[cgma-dev] r2657 - cgm/trunk/geom/OCC
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Feb 25 13:50:04 CST 2009
That was fast... thanks!
- tim
jiangtao_ma at yahoo.com wrote:
> Author: janehu
> Date: 2009-02-25 13:39:48 -0600 (Wed, 25 Feb 2009)
> New Revision: 2657
> Modified:
>    cgm/trunk/geom/OCC/OCCModifyEngine.cpp
> Log:
> Added prism for sides number not equal to 4, haven't tested it yet.
> Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
> --- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-02-24 18:00:34 UTC (rev 2656)
> +++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-02-25 19:39:48 UTC (rev 2657)
> @@ -30,10 +30,12 @@
>  #include "BRepBuilderAPI_TransitionMode.hxx"
>  #include "BRepBuilderAPI_MakeWire.hxx"
>  #include "BRepPrimAPI_MakeHalfSpace.hxx"
> +#include "BRepBuilderAPI_MakePolygon.hxx"
>  #include "BRepBndLib.hxx"
>  #include "IntersectionTool.hpp"
>  #include "TopoDS_Shape.hxx"
>  #include "TopAbs_Orientation.hxx"
> +#include "TopOpeBRep_Point2d.hxx"
>  #include "TColgp_Array1OfPnt.hxx"
>  #include "GC_MakeArcOfCircle.hxx"
>  #include "GC_MakeCircle.hxx"
> @@ -1323,13 +1325,76 @@
>                                 double minor) const
>    //currently OCC only support 4 sided prism
> -  if (sides != 4)
> +  if(major <= 0. || minor <= 0. || (major - minor) <=  -TOL)
> -    PRINT_ERROR("Option not supported for OCC based geometry.\n");
> -    return (BodySM*) NULL;
> +    PRINT_ERROR("Major and minor radii must be greater than zero.\n");
> +    return (BodySM*)NULL;
> -  return brick(2 * major, 2 * minor, height);
> +  if (sides == 4)
> +    return brick(2 * major, 2 * minor, height);
> +  DLIList<gp_Pnt> point_list;
> +  double theta = 360.0/sides;
> +  for(int n =1 ; n < sides; n++)
> +    double angle = theta * n;
> +    gp_Pnt v(-major * cos(angle), -major * sin(angle), -height/2.0);
> +    point_list.append(v);
> +  TopoDS_Edge new_edge;
> +  BRepBuilderAPI_MakePolygon poly_maker;
> +  gp_Dir main_dir(0.0, 0.0, 1.0);
> +  if (fabs(major - minor) < TOL)
> +    Handle(Geom_Circle) curve_ptr;
> +    gp_Pnt center = gp_Pnt( 0.0, 0.0, -height/2.0);
> +    curve_ptr = GC_MakeCircle(center,main_dir, major);
> +    new_edge = BRepBuilderAPI_MakeEdge(curve_ptr);
> +    gp_Pnt v(0, -major, -height/2.0);
> +    for (int i = 0; i <sides; i++)
> +      poly_maker.Add(point_list[i]);
> +    poly_maker.Close();
> +  else
> +    gp_Pnt center(0.0, 0.0, -height/2.0);
> +    gp_Dir x_dir(0.0, 1.0, 0.0);
> +    gp_Ax2 Axis(center, main_dir, x_dir);
> +    Handle(Geom_Curve) curve_ptr = GC_MakeEllipse(Axis, major, minor);
> +    TopoDS_Edge new_edge = BRepBuilderAPI_MakeEdge(curve_ptr);
> +    gp_Pnt v(0, -minor, -height/2.0);
> +    gp_Pln plane(center, main_dir);
> +    TopoDS_Face face = BRepBuilderAPI_MakeFace(plane);
> +    for(int i = 0; i < (sides-1); i++)
> +      curve_ptr = GC_MakeSegment(center, point_list[i]);
> +      TopoDS_Edge edge = BRepBuilderAPI_MakeEdge(curve_ptr);
> +      TopOpeBRep_EdgesIntersector intersector;
> +      intersector.SetFaces(face,face);
> +      intersector.Perform(new_edge, edge);
> +      assert(intersector.NbPoints() == 1);
> +      TopOpeBRep_Point2d point2d = intersector.Point();
> +      gp_Pnt new_v = point2d.Value();
> +      poly_maker.Add(new_v);
> +    poly_maker.Add(v);
> +  TopoDS_Wire wire = poly_maker.Wire();
> +  TopoDS_Face base = BRepBuilderAPI_MakeFace(wire, Standard_True);
> +  gp_Vec norm(main_dir);
> +  BRepSweep_Prism swept(base, norm);
> +  TopoDS_Shape new_shape = swept.Shape();
> +  DLIList<TopologyBridge*> tbs;
> +  tbs += OCCQueryEngine::instance()->populate_topology_bridge(new_shape);
> +  assert(tbs.size() == 1);
> +  BodySM* bodysm = CAST_TO(tbs.get(), BodySM);
> +  return bodysm;
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the cgma-dev
