[cgma-dev] r2617 - cgm/trunk/itaps
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Jan 30 19:26:13 CST 2009
Author: kraftche
Date: 2009-01-30 19:26:13 -0600 (Fri, 30 Jan 2009)
New Revision: 2617
Modified:
   cgm/trunk/itaps/CGMAIterator.hpp
   cgm/trunk/itaps/iGeom.h
   cgm/trunk/itaps/iGeom_CGMA.cc
   cgm/trunk/itaps/testgeom.cc
Log:
o Add has_data argument to iGeom_getNextEntArrIter for consistency with iMesh
o For modify methods that do not change the handle value, pass handle
  by copy rather than reference.
o Add iMesh_isEntArrContained for consistency with iMesh
Modified: cgm/trunk/itaps/CGMAIterator.hpp
--- cgm/trunk/itaps/CGMAIterator.hpp	2009-01-30 23:48:25 UTC (rev 2616)
+++ cgm/trunk/itaps/CGMAIterator.hpp	2009-01-31 01:26:13 UTC (rev 2617)
@@ -78,6 +78,9 @@
    *        nor the remaining number of entities.
   int size() const { return mSize; }
+  bool at_end() const
+    { return mIter == mArray.end(); }
 private:
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h	2009-01-30 23:48:25 UTC (rev 2616)
+++ cgm/trunk/itaps/iGeom.h	2009-01-31 01:26:13 UTC (rev 2617)
@@ -1999,6 +1999,7 @@
                                 iBase_EntityHandle** entity_handles,
                                 int* entity_handles_allocated,
                                 int* entity_handles_size,
+                                int* has_data,
                                 int* err );
     /**\brief  Reset the iterator
@@ -2125,7 +2126,7 @@
   void iGeom_moveEnt( iGeom_Instance,
-                      iBase_EntityHandle* geom_entity,
+                      iBase_EntityHandle geom_entity,
                       double x,
                       double y,
                       double z,
@@ -2135,7 +2136,7 @@
   void iGeom_rotateEnt( iGeom_Instance,
                         double angle,
                         double axis_normal_x,
                         double axis_normal_y,
@@ -2146,7 +2147,7 @@
   void iGeom_reflectEnt( iGeom_Instance,
                          double plane_normal_x,
                          double plane_normal_y,
                          double plane_normal_z,
@@ -2156,7 +2157,7 @@
   void iGeom_scaleEnt( iGeom_Instance,
                        double scale_x,
                        double scale_y,
                        double scale_z,
@@ -2192,7 +2193,7 @@
   void iGeom_sectionEnt( iGeom_Instance,
@@ -2411,6 +2412,25 @@
                             int *is_contained,
                             int *err);
+    /**\brief  Return whether entities are contained in a set
+     * Return whether each entity is contained in the set.
+     * \param instance iMesh instance handle
+     * \param containing_entity_set Entity set being queried
+     * \param entity_handles List of entities for which to check containment.
+     * \param is_contained One value for each input entity, 1 if contained
+     *          in set, zero otherwise.
+     * \param *err Pointer to error type returned from function
+  void iGeom_isEntArrContained( iGeom_Instance instance,
+                         /*in*/ iBase_EntitySetHandle containing_set,
+                         /*in*/ const iBase_EntityHandle* entity_handles,
+                         /*in*/ int num_entity_handles,
+                      /*inout*/ int** is_contained,
+                      /*inout*/ int* is_contained_allocated,
+                        /*out*/ int* is_contained_size,
+                        /*out*/ int* err );
     /**\brief  Return whether an entity set is contained in another set
      * Return whether a set is contained (*is_contained=1) or not contained
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc	2009-01-30 23:48:25 UTC (rev 2616)
+++ cgm/trunk/itaps/iGeom_CGMA.cc	2009-01-31 01:26:13 UTC (rev 2617)
@@ -235,8 +235,6 @@
 extern "C" {
-static bool cgm_initialized = false;
 void iGeom_getDescription( iGeom_Instance geom,
                            char* descr,
                            int* err,
@@ -525,12 +523,14 @@
                         /*inout*/ iBase_EntityHandle **entity_handles,
                         int *entity_handles_allocated,
                         int *entity_handles_size,
+                        int* has_data,
                         int* err
   CGMAIterator* iterator = reinterpret_cast<CGMAIterator*>(entArr_iterator);
   CHECK_SIZE(*entity_handles, iBase_EntityHandle, iterator->size());
   iterator->next( (RefEntity**)*entity_handles, *entity_handles_size );
+  *has_data = iterator->at_end();
@@ -3645,6 +3645,26 @@
   RETURN(iBase_SUCCESS);
+void iGeom_isEntArrContained( iGeom_Instance instance,
+    // go through each entity and look up its dimension
+  CHECK_SIZE(*is_contained, int, num_entity_handles);
+  *is_contained_size = num_entity_handles;
+  *err = iBase_SUCCESS;
+  for (int i = 0; i < num_entity_handles && iBase_SUCCESS == *err; ++i)
+    iGeom_isEntContained( instance, containing_set, entity_handles[i], (*is_contained)+i, err );
+  RETURN(*err);
 void
 iGeom_isEntSetContained (iGeom_Instance instance,
                          /*in*/ iBase_EntitySetHandle containing_entity_set,
@@ -5293,14 +5313,14 @@
 void
 iGeom_moveEnt (iGeom_Instance instance,
-               /*inout*/ iBase_EntityHandle *geom_entity,
+               /*inout*/ iBase_EntityHandle geom_entity,
                /*in*/ double x,
                /*in*/ double y,
                /*in*/ double z,
                int* err)
   CubitVector vec(x, y, z);
-  Body *this_bod = dynamic_cast<Body*>(ENTITY_HANDLE(*geom_entity));
+  Body *this_bod = dynamic_cast<Body*>(ENTITY_HANDLE(geom_entity));
   CubitStatus result;
   if (NULL != this_bod) {
     result = gqt->translate(this_bod, vec);
@@ -5312,7 +5332,7 @@
-  BasicTopologyEntity *this_bte = dynamic_cast<BasicTopologyEntity*>(ENTITY_HANDLE(*geom_entity));
+  BasicTopologyEntity *this_bte = dynamic_cast<BasicTopologyEntity*>(ENTITY_HANDLE(geom_entity));
   if (NULL != this_bte) {
       // non-body move; check to see if there are any siblings to this entity in the
       // same body; if so, we can't move it; if not, get the body and move that; if
@@ -5352,7 +5372,7 @@
 void
 iGeom_rotateEnt (iGeom_Instance instance,
                  /*in*/ double angle,
                  /*in*/ double axis_normal_x,
                  /*in*/ double axis_normal_y,
@@ -5360,7 +5380,7 @@
                  int* err)
   CubitVector this_axis(axis_normal_x, axis_normal_y, axis_normal_z);
   CubitStatus result;
     result = gqt->rotate(this_bod, this_axis, angle);
@@ -5371,7 +5391,7 @@
     result = gqt->rotate(this_bte, this_axis, angle);
     if (CUBIT_SUCCESS != result) {
@@ -5386,14 +5406,14 @@
 void
 iGeom_reflectEnt (iGeom_Instance instance,
                   /*in*/ double plane_normal_x,
                   /*in*/ double plane_normal_y,
                   /*in*/ double plane_normal_z,
                   int* err)
   CubitVector this_plane(plane_normal_x, plane_normal_y, plane_normal_z);
   DLIList<Body*> bods;
   bods.append(this_bod);
   CubitStatus result;
@@ -5406,7 +5426,7 @@
     result = gqt->reflect(this_bte, this_plane);
@@ -5421,14 +5441,14 @@
 void
 iGeom_scaleEnt (iGeom_Instance instance,
                 /*in*/ double scale_x,
                 /*in*/ double scale_y,
                 /*in*/ double scale_z,
                 int* err)
   CubitVector factor(scale_x, scale_y, scale_z);
   CubitStatus result;
     result = gqt->scale(this_bod, factor);
@@ -5439,7 +5459,7 @@
     // there is no body, it's a free entity and we can move it anyway
@@ -5595,7 +5615,7 @@
 void
 iGeom_sectionEnt (iGeom_Instance instance,
@@ -5604,9 +5624,9 @@
                   /*out*/ iBase_EntityHandle *geom_entity2,
                   int* err)
-  Body *this_body = dynamic_cast<Body*>(ENTITY_HANDLE(*geom_entity));
+  Body *this_body = dynamic_cast<Body*>(ENTITY_HANDLE(geom_entity));
   if (NULL == this_body) {
-    RefVolume *this_vol = dynamic_cast<RefVolume*>(ENTITY_HANDLE(*geom_entity));
+    RefVolume *this_vol = dynamic_cast<RefVolume*>(ENTITY_HANDLE(geom_entity));
     if (NULL != this_vol)
       this_body = this_vol->get_body_ptr();
Modified: cgm/trunk/itaps/testgeom.cc
--- cgm/trunk/itaps/testgeom.cc	2009-01-30 23:48:25 UTC (rev 2616)
+++ cgm/trunk/itaps/testgeom.cc	2009-01-31 01:26:13 UTC (rev 2617)
@@ -935,7 +935,7 @@
   CHECK( "Creating cylinder failed." );
     // move it onto the y axis
-  iGeom_moveEnt( geom, &cyl, 0.0, 1.0, -0.5, &err );
+  iGeom_moveEnt( geom, cyl, 0.0, 1.0, -0.5, &err );
   CHECK( "Problems moving surface." );
       // get the surface with max z
@@ -966,7 +966,7 @@
     // sweep it around the x axis
-  iGeom_moveEnt( geom, &cyl, 0.0, 1.0, 0.0, &err );
+  iGeom_moveEnt( geom, cyl, 0.0, 1.0, 0.0, &err );
   iGeom_sweepEntAboutAxis( geom, max_surf, 360.0, 1.0, 0.0, 0.0, &new_body, &err );
@@ -1076,7 +1076,7 @@
   CHECK( "Problems creating brick for transforms test." );
     // move it, then test bounding box
-  iGeom_moveEnt( geom, &brick, 0.5, 1.0, 1.5, &err );
+  iGeom_moveEnt( geom, brick, 0.5, 1.0, 1.5, &err );
   CHECK( "Problems moving brick for transforms test." );
   double bb_min[3], bb_max[3];
@@ -1095,7 +1095,7 @@
     // now rotate it about +x, then test bounding box
-  iGeom_rotateEnt( geom, &brick, 90, 1.0, 0.0, 0.0, &err );
+  iGeom_rotateEnt( geom, brick, 90, 1.0, 0.0, 0.0, &err );
   CHECK( "Problems rotating brick for transforms test." );
   iGeom_getEntBoundBox( geom, brick, bb_min, bb_min+1, bb_min+2, bb_max, bb_max+1, bb_max+2, &err );
@@ -1112,7 +1112,7 @@
     // now reflect through y plane; should recover original bb
-  iGeom_reflectEnt( geom, &brick, 0.0, 1.0, 0.0, &err );
+  iGeom_reflectEnt( geom, brick, 0.0, 1.0, 0.0, &err );
   CHECK( "Problems reflecting brick for transforms test." );
@@ -1152,7 +1152,7 @@
     // section the brick
   iBase_EntityHandle section_result = 0;
-  iGeom_sectionEnt( geom, &subtract_result, 1.0, 0.0, 0.0, 0.25, true, &section_result, &err );
+  iGeom_sectionEnt( geom, subtract_result, 1.0, 0.0, 0.0, 0.25, true, &section_result, &err );
   CHECK( "Problems sectioning for booleans section test." );
     // unite the section result with a new cylinder
More information about the cgma-dev mailing list
