[cgma-dev] r2054 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Sep 3 13:15:05 CDT 2008
Author: janehu
Date: 2008-09-03 13:15:05 -0500 (Wed, 03 Sep 2008)
New Revision: 2054
Modified:
cgm/trunk/geom/OCC/OCCAttribSet.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Remove attributes when the entities get deleted.
Modified: cgm/trunk/geom/OCC/OCCAttribSet.cpp
--- cgm/trunk/geom/OCC/OCCAttribSet.cpp 2008-09-03 16:04:25 UTC (rev 2053)
+++ cgm/trunk/geom/OCC/OCCAttribSet.cpp 2008-09-03 18:15:05 UTC (rev 2054)
@@ -280,7 +280,7 @@
if(!found)
return;
- myLabel.Nullify();
+ myLabel.ForgetAllAttributes();
void OCCAttribSet::remove_attribute( CubitSimpleAttrib* csa,
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-09-03 16:04:25 UTC (rev 2053)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-09-03 18:15:05 UTC (rev 2054)
@@ -1718,6 +1718,9 @@
if (!shape)
return CUBIT_FAILURE;
+ //remove the entry from label tree
+ OCCAttribSet::remove_attribute(*shape) ;
//remove the entry from the map
int k;
OCCBody* occ_body_find = NULL;
@@ -1774,6 +1777,9 @@
if(!solid)
+ OCCAttribSet::remove_attribute(*solid) ;
int k;
if(OCCMap->IsBound(*solid))
@@ -1919,6 +1925,9 @@
unhook_cofaces_of_a_surface(fsurf);
+ OCCAttribSet::remove_attribute(*face) ;
int k;
if(OCCMap->IsBound(*face))
@@ -2102,6 +2111,8 @@
if (!edge)
+ OCCAttribSet::remove_attribute(*edge) ;
int k;
@@ -2162,6 +2173,9 @@
if (!vertex)
+ OCCAttribSet::remove_attribute(*vertex) ;
int k;
if(OCCMap->IsBound(*vertex))
More information about the cgma-dev
