[cgma-dev] r2159 - in cgm/trunk: . m4
kraftche at mcs.anl.gov
Mon Oct 20 15:01:06 CDT 2008
Author: kraftche
Date: 2008-10-20 15:01:05 -0500 (Mon, 20 Oct 2008)
New Revision: 2159
Added:
cgm/trunk/m4/
cgm/trunk/m4/acis.m4
cgm/trunk/m4/boost.m4
cgm/trunk/m4/compiler.m4
cgm/trunk/m4/cplusplus.m4
cgm/trunk/m4/hdf5.m4
cgm/trunk/m4/makevar.m4
cgm/trunk/m4/netcdf.m4
Removed:
cgm/trunk/acsite.m4
Modified:
cgm/trunk/Makefile.am
cgm/trunk/configure.in
Log:
Replace acsite.m4 with split up files in m4/ subdir, and update with changes to MOAB's versions of the *.m4 files
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am 2008-10-20 20:00:22 UTC (rev 2158)
+++ cgm/trunk/Makefile.am 2008-10-20 20:01:05 UTC (rev 2159)
@@ -1,5 +1,7 @@
AUTOMAKE_OPTIONS = foreign
SUBDIRS = util geom init itaps . test cgm_apps
+# Don't loose the autoconf include path
+ACLOCAL_AMFLAGS = -I m4
# Automake doesn't seem to have a directory defined for
# platform-dependent data (or include) files. So put
Deleted: cgm/trunk/acsite.m4
--- cgm/trunk/acsite.m4 2008-10-20 20:00:22 UTC (rev 2158)
+++ cgm/trunk/acsite.m4 2008-10-20 20:01:05 UTC (rev 2159)
@@ -1,964 +0,0 @@
-# Get libtool configuration variable
-# Arguments:
-# libtool config tag (e.g CXX)
-# libtool variable name
-# variable in which to store result
-AC_DEFUN( [ITAPS_LIBTOOL_VAR], [
- $3=`./libtool --tag=$1 --config | sed -e 's/^$2=//p' -e 'd' | tr -d '"\n'`
-# Implement checks for C and C++ compilers, with all corresponding options
-# Sets the following variables:
-# CPP - The C preprocessor
-# CC - The C compiler
-# CXX - The C++ compiler
-# CFLAGS - C compiler flags
-# CXXFLAGS - C++ compiler flags
-# WITH_MPI - 'yes' if parallel support, 'no' otherwise
-AC_DEFUN([SNL_CHECK_COMPILERS], [
- # Save these before calling AC_PROG_CC or AC_PROG_CXX
- # because those macros will modify them, and we want
- # the original user values, not the autoconf defaults.
-USER_CXXFLAGS="$CXXFLAGS"
-USER_CFLAGS="$CFLAGS"
- # Check for Parallel
- # Need to check this early so we can look for the correct compiler
-AC_ARG_WITH( [mpi], AC_HELP_STRING([[--with-mpi(=DIR)]], [Enable parallel support]),
- [WITH_MPI=$withval],[WITH_MPI=no] )
-case "x$WITH_MPI" in
- xno)
- CC_LIST="cc gcc cl egcs pgcc"
- CXX_LIST="CC aCC cxx xlC_r xlC c++ g++ pgCC gpp cc++ cl FCC KCC RCC"
- xyes)
- CC_LIST="mpicc mpcc"
- CXX_LIST="mpiCC mpCC mpicxx"
- x*)
- if test -z "$CC";then
- for prog in mpicc mpcc; do
- if test -x ${WITH_MPI}/bin/$prog; then
- CC="${WITH_MPI}/bin/$prog"
- CC_LIST="$prog"
- fi
- done
- else
- CC_LIST="$CC"
- fi
- if test -z "$CXX";then
- for prog in mpicxx mpiCC mpCC mpicxx; do
- CXX="${WITH_MPI}/bin/$prog"
- CXX_LIST="$prog"
- fi
- done
- else
- CXX_LIST="$CXX"
- fi
- WITH_MPI=yes
-esac
-AC_PROG_CC( [$CC_LIST] )
-AC_PROG_CPP
-AC_PROG_CXX( [$CXX_LIST] )
-AC_PROG_CXXCPP
-# Try to determine compiler-specific flags. This must be done
-# before setting up libtool so that it can override libtool settings.
-SNL_CC_FLAGS
-SNL_CXX_FLAGS
-CFLAGS="$USER_CFLAGS $SNL_CC_SPECIAL"
-CXXFLAGS="$USER_CXXFLAGS $SNL_CXX_SPECIAL"
-# On IBM/AIX, the check for OBJEXT fails for the mpcc compiler.
-# (Comment out this hack, it should be fixed correctly now)
-#if test "x$OBJEXT" = "x"; then
-# OBJEXT=o
-#fi
- # Check for debug flags
-AC_ARG_ENABLE( debug, AC_HELP_STRING([--enable-debug],[Debug symbols (-g)]),
- [enable_debug=$enableval], [enable_debug=] )
-AC_ARG_ENABLE( optimize, AC_HELP_STRING([--enable-optimize],[Compile optimized (-O2)]),
- [enable_cxx_optimize=$enableval
- enable_cc_optimize=$enableval],
- enable_cc_optimize=] )
-# Do enable_optimize by default, unless user has specified
-# custom CXXFLAGS or CFLAGS
-if test "x$enable_debug" = "x"; then
- if test "x$enable_cxx_optimize" = "x"; then
- if test "x$USER_CXXFLAGS" = "x"; then
- enable_cxx_optimize=yes
- fi
- fi
- if test "x$enable_cc_optimize" = "x"; then
- if test "x$USER_CFLAGS" = "x"; then
- enable_cc_optimize=yes
- fi
- fi
-fi
-# Choose compiler flags from CLI args
-if test "xyes" = "x$enable_debug"; then
- CXXFLAGS="$CXXFLAGS -g"
- CFLAGS="$CLFAGS -g"
-fi
-if test "xyes" = "x$enable_cxx_optimize"; then
- CXXFLAGS="$CXXFLAGS -O2 -DNDEBUG"
-fi
-if test "xyes" = "x$enable_cc_optimize"; then
- CFLAGS="$CFLAGS -O2 -DNDEBUG"
-fi
- # Check for 32/64 bit.
- # This requires SNL_CXX_FLAGS and SNL_CC_FLAGS to have been called first
-AC_ARG_ENABLE( 32bit, AC_HELP_STRING([--enable-32bit],[Force 32-bit objects]),
- if test "xyes" != "x$enableval"; then
- AC_MSG_ERROR([Unknown argument --enable-32bit=$enableval])
- elif test "x" = "x$SNL_CXX_32BIT"; then
- AC_MSG_ERROR([Don't know how to force 32-bit C++ on this platform. Try setting CXXFLAGS manually])
- elif test "x" = "x$SNL_CC_32BIT"; then
- AC_MSG_ERROR([Don't know how to force 32-bit C on this platform. Try setting CFLAGS manually])
- fi
- CXXFLAGS="$CXXFLAGS $SNL_CXX_32BIT"
- CFLAGS="$CFLAGS $SNL_CC_32BIT"
- enable_32bit=yes
-# This requires SNL_CXX_FLAGS and SNL_CC_FLAGS to have been called first
-AC_ARG_ENABLE( 64bit, AC_HELP_STRING([--enable-64bit],[Force 64-bit objects]),
- AC_MSG_ERROR([Unknown argument --enable-64bit=$enableval])
- elif test "x" = "x$SNL_CXX_64BIT"; then
- AC_MSG_ERROR([Don't know how to force 64-bit C++ on this platform. Try setting CXXFLAGS manually])
- elif test "x" = "x$SNL_CC_64BIT"; then
- AC_MSG_ERROR([Don't know how to force 64-bit C on this platform. Try setting CFLAGS manually])
- elif test "xyes" = "x$enable_32bit"; then
- AC_MSG_ERROR([Cannot do both --enable-32bit and --enable-64bit])
- fi
- CXXFLAGS="$CXXFLAGS $SNL_CXX_64BIT"
- CFLAGS="$CFLAGS $SNL_CC_64BIT"
-]) # SNL_CHECK_COMPILERS
-# Extract the value of a variable from a makefile fragment.
-# Arguments:
-# - The path of the makefile fragment
-# - The name of the makefile variable
-# - Action on success (the shell variable "make_val" will contain the value
-# of the variable)
-# - Action on failure
-AC_DEFUN([SNL_MAKE_INC_VAR], [
-make_val=
-snl_makefile="snl_check.mak"
-rm -f $snl_makefile
-if test ! -f $1 ; then
- AC_MSG_WARN([File not found: $1])
- $4
-else
-cat >$snl_makefile <<SNL_END_OF_MAKEFILE
-default:
- @echo "\$($2)"
-include $1
-SNL_END_OF_MAKEFILE
-if make -f $snl_makefile > /dev/null 2>&1; then
- make_val=`make -f $snl_makefile`
- rm -f $snl_makefile
- $3
-else
- $4
-fi
-fi
-# Check for existance of new no-file-extension C++ headers.
-# Conditinionally sets the following preprocessor macros:
-# CANT_USE_STD
-# - The new no-extension versions of the c++ headers do not
-# exist or do not define symbols to be in the "std" namespace.
-# For example: if this is defined #include <map.h> rather than <map>.
-# CANT_USE_STD_IO
-# - The new no-extension versions of the c++ IO headers do not
-# For example: if this is defined, #include <iostrea.h> rather than <iostream>
-AC_DEFUN([SNL_CANT_USE_STD], [
-AC_LANG_SAVE
-AC_LANG_CPLUSPLUS
-AC_MSG_CHECKING([for C++-standard header files])
-AC_TRY_COMPILE([#include <vector>
- #include <string>
- #include <map>
- #include <algorithm>
- [std::vector<std::string> v;
- std::map<std::string,std::string> m;
- [AC_MSG_RESULT(yes)],
- [AC_MSG_RESULT(no); CANT_USE_STD=-DCANT_USE_STD])
-AC_MSG_CHECKING([for C++-standard I/O header files])
-AC_TRY_COMPILE([#include <iosfwd>
- #include <iostream>
- #include <ostream>
- #include <sstream>
- [std::cout << std::endl;],
- [AC_MSG_RESULT(no); CANT_USE_STD_IO=-DCANT_USE_STD_IO])
-AC_LANG_RESTORE
-]) # SNL_CANT_USE_STD
-# Check if template definitions (.cpp files) must be
-# included (in the .hpp files).
-# Sets TEMPLATE_DEFS_INCLUDED=1
-AC_DEFUN([SNL_TEMPLATE_DEFS_INCLUDED], [
-AC_LANG_SAVE
-AC_LANG_CPLUSPLUS
-AC_MSG_CHECKING([if template definitions should be included])
-src=conftest.cc
-templ=conftemp.cc
-exe=conftest
-echo "template <typename T> class MyTempl { public: T get() const; };" >$templ
-echo "template <typename T> T MyTempl<T>::get() const { return 0; }" >>$templ
-echo "template <typename T> class MyTempl { public: T get() const; };" >$src
-echo "int main( ) { MyTempl<int> c; return c.get(); }" >>$src
-if $CXX $CXXFLAGS $LDFLAGS $src $templ -o $exe >/dev/null 2>/dev/null; then
- TEMPLATE_DEFS_INCLUDED=
- AC_MSG_RESULT(no)
-else
- TEMPLATE_DEFS_INCLUDED=-DTEMPLATE_DEFS_INCLUDED
- AC_MSG_RESULT(yes)
-fi
-rm -f $src $templ $exe
-AC_LANG_RESTORE
-]) # SNL_TEMPLATE_DEFS_INCLUDED
-# Check for HDF5 library and related stuff
-# Sets HAVE_HDF5 to 'yes' or 'no'
-# If HAVE_HDF5 == yes, then updates INCLUDES and LIBS accordingly.
-AC_DEFUN([SNL_CHECK_HDF5],[
- # CLI option for linking zlib
-AC_ARG_WITH(zlib,
- [AC_HELP_STRING([--with-zlib=DIR],[HDF5 requires zlib, and zlib can be found at...])],
- [WITH_ZLIB=$withval
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-zlib=\"${withval}\""
- ],[WITH_ZLIB=])
-case "x$WITH_ZLIB" in
- xyes|xno|x)
- if ! test -d ${WITH_ZLIB}/lib; then
- AC_MSG_ERROR([Not a directory: ${WITH_ZLIB}/lib])
- fi
- LIBS="$LIBS -L${WITH_ZLIB}/lib"
-esac
-HAVE_ZLIB=no
-if test "x$WITH_ZLIB" != "xno"; then
- AC_CHECK_LIB([z],[deflate],[HAVE_ZLIB=yes],
- [if test "x$WITH_ZLIB" != "x"; then AC_MSG_ERROR([Could not find zlib]); fi])
-fi
- # CLI option for linking szip
-AC_ARG_WITH(szip,
- [AC_HELP_STRING([--with-szip=DIR],[HDF5 requires szip, and szip an be found at...])],
- [WITH_SZIP=$withval
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-szip=\"${withval}\""
- ],[WITH_SZIP=])
-case "x$WITH_SZIP" in
- xyes|xno|x)
- if ! test -d ${WITH_SZIP}/lib; then
- AC_MSG_ERROR([Not a directory: ${WITH_SZIP}/lib])
- fi
- LIBS="$LIBS -L${WITH_SZIP}/lib"
-esac
-HAVE_SZIP=no
-if test "x$WITH_SZIP" != "xno"; then
- AC_CHECK_LIB([sz],[SZ_Decompress],[HAVE_SZIP=yes],
- [if test "x$WITH_SZIP" != "x"; then AC_MSG_ERROR([Could not find libsz]); fi])
-fi
- # CLI option for extra HDF5 link flags
-AC_ARG_WITH([--with-hdf5-ldflags],[AC_HELP_STRING([--with-hdf5-ldflags=...],
- [Extra LDFLAGS required for HDF5 library (e.g. parallel IO lib)])],
- [HDF5_LDFLAGS="$withval"
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-hdf5-ldflags=\"${withval}\""
-],[HDF5_LDFLAGS=])
-case "x$HDF5_LDFLAGS" in
- xno)
- AC_MSG_ERROR("Invalid argument: --without-hdf5-ldflags")
- xyes)
- AC_MSG_ERROR("Nonsensical argument: --with-hdf5-ldflags without any specified flags")
-esac
- # CLI option for HDF5
-AC_MSG_CHECKING([if HDF5 support is enabled])
-AC_ARG_WITH(hdf5,
-[AC_HELP_STRING([--with-hdf5=DIR], [Specify HDF5 library to use for native file format])
-AC_HELP_STRING([--without-hdf5], [Disable support for native HDF5 file format])],
-[HDF5_ARG=$withval
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-hdf5=\"${withval}\""
-], [HDF5_ARG=yes])
-if test "xno" = "x$HDF5_ARG"; then
- AC_MSG_RESULT([no])
-else
- AC_MSG_RESULT([yes])
-fi
- # if HDF5 support is not disabled, check to make sure we have HDF5
-HAVE_HDF5=no
-if test "xno" != "x$HDF5_ARG"; then
- HAVE_HDF5=yes
- # Check for IBM parallel IO library
- if test "x$WITH_MPI" != "xno"; then
- AC_CHECK_LIB([gpfs],[gpfs_stat],[LIBS="-lgpfs $LIBS"])
- fi
- # if a path is specified, update LIBS and INCLUDES accordingly
- if test "xyes" != "x$HDF5_ARG"; then
- if test -d "${HDF5_ARG}/lib"; then
- HDF5_LDFLAGS="$HDF5_LDFLAGS -L${HDF5_ARG}/lib"
- elif test -d "${HDF5_ARG}"; then
- HDF5_LDFLAGS="$HDF5_LDFLAGS -L${HDF5_ARG}"
- else
- AC_MSG_ERROR("$HDF5_ARG is not a directory.")
- fi
- if test -d "${HDF5_ARG}/include"; then
- INCLUDES="$INCLUDES -I${HDF5_ARG}/include"
- else
- INCLUDES="$INCLUDES -I${HDF5_ARG}"
- fi
- fi
- # Add flag to defines
- old_LIBS="$LIBS"
- LIBS="$LIBS $HDF5_LDFLAGS"
- # check for libraries and headers
- old_CPPFLAGS="$CPPFLAGS"
- CPPFLAGS="$CPPFLAGS $INCLUDES"
- AC_CHECK_HEADERS( [hdf5.h], [], [HAVE_HDF5=no] )
- CPPFLAGS="$old_CPPFLAGSS"
- HAVE_LIB_HDF5=no
- AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes] )
- if test $HAVE_LIB_HDF5 = no; then
- if test $HAVE_ZLIB = yes; then
- unset ac_cv_lib_hdf5_H5Fopen
- AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; old_LIBS="-lz $old_LIBS"], [], [-lz] )
- fi
- fi
- if test $HAVE_SZIP = yes; then
- AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; old_LIBS="-lsz $old_LIBS"], [], [-lsz] )
- fi
- fi
- AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; old_LIBS="-lsz -lz $old_LIBS"], [], [-lz -lsz] )
- fi
- fi
- fi
- if test "x$HAVE_LIB_HDF5" = "xno"; then
- AC_MSG_WARN([Could not find HDF5 library (-lhdf5)])
- HAVE_HDF5=no
- fi
- if test "x$HAVE_HDF5" = "xyes"; then
- LIBS="$HDF5_LDFLAGS -lhdf5 $old_LIBS"
- else
- LIBS="$old_LIBS"
- fi
-fi
-]) # SNL_CHECK_HDF5
-# Check for NetCDF library ((C++)
-# Sets HAVE_NETCDF to 'yes' or 'no'
-# If HAVE_NETCDF == yes, then updates INCLUDES and LIBS accordingly.
-AC_DEFUN([SNL_CHECK_NETCDF],[
-AC_MSG_CHECKING([if NetCDF support is enabled])
-AC_ARG_WITH(netcdf,
-[AC_HELP_STRING([--with-netcdf=DIR], [Specify NetCDF library to use for ExodusII file format])
-AC_HELP_STRING([--without-netcdf], [Disable support for ExodusII file format])],
-[NETCDF_ARG=$withval
-DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-netcdf=\"${withval}\""
-, [NETCDF_ARG=yes])
-if test "xno" = "x$NETCDF_ARG"; then
-else
-fi
- # if NetCDF support is not disabled
-HAVE_NETCDF=no
-if test "xno" != "x$NETCDF_ARG"; then
- HAVE_NETCDF=yes
- DEFINES="$DEFINES -DNETCDF_FILE"
- # Check for stream headers and set STRSTREAM_H_SPEC accordingly
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_CHECK_HEADER( [strstream.h], [NETCDF_DEF="<strstream.h>"], [
- AC_CHECK_HEADER( [sstream.h], [NETCDF_DEF="<sstream.h>"], [
- AC_CHECK_HEADER( [strstream], [NETCDF_DEF="<strstream>"], [
- AC_CHECK_HEADER( [sstream], [NETCDF_DEF="<sstream>"] )
- AC_LANG_RESTORE
- if test "xyes" != "x$NETCDF_ARG"; then
- if test -d "${NETCDF_ARG}/lib"; then
- LIBS="$LIBS -L${NETCDF_ARG}/lib"
- elif test -d "${NETCDF_ARG}"; then
- LIBS="$LIBS -L${NETCDF_ARG}"
- else
- AC_MSG_ERROR("$NETCDF_ARG is not a directory.")
- fi
- if test -d "${NETCDF_ARG}/include"; then
- INCLUDES="$INCLUDES -I${NETCDF_ARG}/include"
- elif test -d "${NETCDF_ARG}/inc"; then
- INCLUDES="$INCLUDES -I${NETCDF_ARG}/inc"
- else
- INCLUDES="$INCLUDES -I${NETCDF_ARG}"
- fi
- fi
- old_CXXFLAGS="$CXXFLAGS"
- CXXFLAGS="$CXXFLAGS $INCLUDES"
- old_LIBS="$LIBS"
- # Check for C library
- AC_CHECK_HEADERS( [netcdf.h], [], [AC_MSG_WARN([[NetCDF header not found.]]); HAVE_NETCDF=no] )
- AC_MSG_CHECKING([for netcdf.hh])
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- HAVE_NETCDF_HH=no
- AC_TRY_COMPILE(
-[#include "netcdf.hh"], [], [HAVE_NETCDF_HH=yes; NETCDF_DEF=], [
- AC_TRY_COMPILE(
-[#define STRSTREAM_H_SPEC $NETCDF_DEF
- #include "netcdf.hh"], [], [HAVE_NETCDF_HH=yes], [NAVE_NETCDF_HH=no])])
- AC_MSG_RESULT([$HAVE_NETCDF_HH])
- if test $HAVE_NETCDF_HH != yes; then
- AC_MSG_WARN([NetCDF C++ header not found])
- HAVE_NETCDF=no
- fi
- if test "x$NETCDF_DEF" != "x"; then
- CPPFLAGS="$CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
- CXXFLAGS="$CXXFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
- fi
- AC_MSG_CHECKING([[for netcdf_c++ library]])
- LIBS="$LIBS -lnetcdf_c++ -lnetcdf"
- AC_TRY_LINK(
- [#include <netcdf.hh>], [NcFile ncf("foo",NcFile::ReadOnly);],
- [AC_MSG_RESULT([yes])],
- [AC_MSG_RESULT([no]);
- AC_MSG_ERROR([NetCDF C++ API not found])
- HAVE_NETCDF=no] )
- AC_LANG_RESTORE
- CPPFLAGS="$old_CPPFLAGS"
- CXXFLAGS="$old_CXXFLAGS"
- DEFINES="$DEFINES '-DSTRSTREAM_H_SPEC=$NETCDF_DEF'"
- fi
- if test "x$HAVE_NETCDF" = "xno"; then
- AC_MSG_WARN("NetCDF support disabled")
- LIBS="$old_LIBS"
- fi
-fi
-]) # SNL_HAVE_NETCDF
-# Check for Boost libraryies
-# Sets HAVE_BOOST to 'yes' or 'no' and adds any user-specified path to INCLUDES
-# Unless user specified --without-boost, will check for any passed headers.
-# For any found headers, -DHAVE_[header] will be added to DEFINES
-AC_DEFUN([SNL_CHECK_BOOST],[
-AC_MSG_CHECKING([if boost library is enabled])
-SNL_BOOST_OPT_HEADER_LIST="$1"
-AC_ARG_WITH(boost,
-[AC_HELP_STRING([--with-boost=DIR], [Specify directory where boost is installed])
-AC_HELP_STRING([--without-boost], [Disable support for boost libraries])],
-[BOOST_ARG=$withval
-DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-boost=\"${withval}\""
-, [BOOST_ARG=yes])
-if test "xno" = "x$BOOST_ARG"; then
-else
- # If user-specified directory, add to includes
- if test "xyes" != "x$BOOST_ARG"; then
- INCLUDES="$INCLUDES -I$BOOST_ARG"
- fi
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- AC_CHECK_HEADERS( [$SNL_BOOST_OPT_HEADER_LIST],[def=`echo "$ac_header" | $as_tr_cpp`; DEFINES="$DEFINES -DHAVE_$def"] )
- AC_LANG_RESTORE
-fi
-]) # SNL_CHECK_BOOST
-# Macro to set the following variables:
-# ACIS_VERSION
-# ACIS_LIB_DIR
-# ACIS_DEBUG_LIB_DIR
-# ACIS_PLATFORM
-# This macro expects ACIS_DIR to be set.
-# If ACIS_SYSTEM is set, ACIS_LIB_DIR will
-# be constructed using that value rather than
-# via a trial-and-error search.
-# If ACIS_VERSION is set, the corresponding test
-# will be skipped.
-AC_DEFUN([SNL_ACIS_ENV], [
-AC_CHECK_FILE([$ACIS_DIR/include/acis.hxx], [], [AC_MSG_ERROR("Invalid ACIS path")])
-if test "x" = "x$ACIS_SYSTEM"; then
- dir_list="$ACIS_DIR/bin/*"
-else
- dir_list="$ACIS_DIR/bin/$ACIS_SYSTEM"
-fi
-for dir in $dir_list; do
- # first try non-debug libraries
- case "$dir" in
- *_debug)
- if ! test "$ACIS_VERSION" -gt "600"; then
- SNL_ACIS_VERSION( [$dir] )
- ACIS_LIB_DIR="$dir"
- fi
- esac
- # next try debug libraries
- case "$dir" in
- *_debug)
- ACIS_DEBUG_LIB_DIR="$dir"
- fi
- esac
-done
-if ! test "$ACIS_VERSION" -gt "600"; then
- AC_MSG_ERROR([ACIS configuration failed. Verify ACIS directory. Try specifying ACIS system and version])
-fi
-# If either ACIS_LIB_DIR or ACIS_DEBUG_LIB_DIR is not defined,
-# make both the same
-if test "x" = "x$ACIS_LIB_DIR"; then
- ACIS_LIB_DIR="$ACIS_DEBUG_LIB_DIR"
-elif test "x" = "x$ACIS_DEBUG_LIB_DIR"; then
- ACIS_DEBUG_LIB_DIR="$ACIS_LIB_DIR"
-fi
-# Determine the ACIS platform name from the lib dir
-AC_MSG_CHECKING([ACIS platform name])
-case "$ACIS_LIB_DIR" in
- $ACIS_DIR/bin/aix*)
- ACIS_PLATFORM=aix
- $ACIS_DIR/bin/hp700*)
- ACIS_PLATFORM=hp700
- $ACIS_DIR/bin/linux*)
- ACIS_PLATFORM=linux
- $ACIS_DIR/bin/mac*)
- ACIS_PLATFORM=mac
- $ACIS_DIR/bin/osf1*)
- ACIS_PLATFORM=osf1
- $ACIS_DIR/bin/sgi*)
- ACIS_PLATFORM=sgi
- $ACIS_DIR/bin/solaris*)
- ACIS_PLATFORM=solaris
- AC_MSG_ERROR([Cannot determine ACIS platform name.])
-esac
-AC_MSG_RESULT([$ACIS_PLATFORM])
-# Macro to check for ACIS translators.
-AC_DEFUN([SNL_ACIS_TRANSLATOR], [
-AC_REQUIRE([SNL_ACIS_ENV])
-case "$ACIS_VERSION" in
- 11??)
- ACIS_XLATE_LIBS='-lxacis2k -lxcore2k -lxutil'
- 1[23]??)
- ACIS_XLATE_LIBS='-lSPAXAssemblyRep -lSPAXInterop -lSPAXBase -lxacis2k -lxcore2k -lxutil'
- 14??)
- ACIS_XLATE_LIBS='-lSPAXAssemblyRep -lSPAXInterop -lSPAXAcisBase -lSPAXDefaultGeometryRep -lSPAXGeometryRepresentation -lSPAXPropertiesBRepImporter -lSPAXPropertiesBase -lSPAXBase -lxacis2k -lxcore2k'
- ACIS_XLATE_LIBS='-lSPAXEBOMBase -lSPAXEBOMNewAssemblyExporter -lSPAXEBOMNewAssemblyImporter -lSPAXXMLTk -lpthread -lSPAXPropertiesNewAssemblyImporter -lSPAXAssemblyRep -lSPAXInterop -lSPAXAcisBase -lSPAXDefaultGeometryRep -lSPAXGeometryRepresentation -lSPAXPropertiesBRepImporter -lSPAXPropertiesBase -lSPAXBase -lxacis2k -lxcore2k'
-esac
-old_LIBS="$LIBS"
-LIBS="$LIBS -L$ACIS_LIB_DIR $ACIS_XLATE_LIBS $ACIS_BASE_LIBS"
-AC_CHECK_LIB([xstep],[main],[ACIS_STEP_TRANSLATOR=-DACIS_STEP_TRANSLATOR])
-AC_CHECK_LIB([xiges],[main],[ACIS_IGES_TRANSLATOR=-DACIS_IGES_TRANSLATOR])
-LIBS="$old_LIBS"
-# **************************** INTERNAL STUFF ***********************************
-# Check if the compiler defines a specific preprocessor macro
-# Arguments:
-# - preprocessor define to check for
-# - action upon success
-# - action upon failure
-AC_DEFUN([SNL_TRY_COMPILER_DEFINE], [
-AC_COMPILE_IFELSE([
-AC_LANG_PROGRAM( [[#ifndef $1
- choke me
-#endif]], []) ],
-[$2],[$3])
-# Check for compiler-specific flags.
-# Sets the following environmental variables:
-# SNL_CXX_SPECIAL : Any compiler-specific flags which must be specified
-# SNL_CXX_32BIT : Flag to force compilation of 32-bit code
-# SNL_CXX_64BIT : Flag to force compilation of 64-bit code
-AC_DEFUN([SNL_CXX_FLAGS], [
-AC_REQUIRE([AC_PROG_CXX])
-# Detect compiler
-AC_MSG_CHECKING([for known c++ compilers])
-# Autoconf does G++ for us
-if test x$GXX = xyes; then
- cxx_compiler=GNU
-# Search for other compiler types
-# For efficiency, limit checks to relevant OSs
-else
- cxx_compiler=unknown
- AC_LANG_SAVE
- AC_LANG_CPLUSPLUS
- case "$target_os" in
- aix*)
- SNL_TRY_COMPILER_DEFINE([__IBMCPP__],[cxx_compiler=VisualAge])
- solaris*|sunos*)
- SNL_TRY_COMPILER_DEFINE([__SUNPRO_CC],[cxx_compiler=SunWorkshop])
- irix*)
- SNL_TRY_COMPILER_DEFINE([__sgi],[cxx_compiler=MIPSpro])
- linux*)
- SNL_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cxx_compiler=Intel])
- SNL_TRY_COMPILER_DEFINE([__DECCXX_VER],[cxx_compiler=Compaq])
- SNL_TRY_COMPILER_DEFINE([__PGI],[cxx_cmopiler=PortlandGroup])
- hpux*)
- SNL_TRY_COMPILER_DEFINE([__HP_aCC],[cxx_compiler=HP])
- windows*)
- SNL_TRY_COMPILER_DEFINE([__MSC_VER],[cxx_compiler=VisualStudio])
- SNL_TRY_COMPILER_DEFINE([__BORLANDC__],[cxx_compiler=Borland])
- SNL_TRY_COMPILER_DEFINE([__CYGWIN__],[cxx_compiler=Cygwin])
- SNL_TRY_COMPILER_DEFINE([__MINGW32__],[cxx_compiler=MinGW])
- SNL_TRY_COMPILER_DEFINE([__PGI],[cc_cmopiler=PortlandGroup])
- esac
- AC_LANG_RESTORE
-fi
-AC_MSG_RESULT([$cxx_compiler])
-if test "x$cxx_compiler" = "xunknown"; then
- AC_MSG_WARN([Unrecognized C++ compiler: $CXX])
-fi
-# Now decide special compiler flags using compiler/cpu combination
-AC_MSG_CHECKING([for known compiler/OS combinations])
-case "$cxx_compiler:$host_cpu" in
- GNU:sparc*)
- SNL_CXX_32BIT=-m32
- SNL_CXX_64BIT=-m64
- SNL_CXX_SPECIAL="-Wall -pipe"
- GNU:powerpc*)
- GNU:i?86|GNU:x86_64)
- GNU:mips*)
- SNL_CXX_32BIT="-mips32 -mabi=32"
- SNL_CXX_64BIT="-mips64 -mabi=64"
- VisualAge:*)
- SNL_CXX_32BIT=-q32
- SNL_CXX_64BIT=-q64
- # Do V5.0 namemangling for compatibility with ACIS, and enable RTTI
- SNL_CXX_SPECIAL="-qrtti=all -qnamemangling=v5"
- AR="ar -X 32_64"
- NM="nm -B -X 32_64"
- MIPSpro:mips)
- SNL_CXX_32BIT=-n32
- SNL_CXX_64BIT=-64
- SNL_CXX_SPECIAL=-LANG:std
- MIPSpro:*)
- SunWorkshop:sparc*)
- SNL_CXX_32BIT=-xarch=generic
- SNL_CXX_64BIT=-xarch=generic64
- SunWorkshop:i?86|SunWorkshop:x86_64)
-esac
-AC_MSG_RESULT([$cxx_compiler:$host_cpu])
-]) # end SNL_CXX_FLAGS
-# SNL_CC_SPECIAL : Any compiler-specific flags which must be specified
-# SNL_CC_32BIT : Flag to force compilation of 32-bit code
-# SNL_CC_64BIT : Flag to force compilation of 64-bit code
-AC_DEFUN([SNL_CC_FLAGS], [
-AC_REQUIRE([AC_PROG_CC])
-# Detect compiler
-AC_MSG_CHECKING([for known C compilers])
-# Autoconf does gcc for us
-if test x$GCC = xyes; then
- cc_compiler=GNU
-else
- cc_compiler=unknown
- aix*)
- SNL_TRY_COMPILER_DEFINE([__IBMC__],[cc_compiler=VisualAge])
- solaris*|sunos*)
- SNL_TRY_COMPILER_DEFINE([__SUNPRO_C],[cc_compiler=SunWorkshop])
- irix*)
- SNL_TRY_COMPILER_DEFINE([__sgi],[cc_compiler=MIPSpro])
- linux*)
- SNL_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cc_compiler=Intel])
- SNL_TRY_COMPILER_DEFINE([__DECC_VER],[cc_compiler=Compaq])
- hpux*)
- SNL_TRY_COMPILER_DEFINE([__HP_cc],[cc_compiler=HP])
- windows*)
- SNL_TRY_COMPILER_DEFINE([__MSC_VER],[cc_compiler=VisualStudio])
- SNL_TRY_COMPILER_DEFINE([__BORLANDC__],[cc_compiler=Borland])
- SNL_TRY_COMPILER_DEFINE([__TURBOC__],[cc_compiler=TurboC])
- SNL_TRY_COMPILER_DEFINE([__CYGWIN__],[cc_compiler=Cygwin])
- SNL_TRY_COMPILER_DEFINE([__MINGW32__],[cc_compiler=MinGW])
- esac
-fi
-AC_MSG_RESULT([$cc_compiler])
-if test "x$cc_compiler" = "xunknown"; then
- AC_MSG_WARN([Unrecognized C compiler: $CXX])
-fi
-case "$cc_compiler:$host_cpu" in
- GNU:sparc*)
- SNL_CC_32BIT=-m32
- SNL_CC_64BIT=-m64
- SNL_CC_SPECIAL="-Wall -pipe"
- GNU:powerpc*)
- SNL_CC_32BIT=-m32
- SNL_CC_64BIT=-m64
- SNL_CC_32BIT=-m32
- SNL_CC_64BIT=-m64
- GNU:mips*)
- SNL_CC_32BIT="-mips32 -mabi=32"
- SNL_CC_64BIT="-mips64 -mabi=64"
- VisualAge:*)
- SNL_CC_32BIT=-q32
- SNL_CC_64BIT=-q64
- AR="ar -X 32_64"
- MIPSpro:mips)
- SNL_CC_32BIT=-n32
- SNL_CC_64BIT=-64
- SNL_CC_SPECIAL=-LANG:std
- MIPSpro:*)
- SNL_CC_32BIT=-xarch=generic
- SNL_CC_64BIT=-xarch=generic64
- SNL_CC_32BIT=-m32
- SNL_CC_64BIT=-m64
-esac
-AC_MSG_RESULT([$cc_compiler:$host_cpu])
-]) # end SNL_CC_FLAGS
-# Macro to get ACIS_VERSION
-# Expected arguments: ACIS library path
-AC_DEFUN([SNL_ACIS_VERSION], [
-AC_REQUIRE([AC_PROG_LIBTOOL])
-AC_LANG_SAVE
-AC_LANG_CPLUSPLUS
-AC_MSG_CHECKING([ACIS version of $1])
-src=conftest.cc
-exe=conftest
-cat <<END_SNL_ACIS_VERSION_SRC >$src
-#include <stdio.h>
-int get_major_version();
-int get_minor_version();
-int get_point_version();
-int main(int,char**) { printf("%d\n",
-100*get_major_version() +
- 10*get_minor_version() +
- get_point_version());
-return 0;}
-END_SNL_ACIS_VERSION_SRC
-FLAGS="$CXXFLAGS $LDFLAGS -L$1 -R$1"
-if ./libtool --mode=link $CXX $FLAGS $src -lSpaBase -o $exe >/dev/null 2>/dev/null; then
- ACIS_VERSION=`./$exe || echo 0`
- AC_MSG_RESULT($ACIS_VERSION)
-else
- ACIS_VERSION=0
- AC_MSG_RESULT(failed)
-fi
-#rm -f $src $exe
-AC_LANG_RESTORE
-]) # SNL_ACIS_VERSION
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2008-10-20 20:00:22 UTC (rev 2158)
+++ cgm/trunk/configure.in 2008-10-20 20:01:05 UTC (rev 2159)
@@ -6,6 +6,7 @@
AM_INIT_AUTOMAKE(CGMA,10.2.2)
AC_DISABLE_SHARED
+EXTRA_GNU_FLAGS="-Wall -pipe"
SNL_CHECK_COMPILERS
AC_PROG_FC
AM_CONDITIONAL(build_parallel, [test "x$WITH_MPI" != "xno"])
Added: cgm/trunk/m4/acis.m4
--- cgm/trunk/m4/acis.m4 (rev 0)
+++ cgm/trunk/m4/acis.m4 2008-10-20 20:01:05 UTC (rev 2159)
@@ -0,0 +1,161 @@
+# Macro to set the following variables:
+# ACIS_VERSION
+# ACIS_LIB_DIR
+# ACIS_DEBUG_LIB_DIR
+# ACIS_PLATFORM
+# This macro expects ACIS_DIR to be set.
+# If ACIS_SYSTEM is set, ACIS_LIB_DIR will
+# be constructed using that value rather than
+# via a trial-and-error search.
+# If ACIS_VERSION is set, the corresponding test
+# will be skipped.
+AC_DEFUN([SNL_ACIS_ENV], [
+AC_CHECK_FILE([$ACIS_DIR/include/acis.hxx], [], [AC_MSG_ERROR("Invalid ACIS path")])
+if test "x" = "x$ACIS_SYSTEM"; then
+ dir_list="$ACIS_DIR/bin/*"
+else
+ dir_list="$ACIS_DIR/bin/$ACIS_SYSTEM"
+fi
+for dir in $dir_list; do
+ # first try non-debug libraries
+ case "$dir" in
+ *_debug)
+ if ! test "$ACIS_VERSION" -gt "600"; then
+ SNL_ACIS_VERSION( [$dir] )
+ ACIS_LIB_DIR="$dir"
+ fi
+ esac
+ # next try debug libraries
+ case "$dir" in
+ *_debug)
+ ACIS_DEBUG_LIB_DIR="$dir"
+ fi
+ esac
+done
+if ! test "$ACIS_VERSION" -gt "600"; then
+ AC_MSG_ERROR([ACIS configuration failed. Verify ACIS directory. Try specifying ACIS system and version])
+fi
+# If either ACIS_LIB_DIR or ACIS_DEBUG_LIB_DIR is not defined,
+# make both the same
+if test "x" = "x$ACIS_LIB_DIR"; then
+ ACIS_LIB_DIR="$ACIS_DEBUG_LIB_DIR"
+elif test "x" = "x$ACIS_DEBUG_LIB_DIR"; then
+ ACIS_DEBUG_LIB_DIR="$ACIS_LIB_DIR"
+fi
+# Determine the ACIS platform name from the lib dir
+AC_MSG_CHECKING([ACIS platform name])
+case "$ACIS_LIB_DIR" in
+ $ACIS_DIR/bin/aix*)
+ ACIS_PLATFORM=aix
+ $ACIS_DIR/bin/hp700*)
+ ACIS_PLATFORM=hp700
+ $ACIS_DIR/bin/linux*)
+ ACIS_PLATFORM=linux
+ $ACIS_DIR/bin/mac*)
+ ACIS_PLATFORM=mac
+ $ACIS_DIR/bin/osf1*)
+ ACIS_PLATFORM=osf1
+ $ACIS_DIR/bin/sgi*)
+ ACIS_PLATFORM=sgi
+ $ACIS_DIR/bin/solaris*)
+ ACIS_PLATFORM=solaris
+ AC_MSG_ERROR([Cannot determine ACIS platform name.])
+esac
+AC_MSG_RESULT([$ACIS_PLATFORM])
+# Macro to check for ACIS translators.
+AC_DEFUN([SNL_ACIS_TRANSLATOR], [
+AC_REQUIRE([SNL_ACIS_ENV])
+case "$ACIS_VERSION" in
+ 11??)
+ ACIS_XLATE_LIBS='-lxacis2k -lxcore2k -lxutil'
+ 1[23]??)
+ ACIS_XLATE_LIBS='-lSPAXAssemblyRep -lSPAXInterop -lSPAXBase -lxacis2k -lxcore2k -lxutil'
+ 14??)
+ ACIS_XLATE_LIBS='-lSPAXAssemblyRep -lSPAXInterop -lSPAXAcisBase -lSPAXDefaultGeometryRep -lSPAXGeometryRepresentation -lSPAXPropertiesBRepImporter -lSPAXPropertiesBase -lSPAXBase -lxacis2k -lxcore2k'
+ ACIS_XLATE_LIBS='-lSPAXEBOMBase -lSPAXEBOMNewAssemblyExporter -lSPAXEBOMNewAssemblyImporter -lSPAXXMLTk -lpthread -lSPAXPropertiesNewAssemblyImporter -lSPAXAssemblyRep -lSPAXInterop -lSPAXAcisBase -lSPAXDefaultGeometryRep -lSPAXGeometryRepresentation -lSPAXPropertiesBRepImporter -lSPAXPropertiesBase -lSPAXBase -lxacis2k -lxcore2k'
+esac
+old_LIBS="$LIBS"
+LIBS="$LIBS -L$ACIS_LIB_DIR $ACIS_XLATE_LIBS $ACIS_BASE_LIBS"
+AC_CHECK_LIB([xstep],[main],[ACIS_STEP_TRANSLATOR=-DACIS_STEP_TRANSLATOR])
+AC_CHECK_LIB([xiges],[main],[ACIS_IGES_TRANSLATOR=-DACIS_IGES_TRANSLATOR])
+LIBS="$old_LIBS"
+# **************************** INTERNAL STUFF ***********************************
+# Macro to get ACIS_VERSION
+# Expected arguments: ACIS library path
+AC_DEFUN([SNL_ACIS_VERSION], [
+AC_REQUIRE([AC_PROG_LIBTOOL])
+AC_LANG_SAVE
+AC_LANG_CPLUSPLUS
+AC_MSG_CHECKING([ACIS version of $1])
+src=conftest.cc
+exe=conftest
+cat <<END_SNL_ACIS_VERSION_SRC >$src
+#include <stdio.h>
+int get_major_version();
+int get_minor_version();
+int get_point_version();
+int main(int,char**) { printf("%d\n",
+100*get_major_version() +
+ 10*get_minor_version() +
+ get_point_version());
+return 0;}
+END_SNL_ACIS_VERSION_SRC
+FLAGS="$CXXFLAGS $LDFLAGS -L$1 -R$1"
+if ./libtool --mode=link $CXX $FLAGS $src -lSpaBase -o $exe >/dev/null 2>/dev/null; then
+ ACIS_VERSION=`./$exe || echo 0`
+ AC_MSG_RESULT($ACIS_VERSION)
+else
+ ACIS_VERSION=0
+ AC_MSG_RESULT(failed)
+fi
+#rm -f $src $exe
+AC_LANG_RESTORE
+]) # SNL_ACIS_VERSION
Added: cgm/trunk/m4/boost.m4
--- cgm/trunk/m4/boost.m4 (rev 0)
+++ cgm/trunk/m4/boost.m4 2008-10-20 20:01:05 UTC (rev 2159)
@@ -0,0 +1,30 @@
+# Check for Boost libraryies
+# Sets HAVE_BOOST to 'yes' or 'no' and adds any user-specified path to INCLUDES
+# Unless user specified --without-boost, will check for any passed headers.
+# For any found headers, -DHAVE_[header] will be added to DEFINES
+AC_DEFUN([SNL_CHECK_BOOST],[
+AC_MSG_CHECKING([if boost library is enabled])
+SNL_BOOST_OPT_HEADER_LIST="$1"
+AC_ARG_WITH(boost,
+[AC_HELP_STRING([--with-boost=DIR], [Specify directory where boost is installed])
+AC_HELP_STRING([--without-boost], [Disable support for boost libraries])],
+[BOOST_ARG=$withval
+DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-boost=\"${withval}\""
+, [BOOST_ARG=yes])
+if test "xno" = "x$BOOST_ARG"; then
+ AC_MSG_RESULT([no])
+else
+ AC_MSG_RESULT([yes])
+ # If user-specified directory, add to includes
+ if test "xyes" != "x$BOOST_ARG"; then
+ INCLUDES="$INCLUDES -I$BOOST_ARG"
+ fi
+ AC_LANG_SAVE
+ AC_LANG_CPLUSPLUS
+ AC_CHECK_HEADERS( [$SNL_BOOST_OPT_HEADER_LIST],[def=`echo "$ac_header" | $as_tr_cpp`; DEFINES="$DEFINES -DHAVE_$def"] )
+ AC_LANG_RESTORE
+fi
+]) # SNL_CHECK_BOOST
Added: cgm/trunk/m4/compiler.m4
--- cgm/trunk/m4/compiler.m4 (rev 0)
+++ cgm/trunk/m4/compiler.m4 2008-10-20 20:01:05 UTC (rev 2159)
@@ -0,0 +1,463 @@
+# Get libtool configuration variable
+# Arguments:
+# libtool config tag (e.g CXX)
+# libtool variable name
+# variable in which to store result
+AC_DEFUN([ITAPS_LIBTOOL_VAR], [
+ $3=`./libtool --tag=$1 --config | sed -e 's/^$2=//p' -e 'd' | tr -d '"\n'`
+# Implement checks for C and C++ compilers, with all corresponding options
+# Sets the following variables:
+# CPP - The C preprocessor
+# CC - The C compiler
+# CXX - The C++ compiler
+# CFLAGS - C compiler flags
+# CXXFLAGS - C++ compiler flags
+# WITH_MPI - 'yes' if parallel support, 'no' otherwise
+AC_DEFUN([SNL_CHECK_COMPILERS], [
+ # Save these before calling AC_PROG_CC or AC_PROG_CXX
+ # because those macros will modify them, and we want
+ # the original user values, not the autoconf defaults.
+USER_CXXFLAGS="$CXXFLAGS"
+USER_CFLAGS="$CFLAGS"
+ # Check for Parallel
+ # Need to check this early so we can look for the correct compiler
+AC_ARG_WITH( [mpi], AC_HELP_STRING([[--with-mpi(=DIR)]], [Enable parallel support]),
+ [WITH_MPI=$withval],[WITH_MPI=no] )
+case "x$WITH_MPI" in
+ xno)
+ CC_LIST="cc gcc cl egcs pgcc"
+ CXX_LIST="CC aCC cxx xlC_r xlC c++ g++ pgCC gpp cc++ cl FCC KCC RCC"
+ FC_LIST="gfortran ifort pgf90"
+ F77_LIST="gfortran ifort pgf77"
+ xyes)
+ CC_LIST="mpicc mpcc"
+ CXX_LIST="mpiCC mpCC mpicxx"
+ FC_LIST="mpif90"
+ F77_LIST="mpif77"
+ x*)
+ if test -z "$CC";then
+ for prog in mpicc mpcc; do
+ if test -x ${WITH_MPI}/bin/$prog; then
+ CC="${WITH_MPI}/bin/$prog"
+ CC_LIST="$prog"
+ fi
+ done
+ else
+ CC_LIST="$CC"
+ fi
+ if test -z "$CXX";then
+ for prog in mpicxx mpiCC mpCC mpicxx; do
+ CXX="${WITH_MPI}/bin/$prog"
+ CXX_LIST="$prog"
+ fi
+ done
+ else
+ CXX_LIST="$CXX"
+ fi
+ if test -z "$FC";then
+ for prog in mpif90; do
+ FC="${WITH_MPI}/bin/$prog"
+ FC_LIST="$prog"
+ fi
+ done
+ else
+ FC_LIST="$FC"
+ fi
+ if test -z "$F77";then
+ for prog in mpif77; do
+ F77="${WITH_MPI}/bin/$prog"
+ F77_LIST="$prog"
+ fi
+ done
+ else
+ F77_LIST="$F77"
+ fi
+ WITH_MPI=yes
+esac
+AC_PROG_CC( [$CC_LIST] )
+AC_PROG_CPP
+AC_PROG_CXX( [$CXX_LIST] )
+AC_PROG_CXXCPP
+AC_PROG_FC( [$FC_LIST] )
+AC_PROG_F77( [$F77_LIST] )
+# Try to determine compiler-specific flags. This must be done
+# before setting up libtool so that it can override libtool settings.
+SNL_CC_FLAGS
+SNL_CXX_FLAGS
+CFLAGS="$USER_CFLAGS $SNL_CC_SPECIAL"
+CXXFLAGS="$USER_CXXFLAGS $SNL_CXX_SPECIAL"
+# On IBM/AIX, the check for OBJEXT fails for the mpcc compiler.
+# (Comment out this hack, it should be fixed correctly now)
+#if test "x$OBJEXT" = "x"; then
+# OBJEXT=o
+#fi
+ # Check for debug flags
+AC_ARG_ENABLE( debug, AC_HELP_STRING([--enable-debug],[Debug symbols (-g)]),
+ [enable_debug=$enableval], [enable_debug=] )
+AC_ARG_ENABLE( optimize, AC_HELP_STRING([--enable-optimize],[Compile optimized (-O2)]),
+ [enable_cxx_optimize=$enableval
+ enable_cc_optimize=$enableval
+ enable_fc_optimize=$enableval
+# Do enable_optimize by default, unless user has specified
+# custom CXXFLAGS or CFLAGS
+if test "x$enable_debug" = "x"; then
+ if test "x$enable_cxx_optimize" = "x"; then
+ if test "x$USER_CXXFLAGS" = "x"; then
+ enable_cxx_optimize=yes
+ fi
+ fi
+ if test "x$enable_cc_optimize" = "x"; then
+ if test "x$USER_CFLAGS" = "x"; then
+ enable_cc_optimize=yes
+ fi
+ fi
+ if test "x$enable_fc_optimize" = "x"; then
+ if test "x$USER_FCFLAGS" = "x"; then
+ enable_fc_optimize=yes
+ fi
+ fi
+fi
+# Choose compiler flags from CLI args
+if test "xyes" = "x$enable_debug"; then
+ CXXFLAGS="$CXXFLAGS -g"
+ CFLAGS="$CFLAGS -g"
+ FCFLAGS="$FCFLAGS -g"
+fi
+if test "xyes" = "x$enable_cxx_optimize"; then
+ CXXFLAGS="$CXXFLAGS -O2 -DNDEBUG"
+fi
+if test "xyes" = "x$enable_cc_optimize"; then
+ CFLAGS="$CFLAGS -O2 -DNDEBUG"
+fi
+if test "xyes" = "x$enable_fc_optimize"; then
+ FCFLAGS="$FCFLAGS -O2 -DNDEBUG"
+fi
+ # Check for 32/64 bit.
+ # This requires SNL_CXX_FLAGS and SNL_CC_FLAGS to have been called first
+AC_ARG_ENABLE( 32bit, AC_HELP_STRING([--enable-32bit],[Force 32-bit objects]),
+ if test "xyes" != "x$enableval"; then
+ AC_MSG_ERROR([Unknown argument --enable-32bit=$enableval])
+ elif test "x" = "x$SNL_CXX_32BIT"; then
+ AC_MSG_ERROR([Don't know how to force 32-bit C++ on this platform. Try setting CXXFLAGS manually])
+ elif test "x" = "x$SNL_CC_32BIT"; then
+ AC_MSG_ERROR([Don't know how to force 32-bit C on this platform. Try setting CFLAGS manually])
+ fi
+ CXXFLAGS="$CXXFLAGS $SNL_CXX_32BIT"
+ CFLAGS="$CFLAGS $SNL_CC_32BIT"
+ enable_32bit=yes
+# This requires SNL_CXX_FLAGS and SNL_CC_FLAGS to have been called first
+AC_ARG_ENABLE( 64bit, AC_HELP_STRING([--enable-64bit],[Force 64-bit objects]),
+ AC_MSG_ERROR([Unknown argument --enable-64bit=$enableval])
+ elif test "x" = "x$SNL_CXX_64BIT"; then
+ AC_MSG_ERROR([Don't know how to force 64-bit C++ on this platform. Try setting CXXFLAGS manually])
+ elif test "x" = "x$SNL_CC_64BIT"; then
+ AC_MSG_ERROR([Don't know how to force 64-bit C on this platform. Try setting CFLAGS manually])
+ elif test "xyes" = "x$enable_32bit"; then
+ AC_MSG_ERROR([Cannot do both --enable-32bit and --enable-64bit])
+ fi
+ CXXFLAGS="$CXXFLAGS $SNL_CXX_64BIT"
+ CFLAGS="$CFLAGS $SNL_CC_64BIT"
+]) # SNL_CHECK_COMPILERS
+# Check if the compiler defines a specific preprocessor macro
+# Arguments:
+# - preprocessor define to check for
+# - action upon success
+# - action upon failure
+AC_DEFUN([SNL_TRY_COMPILER_DEFINE], [
+AC_COMPILE_IFELSE([
+AC_LANG_PROGRAM( [[#ifndef $1
+ choke me
+#endif]], []) ],
+[$2],[$3])
+# Check for compiler-specific flags.
+# Sets the following environmental variables:
+# SNL_CXX_SPECIAL : Any compiler-specific flags which must be specified
+# SNL_CXX_32BIT : Flag to force compilation of 32-bit code
+# SNL_CXX_64BIT : Flag to force compilation of 64-bit code
+AC_DEFUN([SNL_CXX_FLAGS], [
+AC_REQUIRE([AC_PROG_CXX])
+# Detect compiler
+AC_MSG_CHECKING([for known c++ compilers])
+# Autoconf does G++ for us
+if test x$GXX = xyes; then
+ cxx_compiler=GNU
+# Search for other compiler types
+# For efficiency, limit checks to relevant OSs
+else
+ cxx_compiler=unknown
+ AC_LANG_SAVE
+ AC_LANG_CPLUSPLUS
+ case "$target_os" in
+ aix*)
+ SNL_TRY_COMPILER_DEFINE([__IBMCPP__],[cxx_compiler=VisualAge])
+ solaris*|sunos*)
+ SNL_TRY_COMPILER_DEFINE([__SUNPRO_CC],[cxx_compiler=SunWorkshop])
+ irix*)
+ SNL_TRY_COMPILER_DEFINE([__sgi],[cxx_compiler=MIPSpro])
+ linux*)
+ SNL_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cxx_compiler=Intel])
+ SNL_TRY_COMPILER_DEFINE([__DECCXX_VER],[cxx_compiler=Compaq])
+ SNL_TRY_COMPILER_DEFINE([__PGI],[cxx_cmopiler=PortlandGroup])
+ hpux*)
+ SNL_TRY_COMPILER_DEFINE([__HP_aCC],[cxx_compiler=HP])
+ windows*)
+ SNL_TRY_COMPILER_DEFINE([__MSC_VER],[cxx_compiler=VisualStudio])
+ SNL_TRY_COMPILER_DEFINE([__BORLANDC__],[cxx_compiler=Borland])
+ SNL_TRY_COMPILER_DEFINE([__CYGWIN__],[cxx_compiler=Cygwin])
+ SNL_TRY_COMPILER_DEFINE([__MINGW32__],[cxx_compiler=MinGW])
+ SNL_TRY_COMPILER_DEFINE([__PGI],[cc_cmopiler=PortlandGroup])
+ esac
+ AC_LANG_RESTORE
+fi
+AC_MSG_RESULT([$cxx_compiler])
+if test "x$cxx_compiler" = "xunknown"; then
+ AC_MSG_WARN([Unrecognized C++ compiler: $CXX])
+fi
+# Now decide special compiler flags using compiler/cpu combination
+AC_MSG_CHECKING([for known compiler/OS combinations])
+case "$cxx_compiler:$host_cpu" in
+ GNU:sparc*)
+ SNL_CXX_32BIT=-m32
+ SNL_CXX_64BIT=-m64
+ SNL_CXX_SPECIAL="$EXTRA_GNU_FLAGS"
+ GNU:powerpc*)
+ GNU:i?86|GNU:x86_64)
+ GNU:mips*)
+ SNL_CXX_32BIT="-mips32 -mabi=32"
+ SNL_CXX_64BIT="-mips64 -mabi=64"
+ GNU:*)
+ VisualAge:*)
+ SNL_CXX_32BIT=-q32
+ SNL_CXX_64BIT=-q64
+ # Do V5.0 namemangling for compatibility with ACIS, and enable RTTI
+ case "$target_vendor" in
+ bgp)
+ SNL_CXX_SPECIAL=""
+ AR="ar"
+ NM="nm -B"
+ SNL_CXX_SPECIAL="-qrtti=all -qnamemangling=v5"
+ AR="ar"
+ NM="nm -B -X 32_64"
+ esac
+ MIPSpro:mips)
+ SNL_CXX_32BIT=-n32
+ SNL_CXX_64BIT=-64
+ SNL_CXX_SPECIAL=-LANG:std
+ MIPSpro:*)
+ SunWorkshop:sparc*)
+ SNL_CXX_32BIT=-xarch=generic
+ SNL_CXX_64BIT=-xarch=generic64
+ SunWorkshop:i?86|SunWorkshop:x86_64)
+esac
+AC_MSG_RESULT([$cxx_compiler:$host_cpu])
+]) # end SNL_CXX_FLAGS
+# SNL_CC_SPECIAL : Any compiler-specific flags which must be specified
+# SNL_CC_32BIT : Flag to force compilation of 32-bit code
+# SNL_CC_64BIT : Flag to force compilation of 64-bit code
+AC_DEFUN([SNL_CC_FLAGS], [
+AC_REQUIRE([AC_PROG_CC])
+# Detect compiler
+AC_MSG_CHECKING([for known C compilers])
+# Autoconf does gcc for us
+if test x$GCC = xyes; then
+ cc_compiler=GNU
+else
+ cc_compiler=unknown
+ aix*)
+ SNL_TRY_COMPILER_DEFINE([__IBMC__],[cc_compiler=VisualAge])
+ solaris*|sunos*)
+ SNL_TRY_COMPILER_DEFINE([__SUNPRO_C],[cc_compiler=SunWorkshop])
+ irix*)
+ SNL_TRY_COMPILER_DEFINE([__sgi],[cc_compiler=MIPSpro])
+ linux*)
+ SNL_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cc_compiler=Intel])
+ SNL_TRY_COMPILER_DEFINE([__DECC_VER],[cc_compiler=Compaq])
+ hpux*)
+ SNL_TRY_COMPILER_DEFINE([__HP_cc],[cc_compiler=HP])
+ windows*)
+ SNL_TRY_COMPILER_DEFINE([__MSC_VER],[cc_compiler=VisualStudio])
+ SNL_TRY_COMPILER_DEFINE([__BORLANDC__],[cc_compiler=Borland])
+ SNL_TRY_COMPILER_DEFINE([__TURBOC__],[cc_compiler=TurboC])
+ SNL_TRY_COMPILER_DEFINE([__CYGWIN__],[cc_compiler=Cygwin])
+ SNL_TRY_COMPILER_DEFINE([__MINGW32__],[cc_compiler=MinGW])
+ esac
+fi
+AC_MSG_RESULT([$cc_compiler])
+if test "x$cc_compiler" = "xunknown"; then
+ AC_MSG_WARN([Unrecognized C compiler: $CXX])
+fi
+case "$cc_compiler:$host_cpu" in
+ GNU:sparc*)
+ SNL_CC_32BIT=-m32
+ SNL_CC_64BIT=-m64
+ SNL_CC_SPECIAL="$EXTRA_GNU_FLAGS"
+ GNU:powerpc*)
+ SNL_CC_32BIT=-m32
+ SNL_CC_64BIT=-m64
+ SNL_CC_32BIT=-m32
+ SNL_CC_64BIT=-m64
+ GNU:mips*)
+ SNL_CC_32BIT="-mips32 -mabi=32"
+ SNL_CC_64BIT="-mips64 -mabi=64"
+ GNU:*)
+ VisualAge:*)
+ bgp)
+ SNL_CC_32BIT=-q32
+ SNL_CC_64BIT=-q64
+ AR="ar"
+ NM="nm -B"
+ SNL_CC_32BIT=-q32
+ SNL_CC_64BIT=-q64
+ AR="ar -X 32_64"
+ esac
+ MIPSpro:mips)
+ SNL_CC_32BIT=-n32
+ SNL_CC_64BIT=-64
+ SNL_CC_SPECIAL=-LANG:std
+ MIPSpro:*)
+ SNL_CC_32BIT=-xarch=generic
+ SNL_CC_64BIT=-xarch=generic64
+ SNL_CC_32BIT=-m32
+ SNL_CC_64BIT=-m64
+esac
+AC_MSG_RESULT([$cc_compiler:$host_cpu])
+]) # end SNL_CC_FLAGS
Added: cgm/trunk/m4/cplusplus.m4
--- cgm/trunk/m4/cplusplus.m4 (rev 0)
+++ cgm/trunk/m4/cplusplus.m4 2008-10-20 20:01:05 UTC (rev 2159)
@@ -0,0 +1,97 @@
+# Check for existance of new no-file-extension C++ headers.
+# Conditinionally sets the following preprocessor macros:
+# CANT_USE_STD
+# - The new no-extension versions of the c++ headers do not
+# exist or do not define symbols to be in the "std" namespace.
+# For example: if this is defined #include <map.h> rather than <map>.
+# CANT_USE_STD_IO
+# - The new no-extension versions of the c++ IO headers do not
+# For example: if this is defined, #include <iostrea.h> rather than <iostream>
+AC_DEFUN([SNL_CANT_USE_STD], [
+AC_LANG_SAVE
+AC_LANG_CPLUSPLUS
+AC_MSG_CHECKING([for C++-standard header files])
+AC_TRY_COMPILE([#include <vector>
+ #include <string>
+ #include <map>
+ #include <algorithm>
+ [std::vector<std::string> v;
+ std::map<std::string,std::string> m;
+ [AC_MSG_RESULT(yes)],
+ [AC_MSG_RESULT(no); CANT_USE_STD=-DCANT_USE_STD])
+AC_MSG_CHECKING([for C++-standard I/O header files])
+AC_TRY_COMPILE([#include <iosfwd>
+ #include <iostream>
+ #include <ostream>
+ #include <sstream>
+ [std::cout << std::endl;],
+ [AC_MSG_RESULT(no); CANT_USE_STD_IO=-DCANT_USE_STD_IO])
+AC_LANG_RESTORE
+]) # SNL_CANT_USE_STD
+# Check if template definitions (.cpp files) must be
+# included (in the .hpp files).
+# Sets TEMPLATE_DEFS_INCLUDED=-DTEMPLATE_DEFS_INCLUDED
+AC_DEFUN([SNL_TEMPLATE_DEFS_INCLUDED], [
+AC_LANG_SAVE
+AC_LANG_CPLUSPLUS
+AC_MSG_CHECKING([if template definitions should be included])
+src=conftest.cc
+templ=conftemp.cc
+exe=conftest
+echo "template <typename T> class MyTempl { public: T get() const; };" >$templ
+echo "template <typename T> T MyTempl<T>::get() const { return 0; }" >>$templ
+echo "template <typename T> class MyTempl { public: T get() const; };" >$src
+echo "int main( ) { MyTempl<int> c; return c.get(); }" >>$src
+if $CXX $CXXFLAGS $LDFLAGS $src $templ -o $exe >/dev/null 2>/dev/null; then
+ TEMPLATE_DEFS_INCLUDED=
+ AC_MSG_RESULT(no)
+else
+ TEMPLATE_DEFS_INCLUDED=-DTEMPLATE_DEFS_INCLUDED
+ AC_MSG_RESULT(yes)
+fi
+rm -f $src $templ $exe
+AC_LANG_RESTORE
+]) # SNL_TEMPLATE_DEFS_INCLUDED
+# Check if compiler supports template class specialization.
+# Sets TEMPLATE_SPECIALIZATION=-DTEMPLATE_SPECIALIZATION
+AC_DEFUN([SNL_TEMPLATE_SPECIALIZATION], [
+AC_LANG_SAVE
+AC_LANG_CPLUSPLUS
+AC_MSG_CHECKING([if C++ compiler supports template specialization])
+AC_TRY_COMPILE([
+template <unsigned S> class MyTempl { public: char data[S]; };
+template <> class MyTempl<0> { public: char value; };
+MyTempl<1> one;
+MyTempl<0> zero;
+one.data[0] = zero.value = '\0';
+[TEMPLATE_SPECIALIZATION=-DTEMPLATE_SPECIALIZATION; AC_MSG_RESULT(yes)],
+[TEMPLATE_SPECIALIZATION=; AC_MSG_RESULT(no)])
+AC_LANG_RESTORE
Added: cgm/trunk/m4/hdf5.m4
--- cgm/trunk/m4/hdf5.m4 (rev 0)
+++ cgm/trunk/m4/hdf5.m4 2008-10-20 20:01:05 UTC (rev 2159)
@@ -0,0 +1,179 @@
+# Check for HDF5 library and related stuff
+# Sets HAVE_HDF5 to 'yes' or 'no'
+# If HAVE_HDF5 == yes, then sets:
+# HDF5_CPPFLAGS
+# HDF5_LDFLAGS
+# HDF5_LIBS
+AC_DEFUN([SNL_CHECK_HDF5],[
+ # CLI option for linking zlib
+AC_ARG_WITH(zlib,
+ [AC_HELP_STRING([--with-zlib=DIR],[HDF5 requires zlib, and zlib can be found at...])],
+ [WITH_ZLIB=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-zlib=\"${withval}\""
+ ],[WITH_ZLIB=])
+case "x$WITH_ZLIB" in
+ xyes|xno|x)
+ if ! test -d ${WITH_ZLIB}/lib; then
+ AC_MSG_ERROR([Not a directory: ${WITH_ZLIB}/lib])
+ fi
+ HDF5_LDFLAGS="$HDF5_LDFLAGS -L${WITH_ZLIB}/lib"
+esac
+HAVE_ZLIB=no
+if test "x$WITH_ZLIB" != "xno"; then
+ old_LDFLAGS="$LIBS"
+ LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
+ AC_CHECK_LIB([z],[deflate],[HAVE_ZLIB=yes],
+ [if test "x$WITH_ZLIB" != "x"; then AC_MSG_ERROR([Could not find zlib]); fi])
+ LDFLAGS="$old_LDFLAGS"
+fi
+ # CLI option for linking szip
+AC_ARG_WITH(szip,
+ [AC_HELP_STRING([--with-szip=DIR],[HDF5 requires szip, and szip an be found at...])],
+ [WITH_SZIP=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-szip=\"${withval}\""
+ ],[WITH_SZIP=])
+case "x$WITH_SZIP" in
+ xyes|xno|x)
+ if ! test -d ${WITH_SZIP}/lib; then
+ AC_MSG_ERROR([Not a directory: ${WITH_SZIP}/lib])
+ fi
+ HDF5_LDFLAGS="$HDF5_LDFLAGS -L${WITH_SZIP}/lib"
+esac
+HAVE_SZIP=no
+if test "x$WITH_SZIP" != "xno"; then
+ old_LDFLAGS="$LDFLAGS"
+ AC_CHECK_LIB([sz],[SZ_Decompress],[HAVE_SZIP=yes],
+ [if test "x$WITH_SZIP" != "x"; then AC_MSG_ERROR([Could not find libsz]); fi])
+fi
+ # CLI option for extra HDF5 link flags
+AC_ARG_WITH([--with-hdf5-ldflags],[AC_HELP_STRING([--with-hdf5-ldflags=...],
+ [Extra LDFLAGS required for HDF5 library (e.g. parallel IO lib)])],
+ [HDF5_LDFLAGS_WITHVAL="$withval";
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-hdf5-ldflags=\"${withval}\""
+],[HDF5_LDFLAGS_WITHVAL=])
+case "x$HDF5_LDFLAGS_WITHVAL" in
+ xno)
+ AC_MSG_ERROR("Invalid argument: --without-hdf5-ldflags")
+ xyes)
+ AC_MSG_ERROR("Nonsensical argument: --with-hdf5-ldflags without any specified flags")
+ HDF5_LDFLAGS="$HDF5_LDFLAGS $HDF5_LDFLAGS_WITHVAL"
+esac
+ # CLI option for HDF5
+AC_MSG_CHECKING([if HDF5 support is enabled])
+AC_ARG_WITH(hdf5,
+[AC_HELP_STRING([--with-hdf5=DIR], [Specify HDF5 library to use for native file format])
+AC_HELP_STRING([--without-hdf5], [Disable support for native HDF5 file format])],
+[HDF5_ARG=$withval
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-hdf5=\"${withval}\""
+], [HDF5_ARG=])
+if test "xno" = "x$HDF5_ARG"; then
+else
+fi
+ # if HDF5 support is not disabled, check to make sure we have HDF5
+HAVE_HDF5=no
+if test "xno" != "x$HDF5_ARG"; then
+ HAVE_HDF5=yes
+ # Check for IBM parallel IO library
+ if test "x$WITH_MPI" != "xno"; then
+ AC_CHECK_LIB([gpfs],[gpfs_stat],[HDF5_LIBS="-lgpfs $HDF5_LIBS"])
+ fi
+ # if a path is specified, update LIBS and INCLUDES accordingly
+ if test "xyes" != "x$HDF5_ARG" && test "x" != "x$HDF5_ARG"; then
+ if test -d "${HDF5_ARG}/lib"; then
+ HDF5_LDFLAGS="$HDF5_LDFLAGS -L${HDF5_ARG}/lib"
+ elif test -d "${HDF5_ARG}"; then
+ HDF5_LDFLAGS="$HDF5_LDFLAGS -L${HDF5_ARG}"
+ else
+ AC_MSG_ERROR("$HDF5_ARG is not a directory.")
+ fi
+ if test -d "${HDF5_ARG}/include"; then
+ HDF5_CPPFLAGS="$HDF5_CPPFLAGS -I${HDF5_ARG}/include"
+ if test "x$GXX" = "xyes"; then
+ HDF5_CPPFLAGS="$HDF5_CPPFLAGS -isystem ${HDF5_ARG}/include"
+ fi
+ else
+ HDF5_CPPFLAGS="$HDF5_CPPFLAGS -I${HDF5_ARG}"
+ fi
+ fi
+ # Add flag to defines
+ old_CPPFLAGS="$CPPFLAGS"
+ old_LIBS="$LIBS"
+ CPPFLAGS="$HDF5_CPPFLAGS $CPPFLAGS"
+ LDFLAGS="$HDF5_LDFLAGS $LDFLAGS"
+ LIBS="$HDF5_LIBS $LIBS"
+ # check for libraries and headers
+ AC_CHECK_HEADERS( [hdf5.h], [], [HAVE_HDF5=no] )
+ HAVE_LIB_HDF5=no
+ AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes] )
+ if test $HAVE_LIB_HDF5 = no; then
+ if test $HAVE_ZLIB = yes; then
+ unset ac_cv_lib_hdf5_H5Fopen
+ AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="-lz $HDF5_LIBS"], [], [-lz] )
+ fi
+ fi
+ if test $HAVE_SZIP = yes; then
+ AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="-lsz $HDF5_LIBS"], [], [-lsz] )
+ fi
+ fi
+ AC_CHECK_LIB( [hdf5], [H5Fopen], [HAVE_LIB_HDF5=yes; HDF5_LIBS="-lsz -lz $HDF5_LIBS"], [], [-lz -lsz] )
+ fi
+ fi
+ fi
+ if test "x$HAVE_LIB_HDF5" = "xno"; then
+ HAVE_HDF5=no
+ fi
+ if test "x$HAVE_HDF5" = "xno"; then
+ if test "x" = "x$HDF5_ARG"; then
+ AC_MSG_WARN([HDF5 library not found or not usable.])
+ else
+ AC_MSG_ERROR([HDF5 library not found or not usable.])
+ fi
+ HDF5_CPPFLAGS=
+ HDF5_LDFLAGS=
+ HDF5_LIBS=
+ else
+ HDF5_LIBS="$HDF5_LIBS -lhdf5"
+ fi
+ CPPFLAGS="$old_CPPFLAGS"
+ LIBS="$old_LIBS"
+fi
+]) # SNL_CHECK_HDF5
Added: cgm/trunk/m4/makevar.m4
--- cgm/trunk/m4/makevar.m4 (rev 0)
+++ cgm/trunk/m4/makevar.m4 2008-10-20 20:01:05 UTC (rev 2159)
@@ -0,0 +1,34 @@
+# Extract the value of a variable from a makefile fragment.
+# Arguments:
+# - The path of the makefile fragment
+# - The name of the makefile variable
+# - Action on success (the shell variable "make_val" will contain the value
+# of the variable)
+# - Action on failure
+AC_DEFUN([SNL_MAKE_INC_VAR], [
+make_val=
+snl_makefile="snl_check.mak"
+rm -f $snl_makefile
+if test ! -f $1 ; then
+ AC_MSG_WARN([File not found: $1])
+ $4
+else
+cat >$snl_makefile <<SNL_END_OF_MAKEFILE
+default:
+ @echo "\$($2)"
+include $1
+SNL_END_OF_MAKEFILE
+if make -f $snl_makefile > /dev/null 2>&1; then
+ make_val=`make -f $snl_makefile`
+ rm -f $snl_makefile
+ $3
+else
+ $4
+fi
+fi
Added: cgm/trunk/m4/netcdf.m4
--- cgm/trunk/m4/netcdf.m4 (rev 0)
+++ cgm/trunk/m4/netcdf.m4 2008-10-20 20:01:05 UTC (rev 2159)
@@ -0,0 +1,104 @@
+# Check for NetCDF library ((C++)
+# Sets HAVE_NETCDF to 'yes' or 'no'
+# If HAVE_NETCDF == yes, then exports NETCDF_CPPFLAGS and NETCDF_LDFLAGS
+AC_DEFUN([SNL_CHECK_NETCDF],[
+AC_MSG_CHECKING([if NetCDF support is enabled])
+AC_ARG_WITH(netcdf,
+[AC_HELP_STRING([--with-netcdf=DIR], [Specify NetCDF library to use for ExodusII file format])
+AC_HELP_STRING([--without-netcdf], [Disable support for ExodusII file format])],
+[NETCDF_ARG=$withval
+DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --with-netcdf=\"${withval}\""
+, [NETCDF_ARG=])
+if test "xno" = "x$NETCDF_ARG"; then
+else
+fi
+ # if NetCDF support is not disabled
+HAVE_NETCDF=no
+if test "xno" != "x$NETCDF_ARG"; then
+ HAVE_NETCDF=yes
+ # Check for stream headers and set STRSTREAM_H_SPEC accordingly
+ AC_LANG_SAVE
+ AC_LANG_CPLUSPLUS
+ AC_CHECK_HEADER( [strstream.h], [NETCDF_DEF="<strstream.h>"], [
+ AC_CHECK_HEADER( [sstream.h], [NETCDF_DEF="<sstream.h>"], [
+ AC_CHECK_HEADER( [strstream], [NETCDF_DEF="<strstream>"], [
+ AC_CHECK_HEADER( [sstream], [NETCDF_DEF="<sstream>"] )
+ AC_LANG_RESTORE
+ if test "xyes" != "x$NETCDF_ARG" && test "x" != "x$NETCDF_ARG"; then
+ if test -d "${NETCDF_ARG}/lib"; then
+ NETCDF_LDFLAGS="-L${NETCDF_ARG}/lib"
+ elif test -d "${NETCDF_ARG}"; then
+ NETCDF_LDFLAGS="-L${NETCDF_ARG}"
+ else
+ AC_MSG_ERROR("$NETCDF_ARG is not a directory.")
+ fi
+ if test -d "${NETCDF_ARG}/include"; then
+ NETCDF_CPPFLAGS="-I${NETCDF_ARG}/include"
+ elif test -d "${NETCDF_ARG}/inc"; then
+ NETCDF_CPPFLAGS="-I${NETCDF_ARG}/inc"
+ else
+ NETCDF_CPPFLAGS="-I${NETCDF_ARG}"
+ fi
+ fi
+ CPPFLAGS="$NETCDF_CPPFLAGS $CPPFLAGS"
+ LDFLAGS="$NETCDF_LDFLAGS $LDFLAGS"
+ # Check for C library
+ AC_CHECK_HEADERS( [netcdf.h], [], [AC_MSG_WARN([[NetCDF header not found.]]); HAVE_NETCDF=no] )
+ AC_MSG_CHECKING([for netcdf.hh])
+ AC_LANG_SAVE
+ AC_LANG_CPLUSPLUS
+ HAVE_NETCDF_HH=no
+ AC_TRY_COMPILE(
+[#include "netcdf.hh"], [], [HAVE_NETCDF_HH=yes; NETCDF_DEF=], [
+ AC_TRY_COMPILE(
+[#define STRSTREAM_H_SPEC $NETCDF_DEF
+ #include "netcdf.hh"], [], [HAVE_NETCDF_HH=yes], [NAVE_NETCDF_HH=no])])
+ AC_MSG_RESULT([$HAVE_NETCDF_HH])
+ if test $HAVE_NETCDF_HH != yes; then
+ AC_MSG_WARN([NetCDF C++ header not found])
+ HAVE_NETCDF=no
+ fi
+ if test "x$NETCDF_DEF" != "x"; then
+ NETCDF_CPPFLAGS="$NETCDF_CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
+ CPPFLAGS="$CPPFLAGS -DSTRSTREAM_H_SPEC=$NETCDF_DEF"
+ fi
+ AC_MSG_CHECKING([[for netcdf_c++ library]])
+ old_LIBS="$LIBS"
+ LIBS="$LIBS -lnetcdf_c++ -lnetcdf"
+ AC_TRY_LINK(
+ [#include <netcdf.hh>], [NcFile ncf("foo",NcFile::ReadOnly);],
+ [AC_MSG_RESULT([yes])],
+ [AC_MSG_RESULT([no]);
+ AC_MSG_WARN([NetCDF C++ API not found])
+ HAVE_NETCDF=no] )
+ LIBS="$old_LIBS"
+ AC_LANG_RESTORE
+ if test "x$HAVE_NETCDF" = "xno"; then
+ if test "x$NETCDF_ARG" != "x"; then
+ AC_MSG_ERROR("NetCDF not found or not working")
+ else
+ AC_MSG_WARN("NetCDF support disabled")
+ fi
+ NETCDF_CPPFLAGS=
+ NETCDF_LDFLAGS=
+ fi
+fi
+]) # SNL_HAVE_NETCDF
More information about the cgma-dev
