[cgma-dev] r2582 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Tue Jan 27 12:01:28 CST 2009
Author: janehu
Date: 2009-01-27 12:01:28 -0600 (Tue, 27 Jan 2009)
New Revision: 2582
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Backed up the file for copying mesh size and interval info for sweep operation in OCC file. It should be done in a more general way.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-01-26 20:51:13 UTC (rev 2581)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2009-01-27 18:01:28 UTC (rev 2582)
@@ -3839,7 +3839,7 @@
// Author : Jane Hu
// Date : 09/08
-CubitStatus OCCModifyEngine::sweep_translational(
+CubitStatus OCCModifyEngine:: sweep_translational(
DLIList<GeometryEntity*>& ref_ent_list,
DLIList<BodySM*>& result_body_list,
const CubitVector& sweep_vector,
@@ -3855,7 +3855,6 @@
//creating draft shell then make solid to achieve.
//while if draft_angle is 0, and stop_surf = 0, to_body = 0
// directly use sweep functions.
- // mesh_size or mesh_scheme will only be preserved when it's not a draft.
TopoDS_Shape *stop_shape = NULL;
if(stop_surf)
@@ -3876,7 +3875,6 @@
gp_Dir adir(sweep_vector.x(), sweep_vector.y(), sweep_vector.z());
gp_Vec aVec(sweep_vector.x(), sweep_vector.y(), sweep_vector.z());
- DLIList<TopoDS_Shape*> shape_list;
for (int i = ref_ent_list.size(); i > 0; i--)
GeometryEntity *ref_ent = ref_ent_list.get_and_step();
@@ -3897,40 +3895,18 @@
continue;
- DLIList<CubitSimpleAttrib*> attribs;
- if(surface)
- surface->get_simple_attribute("MESH_SCHEME", attribs);
- surface->get_simple_attribute("MESH_INTERVAL", attribs);
- else if(curve)
- curve->get_simple_attribute("MESH_SCHEME", attribs);
- curve->get_simple_attribute("MESH_INTERVAL", attribs);
DLIList<TopologyBridge*> tbs;
//create the draft or the sweep
if(stop_shape == NULL && draft_angle == 0.)
BRepSweep_Prism swept(toposhape, aVec);
TopoDS_Shape new_shape = swept.Shape();
- TopoDS_Shape bottom_shape = swept.FirstShape();
- TopoDS_Shape top_shape = swept.LastShape();
- assert(toposhape.IsEqual(bottom_shape) || toposhape.IsEqual(top_shape));
- TopoDS_Shape the_other_shape = toposhape.IsEqual(bottom_shape)? top_shape:
- bottom_shape;
- for(int i = 0; i < attribs.size(); i++)
- OCCAttribSet::append_attribute(attribs.get_and_step(), the_other_shape);
tbs += OCCQueryEngine::instance()->populate_topology_bridge(new_shape);
assert(tbs.size() == 1);
BodySM* bodysm = CAST_TO(tbs.get(), BodySM);
if (bodysm)
result_body_list.append(bodysm);
continue;
@@ -4019,10 +3995,7 @@
if (bodysm)
- shape_list.append(&toposhape);
return CUBIT_SUCCESS;
@@ -4034,10 +4007,6 @@
loops = curve->loops();
if( loops.size()) //not a free curve
- curve->get_simple_attribute("MESH_INTERVAL",attribs);
- curve->get_simple_attribute("MESH_SCHEME",attribs);
//copy the curve
Curve* c_curve = make_Curve(curve);
if(c_curve)
@@ -4047,9 +4016,6 @@
PRINT_ERROR("Can't copy the curve for sweep.\n");
return CUBIT_FAILURE;
- //copy mesh size/interval attributes too
- for(int i = 0 ; i < attribs.size(); i++)
- curve->append_simple_attribute_virt(attribs.get_and_step());
TopoDS_Edge *edge = curve->get_TopoDS_Edge( );
toposhape = BRepBuilderAPI_MakeWire(*edge);
@@ -4068,10 +4034,6 @@
//check if the surface is sheet body, if not, copy it.
if(surface->my_body() == NULL) //not a sheet body
- surface->get_simple_attribute("MESH_INTERVAL",attribs);
- surface->get_simple_attribute("MESH_SCHEME",attribs);
c_surface = make_Surface(surface);
if (c_surface == NULL)
@@ -4079,9 +4041,6 @@
surface = CAST_TO(c_surface, OCCSurface);
- surface->append_simple_attribute_virt(attribs.get_and_step());
if(sweep_v_p)
@@ -4191,7 +4150,7 @@
// Author : Jane Hu
// Date : 10/08
-CubitStatus OCCModifyEngine::sweep_rotational(
+CubitStatus OCCModifyEngine:: sweep_rotational(
const CubitVector& point,
@@ -4304,19 +4263,6 @@
PRINT_ERROR("Only surface or curve can be revolve-swept.\n");
continue;
- if(surface)
- else if(curve)
TopoDS_Shape new_shape;
if(make_solid && curve != NULL )
@@ -4378,15 +4324,6 @@
BRepSweep_Revol revol(toposhape, axis, angle);
new_shape = revol.Shape();
- TopoDS_Shape bottom_shape = revol.FirstShape();
- TopoDS_Shape top_shape = revol.LastShape();
- bottom_shape;
@@ -4489,19 +4426,6 @@
continue;
- if(surface)
- else if(curve)
- DLIList<TopologyBridge*> tbs;
//sweep along the wire
BRepOffsetAPI_MakePipe maker(wire, toposhape);
if(!maker.IsDone())
@@ -4510,17 +4434,7 @@
continue;
TopoDS_Shape newShape = maker.Shape();
- TopoDS_Shape bottom_shape = maker.FirstShape();
- TopoDS_Shape top_shape = maker.LastShape();
- CubitSimpleAttrib* attrib = attribs.get_and_step();
- OCCAttribSet::append_attribute(attrib, bottom_shape);
- OCCAttribSet::append_attribute(attrib, top_shape);
tbs += OCCQueryEngine::instance()->populate_topology_bridge(newShape);
More information about the cgma-dev
