[cgma-dev] r2668 - cgm/trunk/geom/OCC
jiangtao_ma at yahoo.com
Fri Feb 27 11:30:52 CST 2009
Author: janehu
Date: 2009-02-27 11:30:52 -0600 (Fri, 27 Feb 2009)
New Revision: 2668
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Updated to pass test.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-02-27 17:27:46 UTC (rev 2667)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-02-27 17:30:52 UTC (rev 2668)
@@ -1324,7 +1324,6 @@
BodySM* OCCModifyEngine::prism( double height, int sides, double major,
double minor) const
- //currently OCC only support 4 sided prism
if(major <= 0. || minor <= 0. || (major - minor) <= -TOL)
PRINT_ERROR("Major and minor radii must be greater than zero.\n");
@@ -1334,55 +1333,42 @@
if (sides == 4)
return brick(2 * major, 2 * minor, height);
+ //One of the polygon side will be perpendicular to positive x-axis.
+ double y = major * sin(CUBIT_PI/sides);
+ double x = sqrt(major * major - y * y);
+ gp_Pnt start(x, y, -height/2.0);
DLIList<gp_Pnt> point_list;
- double theta = 360.0/sides;
+ double theta = 2.0/sides*CUBIT_PI;
for(int n =1 ; n < sides; n++)
- double angle = theta * n;
- gp_Pnt v(-major * cos(angle), -major * sin(angle), -height/2.0);
+ double angle = theta * (n + 0.5);
+ gp_Pnt v(major * cos(angle), major * sin(angle), -height/2.0);
point_list.append(v);
TopoDS_Edge new_edge;
BRepBuilderAPI_MakePolygon poly_maker;
gp_Dir main_dir(0.0, 0.0, 1.0);
+ point_list.append(start);
if (fabs(major - minor) < TOL)
- Handle(Geom_Circle) curve_ptr;
- gp_Pnt center = gp_Pnt( 0.0, 0.0, -height/2.0);
- curve_ptr = GC_MakeCircle(center,main_dir, major);
- new_edge = BRepBuilderAPI_MakeEdge(curve_ptr);
- gp_Pnt v(0, -major, -height/2.0);
- point_list.append(v);
for (int i = 0; i <sides; i++)
poly_maker.Add(point_list[i]);
- poly_maker.Close();
- else
+ else
- gp_Pnt center(0.0, 0.0, -height/2.0);
- gp_Dir x_dir(0.0, 1.0, 0.0);
- gp_Ax2 Axis(center, main_dir, x_dir);
- Handle(Geom_Curve) curve_ptr = GC_MakeEllipse(Axis, major, minor);
- TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr);
- gp_Pnt v(0, -minor, -height/2.0);
- gp_Pln plane(center, main_dir);
- TopoDS_Face face = BRepBuilderAPI_MakeFace(plane);
- for(int i = 0; i < (sides-1); i++)
+ for (int i = 0; i <sides; i++)
- curve_ptr = GC_MakeSegment(center, point_list[i]);
- TopoDS_Edge edge = BRepBuilderAPI_MakeEdge(curve_ptr);
- TopOpeBRep_EdgesIntersector intersector;
- intersector.SetFaces(face,face);
- intersector.Perform(new_edge, edge);
- assert(intersector.NbPoints() == 1);
- TopOpeBRep_Point2d point2d = intersector.Point();
- gp_Pnt new_v = point2d.Value();
- poly_maker.Add(new_v);
+ x = point_list[i].X();
+ if((y=point_list[i].Y()) > 0.0)
+ y = sqrt((1-x*x/major/major)*minor*minor);
+ else
+ y = -sqrt((1-x*x/major/major)*minor*minor);
+ point_list[i].SetY(y);
+ poly_maker.Add(point_list[i]);
- poly_maker.Add(v);
+ poly_maker.Close();
TopoDS_Wire wire = poly_maker.Wire();
TopoDS_Face base = BRepBuilderAPI_MakeFace(wire, Standard_True);
More information about the cgma-dev
