[cgma-dev] r2281 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Mon Nov 24 13:08:50 CST 2008
Author: janehu
Date: 2008-11-24 13:08:50 -0600 (Mon, 24 Nov 2008)
New Revision: 2281
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Make sure no degenerated curve or surface will generate from populate_topology_bridge. Fix for user reported bug.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-11-24 17:27:15 UTC (rev 2280)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-11-24 19:08:50 UTC (rev 2281)
@@ -1318,6 +1318,8 @@
Surface* face =
populate_topology_bridge(topo_face, build_body);
+ if(!face)
+ continue;
OCCSurface *occ_surface = CAST_TO(face, OCCSurface);
CubitBoolean exist = CUBIT_FALSE;
OCCCoFace * coface = NULL;
@@ -1364,6 +1366,12 @@
*poface = aShape;
surface = new OCCSurface(poface);
+ double tol = get_sme_resabs_tolerance();
+ if(surface->measure() < tol * tol)
+ delete surface;
+ return (Surface*) NULL;
if(PRINT_RESULT)
PRINT_INFO("Adding faces.\n");
iTotalTBCreated++;
@@ -1434,6 +1442,8 @@
for (Ex.Init(aShape); Ex.More(); Ex.Next())
Curve* curve = populate_topology_bridge(Ex.Current());
+ if(!curve)
+ continue;
OCCCurve *occ_curve = CAST_TO(curve, OCCCurve);
DLIList<OCCLoop*> loops = occ_curve->loops();
@@ -1524,6 +1534,11 @@
*poedge = aShape;
iTotalTBCreated++;
curve = new OCCCurve(poedge);
+ if(curve->measure() < get_sme_resabs_tolerance())
+ delete curve;
+ return (Curve*) NULL;
OCCMap->Bind(*poedge, iTotalTBCreated);
OccToCGM->insert(valType(iTotalTBCreated,
(TopologyBridge*)curve));
More information about the cgma-dev
