[cgma-dev] r2282 - cgm/trunk/itaps
    kraftche at mcs.anl.gov
    Tue Nov 25 09:51:46 CST 2008
Author: kraftche
Date: 2008-11-25 09:51:46 -0600 (Tue, 25 Nov 2008)
New Revision: 2282
Modified:
   cgm/trunk/itaps/iGeom_CGMA.cc
Log:
only initialize CGM once
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc	2008-11-24 19:08:50 UTC (rev 2281)
+++ cgm/trunk/itaps/iGeom_CGMA.cc	2008-11-25 15:51:46 UTC (rev 2282)
@@ -216,7 +216,23 @@
 static bool iGeom_is_face_degenerate( RefFace* face );
+static CubitStatus init_cgm( const std::string& engine )
+  CubitStatus status;
+  if (engine.empty())
+    status = InitCGMA::initialize_cgma();
+  else
+    status = InitCGMA::initialize_cgma( engine.c_str() );
+// sometimes can't have following, depending on CGM version
+  // CGMApp::instance()->attrib_manager()->silent_flag(true);
+  CGMApp::instance()->attrib_manager()->auto_flag(true);
+  return status;
 extern "C" {
 void iGeom_getDescription( iGeom_Instance geom,
@@ -253,19 +269,12 @@
     free(opt);
-  CubitStatus status;
-  if (engine.empty())
-    status = InitCGMA::initialize_cgma();
-  else
-    status = InitCGMA::initialize_cgma( engine.c_str() );
+    // initialize static var with result so that call happens only once
+  static const CubitStatus status = init_cgm( engine );
+    // but check the result for every call
   if (CUBIT_SUCCESS != status)
     RETURN (iBase_FAILURE);
-// sometimes can't have following, depending on CGM version
-  // CGMApp::instance()->attrib_manager()->silent_flag(true);
-  CGMApp::instance()->attrib_manager()->auto_flag(true);
     // return the tagmanager as the instance
   *instance_out = &CGMTagManager::instance();
   RETURN(iBase_SUCCESS);
More information about the cgma-dev
