[cgma-dev] r2172 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Oct 22 14:11:10 CDT 2008
Author: janehu
Date: 2008-10-22 14:11:10 -0500 (Wed, 22 Oct 2008)
New Revision: 2172
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
Log:
Added make_solid option for sweep_rotational function, all sweep_translational and sweep_perpendicular function still passes test, sweep_rotational not tested yet.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-10-21 20:19:53 UTC (rev 2171)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-10-22 19:11:10 UTC (rev 2172)
@@ -3830,7 +3830,7 @@
GeometryEntity *ref_ent = ref_ent_list.get_and_step();
//Make copy of the surface for later to build solid.
OCCSurface* surface = CAST_TO(ref_ent, OCCSurface);
- TopoDS_Shape* toposhape = NULL;
+ TopoDS_Shape toposhape ;
if(surface != NULL)
CubitStatus stat = get_sweepable_toposhape(surface, &sweep_vector, toposhape);
@@ -3849,7 +3849,7 @@
//create the draft or the sweep
if(stop_shape == NULL && draft_angle == 0.)
- BRepSweep_Prism swept(*toposhape, aVec);
+ BRepSweep_Prism swept(toposhape, aVec);
TopoDS_Shape new_shape = swept.Shape();
tbs += OCCQueryEngine::instance()->populate_topology_bridge(new_shape);
assert(tbs.size() == 1);
@@ -3860,7 +3860,7 @@
continue;
- BRepOffsetAPI_MakeDraft draft(*toposhape, adir, draft_angle);
+ BRepOffsetAPI_MakeDraft draft(toposhape, adir, draft_angle);
BRepBuilderAPI_TransitionMode Cornertype;
if(draft_type == 1)
Cornertype = BRepBuilderAPI_RightCorner;
@@ -3951,7 +3951,7 @@
CubitStatus OCCModifyEngine::get_sweepable_toposhape(OCCCurve*& curve,
- TopoDS_Shape*& toposhape)const
+ TopoDS_Shape& toposhape)const
DLIList<OCCLoop*> loops;
loops = curve->loops();
@@ -3968,14 +3968,12 @@
TopoDS_Edge *edge = curve->get_TopoDS_Edge( );
- TopoDS_Wire wire = BRepBuilderAPI_MakeWire(*edge);
- toposhape = new TopoDS_Wire(wire);
+ toposhape = BRepBuilderAPI_MakeWire(*edge);
CubitStatus OCCModifyEngine::get_sweepable_toposhape(OCCSurface*& surface,
const CubitVector* sweep_v_p,
GeometryEntity* ref_ent = NULL;
//Make copy of the surface if it's not a sheet surface.
@@ -3993,16 +3991,7 @@
surface = CAST_TO(c_surface, OCCSurface);
- else //sheet body
- delete surface->my_body();
- delete surface->my_shell();
- delete surface->my_lump();
- surface->set_shell(NULL);
- surface->set_lump(NULL);
- surface->set_body(NULL);
if(sweep_v_p)
CubitVector center = surface->center_point();
@@ -4027,13 +4016,25 @@
else
ref_ent = (GeometryEntity *)surface;
- toposhape = OCCQueryEngine::instance()->get_TopoDS_Shape_of_entity(ref_ent);
+ if(surface->my_body() != NULL) //sheet body
+ delete surface->my_body();
+ delete surface->my_shell();
+ delete surface->my_lump();
+ surface->set_shell(NULL);
+ surface->set_lump(NULL);
+ surface->set_body(NULL);
- if(!toposhape)
+ TopoDS_Shape* toposhape_prt =
+ OCCQueryEngine::instance()->get_TopoDS_Shape_of_entity(ref_ent);
+ if(!toposhape_prt)
PRINT_WARNING("GeometryEntity without TopoDS_Shape found.\n");
return CUBIT_FAILURE;
+ toposhape = *toposhape_prt;
return CUBIT_SUCCESS;
@@ -4122,39 +4123,104 @@
+ OCCCurve* curve = CAST_TO(ref_ent, OCCCurve);
if(surface != NULL)
CubitStatus stat = get_sweepable_toposhape(surface, (CubitVector*)NULL, toposhape);
if(!stat)
continue;
- OCCCurve* curve = CAST_TO(ref_ent, OCCCurve);
- if(curve != NULL)
+ else if(curve != NULL)
CubitStatus stat = get_sweepable_toposhape(curve, toposhape);
if(!stat)
continue;
+ else
+ PRINT_ERROR("Only surface or curve can be revolve-swept.\n");
+ continue;
TopoDS_Shape new_shape;
DLIList<TopologyBridge*> tbs;
- if(!make_solid || surface != NULL)
+ if(make_solid && curve != NULL )
+ //giving an open wire and want a solid
- BRepSweep_Revol revol(*toposhape, axis, angle);
- new_shape = revol.Shape();
- tbs += OCCQueryEngine::instance()->populate_topology_bridge(new_shape);
- assert(tbs.size() == 1);
- BodySM* bodysm = CAST_TO(tbs.get(), BodySM);
- if (bodysm)
- result_body_list.append(bodysm);
- continue;
+ if(!toposhape.Closed())
+ //project the start and end points onto the axis
+ gp_Lin line = gp_Lin(axis);
+ TopoDS_Edge edge = BRepBuilderAPI_MakeEdge(line);
+ OCCCurve* acurve = new OCCCurve(&edge);
+ assert(acurve);
+ //get start and end points
+ DLIList<OCCPoint*> point_list;
+ curve->get_points(point_list);
+ assert(2 == point_list.size());
+ CubitVector start = point_list.get_and_step()->coordinates();
+ CubitVector end = point_list.get()->coordinates();
+ CubitBoolean start_closed = CUBIT_FALSE;
+ CubitBoolean end_closed = CUBIT_FALSE;
+ if(acurve->point_containment(start) != CUBIT_PNT_OFF)
+ start_closed = CUBIT_TRUE;
+ if(acurve->point_containment(end) != CUBIT_PNT_OFF)
+ end_closed = CUBIT_TRUE;
+ CubitVector start_proj, end_proj;
+ TopoDS_Edge edge1, edge2;
+ BRepBuilderAPI_MakeWire m_wire;
+ if(!start_closed)
+ acurve->closest_point(start, start_proj);
+ gp_Pnt pt1 = gp_Pnt( start.x(), start.y(), start.z());
+ gp_Pnt pt2 = gp_Pnt( start_proj.x(), start_proj.y(), start_proj.z());
+ edge1 = BRepBuilderAPI_MakeEdge(pt1, pt2);
+ m_wire.Add(edge1);
+ m_wire.Add(TopoDS::Wire(toposhape));
+ else
+ start_proj = start;
+ if(!end_closed)
+ acurve->closest_point(end,end_proj);
+ gp_Pnt pt1 = gp_Pnt( end.x(), end.y(), end.z());
+ gp_Pnt pt2 = gp_Pnt( end_proj.x(), end_proj.y(), end_proj.z());
+ edge2 = BRepBuilderAPI_MakeEdge(pt1, pt2);
+ m_wire.Add(edge2);
+ else
+ end_proj = end;
+ gp_Pnt pt1 = gp_Pnt( end_proj.x(), end_proj.y(), end_proj.z());
+ TopoDS_Edge edge3 = BRepBuilderAPI_MakeEdge(pt1, pt2);
+ m_wire.Add(edge3);
+ TopoDS_Wire wire = m_wire.Wire();
+ toposhape = BRepBuilderAPI_MakeFace(wire);
+ else //closed
+ TopoDS_Wire wire = TopoDS::Wire(toposhape);
+ BRepSweep_Revol revol(toposhape, axis, angle);
+ new_shape = revol.Shape();
- else //giving a wire and want a solid
+ tbs += OCCQueryEngine::instance()->populate_topology_bridge(new_shape);
+ assert(tbs.size() == 1);
+ BodySM* bodysm = CAST_TO(tbs.get(), BodySM);
+ if (bodysm)
+ result_body_list.append(bodysm);
+ continue;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-10-21 20:19:53 UTC (rev 2171)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-10-22 19:11:10 UTC (rev 2172)
@@ -704,10 +704,10 @@
CubitStatus get_sweepable_toposhape(OCCSurface*& surface,
- TopoDS_Shape*& toposhape)const;
+ TopoDS_Shape& toposhape)const;
CubitStatus get_sweepable_toposhape(OCCCurve*& curve,
#endif
More information about the cgma-dev
