[cgma-dev] r1697 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Tue Mar 25 14:11:16 CDT 2008
Author: janehu
Date: 2008-03-25 14:11:16 -0500 (Tue, 25 Mar 2008)
New Revision: 1697
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
Log:
Modified sort_curves and imprint_toposhapes, now the technical question up to solve is when we get the cutting edges, how do we know if the edge is overlapping with the original surface's edges, if so, we don't need to add them into the cutting tool.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-25 18:36:19 UTC (rev 1696)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-03-25 19:11:16 UTC (rev 1697)
@@ -751,11 +751,14 @@
// Date : 03/08
CubitStatus OCCModifyEngine::sort_curves(DLIList<Curve*> curve_list,
- DLIList<DLIList<TopoDS_Edge*>*>& topo_edges_loops)const
+ DLIList<DLIList<TopoDS_Edge*>*>& topo_edges_loops)const
topo_edges_loops.clean_out();
- DLIList<TopoDS_Edge*> topo_edges[curve_list.size()];
+ DLIList<TopoDS_Edge*>* topo_edges[curve_list.size()];
+ for(int i = 0; i < curve_list.size(); i++)
+ topo_edges[i] = new DLIList<TopoDS_Edge*>;
curve_list.reset() ;
Curve const* curve_ptr = NULL ;
OCCCurve* occ_curve = NULL;
@@ -801,18 +804,19 @@
new_end = CUBIT_TRUE;
break;
+ curve_list.step();
if (new_end)//found next curve
topo_edge = occ_curve->get_TopoDS_Edge();
- topo_edges[count].append(topo_edge);
+ topo_edges[count]->append(topo_edge);
curve_list.remove();
if(start->is_equal( *end, tol)) //formed a closed loop
i = 0;
size = curve_list.size() ;
- topo_edges_loops.append(&topo_edges[count]);
+ topo_edges_loops.append(topo_edges[count]);
count++;
else
@@ -1653,6 +1657,7 @@
TopoDS_Shape cut_shape = BRepAlgoAPI_Cut(*from_shape, *tool_shape);
//compare to see if the from_shape has gotten cut.
+ CubitStatus stat;
if(is_volume[i])
GProp_GProps myProps;
@@ -1664,8 +1669,12 @@
//Add imprint code here
if(imprint)
- imprint_toposhapes(from_shape, tool_shape);
- count++;
+ stat = imprint_toposhapes(from_shape, tool_shape);
+ if(!stat)
+ PRINT_ERROR("Can't do imprint operation on the body. \n");
+ count++;
continue;
@@ -1680,8 +1689,12 @@
if(imprint)
- count++;
+ if(!stat)
+ count++;
continue;
@@ -1690,7 +1703,7 @@
//ok, we're done wih all cuts, construct new Body'
- if (count < tool_body_list.size())
+ if (count < tool_body_list.size() )
tbs += OCCQueryEngine::instance()->populate_topology_bridge(*from_shape);
else
@@ -1745,50 +1758,75 @@
TopOpeBRep_ShapeIntersector intersector;
intersector.InitIntersection(*from_shape, *tool_shape);
+ BRepFeat_SplitShape splitor(*from_shape);
TopTools_ListOfShape list_of_edges;
- BRepFeat_SplitShape splitor(*from_shape);
+ int max_edge = 0;
+ TopoDS_Shape from_face;
for(; intersector.MoreIntersection(); intersector.NextIntersection())
TopoDS_Shape face1 = intersector.ChangeFacesIntersector().Face(1);
TopoDS_Shape face2 = intersector.ChangeFacesIntersector().Face(2);
BRepAlgoAPI_Section section(face1, face2);
- list_of_edges.Assign(section.SectionEdges());
- int num_edges = list_of_edges.Extent();
+ TopTools_ListOfShape temp_list_of_edges;
+ temp_list_of_edges.Assign(section.SectionEdges());
+ int num_edges = temp_list_of_edges.Extent();
+ if (max_edge < num_edges)
+ list_of_edges.Assign(temp_list_of_edges);
+ max_edge = num_edges ;
+ from_face = face1;
- TopTools_ListIteratorOfListOfShape Itor;
- Itor.Initialize(list_of_edges);
- DLIList<Curve*> curve_list;
- for(; Itor.More(); Itor.Next())
+ TopTools_ListIteratorOfListOfShape Itor;
+ Itor.Initialize(list_of_edges);
+ DLIList<Curve*> curve_list;
+ for(; Itor.More(); Itor.Next())
+ TopoDS_Edge edge = TopoDS::Edge(Itor.Value());
+ if (max_edge == 1) //surface solid imprint
- TopoDS_Edge edge = TopoDS::Edge(Itor.Value());
- if (num_edges == 1) //surface solid imprint
- splitor.Add(edge, TopoDS::Face(face1));
- break;
- Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
- curve_list.append(curve);
+ splitor.Add(edge, TopoDS::Face(from_face));
+ break;
- if (num_edges > 1)
- DLIList<DLIList<TopoDS_Edge*>*> edge_lists;
- CubitStatus stat = sort_curves(curve_list, edge_lists);
- if (!stat)
- PRINT_ERROR("can't do solid solid imprint without a closed loop.\n");
- return CUBIT_FAILURE;
- assert(edge_lists.size() == 1);
- DLIList<TopoDS_Edge*> edge_list;
- edge_list = *(edge_lists.get());
- BRepBuilderAPI_MakeWire myWire;
- for(int i = 0; i < edge_list.size(); i++)
- myWire.Add(*(edge_list.get_and_step()));
- splitor.Add(TopoDS::Wire(myWire.Shape()),TopoDS::Face(face1));
+ Curve* curve = OCCQueryEngine::instance()->populate_topology_bridge(edge);
+ curve_list.append(curve);
+ if (max_edge > 1)
+ DLIList<DLIList<TopoDS_Edge*>*> edge_lists;
+ CubitStatus stat = sort_curves(curve_list, edge_lists);
+ if (!stat)
+ PRINT_ERROR("can't do solid solid imprint without a closed loop.\n");
+ return CUBIT_FAILURE;
+ assert(edge_lists.size() == 1);
+ DLIList<TopoDS_Edge*>* edge_list;
+ edge_list = edge_lists.get();
+ BRepBuilderAPI_MakeWire myWire;
+ for(int i = 0; i < edge_list->size(); i++)
+ TopoDS_Edge e = *(edge_list->get_and_step());
+ myWire.Add(e);
- splitor.Build();
+ splitor.Add(myWire.Wire(),TopoDS::Face(from_face));
+ splitor.Build();
+ if(splitor.IsDone())
+ delete from_shape;
+ from_shape = new TopoDS_Shape(splitor.Shape());
+ TopExp_Explorer Ex;
+ int num_face = 0;
+ for (Ex.Init(*from_shape, TopAbs_FACE); Ex.More(); Ex.Next())
+ TopoDS_Face face = TopoDS::Face(Ex.Current());
+ num_face++;
+ return CUBIT_SUCCESS;
// Function : imprint
More information about the cgma-dev
