                        out int intersect_coords_size,
                        inout array<double> param_coords,
@@ -593,7 +593,7 @@
                        in int entity_handles_size,
                        in array<double> u,
                        in int u_size,
                        inout array<double> on_coords,
                        out int on_coords_size
                      ) throws iBase.Error;
@@ -669,7 +669,7 @@
     void getArrUVRange(in array<opaque> gentity_handles,
                         inout array <double> uv_min,
                         out int uv_min_size,
                         inout array <double> uv_max,
@@ -702,7 +702,7 @@
                       in array<opaque> face_handles,
                       in int face_handles_size,
                       in array<double> u_in, in int u_in_size,
                       inout array<double> uv, out int uv_size
@@ -711,7 +711,7 @@
                         in int vertex_handles_size,
Modified: cgm/trunk/itaps/iBase.h
--- cgm/trunk/itaps/iBase.h	2009-03-12 17:54:50 UTC (rev 2705)
+++ cgm/trunk/itaps/iBase.h	2009-03-12 21:25:26 UTC (rev 2706)
@@ -114,8 +114,7 @@
   enum iBase_StorageOrder {
     iBase_BLOCKED,
-    iBase_INTERLEAVED,
-    iBase_UNDETERMINED
+    iBase_INTERLEAVED
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h	2009-03-12 17:54:50 UTC (rev 2705)
+++ cgm/trunk/itaps/iGeom.h	2009-03-12 21:25:26 UTC (rev 2706)
@@ -906,7 +906,7 @@
   void iGeom_getArrBoundBox( iGeom_Instance,
                              iBase_EntityHandle const* entity_handles,
-                             int* storage_order,
+                             int storage_order,
                              double** min_corner,
                              int* min_corner_allocated,
                              int* min_corner_size,
@@ -943,8 +943,7 @@
      * \param vertex_handles Array of geom vertex handles whose coordinates are
      *        being requested
      * \param vertex_handles_size Number of vertices in vertex_handles array
-     * \param storage_order Pointer to storage order requested/returned from
-     *        function
+     * \param storage_order Storage order requested for coordinate data
      * \param *coords Pointer to array of coordinates returned from function
      * \param *coords_allocated Pointer to allocated size of coords array
      * \param *coords_size Pointer to occupied size of coords array
@@ -953,7 +952,7 @@
   void iGeom_getVtxArrCoords( iGeom_Instance,
                               double** coordinates,
                               int* coordinates_allocated,
                               int* coordinates_size,
@@ -990,7 +989,7 @@
                               iBase_EntityHandle** intersect_entity_handles,
                               int* intersect_entity_handles_allocated,
                               int* intersect_entity_hangles_size,
                               double** intersect_coords,
                               int* intersect_coords_allocated,
                               int* intersect_coords_size,
@@ -1279,7 +1278,7 @@
  * with respect to implementation.
  * \param entity_handles Entities being queried
  * \param entity_handles_size Number of entities being queried
- * \param storage_order Storage order of uv coordinates input
+ * \param storage_order Storage order of uv coordinates input and xyz coordinate output
  * \param uv Coordinates being queried
  * \param uv_size Number of coordinates in array
  * \param coordinates Coordinates of parametric positions
@@ -1322,7 +1321,7 @@
+ * \param storage_order Storage order of resulting coordinates
@@ -1334,7 +1333,7 @@
                            double const* u,
                            int u_size,
                            double** on_coords,
                            int* on_coords_allocated,
                            int* on_coords_size,
@@ -1518,7 +1517,7 @@
   void iGeom_getArrUVRange( iGeom_Instance,
                             double** uv_min,
                             int* uv_min_allocated,
                             int* uv_min_size,
@@ -1612,7 +1611,7 @@
                           double const* u_in,
                           int u_in_size,
                           double** uv,
                           int* uv_allocated,
                           int* uv_size,
@@ -1634,7 +1633,7 @@
                             iBase_EntityHandle const* face_handles,
                             double** uv,
                             int* uv_allocated,
                             int* uv_size,
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc	2009-03-12 17:54:50 UTC (rev 2705)
+++ cgm/trunk/itaps/iGeom_CGMA.cc	2009-03-12 21:25:26 UTC (rev 2706)
@@ -2819,7 +2819,7 @@
 iGeom_getArrBoundBox (iGeom_Instance instance,
                       /*in*/ const iBase_EntityHandle *gentity_handles,
-                      /*inout*/ int* storage_order,
+                      /*in*/ int storage_order,
                       /*out*/ double **min_corner,
                       int *min_corner_allocated,
                       int *min_corner_size,
@@ -2833,12 +2833,11 @@
   CHECK_SIZE(*max_corner, double, 3*gentity_handles_size);
   size_t step, init;
-  if (*storage_order == iBase_BLOCKED) {
+  if (storage_order == iBase_BLOCKED) {
     step = 1;
     init = gentity_handles_size;
   else {
-    *storage_order = iBase_INTERLEAVED;
     step = 3;
     init = 1;
@@ -2899,7 +2898,7 @@
 iGeom_getVtxArrCoords (iGeom_Instance instance,
                        /*out*/ double **coordinates,
                        int *coordinates_allocated,
                        int *coordinates_size,
@@ -2915,14 +2914,13 @@
   double *x, *y, *z;
   size_t step;
     x = *coordinates;
     y = x + gentity_handles_size;
     z = y + gentity_handles_size;
     step = 1;
   else {
     x = *coordinates;
     y = x + 1;
     z = x + 2;
@@ -2961,7 +2959,7 @@
                        /*inout*/ iBase_EntityHandle **intersect_entity_handles,
                        int *intersect_entity_handles_allocated,
                        int *intersect_entity_handles_size,
                        /*inout*/ double **intersect_coords,
                        int *intersect_coords_allocated,
                        int *intersect_coords_size,
@@ -2982,12 +2980,11 @@
   CHECK_SIZE( *param_coords, double, ray_params.size() );
   size_t init, step;
     init = ray_params.size();
     step = 1;
   else {
     init = 1;
     step = 3;
@@ -3965,7 +3962,7 @@
                     /*in*/ const double *u,
                     int u_size,
@@ -3997,13 +3994,12 @@
   double *x, *y, *z;
   u_iter = u;
   x = *coordinates;
     y = x + count;
     z = y + count;
     coord_step = 1;
   else {
     y = x + 1;
     z = x + 2;
     coord_step = 3;
@@ -4380,7 +4376,7 @@
 iGeom_getArrUVRange (iGeom_Instance instance,
                      /*in*/ iBase_EntityHandle const *gentity_handles,
-                     /*in*/ int* storage_order,
                      /*out*/ double **uv_min,
                      int *uv_min_allocated,
                      int *uv_min_size,
@@ -4393,12 +4389,11 @@
   CHECK_SIZE(*uv_max, double, 2*gentity_handles_size);
   size_t init, step;
     step = 1;
   else {
     init = 1;
     step = 2;
@@ -4481,7 +4476,7 @@
                    /*in*/ const double *in_u,
                    int in_u_size,
-                   /*inout*/ int *storage_order,
                    /*inout*/ double **uv,
                    int *uv_allocated,
                    int *uv_size,
@@ -4507,7 +4502,7 @@
                      /*in*/ iBase_EntityHandle const *face_handles,
                      int *uv_allocated,
                      int *uv_size,
@@ -4726,7 +4721,7 @@
                    int* err)
   iGeom_getArrUtoXYZ(instance, ARRAY_IN(gedge_handles),
-                     ARRAY_IN(parameters), &storage_order,
+                     ARRAY_IN(parameters), storage_order,
                      ARRAY_INOUT(tangents), err);
   if (iBase_SUCCESS == *err)
     iGeom_getArrNrmlXYZ(instance, ARRAY_IN(gedge_handles), storage_order,
More information about the cgma-dev
