[cgma-dev] r1822 - in cgm/trunk: . geom/OCC test
kraftche at mcs.anl.gov
Mon May 19 11:53:46 CDT 2008
Author: kraftche
Date: 2008-05-19 11:53:45 -0500 (Mon, 19 May 2008)
New Revision: 1822
Added:
cgm/trunk/test/sheet.cpp
Modified:
cgm/trunk/configure.in
cgm/trunk/geom/OCC/OCCModifyEngine.hpp
cgm/trunk/geom/OCC/OCCSurface.cpp
cgm/trunk/test/Makefile.am
cgm/trunk/test/makept.cpp
cgm/trunk/test/modify.cpp
Log:
configure.in:
o set HAVE_OCC_DEF="-DHAVE_OCC" if building with OCC
geom/OCC/OCCModifyEngine.hpp:
o add missing forward declarations
o remove unnecessary forward declarations
geom/OCC/OCCSurface.hpp:
o Return CUBIT_UNKNOWN for relative surface/shell sense for
surfaces that are part of a sheet body.
o Do not return a BodySM* from Surface::get_parents_virt. This
function is expected to query *one* level.
test/makept.cpp:
test/modify.cpp:
o Specify correct paths for input files when running in separate
build tree.
test/sheet.cpp:
o Test that Body::is_sheet_body() returns the correct result for
both OCC and ACIS bodies (sheet & non-sheet).
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in 2008-05-16 21:01:29 UTC (rev 1821)
+++ cgm/trunk/configure.in 2008-05-19 16:53:45 UTC (rev 1822)
@@ -252,6 +252,7 @@
# if user specified option (other than --without-occ)
CUBIT_OCC_LIB=
+HAVE_OCC_DEF=
if test "x$occ_DIR" != "xno"; then
OCC_LIBS="-lTKMath -lTKXSBase -lTKernel -lTKShHealing -lTKBRep -lTKG3d -lTKBO -lTKFeat -lTKFillet -lTKG2d -lTKOffset -lTKBool -lTKGeomAlgo -lTKGeomBase -lTKPrim -lTKTopAlgo -lTKHLR -lTKIGES -lTKMesh -lTKPrim -lTKSTEP209 -lTKSTEPAttr -lTKSTEPBase -lTKSTEP -lTKSTL -lTKTopAlgo -lTKXSBase"
CUBIT_OCC_LIB="-lcubit_OCC"
@@ -305,6 +306,7 @@
# Restore original values of variables
CPPFLAGS="$old_CPPFLAGS"
LDFLAGS="$old_LDFLAGS"
+ HAVE_OCC_DEF="-DHAVE_OCC"
fi
# Export these variables as variables in Makefiles
@@ -313,6 +315,7 @@
AC_SUBST(OCC_LIB_FLAG)
AC_SUBST(OCC_LIBS)
AC_SUBST(CUBIT_OCC_LIB)
+AC_SUBST(HAVE_OCC_DEF)
# Allow "if WITH_OCC" in Makefile.am
AM_CONDITIONAL( WITH_OCC, [test "x$occ_DIR" != "xno"] )
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-05-16 21:01:29 UTC (rev 1821)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp 2008-05-19 16:53:45 UTC (rev 1822)
@@ -20,14 +20,13 @@
class Point;
class TopologyBridge;
-class TopologyEntity;
-class Point;
class CoEdgeSM;
class ShellSM;
class OCCBody;
-class Body;
-class RefFace;
class OCCSurface;
+class TopoDS_Shape;
+class TopoDS_Edge;
+class TopoDS_Face;
class OCCModifyEngine : public GeometryModifyEngine
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp 2008-05-16 21:01:29 UTC (rev 1821)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp 2008-05-19 16:53:45 UTC (rev 1822)
@@ -682,12 +682,6 @@
void OCCSurface::get_parents_virt( DLIList<TopologyBridge*>& parents )
- if (myBody) //sheet body
- parents.append(myBody);
- return;
if(myShell) //shell body
parents.append(myShell);
@@ -736,6 +730,11 @@
// return the sense with respect to the given shell
CubitSense OCCSurface::get_shell_sense( ShellSM* shell_ptr ) const
+ OCCShell* shell = dynamic_cast<OCCShell*>(shell_ptr);
+ if (!shell)
+ return CUBIT_UNKNOWN;
+ if (shell->my_surface() == this)
return CUBIT_FORWARD;
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am 2008-05-16 21:01:29 UTC (rev 1821)
+++ cgm/trunk/test/Makefile.am 2008-05-19 16:53:45 UTC (rev 1822)
@@ -11,20 +11,27 @@
-I$(srcdir) \
$(OCC_INC_FLAG)
-TESTS=
+ENGINE_LIBS =
+LINK_FLAGS =
+TESTS = sheet
if build_ACIS
TESTS += webcut
+ ENGINE_LIBS += ../geom/ACIS/libcubit_ACIS.la
+ LINK_FLAGS += -R$(ACIS_LIB_DIR)
endif
if WITH_OCC
TESTS += modify makept
+ ENGINE_LIBS += ../geom/OCC/libcubit_OCC.la
+ LINK_FLAGS += -R$(OCC_LIB_DIR)
endif
-AM_CPPFLAGS += -DSRCDIR=@srcdir@
+AM_CPPFLAGS += -DSRCDIR=@srcdir@ $(HAVE_ACIS_DEF) $(HAVE_OCC_DEF)
check_PROGRAMS = $(TESTS)
webcut_SOURCES = webcut.cpp
makept_SOURCES = makept.cpp
modify_SOURCES = modify.cpp
+sheet_SOURCES = sheet.cpp
LDADD = ../geom/virtual/libcubit_virtual.la \
../geom/facetbool/libcubit_facetbool.la \
../geom/Cholla/libcholla.la \
@@ -37,3 +44,5 @@
makept_LDADD = ../geom/OCC/libcubit_OCC.la $(LDADD)
modify_LDFLAGS = $(LDFLAGS) -R$(OCC_LIB_DIR)
modify_LDADD = ../geom/OCC/libcubit_OCC.la $(LDADD)
+sheet_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
+sheet_LDADD = $(ENGINE_LIBS) $(LDADD)
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp 2008-05-16 21:01:29 UTC (rev 1821)
+++ cgm/trunk/test/makept.cpp 2008-05-19 16:53:45 UTC (rev 1822)
@@ -6,7 +6,6 @@
* This program acts as a simple driver for CGM. It reads in a geometry,
* and performs varies checks for bodies, surfaces, curves and vertices.
-#include "config.h"
#include "CpuTimer.hpp"
#include "GeometryModifyTool.hpp"
#include "GeometryQueryTool.hpp"
@@ -31,6 +30,14 @@
#include "OCCSurface.hpp"
#include "OCCCurve.hpp"
+#ifndef SRCDIR
+# define SRCDIR .
+#endif
+#define STRINGIFY_(X) #X
+#define STRINGIFY(X) STRINGIFY_(X)
+#define SRCPATH STRINGIFY(SRCDIR) "/"
// forward declare some functions used and defined later
CubitStatus read_geometry(int, char **);
CubitStatus make_Point();
@@ -87,9 +94,11 @@
PRINT_SEPARATOR;
for (i = 0; i < num_files; i++) {
- status = gti->import_solid_model(argv[i], "OCC");
+ std::string filename( SRCPATH );
+ filename += argv[i];
+ status = gti->import_solid_model(filename.c_str(), "OCC");
if (status != CUBIT_SUCCESS) {
- PRINT_ERROR("Problems reading geometry file %s.\n", argv[i]);
+ PRINT_ERROR("Problems reading geometry file %s.\n", filename);
PRINT_SEPARATOR;
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp 2008-05-16 21:01:29 UTC (rev 1821)
+++ cgm/trunk/test/modify.cpp 2008-05-19 16:53:45 UTC (rev 1822)
@@ -37,6 +37,14 @@
#include "RefEntityName.hpp"
#include "RefEntityFactory.hpp"
+#ifndef SRCDIR
+# define SRCDIR .
+#endif
@@ -93,9 +101,11 @@
PRINT_SEPARATOR;
PRINT_SEPARATOR;
Added: cgm/trunk/test/sheet.cpp
--- cgm/trunk/test/sheet.cpp (rev 0)
+++ cgm/trunk/test/sheet.cpp 2008-05-19 16:53:45 UTC (rev 1822)
@@ -0,0 +1,134 @@
+ * \file makept.cpp
+ * \brief makept, another simple C++ driver for CGM
+ * This program acts as a simple driver for CGM. It reads in a geometry,
+ * and performs varies checks for bodies, surfaces, curves and vertices.
+#include "GeometryModifyTool.hpp"
+#include "GeometryQueryTool.hpp"
+#include "ModelQueryEngine.hpp"
+#include "Body.hpp"
+#include "RefFace.hpp"
+#include "CubitObserver.hpp"
+#include <typeinfo>
+#include <assert.h>
+#ifdef HAVE_ACIS
+#include "AcisModifyEngine.hpp"
+#include "AcisQueryEngine.hpp"
+#endif
+#ifdef HAVE_OCC
+#include "OCCModifyEngine.hpp"
+#include "OCCQueryEngine.hpp"
+#endif
+int test_sheet_query( GeometryModifyEngine* engine );
+// main program - initialize, then send to proper function
+int main (int argc, char **argv)
+ CubitObserver::init_static_observers();
+ CGMApp::instance()->startup( argc, argv );
+ GeometryQueryEngine* const gqe_list[] = {
+#ifdef HAVE_ACIS
+ AcisQueryEngine::instance(),
+#endif
+#ifdef HAVE_OCC
+ OCCQueryEngine::instance(),
+#endif
+ NULL
+ GeometryModifyEngine* const gme_list[] = {
+#ifdef HAVE_ACIS
+ AcisModifyEngine::instance(),
+#endif
+#ifdef HAVE_OCC
+ OCCModifyEngine::instance(),
+#endif
+ NULL
+ int exit_val = 0;
+ for (int i = 0; gme_list[i]; ++i)
+ exit_val += test_sheet_query( gme_list[i] );
+ return exit_val;
+ CubitStatus rval = GeometryModifyTool::instance()->set_default_gme( engine );
+ assert(rval);
+ Body *sphere = 0, *sheet = 0;
+ sphere = GeometryModifyTool::instance()->sphere( 1.0 );
+ if (!sphere) {
+ fprintf(stderr,"Sphere creation failed for engine (%s)\n",
+ typeid(*engine).name());
+ return 1;
+/* This fails for OCC. Try something else to create sheet body
+ sheet = GeometryModifyTool::instance()->planar_sheet(
+ CubitVector(0,0,0), CubitVector(1,0,0),
+ CubitVector(1,1,0), CubitVector(0,1,0) );
+ if (!sphere) {
+ fprintf(stderr,"Planar sheet creation failed for engine (%s)\n",
+ return 1;
+ DLIList<ModelEntity*> list;
+ rval = ModelQueryEngine::instance()->query_model( *sphere, DagType::ref_face_type(), list );
+ if (!rval || list.size() != 1) {
+ fprintf(stderr,"Failed to get face from body (%s)\n",
+ return 1;
+ RefFace* sphere_face = dynamic_cast<RefFace*>(list.get());
+ assert(NULL != sphere_face);
+ RefFace* sheet_face = GeometryModifyTool::instance()->make_RefFace( sphere_face );
+ if (!sheet_face) {
+ fprintf(stderr,"Failed to create face from sphere face (%s)\n",
+ return 1;
+ list.clean_out();
+ rval = ModelQueryEngine::instance()->query_model( *sheet_face, DagType::body_type(), list );
+ fprintf(stderr,"Failed to get body from sheet face (%s)\n",
+ return 1;
+ sheet = dynamic_cast<Body*>(list.get());
+ assert(NULL != sheet);
+ if (sphere->is_sheet_body()) {
+ fprintf(stderr,"Solid sphere reported as sheet body (%s).\n",
+ return 1;
+ if (!sheet->is_sheet_body()) {
+ fprintf(stderr,"Planar sheet reported as non-sheet body (%s).\n",
+ return 1;
+ printf("Success (%s)\n",typeid(*engine).name());
+ return 0;
More information about the cgma-dev
