[cgma-dev] r2167 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov janehu at mcs.anl.gov
Tue Oct 21 12:28:30 CDT 2008
Author: janehu
Date: 2008-10-21 12:28:30 -0500 (Tue, 21 Oct 2008)
New Revision: 2167
Modified:
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Added vector header for build issues, started on sweep_rotational coding.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-10-21 14:09:52 UTC (rev 2166)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-10-21 17:28:30 UTC (rev 2167)
@@ -127,6 +127,7 @@
 #include "AppUtil.hpp"
 #include "SphereEvaluator.hpp"
 #include "CylinderEvaluator.hpp"
+#include <vector>
 OCCModifyEngine* OCCModifyEngine::instance_ = 0;
 #define DEBUG
@@ -4065,26 +4066,26 @@
 // Function   : sweep_rotational
 // Member Type: PUBLIC
 // Description:
-// Author     : John Fowler
-// Date       : 10/02
+// Author     : Jane Hu
+// Date       : 10/08
 CubitStatus OCCModifyEngine:: sweep_rotational(
-  DLIList<GeometryEntity*>& /*ref_ent_list*/,
-  DLIList<BodySM*>& /*result_body_list*/,
-  const CubitVector& /*point*/,
-  const CubitVector& /*direction*/,
-  double /*angle*/,
-  int /*steps*/,
-  double /*draft_angle*/,
-  int /*draft_type*/,
-  bool /*switchside*/,
-  bool /*make_solid*/,
-  bool /*rigid*/,
-  Surface* stop_surf,
-  BodySM* to_body) const
+  DLIList<GeometryEntity*>& ref_ent_list,
+  DLIList<BodySM*>& result_body_list,
+  const CubitVector& point,
+  const CubitVector& direction,
+  double angle,
+  int steps,  //not used
+  double draft_angle, //not used
+  int draft_type,  //not used
+  bool switchside, //not used
+  bool make_solid,
+  bool rigid,  //not used
+  Surface* stop_surf,  //not used
+  BodySM* to_body ) const  //not used
-  PRINT_ERROR("Option not supported for mesh based geometry.\n");
-  return CUBIT_FAILURE;
+  return CUBIT_SUCCESS;
More information about the cgma-dev mailing list
