[cgma-dev] r2144 - in cgm/trunk: geom geom/OCC test
janehu at mcs.anl.gov janehu at mcs.anl.gov
Tue Oct 14 14:42:15 CDT 2008
Author: janehu
Date: 2008-10-14 14:42:14 -0500 (Tue, 14 Oct 2008)
New Revision: 2144
Added:
   cgm/trunk/test/LeverArm.brep
   cgm/trunk/test/test_occ.cpp
Modified:
   cgm/trunk/geom/GeometryModifyTool.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/test/Makefile.am
   cgm/trunk/test/modify.cpp
Log:
Added testcase from Serge Gosselin and code for sweep_tran
slational and its testcase; changed GeometryModifyTool sweep_translational to pass out the final body generated by sweeping.
Modified: cgm/trunk/geom/GeometryModifyTool.cpp
--- cgm/trunk/geom/GeometryModifyTool.cpp	2008-10-14 19:25:26 UTC (rev 2143)
+++ cgm/trunk/geom/GeometryModifyTool.cpp	2008-10-14 19:42:14 UTC (rev 2144)
@@ -2906,6 +2906,13 @@
   if (!sweep_finish("translational", body_list, result_list, change_newids))
     status = CUBIT_FAILURE;
+  body_list.clean_out();
+  for(int i = 0; i < result_list.size(); i++)
+    Body* body = CAST_TO(result_list.get_and_step()->topology_entity(),Body );
+    if(body)
+      body_list.append(body);
   CAST_LIST( body_list, ref_ent_list, RefEntity);
   return status;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-10-14 19:25:26 UTC (rev 2143)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-10-14 19:42:14 UTC (rev 2144)
@@ -1078,7 +1078,8 @@
   for (Ex.Init(aShell, TopAbs_EDGE); Ex.More()&& stat; Ex.Next())
     TopoDS_Edge edge1 = TopoDS::Edge(Ex.Current());
-    edge_list.append(&edge1);
+    TopoDS_Edge* new_edge = new TopoDS_Edge(edge1);
+    edge_list.append(new_edge);
   int size = edge_list.size();
@@ -1114,6 +1115,14 @@
+  for (int k = 0; k < edge_list.size(); k++)
+    TopoDS_Edge* edge = edge_list.get_and_step();
+    edge->Nullify();
+    delete edge;
   if (num_edges == pairs )
     aShell.Closed(CUBIT_TRUE);
@@ -3792,6 +3801,8 @@
   //in OCC, there's no sweep surface with draft option, this can be done by
   //creating draft shell then make solid to achieve.
+  //while if draft_angle is 0, and stop_surf = 0, to_body = 0
+  // directly use sweep functions.
   TopoDS_Shape *stop_shape = NULL;
   if(stop_surf)
@@ -3810,55 +3821,102 @@
   gp_Dir adir(sweep_vector.x(), sweep_vector.y(), sweep_vector.z());
+  gp_Vec aVec(sweep_vector.x(), sweep_vector.y(), sweep_vector.z());
   for (int i = ref_ent_list.size(); i > 0; i--)
     GeometryEntity *ref_ent = ref_ent_list.get_and_step();
-    //check if the ref_ent has free boundary, if not, bail out
+    //Make copy of the surface for later to build solid.
     OCCSurface* surface = CAST_TO(ref_ent, OCCSurface);
+    Surface* c_surface = NULL;
+    TopoDS_Shape* toposhape = NULL;
     if(surface != NULL)
-      if(surface->my_body() == NULL)
+      //check if the surface is sheet body, if not, copy it.
+      if(surface->my_body() == NULL) //not a sheet body
+        c_surface = make_Surface(surface);
+        if (c_surface == NULL)
+           PRINT_ERROR("Cannot copy surface in sweep_translational.\n");
+           continue;
+        surface = CAST_TO(c_surface, OCCSurface);
+        CubitVector center = surface->center_point();
+        CubitVector normal;
+        surface->closest_point(center,NULL,&normal);
+        if(normal % sweep_vector > 0)
+          DLIList<Surface*> surfaces;
+          surfaces.append(surface);
+          flip_normals(surfaces);
+          surface = CAST_TO(surfaces.get(), OCCSurface);
+          ref_ent = (GeometryEntity *)surface;
+        else if(normal % sweep_vector == 0)
+          PRINT_ERROR("Sweeping direction should not be on the surface.\n");
+          continue;
+      else //sheet body
+        delete surface->my_body();
+        delete surface->my_shell();
+        delete surface->my_lump();
+        surface->set_shell(NULL);
+        surface->set_lump(NULL);
+        surface->set_body(NULL);
+      toposhape = OCCQueryEngine::instance()->get_TopoDS_Shape_of_entity(ref_ent);
+      if(!toposhape)
+        PRINT_WARNING("GeometryEntity without TopoDS_Shape found.\n");
         continue;
-    CubitVector center = surface->center_point();
-    CubitVector normal;
-    surface->closest_point(center,NULL,&normal);
-    if(normal % sweep_vector > 0)
-      DLIList<Surface*> surfaces;
-      surfaces.append(surface);
-      flip_normals(surfaces);
-      surface = CAST_TO(surfaces.get(), OCCSurface);
-      ref_ent = (GeometryEntity *)surface;
-    else if(normal % sweep_vector == 0)
-      PRINT_ERROR("Sweeping direction should not be on the surface.\n");
-      continue;
-    TopoDS_Shape* toposhape =
-          OCCQueryEngine::instance()->get_TopoDS_Shape_of_entity(ref_ent);
     TopoDS_Wire wire;
-    if(!toposhape)
-      PRINT_WARNING("GeometryEntity without TopoDS_Shape found.\n");
-      continue;
     OCCCurve* curve = CAST_TO(ref_ent, OCCCurve);
     if(curve != NULL)
       DLIList<OCCLoop*> loops;
       loops =  curve->loops();
-      if( loops.size())
-        continue;  //not a free curve
-      TopoDS_Edge edge = TopoDS::Edge(*toposhape);
-      wire = BRepBuilderAPI_MakeWire(edge);
+      if( loops.size()) //not a free curve
+        //copy the curve
+        Curve* c_curve = make_Curve(curve);
+        if(c_curve)
+          curve = CAST_TO(c_curve, OCCCurve);
+        else
+          PRINT_ERROR("Can't copy the curve for sweep.\n");
+          continue;
+      TopoDS_Edge *edge = curve->get_TopoDS_Edge( );
+      wire = BRepBuilderAPI_MakeWire(*edge);
       toposhape = &wire;
-    //create the draft
+    DLIList<TopologyBridge*> tbs;
+    //create the draft or the sweep
+    if(stop_shape == NULL && draft_angle == 0.)
+      BRepSweep_Prism swept(*toposhape, aVec);
+      TopoDS_Shape new_shape = swept.Shape();
+      tbs += OCCQueryEngine::instance()->populate_topology_bridge(new_shape);
+      assert(tbs.size() == 1);
+      BodySM* bodysm = CAST_TO(tbs.get(), BodySM);
+      if (bodysm)
+        result_body_list.append(bodysm);
+      continue;
     BRepOffsetAPI_MakeDraft draft(*toposhape, adir, draft_angle);
     BRepBuilderAPI_TransitionMode Cornertype;
     if(draft_type == 1)
@@ -3873,15 +3931,14 @@
       draft.Perform(sweep_vector.length());
     TopoDS_Shape new_shape = draft.Shape();
-    DLIList<TopologyBridge*> tbs;
-    if(bodysm && surface != NULL) //only gets swept side and top surfaces
+    if(bodysm && surface != NULL) //only gets swept side and original surfaces
-       //get surfaces from the shell body and add the original surface to
+       //get surfaces from the shell body and create a top surface to
        //make a swept solid.
        OCCShell* occ_shell = CAST_TO(bodysm, OCCBody)->shell();
        if(!occ_shell)
@@ -3891,10 +3948,48 @@
        DLIList<OCCCoFace*> cofaces = occ_shell->cofaces();
        DLIList<Surface*> surface_list;
-       surface_list.append(surface);
        for(int i = 0; i < cofaces.size(); i++)
          surface_list.append(cofaces.get_and_step()->surface());
+       //create the top surface from edges.
+       DLIList<OCCCoEdge*> coedges;
+       for(int i = 0; i < surface_list.size(); i++)
+         CAST_TO(surface_list.get_and_step(), OCCSurface)->get_coedges(coedges);
+       for(int i = 0; i < coedges.size(); i++)
+         OCCCoEdge* coedge = coedges[i];
+         if(coedge == NULL)
+           continue;
+         for(int j = i+1; j < coedges.size(); j++)
+            OCCCoEdge* temp_coedge = coedges[j];
+            if(temp_coedge == NULL)
+              continue;
+            if(coedge->curve() == temp_coedge->curve() &&
+               coedge->sense() != temp_coedge->sense())
+              coedges.move_to(coedge);
+              coedges.change_to((OCCCoEdge*)NULL);
+              coedges.move_to(temp_coedge);
+       coedges.remove_all_with_value(NULL);
+       assert(coedges.size() > 0);
+       DLIList<Curve*> curves;
+         curves.append(coedges.get_and_step()->curve());
+       Surface* surf = make_Surface(PLANE_SURFACE_TYPE, curves);
+       if(!surf)
+         surf = make_Surface(BEST_FIT_SURFACE_TYPE, curves);
+       if(!surf)
+         PRINT_ERROR("Can't calculate for the top surface.\n");
+         continue;
+       surface_list.append(surf);
        DLIList<BodySM*> bodies;
        create_solid_bodies_from_surfs(surface_list, bodies);
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-10-14 19:25:26 UTC (rev 2143)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-10-14 19:42:14 UTC (rev 2144)
@@ -1459,7 +1459,8 @@
         Curve* test_c = coedge->curve();
         if(test_c == curve)
-          sense = (sense == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD);
+          if(sense == coedge->sense())
+            sense = (sense == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD);
           break;
Added: cgm/trunk/test/LeverArm.brep
--- cgm/trunk/test/LeverArm.brep	                        (rev 0)
+++ cgm/trunk/test/LeverArm.brep	2008-10-14 19:42:14 UTC (rev 2144)
@@ -0,0 +1,4523 @@
+DBRep_DrawableShape
+CASCADE Topology V1, (c) Matra-Datavision
+Locations 22
+1
+              1               0               0               0
+              0               1               0              38
+              0               0               1               0
+2  1 -1 0
+1
+              1               0               0               0
+              0               1               0               7
+              0               0               1               0
+2  3 -1 0
+1
+              1               0               0              -0
+              0               1               0              -7
+              0               0               1              -0
+2  5 -1 0
+1
+              1               0               0               0
+              0               1               0               7
+              0               0               1               0
+2  7 -1 0
+1
+              1               0               0               0
+              0               1               0              26
+              0               0               1               0
+2  9 -1 0
+1
+              1               0               0               0
+              0               1               0              38
+              0               0               1               0
+2  11 -1 0
+1
+              1               0               0               0
+              0               1               0            -706
+              0               0               1              -0
+2  13 -1 0
+1
+              1               0               0              -0
+              0               1               0             -23
+              0               0               1              -0
+2  15 -1 0
+1
+              1               0               0               0
+              0               1               0               7
+              0               0               1               0
+2  17 -1 0
+1
+              1               0               0               0
+              0               1               0              23
+              0               0               1               0
+2  19 -1 0
+1
+              1               0               0              -0
+              0               1               0             -23
+              0               0               1              -0
+2  21 -1 0
+Curve2ds 318
+1 0 0 0 1
+1 -13.030175316602458 -88.88841014078244 -0.064297555996514807 0.99793077129271601
+1 0 4.7123889803846897 1 0
+2 0 0 1 -2.4492935982947064e-16 -2.4492935982947064e-16 -1 18.718520432244532
+1 0 1.5707963267948966 1 0
+2 -45.961890769262091 -91.01022948866742 0.96761875303709655 -0.25241622129121266 0.25241622129121266 0.96761875303709655 33
+1 0 0 0 1
+1 18.679787532408252 -1.2035551156641495 -0.064297555996514807 -0.99793077129271601
+2 0 -103 0.96761875303709655 0.25241622129121211 0.25241622129121216 -0.96761875303709666 14.5
+2 45.961890769262091 -91.01022948866742 -0.99793077129271612 0.064297555996514544 -0.064297555996514544 -0.99793077129271612 33
+1 0 0 0 1
+1 -12.726825855522646 -31.38578533597909 0.064297555996514807 -0.99793077129271601
+2 -6.7392412277663505 -31 0 1 -1 0 6
+2 -4.2264369772112387 -70 -0.99793077129271601 -0.064297555996515612 0.064297555996515612 -0.99793077129271601 6
+1 0 0 0 1
+1 6.7392412277664011 -25 -1 0
+1 0 0 0 1
+1 -4.2264369772112396 -76 1 -0
+2 6.7392412277664011 -31 0.99793077129271601 -0.064297555996515612 0.064297555996515612 0.99793077129271601 6
+2 4.2264369772112893 -70 -1.4802973661668753e-16 -1 1 -1.4802973661668753e-16 6
+1 0 0 0 1
+1 10.214021604967584 -70.385785335979094 0.064297555996514807 0.99793077129271601
+2 0 -103 1 0 -0 1 6.4899997711181641
+1 9.4247779607693793 -38 -1 0
+7 0 0  8 9 2  -6.6100297432205664e-17 89.072721974127148  0.19634954159936213 89.110674894336881  0.39269908219853278 89.148627823262359  0.58904862279541703 89.184351034171414  0.78539816339707613 89.21561524522258  0.98174770399464251 89.240464810747653  1.1780972445959605 89.257497985090595  1.3744467851955342 89.266014608747369  1.5707963267948963 89.266014608785326
+ 4.7123889803846897 9 6.2831853071795862 9
+3 3.0062205578787911 -2.9999999999999996 -1 0 -0 -1 3.0062205578787902 3
+1 298.13177710168731 -22 1 0
+1 6.8484683036804181 -298.13177710168736 0 1
+1 6.2831853071795862 0 0 -1
+7 0 0  6 17 4  0 4.7123889803846897  0 4.7987798030582773  0 4.885181395369707  0 4.9715703789080301  0 5.0579593424615865  0 5.1443609529278076  0 5.3171425868040521  0 5.4035441893341654  0 5.4899331621482235  0 5.5763221349620631  0 5.6627237374922874  0 5.8381228920001202  0 5.9271437405083862  0 6.0161499267741636  0 6.1051561340947984  0 6.1941769634864166  0 6.2831853071795862
+ 0 7 0.33000047848609959 5 0.66000096949313125 5 1 7
+7 0 0  6 17 4  40.48207463561922 0  40.741247103639978 -2.5917246571083297e-08  41.000452392555658 -0.026868167141255839  41.256135088447579 -0.080616811260954435  41.504859263719624 -0.16060925476729393  41.743325286735754 -0.26569622174663499  42.193576003638839 -0.52251469649633187  42.405417818968189 -0.67427880326561329  42.600881661163413 -0.84764666969419977  42.777298352220726 -1.0403632539104168  42.932371202842184 -1.2497951278593087  43.200227504638441 -1.7027153992168553  43.311624479195203 -1.9471062888278112  43.396497047632948 -2.2027042219512394  43.453553650077396 -2.4659118514092464  43.482074608916719 -2.7329749689204927  43.48207463561922 -2.9999999999999991
+8 1.5707963267948966 3.1415926535897931
+1 0.31951846633779724 0 0 1
+1 -1.5707963267948966 0 1 0
+1 1.5707963267948966 0 0 1
+1 89.266014608785312 -2.9999999999999996 -1 -0
+1 0 6.2831853071795862 1 0
+1 6.2831853071795862 -3 -1 -0
+8 4.7123889803846897 6.2831853071795862
+1 0.064341941519098889 0 0 1
+1 -4.7123889803846897 2.2204460492503131e-16 1 0
+1 3.6519457032271907 0 0 1
+1 0 -3.1415926535897931 0 1
+1 0 3.1415926535897931 1 0
+1 6.0280087823608879 -3 1 0
+1 -2.2204460492503131e-16 -2.9999999999999996 1 0
+8 0 1.5707963267948966
+1 0 87.866671263710643 1 0
+1 0 1.5707963267948966 0 1
+1 8.8817841970012523e-16 3.1415926535897931 0 1
+1 6.5383618319982855 -3 -1 -0
+1 3.0772507120706942 -3 1 0
+1 0 0 1 0
+1 1.6351382683139959 1.5707963267948966 0 1
+1 0 -0.99999999999999967 1 0
+1 0 39.08086725242427 1 0
+1 -4.4408920985006262e-16 1.5707963267948966 0 1
+1 0 13.478482455532752 1 0
+1 1.5707963267948966 -1 1 0
+1 3.2059345951088924 -1 1 0
+1 1.5064543852757972 0 0 1
+1 1.6351382683139963 0 0 1
+1 8.4528739544225289 -0.99999999999999967 -1 0
+1 0 8.4528739544225289 1 0
+1 0 39.080867252424277 1 0
+1 6.2188433656604865 -1 1 0
+1 4.7123889803846897 -1 1 0
+1 1.5064543852757977 0 0 1
+1 -1.5707963267948966 7.1054273576010019e-15 1 0
+1 39.08086725242427 -0.99999999999999967 -1 0
+1 0 0 0 -1
+2 11.5 -553.5 0 1 -1 0 6.4899997711181641
+1 9.4247779607693793 -30 -1 0
+1 6.3475272486986851 0 0 -1
+3 91.689727015303092 -13 1 0 -0 1 5.0103675964646497 5
+7 0 0  8 9 2  5.2173112808859194 -569.52396763048068  5.3505455349226247 -569.56153348262887  5.4837797879608843 -569.5959377901745  5.617014040977665 -569.62616440677084  5.7502482940544724 -569.651316922158  5.8834825470476062 -569.67067633545958  6.0167168001062237 -569.68374760146253  6.1499510531428765 -569.69028323735699  6.2831853071795889 -569.69028323739997
+ 2.0757186272961237 9 3.1415926535897927 9
+1 86.679359418838445 -6.5 0 -1
+1 -6.5 -569.69028323739997 1 0
+1 15.751996004303455 -22 1 0
+1 22.567869825654746 -595.25073935823104 0.99793077129271601 0.064297555996514807
+3 91.689727015303092 -25 1 0 -0 1 5.0103675964646497 5
+7 0 0  8 9 2  -4.6464430598112327e-17 -569.69028323739997  0.13323425403670874 -569.69028323735699  0.26646850707271597 -569.68374760163715  0.3997027601121772 -569.67067633499391  0.53293701314441932 -569.65131692122668  0.66617126618530165 -569.62616440653801  0.79940551921936276 -569.5959377901163  0.93263977225696204 -569.56153348262887  1.0658740262936708 -569.52396763048068
+ 3.1415926535897931 9 4.2074666798834626 9
+1 51.541094107988272 -11.801086171518966 0.81970963684880227 -0.57277928668659528
+1 -17.781261788731534 -592.94958781884475 0.99861010839172004 0.052705326276168675
+1 0 0 0 1
+1 72.912765859676938 -564.00754114215385 -0.99793077129271601 0.064297555996514807
+1 -21.886621588231645 -22 1 0
+1 -13.596417075201698 -551.41916387656977 0.99793077129271601 -0.064297555996514807
+2 37.848468303680434 -567.76075877223354 0.064297555996516834 0.99793077129271579 -0.9979307712927159 0.064297555996516847 6
+1 9.4247779607693793 -22 -1 0
+2 6.8484683036804181 -574.5 0 -1 -1 -0 21.718520432244532
+1 0 0 0 1
+1 31.84846830368042 -567.76075877223366 -0 -1
+2 37.848468303680434 -581.23924122776634 -1 0 -0 -1 6
+1 0 0 0 1
+1 38.234253639659521 -587.22682585552263 0.99793077129271601 0.064297555996514807
+1 6.2188433656604873 0 0 -1
+1 2.8864161287710948 0 0 -1
+1 6.0280087823608879 0 0 -1
+1 9.4247779607693793 -8 -1 0
+2 -0.48977051133257987 -599.46189076926214 0 -1 -1 -0 30
+7 0 0  8 23 4  6.2668588981730062 -8  6.269041143195575 -8.0000000065025265  6.2713025583855408 -8.0009630028047116  6.2736280688895647 -8.0030467965331233  6.2759995151906187 -8.0063446201752804  6.2783956531079887 -8.0108851310796592  6.2807921537972575 -8.0166324114556904  6.2831616037503277 -8.0234859683737572  6.2907993313467454 -8.0492371980228601  6.2957306674804023 -8.071809635926753  6.3002485020473866 -8.0974737099509966  6.304382180387905 -8.1249160077870854  6.3081672936152549 -8.1532855091350509  6.3116567714755032 -8.1820921658688768  6.3149157678705876 -8.2113085804253352  6.322750046417112 -8.287058219792133  6.3270229284275556 -8.3336918593399609  6.3309781289870557 -8.3809877474555652  6.3346658952416517 -8.4287923379538494  6.338136445015488 -8.4770000501677671  6.3414185015083842 -8.5255734097806268  6.3445410485152225 -8.5745269600542375  6.3475272486986842 -8.6239396831001347
+ 0 9 0.14682438534335393 7 0.48505737827765527 7 1 9
+7 0 0  8 23 4  4.7123889803846888 -569.46588895491641  4.7254807055194883 -569.46482015673962  4.7390470348389577 -569.46387315581023  4.753002579633784 -569.46308156460816  4.7672430342256584 -569.46246954012315  4.7816451759672676 -569.46205178385321  4.7960668652423042 -569.46183354180596  4.8103470454654627 -569.46181060449737  4.8564617916939472 -569.46233490294219  4.8863683592020886 -569.46364598489367  4.9139275908453497 -569.46564849480581  4.93930497875811 -569.46810155005858  4.9626929006366369 -569.47084495102649  4.984391492144991 -569.47377241675883  5.0047859949666345 -569.47684722497081  5.0541456253938923 -569.48503308328816  5.0813882572389844 -569.49026365364261  5.1068943075219249 -569.49567116792934  5.1309542360788809 -569.50120339067598  5.1538601495965786 -569.5068168043191  5.1757787381305995 -569.51248958710869  5.1968818020635528 -569.51820746927524  5.217311280885915 -569.52396763048057
+1 3.0772507120706942 0 0 -1
+3 90.290383670228422 -13 -1 0 -0 -1 5.0103675964646497 5
+7 0 0  8 9 2  5.2173112808859221 -537.47603236951943  5.3505455349226274 -537.43846651737124  5.4837797879508798 -537.40406220947625  5.6170140410104068 -537.37383559416048  5.7502482939853508 -537.34868307318538  5.88348254707671 -537.32932366640307  6.0167168000971287 -537.31625239783898  6.1499510531428774 -537.30971676264312  6.2831853071795898 -537.30971676260106
+ 5.2173112808859186 9 6.2831853071795862 9
+1 85.280016073763775 -6.5 0 -1
+1 -6.5 -537.30971676260015 1 0
+3 90.290383670228422 -25 -1 0 -0 -1 5.0103675964646497 5
+7 0 0  8 9 2  -4.6464429150546256e-17 -537.30971676260015  0.13323425403670858 -537.30971676264312  0.26646850707254544 -537.31625239853747  0.39970276011285932 -537.32932366384193  0.5329370131394171 -537.348683077842  0.66617126618507427 -537.37383559136651  0.79940551921936276 -537.40406221000012  0.93263977225695927 -537.43846651737124  1.0658740262936679 -537.47603236951943
+ 0 9 1.0658740262936681 9
+1 25.791716685343367 5.2137133657439731 0.81970963684880227 -0.57277928668659528
+1 -47.445656443188525 -554.48476450153566 0.99861010839172004 -0.052705326276168675
+2 11.5 -553.5 0 -1 -1 -0 17.5
+1 6.5383618319982846 0 0 -1
+1 3.3967691784084915 0 0 -1
+7 0 0  5 10 3  3.1579190625963709 -8  3.1500267322632496 -8.000000023517094  3.1410306106195272 -8.0155239049207037  3.1325123059625484 -8.0487030744765011  3.1252887459108436 -8.0934107970305629  3.1070282024046025 -8.2234575841520847  3.0982447038724055 -8.3220033398570568  3.0902025609228927 -8.4211953088539673  3.0834889674396924 -8.520715128180786  3.0772507120706942 -8.6239396831001418
+ 0 6 0.32181783114484497 4 1 6
+7 0 0  5 10 3  4.7123889803846897 -537.53411104508359  4.7597366513958406 -537.53797647182637  4.813673209958127 -537.53977769682479  4.8651367897346178 -537.53844755359444  4.9092902364191264 -537.53463996243374  5.0218721626231471 -537.52249013221206  5.0776981155394996 -537.51112795192046  5.129874306543698 -537.4997632085375  5.1746335305276983 -537.48806550673669  5.2173112808859177 -537.47603236951943
+2 -0.48977051133257987 -507.53810923073792 0 -1 -1 -0 30
+1 3.2059345951088924 0 0 -1
+1 3.205934595108892 0 0 -1
+1 1.5707963267948966 0 0 -1
+2 -6.7167243422012719 29.229997990467794 1 0 -0 1 5
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -7 1 0
+2 -4.2039200916461601 -9.770002009532206 1 0 -0 1 5
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -7 1 0
+1 4.7123889803846897 0 0 -1
+1 7.8539816339744828 0 0 -1
+1 6.2188433656604865 0 0 -1
+2 6.7617581133314797 29.229997990467794 1 0 -0 1 5
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -7 1 0
+2 4.2489538627763679 -9.770002009532206 1 0 -0 1 5
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 0 -1
+7 0 0  5 10 3  3.0772507120706942 -29.37606031689986  3.0832074089549368 -29.474625917102948  3.0896429359960509 -29.570240895931327  3.0971904596451356 -29.665246688253191  3.1055027105237243 -29.759172958112348  3.122907172236741 -29.892115198858253  3.1304176427356336 -29.939847395214837  3.1393193062906426 -29.983065042295571  3.1493096469692179 -29.999999974346178  3.1579190625963709 -30
+ 0 6 0.64797639648373506 4 1 6
+7 0 0  5 10 3  1.0658740262936683 -537.47603236951943  1.1066255517680261 -537.48752240106353  1.1495709139604851 -537.49874624356153  1.1986486752922012 -537.509682194314  1.2516020300726396 -537.52048109711347  1.359329388196352 -537.53343509010995  1.4053873027029538 -537.53755093723942  1.459233547242587 -537.54039643167232  1.5191467174264255 -537.53832767870131  1.5707963267948966 -537.53411104508359
+7 0 0  8 23 4  6.2668588981730062 -30  6.2690411431967723 -29.999999993497479  6.2713025583880588 -29.999036997194203  6.2736280688934754 -29.99695320346337  6.2759995151959425 -29.993655379817344  6.2783956531146936 -29.989114868907659  6.2807921538052804 -29.983367588525066  6.2831616037595674 -29.976514031599471  6.2907993313568573 -29.95076280193296  6.2957306674898579 -29.928190364022349  6.3002485020564638 -29.902526289992821  6.3043821803962397 -29.87508399215389  6.3081672936232911 -29.846714490803429  6.3116567714832632 -29.817907834065721  6.3149157678779897 -29.788691419507728  6.3227500464227555 -29.712941780146252  6.3270229284320356 -29.666308140606453  6.3309781289906244 -29.619012252498369  6.3346658952441874 -29.571207662010483  6.3381364450173781 -29.522999949804635  6.3414185015095779 -29.47442659020053  6.3445410485157838 -29.425473039936481  6.3475272486986842 -29.376060316899867
+ 0 9 0.14682438542568158 7 0.48505737837702279 7 1 9
+7 0 0  8 23 4  1.5707963267948963 -569.4658889549163  1.5577046016529181 -569.46482015673882  1.5441382723255082 -569.46387315580898  1.5301827275223172 -569.4630815646068  1.5159422729219583 -569.4624695401219  1.5015401311720074 -569.4620517838523  1.4871184418890033 -569.4618335418055  1.4728382616584479 -569.46181060449749  1.4267235154243636 -569.46233490294458  1.3968169479199417 -569.46364598489697  1.3692577162785944 -569.46564849481126  1.3438803283702332 -569.46810155006301  1.3204924064931824 -569.47084495103377  1.2987938149862659 -569.47377241676475  1.2783993121665997 -569.47684722497786  1.2290396817497156 -569.48503308329509  1.2017970499117259 -569.49026365364932  1.1762909996342847 -569.49567116793332  1.1522310710841017 -569.50120339068167  1.1293251575702905 -569.50681680432149  1.107406569040946 -569.51248958711108  1.0863035051121952 -569.51820746927626  1.0658740262936712 -569.52396763048057
+7 0 0  8 9 2  0.036887931978989909 0.063028253968584247  0.032276939731617306 0.063081780052004377  0.027665948484257186 0.063170114095797203  0.023054957236716689 0.063293254377612129  0.018443965989590083 0.063451197584356578  0.013832974742051363 0.063643938823929602  0.0092219834947471213 0.063871471627415133  0.0046109922473833165 0.064133787945991658  1.0712359319508935e-14 0.064430878219353671
+ 3.149695980065613 9 3.1865839120445938 9
+3 -1.7434466147832621 -563.91138157807598 -0.99692092926609954 0.078413396758568149 -0.078413396758568149 -0.99692092926609954 1.7470616849752154 1
+1 0 0 0 1
+1 5.3263588681328145 -564.32147263735112 -0.99861010839172004 0.052705326276168675
+1 287.25 -88.850364575678142 -1 0
+1 27.895145836532322 -287.25 0 -1
+1 0 0 0 1
+7 0 0  8 16 3  11.507538861992952 -570.27356302278929  11.50753886199317 -569.2123647878152  11.245556762791594 -568.15104911783578  10.720799987603815 -567.14189405598631  9.955091827617121 -566.23376306315242  8.9779929819434887 -565.47581650645418  7.8505808560728907 -564.893197290035  6.6053755522788133 -564.51625820056881  5.2362809738452851 -564.33828025993694  5.1572760670718587 -564.32798407869655  5.0738373114788677 -564.3183682843877  4.9895325858769359 -564.30982739759872  4.9060458223956704 -564.30238800592872  4.8218703503705003 -564.29585828264044  4.737911784805898 -564.2904151753205  4.6538479157592558 -564.28597839503254
+ 22.085655744626067 9 30.49282572876356 7 31.108979103877161 9
+1 0 0 0 1
+1 11.507538861992956 -578.72643697721128 0 1
+1 0 0 0 1
+7 0 0  8 16 3  4.6538479157594796 -584.71402160496768  4.7379117848061902 -584.70958482466824  4.8218703503707756 -584.70414171739969  4.9060458223954759 -584.69761199399886  4.9895325858773019 -584.6901726024829  5.0738373114789663 -584.68163171555102  5.1572760670719076 -584.67201592133085  5.2362809738455267 -584.66171974005943  6.6053755522795825 -584.48374179944165  7.8505808560694517 -584.10680270993328  8.9779929819483399 -583.52418349360732  9.9550918276129501 -582.76623693677186  10.720799987605456 -581.85810594407906  11.245556762791354 -580.84895088212932  11.507538861992991 -579.78763521219526  11.507538861992957 -578.72643697721128
+ 4.6094584309535671 9 5.2256118060664418 7 13.632781790206472 9
+7 0 0  8 9 2  0.036887931978828038 34.68739053018713  0.032276939731471201 34.687337004103725  0.02766594848411863 34.687248670074041  0.023054957236787743 34.687125529671903  0.018443965989249023 34.686967586545506  0.013832974742101101 34.686774845264154  0.0092219834946618562 34.686547312543553  0.0046109922473303241 34.686284996209736  -2.6507867590329371e-14 34.685987905936344
+ 0.0081033264759815538 9 0.044991258454836647 9
+3 -1.7434466147832621 -585.08861842192402 0.99692092926609954 0.078413396758568163 0.078413396758568163 -0.99692092926609954 1.7470616849752154 1
+1 0 0 0 1
+1 0.050796132397834981 -584.95696461552745 0.99861010839172004 0.052705326276168675
+2 -45.961890769262091 -91.01022948866742 1 0 -0 1 30
+1 0 0 1 0
+1 0 -26 1 0
+1 0 0 1 0
+1 0 -38 1 0
+1 0 0 1 0
+1 0 -38 1 0
+1 0 0 1 0
+1 0 -26 1 0
+1 0 0 1 0
+1 0 -38 1 0
+1 0 0 1 0
+1 0 -38 1 0
+2 45.961890769262091 -91.01022948866742 1 0 -0 1 30
+1 0 0 1 0
+1 0 -26 1 0
+1 0 0 1 0
+1 0 -38 1 0
+1 0 0 1 0
+1 0 -38 1 0
+1 0 0 1 0
+1 0 -706 1 0
+7 0 0  8 9 2  1.5339083948159531 5.6495099033417446  1.3421698447139585 5.5891574890148501  1.1504312956132026 5.5288050629715144  0.95869274650522129 5.4718337278318359  0.76695419741145088 5.4216239903435053  0.5752156483017643 5.3811605209302797  0.38347709920503803 5.3526274873001967  0.19173855010199636 5.3371856915442173  1.7776606945764121e-15 5.3349599205845806
+ 1.5707963267948966 9 3.1047047216108528 9
+7 0 0  8 9 2  1.5707963267948966 -0.25152172878856804  1.379057776692902 -0.19116931446167346  1.1873192275907059 -0.13081688842122219  0.99558067848738574 -0.073845553292692045  0.80384212938361088 -0.023635815770028046  0.61210358028210976 0.016827653605972159  0.42036503118333712 0.045360687251839948  0.2286264820809791 0.060802483008973972  0.036887931978984413 0.063028253968608783
+1 34.750418784155727 -17 -1 0
+1 0 34.750418784155734 1 0
+1 6.2188433656604865 -17 1 0
+1 -1.5707963267948966 -8.8817841970012523e-16 1 0
+1 8.8817841970012523e-16 -17 1 0
+1 1.5707963267948966 -17 1 0
+1 1.6351382683139959 0 0 1
+1 -1.5707963267948966 -3.5527136788005009e-15 1 0
+7 0 0  8 9 2  1.5339083948159635 -0.36660450172173231  1.3421698447139687 -0.30625208739483717  1.1504312956111562 -0.24589966135386021  0.95869274651340675 -0.18892832622651667  0.76695419740281068 -0.13871858870152209  0.57521564830767602 -0.098255119327973262  0.38347709920333273 -0.069722085681007684  0.19173855010199486 -0.054280289924189699  1.3038587692274362e-18 -0.052054518964554986
+ 4.7123889803846897 9 6.2462973752006485 9
+7 0 0  8 9 2  1.5707963267948966 35.001940512944344  1.3790577766929015 34.941588098617416  1.1873192275896827 34.881235672495677  0.99558067849011422 34.824264337614295  0.80384212938497512 34.774054599547526  0.61210358028483824 34.733591130760033  0.42036503118185919 34.705058096813445  0.22862648208083206 34.689616301146749  0.03688793197883708 34.68739053018713
+1 3.5527136788005009e-15 -17 1 0
+7 0 0  5 6 2  0 0.67344697066659853  0.27757815953566495 0.67344697066659698  0.59359411608536683 0.67344697066660075  0.94031427873045581 0.67344697066659709  1.2563302352802845 0.67344697066659887  1.5339083948159575 0.67344697066659853
+ 0 6 9.0233233592510942 6
+8 0 9.0233233592510942
+1 0 31.108979103877161 1 0
+1 1.5339083948159575 0 0 1
+1 39.632898224186292 -13.764077747435053 -0.81970963684880227 -0.57277928668659528
+8 0 0.95993101596832275
+1 0 8.4528739544225111 1 0
+7 0 0  5 6 2  0 22.085655744626067  1.8758623882396017 22.085655744626013  3.6416283706538053 22.085655744626134  5.3816949885973626 22.085655744626017  7.1474609710115828 22.085655744626081  9.0233233592510942 22.085655744626067
+ 0 6 0.95993101596832275 6
+1 9.0233233592510942 0 0 1
+7 0 0  8 16 3  4.7123889803846897 -10.218698186370302  4.8869674020788842 -10.218698186370441  5.0615325297243547 -10.364837881589221  5.2364759544084496 -10.65746706409327  5.4117083000285922 -11.087277481353732  5.587578618190526 -11.641374577232874  5.762239360030283 -12.279547286368819  5.9383653823023561 -12.984291457524785  6.127948182434606 -13.769968698882579  6.1410281497607588 -13.824461398031101  6.1540185344031011 -13.878587127464373  6.1669977894113677 -13.932754788827781  6.179980574380898 -13.987032352401579  6.1929355397126233 -14.041238744436258  6.2058923735895242 -14.095516508210842  6.2188433656604953 -14.149814222914754
+7 0 0  3 4 2  0 -1.7763568394002505e-14  0.30783238734923796 -1.7763568394002498e-14  0.65209862861907031 -1.7763568394002508e-14  0.95993101596832275 -1.7763568394002505e-14
+ 0 4 9.0233233592529061 4
+8 0 9.0233233592529061
+1 0 13.632781790206472 1 0
+1 0.95993101596832275 0 0 1
+1 8.4528739544225111 -10.218698186370304 -1 0
+8 0 1.5339083948159575
+1 0 4.6094584309534463 1 0
+7 0 0  5 6 2  -8.8817841970012523e-16 4.6094584309535671  1.9945303294826002 4.6094584309535556  3.6815821722842701 4.6094584309535822  5.3417411869676137 4.6094584309535573  7.0287930297702017 4.6094584309535698  9.0233233592529078 4.6094584309535671
+ 0 6 1.5339083948159575 6
+1 9.0233233592529061 0 0 1
+7 0 0  8 16 3  3.2059345951088956 -14.149814222914699  3.2188855871797704 -14.095516508210505  3.2318424210571499 -14.041238744436908  3.2447973863878703 -13.987032352400355  3.2577801713587018 -13.932754788828907  3.2707594263658164 -13.878587127463399  3.2837498110088168 -13.824461398031561  3.2968297783347413 -13.769968698882536  3.4864125784674616 -12.984291457523232  3.6625386007376979 -12.279547286374148  3.8371993425808895 -11.641374577225095  4.0130696607389202 -11.08727748136082  4.1883020063619014 -10.657467064089463  4.3632454310447608 -10.364837881590436  4.5378105586904072 -10.218698186370341  4.7123889803846906 -10.218698186370302
+1 35.302449755917756 -16.790016535007734 0.81970963684880227 0.57277928668659528
+2 6.7392412277664038 73.655180278306844 1 0 -0 1 5
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -23 1 0
+1 0 0 1 0
+1 0 -23 1 0
+1 0 0 1 0
+1 0 -23 1 0
+2 -6.7392412277663487 73.655180278306844 1 0 -0 1 5
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -23 1 0
+1 0 0 1 0
+1 0 -23 1 0
+1 0 0 1 0
+1 0 -23 1 0
+2 4.226436977211292 34.655180278306858 1 0 -0 1 5
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -23 1 0
+1 0 0 1 0
+1 0 -23 1 0
+1 0 0 1 0
+1 0 -23 1 0
+2 -4.2264369772112369 34.655180278306858 1 0 -0 1 5
+1 0 0 1 0
+1 0 -7 1 0
+1 0 0 1 0
+1 0 -23 1 0
+1 0 0 1 0
+1 0 -23 1 0
+1 0 0 1 0
+1 0 -23 1 0
+Curves 153
+1 0 0 0 0 0 1
+1 -88.88841014078244 -4.4408920985006262e-16 -13.030175316602458 0.99793077129271601 0 -0.064297555996514807
+2 0 0 0 -0 -1 -0 -2.4492935982947064e-16 0 1 -1 0 -2.4492935982947064e-16 18.718520432244532
+2 -91.01022948866742 0 -45.961890769262091 0 1 0 -0.25241622129121266 0 0.96761875303709655 0.96761875303709655 -0 0.25241622129121266 33
+1 -1.2035551156641495 -4.4408920985006262e-16 18.679787532408252 -0.99793077129271601 0 -0.064297555996514807
+2 -103 -0 0 -0 -1 -0 0.25241622129121227 -0 0.96761875303709666 -0.96761875303709666 0 0.25241622129121227 14.5
+2 -91.01022948866742 -0 45.961890769262091 0 1 0 0.064297555996514669 0 -0.99793077129271612 -0.99793077129271612 0 -0.064297555996514669 33
+1 -31.38578533597909 -2.2204460492503131e-16 -12.726825855522646 -0.99793077129271601 -0 0.064297555996514807
+2 -31 0 -6.7392412277663505 0 1 0 1 -0 0 0 0 -1 6
+2 -70 0 -4.2264369772112387 0 1 0 -0.064297555996515141 0 -0.99793077129271601 -0.99793077129271601 0 0.064297555996515141 6
+1 -25 -2.2204460492503131e-16 6.7392412277664011 0 0 -1
+1 -76 -2.2204460492503131e-16 -4.2264369772112396 -0 -0 1
+2 -31 -0 6.7392412277664011 0 1 0 -0.064297555996515862 0 0.99793077129271601 0.99793077129271601 -0 0.064297555996515862 6
+2 -70 -0 4.2264369772112893 0 1 0 -1 0 -1.7763568394002506e-16 -1.7763568394002506e-16 0 1 6
+1 -70.385785335979094 -2.2204460492503131e-16 10.214021604967584 0.99793077129271601 -0 0.064297555996514807
+8 3.1415926535897931 9.4247779607693793
+2 -103 0 0 -0 1 -0 0 0 1 1 0 -0 6.4899997711181641
+1 0 0 -21.763554203374689 0 1 0
+3 0 2.9999999999999996 -18.757333645495898 1 0 0 0 0 -1 -0 1 0 3.0062205578787902 3
+1 0 22 276.36822289831264 -0 0 1
+1 0 0 21.718520432244532 0 1 0
+8 0 1
+7 0 0  6 17 4  0 0 18.718520432244532  0 2.5917246571083297e-08 18.977692900265289  0 0.026868167141255839 19.23689818918097  0 0.080616811260954435 19.49258088507289  0 0.16060925476729393 19.741305060344935  0 0.26569622174663499 19.979771083361065  0 0.52251469649633187 20.43002180026415  0 0.67427880326561329 20.6418636155935  0 0.84764666969419977 20.837327457788724  0 1.0403632539104168 21.013744148846037  0 1.2497951278593087 21.168816999467495  0 1.7027153992168553 21.436673301263752  0 1.9471062888278112 21.548070275820514  0 2.2027042219512394 21.63294284425826  0 2.4659118514092464 21.689999446702707  0 2.7329749689204927 21.71852040554203  0 2.9999999999999991 21.718520432244532
+2 -88.88841014078244 3 -13.03017531660246 0.99793077129271612 0 -0.064297555996514377 0.064297555996514377 0 0.99793077129271612 0 -1 0 3
+1 -89.08130280877198 2.9999999999999996 -16.023967630480605 0.99793077129271601 0 -0.064297555996514807
+2 0 3 0 -0 -1 -0 -2.4492935982947064e-16 0 1 -1 0 -2.4492935982947064e-16 21.718520432244532
+2 -1.2035551156641513 3 18.679787532408248 -0.99793077129271601 0 -0.064297555996514918 -0.064297555996514918 0 0.99793077129271601 0 1 0 3
+2 -99.33996479127741 3 -14.030471919037899 0.96761875303709644 -0 0.25241622129121316 0.25241622129121316 0 -0.96761875303709644 0 1 0 3
+2 -91.01022948866742 3 -45.961890769262091 0 1 0 -0.25241622129121266 0 0.96761875303709655 0.96761875303709655 -0 0.25241622129121266 30
+1 -1.3964477836536939 2.9999999999999996 21.673579846286401 -0.99793077129271601 0 -0.064297555996514807
+2 -88.888410140782426 2.9999999999999996 13.030175316602458 -0.99793077129271601 0 -0.064297555996514807 0 -1 -0 -0.064297555996514807 -0 0.99793077129271601 3
+2 -99.339964791277424 3 14.030471919037904 -0.96761875303709666 0 0.25241622129121244 -0.25241622129121244 0 -0.96761875303709666 -0 -1 0 3
+2 -103 3 0 -0 -1 -0 0.25241622129121227 -0 0.96761875303709666 -0.96761875303709666 0 0.25241622129121227 17.5
+2 -91.01022948866742 3 45.961890769262091 0 1 0 0.064297555996514669 0 -0.99793077129271612 -0.99793077129271612 0 -0.064297555996514669 30
+2 -31.38578533597909 0.99999999999999978 -12.726825855522646 -0.99793077129271601 -0 0.064297555996514807 0 -1 -0 0.064297555996514807 0 0.99793077129271601 1
+1 -31.321487779982576 0.99999999999999967 -11.728895084229931 -0.99793077129271601 -0 0.064297555996514807
+2 -70.385785335979094 0.99999999999999978 -10.214021604967535 -0.99793077129271601 -0 0.064297555996514807 0 -1 -0 0.064297555996514807 0 0.99793077129271601 1
+2 -25 0.99999999999999978 -6.7392412277663514 0 0 -1 0 -1 0 -1 -0 -0 1
+2 -31 1 -6.7392412277663505 0 1 0 1 -0 0 0 0 -1 5
+2 -70 1 -4.2264369772112387 0 1 0 -0.064297555996515141 0 -0.99793077129271601 -0.99793077129271601 0 0.064297555996515141 5
+2 -76 1 -4.2264369772112387 -2.7755575615628914e-17 0 1 -1 0 -2.7755575615628914e-17 -0 -1 0 1
+2 -25 1 6.7392412277664029 3.6082248300317588e-16 0 -1 1 -0 3.6082248300317588e-16 0 -1 -0 1
+1 -26 0.99999999999999967 6.7392412277664011 0 0 -1
+1 -75 0.99999999999999967 -4.2264369772112396 -0 -0 1
+2 -76 0.99999999999999978 4.2264369772112893 -0 -0 1 -0 -1 -0 1 -0 0 1
+2 -31.385785335979087 0.99999999999999978 12.726825855522696 0.99793077129271601 -0 0.064297555996514807 -0 -1 0 0.064297555996514807 -0 -0.99793077129271601 1
+2 -31 1 6.7392412277664011 0 1 0 -0.064297555996515862 0 0.99793077129271601 0.99793077129271601 -0 0.064297555996515862 5
+2 -70 1 4.2264369772112893 0 1 0 -1 0 -1.7763568394002506e-16 -1.7763568394002506e-16 0 1 5
+2 -70.385785335979094 1 10.214021604967584 0.99793077129271601 -0 0.064297555996514905 -0.064297555996514905 0 0.99793077129271601 -0 -1 0 1
+1 -70.321487779982576 0.99999999999999967 9.216090833674869 0.99793077129271601 -0 0.064297555996514807
+1 -103 38 -6.4899997711181641 0 -1 -0
+2 -103 8 0 -0 1 -0 0 0 1 1 0 -0 6.4899997711181641
+1 -89.08130280877198 0 -16.023967630480609 0 1 0
+8 2.0757186272961237 3.1415926535897927
+3 -91.5 13 -15.868128846303193 0.064297555996514807 -0 0.99793077129271601 -0.99793077129271601 0 0.064297555996514807 -0 -1 0 5.0103675964646497 5
+1 -86.5 6.5 -16.190283237399925 -0 1 0
+1 -15.719401521974326 22 -20.75073935823108 -0.99793077129271601 0 0.064297555996514807
+8 3.1415926535897931 4.2074666798834626
+3 -91.5 25 -15.868128846303193 0.064297555996514807 -0 0.99793077129271601 -0.99793077129271601 0 0.064297555996514807 -0 -1 0 5.0103675964646497 5
+1 -51.434443796455199 11.801086171518966 -18.449587818844702 -0.81801347013659731 0.57277928668659528 0.052705326276168675
+1 -1.3964477836536937 0 -21.673579846286398 -0.99793077129271601 -0 0.064297555996514807
+1 -66 22 574.5 -0 -0 -1
+1 -66.064297555996518 22 10.492458857846115 0.99793077129271601 -0 0.064297555996514807
+1 20.444885378882116 22 23.080836123430274 -0.99793077129271601 0 -0.064297555996514807
+2 -31.000000000000014 22 6.7392412277664562 0 1 -0 -0.064297555996516584 0 0.9979307712927159 0.9979307712927159 0 0.064297555996516584 6
+8 3.1415926535897936 3.2059345951088924
+2 0 22 0 0 -1 -0 0 0 -1 1 0 0 21.718520432244532
+1 -25 22 6.7392412277663993 0 -0 -1
+2 -31.000000000000014 22 -6.7392412277663425 0 1 -0 1 -0 -1.9539925233402753e-15 -1.9539925233402753e-15 0 -1 6
+1 -31.385785335979104 22 -12.726825855522636 -0.99793077129271601 0 0.064297555996514807
+1 -1.3964477836536937 -0 21.673579846286398 0 1 0
+1 -98.582716127403785 0 -16.933328178149193 0 1 0
+8 3.1579190625963709 3.3967691784084915
+2 -91.01022948866742 8 -45.961890769262091 0 -1 -0 0 0 -1 1 0 0 30
+7 0 0  8 23 4  -91.5 8 -15.96588895491641  -91.434541374326017 8.0000000065025265 -15.964820156739755  -91.366705210128004 8.0009630028047116 -15.963873155810228  -91.296943979765771 8.0030467965331233 -15.963081564608244  -91.225802802056606 8.0063446201752804 -15.962469540123188  -91.153919442274798 8.0108851310796592 -15.96205178385337  -91.082024312151987 8.0166324114556904 -15.961833541806064  -91.010940469877028 8.0234859683737572 -15.961810604497476  -90.781809241834011 8.0492371980228601 -15.96233490294224  -90.63387176798274 8.0718096359267673 -15.96364598489367  -90.498347881226721 8.0974737099509504 -15.965648494805613  -90.374359177154332 8.1249160077871494 -15.968101550059203  -90.260837070348259 8.1532855091350029 -15.970844951025853  -90.156192597478778 8.182092165868891 -15.973772416759187  -90.05847050474631 8.2113085804253352 -15.976847224970758  -89.823584745208436 8.287058219792133 -15.98503308328814  -89.695502755823711 8.3336918593399183 -15.990263653643593  -89.576967964354949 8.3809877474557162 -15.99567116792727  -89.466471320359489 8.428792337953622 -16.001203390677649  -89.362504848955055 8.4770000501679394 -16.006816804318923  -89.264205675074706 8.52557340978057 -16.012489587108565  -89.170703440341484 8.5745269600542375 -16.018207469275225  -89.081302808771994 8.6239396831001347 -16.023967630480612
+1 -89.08130280877198 -0 16.023967630480609 0 1 0
+8 5.2173112808859186 6.2831853071795862
+3 -91.5 13 15.86812884630308 -0.064297555996514807 0 0.99793077129271601 0.99793077129271601 0 0.064297555996514807 0 1 -0 5.0103675964646497 5
+1 -86.5 6.5 16.190283237399814 0 1 -0
+8 0 1.0658740262936681
+3 -91.5 25 15.86812884630308 -0.064297555996514807 0 0.99793077129271601 0.99793077129271601 0 0.064297555996514807 0 1 -0 5.0103675964646497 5
+1 -27.134795508421615 -5.2137133657439731 20.015235498464278 -0.81801347013659731 0.57277928668659528 -0.052705326276168675
+1 -1.3964477836536937 -0 21.673579846286398 -0.99793077129271601 0 -0.064297555996514807
+8 2.8864161287710948 6.5383618319982846
+2 -103 8 0 0 -1 -0 0 0 -1 1 0 0 17.5
+1 -98.582716127403785 -0 16.933328178149193 0 1 0
+7 0 0  5 10 3  -91.5 8 15.965888954916412  -91.263261644944265 8.000000023517094 15.962023528173592  -90.993365833668534 8.0155239049207037 15.960222303175367  -90.737809761431393 8.0487030744765011 15.961552446405639  -90.521123453028125 8.0934107970305629 15.965360037566239  -89.973441897875347 8.2234575841520847 15.97750986778791  -89.710129189209866 8.3220033398570568 15.988872048079587  -89.46914397259502 8.4211953088539673 16.000236791462445  -89.268063218529136 8.520715128180786 16.011934493263347  -89.08130280877198 8.6239396831001418 16.023967630480609
+8 6.0280087823608879 6.266858898173008
+2 -91.01022948866742 8 45.961890769262091 0 -1 -0 0 0 -1 1 0 0 30
+1 -31.321487779982576 0 -11.728895084229929 0 1 0
+1 -15.205021074002211 0 -12.767293187889351 -0.99793077129271601 -0 0.064297555996514807
+1 -70.321487779982576 0 -9.2160908336748193 0 1 0
+1 -26 0 -6.7392412277663505 0 1 0
+2 -31 0 -6.7392412277663505 -0 1 0 0 0 1 1 0 -0 5
+2 -70 0 -4.2264369772112387 -0 1 0 0 0 1 1 0 -0 5
+1 -75 0 -4.2264369772112387 0 1 0
+1 -26 0 6.7392412277664011 0 1 0
+1 -26 0 0 0 0 -1
+1 -75 0 4.2264369772112893 0 1 0
+1 -75 0 26.238765716552731 0 0 -1
+1 -31.321487779982576 0 11.728895084229981 0 1 0
+2 -31 0 6.7392412277664011 -0 1 0 0 0 1 1 0 -0 5
+2 -70 0 4.2264369772112893 -0 1 0 0 0 1 1 0 -0 5
+1 -70.321487779982576 0 9.216090833674869 0 1 0
+1 20.959265826854235 0 15.097389953088545 -0.99793077129271601 0 -0.064297555996514807
+1 -91.5 8 553.5 -0 -0 -1
+1 -86.5 13 553.5 -0 -0 -1
+1 -86.5 25 553.5 -0 -0 -1
+7 0 0  5 10 3  -89.08130280877198 29.37606031689986 16.023967630480609  -89.259633942253458 29.474625917102948 16.012477598936542  -89.452382898690104 29.570240895931327 16.001253756438459  -89.678538857621305 29.665246688253191 15.990317805686034  -89.927711713422596 29.759172958112348 15.979518902886527  -90.449684847629072 29.892115198858253 15.966564909889993  -90.67496027773538 29.939847395214837 15.962449062760347  -90.942031014068149 29.983065042295571 15.959603568327786  -91.241751953157646 29.999999974346178 15.961672321298629  -91.5 30 15.965888954916407
+7 0 0  8 23 4  -91.5 30 -15.965888954916407  -91.434541374290106 29.999999993497479 -15.96482015673916  -91.366705210052345 29.999036997194203 -15.963873155809166  -91.29694397964839 29.99695320346337 -15.96308156460691  -91.22580280189689 29.993655379817344 -15.962469540121809  -91.153919442073587 29.989114868907659 -15.962051783852194  -91.082024311911297 29.983367588525066 -15.961833541805325  -91.010940469599888 29.976514031599471 -15.961810604497382  -90.781809241530667 29.95076280193296 -15.962334902944578  -90.633871767699205 29.928190364022328 -15.963645984897452  -90.498347880954213 29.902526289992892 -15.965648494810209  -90.374359176904576 29.875083992153794 -15.968101550064894  -90.260837070107243 29.846714490803496 -15.970844951031767  -90.15619259724599 29.8179078340657 -15.973772416765902  -90.058470504524379 29.788691419507728 -15.976847224977826  -89.823584745039284 29.712941780146252 -15.985033083295054  -89.695502755689489 29.666308140606446 -15.990263653649677  -89.576967964247459 29.619012252498393 -15.995671167932652  -89.466471320284555 29.571207662010448 -16.001203390681752  -89.362504848897572 29.522999949804664 -16.006816804322156  -89.26420567503925 29.474426590200522 -16.012489587110764  -89.170703440324687 29.425473039936481 -16.018207469276305  -89.081302808771994 29.376060316899867 -16.023967630480609
+1 -91.5 30 553.5 -0 -0 -1
+8 3.149695980065613 3.1865839120445938
+3 -64.571852214020126 21 10.58861842192405 0.5735764958448768 0.81915200263095989 -0 0.81662977567304285 -0.57181041324286763 0.078413396758568135 0.064232490987877117 -0.04497608134007354 -0.99692092926609954 1.7470616849752154 1
+1 -70.363097533562168 25.055074255195908 10.178527362648873 0.81801347013659731 -0.57277928668659528 0.052705326276168675
+1 -88.850364575678142 38 287.25 -0 0 -1
+7 1 0  8 16 3  -75.426423504155125 28.600453816260661 4.2264369772108239  1 -75.42642350415521 28.600453816260718 5.2876352121921624  1.0000000000000138 -75.211820342941166 28.450187041826869 6.3489508821416987  0.99999999999995814 -74.78196477965119 28.149198889543261 7.3581059440514682  1.0000000000000713 -74.154733406968063 27.710006686298922 8.2662369368088306  0.9999999999999214 -73.354340930765474 27.149565754302845 9.0241834935736556  1.00000000000006 -72.430819030068477 26.50290865777324 9.6068027099519266  0.99999999999996914 -71.410806611778753 25.788688163015483 9.983741799435192  1.0000000000000091 -70.289310046063775 25.003407692237385 10.161719740062058  0.99999999999999889 -70.224593018462542 24.95809233465566 10.172015921313045  1.00000000000001 -70.156243994721805 24.910233825605182 10.181631715591825  0.99999999999997791 -70.087185609913249 24.861878616510964 10.190172602424408  1.0000000000000251 -70.018797260414871 24.813992571264215 10.197611994054746  0.99999999999998046 -69.94984475393278 24.765711498983773 10.204141717367339  1.0000000000000107 -69.881069926812586 24.717554839151127 10.209584824677723  0.99999999999999645 -69.812208840134105 24.669337779716177 10.21402160496757  1
+1 -75.426423504155125 28.600453816260657 -4.2264369772112218 -0 0 1
+7 1 0  8 16 3  -69.812208840134289 24.669337779716304 -10.21402160496757  1 -69.881069926812856 24.717554839151315 -10.209584824677741  0.99999999999998312 -69.949844753932922 24.765711498983862 -10.204141717367161  1.0000000000000571 -70.018797260414786 24.813992571264187 -10.197611994054524  0.99999999999990374 -70.087185609913547 24.861878616511124 -10.190172602424237  1.0000000000001015 -70.156243994721834 24.910233825605243 -10.181631715592218  0.9999999999999285 -70.224593018462599 24.958092334655689 -10.172015921312724  1.0000000000000311 -70.289310046063974 25.003407692237523 -10.161719740062065  0.99999999999999556 -71.410806611779364 25.788688163015912 -9.9837417994349558  1.0000000000000102 -72.430819030065649 26.502908657771282 -9.6068027099525501  0.99999999999997158 -73.354340930769524 27.149565754305655 -9.0241834935724512  1.0000000000000486 -74.154733406964468 27.710006686296381 -8.266236936810845  0.99999999999994871 -74.781964779652824 28.149198889544412 -7.3581059440496315  1.0000000000000357 -75.211820342940754 28.450187041826581 -6.3489508821431686  0.99999999999998423 -75.426423504155125 28.600453816260661 -5.287635212191538  1.0000000000000038 -75.426423504155125 28.600453816260661 -4.2264369772112786  1
+8 0.0081033264759815538 0.044991258454836647
+3 -64.571852214020126 21 -10.588618421923979 -0.5735764958448768 -0.81915200263095989 0 -0.81662977567304285 0.57181041324286763 0.078413396758568149 -0.064232490987877131 0.044976081340073547 -0.99692092926609954 1.7470616849752154 1
+1 -66.041609753579593 22.029135467623227 -10.456964615527465 -0.81801347013659731 0.57277928668659528 0.052705326276168675
+2 -91.01022948866742 30 -45.961890769262091 0 -1 -0 0 0 -1 1 0 0 30
+2 -91.01022948866742 0 -45.961890769262091 -0 1 0 0 0 1 1 0 -0 30
+2 -103 -0 0 -0 1 0 0 0 1 1 0 -0 17.5
+2 -91.01022948866742 -0 45.961890769262091 -0 1 0 0 0 1 1 0 -0 30
+2 -103 38 0 0 -1 -0 0 0 -1 1 0 0 6.4899997711181641
+8 1.5707963267948966 3.1047047216108528
+3 -66.315298828803378 21 10.476286625404947 0.95188934164484695 -0.30024187178939399 0.061331066249827641 -0.29962060268915874 -0.95386310255948215 -0.019304818563876985 0.064297555996514821 3.469446951953615e-18 -0.99793077129271601 1.0483684685115922 1
+1 -66 21 9.4945280865533999 0.99793077129271601 -0 0.064297555996514807
+2 -31.385785335979101 21 12.726825855522709 -0.99793077129271601 0 -0.064297555996514807 0 1 0 0.064297555996514807 0 -0.99793077129271601 1
+2 -31.000000000000014 21 6.7392412277664562 0 1 -0 -0.064297555996516584 0 0.9979307712927159 0.9979307712927159 0 0.064297555996516584 5
+2 -25.000000000000014 21 6.7392412277664624 -1.0963452368173421e-15 0 1 1 0 1.0963452368173421e-15 0 1 -0 1
+1 -26 21 6.7392412277663993 0 -0 -1
+2 -25 21 -6.7392412277663531 -0 0 1 0 1 0 -1 0 -0 1
+2 -31.000000000000014 21 -6.7392412277663425 0 1 -0 1 -0 -1.9539925233402753e-15 -1.9539925233402753e-15 0 -1 5
+2 -31.385785335979115 21 -12.726825855522637 0.9979307712927159 -0 -0.064297555996517 -0.064297555996517 0 -0.9979307712927159 0 1 0 1
+8 4.7123889803846897 6.2462973752006485
+3 -66.315298828803378 21 -10.47628662540502 -0.95188934164484695 0.30024187178939399 0.061331066249827641 0.29962060268915874 0.95386310255948215 -0.019304818563876985 -0.064297555996514821 -3.469446951953615e-18 -0.99793077129271601 1.0483684685115922 1
+1 -31.32148777998259 21 -11.72889508422992 -0.99793077129271601 0 0.064297555996514807
+2 -91.01022948866742 30 45.961890769262091 0 -1 -0 0 0 -1 1 0 0 30
+2 -103 30 0 0 -1 -0 0 0 -1 1 0 0 17.5
+2 -103 30 0 -0 1 -0 0 0 1 1 0 -0 6.4899997711181641
+7 1 0  2 3 2  -69.812208840134105 24.669337779716177 10.21402160496757  1 -69.770599086554512 24.640202312092946 9.2515850759935496  0.72002762685186827 -70.321487779982533 23.850185777085247 9.2160908336748708  1
+ 0 3 9.0233233592510942 3
+1 -70.872376473410526 24.235922252564947 9.1805965913561565 0.81801347013659731 -0.57277928668659528 0.052705326276168675
+2 -76 27.781301813629696 4.2264369772112893 0 -0 -1 0.5735764958448768 0.81915200263095989 0 0.81915200263095989 -0.5735764958448768 0 1
+7 1 0  8 16 3  -75 27.7813018136297 4.2264369772112884  1 -74.999999999999986 27.781301813629685 5.0993290856818687  1.0000000000000138 -74.825893282220918 27.635162118410385 5.9723070167389984  0.99999999999995814 -74.477286187586827 27.342532935907446 6.8056290682384741  1.0000000000000713 -73.965345330958243 26.912722518645431 7.5625490182697854  0.9999999999999214 -73.305963203397894 26.358625422767815 8.1967325675297165  1.00000000000006 -72.546083974716481 25.720452713630802 8.6847160173410547  0.99999999999996914 -71.707679730999359 25.015708542475345 9.008052571908399  1.0000000000000091 -70.773140232988439 24.230031301117396 9.1667248105252916  0.99999999999999889 -70.708502545898824 24.175538601969169 9.176726505690203  1.00000000000001 -70.644158270646159 24.121412872535021 9.1856800330604003  0.99999999999997791 -70.579742380749209 24.067245211172928 9.1936786075772901  1.0000000000000251 -70.515198941104956 24.012967647597918 9.2007326090571429  0.99999999999998046 -70.450696970111878 23.958761255563953 9.2068035339867276  1.0000000000000107 -70.386108747514271 23.904483491789108 9.2119272479854182  0.99999999999999645 -70.321487779982533 23.850185777085247 9.2160908336748708  1
+7 1 0  2 3 2  -75.426423504155125 28.600453816260661 -4.2264369772112786  1 -75.000000000000028 28.301868818026364 -4.2264369772112538  0.88701084994628931 -75 27.7813018136297 -4.2264369772112413  1
+ 0 3 9.0233233592529061 3
+1 -75 27.781301813629696 -4.2264369772112218 -0 0 1
+2 -70.385785335979094 23.850185777085294 -10.214021604967627 0.81801347013659731 -0.57277928668659528 -0.052705326276168675 0.5735764958448768 0.81915200263096 3.4694469519536142e-18 0.043173673568441727 -0.030230536357845741 0.99861010839172004 1
+7 1 0  8 16 3  -70.32148777998259 23.850185777085301 -9.2160908336748193  1 -70.386108747514342 23.904483491789179 -9.2119272479853596  0.99999999999998312 -70.450696970112119 23.958761255564141 -9.206803533986669  1.0000000000000571 -70.515198941104941 24.012967647597875 -9.2007326090570807  0.99999999999990374 -70.579742380749295 24.067245211172985 -9.1936786075772616  1.0000000000001015 -70.644158270646344 24.121412872535235 -9.1856800330603026  0.9999999999999285 -70.70850254589871 24.175538601969052 -9.1767265056901799  1.0000000000000311 -70.773140232988425 24.230031301117371 -9.1667248105252437  0.99999999999999556 -71.707679731001065 25.015708542476943 -9.008052571908074  1.0000000000000102 -72.546083974710868 25.720452713625512 -8.6847160173418239  0.99999999999997158 -73.305963203405796 26.358625422775354 -8.1967325675292368  1.0000000000000486 -73.96534533095128 26.912722518638805 -7.5625490182693733  0.99999999999994871 -74.477286187590352 27.342532935910757 -6.8056290682397158  1.0000000000000357 -74.82589328221988 27.635162118409465 -5.9723070167378731  0.99999999999998423 -74.999999999999986 27.781301813629696 -5.099329085682764  1.0000000000000038 -75 27.7813018136297 -4.2264369772112413  1
+1 -66.55088869342795 21.209983464992266 -9.4590338442347495 -0.81801347013659731 0.57277928668659528 0.052705326276168675
+1 -31.32148777998259 38 11.728895084229979 -0 -1 -0
+1 20.959265826854235 38 15.097389953088545 -0.99793077129271601 0 -0.064297555996514807
+1 -70.321487779982576 38 9.216090833674869 -0 -1 -0
+2 -31.000000000000014 38 6.7392412277664002 -0 1 0 0 0 1 1 0 -0 5
+1 -26.000000000000014 38 6.7392412277664002 -0 -1 -0
+1 -26 38 0 0 0 -1
+1 -26.000000000000014 38 -6.7392412277663523 -0 -1 -0
+2 -31.000000000000014 38 -6.7392412277663523 -0 1 0 0 0 1 1 0 -0 5
+1 -31.32148777998259 38 -11.728895084229933 -0 -1 -0
+1 -15.205021074002218 38 -12.767293187889351 -0.99793077129271601 -0 0.064297555996514807
+1 -70.321487779982576 38 -9.2160908336748193 -0 -1 -0
+1 -75 38 4.2264369772112884 -0 -1 -0
+2 -70 38 4.2264369772112884 -0 1 0 0 0 1 1 0 -0 5
+1 -75 38 26.238765716552731 0 0 -1
+1 -75 38 -4.2264369772112405 -0 -1 -0
+2 -70 38 -4.2264369772112405 -0 1 0 0 0 1 1 0 -0 5
+Polygon3D 0
+PolygonOnTriangulations 270
+2 3 7
+p 4.37297639619471 1 -18.7573336454959 18.7185204322445
+5 1 6 7 8 5
+p 8.92918231109263 1 -0 22.2681804935318 44.5363609870636 66.8045414805954 89.0727219741272
+4 2 5 6 4
+p 0.481671362759695 1 -2.44929359829471e-16 0.0214473138396995 0.0428946276793992 0.0643419415190989
+4 1 10 11 12
+p 1.43247104438797 1 -2.44929359829471e-16 0.0214473138396995 0.0428946276793992 0.0643419415190989
+4 1 6 7 5
+p 1.05863657228006 1 0 0.106506155445932 0.213012310891865 0.319518466337797
+5 1 10 11 12 9
+p 8.78936407444438 1 2.22044604925031e-16 21.9666678159277 43.9333356318553 65.900003447783 87.8666712637106
+24 1 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 5
+p 3.66570048900402 1 8.88178419700125e-16 0.1587802479664 0.3175604959328 0.4763407438992 0.635120991865599 0.793901239831999 0.952681487798398 1.1114617357648 1.2702419837312 1.4290222316976 1.587802479664 1.7465827276304 1.9053629755968 2.0641432235632 2.22292347152959 2.38170371949599 2.54048396746239 2.69926421542879 2.85804446339519 3.01682471136159 3.17560495932799 3.33438520729439 3.49316545526079 3.65194570322719
+4 1 6 7 5
+5 1 6 7 8 5
+p 3.90695953731085 1 0 9.77021681310607 19.5404336262121 29.3106504393182 39.0808672524243
+13 1 6 7 8 9 10 11 12 13 14 15 16 5
+p 0.691192444040531 1 0 0.1362615223595 0.272523044718999 0.408784567078499 0.545046089437999 0.681307611797498 0.817569134156998 0.953830656516497 1.090092178876 1.2263537012355 1.362615223595 1.4988767459545 1.635138268314
+12 1 6 7 8 9 10 11 12 13 14 15 5
+p 0.648091509967405 1 -4.44089209850063e-16 0.136950398661436 0.273900797322872 0.410851195984308 0.547801594645744 0.68475199330718 0.821702391968617 0.958652790630053 1.09560318929149 1.23255358795293 1.36950398661436 1.5064543852758
+5 1 6 7 8 5
+p 1.34784826555328 1 0 3.36962061388319 6.73924122776638 10.1088618416496 13.4784824555328
+5 1 6 7 8 5
+p 0.845287415442253 1 -0 2.11321848860563 4.22643697721126 6.3396554658169 8.45287395442253
+p 0.691192444040532 1 0 0.1362615223595 0.272523044718999 0.408784567078499 0.545046089437999 0.681307611797499 0.817569134156998 0.953830656516498 1.090092178876 1.2263537012355 1.362615223595 1.4988767459545 1.635138268314
+p 0.648091509967405 1 0 0.136950398661436 0.273900797322872 0.410851195984308 0.547801594645745 0.684751993307181 0.821702391968617 0.958652790630053 1.09560318929149 1.23255358795293 1.36950398661436 1.5064543852758
+5 1 6 7 8 5
+p 3.90695953731085 1 7.105427357601e-15 9.77021681310607 19.5404336262121 29.3106504393182 39.0808672524243
+49 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 2
+p 1.40494504643154 1 3.14159265358979 3.27249234748937 3.40339204138894 3.53429173528852 3.66519142918809 3.79609112308767 3.92699081698724 4.05789051088682 4.18879020478639 4.31968989868596 4.45058959258554 4.58148928648511 4.71238898038469 4.84328867428426 4.97418836818384 5.10508806208341 5.23598775598299 5.36688744988256 5.49778714378214 5.62868683768171 5.75958653158128 5.89048622548086 6.02138591938043 6.15228561328001 6.28318530717958 6.41408500107916 6.54498469497873 6.67588438887831 6.80678408277788 6.93768377667746 7.06858347057703 7.1994831644766 7.33038285837618 7.46128255227575 7.59218224617533 7.7230819400749 7.85398163397448 7.98488132787405 8.11578102177363 8.2466807156732 8.37758040957278 8.50848010347235 8.63937979737193 8.7702794912715 8.90117918517108 9.03207887907065 9.16297857297023 9.29387826686981 9.42477796076938
+2 1 2
+p 4.37297639619471 1 3 22
+2 6 10
+p 8.9081303008772 1 3 22
+4 3 4 5 1
+p 1.30156395368266 1 4.71238898038469 5.23598775598299 5.75958653158129 6.28318530717959
+4 5 13 14 9
+p 3.8682842022183 1 4.71238898038469 5.23598775598299 5.75958653158129 6.28318530717959
+2 2 6
+p 4.37297639619471 1 -298.131777101687 -254.649702466068
+2 12 8
+p 6.60000002 1 -298.131777101687 -254.649702466068
+5 6 12 13 14 9
+p 1.90000002 1 3 7.75 12.5 17.25 22
+9 1 3 4 5 6 7 8 9 2
+p 0.517556951473548 1 0 0.135 0.27 0.405 0.54 0.675 0.81 0.905 1
+4 1 3 4 2
+p 1.29887072035087 1 1.5707963267949 2.0943951023932 2.61799387799149 3.14159265358979
+4 5 11 12 8
+p 1.45127597723772 1 1.5707963267949 2.0943951023932 2.61799387799149 3.14159265358979
+5 2 10 11 12 9
+p 8.92918231109263 1 -0 22.3165036521963 44.6330073043927 66.949510956589 89.2660146087853
+5 1 3 4 5 6
+p 10.0594062581149 1 -0 22.3165036521963 44.6330073043927 66.949510956589 89.2660146087853
+4 2 14 15 13
+p 0.517556951473548 1 -2.44929359829471e-16 0.0214473138396995 0.0428946276793992 0.0643419415190989
+4 6 7 8 1
+p 1.1556074932232 1 -2.44929359829471e-16 0.0214473138396995 0.0428946276793992 0.0643419415190989
+8 12 16 17 18 19 20 21 13
+p 0.517556951473548 1 4.71238898038469 4.9367884556411 5.16118793089752 5.38558740615393 5.60998688141034 5.83438635666676 6.05878583192317 6.28318530717959
+8 1 2 3 4 5 6 7 8
+p 1.79702837976172 1 4.71238898038469 4.9367884556411 5.16118793089752 5.38558740615393 5.60998688141034 5.83438635666676 6.05878583192317 6.28318530717959
+4 1 3 4 2
+p 1.05863657228006 1 4.71238898038469 5.23598775598299 5.75958653158129 6.28318530717959
+4 5 55 56 28
+p 2.12543713881558 1 4.71238898038469 5.23598775598299 5.75958653158129 6.28318530717959
+4 2 9 10 8
+4 1 6 7 8
+p 1.18150061656707 1 0 0.106506155445932 0.213012310891865 0.319518466337797
+5 8 14 15 16 13
+5 3 4 5 6 1
+p 9.80221686496189 1 2.22044604925031e-16 21.9666678159277 43.9333356318553 65.900003447783 87.8666712637106
+4 9 17 18 13
+p 1.29887072035087 1 0 0.523598775598299 1.0471975511966 1.5707963267949
+4 1 2 3 4
+p 1.33373136245007 1 0 0.523598775598299 1.0471975511966 1.5707963267949
+4 5 11 12 8
+p 1.05863657228006 1 1.5707963267949 2.0943951023932 2.61799387799149 3.14159265358979
+28 2 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 28
+p 3.66570048900402 1 8.88178419700125e-16 0.135257248267675 0.270514496535348 0.405771744803022 0.541028993070696 0.676286241338369 0.811543489606043 0.946800737873717 1.08205798614139 1.21731523440906 1.35257248267674 1.48782973094441 1.62308697921209 1.75834422747976 1.89360147574743 2.02885872401511 2.16411597228278 2.29937322055045 2.43463046881813 2.5698877170858 2.70514496535347 2.84040221362115 2.97565946188882 3.1109167101565 3.24617395842417 3.38143120669184 3.51668845495952 3.65194570322719
+28 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 1
+p 4.03737375652102 1 8.88178419700125e-16 0.135257248267675 0.270514496535348 0.405771744803022 0.541028993070696 0.676286241338369 0.811543489606043 0.946800737873717 1.08205798614139 1.21731523440906 1.35257248267674 1.48782973094441 1.62308697921209 1.75834422747976 1.89360147574743 2.02885872401511 2.16411597228278 2.29937322055045 2.43463046881813 2.5698877170858 2.70514496535347 2.84040221362115 2.97565946188882 3.1109167101565 3.24617395842417 3.38143120669184 3.51668845495952 3.65194570322719
+4 4 9 10 8
+4 1 6 7 8
+p 1.17562338582769 1 0 0.106506155445932 0.213012310891865 0.319518466337797
+4 1 3 4 2
+p 0.432956960116958 1 0 0.523598775598299 1.0471975511966 1.5707963267949
+4 5 27 28 17
+p 0.691192444040531 1 0 0.523598775598299 1.0471975511966 1.5707963267949
+5 2 10 11 12 9
+5 1 3 4 5 6
+p 4.33399164974278 1 0 9.77021681310607 19.5404336262121 29.3106504393182 39.0808672524243
+4 5 13 14 9
+4 1 2 3 4
+p 0.648091509967405 1 0 0.523598775598299 1.0471975511966 1.5707963267949
+4 1 3 4 2
+4 5 13 14 9
+p 0.901306858447711 1 0 0.523598775598299 1.0471975511966 1.5707963267949
+11 2 18 19 20 21 22 23 24 25 26 17
+p 0.691192444040531 1 0 0.1635138268314 0.327027653662799 0.490541480494199 0.654055307325598 0.817569134156998 0.981082960988398 1.1445967878198 1.3081106146512 1.4716244414826 1.635138268314
+11 1 6 7 8 9 10 11 12 13 14 15
+p 0.657475492610185 1 0 0.1635138268314 0.327027653662799 0.490541480494199 0.654055307325598 0.817569134156998 0.981082960988398 1.1445967878198 1.3081106146512 1.4716244414826 1.635138268314
+10 4 17 18 19 20 21 22 23 24 16
+p 0.648091509967405 1 -4.44089209850063e-16 0.167383820586199 0.334767641172399 0.502151461758599 0.669535282344799 0.836919102930998 1.0043029235172 1.1716867441034 1.3390705646896 1.5064543852758
+10 1 6 7 8 9 10 11 12 13 14
+p 0.617826960147317 1 -4.44089209850063e-16 0.167383820586199 0.334767641172399 0.502151461758599 0.669535282344799 0.836919102930998 1.0043029235172 1.1716867441034 1.3390705646896 1.5064543852758
+4 5 25 26 16
+p 0.432956960116958 1 1.5707963267949 2.0943951023932 2.61799387799149 3.14159265358979
+4 1 2 3 4
+p 0.845287415442253 1 1.5707963267949 2.0943951023932 2.61799387799149 3.14159265358979
+4 1 3 4 2
+4 5 27 28 17
+p 0.691192444040532 1 1.5707963267949 2.0943951023932 2.61799387799149 3.14159265358979
+5 2 10 11 12 9
+5 1 3 4 5 6
+p 1.54934626303684 1 0 3.36962061388319 6.73924122776638 10.1088618416496 13.4784824555328
+5 4 10 11 12 9
+5 3 4 5 6 1
+p 0.993728355764439 1 -0 2.11321848860563 4.22643697721126 6.3396554658169 8.45287395442253
+4 5 13 14 9
+4 1 2 3 4
+4 1 3 4 2
+4 5 13 14 9
+p 0.691192444040532 1 0 0.1635138268314 0.327027653662799 0.490541480494199 0.654055307325599 0.817569134156998 0.981082960988398 1.1445967878198 1.3081106146512 1.4716244414826 1.635138268314
+p 0.657475492610185 1 0 0.1635138268314 0.327027653662799 0.490541480494199 0.654055307325599 0.817569134156998 0.981082960988398 1.1445967878198 1.3081106146512 1.4716244414826 1.635138268314
+p 0.648091509967405 1 0 0.1673838205862 0.334767641172399 0.502151461758599 0.669535282344799 0.836919102930999 1.0043029235172 1.1716867441034 1.3390705646896 1.5064543852758
+10 1 3 4 5 6 7 8 9 10 11
+p 0.617826960147317 1 0 0.1673838205862 0.334767641172399 0.502151461758599 0.669535282344799 0.836919102930999 1.0043029235172 1.1716867441034 1.3390705646896 1.5064543852758
+4 5 25 26 16
+4 1 2 3 4
+p 0.875446298003835 1 1.5707963267949 2.0943951023932 2.61799387799149 3.14159265358979
+5 4 10 11 12 9
+5 6 7 8 9 1
+p 4.37953361155366 1 7.105427357601e-15 9.77021681310607 19.5404336262121 29.3106504393182 39.0808672524243
+5 1 3 4 5 2
+p 1.40494504643154 1 30 32 34 36 38
+5 6 102 103 104 54
+49 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 1
+49 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 35
+p 3.78837272102338 1 3.14159265358979 3.27249234748937 3.40339204138894 3.53429173528852 3.66519142918809 3.79609112308767 3.92699081698724 4.05789051088682 4.18879020478639 4.31968989868596 4.45058959258554 4.58148928648511 4.71238898038469 4.84328867428426 4.97418836818384 5.10508806208341 5.23598775598299 5.36688744988256 5.49778714378214 5.62868683768171 5.75958653158128 5.89048622548086 6.02138591938043 6.15228561328001 6.28318530717958 6.41408500107916 6.54498469497873 6.67588438887831 6.80678408277788 6.93768377667746 7.06858347057703 7.1994831644766 7.33038285837618 7.46128255227575 7.59218224617533 7.7230819400749 7.85398163397448 7.98488132787405 8.11578102177363 8.2466807156732 8.37758040957278 8.50848010347235 8.63937979737193 8.7702794912715 8.90117918517108 9.03207887907065 9.16297857297023 9.29387826686981 9.42477796076938
+5 8 13 14 15 12
+p 0.964622695531489 1 3 4.40598492077503 5.81196984155007 7.2179547623251 8.62393968310013
+4 2 8 9 7
+p 1.89464550200859 1 2.07571862729612 2.54658240195908 2.84408752777443 3.14159265358979
+4 8 12 13 14
+p 3.23825986622486 1 2.07571862729612 2.54658240195908 2.84408752777443 3.14159265358979
+2 5 7
+p 3.23805666747998 1 6.5 18.5
+2 12 16
+p 6.60000002 1 -15.7519960043035 50.3848562690299
+4 11 14 15 13
+p 1.89464550200859 1 3.14159265358979 3.61189735893276 3.90968201940811 4.20746667988346
+4 2 6 7 8
+p 3.23869078742326 1 3.14159265358979 3.61189735893276 3.90968201940811 4.20746667988346
+2 13 8
+p 3.50222326817937 1 17.8060102129034 45.7399812413541
+5 14 15 16 17 9
+p 0.964622695531969 1 29.3760603168999 31.5320452376749 33.6880301584499 35.844015079225 38
+2 16 17
+p 0.092375373237536 1 87.635254175735 87.8666712637106
+2 1 2
+p 3.78837272102338 1 87.635254175735 87.8666712637106
+2 1 2
+p 2.80580593402022 1 556.988883759103 564.003398394154
+2 1 2
+p 3.50222326817937 1 556.988883759103 564.003398394154
+5 12 16 17 18 13
+p 3.5000452165836 1 0.064430878219365 8.73592785470346 17.4074248311876 26.0789218076716 34.7504187841557
+2 4 1
+p 6.60000002 1 21.8866215882316 86.6241305164904
+2 13 15
+p 8.76848552251183 1 21.8866215882316 86.6241305164904
+p 0.691192444040533 1 0 0.1362615223595 0.272523044718999 0.408784567078499 0.545046089437999 0.681307611797499 0.817569134156998 0.953830656516498 1.090092178876 1.2263537012355 1.362615223595 1.4988767459545 1.635138268314
+4 8 9 10 4
+p 0.558868468606631 1 3.14159265358979 3.16303996742949 3.18448728126919 3.20593459510889
+4 9 10 11 2
+p 1.90000002 1 3.14159265358979 3.16303996742949 3.18448728126919 3.20593459510889
+5 1 6 7 8 5
+p 1.34784826555328 1 -8.88178419700125e-16 3.36962061388319 6.73924122776638 10.1088618416496 13.4784824555328
+p 0.691192444040533 1 0 0.1362615223595 0.272523044718999 0.408784567078499 0.545046089437999 0.681307611797498 0.817569134156998 0.953830656516497 1.090092178876 1.2263537012355 1.362615223595 1.4988767459545 1.635138268314
+5 13 16 17 18 12
+p 3.50004521658397 1 -3.5527136788005e-15 8.67149697648409 17.3429939529682 26.0144909294523 34.6859879059364
+2 17 16
+p 2.80580593402022 1 584.996601605846 592.011116240897
+2 15 13
+p 3.50222326817937 1 584.996601605846 592.011116240897
+5 1 3 4 5 2
+5 3 10 11 12 13
+p 8.76848552251183 1 3 7.75 12.5 17.25 22
+5 1 3 4 5 2
+p 0.964622695531489 1 3 4.25 5.5 6.75 8
+5 1 2 3 4 5
+p 2.80639862379089 1 3 4.25 5.5 6.75 8
+4 9 10 11 2
+p 0.964622695531489 1 3.15791906259637 3.23753576786708 3.31715247313778 3.39676917840849
+4 2 6 7 8
+p 3.6394850747524 1 3.15791906259637 3.23753576786708 3.31715247313778 3.39676917840849
+4 9 16 17 12
+p 0.964622695531489 1 0 0.444444444444444 0.722222222222222 1
+4 2 6 7 8
+p 1.77387750028208 1 0 0.444444444444444 0.722222222222222 1
+5 1 3 4 5 2
+p 0.965119537598682 1 3 4.40598492077504 5.81196984155007 7.21795476232511 8.62393968310014
+4 2 8 9 7
+p 1.89464550200859 1 5.21731128088592 5.68817505554888 5.98568018136423 6.28318530717959
+4 5 9 10 11
+p 3.23825986622486 1 5.21731128088592 5.68817505554888 5.98568018136423 6.28318530717959
+2 1 6
+4 14 17 18 16
+p 1.89464550200859 1 0 0.470304705342964 0.768089365818316 1.06587402629367
+4 1 3 4 5
+p 3.23869078742326 1 0 0.470304705342964 0.768089365818316 1.06587402629367
+2 1 6
+p 3.50222326817937 1 47.5116925459533 75.445663574404
+5 1 3 4 5 2
+p 0.963671960437347 1 29.3760603168999 31.5320452376749 33.6880301584499 35.844015079225 38
+2 19 20
+p 0.0923753732375417 1 87.635254175735 87.8666712637106
+2 3 7
+28 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 5
+p 3.78837273602338 1 2.88641612877109 3.02167337703877 3.15693062530644 3.29218787357412 3.42744512184179 3.56270237010946 3.69795961837714 3.83321686664481 3.96847411491248 4.10373136318016 4.23898861144783 4.3742458597155 4.50950310798318 4.64476035625085 4.78001760451852 4.9152748527862 5.05053210105387 5.18578934932154 5.32104659758922 5.45630384585689 5.59156109412456 5.72681834239224 5.86207559065991 5.99733283892758 6.13259008719526 6.26784733546293 6.4031045837306 6.53836183199828
+28 3 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 8
+p 4.13119557447906 1 2.88641612877109 3.02167337703877 3.15693062530644 3.29218787357412 3.42744512184179 3.56270237010946 3.69795961837714 3.83321686664481 3.96847411491248 4.10373136318016 4.23898861144783 4.3742458597155 4.50950310798318 4.64476035625085 4.78001760451852 4.9152748527862 5.05053210105387 5.18578934932154 5.32104659758922 5.45630384585689 5.59156109412456 5.72681834239224 5.86207559065991 5.99733283892758 6.13259008719526 6.26784733546293 6.4031045837306 6.53836183199828
+5 8 13 14 15 12
+p 0.965119537598682 1 3 4.25 5.5 6.75 8
+4 9 10 11 2
+p 0.965119537598682 1 0 0.444444444444444 0.722222222222222 1
+4 1 3 4 5
+p 1.77325512228679 1 0 0.444444444444444 0.722222222222222 1
+4 12 16 17 9
+p 0.965119537598682 1 6.02800878236089 6.10762548763159 6.1872421929023 6.26685889817301
+4 3 4 5 1
+p 3.6388626967571 1 6.02800878236089 6.10762548763159 6.1872421929023 6.26685889817301
+5 15 27 28 29 16
+p 0.60000002 1 1 2.5 4 5.5 7
+2 2 7
+p 3.90000002 1 16.1498845106291 55.2307517630534
+2 1 2
+p 4.98239222029239 1 16.1498845106291 55.2307517630534
+5 1 3 4 5 2
+5 1 3 4 5 2
+5 6 8 9 10 7
+p 1.34784826555328 1 1 2.5 4 5.5 7
+12 2 17 18 19 20 21 22 23 24 25 26 16
+p 0.60000002 1 1.5707963267949 1.71944526027799 1.86809419376108 2.01674312724417 2.16539206072726 2.31404099421035 2.46268992769344 2.61133886117653 2.75998779465962 2.90863672814271 3.0572856616258 3.20593459510889
+12 3 4 5 6 7 8 9 10 11 12 13 1
+p 2.62009022251507 1 1.5707963267949 1.71944526027799 1.86809419376108 2.01674312724417 2.16539206072726 2.31404099421035 2.46268992769344 2.61133886117653 2.75998779465962 2.90863672814271 3.0572856616258 3.20593459510889
+11 2 16 17 18 19 20 21 22 23 24 15
+p 0.60000002 1 3.20593459510889 3.35658003363647 3.50722547216405 3.65787091069163 3.80851634921921 3.95916178774679 4.10980722627437 4.26045266480195 4.41109810332953 4.56174354185711 4.71238898038469
+11 2 14 15 16 17 18 19 20 21 22 23
+p 2.4794269466149 1 3.20593459510889 3.35658003363647 3.50722547216405 3.65787091069163 3.80851634921921 3.95916178774679 4.10980722627437 4.26045266480195 4.41109810332953 4.56174354185711 4.71238898038469
+5 14 25 26 27 15
+5 3 8 9 10 7
+p 0.845287415442253 1 1 2.5 4 5.5 7
+5 15 27 28 29 16
+2 2 7
+p 1.34784826555328 1 -6.7392412277664 6.73924122776635
+2 24 3
+p 4.98239222029239 1 -6.7392412277664 6.73924122776635
+2 1 2
+p 0.845287415442253 1 1 7
+2 1 2
+p 0.77647953010456 1 1 7
+2 2 7
+p 0.845287415442253 1 22.0123287393414 30.465202693764
+2 37 23
+p 4.08706770218725 1 22.0123287393414 30.465202693764
+5 1 3 4 5 2
+5 1 2 3 4 5
+p 2.89149511052204 1 1 2.5 4 5.5 7
+p 0.60000002 1 6.21884336566049 6.36749229914358 6.51614123262667 6.66479016610976 6.81343909959285 6.96208803307594 7.11073696655903 7.25938590004212 7.40803483352521 7.5566837670083 7.70533270049139 7.85398163397448
+12 25 26 27 28 29 30 31 32 33 34 35 24
+p 2.62009022251507 1 6.21884336566049 6.36749229914358 6.51614123262667 6.66479016610976 6.81343909959285 6.96208803307594 7.11073696655903 7.25938590004212 7.40803483352521 7.5566837670083 7.70533270049139 7.85398163397448
+11 2 13 14 15 16 17 18 19 20 21 12
+p 0.60000002 1 4.71238898038469 4.86303441891227 5.01367985743985 5.16432529596743 5.31497073449501 5.46561617302259 5.61626161155017 5.76690705007775 5.91755248860533 6.06819792713291 6.21884336566049
+11 37 38 39 40 41 42 43 44 45 46 36
+p 2.51472284863581 1 4.71238898038469 4.86303441891227 5.01367985743985 5.16432529596743 5.31497073449501 5.46561617302259 5.61626161155017 5.76690705007775 5.91755248860533 6.06819792713291 6.21884336566049
+5 11 22 23 24 12
+5 6 11 12 13 10
+p 2.91886130605038 1 1 2.5 4 5.5 7
+2 5 10
+p 3.90000002 1 52.3891587580895 91.4700260105138
+2 25 36
+p 4.98239222029239 1 52.3891587580895 91.4700260105138
+2 1 2
+p 3.78837272102338 1 537.534111045084 569.465888954916
+2 1 2
+p 3.95262934250469 1 537.534111045084 569.465888954916
+5 11 15 16 17 14
+p 3.23825986622486 1 537.3097167626 545.4048583813 553.5 561.5951416187 569.6902832374
+5 1 2 3 4 5
+p 3.81187469960491 1 537.3097167626 545.4048583813 553.5 561.5951416187 569.6902832374
+2 6 7
+p 3.23805666747998 1 537.3097167626 569.6902832374
+2 1 2
+p 3.91435888258221 1 537.3097167626 569.6902832374
+4 5 10 11 9
+p 0.969443050382898 1 0 0.444444444444444 0.722222222222222 1
+4 1 6 7 8
+p 0.963671960437347 1 0 0.444444444444444 0.722222222222222 1
+4 12 13 14 8
+p 0.967844617117498 1 0 0.444444444444444 0.722222222222222 1
+4 6 12 13 14
+p 0.964622695531969 1 0 0.444444444444444 0.722222222222222 1
+5 9 15 16 17 12
+p 3.23869078742326 1 537.534111045084 545.517055522542 553.5 561.482944477458 569.465888954916
+5 1 2 3 4 5
+p 3.78837272102338 1 537.534111045084 545.517055522542 553.5 561.482944477458 569.465888954916
+4 3 4 5 2
+p 0.0147662277435451 1 3.14969598006561 3.16609061650072 3.17633726427265 3.18658391204459
+4 2 10 11 12
+p 1.93225957922799 1 3.14969598006561 3.16609061650072 3.17633726427265 3.18658391204459
+5 1 7 8 9 6
+p 0.463000361575411 1 0.673446970666599 1.83882520814606 3.00420344562553 4.16958168310499 5.33495992058446
+2 6 8
+p 3.50222326817937 1 271.211152816347 303.288847183653
+2 3 1
+p 3.78837272102338 1 271.211152816347 303.288847183653
+15 1 6 7 8 9 10 11 12 13 14 15 16 17 18 5
+p 0.598773765423876 1 22.0856557446261 22.6947300713755 23.303804398125 23.9128787248744 24.5219530516239 25.1310273783733 25.7401017051228 26.3491760318722 26.9582503586217 27.7247917372435 28.5470420783553 29.2870673853559 30.0270926923565 30.5680358981168 31.1089791038772
+5 1 6 7 8 5
+p 0.845287415442253 1 -1.77635683940025e-14 2.11321848860561 4.22643697721125 6.33965546581688 8.45287395442251
+14 1 6 7 8 9 10 11 12 13 14 15 16 17 5
+p 0.598773765423906 1 4.60945843095357 5.59615884028787 6.48418920868875 7.28341654024953 8.08264387181032 8.88187120337111 9.60117580177582 10.2485499403401 10.8959240789043 11.5432982174685 12.1906723560328 12.838046494597 13.2354141424017 13.6327817902065
+4 20 21 22 15
+p 0.0147662277434947 1 0.00810332647598155 0.0244979629110283 0.0347446106829325 0.0449912584548366
+4 2 10 11 12
+p 1.93225957922793 1 0.00810332647598155 0.0244979629110283 0.0347446106829325 0.0449912584548366
+5 5 11 12 13 10
+p 0.462811901315945 1 -0.0520545189644926 1.11332371851499 2.27870195599448 3.44408019347396 4.60945843095345
+5 1 3 4 5 2
+p 0.964622695531969 1 30 32 34 36 38
+5 1 2 3 4 5
+p 3.78837272102338 1 30 32 34 36 38
+4 6 7 8 1
+p 0.964622695531969 1 3.15791906259637 3.23753576786708 3.31715247313778 3.39676917840849
+4 5 9 10 11
+p 3.60478460738709 1 3.15791906259637 3.23753576786708 3.31715247313778 3.39676917840849
+4 2 10 11 9
+p 0.964622695531969 1 6.02800878236089 6.13451493780682 6.24102109325275 6.34752724869869
+4 4 5 6 2
+p 3.78837272102338 1 6.02800878236089 6.13451493780682 6.24102109325275 6.34752724869869
+28 4 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 8
+p 3.78837272102338 1 2.88641612877109 3.02167337703877 3.15693062530644 3.29218787357412 3.42744512184179 3.56270237010946 3.69795961837714 3.83321686664481 3.96847411491248 4.10373136318016 4.23898861144783 4.3742458597155 4.50950310798318 4.64476035625085 4.78001760451852 4.9152748527862 5.05053210105387 5.18578934932154 5.32104659758922 5.45630384585689 5.59156109412456 5.72681834239224 5.86207559065991 5.99733283892758 6.13259008719526 6.26784733546293 6.4031045837306 6.53836183199828
+28 5 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59
+p 4.25726285886697 1 2.88641612877109 3.02167337703877 3.15693062530644 3.29218787357412 3.42744512184179 3.56270237010946 3.69795961837714 3.83321686664481 3.96847411491248 4.10373136318016 4.23898861144783 4.3742458597155 4.50950310798318 4.64476035625085 4.78001760451852 4.9152748527862 5.05053210105387 5.18578934932154 5.32104659758922 5.45630384585689 5.59156109412456 5.72681834239224 5.86207559065991 5.99733283892758 6.13259008719526 6.26784733546293 6.4031045837306 6.53836183199828
+4 2 10 11 9
+p 0.963671960437347 1 3.07725071207069 3.18375686751663 3.29026302296256 3.39676917840849
+49 1 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 2
+p 1.40494504643154 1 0 0.130899693899575 0.261799387799149 0.392699081698724 0.523598775598299 0.654498469497873 0.785398163397448 0.916297857297023 1.0471975511966 1.17809724509617 1.30899693899575 1.43989663289532 1.5707963267949 1.70169602069447 1.83259571459405 1.96349540849362 2.0943951023932 2.22529479629277 2.35619449019234 2.48709418409192 2.61799387799149 2.74889357189107 2.87979326579064 3.01069295969022 3.14159265358979 3.27249234748937 3.40339204138894 3.53429173528852 3.66519142918809 3.79609112308767 3.92699081698724 4.05789051088681 4.18879020478639 4.31968989868596 4.45058959258554 4.58148928648511 4.71238898038469 4.84328867428426 4.97418836818384 5.10508806208341 5.23598775598299 5.36688744988256 5.49778714378213 5.62868683768171 5.75958653158128 5.89048622548086 6.02138591938043 6.15228561328001 6.28318530717959
+5 1 3 4 5 2
+p 0.432662427077025 1 1.5707963267949 2.08209912506688 2.59340192333887 2.84905332247486 3.10470472161085
+5 10 14 15 16 6
+p 0.491850747721764 1 1.5707963267949 2.08209912506688 2.59340192333887 2.84905332247486 3.10470472161085
+5 1 7 8 9 6
+p 3.5000452165836 1 -0.251521728788582 8.4989633994475 17.2494485276836 25.9999336559197 34.7504187841557
+5 3 4 5 6 1
+p 3.90000002 1 -0.251521728788582 8.4989633994475 17.2494485276836 25.9999336559197 34.7504187841557
+4 13 14 15 6
+4 1 2 3 4
+p 0.691192444040533 1 0 0.523598775598299 1.0471975511966 1.5707963267949
+11 4 18 19 20 21 22 23 24 25 26 17
+p 0.691192444040533 1 0 0.1635138268314 0.327027653662799 0.490541480494199 0.654055307325599 0.817569134156998 0.981082960988398 1.1445967878198 1.3081106146512 1.4716244414826 1.635138268314
+4 5 27 28 17
+4 1 2 3 4
+p 0.901306858447711 1 1.5707963267949 2.0943951023932 2.61799387799149 3.14159265358979
+5 4 10 11 12 9
+5 1 6 7 8 9
+p 1.54934626303684 1 -8.88178419700125e-16 3.36962061388319 6.73924122776638 10.1088618416496 13.4784824555328
+4 5 13 14 9
+4 1 2 3 4
+p 0.691192444040533 1 0 0.1635138268314 0.327027653662799 0.490541480494199 0.654055307325598 0.817569134156998 0.981082960988398 1.1445967878198 1.3081106146512 1.4716244414826 1.635138268314
+p 0.657475492610188 1 0 0.1635138268314 0.327027653662799 0.490541480494199 0.654055307325598 0.817569134156998 0.981082960988398 1.1445967878198 1.3081106146512 1.4716244414826 1.635138268314
+4 5 27 28 17
+4 13 14 15 6
+5 1 3 4 5 2
+p 0.432662427077025 1 4.71238898038469 5.22369177865668 5.73499457692866 5.99064597606466 6.24629737520065
+5 1 2 3 4 5
+p 0.510584743655017 1 4.71238898038469 5.22369177865668 5.73499457692866 5.99064597606466 6.24629737520065
+5 6 7 8 9 1
+p 3.50004521658397 1 -3.5527136788005e-15 8.75048512823607 17.5009702564721 26.2514553847082 35.0019405129443
+5 1 6 7 8 9
+p 3.90360412119925 1 -3.5527136788005e-15 8.75048512823607 17.5009702564721 26.2514553847082 35.0019405129443
+4 12 13 14 8
+p 0.963671960437347 1 6.02800878236089 6.10762548763159 6.1872421929023 6.26685889817301
+4 6 7 8 1
+p 3.6040240193114 1 6.02800878236089 6.10762548763159 6.1872421929023 6.26685889817301
+5 12 15 16 17 9
+p 0.963671960437347 1 30 32 34 36 38
+5 6 60 61 62 59
+28 6 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 11
+p 4.24254538685304 1 2.88641612877109 3.02167337703877 3.15693062530644 3.29218787357412 3.42744512184179 3.56270237010946 3.69795961837714 3.83321686664481 3.96847411491248 4.10373136318016 4.23898861144783 4.3742458597155 4.50950310798318 4.64476035625085 4.78001760451852 4.9152748527862 5.05053210105387 5.18578934932154 5.32104659758922 5.45630384585689 5.59156109412456 5.72681834239224 5.86207559065991 5.99733283892758 6.13259008719526 6.26784733546293 6.4031045837306 6.53836183199828
+49 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 50
+5 1 3 4 5 2
+p 0.399193137309377 1 0 3.0077744530837 5.71477146085903 7.36904741005506 9.02332335925109
+5 5 31 32 33 19
+p 0.598760186755528 1 0 3.0077744530837 5.71477146085903 7.36904741005506 9.02332335925109
+5 2 11 12 13 10
+p 0.463000361575411 1 0.673446970666599 1.91746270383539 3.16147843700418 4.40549417017297 5.64950990334176
+5 8 9 10 11 3
+p 1.99160352450668 1 0.673446970666599 1.91746270383539 3.16147843700418 4.40549417017297 5.64950990334176
+4 1 3 4 2
+p 0.354657791238049 1 0 0.319977005322774 0.639954010645548 0.959931015968323
+4 5 13 14 9
+p 0.75785118708698 1 0 0.319977005322774 0.639954010645548 0.959931015968323
+13 2 20 21 22 23 24 25 26 27 28 29 30 19
+p 0.598760186755528 1 22.0856557446261 22.7624049965699 23.4391542485137 24.1159035004576 24.7926527524014 25.4694020043452 26.1461512562891 27.0168309485399 28.0319548264556 29.0470787043714 30.0622025822871 30.5855908430821 31.1089791038772
+13 1 6 7 8 9 10 11 12 13 14 15 16 17
+p 1.28165692222989 1 22.0856557446261 22.7624049965699 23.4391542485137 24.1159035004576 24.7926527524014 25.4694020043452 26.1461512562891 27.0168309485399 28.0319548264556 29.0470787043714 30.0622025822871 30.5855908430821 31.1089791038772
+4 1 3 4 2
+p 0.327770434521388 1 0 4.01036593744574 6.51684464834932 9.02332335925291
+4 5 29 30 18
+p 0.598760186755475 1 0 4.01036593744574 6.51684464834932 9.02332335925291
+5 2 10 11 12 9
+5 6 7 8 9 1
+p 1.27813020136297 1 -1.77635683940025e-14 2.11321848860561 4.22643697721125 6.33965546581688 8.45287395442251
+4 1 3 4 2
+p 0.432069274700118 1 0 0.511302798271986 1.02260559654397 1.53390839481596
+4 10 14 15 6
+p 0.462811901315945 1 0 0.511302798271986 1.02260559654397 1.53390839481596
+12 2 19 20 21 22 23 24 25 26 27 28 18
+p 0.598760186755475 1 4.60945843095357 5.7057922191028 6.80212600725202 7.89845979540125 8.88516020473556 9.77319057313643 10.5724179046972 11.2917225031019 12.0110271015066 12.7303316999114 13.1815567450589 13.6327817902065
+12 1 6 7 8 9 10 11 12 13 14 15 16
+p 1.28158776166463 1 4.60945843095357 5.7057922191028 6.80212600725202 7.89845979540125 8.88516020473556 9.77319057313643 10.5724179046972 11.2917225031019 12.0110271015066 12.7303316999114 13.1815567450589 13.6327817902065
+5 1 7 8 9 6
+p 0.462811901315945 1 -0.366604501721728 0.877411231447065 2.12142696461586 3.36544269778465 4.60945843095345
+5 9 11 12 13 14
+p 2.00799869239086 1 -0.366604501721728 0.877411231447065 2.12142696461586 3.36544269778465 4.60945843095345
+5 1 51 52 53 50
+p 1.40494504643154 1 0 2 4 6 8
+5 2 54 55 56 57
+5 1 3 4 5 2
+p 0.60000002 1 17 18.5 20 21.5 23
+2 2 7
+2 1 2
+5 17 22 23 24 18
+p 1.28165692222989 1 14.1498142229147 16.362360667186 18.5749071114574 20.7874535557287 23
+12 1 3 4 5 6 7 8 9 10 11 12 13
+5 15 27 28 29 16
+5 1 2 3 4 5
+p 1.34784826555328 1 17 18.5 20 21.5 23
+2 5 10
+2 13 24
+5 1 3 4 5 2
+12 24 25 26 27 28 29 30 31 32 33 34 23
+5 15 27 28 29 16
+5 1 2 3 4 5
+p 2.89149511052204 1 17 18.5 20 21.5 23
+2 5 10
+p 3.90000002 1 16.1498845106291 55.2307517630533
+2 23 19
+p 4.98239222029239 1 16.1498845106291 55.2307517630533
+5 1 3 4 5 2
+p 1.28158776166463 1 14.1498142229147 16.362360667186 18.5749071114574 20.7874535557287 23
+5 1 3 4 5 2
+p 1.28165692222989 1 10.2186981863703 13.4140236397777 16.6093490931852 19.8046745465926 23
+5 1 2 3 4 5
+p 1.53446156580895 1 10.2186981863703 13.4140236397777 16.6093490931852 19.8046745465926 23
+5 2 19 20 21 18
+p 1.28165692222989 1 4.71238898038469 5.08900257670364 5.46561617302259 5.84222976934154 6.21884336566049
+5 14 15 16 17 2
+p 3.02118708036935 1 4.71238898038469 5.08900257670364 5.46561617302259 5.84222976934154 6.21884336566049
+2 5 10
+p 1.27813020136297 1 22.0123287393414 30.465202693764
+2 14 18
+p 4.45492001574858 1 22.0123287393414 30.465202693764
+2 6 10
+p 1.27813020136297 1 10.2186981863703 23
+2 16 17
+p 1.54657278985786 1 10.2186981863703 23
+5 2 18 19 20 17
+p 1.28158776166463 1 3.20593459510889 3.58254819142784 3.95916178774679 4.33577538406574 4.71238898038469
+5 19 20 21 22 18
+p 3.07412875755578 1 3.20593459510889 3.58254819142784 3.95916178774679 4.33577538406574 4.71238898038469
+Surfaces 94
+1 0 -0 0 0 1 0 0 -0 1 1 0 -0
+2 -88.88841014078244 2.9999999999999996 -13.030175316602458 0.99793077129271601 0 -0.064297555996514807 0 -1 -0 -0.064297555996514807 0 -0.99793077129271601 3
+5 0 3 0 0 1 0 -2.4492935982947064e-16 0 1 -1 0 -2.4492935982947064e-16 18.718520432244532 3
+5 -91.01022948866742 3 -45.961890769262091 -0 -1 -0 -0.25241622129121266 0 0.96761875303709655 0.96761875303709655 -0 0.25241622129121266 33 3
+2 -1.2035551156641495 2.9999999999999996 18.679787532408252 -0.99793077129271601 0 -0.064297555996514807 0 -1 -0 -0.064297555996514807 -0 0.99793077129271601 3
+5 -103 3 0 0 1 0 0.25241622129121227 -0 0.96761875303709666 -0.96761875303709666 -0 0.25241622129121227 14.5 3
+5 -91.01022948866742 3 45.961890769262091 -0 -1 -0 0.064297555996514669 0 -0.99793077129271612 -0.99793077129271612 0 -0.064297555996514669 33 3
+5 -31 1 -6.7392412277663505 -0 -1 -0 1 -0 0 0 -0 -1 6 1
+5 -70 1 -4.2264369772112387 -0 -1 -0 -0.064297555996515141 0 -0.99793077129271601 -0.99793077129271601 -0 0.064297555996515141 6 1
+2 -25 0.99999999999999978 6.7392412277664011 0 0 -1 0 -1 -0 -1 0 -0 1
+2 -76 0.99999999999999978 -4.2264369772112396 -0 -0 1 -0 -1 -0 1 -0 0 1
+5 -31 1 6.7392412277664011 -0 -1 -0 -0.064297555996515862 0 0.99793077129271601 0.99793077129271601 -0 0.064297555996515862 6 1
+5 -70 1 4.2264369772112893 -0 -1 -0 -1 0 -1.7763568394002506e-16 -1.7763568394002506e-16 -0 1 6 1
+2 -70.385785335979094 0.99999999999999978 10.214021604967584 0.99793077129271601 -0 0.064297555996514807 -0 -1 0 0.064297555996514807 -0 -0.99793077129271601 1
+2 -103 38 0 -0 1 -0 0 0 -1 1 0 0 6.4899997711181641
+1 0 0 -21.763554203374689 1 0 0 0 0 1 0 -1 0
+1 6.8484683036804181 22 574.5 0 1 -0 -1 0 0 0 0 1
+2 0 0 0 0 -1 -0 0 0 1 1 0 -0 21.718520432244532
+1 0 0 -21.763554203374685 0.064297555996514807 -0 0.99793077129271601 -0.99793077129271601 0 0.064297555996514807 -0 -1 0
+2 -91.01022948866742 0 -45.961890769262091 0 -1 -0 0 0 1 1 0 -0 30
+1 -1.3964477836536937 0 21.673579846286398 -0.064297555996514807 0 0.99793077129271601 -0.99793077129271601 0 -0.064297555996514807 -0 -1 0
+2 -103 -0 0 0 -1 -0 0 0 1 1 0 -0 17.5
+2 -91.01022948866742 -0 45.961890769262091 0 -1 -0 0 0 1 1 0 -0 30
+1 -31.321487779982576 0 -11.728895084229931 0.064297555996514807 -0 0.99793077129271601 -0.99793077129271601 0 0.064297555996514807 -0 -1 0
+2 -31 0 -6.7392412277663505 0 -1 -0 0 0 1 1 0 -0 5
+2 -70 0 -4.2264369772112387 0 -1 -0 0 0 1 1 0 -0 5
+1 -26 0 6.7392412277664011 -1 0 0 0 0 -1 -0 -1 -0
+1 -75 0 4.2264369772112893 -1 0 0 0 0 -1 -0 -1 -0
+2 -31 0 6.7392412277664011 0 -1 -0 0 0 1 1 0 -0 5
+2 -70 0 4.2264369772112893 0 -1 -0 0 0 1 1 0 -0 5
+1 -31.321487779982583 0 11.728895084229979 -0.064297555996514807 0 0.99793077129271601 -0.99793077129271601 0 -0.064297555996514807 -0 -1 0
+1 -91.5 8 553.5 0 1 -0 -1 0 0 0 0 1
+2 -91.5 13 553.5 0 -0 1 1 0 0 -0 1 0 5
+1 -86.5 13 553.5 1 0 0 -0 1 0 0 -0 1
+2 -91.5 25 553.5 0 -0 1 1 0 0 -0 1 0 5
+1 -66 22 574.5 0.5735764958448768 0.81915200263095989 -0 -0.81915200263095989 0.5735764958448768 0 0 0 1
+2 -66.064297555996518 21 10.492458857846115 0.99793077129271601 -0 0.064297555996514807 0 1 0 0.064297555996514807 -0 -0.99793077129271601 1
+5 -31.000000000000014 21 6.7392412277664562 0 1 -0 -0.064297555996516584 0 0.9979307712927159 0.9979307712927159 0 0.064297555996516584 6 1
+2 -25 21 6.7392412277663993 0 -0 -1 0 1 0 -1 0 -0 1
+5 -31.000000000000014 21 -6.7392412277663425 0 1 -0 1 -0 -1.9539925233402753e-15 -1.9539925233402753e-15 0 -1 6 1
+2 -31.385785335979104 21 -12.726825855522636 -0.99793077129271601 0 0.064297555996514807 0 1 -0 0.064297555996514807 -0 0.99793077129271601 1
+1 -60.229997990467794 0 -0.022516885565078582 0 1 0 0 -0 1 1 0 -0
+1 -91.5 30 553.5 0 1 -0 -1 0 0 0 0 1
+2 -70.936674029407044 24.235922252564947 10.178527362648873 0.81801347013659731 -0.57277928668659528 0.052705326276168675 0.5735764958448768 0.81915200263096 -3.4694469519536142e-18 0.043173673568441727 -0.030230536357845741 -0.99861010839172004 1
+9 1 1 0 0 2 8 3 16 2 3 -75.426423504155125 28.600453816260661 4.2264369772108239  1 -75.42642350415521 28.600453816260718 5.2876352121921624  1.0000000000000138 -75.211820342941166 28.450187041826869 6.3489508821416987  0.99999999999995814 -74.78196477965119 28.149198889543261 7.3581059440514682  1.0000000000000713 -74.154733406968063 27.710006686298922 8.2662369368088306  0.9999999999999214 -73.354340930765474 27.149565754302845 9.0241834935736556  1.00000000000006 -72.430819030068477 26.50290865777324 9.6068027099519266  0.99999999999996914 -71.410806611778753 25.788688163015483 9.983741799435192  1.0000000000000091 -70.289310046063775 25.003407692237385 10.161719740062058  0.99999999999999889 -70.224593018462542 24.95809233465566 10.172015921313045  1.00000000000001 -70.156243994721805 24.910233825605182 10.181631715591825  0.99999999999997791 -70.087185609913249 24.861878616510964 10.190172602424408  1.0000000000000251 -70.018797260414871 24.813992571264215 10.197611994054746  0.99999999999998046 -69.94984475393278 24.765711498983773 10.204141717367339  1.0000000000000107 -69.881069926812586 24.717554839151127 10.209584824677723  0.99999999999999645 -69.812208840134105 24.669337779716177 10.21402160496757  1
+-75.000000000000014 28.301868818026364 4.226436977211061  0.88701084994628931 -75.000000000000043 28.301868818026385 5.1679676097545517  0.88701084994629908 -74.797108400969819 28.15980256898553 6.1215626426215657  0.88141934673143429 -74.383959755518973 27.870512728321284 7.0302225484414356  0.87020196274520167 -73.772366176834282 27.442270228008489 7.8363416767578427  0.85356529664194913 -73.002309846689371 26.903070897445527 8.4769960265978774  0.83139114115657275 -72.135601781207797 26.296195282757822 8.9281247841560472  0.80499774935012702 -71.223987343448528 25.657875882826975 9.1795341331177198  0.77421667140056694 -70.253477095808307 24.978317186473753 9.2480853929504363  0.73789764137794744 -70.184506802033695 24.930023659395033 9.2517537012601831  0.73533429187187715 -70.115483983785182 24.881693354278003 9.2544048712078233  0.73280522664662973 -70.046449398806644 24.833354810006867 9.2559823022387668  0.73026869503559211 -69.977448476513374 24.785039836605087 9.2564760666408201  0.72771653974196637 -69.908475080057045 24.736744137004994 9.2559157756608759  0.72516563775269927 -69.83952266764436 24.688463130592584 9.254282923818705  0.72260149115461536 -69.770599086554512 24.640202312092942 9.2515850759935496  0.72002762685186827
+-75 27.7813018136297 4.2264369772112884  1 -74.999999999999986 27.781301813629685 5.0993290856818687  1.0000000000000138 -74.825893282220918 27.635162118410385 5.9723070167389984  0.99999999999995814 -74.477286187586827 27.342532935907446 6.8056290682384741  1.0000000000000713 -73.965345330958243 26.912722518645431 7.5625490182697854  0.9999999999999214 -73.305963203397894 26.358625422767815 8.1967325675297165  1.00000000000006 -72.546083974716481 25.720452713630802 8.6847160173410547  0.99999999999996914 -71.707679730999359 25.015708542475345 9.008052571908399  1.0000000000000091 -70.773140232988439 24.230031301117396 9.1667248105252916  0.99999999999999889 -70.708502545898824 24.175538601969169 9.176726505690203  1.00000000000001 -70.644158270646159 24.121412872535021 9.1856800330604003  0.99999999999997791 -70.579742380749209 24.067245211172928 9.1936786075772901  1.0000000000000251 -70.515198941104956 24.012967647597918 9.2007326090571429  0.99999999999998046 -70.450696970111878 23.958761255563953 9.2068035339867276  1.0000000000000107 -70.386108747514271 23.904483491789108 9.2119272479854182  0.99999999999999645 -70.321487779982533 23.850185777085247 9.2160908336748708  1
+0 3
+9.0233233592510942 3
+22.085655744626067 9
+30.49282572876356 7
+31.108979103877161 9
+2 -76 27.781301813629696 -4.2264369772112218 -0 0 1 0.5735764958448768 0.81915200263095989 0 0.81915200263095989 -0.5735764958448768 0 1
+9 1 1 0 0 2 8 3 16 2 3 -69.812208840134289 24.669337779716304 -10.21402160496757  1 -69.881069926812856 24.717554839151315 -10.209584824677741  0.99999999999998312 -69.949844753932922 24.765711498983862 -10.204141717367161  1.0000000000000571 -70.018797260414786 24.813992571264187 -10.197611994054524  0.99999999999990374 -70.087185609913547 24.861878616511124 -10.190172602424237  1.0000000000001015 -70.156243994721834 24.910233825605243 -10.181631715592218  0.9999999999999285 -70.224593018462599 24.958092334655689 -10.172015921312724  1.0000000000000311 -70.289310046063974 25.003407692237523 -10.161719740062065  0.99999999999999556 -71.410806611779364 25.788688163015912 -9.9837417994349558  1.0000000000000102 -72.430819030065649 26.502908657771282 -9.6068027099525501  0.99999999999997158 -73.354340930769524 27.149565754305655 -9.0241834935724512  1.0000000000000486 -74.154733406964468 27.710006686296381 -8.266236936810845  0.99999999999994871 -74.781964779652824 28.149198889544412 -7.3581059440496315  1.0000000000000357 -75.211820342940754 28.450187041826581 -6.3489508821431686  0.99999999999998423 -75.426423504155125 28.600453816260661 -5.287635212191538  1.0000000000000038 -75.426423504155125 28.600453816260661 -4.2264369772112786  1
+-69.770599086554753 24.640202312093106 -9.2515850759934946  0.72002762685187027 -69.839522667644616 24.688463130592758 -9.2542829238186659  0.72260149115460792 -69.90847508005703 24.736744137004983 -9.2559157756607888  0.72516563775274478 -69.977448476513544 24.785039836605222 -9.2564760666408397  0.7277165397419032 -70.046449398806814 24.833354810006913 -9.2559823022385821  0.73026869503565517 -70.115483983785296 24.881693354278109 -9.2544048712079228  0.73280522664659986 -70.184506802033567 24.930023659395019 -9.2517537012600481  0.73533429187188859 -70.253477095808421 24.978317186473799 -9.2480853929503848  0.73789764137794056 -71.223987343448982 25.657875882827263 -9.1795341331177909  0.77421667140067818 -72.135601781205978 26.296195282756653 -8.9281247841556421  0.80499774934979151 -73.002309846691503 26.903070897446892 -8.4769960265988136  0.83139114115702994 -73.772366176832605 27.442270228007427 -7.8363416767566614  0.85356529664157177 -74.383959755519598 27.870512728321625 -7.0302225484424303  0.87020196274537054 -74.797108400969563 28.159802568985416 -6.121562642621325  0.88141934673140443 -75 28.30186881802636 -5.1679676097547143  0.88701084994628976 -75.000000000000014 28.301868818026364 -4.2264369772112538  0.88701084994628931
+-70.32148777998259 23.850185777085301 -9.2160908336748193  1 -70.386108747514342 23.904483491789179 -9.2119272479853596  0.99999999999998312 -70.450696970112119 23.958761255564141 -9.206803533986669  1.0000000000000571 -70.515198941104941 24.012967647597875 -9.2007326090570807  0.99999999999990374 -70.579742380749295 24.067245211172985 -9.1936786075772616  1.0000000000001015 -70.644158270646344 24.121412872535235 -9.1856800330603026  0.9999999999999285 -70.70850254589871 24.175538601969052 -9.1767265056901799  1.0000000000000311 -70.773140232988425 24.230031301117371 -9.1667248105252437  0.99999999999999556 -71.707679731001065 25.015708542476943 -9.008052571908074  1.0000000000000102 -72.546083974710868 25.720452713625512 -8.6847160173418239  0.99999999999997158 -73.305963203405796 26.358625422775354 -8.1967325675292368  1.0000000000000486 -73.96534533095128 26.912722518638805 -7.5625490182693733  0.99999999999994871 -74.477286187590352 27.342532935910757 -6.8056290682397158  1.0000000000000357 -74.82589328221988 27.635162118409465 -5.9723070167378731  0.99999999999998423 -74.999999999999986 27.781301813629696 -5.099329085682764  1.0000000000000038 -75 27.7813018136297 -4.2264369772112413  1
+0 3
+9.0233233592529061 3
+4.6094584309535671 9
+5.2256118060664418 7
+13.632781790206472 9
+2 -66.615186249424468 21.209983464992266 -10.456964615527465 -0.81801347013659731 0.57277928668659528 0.052705326276168675 0.5735764958448768 0.81915200263096 3.4694469519536142e-18 0.043173673568441727 -0.030230536357845741 0.99861010839172004 1
+1 -31.321487779982597 38 11.728895084229979 0.064297555996514807 0 -0.99793077129271601 -0.99793077129271601 0 -0.064297555996514807 0 1 0
+1 -26 38 6.7392412277664002 1 -0 0 0 0 -1 0 1 0
+1 -31.32148777998259 38 -11.728895084229929 -0.064297555996514807 0 -0.99793077129271601 -0.99793077129271601 -0 0.064297555996514807 0 1 0
+1 -75 38 4.2264369772112893 1 -0 0 0 0 -1 0 1 0
+1 -104.65518027830686 38 -3.5527136788005009e-15 0 1 0 0 -0 1 1 0 -0
+2 -31.000000000000014 38 6.7392412277664002 0 -1 -0 0 0 1 1 0 -0 5
+2 -31.000000000000014 38 -6.7392412277663523 0 -1 -0 0 0 1 1 0 -0 5
+2 -70 38 4.2264369772112884 0 -1 -0 0 0 1 1 0 -0 5
+2 -70 38 -4.2264369772112405 0 -1 -0 0 0 1 1 0 -0 5
+Triangulations 63
+47 49 1 6.5605776641078
+0 -4.44089209850063e-16 -18.7573336454959 -4.58471522642452e-15 0 18.7185204322445 -88.8884101407824 0 -13.0301753166025 -1.20355511566415 0 18.6797875324082 -0.401431205132772 0 18.714215456703 -0.802677764099095 0 18.7013025102365 -99.3399647912774 0 -14.0304719190379 -95.8982984036923 0 -13.3259170242983 -92.4012363025771 0 -12.9912204690747 -88.8884101407824 -4.44089209850063e-16 13.0301753166025 -99.3399647912774 0 14.0304719190379 -106.81909057089 0 13.9880144127513 -113.282108930348 0 10.2239051220395 -117.009468895473 0 3.73962314502098 -117.009468895473 0 -3.73962314502101 -113.282108930348 0 -10.2239051220396 -106.81909057089 0 -13.9880144127513 -92.4012363025771 0 12.9912204690747 -95.8982984036923 0 13.3259170242983 -31.3857853359791 -2.22044604925031e-16 -12.7268258555226 -70.3857853359791 -2.22044604925031e-16 -10.2140216049675 -25 -2.22044604925031e-16 -6.73924122776635 -25.8693796223569 0 -9.84998624150714 -28.2255781801711 0 -12.0592584801498 -76 0 -4.22643697721124 -73.220059179221 0 -9.28916538018866 -75.2592943954169 0 -7.1143120545539 -25 0 6.7392412277664 -76 -2.22044604925031e-16 4.22643697721129 -31.3857853359791 -2.22044604925031e-16 12.7268258555227 -28.2255781801711 0 12.0592584801498 -25.8693796223569 0 9.84998624150719 -70.3857853359791 0 10.2140216049676 -75.2592943954169 0 7.11431205455395 -73.220059179221 0 9.28916538018871 -103 0 -6.48999977111816 -106.244999885559 0 -5.62050467234352 -108.620504672344 0 -3.24499988555908 -109.489999771118 0 -1.19219361692504e-15 -108.620504672344 0 3.24499988555908 -106.244999885559 0 5.62050467234352 -103 0 6.48999977111816 -99.7550001144409 0 5.62050467234352 -97.3794953276565 0 3.24499988555908 -96.5100002288818 0 -9.54156611959008e-15 -97.3794953276565 0 -3.24499988555909 -99.7550001144409 0 -5.62050467234352 -18.7573336454959 0 18.7185204322445 0 -13.0301753166025 -88.8884101407824 18.6797875324082 -1.20355511566414 18.714215456703 -0.401431205132766 18.7013025102365 -0.802677764099101 -14.0304719190379 -99.3399647912774 -13.3259170242983 -95.8982984036923 -12.9912204690747 -92.4012363025771 13.0301753166025 -88.8884101407824 14.0304719190379 -99.3399647912774 13.9880144127513 -106.81909057089 10.2239051220395 -113.282108930348 3.73962314502098 -117.009468895473 -3.73962314502101 -117.009468895473 -10.2239051220396 -113.282108930348 -13.9880144127513 -106.81909057089 12.9912204690747 -92.4012363025771 13.3259170242983 -95.8982984036923 -12.7268258555226 -31.3857853359791 -10.2140216049675 -70.3857853359791 -6.73924122776635 -25 -9.84998624150714 -25.8693796223569 -12.0592584801498 -28.2255781801711 -4.22643697721124 -76 -9.28916538018866 -73.220059179221 -7.1143120545539 -75.2592943954169 6.7392412277664 -25 4.22643697721129 -76 12.7268258555227 -31.3857853359791 12.0592584801498 -28.2255781801711 9.84998624150719 -25.8693796223569 10.2140216049676 -70.3857853359791 7.11431205455395 -75.2592943954169 9.28916538018871 -73.220059179221 -6.48999977111816 -103 -5.62050467234352 -106.244999885559 -3.24499988555909 -108.620504672344 0 -109.489999771118 3.24499988555908 -108.620504672344 5.62050467234352 -106.244999885559 6.48999977111816 -103 5.62050467234352 -99.7550001144409 3.24499988555907 -97.3794953276565 -1.06581410364015e-14 -96.5100002288818 -3.24499988555909 -97.3794953276565 -5.62050467234352 -99.7550001144409 17 16 37 17 36 7 36 17 37 7 36 47 16 38 37 15 39 38 39 15 14 8 47 46 7 47 8 38 16 15 3 46 45 8 46 9 21 20 3 1 20 24 20 1 3 1 24 23 9 46 3 27 26 3 25 27 3 23 22 1 26 21 3 25 3 45 1 22 4 25 45 29 41 40 13 14 40 39 42 41 12 43 42 11 44 43 19 13 40 14 12 11 42 11 19 43 18 44 19 10 44 18 12 41 13 10 29 45 34 29 10 35 34 10 28 32 4 35 10 33 31 30 4 30 33 10 2 1 4 6 5 2 6 2 4 4 32 31 10 4 30 4 22 28 10 45 44
+11 10 1 3.33224497383348
+0 3 -21.7635542033747 2.27015712151488e-16 22 -21.7635542033747 0 -4.44089209850063e-16 -18.7573336454959 0 0.401923788646684 -20.2604439244353 0 1.5 -21.360797017998 -5.31950330591293e-15 22 21.7185204322445 -4.58471522642452e-15 0 18.7185204322445 -5.31950330591293e-15 3 21.7185204322445 0 0.401922403223833 20.2185180324091 0 1.49999524471386 21.3165938976878 0 11 -0.0225168855650786 0 -3 3.5527136788005e-15 -22 3.00622055787879 0 1.5031102789394 -0.401923788646684 0.402757185376731 -1.5 43.4820746356192 -22 40.4820746356192 0 43.4820746356192 -3 41.9820722357838 -0.401922403223832 43.0801481010625 -1.49999524471386 21.7410373178096 -11 3 1 11 1 4 5 4 1 3 1 2 11 11 6 8 6 11 2 11 8 7 7 10 9 10 7 8 11 7 3
+14 12 1 5.75637988618861
+-88.8884101407824 0 -13.0301753166025 -89.081302808772 3 -16.0239676304806 -88.9848564747772 0.401923788646684 -14.5270714735415 -89.0554600914651 1.5 -15.6228755140755 0 -4.44089209850063e-16 -18.7573336454959 -66.6663076055868 -4.44089209850063e-16 -14.4619648988258 -44.4442050703912 -4.44089209850063e-16 -15.8937544810492 -22.2221025351956 -4.44089209850063e-16 -17.3255440632725 0 3 -21.7635542033747 -66.810977106579 3 -17.4588642737041 -44.540651404386 3 -18.8937609169276 -22.270325702193 3 -20.3286575601512 0 0.401923788646684 -20.2604439244353 0 1.5 -21.360797017998 0 0 1.5707963267949 0 0.523598775598299 0 1.0471975511966 0 0 89.0727219741272 0 22.2681804935318 0 44.5363609870636 0 66.8045414805954 1.5707963267949 89.2660146087853 1.5707963267949 22.3165036521963 1.5707963267949 44.6330073043927 1.5707963267949 66.949510956589 0.52359877589177 89.1693682917607 1.04719755090123 89.2401183057149 1 3 6 6 3 7 8 7 13 13 5 8 7 3 13 3 4 13 4 2 10 4 10 11 14 11 12 11 14 4 12 9 14 4 14 13
+47 71 1 0.746285474702155
+-4.58471522642452e-15 0 18.7185204322445 -5.31950330591293e-15 3 21.7185204322445 0 0.0672002162507167 19.3499358530433 0 0.265789610825355 19.953062268403 0 0.586871638996126 20.5008816507019 0 1.01606061011543 20.9688502975769 0 1.53413092224155 21.3360054539154 0 2.1178774145315 21.5858989795741 0 2.55398025091641 21.6851795636329 -0.401431205132772 0 18.714215456703 -0.802677764099095 0 18.7013025102365 -1.20355511566415 0 18.6797875324082 -1.3964477836537 3 21.6735798462864 -0.465768214019639 3 21.7135255022447 -0.931322188802086 3 21.6985430097615 -1.24647777229851 0.075216263454529 19.3459689941636 -1.28724810769982 0.297093396292742 19.9787453356951 -1.32382172700895 0.65450555259591 20.5463865089943 -1.35436467623563 1.1295305944238 21.020428615369 -1.37734540436937 1.69834878264732 21.377101204178 -1.39161156174238 2.33243719813106 21.5985192224835 -0.903256025375881 1.1295305944238 21.0446394932933 -0.914919382156117 1.53413091097085 21.3163798767793 -0.925635185628506 2.11787743285866 21.5660435542107 -0.829753789509953 0.0672002216115417 19.3321371547611 -0.882886250967394 0.65450555259591 20.5700513954083 -0.928096804488614 2.33243719813106 21.6233959327452 -0.855616739855371 0.265789620842297 19.934708796645 -0.831303841632277 0.075216263454529 19.3682512654825 -0.899175227053545 1.0160605933993 20.9495624308373 -0.929892482998813 2.55398024322568 21.6652328049401 -0.879108041562412 0.586871632216997 20.4820242440534 -0.858494488105856 0.297093396292742 20.001756425205 -0.918582385785707 1.69834878264732 21.4017228899248 -0.45173190416835 1.1295305944238 21.0591704759901 -0.457564924064495 1.53413091097085 21.3310984918094 -0.462924058320213 2.11787743285866 21.5809345579661 -0.414972332091839 0.0672002216115417 19.3454856823317 -0.441544674055828 0.65450555259591 20.5842546827107 -0.464155150882868 2.33243719813106 21.638326537389 -0.427906781991673 0.265789620842297 19.9484733901741 -0.415747536438233 0.075216263454529 19.3816247292615 -0.449691035638401 1.0160605933993 20.9640277643626 -0.465053196674867 2.55398024322568 21.6801922972665 -0.43965513478799 0.586871632216997 20.4961667500336 -0.429345987112245 0.297093396292742 20.0155673140355 -0.4593968471938 1.69834878264732 21.4165004329231 0 4.71238898038469 0 6.28318530717959 0 4.92444653978402 0 5.13650354371654 0 5.34856067249215 0 5.56061730349023 0 5.77267445147137 0 5.9847334500714 0 6.13395882857577 0.0214473138396995 4.71238898038469 0.0428946276793992 4.71238898038469 0.0643419415190989 4.71238898038469 0.0643419415190989 6.28318530717959 0.0214473138396995 6.28318530717959 0.0428946276793992 6.28318530717959 0.0643419415190989 4.9367884556411 0.0643419415190989 5.16118793089752 0.0643419415190989 5.38558740615393 0.0643419415190989 5.60998688141034 0.0643419415190989 5.83438635666676 0.0643419415190989 6.05878583192317 0.0428946276793992 5.60998688141034 0.0428946276793992 5.77267445147137 0.0428946276793992 5.9847334500714 0.0428946276793992 4.92444653978402 0.0428946276793992 5.38558740615393 0.0428946276793992 6.05878583192317 0.0428946276793992 5.13650354371654 0.0428946276793992 4.9367884556411 0.0428946276793992 5.56061730349023 0.0428946276793992 6.13395882857577 0.0428946276793992 5.34856067249215 0.0428946276793992 5.16118793089752 0.0428946276793992 5.83438635666676 0.0214473138396995 5.60998688141034 0.0214473138396995 5.77267445147137 0.0214473138396995 5.9847334500714 0.0214473138396995 4.92444653978402 0.0214473138396995 5.38558740615393 0.0214473138396995 6.05878583192317 0.0214473138396995 5.13650354371654 0.0214473138396995 4.9367884556411 0.0214473138396995 5.56061730349023 0.0214473138396995 6.13395882857577 0.0214473138396995 5.34856067249215 0.0214473138396995 5.16118793089752 0.0214473138396995 5.83438635666676 1 10 3 42 4 3 46 5 4 38 3 10 38 42 3 42 38 25 41 42 29 42 41 4 46 45 5 45 46 33 39 45 32 45 39 5 41 28 46 41 46 4 10 11 38 5 39 6 7 6 35 43 6 39 8 7 47 40 9 8 44 2 9 6 43 35 35 36 7 36 35 22 47 36 23 36 47 7 37 40 8 40 37 24 44 40 27 40 44 9 47 34 37 47 37 8 43 30 35 2 44 14 39 26 43 29 42 25 25 11 12 29 25 16 28 41 29 32 45 33 33 28 17 32 33 17 26 39 32 29 16 28 33 46 28 17 28 16 18 32 17 26 18 30 26 32 18 30 18 19 22 35 30 16 25 12 30 43 26 34 47 23 23 22 19 34 23 20 24 37 34 27 31 44 40 24 27 27 24 21 44 31 14 34 20 24 36 22 23 21 24 20 21 31 27 31 13 15 13 31 21 31 15 14 20 23 19 22 30 19 25 38 11
+16 18 1 1.15679642351948
+-99.3399647912774 0 -14.0304719190379 -98.5827161274038 3 -16.9333281781492 -98.9613404593406 0.401923788646684 -15.4819000485935 -98.684168211381 1.5 -16.5444191829629 -88.8884101407824 0 -13.0301753166025 -95.8982984036923 0 -13.3259170242983 -92.4012363025771 0 -12.9912204690747 -89.081302808772 3 -16.0239676304806 -95.4539285023264 3 -16.2928237283859 -92.2747811376762 3 -15.9885541327281 -88.9848564747772 0.401923788646684 -14.5270714735415 -89.0554600914651 1.5 -15.6228755140755 -95.5134627804322 1.5 -15.8953336006965 -95.6761134530094 0.401923788646684 -14.8093703763421 -92.2917229173332 1.5 -15.5869875654169 -92.3380087201267 0.401923788646684 -14.4898873009014 0 1.5707963267949 0 3.14159265358979 0 2.0943951023932 0 2.61799387799149 0.319518466337797 1.5707963267949 0.106506155445932 1.5707963267949 0.213012310891865 1.5707963267949 0.319518466337797 3.14159265358979 0.106506155445932 3.14159265358979 0.213012310891865 3.14159265358979 0.319518466337797 2.0943951023932 0.319518466337797 2.61799387799149 0.106506155445932 2.61799387799149 0.106506155445932 2.0943951023932 0.213012310891865 2.61799387799149 0.213012310891865 2.0943951023932 3 1 6 6 14 3 14 6 7 3 14 13 2 4 13 13 9 2 9 13 15 4 3 13 14 16 13 7 16 14 16 7 11 5 11 7 16 11 12 15 10 9 10 15 8 12 8 15 15 16 12 16 15 13
+18 16 1 5.16865681225034
+-1.20355511566415 0 18.6797875324082 -1.24647777229851 0.075216263454529 19.3459689941636 -1.28724810769982 0.297093396292742 19.9787453356951 -1.32382172700895 0.65450555259591 20.5463865089943 -1.35436467623563 1.1295305944238 21.020428615369 -1.37734540436937 1.69834878264732 21.377101204178 -1.39161156174238 2.33243719813106 21.5985192224835 -1.3964477836537 3 21.6735798462864 -88.8884101407824 -4.44089209850063e-16 13.0301753166025 -23.1247688719437 -4.44089209850063e-16 17.2673844784568 -45.0459826282233 -4.44089209850063e-16 15.8549814245054 -66.9671963845029 -4.44089209850063e-16 14.4425783705539 -89.081302808772 3 16.0239676304806 -23.3176615399333 3 20.261176792335 -45.2388752962128 3 18.8487737383835 -67.1600890524924 3 17.4363706844321 -88.9848564747772 0.401923788646684 14.5270714735415 -89.0554600914651 1.5 15.6228755140755 0 2.22044604925031e-16 0.224399475256414 2.22044604925031e-16 0.448798950512828 2.22044604925031e-16 0.673198425769241 2.22044604925031e-16 0.897597901025655 2.22044604925031e-16 1.12199737628207 2.22044604925031e-16 1.34639685153848 2.22044604925031e-16 1.5707963267949 2.22044604925031e-16 0 87.8666712637106 0 21.9666678159277 0 43.9333356318553 0 65.900003447783 1.5707963267949 87.8666712637106 1.5707963267949 21.9666678159277 1.5707963267949 43.9333356318553 1.5707963267949 65.900003447783 0.523598775598299 87.8666712637106 1.0471975511966 87.8666712637106 1 2 10 3 4 17 2 3 17 10 2 11 2 9 12 12 11 2 9 2 17 4 5 17 5 6 18 7 8 14 6 7 18 15 16 7 15 7 14 13 7 16 13 18 7 5 18 17
+152 246 1 2.68892720929362
+-99.3399647912774 0 14.0304719190379 -98.5827161274038 3 16.9333281781492 -98.9613404593406 0.401923788646684 15.4819000485935 -98.684168211381 1.5 16.5444191829629 -99.3399647912774 0 -14.0304719190379 -101.6044176792 0 14.4326833951927 -103.903980968681 0 14.4717938904706 -106.180801683727 0 14.1468194534602 -108.377599011596 0 13.4659358705768 -110.439105387504 0 12.4462729776269 -112.313456929548 0 11.1134837032072 -113.953498242934 0 9.50109868604856 -115.317968766944 0 7.64968270300174 -116.372540818214 0 5.60581413045366 -117.090683215002 0 3.42091311413571 -117.454328755141 0 1.14994792851361 -117.454328755141 0 -1.14994792851363 -117.090683215002 0 -3.42091311413574 -116.372540818214 0 -5.60581413045369 -115.317968766944 0 -7.64968270300176 -113.953498242934 0 -9.50109868604858 -112.313456929548 0 -11.1134837032072 -110.439105387504 0 -12.4462729776269 -108.377599011595 0 -13.4659358705768 -106.180801683727 0 -14.1468194534602 -103.903980968681 0 -14.4717938904706 -101.6044176792 0 -14.4326833951927 -98.5827161274038 3 -16.9333281781492 -100.90643888067 3 17.3743201835246 -103.268403980929 3 17.4979415733115 -105.625466239767 3 17.3019341989226 -107.934570027256 3 16.7898784583483 -110.153535754051 3 15.9711278942818 -112.241830351162 3 14.860638336234 -114.161307673309 3 13.4786947076389 -115.876905301193 3 11.8505404882692 -117.357285014411 3 10.005916600441 -118.575405235742 3 7.97851814201292 -119.50901499016 3 5.80537888984623 -120.141060355593 3 3.52619481678678 -120.459995980936 3 1.18259897924576 -120.459995980936 3 -1.18259897924579 -120.141060355593 3 -3.52619481678681 -119.50901499016 3 -5.80537888984625 -118.575405235742 3 -7.97851814201295 -117.357285014411 3 -10.0059166004411 -115.876905301193 3 -11.8505404882692 -114.161307673309 3 -13.478694707639 -112.241830351162 3 -14.860638336234 -110.153535754051 3 -15.9711278942818 -107.934570027256 3 -16.7898784583483 -105.625466239767 3 -17.3019341989226 -103.268403980929 3 -17.4979415733115 -100.90643888067 3 -17.3743201835246 -98.9613404593406 0.401923788646684 -15.4819000485935 -98.684168211381 1.5 -16.5444191829629 -115.581160468924 1.5 -11.5783682522375 -114.773170561091 0.401923788646683 -10.834779874989 -118.768601520639 1.5 6.61025084339159 -117.755907109754 0.401923788646683 6.18572593705232 -101.354360491017 1.5 -17.0186979741612 -101.46004709429 0.401923788646683 -15.9257196084885 -120.044221699266 1.5 1.35599291867679 -118.949604143604 0.401923788646683 1.26890805904949 -111.772026955851 1.5 -14.6763671668119 -111.208668013798 0.401923788646683 -13.7338184580711 -120.058990967541 1.5 1.15543814140643 -118.963424896855 0.401923788646683 1.08123335245326 -104.065954172147 1.5 -17.0648161968458 -103.997496241303 0.401923788646683 -15.968876017071 -106.750730317349 1.5 -16.681613597484 -106.509850133768 0.401923788646683 -15.6102835348527 -113.904965098091 1.5 13.1691285337586 -113.204624158454 0.401923788646683 12.3233780184127 -120.058990967541 1.5 -1.15543814140647 -118.963424896855 0.401923788646683 -1.08123335245329 -103.262239526934 1.5 -17.0960650607021 -103.245397925421 0.401923788646683 -15.9981180098848 -115.581160468924 1.5 11.5783682522375 -114.773170561091 0.401923788646683 10.834779874989 -107.821237394073 1.5 16.4042640834399 -107.511606882063 0.401923788646683 15.3507460190613 -118.217683756767 1.5 -7.79527492833157 -117.24037050125 0.401923788646683 -7.29464515841184 -105.565166963306 1.5 -16.9045594021142 -105.400426276358 0.401923788646683 -15.8189112675863 -119.129851227207 1.5 -5.67204632539274 -118.093956562432 0.401923788646683 -5.30777498500229 -109.989239971624 1.5 -15.6043178238687 -109.540375546561 0.401923788646683 -14.602174074772 -113.904965098091 1.5 -13.1691285337586 -113.204624158454 0.401923788646683 -12.3233780184128 -109.341144671335 1.5 15.8787308808496 -108.933902357623 0.401923788646683 14.8589637192572 -117.525073706639 1.5 9.02033502404103 -116.592241398007 0.401923788646683 8.44102918951916 -104.065954172147 1.5 17.0648161968458 -103.997496241303 0.401923788646683 15.968876017071 -117.027540192258 1.5 9.7761099770735 -116.126660584604 0.401923788646683 9.14826660611752 -118.217683756767 1.5 7.79527492833154 -117.24037050125 0.401923788646683 7.29464515841181 -100.954521853061 1.5 16.9752828924776 -101.085886976613 0.401923788646683 15.8850927392225 -118.768601520639 1.5 -6.61025084339162 -117.755907109754 0.401923788646683 -6.18572593705234 -112.029572552946 1.5 -14.5193329612736 -111.449673463919 0.401923788646683 -13.5868693359854 -100.954521853061 1.5 -16.9752828924776 -101.085886976613 0.401923788646683 -15.8850927392225 -109.989239971624 1.5 15.6043178238687 -109.540375546561 0.401923788646683 14.602174074772 -115.916120533698 1.5 11.2034834086653 -115.086618750824 0.401923788646683 10.4839709639157 -119.129851227207 1.5 5.67204632539272 -118.093956562432 0.401923788646683 5.30777498500226 -119.74738036019 1.5 -3.44520844077142 -118.671826610827 0.401923788646683 -3.22394954677651 -109.341144671335 1.5 -15.8787308808496 -108.933902357623 0.401923788646683 -14.8589637192572 -113.982220439488 1.5 -13.1047718159358 -113.276917991226 0.401923788646683 -12.2631544311252 -106.750730317349 1.5 16.681613597484 -106.509850133768 0.401923788646683 15.6102835348527 -119.61541899863 1.5 4.03386435433865 -118.548340099312 0.401923788646683 3.77480067766699 -119.74738036019 1.5 3.4452084407714 -118.671826610827 0.401923788646683 3.22394954677649 -117.027540192258 1.5 -9.77610997707352 -116.126660584604 0.401923788646683 -9.14826660611755 -111.772026955851 1.5 14.6763671668119 -111.208668013798 0.401923788646683 13.7338184580711 -112.029572552946 1.5 14.5193329612736 -111.449673463919 0.401923788646683 13.5868693359854 -113.982220439488 1.5 13.1047718159358 -113.276917991226 0.401923788646683 12.2631544311251 -105.565166963307 1.5 16.9045594021142 -105.400426276358 0.401923788646683 15.8189112675863 -119.61541899863 1.5 -4.03386435433868 -118.548340099312 0.401923788646683 -3.77480067766702 -120.044221699266 1.5 -1.35599291867682 -118.949604143604 0.401923788646683 -1.26890805904952 -115.916120533698 1.5 -11.2034834086653 -115.086618750824 0.401923788646683 -10.4839709639157 -117.525073706639 1.5 -9.02033502404106 -116.592241398007 0.401923788646683 -8.44102918951918 -103.262239526934 1.5 17.0960650607021 -103.245397925421 0.401923788646683 15.9981180098848 -101.354360491017 1.5 17.0186979741612 -101.46004709429 0.401923788646683 15.9257196084885 -107.821237394073 1.5 -16.4042640834399 -107.511606882063 0.401923788646683 -15.3507460190613 8.88178419700125e-16 4.71238898038469 8.88178419700125e-16 6.28318530717959 8.88178419700125e-16 5.23598775598299 8.88178419700125e-16 5.75958653158129 3.65194570322719 4.71238898038469 0.1587802479664 4.71238898038469 0.3175604959328 4.71238898038469 0.4763407438992 4.71238898038469 0.635120991865599 4.71238898038469 0.793901239831999 4.71238898038469 0.952681487798398 4.71238898038469 1.1114617357648 4.71238898038469 1.2702419837312 4.71238898038469 1.4290222316976 4.71238898038469 1.587802479664 4.71238898038469 1.7465827276304 4.71238898038469 1.9053629755968 4.71238898038469 2.0641432235632 4.71238898038469 2.22292347152959 4.71238898038469 2.38170371949599 4.71238898038469 2.54048396746239 4.71238898038469 2.69926421542879 4.71238898038469 2.85804446339519 4.71238898038469 3.01682471136159 4.71238898038469 3.17560495932799 4.71238898038469 3.33438520729439 4.71238898038469 3.49316545526079 4.71238898038469 3.65194570322719 6.28318530717959 0.135257248267675 6.28318530717959 0.270514496535348 6.28318530717959 0.405771744803022 6.28318530717959 0.541028993070696 6.28318530717959 0.676286241338369 6.28318530717959 0.811543489606043 6.28318530717959 0.946800737873717 6.28318530717959 1.08205798614139 6.28318530717959 1.21731523440906 6.28318530717959 1.35257248267674 6.28318530717959 1.48782973094441 6.28318530717959 1.62308697921209 6.28318530717959 1.75834422747976 6.28318530717959 1.89360147574743 6.28318530717959 2.02885872401511 6.28318530717959 2.16411597228278 6.28318530717959 2.29937322055045 6.28318530717959 2.43463046881813 6.28318530717959 2.5698877170858 6.28318530717959 2.70514496535347 6.28318530717959 2.84040221362115 6.28318530717959 2.97565946188882 6.28318530717959 3.1109167101565 6.28318530717959 3.24617395842417 6.28318530717959 3.38143120669184 6.28318530717959 3.51668845495952 6.28318530717959 3.65194570322719 5.23598775598299 3.65194570322719 5.75958653158129 2.5698877170858 5.75958653158129 2.5698877170858 5.23598775598299 1.4290222316976 5.75958653158129 1.4290222316976 5.23598775598299 3.49316545526079 5.75958653158129 3.49316545526079 5.23598775598299 1.7465827276304 5.75958653158129 1.7465827276304 5.23598775598299 2.85804446339519 5.75958653158129 2.85804446339519 5.23598775598299 1.75834422747976 5.75958653158129 1.75834422747976 5.23598775598299 3.33438520729439 5.75958653158129 3.33438520729439 5.23598775598299 3.17560495932799 5.75958653158129 3.17560495932799 5.23598775598299 0.946800737873717 5.75958653158129 0.946800737873717 5.23598775598299 1.89360147574743 5.75958653158129 1.89360147574743 5.23598775598299 3.38143120669184 5.75958653158129 3.38143120669184 5.23598775598299 1.08205798614139 5.75958653158129 1.08205798614139 5.23598775598299 0.541028993070696 5.75958653158129 0.541028993070696 5.23598775598299 2.29937322055045 5.75958653158129 2.29937322055045 5.23598775598299 3.24617395842417 5.75958653158129 3.24617395842417 5.23598775598299 2.16411597228278 5.75958653158129 2.16411597228278 5.23598775598299 2.97565946188882 5.75958653158129 2.97565946188882 5.23598775598299 2.70514496535347 5.75958653158129 2.70514496535347 5.23598775598299 0.635120991865599 5.75958653158129 0.635120991865599 5.23598775598299 1.2702419837312 5.75958653158129 1.2702419837312 5.23598775598299 0.3175604959328 5.75958653158129 0.3175604959328 5.23598775598299 1.21731523440906 5.75958653158129 1.21731523440906 5.23598775598299 1.35257248267674 5.75958653158129 1.35257248267674 5.23598775598299 0.135257248267675 5.75958653158129 0.135257248267675 5.23598775598299 2.22292347152959 5.75958653158129 2.22292347152959 5.23598775598299 2.84040221362115 5.75958653158129 2.84040221362115 5.23598775598299 3.51668845495952 5.75958653158129 3.51668845495952 5.23598775598299 0.676286241338369 5.75958653158129 0.676286241338369 5.23598775598299 1.1114617357648 5.75958653158129 1.1114617357648 5.23598775598299 1.48782973094441 5.75958653158129 1.48782973094441 5.23598775598299 2.02885872401511 5.75958653158129 2.02885872401511 5.23598775598299 3.01682471136159 5.75958653158129 3.01682471136159 5.23598775598299 2.69926421542879 5.75958653158129 2.69926421542879 5.23598775598299 0.4763407438992 5.75958653158129 0.4763407438992 5.23598775598299 1.587802479664 5.75958653158129 1.587802479664 5.23598775598299 1.62308697921209 5.75958653158129 1.62308697921209 5.23598775598299 2.43463046881813 5.75958653158129 2.43463046881813 5.23598775598299 0.793901239831999 5.75958653158129 0.793901239831999 5.23598775598299 0.811543489606043 5.75958653158129 0.811543489606043 5.23598775598299 0.952681487798398 5.75958653158129 0.952681487798398 5.23598775598299 0.405771744803022 5.75958653158129 0.405771744803022 5.23598775598299 2.0641432235632 5.75958653158129 2.0641432235632 5.23598775598299 1.9053629755968 5.75958653158129 1.9053629755968 5.23598775598299 2.54048396746239 5.75958653158129 2.54048396746239 5.23598775598299 2.38170371949599 5.75958653158129 2.38170371949599 5.23598775598299 0.270514496535348 5.75958653158129 0.270514496535348 5.23598775598299 0.1587802479664 5.75958653158129 0.1587802479664 5.23598775598299 3.1109167101565 5.75958653158129 3.1109167101565 5.23598775598299 1 6 104 3 104 4 104 3 1 6 150 104 148 6 7 9 82 8 7 8 138 112 9 10 6 148 150 4 104 103 147 150 148 98 148 7 138 137 98 148 98 97 124 138 8 124 123 138 98 7 138 104 150 149 81 124 82 94 82 9 111 94 112 132 112 10 134 132 10 131 112 132 94 9 112 93 82 94 124 8 82 134 133 132 10 11 134 74 11 136 11 74 134 135 74 136 80 136 11 11 12 80 73 134 74 80 12 114 102 13 14 116 14 15 100 12 13 128 15 16 113 80 114 100 114 12 95 100 96 102 96 13 60 102 14 101 96 102 100 13 96 99 114 100 115 60 116 126 116 15 127 126 128 64 128 16 68 64 16 63 128 64 126 15 128 125 116 126 60 14 116 59 102 60 16 17 68 79 136 80 67 64 68 103 149 29 149 103 104 147 97 30 97 147 148 149 150 147 149 147 30 137 123 31 123 137 138 81 93 32 93 81 82 111 93 94 93 111 33 123 124 81 123 81 32 97 98 137 97 137 31 2 103 29 30 97 31 31 123 32 149 30 29 131 133 34 133 131 132 131 34 33 34 133 73 34 73 35 133 134 73 33 32 93 131 33 111 111 112 131 103 2 4 135 79 36 79 135 136 113 99 37 99 113 114 79 80 113 79 113 36 95 101 38 101 95 96 59 115 39 115 59 60 125 115 116 115 125 39 101 102 59 101 59 38 99 100 95 99 95 37 35 135 36 37 95 38 38 59 39 113 37 36 127 63 40 63 127 128 63 41 40 41 63 67 41 67 75 63 64 67 40 39 125 127 40 125 125 126 127 135 35 73 73 74 135 68 76 67 76 17 142 17 76 68 75 142 141 118 142 17 17 18 118 76 142 75 118 18 140 84 19 20 130 20 21 88 18 19 58 21 22 139 118 140 88 140 18 106 105 88 140 88 87 84 106 19 84 83 106 88 19 106 142 118 117 145 84 146 130 146 20 143 130 144 58 144 21 122 58 22 57 144 58 130 21 144 129 146 130 84 20 146 122 121 58 22 92 122 76 75 67 22 108 92 108 22 23 108 66 65 66 108 23 66 23 90 92 108 107 90 23 24 86 25 26 78 26 27 152 24 25 110 27 5 90 120 119 120 90 24 152 72 71 72 152 25 86 72 25 72 86 85 120 24 152 120 152 151 70 78 77 78 70 26 109 62 110 110 62 27 55 110 5 62 61 78 78 27 62 70 69 86 86 26 70 90 89 66 122 92 91 109 110 55 141 117 43 117 141 142 139 87 44 87 139 140 117 118 139 117 139 43 105 83 45 83 105 106 145 129 46 129 145 146 143 129 130 129 143 46 83 84 145 83 145 45 87 88 105 87 105 44 42 141 43 44 105 45 45 145 46 139 44 43 57 121 47 121 57 58 121 48 47 48 121 91 48 91 107 121 122 91 47 46 143 57 47 143 143 144 57 141 42 75 107 65 49 65 107 108 89 119 50 119 89 90 65 66 89 65 89 50 151 71 51 71 151 152 85 69 52 69 85 86 77 69 70 69 77 53 71 72 85 71 85 52 119 120 151 119 151 51 49 65 50 51 71 52 52 69 53 119 51 50 61 109 54 109 61 62 54 56 28 56 54 109 109 55 56 61 54 53 77 61 53 77 78 61 107 49 48 91 92 107 75 42 41
+16 18 1 1.12741026982256
+-88.8884101407824 -4.44089209850063e-16 13.0301753166025 -88.9848564747772 0.401923788646684 14.5270714735415 -89.0554600914651 1.5 15.6228755140755 -89.081302808772 3 16.0239676304806 -99.3399647912774 0 14.0304719190379 -92.4012363025771 0 12.9912204690747 -95.8982984036923 0 13.3259170242983 -98.5827161274038 3 16.9333281781492 -92.2747811376762 3 15.9885541327281 -95.4539285023264 3 16.2928237283859 -98.9613404593406 0.401923788646684 15.4819000485935 -98.684168211381 1.5 16.5444191829629 -92.2917229173332 1.5 15.5869875654169 -92.3380087201267 0.401923788646684 14.4898873009014 -95.5134627804322 1.5 15.8953336006965 -95.6761134530093 0.401923788646684 14.8093703763421 0 1.5707963267949 0 2.0943951023932 0 2.61799387799149 0 3.14159265358979 0.319518466337797 1.5707963267949 0.106506155445932 1.5707963267949 0.213012310891865 1.5707963267949 0.319518466337797 3.14159265358979 0.106506155445932 3.14159265358979 0.213012310891865 3.14159265358979 0.319518466337797 2.0943951023932 0.319518466337797 2.61799387799149 0.106506155445932 2.61799387799149 0.106506155445932 2.0943951023932 0.213012310891865 2.61799387799149 0.213012310891865 2.0943951023932 2 1 6 6 14 2 14 6 7 2 14 13 4 3 13 13 9 4 9 13 15 3 2 13 14 16 13 7 16 14 16 7 5 5 11 16 16 11 12 15 10 9 10 15 12 12 8 10 15 16 12 16 15 13
+14 12 1 2.1699582487139
+-31.3857853359791 -2.22044604925031e-16 -12.7268258555226 -31.3214877799826 1 -11.7288950842299 -31.3536365579808 0.133974596215561 -12.2278604698763 -31.3301020190849 0.5 -11.862592456365 -70.3857853359791 -2.22044604925031e-16 -10.2140216049675 -41.1357853359791 -2.22044604925031e-16 -12.0986247928839 -50.8857853359791 -2.22044604925031e-16 -11.4704237302451 -60.6357853359791 -2.22044604925031e-16 -10.8422226676063 -70.3214877799826 1 -9.21609083367482 -41.0714877799826 1 -11.1006940215912 -50.8214877799826 1 -10.4724929589524 -60.5714877799826 1 -9.8442918963136 -70.3536365579808 0.133974596215561 -9.71505621932118 -70.3301020190849 0.5 -9.34978820580984 0 0 1.5707963267949 0 0.523598775598299 0 1.0471975511966 0 0 39.0808672524243 0 9.77021681310607 0 19.5404336262121 0 29.3106504393182 1.5707963267949 39.0808672524243 1.5707963267949 9.77021681310607 1.5707963267949 19.5404336262121 1.5707963267949 29.3106504393182 0.523598775598299 39.0808672524243 1.0471975511966 39.0808672524243 1 3 6 6 3 7 8 7 13 13 5 8 7 3 13 3 4 13 4 2 10 4 10 11 14 11 12 11 14 4 12 9 14 4 14 13
+66 102 1 0.626633573059638
+-25 -2.22044604925031e-16 -6.73924122776635 -26 1 -6.73924122776635 -25.5 0.133974596215561 -6.73924122776635 -25.8660254037844 0.5 -6.73924122776635 -31.3857853359791 -2.22044604925031e-16 -12.7268258555226 -25.0556154754982 0 -7.55428271435672 -25.2214308749545 0 -8.35421456100459 -25.4943722309403 0 -9.12420723770415 -25.8693796223569 0 -9.84998624150714 -26.3395009777412 0 -10.5180967242792 -26.8960209561862 0 -11.116152925292 -27.5286225166166 0 -11.6330677845477 -28.2255781801711 0 -12.0592584801498 -28.9739674399729 0 -12.3868240793685 -29.7599162878417 0 -12.6096920100181 -30.5688544174803 0 -12.7237306367864 -31.3214877799826 1 -11.7288950842299 -26.0666931334625 1 -7.55317203598886 -26.2649933442295 1 -8.34538940580256 -26.5896105273321 1 -9.09475915369695 -27.0318847879236 1 -9.7812901530284 -27.5800174634885 1 -10.3866676423711 -28.2193858797522 1 -10.8947418130483 -28.9329334434676 1 -11.2919586416704 -29.7016246654752 1 -11.5677214742515 -30.5049529752708 1 -11.7146737158328 -31.3536365579808 0.133974596215561 -12.2278604698763 -31.3301020190849 0.5 -11.862592456365 -30.6310849220122 0.5 -11.8599439939714 -30.6047832160236 0.133974596215561 -12.2250231860348 -28.0296726977392 0.5 -10.9267047645665 -27.8179039735652 0.133974596215561 -11.225248904816 -26.9255594612687 0.5 -9.8628016083144 -26.635073266716 0.133974596215561 -10.0854950455546 -26.2890411495714 0.5 -8.77996704574273 -25.9531745450286 0.133974596215561 -8.92546007020934 -29.6668348032394 0.5 -11.6971002125231 -29.5717871320227 0.133974596215561 -12.0505694989001 -25.9345055743721 0.5 -7.57498124626466 -25.5733624468087 0.133974596215561 -7.63456511681111 -26.1381192232725 0.5 -8.38842601652552 -25.7914926786524 0.133974596215561 -8.50600422360619 -29.9389069540998 0.5 -11.7623654251687 -29.8632565971883 0.133974596215561 -12.1204877781638 -27.4883793076098 0.5 -10.4844001385956 -27.2380192098374 0.133974596215561 -10.7514102838316 -27.012186069006 0.5 -9.97266591474408 -26.7278758962628 0.133974596215561 -10.2031920995698 -28.8775465620151 0.5 -11.4139483371127 -28.7262267878143 0.133974596215561 -11.7472303830608 -30.4916882302216 0.5 -11.8479900275501 -30.4554482727979 0.133974596215561 -12.2122169646394 -26.6099208863924 0.5 -9.40098887374126 -26.2969313204938 0.133974596215561 -9.59075749036207 -28.1448795489539 0.5 -11.0060881156456 -27.9413244677274 0.133974596215561 -11.3102918715765 -28.626031476302 0.5 -11.2913801319605 -28.4567799984901 0.133974596215561 -11.6159237091178 -26.4714344975813 0.5 -9.15787506629797 -26.1485715800653 0.133974596215561 -9.33031094629001 -25.9136134768451 0.5 -7.4366416089358 -25.55098085254 0.133974596215561 -7.48636259047419 -26.0554954849235 0.5 -8.1211132388348 -25.7029783020416 0.133974596215561 -8.21963344990141 -29.2664000509526 0.5 -11.5716657094577 -29.1428034866419 0.133974596215561 -11.9161921750683 0 1.5707963267949 0 3.14159265358979 0 2.0943951023932 0 2.61799387799149 1.635138268314 1.5707963267949 0.1362615223595 1.5707963267949 0.272523044718999 1.5707963267949 0.408784567078499 1.5707963267949 0.545046089437999 1.5707963267949 0.681307611797498 1.5707963267949 0.817569134156998 1.5707963267949 0.953830656516498 1.5707963267949 1.090092178876 1.5707963267949 1.2263537012355 1.5707963267949 1.362615223595 1.5707963267949 1.4988767459545 1.5707963267949 1.635138268314 3.14159265358979 0.1635138268314 3.14159265358979 0.327027653662799 3.14159265358979 0.490541480494199 3.14159265358979 0.654055307325598 3.14159265358979 0.817569134156998 3.14159265358979 0.981082960988398 3.14159265358979 1.1445967878198 3.14159265358979 1.3081106146512 3.14159265358979 1.4716244414826 3.14159265358979 1.635138268314 2.0943951023932 1.635138268314 2.61799387799149 1.4988767459545 2.61799387799149 1.4988767459545 2.0943951023932 0.953830656516498 2.61799387799149 0.953830656516498 2.0943951023932 0.654055307325598 2.61799387799149 0.654055307325598 2.0943951023932 0.408784567078499 2.61799387799149 0.408784567078499 2.0943951023932 1.3081106146512 2.61799387799149 1.3081106146512 2.0943951023932 0.1635138268314 2.61799387799149 0.1635138268314 2.0943951023932 0.327027653662799 2.61799387799149 0.327027653662799 2.0943951023932 1.362615223595 2.61799387799149 1.362615223595 2.0943951023932 0.817569134156998 2.61799387799149 0.817569134156998 2.0943951023932 0.681307611797498 2.61799387799149 0.681307611797498 2.0943951023932 1.1445967878198 2.61799387799149 1.1445967878198 2.0943951023932 1.4716244414826 2.61799387799149 1.4716244414826 2.0943951023932 0.545046089437999 2.61799387799149 0.545046089437999 2.0943951023932 0.981082960988398 2.61799387799149 0.981082960988398 2.0943951023932 1.090092178876 2.61799387799149 1.090092178876 2.0943951023932 0.490541480494199 2.61799387799149 0.490541480494199 2.0943951023932 0.1362615223595 2.61799387799149 0.1362615223595 2.0943951023932 0.272523044718999 2.61799387799149 0.272523044718999 2.0943951023932 1.2263537012355 2.61799387799149 1.2263537012355 2.0943951023932 3 1 6 3 6 62 40 6 7 62 40 39 40 62 6 64 42 41 42 64 7 40 7 64 40 64 63 7 8 42 3 62 61 8 9 60 34 10 48 9 10 34 36 60 59 60 36 8 54 34 33 34 54 9 60 9 54 60 54 53 10 11 46 8 36 42 42 36 35 4 61 2 4 3 61 39 63 18 39 40 63 62 39 61 61 39 18 2 61 18 19 18 63 19 41 35 41 19 63 64 41 63 35 59 20 35 36 59 60 53 59 46 48 10 41 42 35 47 48 46 20 53 21 53 20 59 33 47 21 47 33 48 22 21 47 33 21 53 54 33 53 47 46 45 35 20 19 48 33 34 11 12 46 32 45 46 56 32 12 56 12 13 50 13 14 56 58 57 58 56 13 50 66 65 66 50 14 58 13 50 58 50 49 14 38 66 32 56 55 44 38 15 15 38 14 52 15 16 27 16 5 44 52 51 52 44 15 30 27 28 27 30 16 52 16 30 52 30 29 38 44 43 66 38 37 45 31 22 31 45 32 55 57 23 57 55 56 31 32 55 31 55 23 22 31 23 24 23 57 24 49 65 49 24 57 57 58 49 45 22 47 65 37 25 37 65 66 43 51 26 51 43 44 37 38 43 37 43 25 25 43 26 29 28 17 28 29 30 29 17 26 51 29 26 51 52 29 65 25 24 49 50 65 32 46 12
+62 96 1 0.594307872504793
+-70.3857853359791 -2.22044604925031e-16 -10.2140216049675 -70.3536365579808 0.133974596215561 -9.71505621932118 -70.3301020190849 0.5 -9.34978820580984 -70.3214877799826 1 -9.21609083367482 -76 0 -4.22643697721124 -71.1996144637453 0 -10.1052910439808 -71.9909794716385 0 -9.88647237847102 -72.7450611665446 0 -9.5616632322007 -73.4477385270017 0 -9.13694601899376 -74.0858531350895 0 -8.62027404274742 -74.647455582492 0 -8.02132256293895 -75.1220292365071 0 -7.35130761459228 -75.5006871757325 0 -6.62277597550251 -75.7763386075888 0 -5.84937021381668 -75.9438216513256 0 -5.04557321571707 -75 1 -4.22643697721124 -71.1482874989066 1 -9.09279452879484 -71.9429902969599 1 -8.83347384551602 -72.6833826493509 1 -8.44537731302576 -73.3487691163306 1 -7.9393530017815 -73.9205508219211 1 -7.32954529835206 -74.3827453295141 1 -6.63299954166346 -74.7224333827808 1 -5.8691855718529 -74.930120024599 1 -5.0594535094889 -75.5 0.133974596215561 -4.22643697721124 -75.1339745962156 0.5 -4.22643697721124 -73.9766531495924 0.5 -7.47357800932302 -74.2601676172843 0.133974596215561 -7.70508209746164 -74.8489706039034 0.5 -5.91320288778305 -75.1946767210589 0.133974596215561 -6.03346043131706 -74.3827279968835 0.5 -6.90027138867361 -74.6951934667982 0.133974596215561 -7.09090172814386 -72.7552836707386 0.5 -8.55842347861542 -72.951720914286 0.133974596215561 -8.86727134660721 -72.348845715683 0.5 -8.79158965357427 -72.5163060693325 0.133974596215561 -9.11706104428491 -74.5001806366815 0.5 -6.69748319123145 -74.8210198624654 0.133974596215561 -6.87365579810868 -74.9425959450834 0.5 -5.61511997855894 -75.2949770569564 0.133974596215561 -5.71412577743289 -71.9950525650571 0.5 -8.95691902635229 -72.1372893266559 0.133974596215561 -9.2941775323465 -74.025601664583 0.5 -7.41269283521966 -74.3126059041133 0.133974596215561 -7.63985613046615 -72.9501003353368 0.5 -8.42817508971096 -73.1604269830849 0.133974596215561 -8.72773693217855 -74.7067313703233 0.5 -6.27689423406924 -75.0422965777548 0.133974596215561 -6.42308105897824 -75.062222192517 0.5 -5.08177412019946 -75.4231320270589 0.133974596215561 -5.14275516271667 -73.4384991143665 0.5 -8.03884028681631 -73.6836460279636 0.133974596215561 -8.31064460423852 -71.1790557697077 0.5 -9.22318818639764 -71.2631162487973 0.133974596215561 -9.5794302839532 -75.0859048937236 0.5 -4.92734108376599 -75.4485031803818 0.133974596215561 -4.97731186250825 -73.4961110332362 0.5 -7.98607828960675 -73.745365373832 0.133974596215561 -8.25412095395274 -71.0264650303535 0.5 -9.25675154948681 -71.0996465917666 0.133974596215561 -9.61538653841667 -71.7036063381631 0.5 -9.06951663783599 -71.8250645156686 0.133974596215561 -9.41480276169937 -4.44089209850063e-16 1.5707963267949 -4.44089209850063e-16 2.0943951023932 -4.44089209850063e-16 2.61799387799149 -4.44089209850063e-16 3.14159265358979 1.5064543852758 1.5707963267949 0.136950398661436 1.5707963267949 0.273900797322872 1.5707963267949 0.410851195984308 1.5707963267949 0.547801594645744 1.5707963267949 0.68475199330718 1.5707963267949 0.821702391968617 1.5707963267949 0.958652790630053 1.5707963267949 1.09560318929149 1.5707963267949 1.23255358795293 1.5707963267949 1.36950398661436 1.5707963267949 1.5064543852758 3.14159265358979 0.167383820586199 3.14159265358979 0.334767641172399 3.14159265358979 0.502151461758599 3.14159265358979 0.669535282344799 3.14159265358979 0.836919102930998 3.14159265358979 1.0043029235172 3.14159265358979 1.1716867441034 3.14159265358979 1.3390705646896 3.14159265358979 1.5064543852758 2.0943951023932 1.5064543852758 2.61799387799149 0.821702391968617 2.61799387799149 0.821702391968617 2.0943951023932 1.1716867441034 2.61799387799149 1.1716867441034 2.0943951023932 0.958652790630053 2.61799387799149 0.958652790630053 2.0943951023932 0.502151461758599 2.61799387799149 0.502151461758599 2.0943951023932 0.410851195984308 2.61799387799149 0.410851195984308 2.0943951023932 1.0043029235172 2.61799387799149 1.0043029235172 2.0943951023932 1.23255358795293 2.61799387799149 1.23255358795293 2.0943951023932 0.334767641172399 2.61799387799149 0.334767641172399 2.0943951023932 0.836919102930998 2.61799387799149 0.836919102930998 2.0943951023932 0.547801594645744 2.61799387799149 0.547801594645744 2.0943951023932 1.09560318929149 2.61799387799149 1.09560318929149 2.0943951023932 1.3390705646896 2.61799387799149 1.3390705646896 2.0943951023932 0.669535282344799 2.61799387799149 0.669535282344799 2.0943951023932 0.167383820586199 2.61799387799149 0.167383820586199 2.0943951023932 1.36950398661436 2.61799387799149 1.36950398661436 2.0943951023932 0.68475199330718 2.61799387799149 0.68475199330718 2.0943951023932 0.136950398661436 2.61799387799149 0.136950398661436 2.0943951023932 0.273900797322872 2.61799387799149 0.273900797322872 2.0943951023932 1 6 60 6 7 54 2 60 59 60 2 1 54 62 61 62 54 7 60 6 54 60 54 53 7 42 62 36 42 8 8 42 7 34 8 9 52 9 10 36 34 33 34 36 8 46 52 51 52 46 9 34 9 46 34 46 45 10 58 52 42 36 35 62 42 41 3 59 4 3 2 59 53 61 17 53 54 61 60 53 59 59 53 17 4 59 17 18 17 61 18 41 35 41 18 61 62 41 61 35 33 19 35 36 33 46 51 45 45 33 34 41 42 35 33 45 19 45 20 19 20 45 51 20 57 21 57 20 51 51 58 57 58 28 57 35 19 18 58 51 52 10 11 58 11 12 44 12 13 38 28 44 43 44 28 11 32 38 37 38 32 12 44 12 32 44 32 31 13 48 38 11 28 58 48 13 30 30 13 14 50 14 15 56 15 5 30 40 39 40 30 14 50 56 55 56 50 15 40 14 50 40 50 49 5 25 56 48 30 29 38 48 47 27 43 21 27 28 43 31 37 22 31 32 37 44 31 43 43 31 21 21 31 22 22 47 23 47 48 29 37 47 22 23 47 29 38 47 37 27 21 57 39 49 24 39 40 49 55 25 26 55 49 50 29 30 39 49 55 24 23 39 24 16 24 55 26 16 55 39 23 29 25 55 56 28 27 57
+14 12 1 1.0074900874178
+-25 0 6.7392412277664 -26 1 6.7392412277664 -25.5 0.133974596215561 6.7392412277664 -25.8660254037844 0.5 6.7392412277664 -25 -2.22044604925031e-16 -6.73924122776635 -25 -2.22044604925031e-16 3.36962061388321 -25 -2.22044604925031e-16 2.48689957516035e-14 -25 -2.22044604925031e-16 -3.36962061388316 -26 1 -6.73924122776635 -26 1 3.36962061388321 -26 1 2.48689957516035e-14 -26 1 -3.36962061388316 -25.5 0.133974596215561 -6.73924122776635 -25.8660254037844 0.5 -6.73924122776635 0 0 1.5707963267949 0 0.523598775598299 0 1.0471975511966 0 0 13.4784824555328 0 3.36962061388319 0 6.73924122776638 0 10.1088618416496 1.5707963267949 13.4784824555328 1.5707963267949 3.36962061388319 1.5707963267949 6.73924122776638 1.5707963267949 10.1088618416496 0.523598775598299 13.4784824555328 1.0471975511966 13.4784824555328 1 3 6 6 3 7 8 7 13 13 5 8 7 3 13 3 4 13 4 2 10 4 10 11 14 11 12 11 14 4 12 9 14 4 14 13
+14 12 1 0.742204801610929
+-76 0 -4.22643697721124 -75.5 0.133974596215561 -4.22643697721124 -75.1339745962156 0.5 -4.22643697721124 -75 1 -4.22643697721124 -76 -2.22044604925031e-16 4.22643697721129 -76 -2.22044604925031e-16 -2.11321848860561 -76 -2.22044604925031e-16 2.48689957516035e-14 -76 -2.22044604925031e-16 2.11321848860566 -75 1 4.22643697721129 -75 1 -2.11321848860561 -75 1 2.48689957516035e-14 -75 1 2.11321848860566 -75.5 0.133974596215561 4.22643697721129 -75.1339745962156 0.5 4.22643697721129 0 0 0.523598775598299 0 1.0471975511966 0 1.5707963267949 0 0 8.45287395442253 0 2.11321848860563 0 4.22643697721126 0 6.3396554658169 1.5707963267949 8.45287395442253 1.5707963267949 2.11321848860563 1.5707963267949 4.22643697721126 1.5707963267949 6.3396554658169 0.523598775598299 8.45287395442253 1.0471975511966 8.45287395442253 1 2 6 6 2 7 8 7 13 13 5 8 7 2 13 2 3 13 3 4 10 3 10 11 14 11 12 11 14 3 12 9 14 3 14 13
+66 102 1 0.626633573059639
+-31.3857853359791 -2.22044604925031e-16 12.7268258555227 -31.3214877799826 1 11.72889508423 -31.3536365579808 0.133974596215561 12.2278604698763 -31.3301020190849 0.5 11.862592456365 -25 0 6.7392412277664 -30.5688544174803 0 12.7237306367865 -29.7599162878417 0 12.6096920100181 -28.9739674399729 0 12.3868240793685 -28.2255781801711 0 12.0592584801498 -27.5286225166166 0 11.6330677845478 -26.8960209561862 0 11.1161529252921 -26.3395009777412 0 10.5180967242792 -25.8693796223569 0 9.84998624150719 -25.4943722309403 0 9.1242072377042 -25.2214308749545 0 8.35421456100465 -25.0556154754982 0 7.55428271435677 -26 1 6.7392412277664 -30.5049529752708 1 11.7146737158328 -29.7016246654752 1 11.5677214742516 -28.9329334434676 1 11.2919586416704 -28.2193858797522 1 10.8947418130483 -27.5800174634885 1 10.3866676423712 -27.0318847879236 1 9.78129015302846 -26.5896105273321 1 9.09475915369701 -26.2649933442295 1 8.34538940580262 -26.0666931334625 1 7.55317203598891 -25.5 0.133974596215561 6.7392412277664 -25.8660254037844 0.5 6.7392412277664 -26.2890411495714 0.5 8.77996704574278 -25.9531745450286 0.133974596215561 8.92546007020939 -28.1448795489539 0.5 11.0060881156457 -27.9413244677274 0.133974596215561 11.3102918715765 -26.1381192232725 0.5 8.38842601652557 -25.7914926786524 0.133974596215561 8.50600422360624 -27.012186069006 0.5 9.97266591474414 -26.7278758962628 0.133974596215561 10.2031920995698 -30.4916882302216 0.5 11.8479900275501 -30.4554482727979 0.133974596215561 12.2122169646395 -29.2664000509526 0.5 11.5716657094577 -29.1428034866419 0.133974596215561 11.9161921750683 -29.6668348032394 0.5 11.6971002125231 -29.5717871320227 0.133974596215561 12.0505694989001 -26.0554954849235 0.5 8.12111323883486 -25.7029783020416 0.133974596215561 8.21963344990146 -26.4714344975813 0.5 9.15787506629802 -26.1485715800653 0.133974596215561 9.33031094629007 -27.4883793076098 0.5 10.4844001385957 -27.2380192098374 0.133974596215561 10.7514102838316 -28.0296726977392 0.5 10.9267047645665 -27.8179039735652 0.133974596215561 11.225248904816 -25.9345055743721 0.5 7.57498124626472 -25.5733624468087 0.133974596215561 7.63456511681116 -28.626031476302 0.5 11.2913801319606 -28.4567799984901 0.133974596215561 11.6159237091179 -26.9255594612687 0.5 9.86280160831445 -26.635073266716 0.133974596215561 10.0854950455547 -26.6099208863924 0.5 9.40098887374131 -26.2969313204938 0.133974596215561 9.59075749036212 -28.8775465620151 0.5 11.4139483371127 -28.7262267878143 0.133974596215561 11.7472303830608 -30.6310849220122 0.5 11.8599439939714 -30.6047832160236 0.133974596215561 12.2250231860348 -25.9136134768451 0.5 7.43664160893586 -25.55098085254 0.133974596215561 7.48636259047424 -29.9389069540998 0.5 11.7623654251687 -29.8632565971883 0.133974596215561 12.1204877781638 0 1.5707963267949 0 3.14159265358979 0 2.0943951023932 0 2.61799387799149 1.635138268314 1.5707963267949 0.1362615223595 1.5707963267949 0.272523044718999 1.5707963267949 0.408784567078499 1.5707963267949 0.545046089437999 1.5707963267949 0.681307611797499 1.5707963267949 0.817569134156998 1.5707963267949 0.953830656516498 1.5707963267949 1.090092178876 1.5707963267949 1.2263537012355 1.5707963267949 1.362615223595 1.5707963267949 1.4988767459545 1.5707963267949 1.635138268314 3.14159265358979 0.1635138268314 3.14159265358979 0.327027653662799 3.14159265358979 0.490541480494199 3.14159265358979 0.654055307325599 3.14159265358979 0.817569134156998 3.14159265358979 0.981082960988398 3.14159265358979 1.1445967878198 3.14159265358979 1.3081106146512 3.14159265358979 1.4716244414826 3.14159265358979 1.635138268314 2.0943951023932 1.635138268314 2.61799387799149 1.2263537012355 2.61799387799149 1.2263537012355 2.0943951023932 0.654055307325599 2.61799387799149 0.654055307325599 2.0943951023932 1.3081106146512 2.61799387799149 1.3081106146512 2.0943951023932 0.953830656516498 2.61799387799149 0.953830656516498 2.0943951023932 0.1635138268314 2.61799387799149 0.1635138268314 2.0943951023932 0.408784567078499 2.61799387799149 0.408784567078499 2.0943951023932 0.327027653662799 2.61799387799149 0.327027653662799 2.0943951023932 1.362615223595 2.61799387799149 1.362615223595 2.0943951023932 1.1445967878198 2.61799387799149 1.1445967878198 2.0943951023932 0.817569134156998 2.61799387799149 0.817569134156998 2.0943951023932 0.681307611797499 2.61799387799149 0.681307611797499 2.0943951023932 1.4716244414826 2.61799387799149 1.4716244414826 2.0943951023932 0.545046089437999 2.61799387799149 0.545046089437999 2.0943951023932 0.981082960988398 2.61799387799149 0.981082960988398 2.0943951023932 1.090092178876 2.61799387799149 1.090092178876 2.0943951023932 0.490541480494199 2.61799387799149 0.490541480494199 2.0943951023932 0.1362615223595 2.61799387799149 0.1362615223595 2.0943951023932 1.4988767459545 2.61799387799149 1.4988767459545 2.0943951023932 0.272523044718999 2.61799387799149 0.272523044718999 2.0943951023932 3 1 6 3 6 62 38 6 7 62 38 37 38 62 6 66 42 41 42 66 7 38 7 66 38 66 65 7 8 42 3 62 61 8 40 42 60 40 8 60 8 9 32 9 10 60 54 53 54 60 9 32 50 49 50 32 10 54 9 32 54 32 31 10 48 50 40 60 59 42 40 39 4 61 2 4 3 61 37 65 18 37 38 65 62 37 61 61 37 18 2 61 18 19 18 65 19 41 39 41 19 65 66 41 65 39 59 20 39 40 59 54 31 53 53 59 60 41 42 39 59 53 20 53 21 20 21 53 31 22 21 49 49 21 31 47 49 48 22 49 47 32 49 31 48 36 47 39 20 19 49 50 48 10 11 48 11 12 36 13 14 46 12 13 56 36 56 55 56 36 12 58 46 45 46 58 13 56 13 58 56 58 57 14 30 46 36 35 47 30 14 34 34 14 15 52 15 16 64 16 5 34 44 43 44 34 15 52 64 63 64 52 16 44 15 52 44 52 51 5 27 64 30 34 33 46 30 29 35 55 23 35 36 55 57 45 24 57 58 45 56 57 55 55 57 23 22 35 23 24 29 25 24 23 57 29 24 45 46 29 45 22 47 35 33 43 25 33 34 43 52 63 51 51 43 44 29 30 33 43 51 26 25 43 26 63 28 17 28 63 27 63 17 26 51 63 26 33 25 29 27 63 64 48 11 36
+-76 -2.22044604925031e-16 4.22643697721129 -75.5 0.133974596215561 4.22643697721129 -75.1339745962156 0.5 4.22643697721129 -75 1 4.22643697721129 -70.3857853359791 0 10.2140216049676 -75.9438216513256 0 5.04557321571712 -75.7763386075888 0 5.84937021381673 -75.5006871757325 0 6.62277597550256 -75.1220292365071 0 7.35130761459233 -74.647455582492 0 8.02132256293901 -74.0858531350895 0 8.62027404274747 -73.4477385270017 0 9.13694601899381 -72.7450611665446 0 9.56166323220075 -71.9909794716385 0 9.88647237847107 -71.1996144637453 0 10.1052910439808 -70.3214877799826 1 9.21609083367487 -74.930120024599 1 5.05945350948895 -74.7224333827808 1 5.86918557185294 -74.3827453295141 1 6.63299954166351 -73.9205508219211 1 7.32954529835211 -73.3487691163306 1 7.93935300178155 -72.6833826493509 1 8.4453773130258 -71.9429902969599 1 8.83347384551607 -71.1482874989066 1 9.09279452879489 -70.3536365579808 0.133974596215561 9.71505621932123 -70.3301020190849 0.5 9.34978820580989 -73.4961110332362 0.5 7.9860782896068 -73.745365373832 0.133974596215561 8.25412095395279 -71.9950525650571 0.5 8.95691902635234 -72.1372893266559 0.133974596215561 9.29417753234655 -74.5001806366815 0.5 6.6974831912315 -74.8210198624654 0.133974596215561 6.87365579810873 -72.9501003353368 0.5 8.42817508971101 -73.1604269830849 0.133974596215561 8.7277369321786 -72.7552836707386 0.5 8.55842347861546 -72.951720914286 0.133974596215561 8.86727134660726 -74.7067313703233 0.5 6.27689423406929 -75.0422965777548 0.133974596215561 6.42308105897829 -75.0859048937236 0.5 4.92734108376604 -75.4485031803818 0.133974596215561 4.9773118625083 -74.9425959450834 0.5 5.615119978559 -75.2949770569564 0.133974596215561 5.71412577743294 -71.7036063381631 0.5 9.06951663783603 -71.8250645156686 0.133974596215561 9.41480276169942 -74.3827279968835 0.5 6.90027138867366 -74.6951934667982 0.133974596215561 7.09090172814391 -72.348845715683 0.5 8.79158965357432 -72.5163060693325 0.133974596215561 9.11706104428496 -73.4384991143665 0.5 8.03884028681636 -73.6836460279636 0.133974596215561 8.31064460423857 -74.8489706039034 0.5 5.9132028877831 -75.1946767210589 0.133974596215561 6.03346043131711 -75.062222192517 0.5 5.08177412019951 -75.4231320270589 0.133974596215561 5.14275516271672 -71.1790557697077 0.5 9.22318818639769 -71.2631162487973 0.133974596215561 9.57943028395325 -74.025601664583 0.5 7.41269283521971 -74.3126059041133 0.133974596215561 7.6398561304662 -71.0264650303535 0.5 9.25675154948687 -71.0996465917666 0.133974596215561 9.61538653841672 -73.9766531495924 0.5 7.47357800932307 -74.2601676172843 0.133974596215561 7.70508209746169 0 1.5707963267949 0 2.0943951023932 0 2.61799387799149 0 3.14159265358979 1.5064543852758 1.5707963267949 0.136950398661436 1.5707963267949 0.273900797322872 1.5707963267949 0.410851195984308 1.5707963267949 0.547801594645745 1.5707963267949 0.684751993307181 1.5707963267949 0.821702391968617 1.5707963267949 0.958652790630053 1.5707963267949 1.09560318929149 1.5707963267949 1.23255358795293 1.5707963267949 1.36950398661436 1.5707963267949 1.5064543852758 3.14159265358979 0.1673838205862 3.14159265358979 0.334767641172399 3.14159265358979 0.502151461758599 3.14159265358979 0.669535282344799 3.14159265358979 0.836919102930999 3.14159265358979 1.0043029235172 3.14159265358979 1.1716867441034 3.14159265358979 1.3390705646896 3.14159265358979 1.5064543852758 2.0943951023932 1.5064543852758 2.61799387799149 0.821702391968617 2.61799387799149 0.821702391968617 2.0943951023932 1.1716867441034 2.61799387799149 1.1716867441034 2.0943951023932 0.502151461758599 2.61799387799149 0.502151461758599 2.0943951023932 0.958652790630053 2.61799387799149 0.958652790630053 2.0943951023932 1.0043029235172 2.61799387799149 1.0043029235172 2.0943951023932 0.410851195984308 2.61799387799149 0.410851195984308 2.0943951023932 0.136950398661436 2.61799387799149 0.136950398661436 2.0943951023932 0.273900797322872 2.61799387799149 0.273900797322872 2.0943951023932 1.23255358795293 2.61799387799149 1.23255358795293 2.0943951023932 0.547801594645745 2.61799387799149 0.547801594645745 2.0943951023932 1.09560318929149 2.61799387799149 1.09560318929149 2.0943951023932 0.836919102930999 2.61799387799149 0.836919102930999 2.0943951023932 0.334767641172399 2.61799387799149 0.334767641172399 2.0943951023932 0.1673838205862 2.61799387799149 0.1673838205862 2.0943951023932 1.3390705646896 2.61799387799149 1.3390705646896 2.0943951023932 0.669535282344799 2.61799387799149 0.669535282344799 2.0943951023932 1.36950398661436 2.61799387799149 1.36950398661436 2.0943951023932 0.684751993307181 2.61799387799149 0.684751993307181 2.0943951023932 1 6 40 6 7 54 2 40 39 40 2 1 54 42 41 42 54 7 40 6 54 40 54 53 7 52 42 38 52 8 8 52 7 32 8 9 58 9 10 38 32 31 32 38 8 46 58 57 58 46 9 32 9 46 32 46 45 10 62 58 52 38 37 42 52 51 3 39 4 3 2 39 53 41 17 53 54 41 40 53 39 39 53 17 4 39 17 18 17 41 18 51 37 51 18 41 42 51 41 37 31 19 37 38 31 46 57 45 45 31 32 51 52 37 31 45 19 45 20 19 20 45 57 20 61 21 61 20 57 57 62 61 62 28 61 37 19 18 62 57 58 10 11 62 11 12 50 12 13 36 28 50 49 50 28 11 34 36 35 36 34 12 50 12 34 50 34 33 13 48 36 11 28 62 48 13 30 30 13 14 56 14 15 60 15 5 30 44 43 44 30 14 56 60 59 60 56 15 44 14 56 44 56 55 5 25 60 48 30 29 36 48 47 27 49 21 27 28 49 33 35 22 33 34 35 50 33 49 49 33 21 21 33 22 22 47 23 47 48 29 35 47 22 23 47 29 36 47 35 27 21 61 43 55 24 43 44 55 59 25 26 59 55 56 29 30 43 55 59 24 23 43 24 16 24 59 26 16 59 43 23 29 25 59 60 28 27 61
+14 12 1 2.39766805776831
+-70.3857853359791 0 10.2140216049676 -70.3536365579808 0.133974596215561 9.71505621932123 -70.3301020190849 0.5 9.34978820580989 -70.3214877799826 1 9.21609083367487 -31.3857853359791 -2.22044604925031e-16 12.7268258555227 -60.6357853359791 -2.22044604925031e-16 10.8422226676064 -50.8857853359791 -2.22044604925031e-16 11.4704237302451 -41.1357853359791 -2.22044604925031e-16 12.0986247928839 -31.3214877799826 1 11.72889508423 -60.5714877799826 1 9.84429189631365 -50.8214877799826 1 10.4724929589524 -41.0714877799826 1 11.1006940215912 -31.3536365579808 0.133974596215561 12.2278604698763 -31.3301020190849 0.5 11.862592456365 0 7.105427357601e-15 0.523598775598299 7.105427357601e-15 1.0471975511966 7.105427357601e-15 1.5707963267949 7.105427357601e-15 0 39.0808672524243 0 9.77021681310607 0 19.5404336262121 0 29.3106504393182 1.5707963267949 39.0808672524243 1.5707963267949 9.77021681310607 1.5707963267949 19.5404336262121 1.5707963267949 29.3106504393182 0.523598775598299 39.0808672524243 1.0471975511966 39.0808672524243 1 2 6 6 2 7 8 7 13 13 5 8 7 2 13 2 3 13 3 4 10 3 10 11 14 11 12 11 14 3 12 9 14 3 14 13
+104 102 1 1.40494504643154
+-103 8 -6.48999977111816 -103 0 -6.48999977111816 -103 6 -6.48999977111816 -103 4 -6.48999977111816 -103 2 -6.48999977111816 -103 8 -6.48999977111816 -103.847114957633 8 -6.43447692339231 -104.679735543476 8 -6.26885839153318 -105.48361538846 8 -5.99597795453901 -106.244999885559 8 -5.62050467234353 -106.950861534932 8 -5.14886299690595 -107.589122848057 8 -4.5891228480568 -108.148862996906 8 -3.95086153493217 -108.620504672344 8 -3.24499988555909 -108.995977954539 8 -2.48361538846016 -109.268858391533 8 -1.67973554347639 -109.434476923392 8 -0.847114957633072 -109.489999771118 8 -1.27207490980568e-14 -109.434476923392 8 0.847114957633047 -109.268858391533 8 1.67973554347637 -108.995977954539 8 2.48361538846013 -108.620504672344 8 3.24499988555907 -108.148862996906 8 3.95086153493215 -107.589122848057 8 4.58912284805678 -106.950861534932 8 5.14886299690593 -106.244999885559 8 5.62050467234351 -105.48361538846 8 5.995977954539 -104.679735543476 8 6.26885839153317 -103.847114957633 8 6.43447692339231 -103 8 6.48999977111816 -102.152885042367 8 6.43447692339231 -101.320264456524 8 6.26885839153318 -100.51638461154 8 5.99597795453902 -99.7550001144409 8 5.62050467234354 -99.0491384650679 8 5.14886299690597 -98.4108771519432 8 4.58912284805682 -97.8511370030941 8 3.95086153493219 -97.3794953276565 8 3.24499988555911 -97.004022045461 8 2.48361538846018 -96.7311416084668 8 1.67973554347641 -96.5655230766077 8 0.847114957633096 -96.5100002288818 8 3.65726558049372e-14 -96.5655230766077 8 -0.847114957633023 -96.7311416084668 8 -1.67973554347634 -97.004022045461 8 -2.48361538846011 -97.3794953276565 8 -3.24499988555906 -97.851137003094 8 -3.95086153493214 -98.4108771519432 8 -4.58912284805678 -99.0491384650678 8 -5.14886299690594 -99.7550001144409 8 -5.62050467234352 -100.51638461154 8 -5.99597795453901 -101.320264456524 8 -6.26885839153318 -102.152885042367 8 -6.43447692339231 -103 0 -6.48999977111816 -103.847114957633 0 -6.43447692339231 -104.679735543476 0 -6.26885839153318 -105.48361538846 0 -5.99597795453901 -106.244999885559 0 -5.62050467234353 -106.950861534932 0 -5.14886299690595 -107.589122848057 0 -4.5891228480568 -108.148862996906 0 -3.95086153493217 -108.620504672344 0 -3.24499988555909 -108.995977954539 0 -2.48361538846016 -109.268858391533 0 -1.67973554347639 -109.434476923392 0 -0.847114957633072 -109.489999771118 0 -1.27207490980568e-14 -109.434476923392 0 0.847114957633047 -109.268858391533 0 1.67973554347637 -108.995977954539 0 2.48361538846013 -108.620504672344 0 3.24499988555907 -108.148862996906 0 3.95086153493215 -107.589122848057 0 4.58912284805678 -106.950861534932 0 5.14886299690593 -106.244999885559 0 5.62050467234351 -105.48361538846 0 5.995977954539 -104.679735543476 0 6.26885839153317 -103.847114957633 0 6.43447692339231 -103 0 6.48999977111816 -102.152885042367 0 6.43447692339231 -101.320264456524 0 6.26885839153318 -100.51638461154 0 5.99597795453902 -99.7550001144409 0 5.62050467234354 -99.0491384650679 0 5.14886299690597 -98.4108771519432 0 4.58912284805682 -97.8511370030941 0 3.95086153493219 -97.3794953276565 0 3.24499988555911 -97.004022045461 0 2.48361538846018 -96.7311416084668 0 1.67973554347641 -96.5655230766077 0 0.847114957633096 -96.5100002288818 0 3.65726558049372e-14 -96.5655230766077 0 -0.847114957633023 -96.7311416084668 0 -1.67973554347634 -97.004022045461 0 -2.48361538846011 -97.3794953276565 0 -3.24499988555906 -97.851137003094 0 -3.95086153493214 -98.4108771519432 0 -4.58912284805678 -99.0491384650678 0 -5.14886299690594 -99.7550001144409 0 -5.62050467234352 -100.51638461154 0 -5.99597795453901 -101.320264456524 0 -6.26885839153318 -102.152885042367 0 -6.43447692339231 -103 6 -6.48999977111816 -103 4 -6.48999977111816 -103 2 -6.48999977111816 0 -30 0 -38 0 -32 0 -34 0 -36 6.28318530717959 -30 6.15228561328001 -30 6.02138591938044 -30 5.89048622548086 -30 5.75958653158129 -30 5.62868683768171 -30 5.49778714378214 -30 5.36688744988256 -30 5.23598775598299 -30 5.10508806208342 -30 4.97418836818384 -30 4.84328867428427 -30 4.71238898038469 -30 4.58148928648512 -30 4.45058959258554 -30 4.31968989868597 -30 4.18879020478639 -30 4.05789051088682 -30 3.92699081698724 -30 3.79609112308767 -30 3.66519142918809 -30 3.53429173528852 -30 3.40339204138895 -30 3.27249234748937 -30 3.1415926535898 -30 3.01069295969022 -30 2.87979326579065 -30 2.74889357189107 -30 2.6179938779915 -30 2.48709418409192 -30 2.35619449019235 -30 2.22529479629277 -30 2.0943951023932 -30 1.96349540849363 -30 1.83259571459405 -30 1.70169602069448 -30 1.5707963267949 -30 1.43989663289533 -30 1.30899693899575 -30 1.17809724509618 -30 1.0471975511966 -30 0.916297857297026 -30 0.785398163397451 -30 0.654498469497875 -30 0.5235987755983 -30 0.392699081698725 -30 0.261799387799149 -30 0.130899693899574 -30 6.28318530717959 -38 6.15228561328001 -38 6.02138591938044 -38 5.89048622548086 -38 5.75958653158129 -38 5.62868683768171 -38 5.49778714378214 -38 5.36688744988256 -38 5.23598775598299 -38 5.10508806208342 -38 4.97418836818384 -38 4.84328867428427 -38 4.71238898038469 -38 4.58148928648512 -38 4.45058959258554 -38 4.31968989868597 -38 4.18879020478639 -38 4.05789051088682 -38 3.92699081698724 -38 3.79609112308767 -38 3.66519142918809 -38 3.53429173528852 -38 3.40339204138895 -38 3.27249234748937 -38 3.1415926535898 -38 3.01069295969022 -38 2.87979326579065 -38 2.74889357189107 -38 2.6179938779915 -38 2.48709418409192 -38 2.35619449019235 -38 2.22529479629277 -38 2.0943951023932 -38 1.96349540849363 -38 1.83259571459405 -38 1.70169602069448 -38 1.5707963267949 -38 1.43989663289533 -38 1.30899693899575 -38 1.17809724509618 -38 1.0471975511966 -38 0.916297857297026 -38 0.785398163397451 -38 0.654498469497875 -38 0.5235987755983 -38 0.392699081698725 -38 0.261799387799149 -38 0.130899693899574 -38 6.28318530717959 -32 6.28318530717959 -34 6.28318530717959 -36 2 101 5 5 101 4 51 100 99 50 99 98 52 101 100 96 48 97 98 97 49 95 47 96 46 95 94 44 93 92 45 94 93 91 43 92 42 91 90 41 90 89 39 88 87 38 87 86 40 89 88 36 85 84 35 84 83 33 82 81 31 80 79 32 81 80 34 83 82 37 86 85 31 79 78 3 4 53 1 3 53 53 4 101 53 101 52 51 52 100 51 99 50 50 98 49 48 96 47 46 94 45 95 46 47 97 48 49 44 45 93 44 92 43 43 91 42 41 89 40 40 88 39 90 41 42 38 86 37 37 85 36 35 83 34 33 81 32 82 33 34 84 35 36 87 38 39 80 31 32 78 30 31 28 77 76 27 76 75 25 74 73 24 73 72 26 75 74 22 71 70 21 70 69 19 68 67 17 66 65 18 67 66 20 69 68 23 72 71 15 64 63 14 63 62 12 61 60 11 60 59 13 62 61 9 58 57 8 57 56 55 54 104 104 103 55 56 55 7 59 58 10 65 64 16 7 55 103 30 77 29 29 77 28 27 75 26 26 74 25 76 27 28 24 72 23 23 71 22 21 69 20 19 67 18 68 19 20 70 21 22 73 24 25 17 65 16 16 64 15 62 13 14 14 15 63 61 12 13 18 66 17 12 60 11 11 59 10 9 57 8 6 7 102 56 7 8 58 9 10 102 7 103 77 30 78
+18 17 1 5.11646155244813
+-89.081302808772 3 -16.0239676304806 -89.081302808772 8.62393968310013 -16.0239676304806 -66.810977106579 3 -17.4588642737041 -44.540651404386 3 -18.8937609169276 -22.270325702193 3 -20.3286575601512 0 3 -21.7635542033747 -86.5 13 -16.1902832373999 -87.3592862366635 10.1974137782906 -16.13491867053 -86.7196459954998 11.5343207746377 -16.1761312530126 2.27015712151488e-16 22 -21.7635542033747 -86.5 25 -16.1902832373999 -66 22 -17.5111162408969 -89.081302808772 29.3760603168999 -16.0239676304806 -87.0428487503121 27.2657896498585 -16.1553070156771 -87.903802908953 28.4738115208435 -16.0998349831293 -88.8503645756781 38 -16.0388471836533 -89.081302808772 38 -16.0239676304806 -44.540651404386 20.5 -18.8937609169276 89.2660146087853 -3 89.2660146087853 -8.62393968310013 66.949510956589 -3 44.6330073043927 -3 22.3165036521963 -3 0 -3 86.6793594188384 -13 87.5404274020918 -10.1974137782906 86.8994608545475 -11.5343207746377 -2.22044604925031e-16 -22 86.6793594188384 -25 66.1368522733334 -22 89.2660146087853 -29.3760603168999 87.2233337765075 -27.2657896498585 88.0860731402066 -28.4738115208435 89.0345975208097 -38 89.2660146087853 -38 44.6330073043927 -20.5 10 18 5 12 18 10 12 11 7 14 11 12 18 12 3 6 10 5 18 3 4 4 5 18 3 7 9 3 12 7 15 16 13 16 15 14 17 13 16 8 2 1 1 3 8 8 3 9 16 14 12
+17 15 1 4.55376482283495
+-66 22 17.5111162408969 -66 22 10.4966016058463 -31.3857853359791 22 12.7268258555227 -1.39644778365369 22 21.6735798462864 -25 22 6.73924122776646 -28.2255781801711 22 12.0592584801499 -25.8693796223569 22 9.84998624150725 -5.31950330591293e-15 22 21.7185204322445 -0.465768214019647 22 21.7135255022447 -0.931322188802096 22 21.6985430097615 -25 22 -6.73924122776635 2.27015712151488e-16 22 -21.7635542033747 -31.3857853359791 22 -12.7268258555226 -25.8693796223569 22 -9.84998624150714 -28.2255781801711 22 -12.0592584801498 -66 22 -17.5111162408969 -66 22 -10.4966016058463 72.8484683036804 -556.988883759103 72.8484683036804 -564.003398394154 38.2342536396595 -561.773174144477 8.24491608733412 -552.826420153714 31.8484683036804 -567.760758772234 35.0740464838515 -562.44074151985 32.7178479260373 -564.650013758493 6.84846830368043 -552.781479567755 7.31423651770007 -552.786474497755 7.77979049248251 -552.801456990239 31.8484683036804 -581.239241227766 6.84846830368042 -596.263554203375 38.2342536396595 -587.226825855523 32.7178479260373 -584.349986241507 35.0740464838515 -586.55925848015 72.8484683036804 -592.011116240897 72.8484683036804 -584.996601605846 4 12 11 11 12 14 12 15 14 4 11 5 9 8 4 4 10 9 8 12 4 5 7 4 13 15 12 16 17 13 13 12 16 7 6 4 3 2 1 3 1 4 6 3 4
+14 12 1 1.7139018883058
+-1.3964477836537 3 21.6735798462864 -1.39644778365369 22 21.6735798462864 -1.39644778365369 7.75 21.6735798462864 -1.39644778365369 12.5 21.6735798462864 -1.39644778365369 17.25 21.6735798462864 -5.31950330591293e-15 3 21.7185204322445 -0.465768214019639 3 21.7135255022447 -0.931322188802086 3 21.6985430097615 -5.31950330591293e-15 22 21.7185204322445 -0.465768214019647 22 21.7135255022447 -0.931322188802096 22 21.6985430097615 0 7.75 21.7185204322445 0 12.5 21.7185204322445 0 17.25 21.7185204322445 6.21884336566049 -3 6.21884336566049 -22 6.21884336566049 -7.75 6.21884336566049 -12.5 6.21884336566049 -17.25 6.28318530717959 -3 6.26173799333989 -3 6.24029067950019 -3 6.28318530717959 -22 6.26173799333989 -22 6.24029067950019 -22 6.28318530717959 -7.75 6.28318530717959 -12.5 6.28318530717959 -17.25 2 11 5 5 11 4 3 4 8 8 1 3 4 11 8 11 10 8 10 9 14 10 14 13 7 13 12 13 7 10 12 6 7 10 7 8
+17 15 1 1.00799827973861
+-98.5827161274038 3 -16.9333281781492 -98.5827161274038 8 -16.9333281781492 -98.5827161274038 4.25 -16.9333281781492 -98.5827161274038 5.5 -16.9333281781492 -98.5827161274038 6.75 -16.9333281781492 -95.4539285023264 3 -16.2928237283859 -92.2747811376762 3 -15.9885541327281 -89.081302808772 3 -16.0239676304806 -91.5 8 -15.9658889549164 -93.8841091281634 8 -16.0998611025149 -96.2500108721117 8 -16.4230233052967 -89.081302808772 8.62393968310013 -16.0239676304806 -89.081302808772 4.40598492077503 -16.0239676304806 -89.081302808772 5.81196984155007 -16.0239676304806 -89.081302808772 7.2179547623251 -16.0239676304806 -90.0568788533945 8.21278771042945 -15.9770425502351 -89.5076079899165 8.41411140740702 -15.999545588391 6.02800878236089 -3 6.02800878236089 -8 6.02800878236089 -4.25 6.02800878236089 -5.5 6.02800878236089 -6.75 6.13451493780682 -3 6.24102109325275 -3 6.34752724869869 -3 6.26685889817301 -8 6.1872421929023 -8 6.10762548763159 -8 6.34752724869869 -8.62393968310013 6.34752724869869 -4.40598492077503 6.34752724869869 -5.81196984155007 6.34752724869869 -7.2179547623251 6.3149690127571 -8.21278771042945 6.33329365690212 -8.41411140740702 5 2 11 5 11 4 6 11 10 4 11 3 1 3 11 6 1 11 10 7 6 9 16 7 17 12 15 16 17 8 14 13 17 14 17 15 8 17 13 8 7 16 9 7 10
+21 20 1 5.04884917962322
+-89.081302808772 3 16.0239676304806 -89.081302808772 8.62393968310014 16.0239676304806 -1.3964477836537 3 21.6735798462864 -23.3176615399333 3 20.261176792335 -45.2388752962128 3 18.8487737383835 -67.1600890524924 3 17.4363706844321 -86.5 13 16.1902832373999 -87.3592862366634 10.1974137782906 16.1349186705299 -86.7196459954998 11.5343207746377 16.1761312530125 -1.39644778365369 7.75 21.6735798462864 -1.39644778365369 12.5 21.6735798462864 -1.39644778365369 17.25 21.6735798462864 -1.39644778365369 22 21.6735798462864 -86.5 25 16.1902832373999 -66 22 17.5111162408969 -89.081302808772 29.3760603168999 16.0239676304806 -87.0428487503121 27.2657896498585 16.155307015677 -87.903802908953 28.4738115208435 16.0998349831292 -88.8503645756781 38 16.0388471836533 -89.081302808772 38 16.0239676304806 -45.2388752962128 20.5 18.8487737383835 87.8666712637106 -3 87.8666712637106 -8.62393968310014 0 -3 21.9666678159277 -3 43.9333356318553 -3 65.900003447783 -3 85.2800160737638 -13 86.1410840570171 -10.1974137782906 85.5001175094728 -11.5343207746377 0 -7.75 0 -12.5 0 -17.25 0 -22 85.2800160737638 -25 64.7375089282587 -22 87.8666712637106 -29.3760603168999 85.8239904314328 -27.2657896498585 86.6867297951319 -28.4738115208435 87.635254175735 -38 87.8666712637106 -38 43.9333356318553 -20.5 4 12 13 13 21 4 12 4 11 15 21 13 6 21 15 3 10 4 4 10 11 4 21 5 21 6 5 15 7 6 18 17 19 19 20 16 19 16 18 14 15 17 7 9 6 14 7 15 8 2 1 1 6 8 8 6 9 17 15 19
+62 60 1 3.15803629908382
+-98.5827161274038 3 -16.9333281781492 -98.5827161274038 4.25 -16.9333281781492 -98.5827161274038 5.5 -16.9333281781492 -98.5827161274038 6.75 -16.9333281781492 -98.5827161274038 8 -16.9333281781492 -98.5827161274038 3 16.9333281781492 -100.90643888067 3 17.3743201835246 -103.268403980929 3 17.4979415733115 -105.625466239767 3 17.3019341989226 -107.934570027256 3 16.7898784583483 -110.153535754051 3 15.9711278942818 -112.241830351162 3 14.860638336234 -114.161307673309 3 13.4786947076389 -115.876905301193 3 11.8505404882692 -117.357285014411 3 10.005916600441 -118.575405235742 3 7.97851814201292 -119.50901499016 3 5.80537888984623 -120.141060355593 3 3.52619481678678 -120.459995980936 3 1.18259897924576 -120.459995980936 3 -1.18259897924579 -120.141060355593 3 -3.52619481678681 -119.50901499016 3 -5.80537888984625 -118.575405235742 3 -7.97851814201295 -117.357285014411 3 -10.0059166004411 -115.876905301193 3 -11.8505404882692 -114.161307673309 3 -13.478694707639 -112.241830351162 3 -14.860638336234 -110.153535754051 3 -15.9711278942818 -107.934570027256 3 -16.7898784583483 -105.625466239767 3 -17.3019341989226 -103.268403980929 3 -17.4979415733115 -100.90643888067 3 -17.3743201835246 -98.5827161274038 8 16.9333281781492 -100.90643888067 8 17.3743201835246 -103.268403980929 8 17.4979415733115 -105.625466239767 8 17.3019341989226 -107.934570027256 8 16.7898784583483 -110.153535754051 8 15.9711278942818 -112.241830351162 8 14.860638336234 -114.161307673309 8 13.478694707639 -115.876905301193 8 11.8505404882692 -117.357285014411 8 10.0059166004411 -118.575405235742 8 7.97851814201295 -119.50901499016 8 5.80537888984627 -120.141060355593 8 3.52619481678683 -120.459995980936 8 1.18259897924581 -120.459995980936 8 -1.18259897924573 -120.141060355593 8 -3.52619481678675 -119.50901499016 8 -5.80537888984619 -118.575405235742 8 -7.97851814201287 -117.357285014411 8 -10.005916600441 -115.876905301193 8 -11.8505404882692 -114.161307673309 8 -13.4786947076389 -112.241830351162 8 -14.860638336234 -110.153535754052 8 -15.9711278942818 -107.934570027256 8 -16.7898784583483 -105.625466239767 8 -17.3019341989225 -103.268403980929 8 -17.4979415733115 -100.90643888067 8 -17.3743201835246 -98.5827161274038 4.25 16.9333281781492 -98.5827161274038 5.5 16.9333281781492 -98.5827161274038 6.75 16.9333281781492 2.88641612877109 -3 2.88641612877109 -4.25 2.88641612877109 -5.5 2.88641612877109 -6.75 2.88641612877109 -8 6.53836183199828 -3 6.40310458373061 -3 6.26784733546294 -3 6.13259008719526 -3 5.99733283892759 -3 5.86207559065992 -3 5.72681834239224 -3 5.59156109412457 -3 5.45630384585689 -3 5.32104659758922 -3 5.18578934932155 -3 5.05053210105387 -3 4.9152748527862 -3 4.78001760451853 -3 4.64476035625085 -3 4.50950310798318 -3 4.37424585971551 -3 4.23898861144783 -3 4.10373136318016 -3 3.96847411491248 -3 3.83321686664481 -3 3.69795961837714 -3 3.56270237010946 -3 3.42744512184179 -3 3.29218787357412 -3 3.15693062530644 -3 3.02167337703877 -3 6.53836183199828 -8 6.40310458373061 -8 6.26784733546294 -8 6.13259008719526 -8 5.99733283892759 -8 5.86207559065992 -8 5.72681834239224 -8 5.59156109412457 -8 5.45630384585689 -8 5.32104659758922 -8 5.18578934932155 -8 5.05053210105388 -8 4.9152748527862 -8 4.78001760451853 -8 4.64476035625086 -8 4.50950310798318 -8 4.37424585971551 -8 4.23898861144784 -8 4.10373136318016 -8 3.96847411491249 -8 3.83321686664482 -8 3.69795961837714 -8 3.56270237010947 -8 3.4274451218418 -8 3.29218787357412 -8 3.15693062530645 -8 3.02167337703878 -8 6.53836183199828 -4.25 6.53836183199828 -5.5 6.53836183199828 -6.75 5 59 4 4 59 3 57 30 58 59 58 31 29 57 56 55 28 56 27 55 54 25 53 52 26 54 53 23 51 50 21 49 48 22 50 49 24 52 51 20 48 47 2 3 32 32 1 2 59 32 3 32 59 31 30 57 29 58 30 31 28 29 56 28 55 27 26 53 25 54 26 27 24 51 23 22 49 21 50 22 23 52 24 25 48 20 21 47 19 20 18 46 45 17 45 44 15 43 42 14 41 40 14 42 41 16 44 43 11 39 38 10 37 36 10 38 37 7 35 34 33 62 34 36 35 9 40 39 13 34 62 61 19 46 18 17 44 16 45 17 18 15 42 14 13 39 12 40 13 14 43 15 16 11 38 10 36 9 10 12 39 11 7 61 60 9 35 8 6 7 60 35 7 8 7 34 61 46 19 47
+17 15 1 1.00722030724448
+-89.081302808772 3 16.0239676304806 -89.081302808772 8.62393968310014 16.0239676304806 -89.081302808772 4.40598492077504 16.0239676304806 -89.081302808772 5.81196984155007 16.0239676304806 -89.081302808772 7.21795476232511 16.0239676304806 -92.2747811376762 3 15.9885541327281 -95.4539285023264 3 16.2928237283859 -98.5827161274038 3 16.9333281781492 -91.5 8 15.9658889549164 -90.0398685580385 8.2178575479086 15.9775736588581 -89.5010004063661 8.41702053012013 15.9998827158415 -98.5827161274038 8 16.9333281781492 -98.5827161274038 4.25 16.9333281781492 -98.5827161274038 5.5 16.9333281781492 -98.5827161274038 6.75 16.9333281781492 -96.2500108721117 8 16.4230233052967 -93.8841091281635 8 16.0998611025149 3.07725071207069 -3 3.07725071207069 -8.62393968310014 3.07725071207069 -4.40598492077504 3.07725071207069 -5.81196984155007 3.07725071207069 -7.21795476232511 3.18375686751663 -3 3.29026302296256 -3 3.39676917840849 -3 3.15791906259637 -8 3.1092416489637 -8.2178575479086 3.09126377082511 -8.41702053012013 3.39676917840849 -8 3.39676917840849 -4.25 3.39676917840849 -5.5 3.39676917840849 -6.75 3.31715247313779 -8 3.23753576786708 -8 2 11 5 1 10 6 11 10 1 4 5 11 1 3 11 4 11 3 10 9 6 7 17 16 12 15 16 14 16 15 6 17 7 8 16 13 8 7 16 14 13 16 17 6 9
+7 5 1 3.2584979574357
+-31.3214877799826 1 -11.7288950842299 -31.3214877799826 7 -11.7288950842299 -41.0714877799826 1 -11.1006940215912 -50.8214877799826 1 -10.4724929589524 -60.5714877799826 1 -9.8442918963136 -70.3214877799826 1 -9.21609083367482 -70.3214877799826 7 -9.21609083367482 0 -1 0 -7 9.77021681310607 -1 19.5404336262121 -1 29.3106504393182 -1 39.0808672524243 -1 39.0808672524243 -7 2 3 1 3 2 4 4 7 5 7 4 2 6 5 7
+29 27 1 0.614368888152546
+-26 1 -6.73924122776635 -26 7 -6.73924122776635 -26 2.5 -6.73924122776635 -26 4 -6.73924122776635 -26 5.5 -6.73924122776635 -26.0666931334625 1 -7.55317203598886 -26.2649933442295 1 -8.34538940580256 -26.5896105273321 1 -9.09475915369695 -27.0318847879236 1 -9.7812901530284 -27.5800174634885 1 -10.3866676423711 -28.2193858797522 1 -10.8947418130483 -28.9329334434676 1 -11.2919586416704 -29.7016246654752 1 -11.5677214742515 -30.5049529752708 1 -11.7146737158328 -31.3214877799826 1 -11.7288950842299 -31.3214877799826 7 -11.7288950842299 -26.0551396185497 7 -7.47975173273139 -26.2193423231854 7 -8.20392965098609 -26.4889864841077 7 -8.89580262486057 -26.8581248708456 7 -9.5401108096091 -27.3186158234643 7 -10.1226434422175 -27.8603028237748 7 -10.6305522718238 -28.4712385059487 7 -11.052634938779 -29.1379481657968 7 -11.3795820521822 -29.845726956788 7 -11.6041825163858 -30.5789642179011 7 -11.7214825778208 -31.3214877799826 2.5 -11.7288950842299 -31.3214877799826 4 -11.7288950842299 -31.3214877799826 5.5 -11.7288950842299 1.5707963267949 -1 1.5707963267949 -7 1.5707963267949 -2.5 1.5707963267949 -4 1.5707963267949 -5.5 1.7343101536263 -1 1.8978239804577 -1 2.0613378072891 -1 2.22485163412049 -1 2.38836546095189 -1 2.55187928778329 -1 2.71539311461469 -1 2.87890694144609 -1 3.04242076827749 -1 3.20593459510889 -1 3.20593459510889 -7 1.71944526027799 -7 1.86809419376108 -7 2.01674312724417 -7 2.16539206072726 -7 2.31404099421035 -7 2.46268992769344 -7 2.61133886117653 -7 2.75998779465962 -7 2.90863672814271 -7 3.0572856616258 -7 3.20593459510889 -2.5 3.20593459510889 -4 3.20593459510889 -5.5 2 17 5 4 5 17 6 17 18 8 19 20 7 18 19 9 20 21 4 17 3 3 17 1 17 6 1 7 19 8 18 7 6 20 9 8 21 10 9 11 22 23 12 23 24 14 25 26 16 29 26 24 25 13 28 26 29 10 22 11 12 24 13 23 12 11 15 26 27 14 26 15 14 13 25 28 27 26 22 10 21
+27 25 1 0.604456755036829
+-70.3214877799826 1 -9.21609083367482 -70.3214877799826 7 -9.21609083367482 -70.3214877799826 2.5 -9.21609083367482 -70.3214877799826 4 -9.21609083367482 -70.3214877799826 5.5 -9.21609083367482 -71.1482874989066 1 -9.09279452879484 -71.9429902969599 1 -8.83347384551602 -72.6833826493509 1 -8.44537731302576 -73.3487691163306 1 -7.9393530017815 -73.9205508219211 1 -7.32954529835206 -74.3827453295141 1 -6.63299954166346 -74.7224333827808 1 -5.8691855718529 -74.930120024599 1 -5.0594535094889 -75 1 -4.22643697721124 -75 7 -4.22643697721124 -71.0666754944365 7 -9.11133241002949 -71.7877017691617 7 -8.89592542719547 -72.4682345209984 7 -8.57474910369801 -73.0928588921452 7 -8.15507845656241 -73.6474264146048 7 -7.64641951372273 -74.1193754894285 7 -7.06029399144038 -74.4980159215328 7 -6.40997831403934 -74.7747710650429 7 -5.71020288746419 -74.9433720942902 7 -4.97681843846456 -75 2.5 -4.22643697721124 -75 4 -4.22643697721124 -75 5.5 -4.22643697721124 3.20593459510889 -1 3.20593459510889 -7 3.20593459510889 -2.5 3.20593459510889 -4 3.20593459510889 -5.5 3.37331841569509 -1 3.54070223628129 -1 3.70808605686749 -1 3.87546987745369 -1 4.04285369803989 -1 4.21023751862609 -1 4.37762133921229 -1 4.54500515979849 -1 4.71238898038469 -1 4.71238898038469 -7 3.35658003363647 -7 3.50722547216405 -7 3.65787091069163 -7 3.80851634921921 -7 3.95916178774679 -7 4.10980722627437 -7 4.26045266480195 -7 4.41109810332953 -7 4.56174354185711 -7 4.71238898038469 -2.5 4.71238898038469 -4 4.71238898038469 -5.5 2 16 5 4 5 16 6 16 17 7 17 18 8 18 19 4 16 3 3 16 1 16 6 1 7 18 8 17 7 6 19 9 8 19 20 9 10 20 21 11 21 22 13 23 24 15 27 24 22 23 12 26 24 27 10 21 11 11 22 12 14 24 25 13 24 14 13 12 23 24 26 25 20 10 9
+10 8 1 1.39822276492417
+-26 1 6.7392412277664 -26 7 6.7392412277664 -26 1 3.36962061388321 -26 1 2.48689957516035e-14 -26 1 -3.36962061388316 -26 1 -6.73924122776635 -26 7 -6.73924122776635 -26 2.5 -6.73924122776635 -26 4 -6.73924122776635 -26 5.5 -6.73924122776635 -1.77635683940025e-15 -1 0 -7 3.36962061388319 -1 6.73924122776638 -1 10.1088618416496 -1 13.4784824555328 -1 13.4784824555328 -7 13.4784824555328 -2.5 13.4784824555328 -4 13.4784824555328 -5.5 1 2 3 4 3 2 10 5 4 4 2 7 7 10 4 9 8 5 8 6 5 10 9 5
+10 8 1 0.882397650522799
+-75 1 4.22643697721129 -75 7 4.22643697721129 -75 1 -4.22643697721124 -75 1 -2.11321848860561 -75 1 2.48689957516035e-14 -75 1 2.11321848860566 -75 7 -4.22643697721124 -75 2.5 -4.22643697721124 -75 4 -4.22643697721124 -75 5.5 -4.22643697721124 0 -1 0 -7 8.45287395442253 -1 6.3396554658169 -1 4.22643697721126 -1 2.11321848860563 -1 8.45287395442253 -7 8.45287395442253 -2.5 8.45287395442253 -4 8.45287395442253 -5.5 1 2 6 5 6 2 9 4 5 5 2 10 7 10 2 9 8 4 8 3 4 10 9 5
+-31.3214877799826 1 11.72889508423 -31.3214877799826 7 11.72889508423 -31.3214877799826 2.5 11.72889508423 -31.3214877799826 4 11.72889508423 -31.3214877799826 5.5 11.72889508423 -30.5049529752708 1 11.7146737158328 -29.7016246654752 1 11.5677214742516 -28.9329334434676 1 11.2919586416704 -28.2193858797522 1 10.8947418130483 -27.5800174634885 1 10.3866676423712 -27.0318847879236 1 9.78129015302846 -26.5896105273321 1 9.09475915369701 -26.2649933442295 1 8.34538940580262 -26.0666931334625 1 7.55317203598891 -26 1 6.7392412277664 -26 7 6.7392412277664 -30.5789642179011 7 11.7214825778209 -29.845726956788 7 11.6041825163858 -29.1379481657968 7 11.3795820521823 -28.4712385059487 7 11.0526349387791 -27.8603028237748 7 10.6305522718238 -27.3186158234643 7 10.1226434422175 -26.8581248708456 7 9.54011080960916 -26.4889864841077 7 8.89580262486062 -26.2193423231854 7 8.20392965098615 -26.0551396185497 7 7.47975173273145 -26 2.5 6.7392412277664 -26 4 6.7392412277664 -26 5.5 6.7392412277664 6.21884336566049 -1 6.21884336566049 -7 6.21884336566049 -2.5 6.21884336566049 -4 6.21884336566049 -5.5 6.38235719249189 -1 6.54587101932329 -1 6.70938484615469 -1 6.87289867298608 -1 7.03641249981748 -1 7.19992632664888 -1 7.36344015348028 -1 7.52695398031168 -1 7.69046780714308 -1 7.85398163397448 -1 7.85398163397448 -7 6.36749229914358 -7 6.51614123262667 -7 6.66479016610976 -7 6.81343909959285 -7 6.96208803307594 -7 7.11073696655903 -7 7.25938590004212 -7 7.40803483352521 -7 7.5566837670083 -7 7.70533270049139 -7 7.85398163397448 -2.5 7.85398163397448 -4 7.85398163397448 -5.5 2 17 5 4 5 17 6 17 18 8 19 20 7 18 19 9 20 21 4 17 3 3 17 1 17 6 1 7 19 8 18 7 6 20 9 8 21 10 9 11 22 23 12 23 24 14 25 26 16 29 26 24 25 13 28 26 29 10 22 11 12 24 13 23 12 11 15 26 27 14 26 15 14 13 25 28 27 26 22 10 21
+24 22 1 0.648576632562969
+-75 1 4.22643697721129 -75 7 4.22643697721129 -74.930120024599 1 5.05945350948895 -74.7224333827808 1 5.86918557185294 -74.3827453295141 1 6.63299954166351 -73.9205508219211 1 7.32954529835211 -73.3487691163306 1 7.93935300178155 -72.6833826493509 1 8.4453773130258 -71.9429902969599 1 8.83347384551607 -71.1482874989066 1 9.09279452879489 -70.3214877799826 1 9.21609083367487 -70.3214877799826 7 9.21609083367487 -74.9433720942902 7 4.9768184384646 -74.7747710650429 7 5.71020288746424 -74.4980159215328 7 6.40997831403939 -74.1193754894285 7 7.06029399144043 -73.6474264146048 7 7.64641951372277 -73.0928588921452 7 8.15507845656246 -72.4682345209984 7 8.57474910369806 -71.7877017691617 7 8.89592542719551 -71.0666754944365 7 9.11133241002954 -70.3214877799826 2.5 9.21609083367487 -70.3214877799826 4 9.21609083367487 -70.3214877799826 5.5 9.21609083367487 4.71238898038469 -1 4.71238898038469 -7 4.87977280097089 -1 5.04715662155709 -1 5.21454044214329 -1 5.38192426272949 -1 5.54930808331569 -1 5.71669190390189 -1 5.88407572448809 -1 6.05145954507429 -1 6.21884336566049 -1 6.21884336566049 -7 4.86303441891227 -7 5.01367985743985 -7 5.16432529596743 -7 5.31497073449501 -7 5.46561617302259 -7 5.61626161155017 -7 5.76690705007775 -7 5.91755248860533 -7 6.06819792713291 -7 6.21884336566049 -2.5 6.21884336566049 -4 6.21884336566049 -5.5 2 13 1 13 14 3 15 16 5 16 17 6 14 15 4 3 1 13 4 3 14 6 5 16 7 6 17 4 15 5 17 18 7 8 18 19 9 19 20 21 12 24 20 21 10 21 24 23 8 19 9 9 20 10 11 21 22 11 10 21 22 21 23 18 8 7
+13 11 1 3.52247251203152
+-31.3214877799826 1 11.72889508423 -31.3214877799826 2.5 11.72889508423 -31.3214877799826 4 11.72889508423 -31.3214877799826 5.5 11.72889508423 -31.3214877799826 7 11.72889508423 -70.3214877799826 1 9.21609083367487 -60.5714877799826 1 9.84429189631365 -50.8214877799826 1 10.4724929589524 -41.0714877799826 1 11.1006940215912 -70.3214877799826 7 9.21609083367487 -70.3214877799826 2.5 9.21609083367487 -70.3214877799826 4 9.21609083367487 -70.3214877799826 5.5 9.21609083367487 -1.4210854715202e-14 -1 -7.09072460333513e-15 -2.5 -7.09072460333513e-15 -4 -7.09072460333513e-15 -5.5 -7.105427357601e-15 -7 39.0808672524243 -1 29.3106504393182 -1 19.5404336262121 -1 9.77021681310606 -1 39.0808672524243 -7 39.0808672524243 -2.5 39.0808672524243 -4 39.0808672524243 -5.5 4 5 9 3 4 9 1 2 9 9 2 3 5 8 9 10 13 7 13 12 7 8 10 7 11 6 7 12 11 7 10 8 5
+82 82 1 3.79725775760706
+-91.5 8 15.9658889549164 -91.5 8 -15.9658889549164 -98.5827161274038 8 16.9333281781492 -96.2500108721117 8 16.4230233052967 -93.8841091281635 8 16.0998611025149 -93.8841091281634 8 -16.0998611025149 -96.2500108721117 8 -16.4230233052967 -98.5827161274038 8 -16.9333281781492 -100.90643888067 8 17.3743201835246 -103.268403980929 8 17.4979415733115 -105.625466239767 8 17.3019341989226 -107.934570027256 8 16.7898784583483 -110.153535754051 8 15.9711278942818 -112.241830351162 8 14.860638336234 -114.161307673309 8 13.478694707639 -115.876905301193 8 11.8505404882692 -117.357285014411 8 10.0059166004411 -118.575405235742 8 7.97851814201295 -119.50901499016 8 5.80537888984627 -120.141060355593 8 3.52619481678683 -120.459995980936 8 1.18259897924581 -120.459995980936 8 -1.18259897924573 -120.141060355593 8 -3.52619481678675 -119.50901499016 8 -5.80537888984619 -118.575405235742 8 -7.97851814201287 -117.357285014411 8 -10.005916600441 -115.876905301193 8 -11.8505404882692 -114.161307673309 8 -13.4786947076389 -112.241830351162 8 -14.860638336234 -110.153535754052 8 -15.9711278942818 -107.934570027256 8 -16.7898784583483 -105.625466239767 8 -17.3019341989225 -103.268403980929 8 -17.4979415733115 -100.90643888067 8 -17.3743201835246 -103 8 -6.48999977111816 -103.847114957633 8 -6.43447692339231 -104.679735543476 8 -6.26885839153318 -105.48361538846 8 -5.99597795453901 -106.244999885559 8 -5.62050467234353 -106.950861534932 8 -5.14886299690595 -107.589122848057 8 -4.5891228480568 -108.148862996906 8 -3.95086153493217 -108.620504672344 8 -3.24499988555909 -108.995977954539 8 -2.48361538846016 -109.268858391533 8 -1.67973554347639 -109.434476923392 8 -0.847114957633072 -109.489999771118 8 -1.27207490980568e-14 -109.434476923392 8 0.847114957633047 -109.268858391533 8 1.67973554347637 -108.995977954539 8 2.48361538846013 -108.620504672344 8 3.24499988555907 -108.148862996906 8 3.95086153493215 -107.589122848057 8 4.58912284805678 -106.950861534932 8 5.14886299690593 -106.244999885559 8 5.62050467234351 -105.48361538846 8 5.995977954539 -104.679735543476 8 6.26885839153317 -103.847114957633 8 6.43447692339231 -103 8 6.48999977111816 -102.152885042367 8 6.43447692339231 -101.320264456524 8 6.26885839153318 -100.51638461154 8 5.99597795453902 -99.7550001144409 8 5.62050467234354 -99.0491384650679 8 5.14886299690597 -98.4108771519432 8 4.58912284805682 -97.8511370030941 8 3.95086153493219 -97.3794953276565 8 3.24499988555911 -97.004022045461 8 2.48361538846018 -96.7311416084668 8 1.67973554347641 -96.5655230766077 8 0.847114957633096 -96.5100002288818 8 3.65726558049372e-14 -96.5655230766077 8 -0.847114957633023 -96.7311416084668 8 -1.67973554347634 -97.004022045461 8 -2.48361538846011 -97.3794953276565 8 -3.24499988555906 -97.851137003094 8 -3.95086153493214 -98.4108771519432 8 -4.58912284805678 -99.0491384650678 8 -5.14886299690594 -99.7550001144409 8 -5.62050467234352 -100.51638461154 8 -5.99597795453901 -101.320264456524 8 -6.26885839153318 -102.152885042367 8 -6.43447692339231 0 -537.534111045084 0 -569.465888954916 7.0827161274038 -536.566671821851 4.75001087211172 -537.076976694703 2.38410912816346 -537.400138897485 2.38410912816342 -569.599861102515 4.75001087211169 -569.923023305297 7.08271612740379 -570.433328178149 9.40643888067009 -536.125679816475 11.7684039809287 -536.002058426689 14.1254662397666 -536.198065801077 16.4345700272559 -536.710121541652 18.6535357540515 -537.528872105718 20.7418303511616 -538.639361663766 22.661307673309 -540.021305292361 24.376905301193 -541.649459511731 25.8572850144106 -543.494083399559 27.0754052357417 -545.521481857987 28.00901499016 -547.694621110154 28.6410603555925 -549.973805183213 28.9599959809356 -552.317401020754 28.9599959809356 -554.682598979246 28.6410603555925 -557.026194816787 28.00901499016 -559.305378889846 27.0754052357417 -561.478518142013 25.8572850144106 -563.505916600441 24.376905301193 -565.350540488269 22.661307673309 -566.978694707639 20.7418303511617 -568.360638336234 18.6535357540516 -569.471127894282 16.434570027256 -570.289878458348 14.1254662397667 -570.801934198923 11.7684039809289 -570.997941573311 9.40643888067023 -570.874320183525 11.5 -559.989999771118 12.3471149576331 -559.934476923392 13.1797355434764 -559.768858391533 13.9836153884601 -559.495977954539 14.7449998855591 -559.120504672343 15.4508615349322 -558.648862996906 16.0891228480568 -558.089122848057 16.6488629969059 -557.450861534932 17.1205046723435 -556.744999885559 17.495977954539 -555.98361538846 17.7688583915332 -555.179735543476 17.9344769233923 -554.347114957633 17.9899997711182 -553.5 17.9344769233923 -552.652885042367 17.7688583915332 -551.820264456524 17.495977954539 -551.01638461154 17.1205046723435 -550.255000114441 16.648862996906 -549.549138465068 16.0891228480568 -548.910877151943 15.4508615349322 -548.351137003094 14.7449998855591 -547.879495327657 13.9836153884602 -547.504022045461 13.1797355434764 -547.231141608467 12.3471149576331 -547.065523076608 11.5 -547.010000228882 10.652885042367 -547.065523076608 9.82026445652364 -547.231141608467 9.01638461153988 -547.504022045461 8.25500011444094 -547.879495327657 7.54913846506786 -548.351137003094 6.91087715194323 -548.910877151943 6.35113700309407 -549.549138465068 5.87949532765649 -550.255000114441 5.50402204546101 -551.01638461154 5.23114160846683 -551.820264456524 5.0655230766077 -552.652885042367 5.01000022888184 -553.5 5.06552307660769 -554.347114957633 5.23114160846681 -555.179735543476 5.50402204546098 -555.98361538846 5.87949532765646 -556.744999885559 6.35113700309404 -557.450861534932 6.91087715194319 -558.089122848057 7.54913846506783 -558.648862996906 8.25500011444091 -559.120504672343 9.01638461153985 -559.495977954539 9.82026445652362 -559.768858391533 10.6528850423669 -559.934476923392 2 6 77 78 6 7 80 7 8 6 78 77 2 77 76 73 72 2 75 74 2 76 75 2 73 2 74 2 72 71 82 81 8 82 34 35 35 33 36 33 35 34 37 36 32 78 7 79 80 8 81 7 80 79 36 33 32 82 8 34 71 70 1 68 67 1 69 68 1 70 69 1 5 1 65 4 5 64 65 1 66 64 5 65 1 67 66 71 1 2 62 4 63 62 61 3 62 3 4 3 60 9 60 3 61 9 60 59 59 58 10 11 10 58 59 10 9 58 57 11 63 4 64 37 31 38 31 37 32 40 39 29 38 30 39 41 40 28 27 42 41 25 44 43 24 45 44 43 42 26 38 31 30 29 28 40 27 26 42 27 41 28 25 43 26 24 23 45 44 25 24 23 22 46 46 45 23 46 22 47 29 39 30 15 54 53 18 51 50 17 52 51 16 53 52 12 57 56 57 12 11 13 56 55 54 14 55 56 13 12 50 49 19 48 47 21 20 19 49 20 48 21 47 22 21 19 18 50 15 14 54 13 55 14 17 16 52 16 15 53 17 51 18 20 49 48
+17 15 1 2.86909026062469
+-91.5 8 15.9658889549164 -91.5 8 -15.9658889549164 -90.0398685580385 8.2178575479086 15.9775736588581 -89.5010004063661 8.41702053012013 15.9998827158415 -89.081302808772 8.62393968310014 16.0239676304806 -90.0568788533945 8.21278771042945 -15.9770425502351 -89.5076079899165 8.41411140740702 -15.999545588391 -89.081302808772 8.62393968310013 -16.0239676304806 -87.3592862366634 10.1974137782906 16.1349186705299 -86.7196459954998 11.5343207746377 16.1761312530125 -86.5 13 16.1902832373999 -87.3592862366635 10.1974137782906 -16.13491867053 -86.7196459954998 11.5343207746377 -16.1761312530126 -86.5 13 -16.1902832373999 -86.5 13 8.09514161869993 -86.5 13 0 -86.5 13 -8.09514161869993 4.71238898038469 -537.534111045084 4.71238898038469 -569.465888954916 5.00873124517697 -537.522426341142 5.12368881336199 -537.500117284158 5.21731128088592 -537.476032369519 5.00517858361172 -569.477042550235 5.12224622673602 -569.499545588391 5.21731128088592 -569.523967630481 5.68817505564806 -537.365081329 5.98568018098933 -537.323868746898 6.28318530717959 -537.309716762601 5.68817505565486 -569.634918670241 5.98568018099204 -569.676131252826 6.28318530717959 -569.6902832374 6.28318530717959 -545.4048583813 6.28318530717959 -553.5 6.28318530717959 -561.5951416187 2 6 1 7 8 4 6 7 3 3 1 6 5 4 8 3 7 4 8 9 5 10 12 13 14 17 13 16 13 17 9 12 10 15 11 10 16 15 10 13 16 10 12 9 8
+7 5 1 3.38151117551121
+-86.5 13 16.1902832373999 -86.5 13 8.09514161869993 -86.5 13 0 -86.5 13 -8.09514161869993 -86.5 13 -16.1902832373999 -86.5 25 16.1902832373999 -86.5 25 -16.1902832373999 0 -537.3097167626 0 -545.4048583813 0 -553.5 0 -561.5951416187 0 -569.6902832374 12 -537.3097167626 12 -569.6902832374 4 5 7 3 4 7 3 6 2 6 3 7 6 1 2
+17 15 1 2.5946198187254
+-86.5 25 16.1902832373999 -86.5 25 -16.1902832373999 -87.0428487503121 27.2657896498585 16.155307015677 -87.903802908953 28.4738115208435 16.0998349831292 -89.081302808772 29.3760603168999 16.0239676304806 -87.0428487503121 27.2657896498585 -16.1553070156771 -87.903802908953 28.4738115208435 -16.0998349831293 -89.081302808772 29.3760603168999 -16.0239676304806 -91.5 30 15.9658889549164 -89.8055397317911 29.7041322267322 15.9860875622478 -90.4780917568618 29.8944308239311 15.9666152791692 -91.5 30 -15.9658889549164 -90.0568788533967 29.7872122895712 -15.977042550235 -89.5076079899183 29.5858885925938 -15.9995455883909 -91.5 30 7.9829444774582 -91.5 30 0 -91.5 30 -7.9829444774582 0 -537.3097167626 0 -569.6902832374 0.470304705451268 -537.344692984182 0.768089365449089 -537.400165016542 1.06587402629367 -537.476032369519 0.470304705452451 -569.655307014966 0.768089365449697 -569.599834982849 1.06587402629367 -569.523967630481 1.5707963267949 -537.534111045084 1.22505751892619 -537.513912437752 1.36496640238867 -537.533384720831 1.5707963267949 -569.465888954916 1.27800672356833 -569.477042550235 1.16093908044396 -569.499545588391 1.5707963267949 -545.517055522542 1.5707963267949 -553.5 1.5707963267949 -561.482944477458 3 2 6 4 6 7 5 7 8 1 2 3 3 6 4 7 5 4 8 14 5 10 14 13 13 12 11 17 11 12 10 13 11 16 15 11 15 9 11 17 16 11 14 10 5
+23 22 1 2.3968777540786
+-66 22 17.5111162408969 -66 22 10.4966016058463 -65.9990284558852 21.999319717382 10.4597081659336 -65.9997001171964 21.9997900197679 10.4760865761612 -65.9999250273312 21.999947503564 10.486338721684 -88.8503645756781 38 16.0388471836533 -69.8122088401342 24.6693377797162 10.2140216049676 -88.8503645756781 38 -16.0388471836533 -75.4264235041551 28.6004538162607 4.22643697721129 -74.9290817069124 28.2522112869335 6.61727275602827 -73.5222190416686 27.2671152912284 8.60921153367265 -71.7771653314839 26.0452153398957 9.74418331606857 -66 22 -17.5111162408969 -75.4264235041551 28.6004538162607 -4.22643697721128 -66 22 -10.4966016058463 -69.8122088401342 24.6693377797163 -10.2140216049676 -72.6101911568408 26.6285063924988 -9.30985607969134 -74.6742333683332 28.0737645315759 -7.13396509302974 -75.235166869311 28.466534458109 -5.72864357197918 -65.9990284558852 21.9993197173819 -10.4597081659336 -65.9997001171964 21.9997900197679 -10.4760865761612 -65.9999250273312 21.999947503564 -10.486338721684 -77.4246965157816 29.999659858691 0 0 -556.988883759103 0 -564.003398394154 -0.00118603642762971 -564.040291834066 -0.000366089324813856 -564.023913423839 -9.15247335595559e-05 -564.013661278316 27.8951458365323 -558.461152816347 4.65384791575937 -564.285978395032 27.8951458365323 -590.538847183653 11.507538861993 -570.273563022789 10.9003966031139 -567.882727243972 9.18293432416528 -565.890788466328 7.05261699041048 -564.755816683931 0 -592.011116240897 11.507538861993 -578.726436977211 0 -584.996601605846 4.65384791575948 -584.714021604968 8.06955380150468 -583.809856079692 10.5892842115667 -581.63396509303 11.2740576103695 -580.228643571979 -0.0011860364276195 -584.959708165934 -0.000366089324810082 -584.976086576161 -9.15247335584457e-05 -584.986338721684 13.9469799000523 -574.5 16 22 15 16 21 22 16 20 21 4 3 7 5 4 7 2 7 1 7 2 5 1 7 12 15 13 16 16 13 17 18 17 8 14 19 23 8 19 18 23 19 8 13 8 17 11 10 6 12 11 6 9 23 6 6 23 8 9 6 10 14 23 9 12 6 1
+17 15 1 0.964622695531969
+-98.5827161274038 30 -16.9333281781492 -98.5827161274038 38 -16.9333281781492 -98.5827161274038 32 -16.9333281781492 -98.5827161274038 34 -16.9333281781492 -98.5827161274038 36 -16.9333281781492 -91.5 30 -15.9658889549164 -93.8841091281634 30 -16.0998611025149 -96.2500108721117 30 -16.4230233052967 -89.081302808772 38 -16.0239676304806 -95.4539285023264 38 -16.2928237283859 -92.2747811376762 38 -15.9885541327281 -90.0568788533967 29.7872122895712 -15.977042550235 -89.5076079899183 29.5858885925938 -15.9995455883909 -89.081302808772 29.3760603168999 -16.0239676304806 -89.081302808772 31.5320452376749 -16.0239676304806 -89.081302808772 33.6880301584499 -16.0239676304806 -89.081302808772 35.844015079225 -16.0239676304806 6.02800878236089 -30 6.02800878236089 -38 6.02800878236089 -32 6.02800878236089 -34 6.02800878236089 -36 6.26685889817301 -30 6.1872421929023 -30 6.10762548763159 -30 6.34752724869869 -38 6.13451493780682 -38 6.24102109325275 -38 6.31496901275703 -29.7872122895712 6.33329365690206 -29.5858885925938 6.34752724869868 -29.3760603168999 6.34752724869869 -31.5320452376749 6.34752724869869 -33.6880301584499 6.34752724869869 -35.844015079225 8 5 2 10 8 2 5 8 4 1 3 8 8 3 4 10 7 8 10 11 7 12 11 9 13 9 17 13 17 16 6 11 12 13 15 14 13 12 9 15 13 16 11 6 7
+53 53 1 3.78837272102338
+-88.8503645756781 38 -16.0388471836533 -89.081302808772 38 -16.0239676304806 -88.8503645756781 38 16.0388471836533 -98.5827161274038 38 -16.9333281781492 -95.4539285023264 38 -16.2928237283859 -92.2747811376762 38 -15.9885541327281 -89.081302808772 38 16.0239676304806 -98.5827161274038 38 16.9333281781492 -100.90643888067 38 -17.3743201835246 -103.268403980929 38 -17.4979415733115 -105.625466239767 38 -17.3019341989226 -107.934570027256 38 -16.7898784583483 -110.153535754051 38 -15.9711278942818 -112.241830351162 38 -14.860638336234 -114.161307673309 38 -13.478694707639 -115.876905301193 38 -11.8505404882692 -117.357285014411 38 -10.0059166004411 -118.575405235742 38 -7.97851814201295 -119.50901499016 38 -5.80537888984627 -120.141060355593 38 -3.52619481678683 -120.459995980936 38 -1.18259897924581 -120.459995980936 38 1.18259897924573 -120.141060355593 38 3.52619481678675 -119.50901499016 38 5.80537888984619 -118.575405235742 38 7.97851814201287 -117.357285014411 38 10.005916600441 -115.876905301193 38 11.8505404882692 -114.161307673309 38 13.4786947076389 -112.241830351162 38 14.860638336234 -110.153535754052 38 15.9711278942818 -107.934570027256 38 16.7898784583483 -105.625466239767 38 17.3019341989225 -103.268403980929 38 17.4979415733115 -100.90643888067 38 17.3743201835246 -92.2747811376762 38 15.9885541327281 -95.4539285023264 38 16.2928237283859 -103 38 -6.48999977111816 -100.655541669127 38 -6.05174455540831 -98.6277154269305 38 -4.79616770361636 -97.1903904439923 38 -2.89284182696832 -96.5376854237507 38 -0.598821631798279 -96.7577517959528 38 1.77607274293133 -97.8208683776029 38 3.91109865216925 -99.5834553834167 38 5.51790901628594 -101.807465671427 38 6.37949519196383 -104.192534328573 38 6.37949519196384 -106.416544616583 38 5.51790901628594 -108.179131622397 38 3.91109865216926 -109.242248204047 38 1.77607274293134 -109.462314576249 38 -0.59882163179827 -108.809609556008 38 -2.89284182696831 -107.372284573069 38 -4.79616770361635 -105.344458330873 38 -6.05174455540831 -16.0388471836533 -88.8503645756781 -16.0239676304806 -89.081302808772 16.0388471836533 -88.8503645756781 -16.9333281781492 -98.5827161274038 -16.2928237283859 -95.4539285023264 -15.9885541327281 -92.2747811376762 16.0239676304806 -89.081302808772 16.9333281781492 -98.5827161274038 -17.3743201835246 -100.90643888067 -17.4979415733115 -103.268403980929 -17.3019341989226 -105.625466239767 -16.7898784583483 -107.934570027256 -15.9711278942818 -110.153535754051 -14.860638336234 -112.241830351162 -13.478694707639 -114.161307673309 -11.8505404882692 -115.876905301193 -10.0059166004411 -117.357285014411 -7.97851814201295 -118.575405235742 -5.80537888984627 -119.50901499016 -3.52619481678683 -120.141060355593 -1.18259897924581 -120.459995980936 1.18259897924573 -120.459995980936 3.52619481678675 -120.141060355593 5.80537888984619 -119.50901499016 7.97851814201287 -118.575405235742 10.005916600441 -117.357285014411 11.8505404882692 -115.876905301193 13.4786947076389 -114.161307673309 14.860638336234 -112.241830351162 15.9711278942818 -110.153535754052 16.7898784583483 -107.934570027256 17.3019341989225 -105.625466239767 17.4979415733115 -103.268403980929 17.3743201835246 -100.90643888067 15.9885541327281 -92.2747811376762 16.2928237283859 -95.4539285023264 -6.48999977111816 -103 -6.05174455540831 -100.655541669127 -4.79616770361636 -98.6277154269305 -2.89284182696832 -97.1903904439923 -0.598821631798277 -96.5376854237507 1.77607274293133 -96.7577517959528 3.91109865216925 -97.8208683776029 5.51790901628594 -99.5834553834167 6.37949519196383 -101.807465671427 6.37949519196384 -104.192534328573 5.51790901628594 -106.416544616583 3.91109865216926 -108.179131622397 1.77607274293134 -109.242248204047 -0.59882163179827 -109.462314576249 -2.89284182696831 -108.809609556008 -4.79616770361635 -107.372284573069 -6.05174455540831 -105.344458330873 14 53 13 15 52 14 12 53 11 12 13 53 52 15 16 50 51 19 20 50 19 17 18 51 51 52 17 18 19 51 17 52 16 14 52 53 9 38 4 5 4 38 1 2 40 37 9 10 38 9 37 39 5 38 6 39 40 6 5 39 41 1 40 40 2 6 10 11 37 11 53 37 1 41 3 50 20 21 49 22 23 49 23 24 49 50 22 25 48 49 49 24 25 22 50 21 26 27 48 27 28 48 28 29 47 29 30 47 47 48 28 25 26 48 46 30 31 33 45 46 8 44 45 7 42 43 44 35 43 36 35 44 7 43 35 47 30 46 33 34 45 45 34 8 7 3 42 36 44 8 46 32 33 31 32 46 42 3 41
+18 16 1 1.95959387991784
+-66.2510012728069 21 9.47835585411223 -65.9990284558852 21.999319717382 10.4597081659336 -66.1055246932253 21.4893138423102 9.61588645419513 -66.0137050773389 21.8534688083843 9.9734940462421 -65.9959888004816 21.9575146594368 10.207877480884 -31.3214877799826 21 11.72889508423 -57.5186228996008 21 10.0409906616417 -48.7862445263947 21 10.6036254691711 -40.0538661531887 21 11.1662602767006 -65.9997001171964 21.9997900197679 10.4760865761612 -65.9999250273312 21.999947503564 10.486338721684 -66 22 10.4966016058463 -31.3857853359791 22 12.7268258555227 -31.3536365579808 21.8660254037844 12.2278604698764 -31.3301020190849 21.5 11.862592456365 -57.3464463339948 22 11.0541576682654 -48.6928926679895 22 11.6117137306845 -40.0393390019843 22 12.1692697931036 1.5707963267949 -0.251521728788568 0.0368879319789844 0.0630282539686088 1.05949352822722 -0.0975032915748513 0.548190730544073 0.0171196218005552 0.29253933154878 0.0498695223858501 1.5707963267949 34.7504187841557 1.5707963267949 8.4989633994475 1.5707963267949 17.2494485276836 1.5707963267949 25.9999336559197 0.0204932954403005 0.0634110742308209 0.0102466481423906 0.0638458173661103 1.07127848258948e-14 0.0644308782193537 0 34.7504187841557 0.523598775598299 34.7504187841557 1.0471975511966 34.7504187841557 0 8.73592785470346 0 17.4074248311876 0 26.0789218076716 17 11 10 2 5 13 18 10 2 16 12 11 10 18 17 17 16 11 18 2 13 5 14 13 15 4 3 1 7 3 8 3 7 14 4 15 6 3 9 6 15 3 8 9 3 4 14 5
+-31.3857853359791 22 12.7268258555227 -31.3536365579808 21.8660254037844 12.2278604698764 -31.3301020190849 21.5 11.862592456365 -31.3214877799826 21 11.72889508423 -25 22 6.73924122776646 -30.5688544174803 22 12.7237306367866 -29.7599162878418 22 12.6096920100182 -28.973967439973 22 12.3868240793686 -28.2255781801711 22 12.0592584801499 -27.5286225166166 22 11.6330677845479 -26.8960209561862 22 11.1161529252922 -26.3395009777413 22 10.5180967242793 -25.8693796223569 22 9.84998624150725 -25.4943722309403 22 9.12420723770426 -25.2214308749545 22 8.35421456100471 -25.0556154754982 22 7.55428271435683 -26 21 6.73924122776646 -30.5049529752708 21 11.7146737158329 -29.7016246654752 21 11.5677214742516 -28.9329334434676 21 11.2919586416705 -28.2193858797522 21 10.8947418130484 -27.5800174634885 21 10.3866676423712 -27.0318847879236 21 9.78129015302851 -26.5896105273321 21 9.09475915369707 -26.2649933442295 21 8.34538940580268 -26.0666931334625 21 7.55317203598897 -25.5 21.8660254037844 6.73924122776646 -25.8660254037845 21.5 6.73924122776646 -26.2890411495714 21.5 8.77996704574284 -25.9531745450286 21.8660254037844 8.92546007020945 -28.1448795489539 21.5 11.0060881156457 -27.9413244677274 21.8660254037844 11.3102918715766 -26.1381192232725 21.5 8.38842601652563 -25.7914926786525 21.8660254037844 8.5060042236063 -27.012186069006 21.5 9.97266591474419 -26.7278758962628 21.8660254037844 10.2031920995699 -30.4916882302217 21.5 11.8479900275502 -30.4554482727979 21.8660254037844 12.2122169646395 -29.2664000509526 21.5 11.5716657094578 -29.1428034866419 21.8660254037844 11.9161921750684 -29.6668348032394 21.5 11.6971002125232 -29.5717871320227 21.8660254037844 12.0505694989002 -26.0554954849235 21.5 8.12111323883491 -25.7029783020416 21.8660254037844 8.21963344990152 -26.4714344975813 21.5 9.15787506629808 -26.1485715800654 21.8660254037844 9.33031094629013 -27.4883793076099 21.5 10.4844001385957 -27.2380192098374 21.8660254037844 10.7514102838317 -28.0296726977392 21.5 10.9267047645666 -27.8179039735653 21.8660254037844 11.2252489048161 -25.9345055743721 21.5 7.57498124626477 -25.5733624468087 21.8660254037844 7.63456511681122 -28.626031476302 21.5 11.2913801319606 -28.4567799984902 21.8660254037844 11.6159237091179 -26.9255594612687 21.5 9.86280160831451 -26.635073266716 21.8660254037844 10.0854950455547 -26.6099208863924 21.5 9.40098887374137 -26.2969313204938 21.8660254037844 9.59075749036218 -28.8775465620152 21.5 11.4139483371128 -28.7262267878143 21.8660254037844 11.7472303830609 -30.6310849220122 21.5 11.8599439939715 -30.6047832160236 21.8660254037844 12.2250231860349 -25.9136134768451 21.5 7.43664160893591 -25.55098085254 21.8660254037844 7.4863625904743 -29.9389069540998 21.5 11.7623654251688 -29.8632565971883 21.8660254037844 12.1204877781639 0 1.5707963267949 0 2.0943951023932 0 2.61799387799149 0 3.14159265358979 1.635138268314 1.5707963267949 0.1362615223595 1.5707963267949 0.272523044718999 1.5707963267949 0.408784567078499 1.5707963267949 0.545046089437999 1.5707963267949 0.681307611797499 1.5707963267949 0.817569134156998 1.5707963267949 0.953830656516498 1.5707963267949 1.090092178876 1.5707963267949 1.2263537012355 1.5707963267949 1.362615223595 1.5707963267949 1.4988767459545 1.5707963267949 1.635138268314 3.14159265358979 0.1635138268314 3.14159265358979 0.327027653662799 3.14159265358979 0.490541480494199 3.14159265358979 0.654055307325599 3.14159265358979 0.817569134156998 3.14159265358979 0.981082960988398 3.14159265358979 1.1445967878198 3.14159265358979 1.3081106146512 3.14159265358979 1.4716244414826 3.14159265358979 1.635138268314 2.0943951023932 1.635138268314 2.61799387799149 1.2263537012355 2.61799387799149 1.2263537012355 2.0943951023932 0.654055307325599 2.61799387799149 0.654055307325599 2.0943951023932 1.3081106146512 2.61799387799149 1.3081106146512 2.0943951023932 0.953830656516498 2.61799387799149 0.953830656516498 2.0943951023932 0.1635138268314 2.61799387799149 0.1635138268314 2.0943951023932 0.408784567078499 2.61799387799149 0.408784567078499 2.0943951023932 0.327027653662799 2.61799387799149 0.327027653662799 2.0943951023932 1.362615223595 2.61799387799149 1.362615223595 2.0943951023932 1.1445967878198 2.61799387799149 1.1445967878198 2.0943951023932 0.817569134156998 2.61799387799149 0.817569134156998 2.0943951023932 0.681307611797499 2.61799387799149 0.681307611797499 2.0943951023932 1.4716244414826 2.61799387799149 1.4716244414826 2.0943951023932 0.545046089437999 2.61799387799149 0.545046089437999 2.0943951023932 0.981082960988398 2.61799387799149 0.981082960988398 2.0943951023932 1.090092178876 2.61799387799149 1.090092178876 2.0943951023932 0.490541480494199 2.61799387799149 0.490541480494199 2.0943951023932 0.1362615223595 2.61799387799149 0.1362615223595 2.0943951023932 1.4988767459545 2.61799387799149 1.4988767459545 2.0943951023932 0.272523044718999 2.61799387799149 0.272523044718999 2.0943951023932 2 1 6 2 6 62 38 6 7 62 38 37 38 62 6 66 42 41 42 66 7 38 7 66 38 66 65 7 8 42 2 62 61 8 40 42 60 40 8 60 8 9 32 9 10 60 54 53 54 60 9 32 50 49 50 32 10 54 9 32 54 32 31 10 48 50 40 60 59 42 40 39 3 61 4 3 2 61 37 65 18 37 38 65 62 37 61 61 37 18 4 61 18 19 18 65 19 41 39 41 19 65 66 41 65 39 59 20 39 40 59 54 31 53 53 59 60 41 42 39 59 53 20 53 21 20 21 53 31 22 21 49 49 21 31 47 49 48 22 49 47 32 49 31 48 36 47 39 20 19 49 50 48 10 11 48 11 12 36 13 14 46 12 13 56 36 56 55 56 36 12 58 46 45 46 58 13 56 13 58 56 58 57 14 30 46 36 35 47 30 14 34 34 14 15 52 15 16 64 16 5 34 44 43 44 34 15 52 64 63 64 52 16 44 15 52 44 52 51 5 27 64 30 34 33 46 30 29 35 55 23 35 36 55 57 45 24 57 58 45 56 57 55 55 57 23 22 35 23 24 29 25 24 23 57 29 24 45 46 29 45 22 47 35 33 43 25 33 34 43 52 63 51 51 43 44 29 30 33 43 51 26 25 43 26 63 28 17 28 63 27 63 17 26 51 63 26 33 25 29 27 63 64 48 11 36
+14 12 1 1.0074900874178
+-25 22 6.73924122776646 -25.5 21.8660254037844 6.73924122776646 -25.8660254037845 21.5 6.73924122776646 -26 21 6.73924122776646 -25 22 -6.73924122776635 -25 22 3.36962061388321 -25 22 2.39808173319034e-14 -25 22 -3.36962061388316 -26 21 -6.73924122776635 -26 21 3.36962061388321 -26 21 2.39808173319034e-14 -26 21 -3.36962061388316 -25.5 21.8660254037844 -6.73924122776635 -25.8660254037844 21.5 -6.73924122776635 0 -8.88178419700125e-16 0.523598775598299 -8.88178419700125e-16 1.0471975511966 -8.88178419700125e-16 1.5707963267949 -8.88178419700125e-16 0 13.4784824555328 0 3.36962061388319 0 6.73924122776638 0 10.1088618416496 1.5707963267949 13.4784824555328 1.5707963267949 3.36962061388319 1.5707963267949 6.73924122776638 1.5707963267949 10.1088618416496 0.523598775598299 13.4784824555328 1.0471975511966 13.4784824555328 1 2 6 6 2 7 8 7 13 13 5 8 7 2 13 2 3 13 3 4 10 3 10 11 14 11 12 11 14 3 12 9 14 3 14 13
+66 102 1 0.626633573059639
+-25 22 -6.73924122776635 -25.5 21.8660254037844 -6.73924122776635 -25.8660254037844 21.5 -6.73924122776635 -26 21 -6.73924122776635 -31.3857853359791 22 -12.7268258555226 -25.0556154754982 22 -7.55428271435672 -25.2214308749545 22 -8.3542145610046 -25.4943722309403 22 -9.12420723770416 -25.8693796223569 22 -9.84998624150714 -26.3395009777413 22 -10.5180967242792 -26.8960209561862 22 -11.116152925292 -27.5286225166166 22 -11.6330677845477 -28.2255781801711 22 -12.0592584801498 -28.973967439973 22 -12.3868240793685 -29.7599162878418 22 -12.6096920100181 -30.5688544174803 22 -12.7237306367864 -31.3214877799826 21 -11.7288950842299 -26.0666931334625 21 -7.55317203598886 -26.2649933442295 21 -8.34538940580257 -26.5896105273321 21 -9.09475915369696 -27.0318847879236 21 -9.7812901530284 -27.5800174634885 21 -10.3866676423711 -28.2193858797522 21 -10.8947418130483 -28.9329334434676 21 -11.2919586416704 -29.7016246654752 21 -11.5677214742515 -30.5049529752708 21 -11.7146737158328 -31.3536365579809 21.8660254037844 -12.2278604698763 -31.3301020190849 21.5 -11.8625924563649 -30.6310849220122 21.5 -11.8599439939714 -30.6047832160236 21.8660254037844 -12.2250231860348 -28.0296726977392 21.5 -10.9267047645665 -27.8179039735653 21.8660254037844 -11.225248904816 -26.9255594612687 21.5 -9.8628016083144 -26.635073266716 21.8660254037844 -10.0854950455546 -26.2890411495714 21.5 -8.77996704574273 -25.9531745450286 21.8660254037844 -8.92546007020934 -29.6668348032394 21.5 -11.6971002125231 -29.5717871320228 21.8660254037844 -12.0505694989 -25.9345055743721 21.5 -7.57498124626466 -25.5733624468087 21.8660254037844 -7.63456511681111 -26.1381192232725 21.5 -8.38842601652552 -25.7914926786525 21.8660254037844 -8.50600422360619 -29.9389069540998 21.5 -11.7623654251687 -29.8632565971883 21.8660254037844 -12.1204877781638 -27.4883793076099 21.5 -10.4844001385956 -27.2380192098374 21.8660254037844 -10.7514102838316 -27.012186069006 21.5 -9.97266591474408 -26.7278758962628 21.8660254037844 -10.2031920995698 -28.8775465620152 21.5 -11.4139483371127 -28.7262267878143 21.8660254037844 -11.7472303830608 -30.4916882302217 21.5 -11.8479900275501 -30.4554482727979 21.8660254037844 -12.2122169646394 -26.6099208863924 21.5 -9.40098887374126 -26.2969313204938 21.8660254037844 -9.59075749036207 -28.1448795489539 21.5 -11.0060881156456 -27.9413244677274 21.8660254037844 -11.3102918715765 -28.626031476302 21.5 -11.2913801319605 -28.4567799984902 21.8660254037844 -11.6159237091178 -26.4714344975813 21.5 -9.15787506629797 -26.1485715800654 21.8660254037844 -9.33031094629002 -25.9136134768451 21.5 -7.4366416089358 -25.55098085254 21.8660254037844 -7.48636259047419 -26.0554954849235 21.5 -8.1211132388348 -25.7029783020416 21.8660254037844 -8.21963344990141 -29.2664000509526 21.5 -11.5716657094577 -29.1428034866419 21.8660254037844 -11.9161921750683 0 1.5707963267949 0 2.0943951023932 0 2.61799387799149 0 3.14159265358979 1.635138268314 1.5707963267949 0.1362615223595 1.5707963267949 0.272523044718999 1.5707963267949 0.408784567078499 1.5707963267949 0.545046089437999 1.5707963267949 0.681307611797498 1.5707963267949 0.817569134156998 1.5707963267949 0.953830656516498 1.5707963267949 1.090092178876 1.5707963267949 1.2263537012355 1.5707963267949 1.362615223595 1.5707963267949 1.4988767459545 1.5707963267949 1.635138268314 3.14159265358979 0.1635138268314 3.14159265358979 0.327027653662799 3.14159265358979 0.490541480494199 3.14159265358979 0.654055307325598 3.14159265358979 0.817569134156998 3.14159265358979 0.981082960988398 3.14159265358979 1.1445967878198 3.14159265358979 1.3081106146512 3.14159265358979 1.4716244414826 3.14159265358979 1.635138268314 2.0943951023932 1.635138268314 2.61799387799149 1.4988767459545 2.61799387799149 1.4988767459545 2.0943951023932 0.953830656516498 2.61799387799149 0.953830656516498 2.0943951023932 0.654055307325598 2.61799387799149 0.654055307325598 2.0943951023932 0.408784567078499 2.61799387799149 0.408784567078499 2.0943951023932 1.3081106146512 2.61799387799149 1.3081106146512 2.0943951023932 0.1635138268314 2.61799387799149 0.1635138268314 2.0943951023932 0.327027653662799 2.61799387799149 0.327027653662799 2.0943951023932 1.362615223595 2.61799387799149 1.362615223595 2.0943951023932 0.817569134156998 2.61799387799149 0.817569134156998 2.0943951023932 0.681307611797498 2.61799387799149 0.681307611797498 2.0943951023932 1.1445967878198 2.61799387799149 1.1445967878198 2.0943951023932 1.4716244414826 2.61799387799149 1.4716244414826 2.0943951023932 0.545046089437999 2.61799387799149 0.545046089437999 2.0943951023932 0.981082960988398 2.61799387799149 0.981082960988398 2.0943951023932 1.090092178876 2.61799387799149 1.090092178876 2.0943951023932 0.490541480494199 2.61799387799149 0.490541480494199 2.0943951023932 0.1362615223595 2.61799387799149 0.1362615223595 2.0943951023932 0.272523044718999 2.61799387799149 0.272523044718999 2.0943951023932 1.2263537012355 2.61799387799149 1.2263537012355 2.0943951023932 2 1 6 2 6 62 40 6 7 62 40 39 40 62 6 64 42 41 42 64 7 40 7 64 40 64 63 7 8 42 2 62 61 8 9 60 34 10 48 9 10 34 36 60 59 60 36 8 54 34 33 34 54 9 60 9 54 60 54 53 10 11 46 8 36 42 42 36 35 3 61 4 3 2 61 39 63 18 39 40 63 62 39 61 61 39 18 4 61 18 19 18 63 19 41 35 41 19 63 64 41 63 35 59 20 35 36 59 60 53 59 46 48 10 41 42 35 47 48 46 20 53 21 53 20 59 33 47 21 47 33 48 22 21 47 33 21 53 54 33 53 47 46 45 35 20 19 48 33 34 11 12 46 32 45 46 56 32 12 56 12 13 50 13 14 56 58 57 58 56 13 50 66 65 66 50 14 58 13 50 58 50 49 14 38 66 32 56 55 44 38 15 15 38 14 52 15 16 27 16 5 44 52 51 52 44 15 30 27 28 27 30 16 52 16 30 52 30 29 38 44 43 66 38 37 45 31 22 31 45 32 55 57 23 57 55 56 31 32 55 31 55 23 22 31 23 24 23 57 24 49 65 49 24 57 57 58 49 45 22 47 65 37 25 37 65 66 43 51 26 51 43 44 37 38 43 37 43 25 25 43 26 29 28 17 28 29 30 29 17 26 51 29 26 51 52 29 65 25 24 49 50 65 32 46 12
+18 16 1 2.05326385958412
+-66.2510012728069 21 -9.4783558541123 -65.9990284558852 21.9993197173819 -10.4597081659336 -66.1055246932253 21.4893138423102 -9.6158864541952 -66.0137050773389 21.8534688083843 -9.97349404624218 -65.9959888004816 21.9575146594369 -10.207877480884 -31.3214877799826 21 -11.7288950842299 -40.0538661531887 21 -11.1662602767005 -48.7862445263947 21 -10.6036254691711 -57.5186228996008 21 -10.0409906616416 -65.9997001171964 21.9997900197679 -10.4760865761612 -65.9999250273312 21.999947503564 -10.486338721684 -66 22 -10.4966016058463 -31.3857853359791 22 -12.7268258555226 -31.3536365579809 21.8660254037844 -12.2278604698763 -31.3301020190849 21.5 -11.8625924563649 -40.0393390019843 22 -12.1692697931035 -48.6928926679896 22 -11.6117137306844 -57.3464463339948 22 -11.0541576682654 1.5707963267949 35.0019405129443 0.0368879319788371 34.6873905301871 1.05949352822808 34.8479220757019 0.548190730544787 34.7332991623333 0.292539331548636 34.700549261759 1.5707963267949 -3.5527136788005e-15 1.5707963267949 8.75048512823607 1.5707963267949 17.5009702564721 1.5707963267949 26.2514553847082 0.0204932954401994 34.6870077098826 0.010246648142324 34.6865729667718 -2.65074420746636e-14 34.6859879059363 0 -3.5527136788005e-15 0.523598775598299 -3.5527136788005e-15 1.0471975511966 -3.5527136788005e-15 0 8.67149697648409 0 17.3429939529682 0 26.0144909294523 16 13 2 18 17 11 16 10 17 12 18 11 10 11 17 5 2 13 2 10 16 13 14 5 4 14 15 15 6 3 7 3 6 4 15 3 8 9 3 9 1 3 7 8 3 14 4 5
+17 15 1 0.963671960437347
+-89.081302808772 29.3760603168999 16.0239676304806 -89.081302808772 38 16.0239676304806 -89.081302808772 31.5320452376749 16.0239676304806 -89.081302808772 33.6880301584499 16.0239676304806 -89.081302808772 35.844015079225 16.0239676304806 -89.8055397317911 29.7041322267322 15.9860875622478 -90.4780917568618 29.8944308239311 15.9666152791692 -91.5 30 15.9658889549164 -98.5827161274038 38 16.9333281781492 -92.2747811376762 38 15.9885541327281 -95.4539285023264 38 16.2928237283859 -98.5827161274038 30 16.9333281781492 -96.2500108721117 30 16.4230233052967 -93.8841091281635 30 16.0998611025149 -98.5827161274038 32 16.9333281781492 -98.5827161274038 34 16.9333281781492 -98.5827161274038 36 16.9333281781492 3.07725071207069 -29.3760603168999 3.07725071207069 -38 3.07725071207069 -31.5320452376749 3.07725071207069 -33.6880301584499 3.07725071207069 -35.844015079225 3.10142552859272 -29.7041322267322 3.12385381129807 -29.8944308239311 3.15791906259637 -30 3.39676917840849 -38 3.18375686751663 -38 3.29026302296256 -38 3.39676917840849 -30 3.31715247313779 -30 3.23753576786708 -30 3.39676917840849 -32 3.39676917840849 -34 3.39676917840849 -36 5 2 6 3 4 6 5 6 4 6 1 3 10 8 7 6 2 7 7 2 10 14 10 11 11 9 13 17 13 9 14 11 13 16 15 13 15 12 13 17 16 13 10 14 8
+47 46 1 3.65857182541816
+-31.3214877799826 0 -11.7288950842299 -70.3214877799826 0 -9.21609083367482 -26 0 -6.73924122776635 -26.0551396185497 0 -7.47975173273139 -26.2193423231854 0 -8.20392965098609 -26.4889864841077 0 -8.89580262486057 -26.8581248708456 0 -9.5401108096091 -27.3186158234643 0 -10.1226434422175 -27.8603028237748 0 -10.6305522718238 -28.4712385059487 0 -11.052634938779 -29.1379481657968 0 -11.3795820521822 -29.845726956788 0 -11.6041825163858 -30.5789642179011 0 -11.7214825778208 -71.0666754944365 0 -9.11133241002949 -71.7877017691617 0 -8.89592542719547 -72.4682345209984 0 -8.57474910369801 -73.0928588921452 0 -8.15507845656241 -73.6474264146048 0 -7.64641951372273 -74.1193754894285 0 -7.06029399144038 -74.4980159215328 0 -6.40997831403934 -74.7747710650429 0 -5.71020288746419 -74.9433720942902 0 -4.97681843846456 -75 0 -4.22643697721124 -26 0 6.7392412277664 -31.3214877799826 0 11.72889508423 -30.5789642179011 0 11.7214825778209 -29.845726956788 0 11.6041825163858 -29.1379481657968 0 11.3795820521823 -28.4712385059487 0 11.0526349387791 -27.8603028237748 0 10.6305522718238 -27.3186158234643 0 10.1226434422175 -26.8581248708456 0 9.54011080960916 -26.4889864841077 0 8.89580262486062 -26.2193423231854 0 8.20392965098615 -26.0551396185497 0 7.47975173273145 -70.3214877799826 0 9.21609083367487 -75 0 4.22643697721129 -74.9433720942902 0 4.9768184384646 -74.7747710650429 0 5.71020288746424 -74.4980159215328 0 6.40997831403939 -74.1193754894285 0 7.06029399144043 -73.6474264146048 0 7.64641951372277 -73.0928588921452 0 8.15507845656246 -72.4682345209984 0 8.57474910369806 -71.7877017691617 0 8.89592542719551 -71.0666754944365 0 9.11133241002954 -50.5 0 2.57571741713036e-14 -11.7063781986649 28.9085102104852 -9.19357394810974 -10.0914897895148 -6.71672434220127 34.2299979904678 -7.45723484716631 34.1748583719181 -8.18141276542101 34.0106556672824 -8.87328573929549 33.7410115063601 -9.51759392404402 33.3718731196222 -10.1001265566524 32.9113821670035 -10.6080353862587 32.369695166693 -11.0301180532139 31.7587594845191 -11.3570651666171 31.092049824671 -11.5816656308207 30.3842710336798 -11.6989656922557 29.6510337725667 -9.08881552446441 -10.8366775039687 -8.87340854163039 -11.5577037786939 -8.55223221813293 -12.2382365305306 -8.13256157099733 -12.8628609016774 -7.62390262815765 -13.417428424137 -7.03777710587531 -13.8893774989607 -6.38746142847427 -14.268017931065 -5.68768600189911 -14.5447730745751 -4.95430155289948 -14.7133741038224 -4.20392009164616 -14.7700020095322 6.76175811333148 34.2299979904678 11.7514119697951 28.9085102104852 11.7439994633859 29.6510337725667 11.6266994019509 30.3842710336798 11.4020989377473 31.092049824671 11.0751518243442 31.7587594845191 10.6530691573889 32.369695166693 10.1451603277826 32.9113821670035 9.56262769517424 33.3718731196222 8.9183195104257 33.7410115063601 8.22644653655122 34.0106556672824 7.50226861829653 34.1748583719181 9.23860771923995 -10.0914897895148 4.24895386277637 -14.7700020095322 4.99933532402968 -14.7133741038224 5.73271977302931 -14.5447730745751 6.43249519960447 -14.268017931065 7.08281087700551 -13.8893774989607 7.66893639928785 -13.417428424137 8.17759534212754 -12.8628609016774 8.59726598926314 -12.2382365305306 8.91844231276059 -11.5577037786939 9.13384929559462 -10.8366775039687 0.0225168855651035 9.72999799046779 21 14 16 14 15 16 2 14 23 16 17 18 21 22 14 22 23 14 18 19 20 20 21 16 20 16 18 47 1 2 1 12 13 12 1 9 11 9 10 9 11 12 1 6 9 9 7 8 9 6 7 6 4 5 4 6 3 1 3 6 3 1 25 2 23 36 38 36 37 40 38 39 2 36 47 38 40 42 41 42 40 36 23 37 42 43 44 44 45 38 45 46 36 36 38 45 38 42 44 47 36 25 33 31 32 28 31 33 24 34 35 34 24 33 28 33 24 26 28 25 28 26 27 30 28 29 30 31 28 28 24 25 3 25 24 25 1 47
+54 54 1 3.71478536095373
+-91.5 30 15.9658889549164 -91.5 30 7.9829444774582 -91.5 30 0 -91.5 30 -7.9829444774582 -91.5 30 -15.9658889549164 -98.5827161274038 30 16.9333281781492 -96.2500108721117 30 16.4230233052967 -93.8841091281635 30 16.0998611025149 -93.8841091281634 30 -16.0998611025149 -96.2500108721117 30 -16.4230233052967 -98.5827161274038 30 -16.9333281781492 -100.90643888067 30 17.3743201835246 -103.268403980929 30 17.4979415733115 -105.625466239767 30 17.3019341989226 -107.934570027256 30 16.7898784583483 -110.153535754051 30 15.9711278942818 -112.241830351162 30 14.860638336234 -114.161307673309 30 13.478694707639 -115.876905301193 30 11.8505404882692 -117.357285014411 30 10.0059166004411 -118.575405235742 30 7.97851814201295 -119.50901499016 30 5.80537888984627 -120.141060355593 30 3.52619481678683 -120.459995980936 30 1.18259897924581 -120.459995980936 30 -1.18259897924573 -120.141060355593 30 -3.52619481678675 -119.50901499016 30 -5.80537888984619 -118.575405235742 30 -7.97851814201287 -117.357285014411 30 -10.005916600441 -115.876905301193 30 -11.8505404882692 -114.161307673309 30 -13.4786947076389 -112.241830351162 30 -14.860638336234 -110.153535754052 30 -15.9711278942818 -107.934570027256 30 -16.7898784583483 -105.625466239767 30 -17.3019341989225 -103.268403980929 30 -17.4979415733115 -100.90643888067 30 -17.3743201835246 -103 30 -6.48999977111816 -105.344458330873 30 -6.05174455540831 -107.372284573069 30 -4.79616770361636 -108.809609556008 30 -2.89284182696832 -109.462314576249 30 -0.598821631798284 -109.242248204047 30 1.77607274293132 -108.179131622397 30 3.91109865216925 -106.416544616583 30 5.51790901628593 -104.192534328573 30 6.37949519196383 -101.807465671427 30 6.37949519196384 -99.5834553834167 30 5.51790901628594 -97.8208683776029 30 3.91109865216926 -96.7577517959528 30 1.77607274293134 -96.5376854237507 30 -0.598821631798263 -97.1903904439923 30 -2.89284182696831 -98.6277154269305 30 -4.79616770361635 -100.655541669127 30 -6.05174455540831 0 -537.534111045084 0 -545.517055522542 0 -553.5 0 -561.482944477458 0 -569.465888954916 7.0827161274038 -536.566671821851 4.75001087211172 -537.076976694703 2.38410912816346 -537.400138897485 2.38410912816342 -569.599861102515 4.75001087211169 -569.923023305297 7.08271612740379 -570.433328178149 9.40643888067009 -536.125679816475 11.7684039809287 -536.002058426689 14.1254662397666 -536.198065801077 16.4345700272559 -536.710121541652 18.6535357540515 -537.528872105718 20.7418303511616 -538.639361663766 22.661307673309 -540.021305292361 24.376905301193 -541.649459511731 25.8572850144106 -543.494083399559 27.0754052357417 -545.521481857987 28.00901499016 -547.694621110154 28.6410603555925 -549.973805183213 28.9599959809356 -552.317401020754 28.9599959809356 -554.682598979246 28.6410603555925 -557.026194816787 28.00901499016 -559.305378889846 27.0754052357417 -561.478518142013 25.8572850144106 -563.505916600441 24.376905301193 -565.350540488269 22.661307673309 -566.978694707639 20.7418303511617 -568.360638336234 18.6535357540516 -569.471127894282 16.434570027256 -570.289878458348 14.1254662397667 -570.801934198923 11.7684039809289 -570.997941573311 9.40643888067023 -570.874320183525 11.5 -559.989999771118 13.844458330873 -559.551744555408 15.8722845730695 -558.296167703616 17.3096095560077 -556.392841826968 17.9623145762493 -554.098821631798 17.7422482040472 -551.723927257069 16.6791316223971 -549.588901347831 14.9165446165833 -547.982090983714 12.6925343285726 -547.120504808036 10.3074656714274 -547.120504808036 8.08345538341673 -547.982090983714 6.3208683776029 -549.588901347831 5.25775179595283 -551.723927257069 5.03768542375069 -554.098821631798 5.69039044399226 -556.392841826968 7.12771542693053 -558.296167703616 9.15554166912703 -559.551744555408 9 10 4 5 9 4 3 4 52 53 52 4 3 52 51 4 10 54 54 11 37 38 37 36 53 4 54 35 39 38 54 37 38 38 36 35 54 10 11 2 3 50 50 3 51 2 50 49 1 2 8 7 8 2 7 2 48 2 49 48 47 46 13 48 47 6 6 47 12 12 47 13 46 14 13 14 46 15 48 6 7 34 33 39 33 32 39 41 40 29 40 39 32 31 40 32 30 29 40 29 28 41 41 27 42 27 26 42 28 27 41 31 30 40 42 26 25 21 44 43 18 45 44 16 46 45 46 16 15 17 16 45 17 45 18 43 42 24 43 23 22 21 43 22 44 19 18 20 19 44 20 44 21 24 23 43 42 25 24 39 35 34
+16 14 1 0.454261152045491
+-69.8122088401342 24.6693377797162 10.2140216049676 -70.3214877799826 23.8501857770853 9.21609083367487 -69.8616292449605 24.5547371826532 9.73562040392352 -70.0310243842875 24.2804567015836 9.38395437956577 -70.1731588605408 24.0661588415051 9.26105485980392 -65.9990284558852 21.999319717382 10.4597081659336 -68.858913744072 24.0018332641327 10.2754432452091 -67.9056186480097 23.3343287485491 10.3368648854506 -66.9523235519475 22.6668242329655 10.3982865256921 -66.2510012728069 21 9.47835585411223 -69.3038661531886 23.137639332814 9.28165708878418 -68.2862445263947 22.4250928885426 9.34722334389353 -67.2686228996008 21.7125464442713 9.41278959900288 -66.1055246932253 21.4893138423102 9.61588645419513 -66.0137050773389 21.8534688083843 9.9734940462421 -65.9959888004816 21.9575146594368 10.207877480884 0 0.673446970666599 1.53390839481596 0.673446970666599 0.499603143812838 0.673446970666599 0.981289466474616 0.673446970666599 1.26729987520178 0.673446970666599 0 5.33495992058446 0 1.83882520814606 0 3.00420344562553 0 4.16958168310499 1.53390839481596 5.64950990334176 1.53390839481596 1.91746270383539 1.53390839481596 3.16147843700418 1.53390839481596 4.40549417017297 1.02260559624887 5.4954914661257 0.511302798565877 5.38086855275015 0.255651399569998 5.34811865216574 16 7 1 3 16 1 7 16 8 6 9 16 16 9 8 3 15 16 3 4 15 14 4 5 2 11 5 12 5 11 13 10 5 13 5 12 10 14 5 4 14 15
+33 31 1 0.537737982543245
+-75.4264235041551 28.6004538162607 4.22643697721129 -75 27.7813018136297 4.22643697721129 -75.1978767783311 28.3784603664944 4.22643697721129 -75.050757348812 28.0958465468006 4.22643697721129 -69.8122088401342 24.6693377797162 10.2140216049676 -75.3949060937558 28.5783850845028 4.84039243520989 -75.3006958142016 28.512418326385 5.44778922675438 -75.1448467573293 28.4032916250714 6.04217281839071 -74.9290817069124 28.2522112869335 6.61727275602828 -74.6557455647346 28.0608192301301 7.16706087843728 -74.3277655798592 27.8311651368386 7.68581613634279 -73.9486066885906 27.5656751819539 8.16818239317664 -73.5222190416686 27.2671152912284 8.60921153367266 -72.9252746357272 26.8491302536842 9.09859022914713 -72.2204916828047 26.3556358409621 9.53377686006524 -71.5397439197018 25.8789710519355 9.83926264889118 -70.8261798249281 25.3793280165447 10.0580036576873 -70.2947376449139 25.0072081384541 10.16075775789 -70.3214877799826 23.8501857770853 9.21609083367487 -74.96843288326 27.7548046217173 4.7874177850959 -74.874069818901 27.6755921203223 5.34153580687376 -74.7179738928815 27.5445451157118 5.88194256827686 -74.501959060867 27.3631711826858 6.40183617744289 -74.2286169488278 27.1336309798104 6.89454937061126 -73.9013218710374 26.858745474255 7.35368808581046 -73.4075820830876 26.4440064172365 7.88544713809272 -72.7416155149901 25.8845010349204 8.40777128214955 -71.9960533912546 25.2579931087525 8.81073459153663 -71.1910383667129 24.5813518016648 9.08250404726461 -70.7597387162134 24.2187088537628 9.16837955937179 -69.8616292449605 24.5547371826532 9.73562040392352 -70.0310243842875 24.2804567015836 9.38395437956577 -70.1731588605408 24.0661588415051 9.26105485980392 0 22.0856557446261 9.02332335925109 22.0856557446261 3.03360079557504 22.0856557446261 5.98972256367613 22.0856557446261 0 31.1089791038772 0 22.6947300713755 0 23.303804398125 0 23.9128787248744 0 24.5219530516239 0 25.1310273783733 0 25.7401017051228 0 26.3491760318722 0 26.9582503586217 0 27.7247917372435 0 28.5470420783553 0 29.2870673853559 0 30.0270926923565 0 30.5680358981168 9.02332335925109 31.1089791038772 9.02332335925109 22.7624049965699 9.02332335925109 23.4391542485137 9.02332335925109 24.1159035004576 9.02332335925109 24.7926527524014 9.02332335925109 25.4694020043452 9.02332335925109 26.1461512562891 9.02332335925109 27.0168309485399 9.02332335925109 28.0319548264556 9.02332335925109 29.0470787043714 9.02332335925109 30.0622025822871 9.02332335925109 30.5855908430821 3.0077744530837 31.1089791038772 5.71477146085903 31.1089791038772 7.36904741005506 31.1089791038772 20 7 6 22 9 8 8 7 21 24 11 10 26 13 12 12 11 25 10 9 23 27 15 14 29 17 16 16 15 28 31 18 32 31 5 18 29 18 17 26 14 13 6 1 3 4 20 6 2 20 4 20 21 7 22 8 21 24 10 23 23 9 22 24 25 11 14 26 27 30 33 32 27 28 15 12 25 26 29 16 28 30 32 18 30 19 33 30 18 29 6 3 4
+14 12 1 0.694049113123218
+-75.4264235041551 28.6004538162607 -4.22643697721128 -75 27.7813018136297 -4.22643697721124 -75.1393897373043 28.2905659648742 -4.22643697721126 -75.0344655490946 28.0415770988853 -4.22643697721125 -75.4264235041551 28.6004538162607 4.22643697721129 -75.4264235041551 28.6004538162607 -2.11321848860561 -75.4264235041551 28.6004538162607 2.48689957516035e-14 -75.4264235041551 28.6004538162607 2.11321848860566 -75 27.7813018136297 4.22643697721129 -75 27.7813018136297 -2.11321848860561 -75 27.7813018136297 2.48689957516035e-14 -75 27.7813018136297 2.11321848860566 -75.1978767783311 28.3784603664944 4.22643697721129 -75.050757348812 28.0958465468006 4.22643697721129 0 -1.77635683940025e-14 0.959931015968323 -1.77635683940025e-14 0.425636450062169 -1.77635683940025e-14 0.696532071895963 -1.77635683940025e-14 0 8.45287395442251 0 2.11321848860561 0 4.22643697721125 0 6.33965546581688 0.959931015968323 8.45287395442251 0.959931015968323 2.11321848860561 0.959931015968323 4.22643697721125 0.959931015968323 6.33965546581688 0.319977005322774 8.45287395442251 0.639954010645548 8.45287395442251 6 1 13 13 1 3 8 7 13 13 5 8 7 6 13 3 14 13 4 2 10 4 10 11 12 9 4 12 4 11 9 14 4 4 14 3
+30 28 1 0.557090853408744
+-69.8122088401342 24.6693377797163 -10.2140216049676 -70.3214877799826 23.8501857770853 -9.21609083367491 -69.8644393407588 24.5497823840678 -9.72538785586065 -70.050022044509 24.2512810490705 -9.36173902571804 -75.4264235041551 28.6004538162607 -4.22643697721128 -70.7326426426589 25.3138325662927 -10.0796457909723 -71.5895562889465 25.9138500537683 -9.82028285210744 -72.3199857406501 26.4253023410416 -9.48026392045895 -72.9977617842927 26.899886309379 -9.0457638548712 -73.6109758841674 27.3292635110206 -8.52462763891614 -74.0987694146994 27.6708202709866 -7.9891282665697 -74.4798066896117 27.9376254844617 -7.45985360525492 -74.8012244964402 28.1626846905074 -6.89210446595361 -75.059162653133 28.3432949601342 -6.29252710989362 -75.2504771266171 28.4772548173438 -5.66819773006634 -75.3727960762255 28.5629034811651 -5.02653751248231 -75.4130020612213 28.591056019292 -4.62739941159502 -75 27.7813018136297 -4.22643697721124 -71.2313926729787 24.6152751458974 -9.07242790294598 -72.0958738246505 25.3418825295502 -8.76596746117096 -72.8878983199599 26.0074082074161 -8.30810825408314 -73.5180409257265 26.5367969673408 -7.77937435468728 -74.0038855117472 26.94488959089 -7.22125270160224 -74.3661888832388 27.2491616638719 -6.66291179647857 -74.626066447607 27.4673793357531 -6.12366921722968 -74.8194963581413 27.6297779025165 -5.55776798235922 -74.9439039396243 27.7342145935049 -4.97332182859881 -74.9859601442055 27.769516999784 -4.60089638652717 -75.1393897373043 28.2905659648742 -4.22643697721126 -75.0344655490946 28.0415770988853 -4.22643697721125 -8.88178419700125e-16 4.60945843095357 9.02332335925291 4.60945843095357 3.07436173365025 4.60945843095357 5.94896162560212 4.60945843095357 0 13.6327817902065 0 5.59615884028787 0 6.48418920868875 0 7.28341654024953 0 8.08264387181032 0 8.88187120337111 0 9.60117580177582 0 10.2485499403401 0 10.8959240789043 0 11.5432982174685 0 12.1906723560328 0 12.838046494597 0 13.2354141424017 9.02332335925291 13.6327817902065 9.02332335925291 5.7057922191028 9.02332335925291 6.80212600725202 9.02332335925291 7.89845979540125 9.02332335925291 8.88516020473556 9.02332335925291 9.77319057313643 9.02332335925291 10.5724179046972 9.02332335925291 11.2917225031019 9.02332335925291 12.0110271015066 9.02332335925291 12.7303316999114 9.02332335925291 13.1815567450589 4.01036593744574 13.6327817902065 6.51684464834932 13.6327817902065 6 1 3 19 7 6 9 8 21 7 20 8 22 10 9 10 22 11 23 12 11 25 14 13 13 12 24 27 16 15 29 5 17 17 16 28 15 14 26 3 4 6 19 20 7 19 4 2 20 21 8 23 11 22 22 9 21 23 24 12 26 14 25 28 30 29 26 27 15 13 24 25 28 16 27 28 18 30 28 29 17 19 6 4
+15 13 1 0.474755111900713
+-66.2510012728069 21 -9.4783558541123 -66.1055246932253 21.4893138423102 -9.6158864541952 -66.0137050773389 21.8534688083843 -9.97349404624218 -65.9959888004816 21.9575146594369 -10.207877480884 -65.9990284558852 21.9993197173819 -10.4597081659336 -70.3214877799826 23.8501857770853 -9.21609083367491 -67.2686228996008 21.7125464442713 -9.41278959900296 -68.2862445263947 22.4250928885426 -9.34722334389361 -69.3038661531887 23.137639332814 -9.28165708878426 -69.8122088401342 24.6693377797163 -10.2140216049676 -66.9523235519474 22.6668242329655 -10.3982865256921 -67.9056186480097 23.3343287485491 -10.3368648854506 -68.858913744072 24.0018332641327 -10.2754432452091 -69.8644393407588 24.5497823840678 -9.72538785586065 -70.050022044509 24.2512810490705 -9.36173902571804 1.53390839481596 -0.366604501721732 1.02260559624944 -0.212586064507815 0.511302798566075 -0.0979631511324869 0.255651399569977 -0.0652132505472718 -2.77555756156289e-17 -0.052054518964555 1.53390839481596 4.60945843095345 1.53390839481596 0.877411231447065 1.53390839481596 2.12142696461586 1.53390839481596 3.36544269778465 0 4.60945843095345 0 1.11332371851499 0 2.27870195599448 0 3.44408019347396 0.511302798271986 4.60945843095345 1.02260559654397 4.60945843095345 5 4 11 11 4 12 12 4 13 10 13 4 14 10 4 4 3 14 15 3 2 1 7 2 8 2 7 15 8 9 8 15 2 9 6 15 3 15 14
+62 60 1 4.01913842194169
+-98.5827161274038 30 -16.9333281781492 -98.5827161274038 32 -16.9333281781492 -98.5827161274038 34 -16.9333281781492 -98.5827161274038 36 -16.9333281781492 -98.5827161274038 38 -16.9333281781492 -98.5827161274038 30 16.9333281781492 -100.90643888067 30 17.3743201835246 -103.268403980929 30 17.4979415733115 -105.625466239767 30 17.3019341989226 -107.934570027256 30 16.7898784583483 -110.153535754051 30 15.9711278942818 -112.241830351162 30 14.860638336234 -114.161307673309 30 13.478694707639 -115.876905301193 30 11.8505404882692 -117.357285014411 30 10.0059166004411 -118.575405235742 30 7.97851814201295 -119.50901499016 30 5.80537888984627 -120.141060355593 30 3.52619481678683 -120.459995980936 30 1.18259897924581 -120.459995980936 30 -1.18259897924573 -120.141060355593 30 -3.52619481678675 -119.50901499016 30 -5.80537888984619 -118.575405235742 30 -7.97851814201287 -117.357285014411 30 -10.005916600441 -115.876905301193 30 -11.8505404882692 -114.161307673309 30 -13.4786947076389 -112.241830351162 30 -14.860638336234 -110.153535754052 30 -15.9711278942818 -107.934570027256 30 -16.7898784583483 -105.625466239767 30 -17.3019341989225 -103.268403980929 30 -17.4979415733115 -100.90643888067 30 -17.3743201835246 -100.90643888067 38 -17.3743201835246 -103.268403980929 38 -17.4979415733115 -105.625466239767 38 -17.3019341989226 -107.934570027256 38 -16.7898784583483 -110.153535754051 38 -15.9711278942818 -112.241830351162 38 -14.860638336234 -114.161307673309 38 -13.478694707639 -115.876905301193 38 -11.8505404882692 -117.357285014411 38 -10.0059166004411 -118.575405235742 38 -7.97851814201295 -119.50901499016 38 -5.80537888984627 -120.141060355593 38 -3.52619481678683 -120.459995980936 38 -1.18259897924581 -120.459995980936 38 1.18259897924573 -120.141060355593 38 3.52619481678675 -119.50901499016 38 5.80537888984619 -118.575405235742 38 7.97851814201287 -117.357285014411 38 10.005916600441 -115.876905301193 38 11.8505404882692 -114.161307673309 38 13.4786947076389 -112.241830351162 38 14.860638336234 -110.153535754052 38 15.9711278942818 -107.934570027256 38 16.7898784583483 -105.625466239767 38 17.3019341989225 -103.268403980929 38 17.4979415733115 -100.90643888067 38 17.3743201835246 -98.5827161274038 38 16.9333281781492 -98.5827161274038 32 16.9333281781492 -98.5827161274038 34 16.9333281781492 -98.5827161274038 36 16.9333281781492 2.88641612877109 -30 2.88641612877109 -32 2.88641612877109 -34 2.88641612877109 -36 2.88641612877109 -38 6.53836183199828 -30 6.40310458373061 -30 6.26784733546294 -30 6.13259008719526 -30 5.99733283892759 -30 5.86207559065992 -30 5.72681834239224 -30 5.59156109412457 -30 5.45630384585689 -30 5.32104659758922 -30 5.18578934932155 -30 5.05053210105388 -30 4.9152748527862 -30 4.78001760451853 -30 4.64476035625086 -30 4.50950310798318 -30 4.37424585971551 -30 4.23898861144784 -30 4.10373136318016 -30 3.96847411491249 -30 3.83321686664482 -30 3.69795961837714 -30 3.56270237010947 -30 3.4274451218418 -30 3.29218787357412 -30 3.15693062530645 -30 3.02167337703878 -30 3.02167337703877 -38 3.15693062530644 -38 3.29218787357412 -38 3.42744512184179 -38 3.56270237010946 -38 3.69795961837714 -38 3.83321686664481 -38 3.96847411491248 -38 4.10373136318016 -38 4.23898861144783 -38 4.3742458597155 -38 4.50950310798318 -38 4.64476035625085 -38 4.78001760451852 -38 4.9152748527862 -38 5.05053210105387 -38 5.18578934932154 -38 5.32104659758922 -38 5.45630384585689 -38 5.59156109412456 -38 5.72681834239224 -38 5.86207559065991 -38 5.99733283892758 -38 6.13259008719526 -38 6.26784733546293 -38 6.4031045837306 -38 6.53836183199828 -38 6.53836183199828 -32 6.53836183199828 -34 6.53836183199828 -36 5 33 4 4 33 3 35 31 34 33 34 32 30 35 36 37 29 36 28 37 38 26 39 40 27 38 39 24 41 42 22 43 44 23 42 43 25 40 41 21 44 45 2 3 32 32 1 2 33 32 3 32 34 31 30 36 29 35 30 31 28 29 37 28 38 27 26 40 25 39 26 27 24 42 23 22 44 21 43 22 23 41 24 25 45 20 21 45 46 20 19 46 47 18 47 48 16 49 50 14 51 52 15 50 51 17 48 49 12 53 54 10 55 56 11 54 55 8 57 58 59 62 58 56 57 9 52 53 13 58 62 61 19 47 18 17 49 16 48 17 18 15 51 14 13 53 12 52 13 14 50 15 16 11 55 10 56 9 10 12 54 11 7 61 60 9 57 8 6 7 60 58 7 8 7 58 61 46 19 20
+104 102 1 1.40494504643154
+-103 38 -6.48999977111816 -103 38 -6.48999977111816 -102.152885042367 38 -6.43447692339231 -101.320264456524 38 -6.26885839153318 -100.51638461154 38 -5.99597795453901 -99.7550001144409 38 -5.62050467234352 -99.0491384650678 38 -5.14886299690595 -98.4108771519432 38 -4.5891228480568 -97.8511370030941 38 -3.95086153493216 -97.3794953276565 38 -3.24499988555908 -97.004022045461 38 -2.48361538846015 -96.7311416084668 38 -1.67973554347638 -96.5655230766077 38 -0.84711495763306 -96.5100002288818 38 1.04367156283313e-15 -96.5655230766077 38 0.847114957633062 -96.7311416084668 38 1.67973554347638 -97.004022045461 38 2.48361538846015 -97.3794953276565 38 3.24499988555908 -97.8511370030941 38 3.95086153493216 -98.4108771519432 38 4.5891228480568 -99.0491384650678 38 5.14886299690595 -99.7550001144409 38 5.62050467234352 -100.51638461154 38 5.99597795453901 -101.320264456524 38 6.26885839153318 -102.152885042367 38 6.43447692339231 -103 38 6.48999977111816 -103.847114957633 38 6.43447692339231 -104.679735543476 38 6.26885839153318 -105.48361538846 38 5.99597795453901 -106.244999885559 38 5.62050467234353 -106.950861534932 38 5.14886299690595 -107.589122848057 38 4.5891228480568 -108.148862996906 38 3.95086153493217 -108.620504672344 38 3.24499988555909 -108.995977954539 38 2.48361538846016 -109.268858391533 38 1.6797355434764 -109.434476923392 38 0.847114957633078 -109.489999771118 38 1.84850268386228e-14 -109.434476923392 38 -0.847114957633041 -109.268858391533 38 -1.67973554347636 -108.995977954539 38 -2.48361538846013 -108.620504672344 38 -3.24499988555906 -108.148862996906 38 -3.95086153493214 -107.589122848057 38 -4.58912284805678 -106.950861534932 38 -5.14886299690593 -106.244999885559 38 -5.62050467234351 -105.48361538846 38 -5.995977954539 -104.679735543476 38 -6.26885839153317 -103.847114957633 38 -6.43447692339231 -103 30 -6.48999977111816 -103 36 -6.48999977111816 -103 34 -6.48999977111816 -103 32 -6.48999977111816 -103 36 -6.48999977111816 -103 34 -6.48999977111816 -103 32 -6.48999977111816 -103 30 -6.48999977111816 -103.847114957633 30 -6.43447692339231 -104.679735543476 30 -6.26885839153318 -105.48361538846 30 -5.99597795453901 -106.244999885559 30 -5.62050467234353 -106.950861534932 30 -5.14886299690595 -107.589122848057 30 -4.5891228480568 -108.148862996906 30 -3.95086153493217 -108.620504672344 30 -3.24499988555909 -108.995977954539 30 -2.48361538846016 -109.268858391533 30 -1.67973554347639 -109.434476923392 30 -0.847114957633072 -109.489999771118 30 -1.27207490980568e-14 -109.434476923392 30 0.847114957633047 -109.268858391533 30 1.67973554347637 -108.995977954539 30 2.48361538846013 -108.620504672344 30 3.24499988555907 -108.148862996906 30 3.95086153493215 -107.589122848057 30 4.58912284805678 -106.950861534932 30 5.14886299690593 -106.244999885559 30 5.62050467234351 -105.48361538846 30 5.995977954539 -104.679735543476 30 6.26885839153317 -103.847114957633 30 6.43447692339231 -103 30 6.48999977111816 -102.152885042367 30 6.43447692339231 -101.320264456524 30 6.26885839153318 -100.51638461154 30 5.99597795453902 -99.7550001144409 30 5.62050467234354 -99.0491384650679 30 5.14886299690597 -98.4108771519432 30 4.58912284805682 -97.8511370030941 30 3.95086153493219 -97.3794953276565 30 3.24499988555911 -97.004022045461 30 2.48361538846018 -96.7311416084668 30 1.67973554347641 -96.5655230766077 30 0.847114957633096 -96.5100002288818 30 3.65726558049372e-14 -96.5655230766077 30 -0.847114957633023 -96.7311416084668 30 -1.67973554347634 -97.004022045461 30 -2.48361538846011 -97.3794953276565 30 -3.24499988555906 -97.851137003094 30 -3.95086153493214 -98.4108771519432 30 -4.58912284805678 -99.0491384650678 30 -5.14886299690594 -99.7550001144409 30 -5.62050467234352 -100.51638461154 30 -5.99597795453901 -101.320264456524 30 -6.26885839153318 -102.152885042367 30 -6.43447692339231 0 0 6.28318530717959 0 0.130899693899575 0 0.261799387799149 0 0.392699081698724 0 0.523598775598299 0 0.654498469497873 0 0.785398163397448 0 0.916297857297023 0 1.0471975511966 0 1.17809724509617 0 1.30899693899575 0 1.43989663289532 0 1.5707963267949 0 1.70169602069447 0 1.83259571459405 0 1.96349540849362 0 2.0943951023932 0 2.22529479629277 0 2.35619449019234 0 2.48709418409192 0 2.61799387799149 0 2.74889357189107 0 2.87979326579064 0 3.01069295969022 0 3.14159265358979 0 3.27249234748937 0 3.40339204138894 0 3.53429173528852 0 3.66519142918809 0 3.79609112308767 0 3.92699081698724 0 4.05789051088681 0 4.18879020478639 0 4.31968989868596 0 4.45058959258554 0 4.58148928648511 0 4.71238898038469 0 4.84328867428426 0 4.97418836818384 0 5.10508806208341 0 5.23598775598298 0 5.36688744988256 0 5.49778714378213 0 5.62868683768171 0 5.75958653158128 0 5.89048622548086 0 6.02138591938043 0 6.15228561328001 0 0 -8 0 -2 0 -4 0 -6 6.28318530717959 -2 6.28318530717959 -4 6.28318530717959 -6 6.28318530717959 -8 6.15228561328001 -8 6.02138591938044 -8 5.89048622548086 -8 5.75958653158129 -8 5.62868683768171 -8 5.49778714378214 -8 5.36688744988256 -8 5.23598775598299 -8 5.10508806208342 -8 4.97418836818384 -8 4.84328867428427 -8 4.71238898038469 -8 4.58148928648512 -8 4.45058959258554 -8 4.31968989868597 -8 4.18879020478639 -8 4.05789051088682 -8 3.92699081698724 -8 3.79609112308767 -8 3.66519142918809 -8 3.53429173528852 -8 3.40339204138895 -8 3.27249234748937 -8 3.1415926535898 -8 3.01069295969022 -8 2.87979326579065 -8 2.74889357189107 -8 2.6179938779915 -8 2.48709418409192 -8 2.35619449019235 -8 2.22529479629277 -8 2.0943951023932 -8 1.96349540849363 -8 1.83259571459405 -8 1.70169602069448 -8 1.5707963267949 -8 1.43989663289533 -8 1.30899693899575 -8 1.17809724509618 -8 1.0471975511966 -8 0.916297857297026 -8 0.785398163397451 -8 0.654498469497875 -8 0.5235987755983 -8 0.392699081698725 -8 0.261799387799149 -8 0.130899693899574 -8 50 104 53 52 104 3 5 103 102 6 102 101 3 104 103 104 52 53 100 7 101 99 8 100 9 99 98 11 97 96 10 98 97 95 12 96 13 95 94 14 94 93 16 92 91 17 91 90 15 93 92 19 89 88 20 88 87 22 86 85 24 84 83 23 85 84 21 87 86 18 90 89 25 83 82 51 3 1 51 52 3 3 103 4 4 103 5 6 5 102 6 101 7 7 100 8 9 98 10 11 96 12 97 11 10 99 9 8 13 12 95 13 94 14 14 93 15 16 91 17 17 90 18 92 16 15 19 88 20 20 87 21 22 85 23 24 83 25 84 24 23 86 22 21 89 19 18 82 26 25 82 81 26 27 81 80 28 80 79 30 78 77 31 77 76 29 79 78 33 75 74 34 74 73 36 72 71 38 70 69 37 71 70 35 73 72 32 76 75 40 68 67 41 67 66 43 65 64 44 64 63 42 66 65 46 62 61 47 61 60 49 59 58 57 56 58 60 59 48 63 62 45 69 68 39 56 55 58 27 80 28 28 79 29 30 77 31 31 76 32 78 30 29 33 74 34 34 73 35 36 71 37 38 69 39 70 38 37 72 36 35 75 33 32 40 67 41 41 66 42 43 64 44 43 42 65 49 55 54 39 68 40 44 63 45 45 62 46 47 60 48 2 49 54 59 49 48 61 47 46 58 55 49 81 27 26
+12 11 1 3.14633560706816
+-31.3214877799826 21 11.72889508423 -31.3214877799826 15 11.72889508423 -66.2510012728069 21 9.47835585411223 -57.5186228996008 21 10.0409906616417 -48.7862445263947 21 10.6036254691711 -40.0538661531887 21 11.1662602767006 -70.3214877799826 15 9.21609083367487 -70.3214877799826 23.8501857770853 9.21609083367487 -69.3038661531886 23.137639332814 9.28165708878418 -68.2862445263947 22.4250928885426 9.34722334389353 -67.2686228996008 21.7125464442713 9.41278959900288 -50.8214877799826 19.4250928885426 10.4724929589524 -1.77635683940025e-14 -17 -7.105427357601e-15 -23 35.0019405129443 -17 26.2514553847082 -17 17.5009702564722 -17 8.75048512823607 -17 39.0808672524243 -23 39.0808672524243 -14.1498142229147 38.0611355675543 -14.862360667186 37.0414038826843 -15.5749071114574 36.0216721978143 -16.2874535557287 19.5404336262121 -18.5749071114574 6 1 2 12 2 7 6 2 12 5 6 12 4 5 12 12 7 4 3 7 11 7 3 4 11 7 10 9 10 7 8 9 7
+29 27 1 0.614368888152546
+-31.3214877799826 21 11.72889508423 -31.3214877799826 15 11.72889508423 -31.3214877799826 19.5 11.72889508423 -31.3214877799826 18 11.72889508423 -31.3214877799826 16.5 11.72889508423 -30.5049529752708 21 11.7146737158329 -29.7016246654752 21 11.5677214742516 -28.9329334434676 21 11.2919586416705 -28.2193858797522 21 10.8947418130484 -27.5800174634885 21 10.3866676423712 -27.0318847879236 21 9.78129015302851 -26.5896105273321 21 9.09475915369707 -26.2649933442295 21 8.34538940580268 -26.0666931334625 21 7.55317203598897 -26 21 6.73924122776646 -26 15 6.7392412277664 -30.5789642179011 15 11.7214825778209 -29.845726956788 15 11.6041825163858 -29.1379481657968 15 11.3795820521823 -28.4712385059488 15 11.0526349387791 -27.8603028237748 15 10.6305522718238 -27.3186158234644 15 10.1226434422175 -26.8581248708456 15 9.54011080960915 -26.4889864841077 15 8.89580262486062 -26.2193423231854 15 8.20392965098615 -26.0551396185498 15 7.47975173273145 -26 19.5 6.7392412277664 -26 18 6.7392412277664 -26 16.5 6.7392412277664 6.21884336566049 -17 6.21884336566049 -23 6.21884336566049 -18.5 6.21884336566049 -20 6.21884336566049 -21.5 6.38235719249189 -17 6.54587101932329 -17 6.70938484615469 -17 6.87289867298608 -17 7.03641249981748 -17 7.19992632664888 -17 7.36344015348028 -17 7.52695398031168 -17 7.69046780714308 -17 7.85398163397448 -17 7.85398163397448 -23 6.36749229914358 -23 6.51614123262667 -23 6.66479016610976 -23 6.81343909959285 -23 6.96208803307594 -23 7.11073696655903 -23 7.25938590004212 -23 7.40803483352521 -23 7.5566837670083 -23 7.70533270049139 -23 7.85398163397448 -18.5 7.85398163397448 -20 7.85398163397448 -21.5 2 17 5 4 5 17 6 17 18 8 19 20 7 18 19 9 20 21 4 17 3 3 17 1 17 6 1 7 19 8 18 7 6 20 9 8 21 10 9 11 22 23 12 23 24 14 25 26 16 29 26 24 25 13 28 26 29 10 22 11 12 24 13 23 12 11 15 26 27 14 26 15 14 13 25 28 27 26 22 10 21
+10 8 1 1.39822276492417
+-26 21 6.73924122776646 -26 19.5 6.7392412277664 -26 18 6.7392412277664 -26 16.5 6.7392412277664 -26 15 6.7392412277664 -26 21 3.36962061388321 -26 21 2.39808173319034e-14 -26 21 -3.36962061388316 -26 21 -6.73924122776635 -26 15 -6.73924122776635 -6.12843109593086e-14 -17 0 -18.5 0 -20 0 -21.5 0 -23 3.36962061388319 -17 6.73924122776638 -17 10.1088618416496 -17 13.4784824555328 -17 13.4784824555328 -23 4 5 7 2 3 6 1 2 6 4 6 3 4 7 6 7 5 10 8 7 10 9 8 10
+29 27 1 0.614368888152547
+-26 21 -6.73924122776635 -26 15 -6.73924122776635 -26 19.5 -6.73924122776635 -26 18 -6.73924122776635 -26 16.5 -6.73924122776635 -26.0666931334625 21 -7.55317203598886 -26.2649933442295 21 -8.34538940580257 -26.5896105273321 21 -9.09475915369696 -27.0318847879236 21 -9.7812901530284 -27.5800174634885 21 -10.3866676423711 -28.2193858797522 21 -10.8947418130483 -28.9329334434676 21 -11.2919586416704 -29.7016246654752 21 -11.5677214742515 -30.5049529752708 21 -11.7146737158328 -31.3214877799826 21 -11.7288950842299 -31.3214877799826 15 -11.7288950842299 -26.0551396185498 15 -7.47975173273139 -26.2193423231854 15 -8.20392965098609 -26.4889864841077 15 -8.89580262486057 -26.8581248708456 15 -9.5401108096091 -27.3186158234643 15 -10.1226434422175 -27.8603028237748 15 -10.6305522718238 -28.4712385059488 15 -11.052634938779 -29.1379481657968 15 -11.3795820521822 -29.845726956788 15 -11.6041825163858 -30.5789642179011 15 -11.7214825778208 -31.3214877799826 19.5 -11.7288950842299 -31.3214877799826 18 -11.7288950842299 -31.3214877799826 16.5 -11.7288950842299 1.5707963267949 -17 1.5707963267949 -23 1.5707963267949 -18.5 1.5707963267949 -20 1.5707963267949 -21.5 1.7343101536263 -17 1.8978239804577 -17 2.0613378072891 -17 2.22485163412049 -17 2.38836546095189 -17 2.55187928778329 -17 2.71539311461469 -17 2.87890694144609 -17 3.04242076827749 -17 3.20593459510889 -17 3.20593459510889 -23 1.71944526027799 -23 1.86809419376108 -23 2.01674312724417 -23 2.16539206072726 -23 2.31404099421035 -23 2.46268992769344 -23 2.61133886117653 -23 2.75998779465962 -23 2.90863672814271 -23 3.0572856616258 -23 3.20593459510889 -18.5 3.20593459510889 -20 3.20593459510889 -21.5 2 17 5 4 5 17 6 17 18 8 19 20 7 18 19 9 20 21 4 17 3 3 17 1 17 6 1 7 19 8 18 7 6 20 9 8 21 10 9 11 22 23 12 23 24 14 25 26 16 29 26 24 25 13 28 26 29 10 22 11 12 24 13 23 12 11 15 26 27 14 26 15 14 13 25 28 27 26 22 10 21
+15 14 1 3.24863446698925
+-31.3214877799826 21 -11.7288950842299 -31.3214877799826 19.5 -11.7288950842299 -31.3214877799826 18 -11.7288950842299 -31.3214877799826 16.5 -11.7288950842299 -31.3214877799826 15 -11.7288950842299 -40.0538661531887 21 -11.1662602767005 -48.7862445263947 21 -10.6036254691711 -57.5186228996008 21 -10.0409906616416 -66.2510012728069 21 -9.4783558541123 -70.3214877799826 15 -9.21609083367482 -67.2686228996008 21.7125464442713 -9.41278959900296 -68.2862445263947 22.4250928885426 -9.34722334389361 -69.3038661531887 23.137639332814 -9.28165708878426 -70.3214877799826 23.8501857770853 -9.21609083367491 -50.8214877799826 19.4250928885426 -10.4724929589524 1.4210854715202e-14 -17 0 -18.5 0 -20 0 -21.5 0 -23 8.75048512823608 -17 17.5009702564722 -17 26.2514553847082 -17 35.0019405129443 -17 39.0808672524243 -23 36.0216721978143 -16.2874535557287 37.0414038826843 -15.5749071114574 38.0611355675543 -14.862360667186 39.0808672524243 -14.1498142229147 19.5404336262121 -18.5749071114574 4 5 6 3 4 6 1 2 6 6 2 3 6 15 7 6 5 15 15 8 7 8 15 10 9 10 11 10 9 8 15 5 10 12 11 10 14 13 10 12 10 13
+24 22 1 1.28165692222989
+-75 27.7813018136297 4.22643697721129 -75 15 4.22643697721129 -75 24.5859763602223 4.22643697721129 -75 21.3906509068148 4.22643697721129 -75 18.1953254534074 4.22643697721129 -74.96843288326 27.7548046217173 4.7874177850959 -74.874069818901 27.6755921203223 5.34153580687376 -74.7179738928815 27.5445451157118 5.88194256827686 -74.501959060867 27.3631711826858 6.40183617744289 -74.2286169488278 27.1336309798104 6.89454937061126 -73.9013218710374 26.858745474255 7.35368808581046 -73.4075820830876 26.4440064172365 7.88544713809272 -72.7416155149901 25.8845010349204 8.40777128214955 -71.9960533912546 25.2579931087525 8.81073459153663 -71.1910383667129 24.5813518016648 9.08250404726461 -70.7597387162134 24.2187088537628 9.16837955937179 -70.3214877799826 23.8501857770853 9.21609083367487 -70.3214877799826 15 9.21609083367487 -74.6495769739313 15 6.06530455359848 -73.6474264146048 15 7.64641951372277 -72.1340189746507 15 8.74815822202844 -70.3214877799826 21.637639332814 9.21609083367487 -70.3214877799826 19.4250928885426 9.21609083367487 -70.3214877799826 17.2125464442713 9.21609083367487 4.71238898038469 -10.2186981863703 4.71238898038469 -23 4.71238898038469 -13.4140236397777 4.71238898038469 -16.6093490931852 4.71238898038469 -19.8046745465926 4.82482060552532 -10.2451953782827 4.93730005506341 -10.3244078796777 5.04986025370574 -10.4554548842882 5.16251604804499 -10.6368288173142 5.27526609637396 -10.8663690201896 5.38809692118616 -11.141254525745 5.5333525332322 -11.5559935827635 5.70282757751223 -12.1154989650796 5.87252945128711 -12.7420068912475 6.04266555027868 -13.4186481983352 6.13064670420867 -13.7812911462372 6.2188433656605 -14.1498142229148 6.21884336566049 -23 5.08900257670364 -23 5.46561617302259 -23 5.84222976934154 -23 6.21884336566049 -16.362360667186 6.21884336566049 -18.5749071114574 6.21884336566049 -20.7874535557287 6 5 2 6 4 5 7 2 19 4 6 3 20 10 19 11 10 20 3 6 1 2 7 6 8 7 19 19 9 8 19 10 9 13 20 21 15 21 18 16 18 24 16 24 23 22 16 23 20 13 12 21 14 13 15 14 21 18 16 15 22 17 16 20 12 11
+10 8 1 1.34221304247446
+-75 27.7813018136297 4.22643697721129 -75 24.5859763602223 4.22643697721129 -75 21.3906509068148 4.22643697721129 -75 18.1953254534074 4.22643697721129 -75 15 4.22643697721129 -75 27.7813018136297 -4.22643697721124 -75 27.7813018136297 -2.11321848860561 -75 27.7813018136297 2.48689957516035e-14 -75 27.7813018136297 2.11321848860566 -75 15 -4.22643697721124 0 -10.2186981863703 8.88178419700125e-16 -13.4140236397777 8.88178419700125e-16 -16.6093490931852 8.88178419700125e-16 -19.8046745465926 8.88178419700125e-16 -23 8.45287395442253 -10.2186981863703 6.3396554658169 -10.2186981863703 4.22643697721126 -10.2186981863703 2.11321848860563 -10.2186981863703 8.45287395442253 -23 4 5 10 2 3 8 1 2 9 4 10 3 2 8 9 3 10 7 8 3 7 6 7 10
+20 18 1 1.34783401871294
+-70.3214877799826 23.8501857770853 -9.21609083367491 -70.3214877799826 15 -9.21609083367482 -70.3214877799826 21.637639332814 -9.21609083367482 -70.3214877799826 19.4250928885426 -9.21609083367482 -70.3214877799826 17.2125464442713 -9.21609083367482 -71.2313926729787 24.6152751458974 -9.07242790294598 -72.0958738246505 25.3418825295502 -8.76596746117096 -72.8878983199599 26.0074082074161 -8.30810825408314 -73.5180409257265 26.5367969673408 -7.77937435468728 -74.0038855117472 26.94488959089 -7.22125270160224 -74.3661888832388 27.2491616638719 -6.66291179647857 -74.626066447607 27.4673793357531 -6.12366921722968 -74.8194963581413 27.6297779025165 -5.55776798235922 -74.9439039396243 27.7342145935049 -4.97332182859881 -74.9859601442055 27.769516999784 -4.60089638652717 -75 27.7813018136297 -4.22643697721124 -75 15 -4.22643697721124 -72.1340189746507 15 -8.74815822202839 -73.6474264146048 15 -7.64641951372273 -74.6495769739313 15 -6.06530455359844 3.20593459510889 -14.1498142229147 3.20593459510889 -23 3.20593459510889 -16.362360667186 3.20593459510889 -18.5749071114574 3.20593459510889 -20.7874535557287 3.39043104698523 -13.3847248541026 3.57412894899877 -12.6581174704498 3.75735332525416 -11.9925917925839 3.92205520178068 -11.4632030326592 4.07018411594252 -11.05511040911 4.20340021237615 -10.7508383361281 4.32319026802079 -10.5326206642469 4.44287111514516 -10.3702220974835 4.56245197207124 -10.2657854064951 4.63742789776695 -10.230483000216 4.71238898038469 -10.2186981863703 4.71238898038469 -23 3.58254819142784 -23 3.95916178774679 -23 4.33577538406574 -23 6 5 2 3 4 6 5 6 4 2 18 6 1 3 6 18 8 7 7 6 18 9 8 19 8 18 19 19 10 9 10 19 11 12 11 20 20 11 19 14 20 17 12 20 13 17 15 14 14 13 20 15 17 16
+35 34 1 3.84219911994763
+-31.3214877799826 38 11.72889508423 -70.3214877799826 38 9.21609083367487 -30.5789642179011 38 11.7214825778209 -29.845726956788 38 11.6041825163858 -29.1379481657968 38 11.3795820521823 -28.4712385059488 38 11.0526349387791 -27.8603028237748 38 10.6305522718238 -27.3186158234644 38 10.1226434422175 -26.8581248708456 38 9.54011080960915 -26.4889864841077 38 8.89580262486062 -26.2193423231854 38 8.20392965098615 -26.0551396185498 38 7.47975173273145 -26 38 6.7392412277664 -75 38 4.22643697721129 -74.6495769739313 38 6.06530455359848 -73.6474264146048 38 7.64641951372277 -72.1340189746507 38 8.74815822202844 -75 38 -4.22643697721124 -70.3214877799826 38 -9.21609083367482 -72.1340189746507 38 -8.74815822202839 -73.6474264146048 38 -7.64641951372273 -74.6495769739313 38 -6.06530455359844 -31.3214877799826 38 -11.7288950842299 -26 38 -6.73924122776635 -26.0551396185498 38 -7.47975173273139 -26.2193423231854 38 -8.20392965098609 -26.4889864841077 38 -8.89580262486057 -26.8581248708456 38 -9.5401108096091 -27.3186158234643 38 -10.1226434422175 -27.8603028237748 38 -10.6305522718238 -28.4712385059488 38 -11.052634938779 -29.1379481657968 38 -11.3795820521822 -29.845726956788 38 -11.6041825163858 -30.5789642179011 38 -11.7214825778208 -50.5 38 2.30926389122033e-14 11.72889508423 73.3336924983243 9.21609083367487 34.3336924983243 11.7214825778209 74.0762160604057 11.6041825163858 74.8094533215189 11.3795820521823 75.51723211251 11.0526349387791 76.1839417723581 10.6305522718238 76.7948774545321 10.1226434422175 77.3365644548425 9.54011080960916 77.7970554074613 8.89580262486063 78.1661937941991 8.20392965098615 78.4358379551214 7.47975173273145 78.6000406597571 6.7392412277664 78.6551802783068 4.22643697721129 29.6551802783069 6.06530455359849 30.0056033043756 7.64641951372278 31.0077538637021 8.74815822202844 32.5211613036562 -4.22643697721124 29.6551802783069 -9.21609083367482 34.3336924983243 -8.74815822202839 32.5211613036562 -7.64641951372273 31.0077538637021 -6.06530455359844 30.0056033043756 -11.7288950842299 73.3336924983243 -6.73924122776635 78.6551802783068 -7.47975173273139 78.6000406597571 -8.20392965098609 78.4358379551214 -8.89580262486056 78.1661937941991 -9.5401108096091 77.7970554074613 -10.1226434422175 77.3365644548425 -10.6305522718238 76.7948774545321 -11.052634938779 76.1839417723581 -11.3795820521822 75.5172321125101 -11.6041825163858 74.8094533215189 -11.7214825778208 74.0762160604057 2.66453525910038e-14 54.1551802783069 23 25 34 30 33 34 1 24 23 18 19 22 21 22 19 20 21 19 23 19 35 31 32 30 28 29 30 32 33 30 27 28 25 27 25 26 28 30 25 25 30 34 23 24 25 19 18 14 17 14 15 16 17 15 2 35 19 2 19 14 2 1 35 3 5 1 13 24 1 14 17 2 4 5 3 10 11 12 10 12 8 12 13 1 6 8 12 8 9 10 8 6 7 1 6 12 5 6 1 1 23 35
+TShapes 392
+Ve
+1e-07
+0 -4.44089209850063e-16 -18.7573336454959
+0 0
+0101100
+Ve
+3.80674218288283e-07
+-4.58471522642452e-15 0 18.7185204322445
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  1 0 -18.7573336454959 18.7185204322445
+6  1 2 0
+0
+0101000
++392 0 -391 0 *
+Ve
+1e-07
+-88.8884101407824 0 -13.0301753166025
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  2 0 -0 89.0727219741272
+2  1 2 0 -0 89.0727219741272
+2  2 1 0 -0 89.0727219741272
+4 G1 2 0 1 0
+6  2 3 0
+0
+0101000
++389 0 -392 0 *
+Ve
+1e-07
+-1.20355511566415 0 18.6797875324082
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  3 0 -2.44929359829471e-16 0.0643419415190989
+2  3 3 0 -2.44929359829471e-16 0.0643419415190989
+2  4 1 0 -2.44929359829471e-16 0.0643419415190989
+4 G1 3 0 1 0
+6  3 1 0
+6  4 4 0
+0
+0101100
++391 0 -387 0 *
+Ve
+1e-07
+-99.3399647912774 0 -14.0304719190379
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  4 0 0 0.319518466337797
+2  5 4 0 0 0.319518466337797
+2  6 1 0 0 0.319518466337797
+4 G1 4 0 1 0
+6  5 5 0
+0
+0101100
++385 0 -389 0 *
+Ve
+1e-07
+-88.8884101407824 -4.44089209850063e-16 13.0301753166025
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  5 0 2.22044604925031e-16 87.8666712637106
+2  7 5 0 2.22044604925031e-16 87.8666712637106
+2  8 1 0 2.22044604925031e-16 87.8666712637106
+4 G1 5 0 1 0
+6  6 6 0
+0
+0101000
++387 0 -383 0 *
+Ve
+1e-07
+-99.3399647912774 0 14.0304719190379
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  6 0 8.88178419700125e-16 3.65194570322719
+2  9 6 0 8.88178419700125e-16 3.65194570322719
+2  10 1 0 8.88178419700125e-16 3.65194570322719
+4 G1 6 0 1 0
+6  7 7 0
+0
+0101100
++381 0 -385 0 *
+Ed
+ 1e-07 1 1 0
+1  7 0 0 0.319518466337797
+2  11 7 0 0 0.319518466337797
+2  12 1 0 0 0.319518466337797
+4 G1 7 0 1 0
+6  8 8 0
+0
+0101100
++383 0 -381 0 *
+Wi
+0101100
+-390 0 -388 0 -386 0 -384 0 -382 0 -380 0 -379 0 *
+Ve
+1e-07
+-31.3857853359791 -2.22044604925031e-16 -12.7268258555226
+0 0
+0101100
+Ve
+1e-07
+-70.3857853359791 -2.22044604925031e-16 -10.2140216049675
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  8 0 0 39.0808672524243
+2  13 8 0 0 39.0808672524243
+2  14 1 0 0 39.0808672524243
+4 G1 8 0 1 0
+6  9 9 0
+0
+0101000
++377 0 -376 0 *
+Ve
+1e-07
+-25 -2.22044604925031e-16 -6.73924122776635
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  9 0 0 1.635138268314
+2  15 9 0 0 1.635138268314
+2  16 1 0 0 1.635138268314
+4 G1 9 0 1 0
+6  10 10 0
+0
+0101100
++374 0 -377 0 *
+Ve
+1e-07
+-76 0 -4.22643697721124
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  10 0 -4.44089209850063e-16 1.5064543852758
+2  17 10 0 -4.44089209850063e-16 1.5064543852758
+2  18 1 0 -4.44089209850063e-16 1.5064543852758
+4 G1 10 0 1 0
+6  11 11 0
+0
+0101100
++376 0 -372 0 *
+Ve
+1e-07
+-25 0 6.7392412277664
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  11 0 0 13.4784824555328
+2  19 11 0 0 13.4784824555328
+2  20 1 0 0 13.4784824555328
+4 G1 11 0 1 0
+6  12 12 0
+0
+0101000
++370 0 -374 0 *
+Ve
+1e-07
+-76 -2.22044604925031e-16 4.22643697721129
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  12 0 -0 8.45287395442253
+2  21 12 0 -0 8.45287395442253
+2  22 1 0 -0 8.45287395442253
+4 G1 12 0 1 0
+6  13 13 0
+0
+0101000
++372 0 -368 0 *
+Ve
+1e-07
+-31.3857853359791 -2.22044604925031e-16 12.7268258555227
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  13 0 0 1.635138268314
+2  23 13 0 0 1.635138268314
+2  24 1 0 0 1.635138268314
+4 G1 13 0 1 0
+6  14 14 0
+0
+0101100
++366 0 -370 0 *
+Ve
+1e-07
+-70.3857853359791 0 10.2140216049676
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  14 0 0 1.5064543852758
+2  25 14 0 0 1.5064543852758
+2  26 1 0 0 1.5064543852758
+4 G1 14 0 1 0
+6  15 15 0
+0
+0101100
++368 0 -364 0 *
+Ed
+ 1e-07 1 1 0
+1  15 0 7.105427357601e-15 39.0808672524243
+2  27 15 0 7.105427357601e-15 39.0808672524243
+2  28 1 0 7.105427357601e-15 39.0808672524243
+4 G1 15 0 1 0
+6  16 16 0
+0
+0101000
++364 0 -366 0 *
+Wi
+0101100
+-375 0 -373 0 -371 0 -369 0 -367 0 -365 0 -363 0 -362 0 *
+Ve
+7.060000002e-05
+-103 0 -6.48999977111816
+0 0
+0101100
+Ed
+ 6.48999977111752e-08 1 1 0
+1  16 0 3.14159265358979 9.42477796076938
+2  29 1 0 3.14159265358979 9.42477796076938
+2  30 16 0 3.14159265358979 9.42477796076938
+6  17 17 0
+0
+0101100
++360 0 -360 0 *
+Wi
+0101100
+-359 0 *
+Fa
+0  1e-07 1 0
+2  1
+0101000
++378 0 +361 0 +358 0 *
+Ve
+1e-07
+0 3 -21.7635542033747
+0 0
+0101100
+Ve
+0.0001
+2.27015712151488e-16 22 -21.7635542033747
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  17 0 3 22
+6  18 2 0
+6  19 18 0
+0
+0101000
++356 0 -355 0 *
+Ed
+ 1e-07 1 1 0
+1  18 0 4.71238898038469 6.28318530717959
+2  31 2 0 4.71238898038469 6.28318530717959
+2  32 17 0 4.71238898038469 6.28318530717959
+6  20 2 0
+6  21 3 0
+0
+0101000
++392 0 -356 0 *
+Ve
+0.0001
+-5.31950330591293e-15 22 21.7185204322445
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  19 0 -298.131777101687 -254.649702466068
+2  33 17 0 -298.131777101687 -254.649702466068
+2  34 18 0 -298.131777101687 -254.649702466068
+6  22 2 0
+6  23 19 0
+0
+0101000
++355 0 -352 0 *
+Ve
+-5.31950330591293e-15 3 21.7185204322445
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  20 0 3 22
+2  35 19 0 3 22
+6  24 20 0
+0
+0101000
++350 0 -352 0 *
+Ed
+ 3.80674218288283e-07 1 1 0
+1  21 0 0 1
+2  36 3 0 0 1
+2  37 17 0 0 1
+6  25 4 0
+0
+0101000
++391 0 -350 0 *
+Wi
+0101100
++354 0 +353 0 +351 0 -390 0 -349 0 -348 0 *
+Fa
+0  1e-07 17 0
+2  2
+0101000
++347 0 *
+Ve
+1e-07
+-89.081302808772 3 -16.0239676304806
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  22 0 1.5707963267949 3.14159265358979
+2  38 4 0 1.5707963267949 3.14159265358979
+2  39 2 0 1.5707963267949 3.14159265358979
+4 G1 4 0 2 0
+6  26 3 0
+6  27 5 0
+0
+0101100
++389 0 -345 0 *
+Ed
+ 1e-07 1 1 0
+1  23 0 -0 89.2660146087853
+2  40 2 0 -0 89.2660146087853
+2  41 20 0 -0 89.2660146087853
+4 G1 2 0 20 0
+6  28 3 0
+6  29 18 0
+0
+0101000
++345 0 -356 0 *
+Wi
+0101100
++344 0 -388 0 +343 0 -353 0 *
+Fa
+0  0 2 0
+2  3
+0101000
++342 0 *
+Ve
+1e-07
+-1.3964477836537 3 21.6735798462864
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  24 0 -2.44929359829471e-16 0.0643419415190989
+2  42 3 0 -2.44929359829471e-16 0.0643419415190989
+2  43 19 0 -2.44929359829471e-16 0.0643419415190989
+4 G1 3 0 19 0
+6  30 4 0
+6  31 20 0
+0
+0101100
++350 0 -340 0 *
+Ed
+ 1e-07 1 1 0
+1  25 0 4.71238898038469 6.28318530717959
+2  44 3 0 4.71238898038469 6.28318530717959
+2  45 5 0 4.71238898038469 6.28318530717959
+4 G1 3 0 5 0
+6  32 4 0
+6  33 6 0
+0
+0101100
++387 0 -340 0 *
+Wi
+0101100
+-348 0 +386 0 -339 0 +338 0 *
+Fa
+0  0 3 0
+2  4
+0101000
++337 0 *
+Ve
+1e-07
+-98.5827161274038 3 -16.9333281781492
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  26 0 4.71238898038469 6.28318530717959
+2  46 6 0 4.71238898038469 6.28318530717959
+2  47 4 0 4.71238898038469 6.28318530717959
+4 G1 6 0 4 0
+6  34 5 0
+6  35 7 0
+0
+0101100
++385 0 -335 0 *
+Ed
+ 1e-07 1 1 0
+1  27 0 0 0.319518466337797
+2  48 4 0 0 0.319518466337797
+2  49 21 0 0 0.319518466337797
+4 G1 4 0 21 0
+6  36 5 0
+6  37 21 0
+0
+0101100
++335 0 -345 0 *
+Wi
+0101100
+-334 0 +384 0 -333 0 +344 0 *
+Fa
+0  0 4 0
+2  5
+0101000
++332 0 *
+Ve
+1e-07
+-89.081302808772 3 16.0239676304806
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  28 0 2.22044604925031e-16 87.8666712637106
+2  50 5 0 2.22044604925031e-16 87.8666712637106
+2  51 22 0 2.22044604925031e-16 87.8666712637106
+4 G1 5 0 22 0
+6  38 6 0
+6  39 22 0
+0
+0101000
++340 0 -330 0 *
+Ed
+ 1e-07 1 1 0
+1  29 0 0 1.5707963267949
+2  52 5 0 0 1.5707963267949
+2  53 7 0 0 1.5707963267949
+4 G1 5 0 7 0
+6  40 6 0
+6  41 8 0
+0
+0101100
++383 0 -330 0 *
+Wi
+0101100
++338 0 -382 0 +329 0 -328 0 *
+Fa
+0  0 5 0
+2  6
+0101000
++327 0 *
+Ve
+1e-07
+-98.5827161274038 3 16.9333281781492
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  30 0 1.5707963267949 3.14159265358979
+2  54 7 0 1.5707963267949 3.14159265358979
+2  55 6 0 1.5707963267949 3.14159265358979
+4 G1 7 0 6 0
+6  42 8 0
+0
+0101100
++381 0 -325 0 *
+Ed
+ 1e-07 1 1 0
+1  31 0 8.88178419700125e-16 3.65194570322719
+2  56 6 0 8.88178419700125e-16 3.65194570322719
+2  57 23 0 8.88178419700125e-16 3.65194570322719
+4 G1 6 0 23 0
+6  43 7 0
+6  44 23 0
+0
+0101100
++325 0 -335 0 *
+Wi
+0101100
+-324 0 +380 0 -323 0 +334 0 *
+Fa
+0  0 6 0
+2  7
+0101000
++322 0 *
+Ed
+ 1e-07 1 1 0
+1  32 0 0 0.319518466337797
+2  58 7 0 0 0.319518466337797
+2  59 24 0 0 0.319518466337797
+4 G1 7 0 24 0
+6  45 8 0
+6  46 24 0
+0
+0101100
++330 0 -325 0 *
+Wi
+0101100
+-328 0 +379 0 -320 0 +324 0 *
+Fa
+0  0 7 0
+2  8
+0101000
++319 0 *
+Ve
+1e-07
+-31.3214877799826 1 -11.7288950842299
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  33 0 0 1.5707963267949
+2  60 8 0 0 1.5707963267949
+2  61 9 0 0 1.5707963267949
+4 G1 8 0 9 0
+6  47 9 0
+6  48 10 0
+0
+0101100
++377 0 -317 0 *
+Ve
+1e-07
+-70.3214877799826 1 -9.21609083367482
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  34 0 0 39.0808672524243
+2  62 8 0 0 39.0808672524243
+2  63 25 0 0 39.0808672524243
+4 G1 8 0 25 0
+6  49 9 0
+6  50 25 0
+0
+0101000
++317 0 -315 0 *
+Ed
+ 1e-07 1 1 0
+1  35 0 0 1.5707963267949
+2  64 8 0 0 1.5707963267949
+2  65 10 0 0 1.5707963267949
+4 G1 8 0 10 0
+6  51 9 0
+6  52 11 0
+0
+0101100
++376 0 -315 0 *
+Wi
+0101100
++316 0 -375 0 +314 0 -313 0 *
+Fa
+0  0 8 0
+2  9
+0101000
++312 0 *
+Ve
+1e-07
+-26 1 -6.73924122776635
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  36 0 0 1.5707963267949
+2  66 11 0 0 1.5707963267949
+2  67 9 0 0 1.5707963267949
+4 G1 11 0 9 0
+6  53 10 0
+6  54 12 0
+0
+0101100
++374 0 -310 0 *
+Ed
+ 1e-07 1 1 0
+1  37 0 0 1.635138268314
+2  68 9 0 0 1.635138268314
+2  69 26 0 0 1.635138268314
+4 G1 9 0 26 0
+6  55 10 0
+6  56 26 0
+0
+0101100
++310 0 -317 0 *
+Wi
+0101100
+-309 0 +373 0 -308 0 +316 0 *
+Fa
+0  0 9 0
+2  10
+0101000
++307 0 *
+Ve
+1e-07
+-75 1 -4.22643697721124
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  38 0 -4.44089209850063e-16 1.5064543852758
+2  70 10 0 -4.44089209850063e-16 1.5064543852758
+2  71 27 0 -4.44089209850063e-16 1.5064543852758
+4 G1 10 0 27 0
+6  57 11 0
+6  58 27 0
+0
+0101100
++315 0 -305 0 *
+Ed
+ 1e-07 1 1 0
+1  39 0 1.5707963267949 3.14159265358979
+2  72 10 0 1.5707963267949 3.14159265358979
+2  73 12 0 1.5707963267949 3.14159265358979
+4 G1 10 0 12 0
+6  59 11 0
+6  60 13 0
+0
+0101100
++372 0 -305 0 *
+Wi
+0101100
+-313 0 +371 0 -304 0 +303 0 *
+Fa
+0  0 10 0
+2  11
+0101000
++302 0 *
+Ve
+1e-07
+-26 1 6.7392412277664
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  40 0 1.5707963267949 3.14159265358979
+2  74 13 0 1.5707963267949 3.14159265358979
+2  75 11 0 1.5707963267949 3.14159265358979
+4 G1 13 0 11 0
+6  61 12 0
+6  62 14 0
+0
+0101100
++370 0 -300 0 *
+Ed
+ 1e-07 1 1 0
+1  41 0 0 13.4784824555328
+2  76 11 0 0 13.4784824555328
+2  77 28 0 0 13.4784824555328
+4 G1 11 0 28 0
+6  63 12 0
+6  64 28 0
+0
+0101000
++300 0 -310 0 *
+Wi
+0101100
++299 0 -369 0 +298 0 -309 0 *
+Fa
+0  0 11 0
+2  12
+0101000
++297 0 *
+Ve
+1e-07
+-75 1 4.22643697721129
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  42 0 -0 8.45287395442253
+2  78 12 0 -0 8.45287395442253
+2  79 29 0 -0 8.45287395442253
+4 G1 12 0 29 0
+6  65 13 0
+6  66 29 0
+0
+0101000
++305 0 -295 0 *
+Ed
+ 1e-07 1 1 0
+1  43 0 0 1.5707963267949
+2  80 12 0 0 1.5707963267949
+2  81 14 0 0 1.5707963267949
+4 G1 12 0 14 0
+6  67 13 0
+6  68 15 0
+0
+0101100
++368 0 -295 0 *
+Wi
+0101100
++303 0 -367 0 +294 0 -293 0 *
+Fa
+0  0 12 0
+2  13
+0101000
++292 0 *
+Ve
+1e-07
+-31.3214877799826 1 11.72889508423
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  44 0 0 1.5707963267949
+2  82 15 0 0 1.5707963267949
+2  83 13 0 0 1.5707963267949
+4 G1 15 0 13 0
+6  69 14 0
+6  70 16 0
+0
+0101100
++366 0 -290 0 *
+Ed
+ 1e-07 1 1 0
+1  45 0 0 1.635138268314
+2  84 13 0 0 1.635138268314
+2  85 30 0 0 1.635138268314
+4 G1 13 0 30 0
+6  71 14 0
+6  72 30 0
+0
+0101100
++290 0 -300 0 *
+Wi
+0101100
+-289 0 +365 0 -288 0 +299 0 *
+Fa
+0  0 13 0
+2  14
+0101000
++287 0 *
+Ve
+1e-07
+-70.3214877799826 1 9.21609083367487
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  46 0 0 1.5064543852758
+2  86 14 0 0 1.5064543852758
+2  87 31 0 0 1.5064543852758
+4 G1 14 0 31 0
+6  73 15 0
+6  74 31 0
+0
+0101100
++295 0 -285 0 *
+Ed
+ 1e-07 1 1 0
+1  47 0 1.5707963267949 3.14159265358979
+2  88 14 0 1.5707963267949 3.14159265358979
+2  89 15 0 1.5707963267949 3.14159265358979
+4 G1 14 0 15 0
+6  75 15 0
+6  76 16 0
+0
+0101100
++364 0 -285 0 *
+Wi
+0101100
+-293 0 +363 0 -284 0 +283 0 *
+Fa
+0  0 14 0
+2  15
+0101000
++282 0 *
+Ed
+ 1e-07 1 1 0
+1  48 0 7.105427357601e-15 39.0808672524243
+2  90 15 0 7.105427357601e-15 39.0808672524243
+2  91 32 0 7.105427357601e-15 39.0808672524243
+4 G1 15 0 32 0
+6  77 16 0
+6  78 32 0
+0
+0101000
++285 0 -290 0 *
+Wi
+0101100
++283 0 -362 0 +280 0 -289 0 *
+Fa
+0  0 15 0
+2  16
+0101000
++279 0 *
+Ve
+0.0001
+-103 8 -6.48999977111816
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  49 0 30 38
+3  92 93CN 16 0 30 38
+7  79 80 17 0
+0
+0101000
++277 0 -360 0 *
+Ed
+1  50 0 3.14159265358979 9.42477796076938
+2  94 33 0 3.14159265358979 9.42477796076938
+2  95 16 0 3.14159265358979 9.42477796076938
+6  81 17 0
+6  82 33 0
+0
+0101100
++277 0 -277 0 *
+Wi
+0101100
++276 0 +275 0 -359 0 -276 0 *
+Fa
+0  1e-07 16 0
+2  17
+0101000
++274 0 *
+Ve
+0.000457175791099243
+-89.081302808772 8.62393968310013 -16.0239676304806
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  51 0 3 8.62393968310013
+2  96 21 0 3 8.62393968310013
+4 G1 21 0 20 0
+6  83 21 0
+0
+0101000
++345 0 -272 0 *
+Ve
+0.0001
+-86.5 13 -16.1902832373999
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  52 0 2.07571862729612 3.14159265358979
+2  97 20 0 2.07571862729612 3.14159265358979
+2  98 34 0 2.07571862729612 3.14159265358979
+6  84 18 0
+6  85 34 0
+0
+0101000
++272 0 -270 0 *
+Ve
+0.0001
+-86.5 25 -16.1902832373999
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  53 0 6.5 18.5
+2  99 20 0 6.5 18.5
+2  100 35 0 6.5 18.5
+6  86 35 0
+0
+0101000
++270 0 -268 0 *
+Ve
+0.0001
+-66 22 -17.5111162408969
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  54 0 -15.7519960043035 50.3848562690299
+2  101 20 0 -15.7519960043035 50.3848562690299
+2  102 18 0 -15.7519960043035 50.3848562690299
+6  87 19 0
+0
+0101000
++355 0 -266 0 *
+Ve
+0.000457175782876285
+-89.081302808772 29.3760603168999 -16.0239676304806
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  55 0 3.14159265358979 4.20746667988346
+2  103 20 0 3.14159265358979 4.20746667988346
+2  104 36 0 3.14159265358979 4.20746667988346
+6  88 18 0
+6  89 36 0
+0
+0101000
++268 0 -264 0 *
+Ve
+0.0001
+-88.8503645756781 38 -16.0388471836533
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  56 0 17.8060102129034 45.7399812413541
+2  105 20 0 17.8060102129034 45.7399812413541
+2  106 37 0 17.8060102129034 45.7399812413541
+6  90 37 0
+0
+0101000
++266 0 -262 0 *
+Ve
+1e-07
+-89.081302808772 0 -16.0239676304806
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  51 0 29.3760603168999 38
+2  96 21 0 29.3760603168999 38
+4 G1 21 0 20 0
+6  91 38 0
+0
+0101000
++264 0 -260 1 *
+Ed
+ 1e-07 1 1 0
+1  57 0 87.635254175735 87.8666712637106
+6  92 18 2
+6  93 39 2
+0
+0101000
++262 2 -260 0 *
+Wi
+0101100
+-271 0 +343 0 -269 0 +354 0 -267 0 +265 0 -263 0 +261 0 -259 0 +258 1
+Fa
+0  1e-07 20 0
+2  18
+0101000
++257 0 *
+Ve
+1e-07
+-66 22 10.4966016058463
+0 0
+0101100
+Ve
+0.0001
+-66 22 17.5111162408969
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  58 0 556.988883759103 564.003398394154
+6  94 19 0
+6  95 37 0
+0
+0101000
+-255 0 +254 0 *
+Ve
+1e-07
+-31.3857853359791 22 12.7268258555227
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  59 0 0.064430878219365 34.7504187841557
+2  107 38 0 0.064430878219365 34.7504187841557
+2  108 18 0 0.064430878219365 34.7504187841557
+4 G1 38 0 18 0
+6  96 40 0
+0
+0101000
++255 0 -252 0 *
+Ve
+0.0001
+-1.39644778365369 22 21.6735798462864
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  60 0 21.8866215882316 86.6241305164904
+2  109 22 0 21.8866215882316 86.6241305164904
+2  110 18 0 21.8866215882316 86.6241305164904
+6  97 19 0
+6  98 22 0
+0
+0101000
++250 0 -254 0 *
+Ve
+1e-07
+-25 22 6.73924122776646
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  61 0 0 1.635138268314
+2  111 39 0 0 1.635138268314
+2  112 18 0 0 1.635138268314
+4 G1 39 0 18 0
+6  99 41 0
+0
+0101100
++252 0 -248 0 *
+Ed
+ 2.17185204322443e-07 1 1 0
+1  62 0 3.14159265358979 3.20593459510889
+2  113 19 0 3.14159265358979 3.20593459510889
+2  114 18 0 3.14159265358979 3.20593459510889
+6  100 19 0
+6  101 20 0
+0
+0101000
++352 0 -250 0 *
+Ve
+1e-07
+-25 22 -6.73924122776635
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  63 0 -8.88178419700125e-16 13.4784824555328
+2  115 40 0 -8.88178419700125e-16 13.4784824555328
+2  116 18 0 -8.88178419700125e-16 13.4784824555328
+4 G1 40 0 18 0
+6  102 42 0
+0
+0101000
++248 0 -245 0 *
+Ve
+1e-07
+-31.3857853359791 22 -12.7268258555226
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  64 0 0 1.635138268314
+2  117 41 0 0 1.635138268314
+2  118 18 0 0 1.635138268314
+4 G1 41 0 18 0
+6  103 43 0
+0
+0101100
++245 0 -243 0 *
+Ve
+1e-07
+-66 22 -10.4966016058463
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  65 0 -3.5527136788005e-15 34.6859879059364
+2  119 42 0 -3.5527136788005e-15 34.6859879059364
+2  120 18 0 -3.5527136788005e-15 34.6859879059364
+4 G1 42 0 18 0
+6  104 44 0
+0
+0101000
++243 0 -241 0 *
+Ed
+ 1e-07 1 1 0
+1  58 0 584.996601605846 592.011116240897
+6  105 19 0
+6  106 37 0
+0
+0101000
++241 0 -266 0 *
+Wi
+0101100
+-253 0 -251 0 -249 0 -247 0 -246 0 -244 0 -351 0 -242 0 +265 0 -240 0
+-239 0 *
+Fa
+0  1e-07 18 0
+2  19
+0101000
++238 0 *
+Ed
+ 1e-07 1 1 0
+1  66 0 3 22
+2  121 19 0 3 22
+4 G1 19 0 22 0
+6  107 20 0
+6  108 22 0
+0
+0101000
++340 0 -250 0 *
+Wi
+0101100
++236 0 +339 0 -246 0 -349 0 *
+Fa
+0  1e-07 19 0
+2  20
+0101000
++235 0 *
+Ve
+0.0001
+-98.5827161274038 8 -16.9333281781492
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  67 0 3 8
+2  122 23 0 3 8
+2  123 21 0 3 8
+4 G1 23 0 21 0
+6  109 21 0
+6  110 23 0
+0
+0101000
++335 0 -233 0 *
+Ve
+-91.5 8 -15.9658889549164
+0 0
+0101100
+Ed
+ 2.99999999999999e-07 1 1 0
+1  68 0 3.15791906259637 3.39676917840849
+2  124 21 0 3.15791906259637 3.39676917840849
+2  125 33 0 3.15791906259637 3.39676917840849
+6  111 21 0
+6  112 33 0
+0
+0101000
++231 0 -233 0 *
+Ed
+ 0.000457175791099243 1 1 0
+1  69 0 0 1
+2  126 21 0 0 1
+2  127 34 0 0 1
+6  113 21 0
+6  114 34 0
+0
+0101000
++231 0 -272 0 *
+Wi
+0101100
++232 0 -333 0 -230 0 -271 0 +229 0 *
+Fa
+0  1e-07 21 0
+2  21
+0101000
++228 0 *
+Ve
+0.0136538066327693
+-89.081302808772 8.62393968310014 16.0239676304806
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  70 0 3 8.62393968310014
+2  128 24 0 3 8.62393968310014
+4 G1 24 0 22 0
+6  115 24 0
+0
+0101000
++330 0 -226 0 *
+Ve
+0.0001
+-86.5 13 16.1902832373999
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  71 0 5.21731128088592 6.28318530717959
+2  129 22 0 5.21731128088592 6.28318530717959
+2  130 34 0 5.21731128088592 6.28318530717959
+6  116 22 0
+6  117 34 0
+0
+0101000
++226 0 -224 0 *
+Ve
+0.0001
+-86.5 25 16.1902832373999
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  72 0 6.5 18.5
+2  131 22 0 6.5 18.5
+2  132 35 0 6.5 18.5
+6  118 35 0
+0
+0101000
++224 0 -222 0 *
+Ve
+0.00245521736461804
+-89.081302808772 29.3760603168999 16.0239676304806
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  73 0 0 1.06587402629367
+2  133 22 0 0 1.06587402629367
+2  134 36 0 0 1.06587402629367
+6  119 22 0
+6  120 36 0
+0
+0101000
++222 0 -220 0 *
+Ve
+0.0001
+-88.8503645756781 38 16.0388471836533
+0 0
+0101100
+Ed
+ 1e-08 1 1 0
+1  74 0 47.5116925459533 75.445663574404
+2  135 22 0 47.5116925459533 75.445663574404
+2  136 37 0 47.5116925459533 75.445663574404
+6  121 37 0
+0
+0101000
++254 0 -218 0 *
+Ve
+1e-07
+-89.081302808772 -0 16.0239676304806
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  70 0 29.3760603168999 38
+2  128 24 0 29.3760603168999 38
+4 G1 24 0 22 0
+6  122 45 0
+0
+0101000
++220 0 -216 1 *
+Ed
+ 1e-07 1 1 0
+1  75 0 87.635254175735 87.8666712637106
+6  123 22 2
+6  124 39 2
+0
+0101000
++218 2 -216 0 *
+Wi
+0101100
+-225 0 -329 0 -223 0 +236 0 -221 0 +249 0 -219 0 +217 0 -215 0 +214 1
+Fa
+0  1e-07 22 0
+2  22
+0101000
++213 0 *
+Ve
+0.0001
+-98.5827161274038 8 16.9333281781492
+0 0
+0101100
+Ed
+ 1.74999999999998e-07 1 1 0
+1  76 0 2.88641612877109 6.53836183199828
+2  137 23 0 2.88641612877109 6.53836183199828
+2  138 33 0 2.88641612877109 6.53836183199828
+6  125 23 0
+6  126 33 0
+0
+0101000
++211 0 -233 0 *
+Ed
+ 1e-07 1 1 0
+1  77 0 3 8
+2  139 23 0 3 8
+2  140 24 0 3 8
+4 G1 23 0 24 0
+6  127 24 0
+0
+0101000
++325 0 -211 0 *
+Wi
+0101100
++232 0 +323 0 -210 0 -209 0 *
+Fa
+0  1e-07 23 0
+2  23
+0101000
++208 0 *
+Ve
+0.0136538066327693
+-91.5 8 15.9658889549164
+0 0
+0101100
+Ed
+ 0.0136538066327693 1 1 0
+1  78 0 0 1
+2  141 24 0 0 1
+2  142 34 0 0 1
+6  128 24 0
+6  129 34 0
+0
+0101000
++206 0 -226 0 *
+Ed
+1  79 0 6.02800878236089 6.26685889817301
+2  143 24 0 6.02800878236089 6.26685889817301
+2  144 33 0 6.02800878236089 6.26685889817301
+6  130 24 0
+6  131 33 0
+0
+0101000
++211 0 -206 0 *
+Wi
+0101100
++225 0 -320 0 -205 0 -209 0 -204 0 *
+Fa
+0  1e-07 24 0
+2  24
+0101000
++203 0 *
+Ve
+1e-07
+-31.3214877799826 0 -11.7288950842299
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  80 0 1 7
+2  145 26 0 1 7
+4 G1 25 0 26 0
+6  132 26 0
+0
+0101000
++317 0 -201 3 *
+Ve
+1e-07
+-70.3214877799826 0 -9.21609083367482
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  81 0 16.1498845106291 55.2307517630534
+6  133 25 4
+6  134 46 0
+0
+0101000
++201 0 -199 0 *
+Ed
+ 1e-07 1 1 0
+1  82 0 1 7
+2  146 27 0 1 7
+4 G1 25 0 27 0
+6  135 27 0
+0
+0101000
++315 0 -199 3 *
+Wi
+0101100
++200 0 -314 0 +198 3 -197 0 *
+Fa
+0  1e-07 25 0
+2  25
+0101000
++196 0 *
+Ve
+1e-07
+-26 0 -6.73924122776635
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  83 0 1 7
+2  147 26 0 1 7
+4 G1 26 0 28 0
+6  136 26 0
+6  137 28 0
+0
+0101000
++310 0 -194 3 *
+Ed
+ 1e-07 1 1 0
+2  148 43 0 1.5707963267949 3.20593459510889
+1  84 0 1.5707963267949 3.20593459510889
+2  149 44 0 1.5707963267949 3.20593459510889
+2  150 44 6 1.5707963267949 3.20593459510889
+2  151 45 0 1.5707963267949 3.20593459510889
+2  152 45 8 1.5707963267949 3.20593459510889
+2  153 26 0 1.5707963267949 3.20593459510889
+2  154 26 4 1.5707963267949 3.20593459510889
+6  138 26 4
+6  139 46 0
+0
+0101000
++194 0 -201 0 *
+Wi
+0101100
++193 0 -308 0 +192 3 -200 0 *
+Fa
+0  1e-07 26 0
+2  26
+0101000
++191 0 *
+Ve
+1e-07
+-75 0 -4.22643697721124
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+2  155 46 0 3.20593459510889 4.71238898038469
+1  85 0 3.20593459510889 4.71238898038469
+2  156 47 0 3.20593459510889 4.71238898038469
+2  157 47 6 3.20593459510889 4.71238898038469
+2  158 48 0 3.20593459510889 4.71238898038469
+2  159 48 8 3.20593459510889 4.71238898038469
+2  160 27 0 3.20593459510889 4.71238898038469
+2  161 27 4 3.20593459510889 4.71238898038469
+6  140 27 4
+6  141 46 0
+0
+0101000
++199 0 -189 0 *
+Ed
+ 1e-07 1 1 0
+1  86 0 1 7
+2  162 27 0 1 7
+4 G1 27 0 29 0
+6  142 27 0
+6  143 29 0
+0
+0101000
++305 0 -189 3 *
+Wi
+0101100
++197 0 -304 0 +188 3 -187 0 *
+Fa
+0  1e-07 27 0
+2  27
+0101000
++186 0 *
+Ve
+1e-07
+-26 0 6.7392412277664
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  87 0 1 7
+2  163 30 0 1 7
+4 G1 28 0 30 0
+6  144 30 0
+0
+0101000
++300 0 -184 3 *
+Ed
+ 1e-07 1 1 0
+1  88 0 -6.7392412277664 6.73924122776635
+6  145 28 4
+6  146 46 0
+0
+0101000
++184 0 -194 0 *
+Wi
+0101100
++183 0 -298 0 +182 3 -193 0 *
+Fa
+0  1e-07 28 0
+2  28
+0101000
++181 0 *
+Ve
+1e-07
+-75 0 4.22643697721129
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  89 0 1 7
+2  164 31 0 1 7
+4 G1 31 0 29 0
+6  147 29 0
+6  148 31 0
+0
+0101000
++295 0 -179 3 *
+Ed
+ 1e-07 1 1 0
+1  90 0 22.0123287393414 30.465202693764
+6  149 29 4
+6  150 46 0
+0
+0101000
++179 0 -189 0 *
+Wi
+0101100
++178 0 +294 0 +177 3 -187 0 *
+Fa
+0  1e-07 29 0
+2  29
+0101000
++176 0 *
+Ve
+1e-07
+-31.3214877799826 0 11.72889508423
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  91 0 1 7
+2  165 30 0 1 7
+4 G1 30 0 32 0
+6  151 30 0
+6  152 32 0
+0
+0101000
++290 0 -174 3 *
+Ed
+ 1e-07 1 1 0
+2  166 49 0 6.21884336566049 7.85398163397448
+1  92 0 6.21884336566049 7.85398163397448
+2  167 50 0 6.21884336566049 7.85398163397448
+2  168 50 6 6.21884336566049 7.85398163397448
+2  169 51 0 6.21884336566049 7.85398163397448
+2  170 51 8 6.21884336566049 7.85398163397448
+2  171 30 0 6.21884336566049 7.85398163397448
+2  172 30 4 6.21884336566049 7.85398163397448
+6  153 30 4
+6  154 46 0
+0
+0101000
++174 0 -184 0 *
+Wi
+0101100
++173 0 -288 0 +172 3 -183 0 *
+Fa
+0  1e-07 30 0
+2  30
+0101000
++171 0 *
+Ve
+1e-07
+-70.3214877799826 0 9.21609083367487
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+2  173 52 0 4.71238898038469 6.21884336566049
+1  93 0 4.71238898038469 6.21884336566049
+2  174 53 0 4.71238898038469 6.21884336566049
+2  175 53 6 4.71238898038469 6.21884336566049
+2  176 54 0 4.71238898038469 6.21884336566049
+2  177 54 8 4.71238898038469 6.21884336566049
+2  178 31 0 4.71238898038469 6.21884336566049
+2  179 31 4 4.71238898038469 6.21884336566049
+6  155 31 4
+6  156 46 0
+0
+0101000
++179 0 -169 0 *
+Ed
+ 1e-07 1 1 0
+1  94 0 1 7
+2  180 31 0 1 7
+4 G1 32 0 31 0
+6  157 31 0
+6  158 32 0
+0
+0101000
++285 0 -169 3 *
+Wi
+0101100
++178 0 -284 0 +168 3 -167 0 *
+Fa
+0  1e-07 31 0
+2  31
+0101000
++166 0 *
+Ed
+ 1e-07 1 1 0
+1  95 0 52.3891587580895 91.4700260105138
+6  159 32 4
+6  160 46 0
+0
+0101000
++174 0 -169 0 *
+Wi
+0101100
++173 0 +280 0 +164 3 -167 0 *
+Fa
+0  1e-07 32 0
+2  32
+0101000
++163 0 *
+Ed
+ 1e-07 1 1 0
+1  96 0 537.534111045084 569.465888954916
+2  181 34 0 537.534111045084 569.465888954916
+4 G1 34 0 33 0
+6  161 33 0
+6  162 34 0
+0
+0101000
++206 0 -231 0 *
+Wi
+0101100
++161 0 +204 0 +230 0 -210 0 *
+Wi
+0101100
+-275 0 *
+Fa
+0  1e-07 33 0
+2  33
+0101000
++160 0 +159 0 *
+Ed
+ 1e-07 1 1 0
+1  97 0 537.3097167626 569.6902832374
+2  182 34 0 537.3097167626 569.6902832374
+4 G1 35 0 34 0
+6  163 34 0
+6  164 35 0
+0
+0101000
++224 0 -270 0 *
+Wi
+0101100
++161 0 -205 0 +229 0 -223 0 +269 0 -157 0 *
+Fa
+0  1e-07 34 0
+2  34
+0101000
++156 0 *
+Ed
+ 1e-07 1 1 0
+1  98 0 537.3097167626 569.6902832374
+2  183 36 0 537.3097167626 569.6902832374
+4 G1 36 0 35 0
+6  165 35 0
+6  166 36 0
+0
+0101000
++222 0 -268 0 *
+Wi
+0101100
++157 0 -221 0 +267 0 -154 0 *
+Fa
+0  1e-07 35 0
+2  35
+0101000
++153 0 *
+Ve
+-91.5 30 15.9658889549164
+0 0
+0101100
+Ed
+ 0.00245521736461804 1 1 0
+1  99 0 0 1
+2  184 24 0 0 1
+2  185 36 0 0 1
+6  167 36 0
+6  168 45 0
+0
+0101000
++220 0 -151 0 *
+Ve
+-91.5 30 -15.9658889549164
+0 0
+0101100
+Ed
+ 0.000457175782876285 1 1 0
+1  100 0 0 1
+2  186 21 0 0 1
+2  187 36 0 0 1
+6  169 36 0
+6  170 38 0
+0
+0101000
++149 0 -264 0 *
+Ed
+ 1e-07 1 1 0
+1  101 0 537.534111045084 569.465888954916
+2  188 36 0 537.534111045084 569.465888954916
+4 G1 55 0 36 0
+6  171 36 0
+6  172 47 0
+0
+0101000
++151 0 -149 0 *
+Wi
+0101100
++154 0 -219 0 +263 0 -150 0 -148 0 -147 0 *
+Fa
+0  1e-07 36 0
+2  36
+0101000
++146 0 *
+Ve
+1e-07
+-65.9990284558852 21.999319717382 10.4597081659336
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  102 0 3.14969598006561 3.18658391204459
+2  189 38 0 3.14969598006561 3.18658391204459
+2  190 37 0 3.14969598006561 3.18658391204459
+6  173 37 0
+6  174 40 0
+0
+0101000
++144 0 -255 0 *
+Ve
+7.651324100635e-05
+-69.8122088401342 24.6693377797162 10.2140216049676
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  103 0 0.673446970666599 5.33495992058446
+2  191 56 0 0.673446970666599 5.33495992058446
+2  192 37 0 0.673446970666599 5.33495992058446
+4 G1 56 0 37 0
+6  175 48 0
+0
+0101000
++142 0 -144 0 *
+Ed
+ 1e-08 1 1 0
+1  104 0 271.211152816347 303.288847183653
+2  193 1 1 271.211152816347 303.288847183653
+2  194 37 0 271.211152816347 303.288847183653
+6  176 37 0
+6  177 39 0
+0
+0101000
++218 0 -262 0 *
+Ve
+7.651324100635e-05
+0 0
+0101100
+Ed
+ 7.651324100635e-05 1 1 0
+1  105 0 22.0856557446261 31.1089791038772
+2  195 57 0 22.0856557446261 31.1089791038772
+2  196 37 0 22.0856557446261 31.1089791038772
+4 G1 57 0 37 0
+6  178 49 0
+0
+0101000
++139 0 -142 0 *
+Ve
+0.000137041836253824
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  106 0 -1.77635683940025e-14 8.45287395442251
+2  197 58 0 -1.77635683940025e-14 8.45287395442251
+2  198 37 0 -1.77635683940025e-14 8.45287395442251
+4 G1 58 0 37 0
+6  179 50 0
+0
+0101000
++137 0 -139 0 *
+Ve
+7.65132413866445e-05
+0 0
+0101100
+Ed
+ 7.65132413866445e-05 1 1 0
+1  107 0 4.60945843095357 13.6327817902065
+2  199 59 0 4.60945843095357 13.6327817902065
+2  200 37 0 4.60945843095357 13.6327817902065
+4 G1 59 0 37 0
+6  180 51 0
+0
+0101000
++135 0 -137 0 *
+Ve
+1e-07
+-65.9990284558852 21.9993197173819 -10.4597081659336
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  108 0 0.00810332647598155 0.0449912584548366
+2  201 42 0 0.00810332647598155 0.0449912584548366
+2  202 37 0 0.00810332647598155 0.0449912584548366
+6  181 37 0
+6  182 44 0
+0
+0101000
++133 0 -241 0 *
+Ed
+ 1e-07 1 1 0
+1  109 0 -0.0520545189644926 4.60945843095345
+2  203 60 0 -0.0520545189644926 4.60945843095345
+2  204 37 0 -0.0520545189644926 4.60945843095345
+4 G1 60 0 37 0
+6  183 52 0
+0
+0101000
++133 0 -135 0 *
+Wi
+0101100
++253 0 -143 0 -217 0 -141 0 -140 0 -138 0 +261 0 -136 0 +239 0 -134 0
++132 0 -131 0 *
+Fa
+0  1e-07 37 0
+2  37
+0101000
++130 0 *
+Ve
+0.0001
+0 0
+0101100
+Ve
+1e-07
+-98.5827161274038 0 -16.9333281781492
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  67 0 30 38
+2  122 23 0 30 38
+2  123 21 0 30 38
+4 G1 23 0 21 0
+6  184 38 0
+6  185 53 0
+0
+0101000
++128 0 -127 1 *
+Ed
+1  110 0 3.15791906259637 3.39676917840849
+2  205 21 0 3.15791906259637 3.39676917840849
+2  206 55 0 3.15791906259637 3.39676917840849
+6  186 38 0
+6  187 47 0
+0
+0101000
++149 0 -128 0 *
+Ed
+ 1e-07 1 1 0
+2  207 61 0 6.02800878236089 6.34752724869869
+1  111 0 6.02800878236089 6.34752724869869
+2  208 62 0 6.02800878236089 6.34752724869869
+2  209 62 10 6.02800878236089 6.34752724869869
+2  210 63 0 6.02800878236089 6.34752724869869
+2  211 63 12 6.02800878236089 6.34752724869869
+2  212 21 0 6.02800878236089 6.34752724869869
+2  213 21 2 6.02800878236089 6.34752724869869
+6  188 38 2
+6  189 39 2
+0
+0101000
++127 0 -260 0 *
+Wi
+0101100
++126 0 +125 0 +124 1 -148 0 -259 0 *
+Fa
+0  1e-07 21 0
+2  38
+0101000
++123 0 *
+Ve
+1e-07
+-98.5827161274038 -0 16.9333281781492
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  112 0 2.88641612877109 6.53836183199828
+2  214 64 0 2.88641612877109 6.53836183199828
+2  215 64 10 2.88641612877109 6.53836183199828
+2  216 65 0 2.88641612877109 6.53836183199828
+2  217 65 12 2.88641612877109 6.53836183199828
+2  218 23 0 2.88641612877109 6.53836183199828
+2  219 23 2 2.88641612877109 6.53836183199828
+6  190 39 2
+6  191 53 2
+0
+0101000
++127 0 -121 0 *
+Ed
+ 1e-07 1 1 0
+2  220 66 0 3.07725071207069 3.39676917840849
+1  113 0 3.07725071207069 3.39676917840849
+2  221 67 0 3.07725071207069 3.39676917840849
+2  222 67 10 3.07725071207069 3.39676917840849
+2  223 68 0 3.07725071207069 3.39676917840849
+2  224 68 12 3.07725071207069 3.39676917840849
+2  225 24 0 3.07725071207069 3.39676917840849
+2  226 24 2 3.07725071207069 3.39676917840849
+6  192 45 2
+0
+0101000
++216 0 -121 0 *
+Wi
+0101100
++258 1 +140 0 -124 1 -214 1 +120 1 -119 1 *
+Ve
+1e-07
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  114 0 0 6.28318530717959
+2  227 16 0 0 6.28318530717959
+2  228 16 14 0 6.28318530717959
+6  193 54 0
+0
+0101100
++117 0 -117 0 *
+Wi
+0101100
++116 0 *
+Fa
+0  1e-07 1 1
+2  39
+0101000
++118 0 +115 0 *
+Ve
+1e-07
+-66.2510012728069 21 9.47835585411223
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  115 0 1.5707963267949 3.10470472161085
+2  229 56 0 1.5707963267949 3.10470472161085
+2  230 38 0 1.5707963267949 3.10470472161085
+6  194 40 0
+6  195 48 0
+0
+0101000
++113 0 -144 0 *
+Ve
+1e-07
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  116 0 -0.251521728788582 34.7504187841557
+2  231 38 0 -0.251521728788582 34.7504187841557
+2  232 69 0 -0.251521728788582 34.7504187841557
+4 G1 38 0 69 0
+6  196 40 0
+6  197 55 0
+0
+0101000
++113 0 -111 0 *
+Ed
+ 1e-07 1 1 0
+1  117 0 0 1.5707963267949
+2  233 38 0 0 1.5707963267949
+2  234 39 0 0 1.5707963267949
+4 G1 38 0 39 0
+6  198 40 0
+6  199 41 0
+0
+0101100
++252 0 -111 0 *
+Wi
+0101100
+-112 0 +110 0 -143 0 -109 0 -251 0 *
+Fa
+0  0 38 0
+2  40
+0101000
++108 0 *
+Ve
+1e-07
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  118 0 0 1.635138268314
+2  235 39 0 0 1.635138268314
+2  236 70 0 0 1.635138268314
+4 G1 39 0 70 0
+6  200 41 0
+6  201 56 0
+0
+0101100
++111 0 -106 0 *
+Ed
+ 1e-07 1 1 0
+1  119 0 1.5707963267949 3.14159265358979
+2  237 39 0 1.5707963267949 3.14159265358979
+2  238 40 0 1.5707963267949 3.14159265358979
+4 G1 39 0 40 0
+6  202 41 0
+6  203 42 0
+0
+0101100
++248 0 -106 0 *
+Wi
+0101100
+-109 0 +247 0 -105 0 +104 0 *
+Fa
+0  0 39 0
+2  41
+0101000
++103 0 *
+Ve
+1e-07
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  120 0 -8.88178419700125e-16 13.4784824555328
+2  239 40 0 -8.88178419700125e-16 13.4784824555328
+2  240 71 0 -8.88178419700125e-16 13.4784824555328
+4 G1 40 0 71 0
+6  204 42 0
+6  205 57 0
+0
+0101000
++106 0 -101 0 *
+Ed
+ 1e-07 1 1 0
+1  121 0 0 1.5707963267949
+2  241 40 0 0 1.5707963267949
+2  242 41 0 0 1.5707963267949
+4 G1 40 0 41 0
+6  206 42 0
+6  207 43 0
+0
+0101100
++245 0 -101 0 *
+Wi
+0101100
++104 0 -244 0 +100 0 -99 0 *
+Fa
+0  0 40 0
+2  42
+0101000
++98 0 *
+Ve
+1e-07
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  122 0 0 1.635138268314
+2  243 41 0 0 1.635138268314
+2  244 72 0 0 1.635138268314
+4 G1 41 0 72 0
+6  208 43 0
+6  209 58 0
+0
+0101100
++101 0 -96 0 *
+Ed
+ 1e-07 1 1 0
+1  123 0 1.5707963267949 3.14159265358979
+2  245 41 0 1.5707963267949 3.14159265358979
+2  246 42 0 1.5707963267949 3.14159265358979
+4 G1 41 0 42 0
+6  210 43 0
+6  211 44 0
+0
+0101100
++243 0 -96 0 *
+Wi
+0101100
+-99 0 +242 0 -95 0 +94 0 *
+Fa
+0  0 41 0
+2  43
+0101000
++93 0 *
+Ve
+1e-07
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  124 0 4.71238898038469 6.24629737520065
+2  247 60 0 4.71238898038469 6.24629737520065
+2  248 42 0 4.71238898038469 6.24629737520065
+6  212 44 0
+6  213 52 0
+0
+0101000
++91 0 -133 0 *
+Ed
+ 1e-07 1 1 0
+1  125 0 -3.5527136788005e-15 35.0019405129443
+2  249 42 0 -3.5527136788005e-15 35.0019405129443
+2  250 73 0 -3.5527136788005e-15 35.0019405129443
+4 G1 42 0 73 0
+6  214 44 0
+6  215 59 0
+0
+0101000
++96 0 -91 0 *
+Wi
+0101100
++90 0 +89 0 +132 0 +94 0 -240 0 *
+Fa
+0  0 42 0
+2  44
+0101000
++88 0 *
+Ve
+0.0001
+-98.5827161274038 30 16.9333281781492
+0 0
+0101100
+Ed
+1  126 0 6.02800878236089 6.26685889817301
+2  251 24 0 6.02800878236089 6.26685889817301
+2  252 55 0 6.02800878236089 6.26685889817301
+6  216 45 0
+6  217 47 0
+0
+0101000
++86 0 -151 0 *
+Ed
+ 1e-07 1 1 0
+1  77 0 30 38
+2  139 23 0 30 38
+2  140 24 0 30 38
+4 G1 23 0 24 0
+6  218 45 0
+6  219 53 0
+0
+0101000
++86 0 -121 1 *
+Wi
+0101100
++215 0 -150 0 +119 1 +85 0 -84 0 *
+Fa
+0  1e-07 24 0
+2  45
+0101000
++83 0 *
+Wi
+0101100
++198 0 +192 0 +188 0 +182 0 +172 0 -164 0 +168 0 -177 0 *
+Fa
+0  1e-07 74 0
+2  46
+0101000
++81 0 *
+Ed
+1  127 0 2.88641612877109 6.53836183199828
+2  253 23 0 2.88641612877109 6.53836183199828
+2  254 55 0 2.88641612877109 6.53836183199828
+6  220 47 0
+6  221 53 0
+0
+0101000
++86 0 -128 0 *
+Wi
+0101100
++147 0 +85 0 +125 0 -79 0 *
+Ve
+0.0001
+-103 30 -6.48999977111816
+0 0
+0101100
+Ed
+1  128 0 3.14159265358979 9.42477796076938
+2  255 55 0 3.14159265358979 9.42477796076938
+2  256 16 0 3.14159265358979 9.42477796076938
+6  222 54 0
+0
+0101100
++77 0 -77 0 *
+Wi
+0101100
+-76 0 *
+Fa
+0  1e-07 55 0
+2  47
+0101000
++78 0 +75 0 *
+Ve
+0.0001
+-70.3214877799826 23.8501857770853 9.21609083367487
+0 0
+0101100
+Ed
+ 2.6035990371665e-05 1 1 0
+1  129 0 0 9.02332335925109
+2  257 56 0 0 9.02332335925109
+2  258 57 0 0 9.02332335925109
+4 G1 57 0 56 0
+6  223 48 0
+6  224 49 0
+0
+0101000
++142 0 -73 0 *
+Ed
+ 1e-07 1 1 0
+1  130 0 0.673446970666599 5.64950990334176
+2  259 56 0 0.673446970666599 5.64950990334176
+2  260 69 0 0.673446970666599 5.64950990334176
+4 G1 56 0 69 0
+6  225 48 0
+6  226 55 0
+0
+0101000
++73 0 -113 0 *
+Wi
+0101100
++72 0 -141 0 +71 0 +112 0 *
+Fa
+0  0 56 0
+2  48
+0101000
++70 0 *
+Ve
+0.0001
+0 0
+0101100
+Ed
+ 3.69796737134414e-07 1 1 0
+1  131 0 0 0.959931015968323
+2  261 58 0 0 0.959931015968323
+2  262 57 0 0 0.959931015968323
+4 G1 58 0 57 0
+6  227 49 0
+6  228 50 0
+0
+0101100
++139 0 -68 0 *
+Ed
+ 1.70884701121558e-05 1 1 0
+1  132 0 22.0856557446261 31.1089791038772
+2  263 57 0 22.0856557446261 31.1089791038772
+2  264 75 0 22.0856557446261 31.1089791038772
+4 G1 57 0 75 0
+6  229 49 0
+6  230 60 0
+0
+0101000
++68 0 -73 0 *
+Wi
+0101100
++67 0 -138 0 +66 0 -72 0 *
+Fa
+0  8.61989926814529e-06 57 0
+2  49
+0101000
++65 0 *
+Ve
+-75 27.7813018136297 -4.22643697721124
+0 0
+0101100
+Ed
+ 0.000137041836253824 1 1 0
+1  133 0 0 9.02332335925291
+2  265 58 0 0 9.02332335925291
+2  266 59 0 0 9.02332335925291
+4 G1 59 0 58 0
+6  231 50 0
+6  232 51 0
+0
+0101000
++137 0 -63 0 *
+Ed
+ 1e-07 1 1 0
+1  134 0 -1.77635683940025e-14 8.45287395442251
+2  267 58 0 -1.77635683940025e-14 8.45287395442251
+2  268 76 0 -1.77635683940025e-14 8.45287395442251
+4 G1 58 0 76 0
+6  233 50 0
+6  234 61 0
+0
+0101000
++63 0 -68 0 *
+Wi
+0101100
++62 0 -136 0 +61 0 -67 0 *
+Fa
+0  0 58 0
+2  50
+0101000
++60 0 *
+Ve
+0.0001
+0 0
+0101100
+Ed
+ 1.03517356427749e-05 1 1 0
+1  135 0 0 1.53390839481596
+2  269 60 0 0 1.53390839481596
+2  270 59 0 0 1.53390839481596
+4 G1 60 0 59 0
+6  235 51 0
+6  236 52 0
+0
+0101100
++135 0 -58 0 *
+Ed
+ 1.70884699292667e-05 1 1 0
+1  136 0 4.60945843095357 13.6327817902065
+2  271 59 0 4.60945843095357 13.6327817902065
+2  272 77 0 4.60945843095357 13.6327817902065
+4 G1 59 0 77 0
+6  237 51 0
+6  238 62 0
+0
+0101000
++58 0 -63 0 *
+Wi
+0101100
++57 0 -134 0 +56 0 -62 0 *
+Fa
+0  8.61989920905233e-06 59 0
+2  51
+0101000
++55 0 *
+Ed
+ 1e-07 1 1 0
+1  137 0 -0.366604501721728 4.60945843095345
+2  273 60 0 -0.366604501721728 4.60945843095345
+2  274 73 0 -0.366604501721728 4.60945843095345
+4 G1 60 0 73 0
+6  239 52 0
+6  240 59 0
+0
+0101000
++91 0 -58 0 *
+Wi
+0101100
+-90 0 +53 0 -131 0 -57 0 *
+Fa
+0  0 60 0
+2  52
+0101000
++52 0 *
+Wi
+0101100
++126 0 +79 0 +120 1 -84 0 *
+Fa
+0  1e-07 23 0
+2  53
+0101000
++50 0 *
+Ed
+ 1e-07 1 1 0
+1  49 0 0 8
+3  92 93CN 16 0 0 8
+7  241 242 54 0
+0
+0101000
+-77 0 +117 0 *
+Wi
+0101100
+-116 0 +48 0 -48 0 -76 0 *
+Fa
+0  1e-07 16 0
+2  54
+0101000
++47 0 *
+Ve
+1e-07
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  138 0 17 23
+2  275 70 0 17 23
+4 G1 69 0 70 0
+6  243 56 0
+0
+0101000
++111 0 -45 15 *
+Ve
+1e-07
+-70.3214877799826 38 9.21609083367487
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  139 0 52.3891587580895 91.4700260105138
+6  244 55 16
+6  245 63 0
+0
+0101000
++45 0 -43 0 *
+Ed
+ 1e-07 1 1 0
+1  140 0 14.1498142229147 23
+2  276 75 0 14.1498142229147 23
+4 G1 69 0 75 0
+6  246 60 0
+0
+0101000
++73 0 -43 15 *
+Wi
+0101100
++44 0 +110 0 +42 15 +71 0 -41 0 *
+Fa
+0  1e-07 69 0
+2  55
+0101000
++40 0 *
+Ve
+1e-07
+-26 38 6.7392412277664
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+2  277 78 0 6.21884336566049 7.85398163397448
+1  141 0 6.21884336566049 7.85398163397448
+2  278 79 0 6.21884336566049 7.85398163397448
+2  279 79 18 6.21884336566049 7.85398163397448
+2  280 80 0 6.21884336566049 7.85398163397448
+2  281 80 20 6.21884336566049 7.85398163397448
+2  282 81 0 6.21884336566049 7.85398163397448
+2  283 81 22 6.21884336566049 7.85398163397448
+2  284 70 0 6.21884336566049 7.85398163397448
+2  285 70 16 6.21884336566049 7.85398163397448
+6  247 56 16
+6  248 63 0
+0
+0101000
++45 0 -38 0 *
+Ed
+ 1e-07 1 1 0
+1  142 0 17 23
+2  286 70 0 17 23
+4 G1 70 0 71 0
+6  249 56 0
+6  250 57 0
+0
+0101000
++106 0 -38 15 *
+Wi
+0101100
++44 0 -105 0 +37 15 -36 0 *
+Fa
+0  1e-07 70 0
+2  56
+0101000
++35 0 *
+Ve
+1e-07
+-26 38 -6.73924122776635
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  143 0 -6.7392412277664 6.73924122776635
+6  251 57 16
+6  252 63 0
+0
+0101000
++38 0 -33 0 *
+Ed
+ 1e-07 1 1 0
+1  144 0 17 23
+2  287 72 0 17 23
+4 G1 72 0 71 0
+6  253 58 0
+0
+0101000
++101 0 -33 15 *
+Wi
+0101100
++36 0 -100 0 +32 15 -31 0 *
+Fa
+0  1e-07 71 0
+2  57
+0101000
++30 0 *
+Ve
+1e-07
+-31.3214877799826 38 -11.7288950842299
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+2  288 82 0 1.5707963267949 3.20593459510889
+1  145 0 1.5707963267949 3.20593459510889
+2  289 83 0 1.5707963267949 3.20593459510889
+2  290 83 18 1.5707963267949 3.20593459510889
+2  291 84 0 1.5707963267949 3.20593459510889
+2  292 84 20 1.5707963267949 3.20593459510889
+2  293 85 0 1.5707963267949 3.20593459510889
+2  294 85 22 1.5707963267949 3.20593459510889
+2  295 72 0 1.5707963267949 3.20593459510889
+2  296 72 16 1.5707963267949 3.20593459510889
+6  254 58 16
+6  255 63 0
+0
+0101000
++33 0 -28 0 *
+Ed
+ 1e-07 1 1 0
+1  146 0 17 23
+2  297 72 0 17 23
+4 G1 73 0 72 0
+6  256 58 0
+6  257 59 0
+0
+0101000
++96 0 -28 15 *
+Wi
+0101100
++31 0 -95 0 +27 15 -26 0 *
+Fa
+0  1e-07 72 0
+2  58
+0101000
++25 0 *
+Ve
+1e-07
+-70.3214877799826 38 -9.21609083367482
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  147 0 16.1498845106291 55.2307517630533
+6  258 59 16
+6  259 63 0
+0
+0101000
++28 0 -23 0 *
+Ed
+ 1e-07 1 1 0
+1  148 0 14.1498142229147 23
+2  298 77 0 14.1498142229147 23
+4 G1 77 0 73 0
+6  260 62 0
+0
+0101000
++58 0 -23 15 *
+Wi
+0101100
++26 0 -89 0 +22 15 -53 0 -21 0 *
+Fa
+0  1e-07 73 0
+2  59
+0101000
++20 0 *
+Ve
+1e-07
+-75 38 4.22643697721129
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  149 0 10.2186981863703 23
+2  299 75 0 10.2186981863703 23
+4 G1 75 0 76 0
+6  261 60 0
+6  262 61 0
+0
+0101000
++68 0 -18 15 *
+Ed
+ 1e-07 1 1 0
+2  300 86 0 4.71238898038469 6.21884336566049
+1  150 0 4.71238898038469 6.21884336566049
+2  301 87 0 4.71238898038469 6.21884336566049
+2  302 87 18 4.71238898038469 6.21884336566049
+2  303 88 0 4.71238898038469 6.21884336566049
+2  304 88 20 4.71238898038469 6.21884336566049
+2  305 89 0 4.71238898038469 6.21884336566049
+2  306 89 22 4.71238898038469 6.21884336566049
+2  307 75 0 4.71238898038469 6.21884336566049
+2  308 75 16 4.71238898038469 6.21884336566049
+6  263 60 16
+6  264 63 0
+0
+0101000
++18 0 -43 0 *
+Wi
+0101100
++17 0 -66 0 +16 15 -41 0 *
+Fa
+0  1e-07 75 0
+2  60
+0101000
++15 0 *
+Ve
+1e-07
+-75 38 -4.22643697721124
+0 0
+0101100
+Ed
+ 1e-07 1 1 0
+1  151 0 22.0123287393414 30.465202693764
+6  265 61 16
+6  266 63 0
+0
+0101000
++18 0 -13 0 *
+Ed
+ 1e-07 1 1 0
+1  152 0 10.2186981863703 23
+2  309 77 0 10.2186981863703 23
+4 G1 76 0 77 0
+6  267 61 0
+6  268 62 0
+0
+0101000
++63 0 -13 15 *
+Wi
+0101100
++17 0 +61 0 +12 15 -11 0 *
+Fa
+0  1e-07 76 0
+2  61
+0101000
++10 0 *
+Ed
+ 1e-07 1 1 0
+2  310 90 0 3.20593459510889 4.71238898038469
+1  153 0 3.20593459510889 4.71238898038469
+2  311 91 0 3.20593459510889 4.71238898038469
+2  312 91 18 3.20593459510889 4.71238898038469
+2  313 92 0 3.20593459510889 4.71238898038469
+2  314 92 20 3.20593459510889 4.71238898038469
+2  315 93 0 3.20593459510889 4.71238898038469
+2  316 93 22 3.20593459510889 4.71238898038469
+2  317 77 0 3.20593459510889 4.71238898038469
+2  318 77 16 3.20593459510889 4.71238898038469
+6  269 62 16
+6  270 63 0
+0
+0101000
++23 0 -13 0 *
+Wi
+0101100
++21 0 -56 0 +8 15 -11 0 *
+Fa
+0  1e-07 77 0
+2  62
+0101000
++7 0 *
+Wi
+0101100
+-42 0 +37 0 +16 0 -12 0 +8 0 +22 0 +27 0 +32 0 *
+Fa
+0  1e-07 94 0
+2  63
+0101000
++5 0 *
+Sh
+0101100
+-357 0 +346 0 +341 0 -336 0 -331 0 +326 0 -321 0 -318 0 +311 0 -306 0
+-301 0 +296 0 +291 0 -286 0 -281 0 +278 0 +273 0 -256 0 +237 0 -234 0
++227 0 +212 0 -207 0 +202 0 +195 0 +190 0 +185 0 +180 0 -175 0 +170 0
++165 0 -162 0 +158 0 -155 0 -152 0 -145 0 +129 0 +122 0 +114 0 -107 0
++102 0 -97 0 +92 0 -87 0 +82 0 -80 3 -74 0 -69 0 -64 0 -59 0
+-54 0 -51 0 -49 0 +46 0 +39 0 -34 0 -29 0 -24 0 -19 0 -14 0
++9 0 -6 0 +4 15 *
+So
+0100000
++3 0 *
+Co
+0100000
++2 0 *
++1 0
\ No newline at end of file
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am	2008-10-14 19:25:26 UTC (rev 2143)
+++ cgm/trunk/test/Makefile.am	2008-10-14 19:42:14 UTC (rev 2144)
@@ -18,7 +18,7 @@
   LINK_FLAGS += -R$(ACIS_LIB_DIR)
 endif
 if WITH_OCC
-  TESTS += modify makept r_w
+  TESTS += modify makept r_w test_occ
   LINK_FLAGS += -R$(OCC_LIB_DIR)
 endif
@@ -32,6 +32,7 @@
 modify_SOURCES = modify.cpp
 sheet_SOURCES  = sheet.cpp
 r_w_SOURCES    = r_w.cpp
+test_occ_SOURCES = test_occ.cpp
 LDADD = ../libcgm.la
 webcut_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
 hollow_acis_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
@@ -43,6 +44,7 @@
 EXTRA_DIST = 62_shaver1.brep \
              66_shaver3.brep \
              72_shaver6.brep \
+             LeverArm.brep\
              aftersub.occ_ref \
              beforesub.occ_ref \
              beforesub2.occ_ref \
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp	2008-10-14 19:25:26 UTC (rev 2143)
+++ cgm/trunk/test/modify.cpp	2008-10-14 19:42:14 UTC (rev 2144)
@@ -716,6 +716,7 @@
        ref_faces.get()->center_point() == center )
       break;
+  RefFace* sweep_face = gmti->make_RefFace(ref_faces.get());
   DLIList<RefFace*> faces_to_remove;
   faces_to_remove.append(ref_faces.get());
   from_bodies = new_bodies;
@@ -725,11 +726,26 @@
   n = new_bodies.get()->num_ref_faces(); //n = 10
   d = new_bodies.get()->measure(); //d = 72.3618
-  RefFace* sweep_face = gmti->make_RefFace(ref_faces.get());
   DLIList<RefEntity*> refentities;
   refentities.append(sweep_face);
-//  gmti->sweep_translational(refentities, v_move8, 0, 1, CUBIT_FALSE, CUBIT_FALSE);
-//  body = CAST_TO(refentities.get(), Body);
-//  d = body->measure();
+  RefFace* draft_face = gmti->make_RefFace(sweep_face);
+  gmti->sweep_translational(refentities, v_move8, 0, 1, CUBIT_FALSE, CUBIT_FALSE);
+  body = CAST_TO(refentities.get(), Body);
+  d = body->measure();
+  //d = 31.4159
+  refentities.clean_out();
+  refentities.append(draft_face);
+  gmti->sweep_translational(refentities, v_move8, 0.087, 1, CUBIT_FALSE, CUBIT_FALSE);
+  //d = 66.3676  theoretical calculation is 66.7833, error 0.62%
+  DLIList<RefEdge*> edges;
+  body->ref_edges(edges);
+  refentities.append(edges.get());
+  //d = area = 90.1292 theoretica calculation is 90.5754, error 0.49%
   return CUBIT_SUCCESS;
Added: cgm/trunk/test/test_occ.cpp
--- cgm/trunk/test/test_occ.cpp	                        (rev 0)
+++ cgm/trunk/test/test_occ.cpp	2008-10-14 19:42:14 UTC (rev 2144)
@@ -0,0 +1,141 @@
+#include <cassert>
+#include <cstdio>
+#include <cstdlib>
+#include <list>
+#include <map>
+#include <string>
+#include "AppUtil.hpp"
+#include "CGMApp.hpp"
+#include "CubitObserver.hpp"
+#include "CubitVector.hpp"
+#include "DLIList.hpp"
+#include "GeometryModifyTool.hpp"
+#include "GeometryQueryTool.hpp"
+#include "GMem.hpp"
+#include "OCCModifyEngine.hpp"
+#include "OCCQueryEngine.hpp"
+#include "RefVertex.hpp"
+#include "RefEdge.hpp"
+#include "RefFace.hpp"
+#include "RefVolume.hpp"
+using std::list;
+using std::pair;
+using std::set;
+using std::map;
+using std::vector;
+int main( int argc, char** argv ) {
+  AppUtil::instance()->startup(argc, argv);
+  CGMApp::instance()->startup(argc, argv);
+  CubitObserver::init_static_observers();
+  OCCQueryEngine::instance();
+  OCCModifyEngine::instance();
+  GeometryQueryTool *gti = GeometryQueryTool::instance();
+  GeometryModifyTool *gmti = GeometryModifyTool::instance();
+  // Read in the geometry from files specified on the command line
+  std::string filename("./LeverArm.brep");
+  assert(gti);
+  CubitStatus status = gti->import_solid_model(filename.c_str(), "OCC");
+  if (status != CUBIT_SUCCESS)
+    PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str());
+  DLIList<RefEdge*> my_curvs;
+  DLIList<RefFace*> my_surfs;
+  gti->ref_edges(my_curvs);
+  gti->ref_faces(my_surfs);
+  // ***** Discretize the curves ***** //
+  map< RefEdge*, list<double> > discrete_curves;
+  for(int i = 0; i < my_curvs.size(); ++i) {
+    list<double> sample_params;
+    RefEdge* this_curv = my_curvs.get_and_step();
+    //Insert nine arbitrary points on each curves
+    double delta = this_curv->end_param() - this_curv->start_param();
+    for(int j = 1; j < 10; ++j)
+      sample_params.push_back( this_curv->start_param() + (static_cast<double>(j) * delta / 10.) );
+    discrete_curves.insert( std::make_pair(this_curv, sample_params) );
+  //Pick one of the surfaces arbitrarily and attempt to find the u-v coordinates
+  //of the points discretizing the boundary of this surface.
+    RefFace* this_surf = my_surfs.next(7);
+    DLIList<RefVertex*> surf_points;
+    DLIList<RefEdge*> surf_curves;
+    this_surf->ref_vertices(surf_points);
+    this_surf->ref_edges(surf_curves);
+    CubitVector coord0, coord1;
+    double u, v;
+    double max_u, min_u, max_v, min_v;
+    this_surf->get_param_range_U(min_u, max_u);
+    this_surf->get_param_range_V(min_v, max_v);
+    //Deals with curve end points.
+    for(int i = 0; i < surf_points.size(); ++i) {
+      RefVertex* this_point = surf_points.get_and_step();
+      u = v = -1.e300;
+      coord0 = this_point->coordinates();
+      this_surf->u_v_from_position(coord0, u, v, &coord1);
+      if( u < min_u || v < min_v ) {
+	printf("Failed to find a parameter with valid range for an apex point\n");
+	printf("  point coords:     %e %e %e\n", coord0.x(), coord0.y(), coord0.z());
+	printf("  projected coords: %e %e %e\n", coord1.x(), coord1.y(), coord1.z());
+	printf("  params returned:  %e %e\n\n", u, v);
+    //Deals with discretization points on curves.
+    for(int i = 0; i < surf_curves.size(); ++i) {
+      RefEdge* this_curv = surf_curves.get_and_step();
+      assert(discrete_curves.count(this_curv) == 1);
+      list<double> curve_params = discrete_curves.find(this_curv)->second;
+      list<double>::iterator it = curve_params.begin(), it_end = curve_params.end();
+      for( ; it != it_end; ++it) {
+	u = v = -1.e300;
+	this_curv->position_from_u(*it, coord0);
+	  printf("Failed to find a parameter with valid range for a curve point\n");
+  printf("done...\n");
+  return(0);
More information about the cgma-dev mailing list
