[cgma-dev] r2217 - in cgm/trunk: init itaps
kraftche at mcs.anl.gov
Wed Nov 5 13:25:22 CST 2008
Author: kraftche
Date: 2008-11-05 13:25:21 -0600 (Wed, 05 Nov 2008)
New Revision: 2217
Modified:
cgm/trunk/init/InitCGMA.cpp
cgm/trunk/init/InitCGMA.hpp
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
o Remove InitCGMA::initialize_engine(const char*).
o Make InitCGMA::initialize_cgma() initialize all engines
o Add optional "const char* default_engine_name" argument to
Modified: cgm/trunk/init/InitCGMA.cpp
--- cgm/trunk/init/InitCGMA.cpp 2008-11-05 18:36:37 UTC (rev 2216)
+++ cgm/trunk/init/InitCGMA.cpp 2008-11-05 19:25:21 UTC (rev 2217)
@@ -3,6 +3,8 @@
#include "VirtualQueryEngine.hpp"
#include "FacetQueryEngine.hpp"
#include "FacetModifyEngine.hpp"
+#include "GeometryQueryTool.hpp"
+#include "GeometryModifyTool.hpp"
#include <ctype.h>
@@ -48,59 +50,56 @@
-CubitStatus InitCGMA::initialize_cgma()
+CubitStatus InitCGMA::initialize_cgma( const char* default_engine_name )
CGMApp::instance()->startup( 0, NULL );
- return CUBIT_SUCCESS;
+ GeometryModifyEngine* default_engine = 0;
-CubitStatus InitCGMA::initialize_engine( const char* name )
- if (!name) {
-#if defined(CUBIT_CGM) || defined(ACIS)
- name = "ACIS";
-#elif defined (HAVE_OCC)
- name = "OCC";
-#else
- PRINT_INFO("No engine to default to in InitCGMA");
- return CUBIT_FAILURE;
-#endif
- if (streq_nocase(name,"ACIS")) {
-#ifdef CUBIT_CGM
+#if defined(CUBIT_CGM) || defined(HAVE_ACIS)
+ GeometryModifyEngine* acis_engine_ptr;
+ #ifdef CUBIT_CGM
if (!AcisQueryEngine::instance_)
AcisQueryEngine::instance_ = new (reinterpret_cast<AcisQueryEngine*>(new dummym)) AcisQueryEngine;
if (!AcisModifyEngine::instance_)
AcisModifyEngine::instance_ = new (reinterpret_cast<AcisModifyEngine*>(new dummym)) AcisModifyEngine;
-#elif defined (HAVE_ACIS)
+ acis_engine_ptr = AcisModfyEngine::instance();
+ #else
AcisQueryEngine::instance();
AcisModifyEngine::instance();
-#else
+ acis_engine_ptr = AcisModifyEngine::instance();
+ #endif
+ if (default_engine_name && streq_nocase("ACIS",default_engine_name))
+ default_engine = acis_engine_ptr;
#endif
- else if (streq_nocase(name,"VIRTUAL") || streq_nocase(name,"vg")) {
- VirtualQueryEngine::instance();
#ifdef HAVE_OCC
- else if (streq_nocase(name,"OCC")) {
- OCCQueryEngine::instance();
- OCCModifyEngine::instance();
+ OCCQueryEngine::instance();
+ OCCModifyEngine::instance();
+ if (default_engine_name && streq_nocase("OCC",default_engine_name))
+ default_engine = OCCModifyEngine::instance();
#endif
- else if (streq_nocase(name,"facet")) {
- FacetQueryEngine::instance();
- FacetModifyEngine::instance();
+ FacetQueryEngine::instance();
+ FacetModifyEngine::instance();
+ VirtualQueryEngine::instance();
+ if (default_engine_name && streq_nocase("FACET",default_engine_name))
+ default_engine = FacetModifyEngine::instance();
+ if(default_engine_name) {
+ if (!default_engine) {
+ PRINT_ERROR("Invalid or unsupported engine: '%s'\n", default_engine_name);
+ return CUBIT_FAILURE;
+ CubitStatus rval;
+ rval = GeometryModifyTool::instance()->set_default_gme(default_engine);
+ if (CUBIT_SUCCESS != rval)
+ return rval;
+ rval = GeometryQueryTool::instance()->set_default_gqe(default_engine->get_gqe());
+ return rval;
- else {
Modified: cgm/trunk/init/InitCGMA.hpp
--- cgm/trunk/init/InitCGMA.hpp 2008-11-05 18:36:37 UTC (rev 2216)
+++ cgm/trunk/init/InitCGMA.hpp 2008-11-05 19:25:21 UTC (rev 2217)
@@ -7,9 +7,7 @@
public:
- static CubitStatus initialize_cgma();
- static CubitStatus initialize_engine( const char* name );
+ static CubitStatus initialize_cgma( const char* default_engine_name = 0 );
#endif
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2008-11-05 18:36:37 UTC (rev 2216)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2008-11-05 19:25:21 UTC (rev 2217)
@@ -233,10 +233,7 @@
int* err,
const int options_size)
- CubitStatus status = InitCGMA::initialize_cgma();
- if (CUBIT_SUCCESS != status) RETURN(iBase_FAILURE);
- // scan options for engine to use
+ // scan options for default engine option
std::string engine;
if (options && options_size) {
char* opt = (char*)malloc( options_size + 1 );
@@ -256,7 +253,14 @@
free(opt);
- InitCGMA::initialize_engine(engine.empty() ? 0 : engine.c_str());
+ CubitStatus status;
+ if (engine.empty())
+ status = InitCGMA::initialize_cgma();
+ else
+ status = InitCGMA::initialize_cgma( engine.c_str() );
+ if (CUBIT_SUCCESS != status)
+ RETURN (iBase_FAILURE);
// sometimes can't have following, depending on CGM version
// CGMApp::instance()->attrib_manager()->silent_flag(true);
More information about the cgma-dev
