[cgma-dev] r2183 - in cgm/trunk: . itaps
kraftche at mcs.anl.gov
Wed Oct 29 14:44:57 CDT 2008
Author: kraftche
Date: 2008-10-29 14:44:57 -0500 (Wed, 29 Oct 2008)
New Revision: 2183
Modified:
cgm/trunk/Makefile.am
cgm/trunk/configure.in
cgm/trunk/itaps/Makefile.am
Log:
fix test build issues
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am 2008-10-29 19:22:27 UTC (rev 2182)
+++ cgm/trunk/Makefile.am 2008-10-29 19:44:57 UTC (rev 2183)
@@ -1,5 +1,5 @@
AUTOMAKE_OPTIONS = foreign
-SUBDIRS = util geom init itaps . test cgm_apps
+SUBDIRS = util geom init . itaps test cgm_apps
# Don't loose the autoconf include path
ACLOCAL_AMFLAGS = -I m4
@@ -59,7 +59,6 @@
libcgm_la_LIBADD = init/libcgma_init.la \
- itaps/libiGeom.la \
$(CORE_CGM_LIBS) \
$(EXT_LINK_FLAGS) \
$(EXT_LIBS)
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2008-10-29 19:22:27 UTC (rev 2182)
+++ cgm/trunk/configure.in 2008-10-29 19:44:57 UTC (rev 2183)
@@ -125,7 +125,7 @@
fi
CGM_LIBS_LINK='$(CUBIT_LDFLAGS) $(CUBIT_LIBS)'
CGM_LIBS_FILES='$(CUBIT_FILE)'
- CGM_LIBS_LTFLAGS='$(CUBIT_LTFLAGS)'
+ CGM_LIBS_LTFLAGS="$CGM_LIBS_LTFLAGS $CUBIT_LTFLAGS"
CUBIT_CGM="-DCUBIT_CGM"
dnl AC_DEFINE( HAVE_ACIS, "Have CGM ACIS Implementation" )
HAVE_ACIS_DEF=-DHAVE_ACIS
@@ -199,6 +199,8 @@
ACIS_LINK_FLAGS='-L$(ACIS_LIB_DIR)'
ACIS_HEALER="-DACIS_HEALER"
ACIS_INCLUDES="-I$ACIS_DIR/include"
+ ACIS_LTFLAGS="-R$ACIC_LIB_DIR"
+ CGM_LIBS_LTFLAGS="$CGM_LIBS_LTFLAGS $ACIS_LTFLAGS"
if test "x$GXX" = "xyes"; then
CPPFLAGS="$CPPFLAGS -isystem $ACIS_DIR/include"
fi
Modified: cgm/trunk/itaps/Makefile.am
--- cgm/trunk/itaps/Makefile.am 2008-10-29 19:22:27 UTC (rev 2182)
+++ cgm/trunk/itaps/Makefile.am 2008-10-29 19:44:57 UTC (rev 2183)
@@ -10,14 +10,8 @@
SUBDIRS = . $(SIDL_DIR)
-noinst_LTLIBRARIES = libiGeom.la
+lib_LTLIBRARIES = libiGeom.la
-if build_ACIS
- TEST_ACISPATH = -R$(ACIS_LIB_DIR)
-else
- TEST_ACISPATH =
-endif
libiGeom_la_includedir = $(includedir)
libiGeom_la_LIBADD = ../libcgm.la
@@ -49,9 +43,9 @@
check_PROGRAMS = $(TESTS)
testgeom_SOURCES = testgeom.cc
-testgeom_LDADD = ../libcgm.la
+testgeom_LDADD = libiGeom.la
testgeom_CPPFLAGS = $(CPPFLAGS) -DSRCDIR=$(srcdir)
-testgeom_LDFLAGS = $(TEST_ACISPATH)
+testgeom_LDFLAGS = $(CGM_LIBS_LTFLAGS)
# Automake doesn't seem to have a directory defined for
# platform-dependent data (or include) files. So put
More information about the cgma-dev
