[cgma-dev] r2179 - in cgm/trunk: . geom/virtual itaps
tautges at mcs.anl.gov
Wed Oct 29 11:22:37 CDT 2008
Author: tautges
Date: 2008-10-29 11:22:36 -0500 (Wed, 29 Oct 2008)
New Revision: 2179
Added:
cgm/trunk/itaps/iBase_f.h
cgm/trunk/itaps/iGeom-Defs.inc.in
cgm/trunk/itaps/iGeom_f.h
Modified:
cgm/trunk/configure.in
cgm/trunk/geom/virtual/HiddenEntitySet.cpp
cgm/trunk/itaps/Makefile.am
cgm/trunk/itaps/iGeom_protos.h
cgm/trunk/itaps/testgeom.cc
Log:
- Adding C++ link libs similar to how this is done in MOAB, so a non-C++ application can link with cgm
- Adding fortran stuff for iGeom
- Coupla fixes for problems exposed by gcc4.3
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2008-10-29 15:11:43 UTC (rev 2178)
+++ cgm/trunk/configure.in 2008-10-29 16:22:36 UTC (rev 2179)
@@ -26,6 +26,15 @@
+# Extract libtool config
+ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [CGM_CXX_LINKFLAGS])
+ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [CGM_CXX_LIBS])
+AC_SUBST(CGM_CXX_LINKFLAGS)
+AC_SUBST(CGM_CXX_LIBS)
# MPI OPTIONS
@@ -391,6 +400,7 @@
init/Makefile
cgm.make
itaps/Makefile
+ itaps/iGeom-Defs.inc
itaps/SIDL/Makefile
test/Makefile
cgm_apps/Makefile
Modified: cgm/trunk/geom/virtual/HiddenEntitySet.cpp
--- cgm/trunk/geom/virtual/HiddenEntitySet.cpp 2008-10-29 15:11:43 UTC (rev 2178)
+++ cgm/trunk/geom/virtual/HiddenEntitySet.cpp 2008-10-29 16:22:36 UTC (rev 2179)
@@ -29,7 +29,9 @@
#include "CompositeCoEdge.hpp"
#include "CompositeSurface.hpp"
+#include <algorithm>
HiddenEntitySet::~HiddenEntitySet()
std::vector<TopologyBridge*>::iterator iter;
Modified: cgm/trunk/itaps/Makefile.am
--- cgm/trunk/itaps/Makefile.am 2008-10-29 15:11:43 UTC (rev 2178)
+++ cgm/trunk/itaps/Makefile.am 2008-10-29 16:22:36 UTC (rev 2179)
@@ -40,7 +40,9 @@
iBase.h \
iGeom.h \
iBase_FCDefs.h \
- iGeom_protos.h
+ iGeom_protos.h \
+ iBase_f.h \
+ iGeom_f.h
TESTS = testgeom
@@ -63,14 +65,14 @@
# that the correct values are set (e.g. if someone does
# 'make prefix=/foo install', we don't know the correct install
# directory until we're doing the install.
-iGeom-Defs.inc: Makefile.am
- @echo "include $(cfgdir)/cgm.make" > $@
- @echo 'iGeom_LDFLAGS = $$(CGM_LDFLAGS)' >> $@
- @echo 'iGeom_LTFLAGS = $$(CGM_LTFLAGS)' >> $@
- @echo 'iGeom_LIBS = $$(CGM_LIBS)' >> $@
- @echo 'iGeom_DEFINES = $$(CGM_DEFINES)' >> $@
- @echo 'iGeom_INCLUDES = $$(CGM_INCLUDES)' >> $@
- @echo 'iGeom_CPPFLAGS = $$(CGM_CPPFLAGS)' >> $@
+install-data-hook:
+ echo "include $(libdir)/cgm.make" >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
+ echo 'IGEOM_LDFLAGS = $$(CGM_LDFLAGS) $$(IGEOM_CXX_LDFLAGS)' >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
+ echo 'IGEOM_LTFLAGS = $$(CGM_LTFLAGS)' >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
+ echo 'IGEOM_LIBS = $$(CGM_LIBS) $$(IGEOM_CXX_LIBS)' >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
+ echo 'IGEOM_DEFINES = $$(CGM_DEFINES)' >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
+ echo 'IGEOM_INCLUDES = $$(CGM_INCLUDES)' >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
+ echo 'IGEOM_CPPFLAGS = $$(CGM_CPPFLAGS)' >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
EXTRA_DIST = testgeom.sat
Added: cgm/trunk/itaps/iBase_f.h
--- cgm/trunk/itaps/iBase_f.h (rev 0)
+++ cgm/trunk/itaps/iBase_f.h 2008-10-29 16:22:36 UTC (rev 2179)
@@ -0,0 +1,113 @@
+#ifndef IBASE_F_H
+#define IBASE_F_H
+#define iBase_EntityHandle integer
+#define iBase_EntitySetHandle integer
+#define iBase_TagHandle integer
+#endif
+ integer iBase_VERTEX
+ integer iBase_EDGE
+ integer iBase_FACE
+ integer iBase_REGION
+ integer iBase_ALL_TYPES
+ parameter (iBase_VERTEX = 0)
+ parameter (iBase_EDGE = 1)
+ parameter (iBase_FACE = 2)
+ parameter (iBase_REGION = 3)
+ parameter (iBase_ALL_TYPES = 4)
+ integer iBase_NEW
+ integer iBase_ALREADY_EXISTED
+ integer iBase_CREATED_DUPLICATE
+ integer iBase_CREATION_FAILED
+ parameter (iBase_NEW = 0)
+ parameter (iBase_ALREADY_EXISTED = 1)
+ parameter (iBase_CREATED_DUPLICATE = 2)
+ parameter (iBase_CREATION_FAILED = 3)
+ integer iBase_SILENT
+ integer iBase_WARN_ONLY
+ integer iBase_THROW_ERROR
+ parameter (iBase_SILENT = 0)
+ parameter (iBase_WARN_ONLY = 1)
+ parameter (iBase_THROW_ERROR = 4)
+ integer iBase_SUCCESS
+ integer iBase_MESH_ALREADY_LOADED
+ integer iBase_NO_MESH_DATA
+ integer iBase_FILE_NOT_FOUND
+ integer iBase_FILE_WRITE_ERROR
+ integer iBase_NIL_ARRAY
+ integer iBase_BAD_ARRAY_SIZE
+ integer iBase_BAD_ARRAY_DIMENSION
+ integer iBase_INVALID_ENTITY_HANDLE
+ integer iBase_INVALID_ENTITY_COUNT
+ integer iBase_INVALID_ENTITY_TYPE
+ integer iBase_INVALID_ENTITY_TOPOLOGY
+ integer iBase_BAD_TYPE_AND_TOPO
+ integer iBase_ENTITY_CREATION_ERROR
+ integer iBase_INVALID_TAG_HANDLE
+ integer iBase_TAG_NOT_FOUND
+ integer iBase_TAG_ALREADY_EXISTS
+ integer iBase_TAG_IN_USE
+ integer iBase_INVALID_ENTITYSET_HANDLE
+ integer iBase_INVALID_ITERATOR_HANDLE
+ integer iBase_INVALID_ARGUMENT
+ integer iBase_MEMORY_ALLOCATION_FAILED
+ integer iBase_NOT_SUPPORTED
+ integer iBase_FAILURE
+ parameter (iBase_SUCCESS = 0)
+ parameter (iBase_MESH_ALREADY_LOADED = 1)
+ parameter (iBase_NO_MESH_DATA = 2)
+ parameter (iBase_FILE_NOT_FOUND = 3)
+ parameter (iBase_FILE_WRITE_ERROR = 4)
+ parameter (iBase_NIL_ARRAY = 5)
+ parameter (iBase_BAD_ARRAY_SIZE = 6)
+ parameter (iBase_BAD_ARRAY_DIMENSION = 7)
+ parameter (iBase_INVALID_ENTITY_HANDLE = 8)
+ parameter (iBase_INVALID_ENTITY_COUNT = 9)
+ parameter (iBase_INVALID_ENTITY_TYPE = 10)
+ parameter (iBase_INVALID_ENTITY_TOPOLOGY = 11)
+ parameter (iBase_BAD_TYPE_AND_TOPO = 12)
+ parameter (iBase_ENTITY_CREATION_ERROR = 13)
+ parameter (iBase_INVALID_TAG_HANDLE = 14)
+ parameter (iBase_TAG_NOT_FOUND = 15)
+ parameter (iBase_TAG_ALREADY_EXISTS = 16)
+ parameter (iBase_TAG_IN_USE = 17)
+ parameter (iBase_INVALID_ENTITYSET_HANDLE = 18)
+ parameter (iBase_INVALID_ITERATOR_HANDLE = 19)
+ parameter (iBase_INVALID_ARGUMENT = 20)
+ parameter (iBase_MEMORY_ALLOCATION_FAILED = 21)
+ parameter (iBase_NOT_SUPPORTED = 22)
+ parameter (iBase_FAILURE = 23)
+ integer iBase_BLOCKED
+ integer iBase_INTERLEAVED
+ integer iBase_UNDETERMINED
+ parameter (iBase_BLOCKED = 0)
+ parameter (iBase_INTERLEAVED = 1)
+ parameter (iBase_UNDETERMINED = 2)
+ integer iBase_INTEGER
+ integer iBase_DOUBLE
+ integer iBase_ENTITY_HANDLE
+ integer iBase_BYTES
+ parameter (iBase_INTEGER = 0)
+ parameter (iBase_DOUBLE = 1)
+ parameter (iBase_ENTITY_HANDLE = 2)
+ parameter (iBase_BYTES = 3)
Added: cgm/trunk/itaps/iGeom-Defs.inc.in
--- cgm/trunk/itaps/iGeom-Defs.inc.in (rev 0)
+++ cgm/trunk/itaps/iGeom-Defs.inc.in 2008-10-29 16:22:36 UTC (rev 2179)
@@ -0,0 +1,13 @@
+IGEOM_FC = @FC@
+IGEOM_FCFLAGS = @FCFLAGS@
+IGEOM_FCDEFS = @DEFS@
+IGEOM_CXX_LDFLAGS = @CGM_CXX_LINKFLAGS@
+IGEOM_CXX_LIBS = @CGM_CXX_LIBS@
+include @abs_builddir@/cgm.make
+IGEOM_LDFLAGS = $(CGM_LDFLAGS) $(IGEOM_CXX_LDFLAGS)
+IGEOM_LTFLAGS = $(CGM_LTFLAGS)
+IGEOM_LIBS = $(CGM_LIBS) $(IGEOM_CXX_LIBS)
+IGEOM_DEFINES = $(CGM_DEFINES)
+IGEOM_INCLUDES = $(CGM_INCLUDES)
+IGEOM_CPPFLAGS = $(CGM_CPPFLAGS)
Added: cgm/trunk/itaps/iGeom_f.h
--- cgm/trunk/itaps/iGeom_f.h (rev 0)
+++ cgm/trunk/itaps/iGeom_f.h 2008-10-29 16:22:36 UTC (rev 2179)
@@ -0,0 +1,11 @@
+#ifndef IGEOM_F_H
+#define IGEOM_F_H
+#define iGeom_Instance integer
+#define iGeom_EntityIterator integer
+#define iGeom_EntityArrIterator integer
+#endif
+#include "iBase_f.h"
Modified: cgm/trunk/itaps/iGeom_protos.h
--- cgm/trunk/itaps/iGeom_protos.h 2008-10-29 15:11:43 UTC (rev 2178)
+++ cgm/trunk/itaps/iGeom_protos.h 2008-10-29 16:22:36 UTC (rev 2179)
@@ -72,6 +72,8 @@
#define iGeom_createTorus FC_FUNC_(igeom_createtorus, IGEOM_CREATETORUS)
#define iGeom_createCylinder FC_FUNC_(igeom_createcylinder, IGEOM_CREATECYLINDER)
#define iGeom_createBrick FC_FUNC_(igeom_createbrick, IGEOM_CREATEBRICK)
+#define iGeom_createSphere FC_FUNC_(igeom_createsphere, IGEOM_CREATESPHERE)
+#define iGeom_createPrism FC_FUNC_(igeom_createprism, IGEOM_CREATEPRISM)
#define iGeom_deleteEnt FC_FUNC_(igeom_deleteent, IGEOM_DELETEENT)
#define iGeom_sweepEntAboutAxis FC_FUNC_(igeom_sweepentaboutaxis, IGEOM_SWEEPENTABOUTAXIS)
#define iGeom_copyEnt FC_FUNC_(igeom_copyent, IGEOM_COPYENT)
Modified: cgm/trunk/itaps/testgeom.cc
--- cgm/trunk/itaps/testgeom.cc 2008-10-29 15:11:43 UTC (rev 2178)
+++ cgm/trunk/itaps/testgeom.cc 2008-10-29 16:22:36 UTC (rev 2179)
@@ -18,6 +18,7 @@
#include "iGeom.h"
#include <iostream>
#include <set>
#include <vector>
#include <iterator>
@@ -433,9 +434,9 @@
bool gentityset_test(iGeom_Instance geom, bool /*multiset*/, bool /*ordered*/)
int num_type = 4;
+ iBase_EntitySetHandle ges_array[4];
+ int number_array[4];
int num_all_gentities_super = 0;
- iBase_EntitySetHandle ges_array[num_type];
- int number_array[num_type];
int ent_type = iBase_VERTEX;
int err;
More information about the cgma-dev
