[cgma-dev] r2181 - in cgm/trunk: . itaps
tautges at mcs.anl.gov
Wed Oct 29 13:50:15 CDT 2008
Author: tautges
Date: 2008-10-29 13:50:15 -0500 (Wed, 29 Oct 2008)
New Revision: 2181
Modified:
cgm/trunk/configure.in
cgm/trunk/itaps/Makefile.am
Log:
Adding a warning message when linking against CUBIT, saying you have to set LD_LIBRARY_PATH to point to cubit libs.
Changing case in one of the fields in the Makefile.
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2008-10-29 16:46:16 UTC (rev 2180)
+++ cgm/trunk/configure.in 2008-10-29 18:50:15 UTC (rev 2181)
@@ -410,3 +410,8 @@
AC_OUTPUT
+if test "x$CUBIT_DIR" != "xno" && test "x$CUBIT_DIR" != "x"; then
+ AC_MSG_WARN([Linking against Cubit-based CGM; you'll need to add Cubit's 'bin' directory
+ to your LD_LIBRARY_PATH before linking, or add -R (linux) or equivalent (non-linux)
+ to your link statement to link applications.])
+fi
Modified: cgm/trunk/itaps/Makefile.am
--- cgm/trunk/itaps/Makefile.am 2008-10-29 16:46:16 UTC (rev 2180)
+++ cgm/trunk/itaps/Makefile.am 2008-10-29 18:50:15 UTC (rev 2181)
@@ -20,7 +20,7 @@
libiGeom_la_includedir = $(includedir)
-libiGeom_la_libadd = $(top_builddir)/libcgm.la
+libiGeom_la_LIBADD = ../libcgm.la
INCLUDES = -I$(top_srcdir)/util \
-I$(top_srcdir)/geom \
More information about the cgma-dev
