[cgma-dev] r1813 - in cgm/trunk/geom: . facet virtual
    kraftche at mcs.anl.gov
    Thu May 15 14:54:12 CDT 2008
Author: kraftche
Date: 2008-05-15 14:54:11 -0500 (Thu, 15 May 2008)
New Revision: 1813
Modified:
   cgm/trunk/geom/Body.cpp
   cgm/trunk/geom/facet/FacetBody.hpp
   cgm/trunk/geom/virtual/CompositeBody.hpp
   cgm/trunk/geom/virtual/PartitionBody.hpp
Log:
Back out most of revsion 1782 (April 28, 2008):
  - breaks is_sheet_body() and related functions for all geometry
    engines except OCC (virtual, facet, etc.)
  - breaks build of ACIS engine
  - might make Body::is_sheet_body() work for OCC, but is an incomplete
    solution because Shell::is_sheet(), BTE::is_nonmanifold(), etc.
    are still broken for OCC
  - if OCC correctly returns relative sense between Surfaces and
    ShellSMs, then no change to RefEntity-level code is necessary
Modified: cgm/trunk/geom/Body.cpp
--- cgm/trunk/geom/Body.cpp	2008-05-15 15:22:20 UTC (rev 1812)
+++ cgm/trunk/geom/Body.cpp	2008-05-15 19:54:11 UTC (rev 1813)
@@ -193,19 +193,8 @@
   DLIList<RefVolume*> volumes;
   ref_volumes(volumes);
   while (volumes.size())
     if (!volumes.pop()->is_sheet())
-      //OCC sheet body just has one face or shell, not like Acis
-      BodySM* bodysm = get_body_sm_ptr();
-      if (bodysm == NULL)
-        PRINT_ERROR("Body %d is invalid -- no attached BodySM.\n", this->id());
-        return CUBIT_FALSE;
-      return bodysm->is_sheet_body();
+      return CUBIT_FALSE;
   return CUBIT_TRUE;
Modified: cgm/trunk/geom/facet/FacetBody.hpp
--- cgm/trunk/geom/facet/FacetBody.hpp	2008-05-15 15:22:20 UTC (rev 1812)
+++ cgm/trunk/geom/facet/FacetBody.hpp	2008-05-15 19:54:11 UTC (rev 1813)
@@ -191,7 +191,6 @@
   virtual CubitPointContainment point_containment( const CubitVector& pos );
-  virtual CubitBoolean is_sheet_body(){return CUBIT_FALSE;}
 protected:
 private:
Modified: cgm/trunk/geom/virtual/CompositeBody.hpp
--- cgm/trunk/geom/virtual/CompositeBody.hpp	2008-05-15 15:22:20 UTC (rev 1812)
+++ cgm/trunk/geom/virtual/CompositeBody.hpp	2008-05-15 19:54:11 UTC (rev 1813)
@@ -78,7 +78,6 @@
     void combine( CompositeBody* other );
-    CubitBoolean is_sheet_body(){return CUBIT_FALSE;}
   private:
     CompositeLump* firstLump;
Modified: cgm/trunk/geom/virtual/PartitionBody.hpp
--- cgm/trunk/geom/virtual/PartitionBody.hpp	2008-05-15 15:22:20 UTC (rev 1812)
+++ cgm/trunk/geom/virtual/PartitionBody.hpp	2008-05-15 19:54:11 UTC (rev 1813)
@@ -100,8 +100,7 @@
     void transform(const CubitTransformMatrix&) {}
     void get_all_children( DLIList<PartitionEntity*>& list );
   protected:
   private:
More information about the cgma-dev
