[cgma-dev] r2279 - in cgm/trunk: geom/OCC test
janehu at mcs.anl.gov
Mon Nov 24 11:24:24 CST 2008
Author: janehu
Date: 2008-11-24 11:24:24 -0600 (Mon, 24 Nov 2008)
New Revision: 2279
Modified:
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/test/makept.cpp
cgm/trunk/test/modify.cpp
Log:
Modified to correctly tessellate a curve.
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-11-24 16:03:10 UTC (rev 2278)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-11-24 17:24:24 UTC (rev 2279)
@@ -31,6 +31,7 @@
#include "Poly_Triangle.hxx"
#include "BRepAlgoAPI_BooleanOperation.hxx"
#include "Handle_Poly_Triangulation.hxx"
+#include "GCPnts_TangentialDeflection.hxx"
#include "BRepAdaptor_Curve.hxx"
#include "BndLib_Add3dCurve.hxx"
#include "Poly_Polygon3D.hxx"
@@ -357,33 +358,31 @@
if (!Topo_Edge)
return CUBIT_FAILURE;
- //do triangulation
- double deflection = 0.01;
- double angle = 0.5;
+ //do tessellation
+ double deflection = 0.2;
+ double angle = 0.2;
BRepAdaptor_Curve acurve(*Topo_Edge);
- Bnd_Box aBox;
- BndLib_Add3dCurve::Add(acurve, Precision::Approximation(), aBox);
- BRepMesh_FastDiscret *myMesh =
- new BRepMesh_FastDiscret(deflection, *Topo_Edge, aBox, angle, Standard_True, Standard_True);
+ GCPnts_TangentialDeflection *myMesh =
+ new GCPnts_TangentialDeflection(acurve, angle, deflection);
if (myMesh == NULL)
- PRINT_ERROR("Can't get triangulation representation for this curve.\n");
+ PRINT_ERROR("Can't tessellate for this curve.\n");
- num_points = myMesh->NbVertices();
+ num_points = myMesh->NbPoints();
//! Note: If the polygon is closed, the point of closure is
//! repeated at the end of its table of nodes. Thus, on a closed
- //! triangle the function NbNodes returns 4.
+ //! triangle the function NbNodes returns 4?
GPoint *gPnts= new GPoint[num_points];
for (int i = 1; i <= num_points ; i ++)
- gp_Pnt gp_pnt = myMesh->Pnt(i);
+ gp_Pnt gp_pnt = myMesh->Value(i);
GPoint gPnt;
gPnt.x = gp_pnt.X();
gPnt.y = gp_pnt.Y();
gPnt.z = gp_pnt.Z();
- gPnts[i] = gPnt;
+ gPnts[i-1] = gPnt;
gMem->replace_point_list( gPnts, num_points, num_points );
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2008-11-24 16:03:10 UTC (rev 2278)
+++ cgm/trunk/test/makept.cpp 2008-11-24 17:24:24 UTC (rev 2279)
@@ -29,6 +29,7 @@
#include "OCCBody.hpp"
#include "OCCSurface.hpp"
#include "OCCCurve.hpp"
+#include "OCCDrawTool.hpp"
#ifndef SRCDIR
# define SRCDIR .
@@ -114,6 +115,26 @@
OCCQueryEngine::instance();
OCCModifyEngine::instance();
+ //Create sphere
+ RefEntity* sphereEnt= GeometryModifyTool::instance()->sphere(1.5);
+ sphereEnt->entity_name("sphere");
+ TopoDS_CompSolid* objOCC;
+ Body* tmpBd = GeometryQueryTool::instance()->get_first_body();
+ DLIList<RefVertex*> vertices;
+ tmpBd->ref_vertices(vertices);
+ DLIList<RefEdge*> ref_edges;
+ tmpBd->ref_edges(ref_edges);
+ for(int i = 0; i < ref_edges.size(); i++)
+ vertices.clean_out();
+ ref_edges.get()->ref_vertices(vertices);
+ ref_edges.get_and_step()->measure();
+ BodySM* tmpBdSM = tmpBd->get_body_sm_ptr();
+ objOCC = ( (OCCBody*) tmpBdSM )->get_TopoDS_Shape(); //Opencascade Object
+ OCCDrawTool::instance()->draw_TopoDS_Shape(objOCC, 200);
// Read in the geometry from files specified on the command line
const char *argv = "66_shaver3.brep";
CubitStatus status = read_geometry(1, &argv);
@@ -417,7 +438,7 @@
gti->delete_RefEntity( free_entities.get_and_step());
- DLIList<RefEdge *> ref_edges;
+ ref_edges.clean_out();
gti->ref_edges(ref_edges);
//make a new refedge out of existing refedge.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2008-11-24 16:03:10 UTC (rev 2278)
+++ cgm/trunk/test/modify.cpp 2008-11-24 17:24:24 UTC (rev 2279)
@@ -781,6 +781,17 @@
n = new_bodies.get()->num_ref_faces(); //n = 10
d = new_bodies.get()->measure(); //d = 72.3618
+ bodies.clean_out();
+ gti->bodies(bodies); //bodies.size() = 2
+ free_entities.clean_out();
+ gti->get_free_ref_entities(free_entities); //free_entities.size() = 0
+ assert(free_entities.size() == 0);
+ //delete hollowed body and keep sweep_face.
+ gti->delete_Body(new_bodies);
DLIList<RefEntity*> refentities;
refentities.append(sweep_face);
RefFace* draft_face = gmti->make_RefFace(sweep_face);
More information about the cgma-dev
