[cgma-dev] r2505 - cgm/trunk/test
    janehu at mcs.anl.gov
    Mon Jan  5 14:17:00 CST 2009
Author: janehu
Date: 2009-01-05 14:16:58 -0600 (Mon, 05 Jan 2009)
New Revision: 2505
Added:
   cgm/trunk/test/operation.cpp
Modified:
   cgm/trunk/test/Makefile.am
Log:
Added tests for get_mid_plane function.
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am	2009-01-05 20:16:07 UTC (rev 2504)
+++ cgm/trunk/test/Makefile.am	2009-01-05 20:16:58 UTC (rev 2505)
@@ -21,7 +21,7 @@
 endif
 endif
 if build_OCC
-  TESTS += modify makept r_w test_occ
+  TESTS += modify makept r_w test_occ operation
 endif
 AM_CPPFLAGS =
@@ -37,6 +37,7 @@
 sheet_SOURCES  = sheet.cpp
 r_w_SOURCES    = r_w.cpp
 test_occ_SOURCES = test_occ.cpp
+operation_SOURCES = operation.cpp
 LDADD = ../libcgm.la
 webcut_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
 hollow_acis_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
@@ -45,6 +46,7 @@
 sheet_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
 r_w_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
 test_occ_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
+operation_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
 # Files that are used as input to tests, and therefore
 # must be included in tarball for tests to run.
Added: cgm/trunk/test/operation.cpp
--- cgm/trunk/test/operation.cpp	                        (rev 0)
+++ cgm/trunk/test/operation.cpp	2009-01-05 20:16:58 UTC (rev 2505)
@@ -0,0 +1,204 @@
+ * \file operation.cpp
+ * \brief operation, another simple C++ driver for CGM
+ * This program acts as a simple driver for CGM.  It reads in a geometry,
+ * and performs varies checks for bodies, surfaces, curves and vertices.
+#include "config.h"
+#include "CpuTimer.hpp"
+#include "GeometryModifyTool.hpp"
+#include "GeometryQueryTool.hpp"
+#include "OCCQueryEngine.hpp"
+#include "CubitUtil.hpp"
+#include "CubitMessage.hpp"
+#include "CubitDefines.h"
+#include "RefEntity.hpp"
+#include "Body.hpp"
+#include "RefVolume.hpp"
+#include "RefFace.hpp"
+#include "RefEdge.hpp"
+#include "RefVertex.hpp"
+#include "CubitObserver.hpp"
+#include "CastTo.hpp"
+#include "OCCModifyEngine.hpp"
+#include "AppUtil.hpp"
+#include "RefEntityFactory.hpp"
+#include "BodySM.hpp"
+#include "Lump.hpp"
+#include "OCCLump.hpp"
+#include "OCCBody.hpp"
+#include "OCCSurface.hpp"
+#include "OCCCurve.hpp"
+#include "OCCShell.hpp"
+#include "TopoDS_Shape.hxx"
+#include "RefEntityName.hpp"
+#include <algorithm>
+#ifndef SRCDIR
+# define SRCDIR .
+#endif
+#define STRINGIFY_(X) #X
+#define STRINGIFY(X) STRINGIFY_(X)
+#define SRCPATH STRINGIFY(SRCDIR) "/"
+// forward declare some functions used and defined later
+CubitStatus read_geometry(int, char **, bool local = false);
+CubitStatus make_Point();
+// macro for printing a separator line
+#define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
+// main program - initialize, then send to proper function
+int main (int argc, char **argv)
+  CubitObserver::init_static_observers();
+    // Initialize the GeometryTool
+  CGMApp::instance()->startup( argc, argv );
+  OCCQueryEngine::instance();
+  OCCModifyEngine::instance();
+    // If there aren't any file arguments, print usage and exit
+  //if (argc == 1) {
+  //  PRINT_INFO("Usage: mergechk <geom_file> [<geom_file> ...]\n");
+  //  exit(0);
+  CubitStatus status = CUBIT_SUCCESS;
+  //Do make point.
+  status = make_Point();
+  if (status == CUBIT_FAILURE)
+     PRINT_INFO("Operation Failed");
+  int ret_val = ( CubitMessage::instance()->error_count() );
+  if ( ret_val > 0 )
+    PRINT_ERROR("Errors found during Mergechk session.\n");
+  return ret_val;
+std::string type_from_file_name( const std::string& filename )
+  size_t dot_pos = filename.find_last_of( '.' );
+  if (dot_pos == std::string::npos)
+    return std::string();
+  std::string extension = filename.substr( dot_pos + 1 );
+  std::transform( extension.begin(), extension.end(), extension.begin(), tolower );
+  if (extension == "occ" || extension == "brep")
+    return "OCC";
+  else if (extension == "step" || extension == "stp")
+    return "STEP";
+  else if (extension == "iges" || extension == "igs")
+    return "IGES";
+  else
+/// attribs module: list, modify attributes in a give model or models
+/// Arguments: file name(s) of geometry files in which to look
+CubitStatus read_geometry(int num_files, const char **argv, bool local)
+  GeometryQueryTool *gti = GeometryQueryTool::instance();
+  assert(gti);
+  int i;
+  PRINT_SEPARATOR;
+  for (i = 0; i < num_files; i++) {
+    std::string type = type_from_file_name( argv[i] );
+    if (type.empty()) // just guess OCC
+      type = "OCC";
+    std::string filename( local ? "./" : SRCPATH );
+    filename += argv[i];
+    status = gti->import_solid_model(filename.c_str(), type.c_str());
+    if (status != CUBIT_SUCCESS) {
+      PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str());
+      abort();
+  PRINT_SEPARATOR;
+  return CUBIT_SUCCESS;
+  GeometryModifyTool *gmti = GeometryModifyTool::instance();
+  DLIList<Body*> bodies;
+  DLIList<RefEntity*>  free_entities;
+  // Read in the geometry from files specified on the command line
+  const char *argv = "stitch.name_occ";
+  CubitStatus status = read_geometry(1, &argv, false);
+  if (status == CUBIT_FAILURE) exit(1);
+  //Read in 2 volumes.
+  gti->bodies(bodies);
+  DLIList<Body*> new_bodies;
+  DLIList<Body*> from_bodies;
+  BodySM* from_body = bodies.get()->get_body_sm_ptr();
+  from_bodies.append(bodies.get());
+  CubitVector v1(1,1,3);
+  CubitVector v2(1,2,2);
+  CubitVector v3(1,1,1);
+  BodySM* mid_plane;
+  status = OCCModifyEngine::instance()->get_mid_plane(v1, v2, v3, from_body, mid_plane);
+  if(mid_plane)
+    Body *midplane_body;
+    midplane_body = gti->make_Body(mid_plane);
+    double d = midplane_body->measure();
+    //d = 100
+  v1.x(2);
+  v2.x(2);
+  v3.x(2);
+  if(mid_plane)
+    //d = 70
+  status = gmti->webcut_with_plane(from_bodies, v1, v2, v3, new_bodies, CUBIT_TRUE);
+  //double d = new_bodies.step_and_get()->measure();
+  //CubitVector v = new_bodies.get()->center_point();
+  //int n = new_bodies.get()->num_ref_faces();
+  // n = 6
+  //new bodies has 2 bodies, one has a volume = 10 and the other has a
+  //volume = 50; each of them has 6 ref_faces, of which 3 are new and 3 are
+  //remaining (unchanged or modified).
+  bodies.clean_out();
+  //delete all entities
+  gti->delete_Body(bodies);
+  gti->get_free_ref_entities(free_entities);
+  assert(free_entities.size() ==0);
More information about the cgma-dev
