[cgma-dev] r2220 - cgm/trunk/test
janehu at mcs.anl.gov
Thu Nov 6 15:55:19 CST 2008
Author: janehu
Date: 2008-11-06 15:55:18 -0600 (Thu, 06 Nov 2008)
New Revision: 2220
Modified:
cgm/trunk/test/modify.cpp
Log:
updated modify.cpp according to creation changes.
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2008-11-06 21:54:18 UTC (rev 2219)
+++ cgm/trunk/test/modify.cpp 2008-11-06 21:55:18 UTC (rev 2220)
@@ -144,7 +144,7 @@
DLIList<Surface*> surface_list;
test_face = gmti->make_RefFace(ref_faces.get());
surface_list.append(test_face->get_surface_ptr());
- CubitVector v_test(0,5,5);
+ CubitVector v_test(-5,0,0);
CubitVector normal;
normal = test_face->normal_at(v_test); //(-1,0,0)
ome->flip_normals(surface_list);
@@ -266,10 +266,12 @@
int width = 10; //we can also test for width < 10
from_body2 = gmti->brick(4, width, 4);
tool_body = gmti->brick(10, 10, 10);
- CubitVector v_move(1,0,-1);
- CubitVector v_movei(0,0,1);
+ CubitVector v_move(3,width/2.0,1);
+ CubitVector v_movei(5,5,6);
+ CubitVector v_moveii(5,5,5);
gti->translate(from_body2,v_move);
gti->translate(tool_body, v_movei);
+ gti->translate(from_body, v_moveii);
DLIList<Body*> from_bodies;
from_bodies.append(from_body);
new_bodies.clean_out();
@@ -286,8 +288,8 @@
CUBIT_TRUE, CUBIT_FALSE);
//Created volume(s): 22, 23
//Destroyed volume(s): 19, 21
- d = new_bodies.step_and_get()->measure();
- v = new_bodies.get()->center_point();
+ d = new_bodies.step_and_get()->measure(); //d = 50
+ v = new_bodies.get()->center_point(); //v = (7.5, 5, .05)
int n = new_bodies.get()->num_ref_faces();
// n = 6
//new bodies has 2 bodies, one has a volume = 10 and the other has a
@@ -306,8 +308,10 @@
from_body = gmti->brick(10, 10, 10);
tool_body = gmti->brick(11, 1, 1);
- CubitVector v_move4(0,1,-1);
+ CubitVector v_move4(5,6,4);
+ CubitVector v_move4i(5.5,0.5,0.5);
gti->translate(from_body,v_move4);
+ gti->translate(tool_body,v_move4i);
Body* cp_from_body = gmti->copy_body(from_body);
Body* cp_from_body2 = gmti->copy_body(cp_from_body);
@@ -399,6 +403,8 @@
//test for shell body subtract.
tool_body = gmti->brick(1, 1, 1);
+ CubitVector new_move(0.5,0.5,0.5);
+ gti->translate(tool_body,new_move);
//just need two surfaces.
DLIList<RefFace*> reffaces;
tool_body->ref_faces(reffaces);
@@ -446,7 +452,7 @@
tool_body = gmti->brick(4, 4, 4);
- CubitVector v_move3(0,1,0);
+ CubitVector v_move3(2,3,2);
gti->translate(tool_body,v_move3);
Body* copy_tool_body = gmti->copy_body(tool_body);
Body* copy_tool_body2 = gmti->copy_body(tool_body);
@@ -493,9 +499,10 @@
//test solid solid imprint
- CubitVector v_move5(0,0.5,0);
+ CubitVector v_move5(2,2.5,2);
gti->translate(tool_body,v_move5);
from_body = gmti->brick(1,1,1);
+ gti->translate(from_body, new_move);
from_bodies.clean_out();
@@ -519,11 +526,12 @@
DLIList <OCCBody* > *occ_bodies = oqe->BodyList;
from_body = gmti->brick(4, 4, 4);
- CubitVector v_move9(0,3,0);
+ CubitVector v_move9(2,5,2);
gti->translate(from_body,v_move9);
ref_faces.clean_out();
from_body->ref_faces(ref_faces);
+ gti->translate(tool_body, v_move4i);
ref_edges.clean_out();
tool_body->ref_edges(ref_edges);
@@ -546,6 +554,9 @@
//1. from body is the commom body, no update
+ CubitVector new_move2(2, 2, 2);
+ gti->translate(tool_body, new_move2);
@@ -556,8 +567,7 @@
//2. common body is part of from body, update the correponding face
- CubitVector v_move7(0,0.5,0);
- gti->translate(tool_body,v_move7);
+ gti->translate(tool_body,v_move5);
@@ -569,8 +579,9 @@
//3. there's no common body, from body is deleted or kept depending on
//keep-old flag.
+ CubitVector v_m(0, 0.5, 0);
+ gti->translate(tool_body,v_m);
@@ -595,7 +606,8 @@
//test chop operation
from_bodies.append(tool_body);
@@ -619,7 +631,9 @@
//test chop 2
tool_body = gmti->brick(1,1,1);
+ CubitVector v_move7(0.5, 1, 0.5);
+ gti->translate(from_body, new_move2);
@@ -643,8 +657,9 @@
//test unite 1
@@ -665,9 +680,10 @@
gti->get_free_ref_entities(free_entities); //free_entities.size() = 0
assert(free_entities.size() == 0);
//test unite 2
- tool_body = gmti->brick(4, 4,4);
+ tool_body = gmti->brick(4, 4, 4);
@@ -693,10 +709,10 @@
//test making thick body.
from_body = gmti->cylinder(10, 4, 4, 4);
tool_body = gmti->cylinder(5,1,1,1);
- // v = from_body->center_point();
- //v = tool_body->center_point();
- CubitVector v_move8(0,0,10);
+ CubitVector v_move8(0,0,12.5);
+ CubitVector v_move8i(0 , 0 , 5);
gti->translate(tool_body,v_move8);
+ gti->translate(from_body, v_move8i);
@@ -735,10 +751,11 @@
gmti->sweep_translational(refentities, v_move8, 0, 1, CUBIT_FALSE, CUBIT_FALSE);
body = CAST_TO(refentities.get(), Body);
d = body->measure();
- //d = 31.4159
+ //d = 39.2699
refentities.clean_out();
refentities.append(draft_face);
- gmti->sweep_translational(refentities, v_move8, 0.087, 1, CUBIT_FALSE, CUBIT_FALSE);
+ CubitVector v_move8ii(0,0,10);
+ gmti->sweep_translational(refentities, v_move8ii, 0.087, 1, CUBIT_FALSE, CUBIT_FALSE);
//d = 66.3676 theoretical calculation is 66.7833, error 0.62%
@@ -746,7 +763,7 @@
body->ref_edges(edges);
refentities.append(edges.get());
//d = area = 90.1292 theoretica calculation is 90.5754, error 0.49%
More information about the cgma-dev
