[cgma-dev] r1852 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed May 28 14:44:00 CDT 2008
Author: janehu
Date: 2008-05-28 14:44:00 -0500 (Wed, 28 May 2008)
New Revision: 1852
Modified:
cgm/trunk/geom/OCC/OCCCurve.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
Log:
Have to write separately for edge imprinting bodies.
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp 2008-05-27 22:48:52 UTC (rev 1851)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp 2008-05-28 19:44:00 UTC (rev 1852)
@@ -811,7 +811,8 @@
int ii;
for (ii=M.Extent(); ii>0; ii--) {
TopologyBridge *point = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
- result_list.append_unique(dynamic_cast<OCCPoint*>(point));
+ if (point)
+ result_list.append_unique(dynamic_cast<OCCPoint*>(point));
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-05-27 22:48:52 UTC (rev 1851)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-05-28 19:44:00 UTC (rev 1852)
@@ -64,6 +64,7 @@
#include "BRepAlgoAPI_Fuse.hxx"
#include "BRepAlgoAPI_Cut.hxx"
#include "BRepAlgoAPI_Section.hxx"
+#include "BRepAlgoAPI_Common.hxx"
#include "BRepPrimAPI_MakeSphere.hxx"
#include "BRepPrimAPI_MakeBox.hxx"
#include "BRepPrimAPI_MakeWedge.hxx"
@@ -1895,7 +1896,7 @@
// Member Type: PROTECTED
// Description: imprint boolean operation on OCC-based bodies.
// from_shape must be TopoDS_Face or above, tool_shape can be
-// TopoDS_Edge or above.
+// TopoDS_Edge or above.
// Author : Jane HU
// Date : 03/08
@@ -1912,22 +1913,30 @@
double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
while( more_face)
+ TopoDS_Face from_face,tool_face;
+ TopoDS_Edge* common_edge = NULL;
+ DLIList<TopoDS_Shape*> tool_faces_edges;
+ TopTools_ListOfShape list_of_edges;
+ BRepFeat_SplitShape splitor(*from_shape);
+ if (tool_shape->TShape()->ShapeType() == TopAbs_EDGE)
+ if(count == 1)
+ break;
+ common_edge = find_imprinting_edge(*from_shape, TopoDS::Edge(*tool_shape),from_face);
+ if (common_edge)
+ list_of_edges.Append(*common_edge);
+ else
TopOpeBRep_ShapeIntersector intersector;
intersector.InitIntersection(*from_shape, *tool_shape);
- BRepFeat_SplitShape splitor(*from_shape);
- TopTools_ListOfShape list_of_edges;
//find the intersecting edges and faces.
int max_edge = 0;
- TopoDS_Face from_face,tool_face;
- DLIList<TopoDS_Shape*> tool_faces_edges;
for(; intersector.MoreIntersection(); intersector.NextIntersection())
TopoDS_Shape face1;
- if(tool_shape->TShape()->ShapeType() == TopAbs_EDGE)
- face1 = intersector.ChangeFaceEdgeIntersector().Shape(1);
- else
- face1 = intersector.ChangeFacesIntersector().Face(1);
+ face1 = intersector.ChangeFacesIntersector().Face(1);
CubitBoolean has_imprinted = CUBIT_FALSE;
for (int j = 0; j < from_faces.size(); j++)
@@ -1944,18 +1953,12 @@
TopoDS_Shape edge_face;
- edge_face = intersector.ChangeFaceEdgeIntersector().Shape(2);
- else
- edge_face = intersector.ChangeFacesIntersector().Face(2);
+ edge_face = intersector.ChangeFacesIntersector().Face(2);
BRepAlgoAPI_Section section(face1, edge_face);
//intersection edges between face1 and edge_face
TopTools_ListOfShape temp_list_of_edges;
- if (tool_shape->TShape()->ShapeType() == TopAbs_EDGE)
- temp_list_of_edges.Append(edge_face);
- else
- temp_list_of_edges.Assign(section.SectionEdges());
+ temp_list_of_edges.Assign(section.SectionEdges());
int num_edges = temp_list_of_edges.Extent();
CubitBoolean is_same = face1.IsSame(from_face);
@@ -2026,6 +2029,7 @@
if (from_face.IsNull())
more_face = CUBIT_FALSE;
@@ -2042,6 +2046,13 @@
tool_faces_edges.clean_out();
+ for (int iii=0; iii < from_faces.size(); iii++)
+ TopoDS_Face* topo_face = from_faces.get_and_step();
+ topo_face->Nullify();
+ delete topo_face;
continue;
@@ -2273,6 +2284,45 @@
return CUBIT_FAILURE;
+// Function : find_imprinting_edge
+// Member Type: PROTECTED
+// Description: imprint boolean operation on OCC-based bodies.
+// from_shape must be TopoDS_Face or above, tool_shape must be
+// TopoDS_Edge.
+// Author : Jane HU
+// Date : 05/08
+TopoDS_Edge* OCCModifyEngine::find_imprinting_edge(TopoDS_Shape& from_shape,
+ TopoDS_Edge& tool_shape,
+ TopoDS_Face& face)const
+ //list of face on from_shape that has been imprinted
+ DLIList<TopoDS_Face*> from_faces;
+ double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
+ TopExp_Explorer Ex;
+ for (Ex.Init(from_shape, TopAbs_FACE); Ex.More(); Ex.Next())
+ face = TopoDS::Face(Ex.Current());
+ BRepAlgoAPI_Common intersector(face, tool_shape);
+ TopTools_ListOfShape shapes;
+ shapes.Assign(intersector.Modified(tool_shape));
+ if (shapes.IsEmpty())
+ continue;
+ if ( shapes.Extent() > 1)
+ PRINT_ERROR("Edge has multiple intersection with the shape, make it simpler. \n");
+ continue;
+ if (shapes.First().TShape()->ShapeType() != TopAbs_EDGE)
+ continue;
+ TopoDS_Edge* edge = new TopoDS_Edge(TopoDS::Edge(shapes.First()));
+ return edge;
+ face.Nullify();
+ return NULL;
int OCCModifyEngine::check_intersection(DLIList<TopoDS_Edge*>* edge_list,
TopoDS_Face from_face)const
@@ -2526,7 +2576,6 @@
for(int i = 0; i < size; i++)
TopoDS_Shape* shape1 = shape_list[i];
- shape_list.append(shape1);
CubitBoolean modified = CUBIT_FALSE;
for(int j = i+1; j < size+i; j ++)
@@ -2548,6 +2597,7 @@
tbs += OCCQueryEngine::instance()->populate_topology_bridge(*shape1);
new_from_body_list.append(CAST_TO(tbs.get(),BodySM));
+ shape_list.reset();
if( size > 2 )
AppUtil::instance()->progress_tool()->step();
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-05-27 22:48:52 UTC (rev 1851)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-05-28 19:44:00 UTC (rev 1852)
@@ -660,7 +660,11 @@
Surface* old_surface_ptr) const;
//CubitStatus imprint_toposhapes(TopoDS_Shape*&, TopoDS_Shape*) const;
+ TopoDS_Edge* find_imprinting_edge(TopoDS_Shape& from_shape,
+ TopoDS_Face& face)const;
CubitStatus sort_curves(DLIList<Curve*> curve_list,
DLIList<DLIList<TopoDS_Edge*>*>& topo_edges_loops)const;
More information about the cgma-dev
