[cgma-dev] r2265 - cgm/trunk/test
janehu at mcs.anl.gov janehu at mcs.anl.gov
Mon Nov 17 11:36:51 CST 2008
Author: janehu
Date: 2008-11-17 11:36:51 -0600 (Mon, 17 Nov 2008)
New Revision: 2265
Modified:
   cgm/trunk/test/hollow_acis.cpp
   cgm/trunk/test/makept.cpp
   cgm/trunk/test/modify.cpp
   cgm/trunk/test/r_w.cpp
   cgm/trunk/test/sheet.cpp
   cgm/trunk/test/test_occ.cpp
   cgm/trunk/test/webcut.cpp
Log:
Remove unnessecary warnings from compiling.
Modified: cgm/trunk/test/hollow_acis.cpp
--- cgm/trunk/test/hollow_acis.cpp	2008-11-15 09:37:07 UTC (rev 2264)
+++ cgm/trunk/test/hollow_acis.cpp	2008-11-17 17:36:51 UTC (rev 2265)
@@ -53,7 +53,7 @@
     // Initialize the GeometryTool
   CGMApp::instance()->startup( argc, argv );
-  GeometryQueryTool *gti = GeometryQueryTool::instance();
+  GeometryQueryTool::instance();
   AcisQueryEngine::instance();
   AcisModifyEngine::instance();
@@ -85,7 +85,7 @@
 /// Arguments: file name(s) of geometry files in which to look
-CubitStatus read_geometry(int num_files, char **argv)
+CubitStatus read_geometry(int num_files, const char **argv)
   CubitStatus status = CUBIT_SUCCESS;
@@ -93,8 +93,6 @@
   int i;
     // For each file, open and read the geometry
-  FILE *file_ptr;
   PRINT_SEPARATOR;
   for (i = 0; i < num_files; i++) {
@@ -114,7 +112,7 @@
   GeometryModifyTool *gmti = GeometryModifyTool::instance();
   // Read in the geometry from files specified on the command line
-  char *argv = STRINGIFY(SRCDIR) "/hollow.sat";
+  const char *argv = STRINGIFY(SRCDIR) "/hollow.sat";
   CubitStatus status = read_geometry(1, &argv);
   if (status == CUBIT_FAILURE) exit(1);
   else if (gti->num_bodies() == 0) {
@@ -149,6 +147,6 @@
   //Destroyed volume(s): 1
   n = new_bodies.get()->num_ref_faces(); //n = 9
   d = new_bodies.get()->measure(); //d = 72.4074
-  return CUBIT_SUCCESS;
+  return stat ;
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp	2008-11-15 09:37:07 UTC (rev 2264)
+++ cgm/trunk/test/makept.cpp	2008-11-17 17:36:51 UTC (rev 2265)
@@ -39,7 +39,7 @@
 #define SRCPATH STRINGIFY(SRCDIR) "/"
 // forward declare some functions used and defined later
-CubitStatus read_geometry(int, char **);
+CubitStatus read_geometry(int, const char **, bool local = false);
 CubitStatus make_Point();
 // macro for printing a separator line
 #define PRINT_SEPARATOR   PRINT_INFO("=======================================\n");
@@ -84,7 +84,7 @@
+CubitStatus read_geometry(int num_files, const char **argv, bool local)
@@ -94,7 +94,7 @@
   PRINT_SEPARATOR;
-    std::string filename( SRCPATH );
+    std::string filename( local ? "./" : SRCPATH );
     filename += argv[i];
     status = gti->import_solid_model(filename.c_str(), "OCC");
     if (status != CUBIT_SUCCESS) {
@@ -115,16 +115,16 @@
   OCCModifyEngine::instance();
-  char *argv = "./66_shaver3.brep";
+  const char *argv = "66_shaver3.brep";
-  argv = "./62_shaver1.brep";
-  status = read_geometry(1, &argv);
+  const char *argv2 = "62_shaver1.brep";
+  status = read_geometry(1, &argv2);
-  argv = "./72_shaver6.brep";
+  const char *argv3 = "72_shaver6.brep";
+  status = read_geometry(1, &argv3);
   // test create a Compound body.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp	2008-11-15 09:37:07 UTC (rev 2264)
+++ cgm/trunk/test/modify.cpp	2008-11-17 17:36:51 UTC (rev 2265)
@@ -46,7 +46,7 @@
-CubitStatus read_geometry(int, char **, bool local = false);
@@ -91,7 +91,7 @@
-CubitStatus read_geometry(int num_files, char **argv, bool local)
@@ -116,7 +116,6 @@
-  RefEntityFactory* ref = RefEntityFactory::instance();
@@ -176,8 +175,7 @@
   //create solid from surfaces
-  GeometryModifyEngine *gme = gmti->get_engine(occ_surfaces.get());
-  BodySM* stitched_body = NULL;
+  //GeometryModifyEngine *gme = gmti->get_engine(occ_surfaces.get());
   DLIList<Body*> new_bodies;
   gmti->create_solid_bodies_from_surfs(face_list, new_bodies);
   //Created volume(s): 9
@@ -205,7 +203,7 @@
-  char *argv = "stitch.occ";
+  const char *argv = "stitch.occ";
   CubitStatus status = read_geometry(1, &argv, true);
   //Read in 1 volume.
@@ -229,8 +227,12 @@
   Body* tool_body = gmti->cylinder(10, 1, 1, 1);
   double d;
   d = from_body->measure(); //d = 219.91
+  bodysm = from_body->get_body_sm_ptr();
+  CubitVector center1;
+  CAST_TO(bodysm, OCCBody)->mass_properties(center1, d);
   d = from_body2->measure();//d = 67.02
   d = tool_body->measure(); //d = 31.41
   // test for sphere making
   Body* test_body = gmti->sphere(5);
@@ -522,9 +524,6 @@
   gti->get_free_ref_entities(free_entities);
   assert(free_entities.size() == 0);
-  OCCQueryEngine* oqe = OCCQueryEngine::instance();
-  DLIList <OCCBody* > *occ_bodies = oqe->BodyList;
   from_body  = gmti->brick(4, 4, 4);
   CubitVector v_move9(2,5,2);
   gti->translate(from_body,v_move9);
@@ -747,7 +746,6 @@
   RefFace* draft_face = gmti->make_RefFace(sweep_face);
   RefFace* perp_face = gmti->make_RefFace(sweep_face);
   RefFace* rotate_face = gmti->make_RefFace(sweep_face);
-  RefFace* rotate_face2 = gmti->make_RefFace(sweep_face);
   gmti->sweep_translational(refentities, v_move8, 0, 1, CUBIT_FALSE, CUBIT_FALSE);
   body = CAST_TO(refentities.get(), Body);
   d = body->measure();
Modified: cgm/trunk/test/r_w.cpp
--- cgm/trunk/test/r_w.cpp	2008-11-15 09:37:07 UTC (rev 2264)
+++ cgm/trunk/test/r_w.cpp	2008-11-17 17:36:51 UTC (rev 2265)
@@ -91,7 +91,7 @@
@@ -125,7 +125,7 @@
   DLIList<RefEntity*>  free_entities;
-  char *argv = "stitch.occ_name";
+  const char *argv = "stitch.occ_name";
   CubitStatus status = read_geometry(1, &argv, false);
   //Read in 2 volumes.
@@ -152,8 +152,8 @@
       gti->delete_RefEntity( free_entities.get_and_step());
-  argv = "beforesub.occ";
-  status = read_geometry(1, &argv, true);
+  const char *argv1 = "beforesub.occ";
+  status = read_geometry(1, &argv1, true);
@@ -197,8 +197,8 @@
   assert(free_entities.size() ==0);
-  argv = "unite1.occ";
-  status = read_geometry(1, &argv, false);
+  const char *argv2 = "unite1.occ";
+  status = read_geometry(1, &argv2, false);
@@ -223,8 +223,8 @@
+  const char *argv3 = "unite1.occ";
+  status = read_geometry(1, &argv3, false);
@@ -253,8 +253,8 @@
-  argv = "unite4.occ";
+  const char *argv4 = "unite4.occ";
+  status = read_geometry(1, &argv4, false);
@@ -279,8 +279,7 @@
Modified: cgm/trunk/test/sheet.cpp
--- cgm/trunk/test/sheet.cpp	2008-11-15 09:37:07 UTC (rev 2264)
+++ cgm/trunk/test/sheet.cpp	2008-11-17 17:36:51 UTC (rev 2265)
@@ -36,17 +36,6 @@
   CubitStatus result = InitCGMA::initialize_cgma();
   if (CUBIT_SUCCESS != result) return 1;
-  GeometryQueryEngine* const gqe_list[] = {
-#ifdef HAVE_ACIS
-//    AcisQueryEngine::instance(),
-#endif
-#ifdef HAVE_OCC
-//    OCCQueryEngine::instance(),
-#endif
-    NULL
   GeometryModifyEngine* const gme_list[] = {
 #ifdef HAVE_ACIS
 //    AcisModifyEngine::instance(),
Modified: cgm/trunk/test/test_occ.cpp
--- cgm/trunk/test/test_occ.cpp	2008-11-15 09:37:07 UTC (rev 2264)
+++ cgm/trunk/test/test_occ.cpp	2008-11-17 17:36:51 UTC (rev 2265)
@@ -42,7 +42,7 @@
-  GeometryModifyTool *gmti = GeometryModifyTool::instance();
+  GeometryModifyTool::instance();
   assert(gti);
Modified: cgm/trunk/test/webcut.cpp
--- cgm/trunk/test/webcut.cpp	2008-11-15 09:37:07 UTC (rev 2264)
+++ cgm/trunk/test/webcut.cpp	2008-11-17 17:36:51 UTC (rev 2265)
@@ -64,7 +64,7 @@
@@ -107,7 +107,7 @@
@@ -115,8 +115,6 @@
   int i;
-  FILE *file_ptr;
   PRINT_SEPARATOR;
@@ -136,7 +134,7 @@
-  char *argv = STRINGIFY(SRCDIR) "/model2.sat";
+  const char *argv = STRINGIFY(SRCDIR) "/model2.sat";
@@ -191,7 +189,7 @@
@@ -242,7 +240,7 @@
@@ -296,7 +294,7 @@
-  char *argv = STRINGIFY(SRCDIR) "/huge.sat";
+  const char *argv = STRINGIFY(SRCDIR) "/huge.sat";
@@ -362,7 +360,7 @@
-  char *argv = STRINGIFY(SRCDIR) "/model3.sat";
+  const char *argv = STRINGIFY(SRCDIR) "/model3.sat";
@@ -422,7 +420,7 @@
@@ -493,7 +491,7 @@
-  char *argv = STRINGIFY(SRCDIR) "/model4.sat";
+  const char *argv = STRINGIFY(SRCDIR) "/model4.sat";
@@ -550,7 +548,7 @@
-  char *argv = STRINGIFY(SRCDIR) "/model5.sat";
+  const char *argv = STRINGIFY(SRCDIR) "/model5.sat";
@@ -597,7 +595,7 @@
-  char *argv = STRINGIFY(SRCDIR) "/model7.sat";
+  const char *argv = STRINGIFY(SRCDIR) "/model7.sat";
@@ -648,7 +646,7 @@
-  char *argv = STRINGIFY(SRCDIR) "/model6.sat";
+  const char *argv = STRINGIFY(SRCDIR) "/model6.sat";
@@ -698,7 +696,7 @@
@@ -758,7 +756,7 @@
More information about the cgma-dev mailing list
