[cgma-dev] r2521 - cgm/trunk/geom/OCC
    janehu at mcs.anl.gov
    Thu Jan  8 15:13:41 CST 2009
Author: janehu
Date: 2009-01-08 15:13:41 -0600 (Thu, 08 Jan 2009)
New Revision: 2521
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added loft_surfaces_to_body and some other minor changes for functions.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-01-08 19:30:03 UTC (rev 2520)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2009-01-08 21:13:41 UTC (rev 2521)
@@ -5913,38 +5913,47 @@
 // Description: Creates an offset surface.
-// Author     : Tyronne Lim
-// Date       : 08/18/03
+// Author     : Jane Hu
+// Date       : 01/09
 CubitStatus OCCModifyEngine::create_offset_surface( Surface* /*ref_face_ptr*/,
-                                                      BodySM*& /*new_body*/,
-                                                      double /*offset_distance*/ ) const
+                                                    BodySM*& /*new_body*/,
+                                                    double /*offset_distance*/ ) const
-   PRINT_ERROR("Function not implemented in this engine.\n");
+   PRINT_ERROR("Function not implemented because offset_distance \n"
+               "doesn't show offset direction.\n");
    return CUBIT_FAILURE;
 // Description: Creates an offset body.
-// Date       : 08/18/03
+// Date       : 01/09
 CubitStatus OCCModifyEngine::create_offset_body( BodySM* body_ptr,
-                                                   BodySM*& new_bodysm,
-                                                   double offset_distance ) const
+                                                 BodySM*& new_bodysm,
+                                                 double offset_distance ) const
 // Description: Creates a skin surface.
-// Date       : 08/18/03
+// Date       : 01/09
-CubitStatus OCCModifyEngine::create_skin_surface( DLIList<Curve*>& /*curves*/,
-                                                    BodySM*& /*new_body*/ ) const
+CubitStatus OCCModifyEngine::create_skin_surface( DLIList<Curve*>& curves,
+                                                  BodySM*& new_body ) const
+   new_body = NULL;
+   Surface* surf = make_Surface(BEST_FIT_SURFACE_TYPE, curves);
+   if(surf)
+     new_body = CAST_TO(surf, OCCSurface)->my_body();
+     return CUBIT_SUCCESS;
@@ -5954,38 +5963,80 @@
 // Date       : 08/18/03
 CubitStatus OCCModifyEngine::loft_surfaces( Surface * /*face1*/,
-                                              const double & /*takeoff1*/,
-                                              Surface * /*face2*/,
-                                              const double & /*takeoff2*/,
-                                              CubitBoolean /*arc_length_option*/,
-                                              CubitBoolean /*twist_option*/,
-                                              CubitBoolean /*align_direction*/,
-                                              CubitBoolean /*perpendicular*/,
-                                              CubitBoolean /*simplify_option*/ ) const
+                                            const double & /*takeoff1*/,
+                                            Surface * /*face2*/,
+                                            const double & /*takeoff2*/,
+                                            CubitBoolean /*arc_length_option*/,
+                                            CubitBoolean /*twist_option*/,
+                                            CubitBoolean /*align_direction*/,
+                                            CubitBoolean /*perpendicular*/,
+                                            CubitBoolean /*simplify_option*/ ) const
-// Description: Creates a body by lofting surfaces between bodies.
-// Date       : 08/18/03
+// Description: Creates a body by lofting surfaces between surfaces
+// Date       : 01/09
-CubitStatus OCCModifyEngine::loft_surfaces_to_body( Surface * /*face1*/,
+CubitStatus OCCModifyEngine::loft_surfaces_to_body( Surface * face1,
+                             Surface * face2,
+                             BodySM*& new_body,
-   return CUBIT_FAILURE;
+   BRepOffsetAPI_ThruSections loft(CUBIT_TRUE);
+   OCCSurface* surf1 = CAST_TO(face1, OCCSurface);
+   OCCSurface* surf2 = CAST_TO(face2, OCCSurface);
+   if(!surf1 || !surf2)
+     PRINT_ERROR("Surfaces are not OCC type.\n");
+     return CUBIT_FAILURE;
+   TopoDS_Face* topo_face1 = surf1->get_TopoDS_Face();
+   TopoDS_Face* topo_face2 = surf2->get_TopoDS_Face();
+   TopExp_Explorer Ex;
+   Ex.Init(*topo_face1, TopAbs_WIRE);
+   TopoDS_Wire wire1 = TopoDS::Wire(Ex.Current());
+   if(Ex.More())
+     PRINT_ERROR("Surface1 must have only one loop.\n");
+   Ex.Init(*topo_face2, TopAbs_WIRE);
+   TopoDS_Wire wire2 = TopoDS::Wire(Ex.Current());
+   if(Ex.More())
+     PRINT_ERROR("Surface2 must have only one loop.\n");
+   loft.AddWire(wire1);
+   loft.AddWire(wire2);
+   loft.Build();
+   if(!loft.IsDone())
+     PRINT_ERROR("Surfaces can't be loft into a body.\n");
+   TopoDS_Shape shape = loft.Shape();
+   TopoDS_Solid solid = TopoDS::Solid(shape);
+   Lump* lump = OCCQueryEngine::instance()->populate_topology_bridge(solid);
+   if (lump == NULL)
+     PRINT_ERROR("In OCCModifyEngine::loft_surfaces_to_body\n"
+                 "   Cannot create a loft body for given surfaces.\n");
+   new_body = CAST_TO(lump, OCCLump)->get_body();
More information about the cgma-dev
