[cgma-dev] r1863 - in cgm/trunk: geom/OCC test
janehu at mcs.anl.gov
Thu May 29 15:06:23 CDT 2008
Author: janehu
Date: 2008-05-29 15:06:23 -0500 (Thu, 29 May 2008)
New Revision: 1863
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/test/modify.cpp
Log:
Test-passed edge imprint on surface.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-05-29 17:58:25 UTC (rev 1862)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-05-29 20:06:23 UTC (rev 1863)
@@ -122,7 +122,7 @@
#include "SphereEvaluator.hpp"
#include "CylinderEvaluator.hpp"
OCCModifyEngine* OCCModifyEngine::instance_ = 0;
+#define DEBUG
// Function : OCCModifyEngine
// Member Type: PUBLIC
@@ -1897,11 +1897,14 @@
// Description: imprint boolean operation on OCC-based bodies.
// from_shape must be TopoDS_Face or above, tool_shape can be
// TopoDS_Edge or above.
+// on_faces works only when tool_shape is an Edge, indicates that
+// those edges only imprint on the on_faces.
// Author : Jane HU
// Date : 03/08
CubitStatus OCCModifyEngine::imprint_toposhapes(TopoDS_Shape*& from_shape,
- TopoDS_Shape* tool_shape)const
+ TopoDS_Shape* tool_shape,
+ DLIList<TopoDS_Face*>*on_faces)const
int count = 0; //number of imprinting
@@ -1918,13 +1921,27 @@
DLIList<TopoDS_Shape*> tool_faces_edges;
TopTools_ListOfShape list_of_edges;
BRepFeat_SplitShape splitor(*from_shape);
+ CubitBoolean qualified = CUBIT_TRUE;
if (tool_shape->TShape()->ShapeType() == TopAbs_EDGE)
if(count == 1)
break;
common_edge = find_imprinting_edge(*from_shape, TopoDS::Edge(*tool_shape),from_face);
if (common_edge)
- list_of_edges.Append(*common_edge);
+ for (int i = 0; on_faces && i < on_faces->size(); i++)
+ if (from_face.IsSame(*(on_faces->get_and_step())))
+ qualified = CUBIT_FALSE;
+ break;
+ if (qualified && (from_faces.size() == 0 || (from_faces.size() && !from_face.IsSame(*from_faces.get()))) )
+ list_of_edges.Append(*common_edge);
+ else
+ from_face.Nullify();
else
@@ -2278,7 +2295,10 @@
num_face++;
+#ifdef DEBUG
PRINT_INFO("Total %d cuts performed, with from_shape having %d faces.\n", count, num_face);
+#endif
if (count > 0)
return CUBIT_SUCCESS;
return CUBIT_FAILURE;
@@ -2299,7 +2319,6 @@
//list of face on from_shape that has been imprinted
DLIList<TopoDS_Face*> from_faces;
- double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
TopExp_Explorer Ex;
for (Ex.Init(from_shape, TopAbs_FACE); Ex.More(); Ex.Next())
@@ -2434,7 +2453,7 @@
bodysm_list.append(BodyPtr1);
bodysm_list.append(BodyPtr2);
- CubitStatus stat = get_the_shape_list(bodysm_list, shape_list, keep_old);
+ CubitStatus stat = get_shape_list(bodysm_list, shape_list, keep_old);
if(!stat)
return stat;
@@ -2480,7 +2499,7 @@
// Author : Jane Hu
// Date : 05/08
-CubitStatus OCCModifyEngine::get_the_shape_list(DLIList<BodySM*> BodySM_list,
+CubitStatus OCCModifyEngine::get_shape_list(DLIList<BodySM*> BodySM_list,
DLIList<TopoDS_Shape*>& shape_list,
bool keep_old) const
@@ -2557,7 +2576,7 @@
CubitStatus success = CUBIT_SUCCESS;
DLIList<TopoDS_Shape*> shape_list;
- CubitStatus stat = get_the_shape_list(from_body_list, shape_list, keep_old);
+ CubitStatus stat = get_shape_list(from_body_list, shape_list, keep_old);
if(!stat)
return stat;
@@ -2627,7 +2646,7 @@
DLIList<TopoDS_Shape*> shape_list, tool_shapes;
- CubitStatus stat = get_the_shape_list(body_list, shape_list, keep_old);
+ CubitStatus stat = get_shape_list(body_list, shape_list, keep_old);
if (!stat)
return stat;
@@ -2690,17 +2709,104 @@
// Function : imprint
-// Description: imprint boolean operation on facet-based bodies
-// Author : John Fowler
-// Date : 10/02
+// Description: to be consistante with Acis imprint.
+// The surfaces must be part of a body, but the curves
+// just have to be valid OCC edge.
+// Author : Jane Hu
+// Date : 05/08
-CubitStatus OCCModifyEngine::imprint( DLIList<Surface*> &/*ref_face_list*/,
- DLIList<Curve*> &/*ref_edge_list*/,
- DLIList<BodySM*>& /*new_body_list*/,
- bool /*keep_old_body*/ ) const
+CubitStatus OCCModifyEngine::imprint( DLIList<Surface*> &ref_face_list,
+ DLIList<Curve*> &edge_list,
+ DLIList<BodySM*>& new_body_list,
+ bool keep_old ) const
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return CUBIT_FAILURE;
+ DLIList<TopoDS_Face*> face_list;
+ DLIList<TopoDS_Shape*> shape_list;
+ for(int i = 0; i <ref_face_list.size(); i++)
+ OCCSurface* surface = CAST_TO(ref_face_list.get_and_step(), OCCSurface);
+ if(!surface)
+ continue;
+ TopoDS_Face* topo_face = surface->get_TopoDS_Face();
+ face_list.append(topo_face);
+ if(surface->my_shell() && !surface->my_body())//shell body
+ shape_list.append(surface->my_shell()->get_TopoDS_Shell());
+ else if(surface->my_body()) //a sheet body
+ shape_list.append(topo_face);
+ else
+ int size = shape_list.size();
+ OCCQueryEngine* oqe = OCCQueryEngine::instance();
+ DLIList <OCCBody* > *bodies = oqe->BodyList;
+ TopTools_IndexedDataMapOfShapeListOfShape M;
+ OCCBody * body = NULL;
+ for(int i = 0; i < bodies->size(); i++)
+ body = bodies->get_and_step();
+ TopExp::MapShapesAndAncestors(*(body->get_TopoDS_Shape()),
+ TopAbs_FACE, TopAbs_SOLID, M);
+ if(!M.Contains(*topo_face))
+ continue;
+ const TopTools_ListOfShape& ListOfShapes =
+ M.FindFromKey(*topo_face);
+ if (!ListOfShapes.IsEmpty())
+ TopTools_ListIteratorOfListOfShape it(ListOfShapes) ;
+ for (;it.More(); it.Next())
+ TopoDS_Solid solid = TopoDS::Solid(it.Value());
+ int k = oqe->OCCMap->Find(solid);
+ OCCLump* lump = (OCCLump*)oqe->OccToCGM->find(k)->second;
+ if(lump && lump->get_TopoDS_Solid())
+ shape_list.append_unique(lump->get_TopoDS_Solid());
+ assert(size < shape_list.size());
+ if(keep_old)
+ for(int i = 0; i < shape_list.size(); i++)
+ TopoDS_Shape* shape = shape_list.get();
+ BRepBuilderAPI_Copy api_copy(*shape);
+ TopoDS_Shape newShape = api_copy.ModifiedShape(*shape);
+ TopoDS_Shape* Shape1 = new TopoDS_Shape(newShape);
+ shape_list.change_to(Shape1);
+ shape_list.step();
+ for (int i = 0; i < edge_list.size(); i++)
+ OCCCurve* curve = CAST_TO(edge_list.get_and_step(), OCCCurve) ;
+ if (!curve)
+ continue;
+ TopoDS_Edge* edge = curve->get_TopoDS_Edge();
+ if (edge->IsNull())
+ continue;
+ for(int j = 0; j < shape_list.size(); j ++)
+ TopoDS_Shape* shape = shape_list.get_and_step();
+ imprint_toposhapes(shape, (TopoDS_Shape*)edge, &face_list);
+ DLIList<TopologyBridge*> tbs;
+ tbs += OCCQueryEngine::instance()->populate_topology_bridge(*shape);
+ new_body_list.append(CAST_TO(tbs.get(),BodySM));
+ return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-05-29 17:58:25 UTC (rev 1862)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-05-29 20:06:23 UTC (rev 1863)
@@ -652,14 +652,14 @@
DLIList<TopologyBridge*>*,
DLIList<TopologyBridge*>* ) const;
- CubitStatus imprint_toposhapes(TopoDS_Shape*&, TopoDS_Shape*) const;
protected:
const TopoDS_Face* make_TopoDS_Face( GeometryType surface_type,
DLIList<DLIList<TopoDS_Edge*>*> topo_edges,
Surface* old_surface_ptr) const;
- //CubitStatus imprint_toposhapes(TopoDS_Shape*&, TopoDS_Shape*) const;
+ CubitStatus imprint_toposhapes(TopoDS_Shape*&, TopoDS_Shape*,
+ DLIList<TopoDS_Face*>*on_faces = NULL) const;
TopoDS_Edge* find_imprinting_edge(TopoDS_Shape& from_shape,
TopoDS_Edge& tool_shape,
@@ -673,7 +673,7 @@
private:
int check_intersection(DLIList<TopoDS_Edge*>* edge_list,
TopoDS_Face from_face)const;
- CubitStatus get_the_shape_list(DLIList<BodySM*> BodySM_list,
+ CubitStatus get_shape_list(DLIList<BodySM*> BodySM_list,
bool keep_old) const;
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-05-29 17:58:25 UTC (rev 1862)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-05-29 20:06:23 UTC (rev 1863)
@@ -683,7 +683,7 @@
void OCCSurface::get_parents_virt( DLIList<TopologyBridge*>& parents )
- if(myShell) //shell body
+ if(myShell) //shell or sheet body
parents.append(myShell);
return;
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2008-05-29 17:58:25 UTC (rev 1862)
+++ cgm/trunk/test/modify.cpp 2008-05-29 20:06:23 UTC (rev 1863)
@@ -293,6 +293,7 @@
CubitVector v_move4(0,1,-1);
gti->translate(from_body,v_move4);
Body* cp_from_body = gmti->copy_body(from_body);
+ Body* cp_from_body2 = gmti->copy_body(from_body);
Body* cp_tool_body = gmti->copy_body(tool_body);
from_bodies.clean_out();
from_bodies.append(from_body);
@@ -311,6 +312,22 @@
from_bodies.append(cp_from_body);
CubitStatus stat = gmti->imprint(from_bodies, ref_edges, new_bodies, CUBIT_FALSE, CUBIT_TRUE );
+ //test edge imprint on surface
+ CubitVector vv(5,1,4.0);
+ face_list.clean_out();
+ cp_from_body2->ref_faces(face_list);
+ int size = face_list.size();
+ for(int i = 0; i < size; i++)
+ CubitVector v = face_list.get()->center_point();
+ if(!v.about_equal(vv))
+ face_list.remove();
+ else
+ face_list.step();
+ assert(face_list.size() == 1);
+ stat = gmti->imprint(face_list, ref_edges, new_bodies, CUBIT_FALSE);
bodies.clean_out();
gti->bodies(bodies);
//delete all entities
@@ -395,7 +412,7 @@
from_bodies.append(tool_body);
- //test a shell cutting a body, failed operation with a warning message.
+ //test a shell cutting a body, failed operation with an Error message.
rsl = gmti->subtract(from_body2, from_bodies, new_bodies,
CUBIT_TRUE, CUBIT_TRUE);
@@ -404,10 +421,6 @@
CubitVector v_move5(0,0.5,0);
gti->translate(tool_body,v_move5);
from_body = gmti->brick(1,1,1);
- //from_shape = CAST_TO(from_body->get_body_sm_ptr(), OCCBody)->get_TopoDS_Shape();
- //tool_shape = CAST_TO(tool_body->get_body_sm_ptr(),OCCBody)->get_TopoDS_Shape();
-// ome->imprint_toposhapes(tool_shape, from_shape);
-// ome->imprint_toposhapes(from_shape, tool_shape);
new_bodies.clean_out();
More information about the cgma-dev
