[cgma-dev] CGMA check for *64* failed.
Jiangtao Hu jiangtao_ma at yahoo.com
Thu Oct 30 10:48:36 CDT 2008
Hi, Jason,
this test build should be linked against occ6.3, which is in /home/jhu directory. If you'd like to build occ6.3, I have a patch change to add to it:
http://homepages.cae.wisc.edu/~janeh/OCC/patch6.3.html
please apply it before your build.
Then it should pass.
Jane
/opt/occ6.2/ros/inc/IntPatch_IntersectionGen.lxx:57: warning: deprecated
conversion from string constant to ‘char*’
../../../trunk/geom/OCC/OCCModifyEngine.cpp: In member function ‘virtual
CubitStatus
OCCModifyEngine::sweep_along_curve(DLIList<GeometryEntity*>&,
DLIList<BodySM*>&, DLIList<Curve*>&, double, int, bool,
Surface*, BodySM*) const’:
../../../trunk/geom/OCC/OCCModifyEngine.cpp:4351: warning: statement has no
effect
../../../trunk/geom/OCC/OCCModifyEngine.cpp:4354: error:
‘BRepLib_FuseEdges’ was not declared in this scope
../../../trunk/geom/OCC/OCCModifyEngine.cpp:4354: error: expected `;'
before ‘fuser’
../../../trunk/geom/OCC/OCCModifyEngine.cpp:4355: error: ‘fuser’ was not
make[3]: *** [OCCModifyEngine.lo] Error 1
make[3]: Leaving directory `/home/jason/cgm/test/64/geom/OCC'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/jason/cgm/test/64/geom'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/jason/cgm/test/64'
make: *** [all] Error 2
URL: <https://lists.mcs.anl.gov/mailman/private/cgma-dev/attachments/20081030/4bab4df7/attachment.html>
More information about the cgma-dev mailing list
