[cgma-dev] r2211 - cgm/trunk/init
kraftche at mcs.anl.gov
Wed Nov 5 12:19:29 CST 2008
Author: kraftche
Date: 2008-11-05 12:19:29 -0600 (Wed, 05 Nov 2008)
New Revision: 2211
Modified:
cgm/trunk/init/InitCGMA.cpp
Log:
Choose default engine if initialize_engine is called with NULL engine string
Modified: cgm/trunk/init/InitCGMA.cpp
--- cgm/trunk/init/InitCGMA.cpp 2008-11-05 15:30:24 UTC (rev 2210)
+++ cgm/trunk/init/InitCGMA.cpp 2008-11-05 18:19:29 UTC (rev 2211)
@@ -57,6 +57,18 @@
CubitStatus InitCGMA::initialize_engine( const char* name )
+ if (!name) {
+#if defined(CUBIT_CGM) || defined(ACIS)
+ name = "ACIS";
+#elif defined (HAVE_OCC)
+ name = "OCC";
+#else
+ PRINT_INFO("No engine to default to in InitCGMA");
+ return CUBIT_FAILURE;
+#endif
if (streq_nocase(name,"ACIS")) {
#ifdef CUBIT_CGM
if (!AcisQueryEngine::instance_)
@@ -75,7 +87,7 @@
VirtualQueryEngine::instance();
#ifdef HAVE_OCC
- else if (streq_nocase(name,"OCC") || streq_nocase(name,"occ")) {
+ else if (streq_nocase(name,"OCC")) {
OCCQueryEngine::instance();
OCCModifyEngine::instance();
More information about the cgma-dev
