[cgma-dev] r1649 - in cgm/trunk: geom/OCC test
janehu at mcs.anl.gov janehu at mcs.anl.gov
Thu Mar 13 14:31:27 CDT 2008
Author: janehu
Date: 2008-03-13 14:31:27 -0500 (Thu, 13 Mar 2008)
New Revision: 1649
Modified:
   cgm/trunk/geom/OCC/OCCBody.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCQueryEngine.cpp
   cgm/trunk/geom/OCC/OCCShell.cpp
   cgm/trunk/geom/OCC/OCCSurface.cpp
   cgm/trunk/test/Makefile.am
   cgm/trunk/test/modify.cpp
Log:
Modified model import/export code to work with shell bodies,standalone surfaces and shells are all in bodySM's. Added tests on these and stitch surfs now working too.
Modified: cgm/trunk/geom/OCC/OCCBody.cpp
--- cgm/trunk/geom/OCC/OCCBody.cpp	2008-03-13 19:27:31 UTC (rev 1648)
+++ cgm/trunk/geom/OCC/OCCBody.cpp	2008-03-13 19:31:27 UTC (rev 1649)
@@ -88,6 +88,7 @@
   myTopoDSShape = new TopoDS_CompSolid(Co);
   IsSheetBody = CUBIT_FALSE;
+  myShell = NULL;
   update_bounding_box();
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-03-13 19:27:31 UTC (rev 1648)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-03-13 19:31:27 UTC (rev 1649)
@@ -1487,8 +1487,6 @@
       stitched_body = face->my_body();
-  //delete all original surfaces
-  OCCQueryEngine::instance()->delete_solid_model_entities(surf_bodies);
   return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-03-13 19:27:31 UTC (rev 1648)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp	2008-03-13 19:31:27 UTC (rev 1649)
@@ -1082,7 +1082,12 @@
   for (Ex.Init(aShape, TopAbs_FACE, TopAbs_SHELL); Ex.More(); Ex.Next())
-    tblist.append(populate_topology_bridge(TopoDS::Face(Ex.Current()),CUBIT_TRUE));
+    Surface* face =
+      populate_topology_bridge(TopoDS::Face(Ex.Current()),CUBIT_TRUE);
+    if(face)
+      tblist.append(CAST_TO(face, OCCSurface)->my_body());
   for (Ex.Init(aShape, TopAbs_WIRE, TopAbs_FACE); Ex.More(); Ex.Next())
     populate_topology_bridge(TopoDS::Wire(Ex.Current()), CUBIT_TRUE);
@@ -1092,6 +1097,7 @@
   for (Ex.Init(aShape, TopAbs_VERTEX, TopAbs_EDGE); Ex.More(); Ex.Next())
     tblist.append(populate_topology_bridge(TopoDS::Vertex(Ex.Current())));
+  tblist.remove_all_with_value(NULL);
   return tblist;
@@ -1110,21 +1116,22 @@
       OccToCGM->insert(valType(iTotalTBCreated,
 			       (TopologyBridge*)body));
       BodyList->append(body);
+      TopExp_Explorer Ex;
+      DLIList<Lump*> lumps;
+      for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next())
+          Lump* lump = populate_topology_bridge(TopoDS::Solid(Ex.Current()));
+          lumps.append(lump);
+          CAST_TO(lump, OCCLump)->add_body(body);
+      body->lumps(lumps);
   else
       int k = OCCMap->Find(*posolid);
       body = (OCCBody*)(OccToCGM->find(k))->second;
-  TopExp_Explorer Ex;
-  DLIList<Lump*> lumps;
-  for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next())
-      Lump* lump = populate_topology_bridge(TopoDS::Solid(Ex.Current()));
-      lumps.append(lump);
-      CAST_TO(lump, OCCLump)->add_body(body);
-  body->lumps(lumps);
   return body;
@@ -1137,31 +1144,32 @@
   OCCLump *lump;
   OCCBody *body;
   if (!OCCMap->IsBound(*posolid))
+    if(PRINT_RESULT)
+      PRINT_INFO("Adding solids.\n");
+    iTotalTBCreated++;
+    lump = new OCCLump(posolid);
+    if (build_body)
-      if(PRINT_RESULT)
-	PRINT_INFO("Adding solids.\n");
-      iTotalTBCreated++;
-      lump = new OCCLump(posolid);
-      if (build_body)
-	  body = new OCCBody(lumps);
-	  BodyList->append(body);
-	  lump->add_body(body);
-      OCCMap->Bind(*posolid, iTotalTBCreated);
-      OccToCGM->insert(valType(iTotalTBCreated,
-			       (TopologyBridge*)lump));
+      body = new OCCBody(lumps);
+      BodyList->append(body);
+      lump->add_body(body);
+    OCCMap->Bind(*posolid, iTotalTBCreated);
+    OccToCGM->insert(valType(iTotalTBCreated,
+		       (TopologyBridge*)lump));
+    for (Ex.Init(aShape, TopAbs_SHELL); Ex.More(); Ex.Next())
+      populate_topology_bridge(TopoDS::Shell(Ex.Current()));
   else
-      int k = OCCMap->Find(*posolid);
-      lump = (OCCLump*)(OccToCGM->find(k))->second;
-  for (Ex.Init(aShape, TopAbs_SHELL); Ex.More(); Ex.Next())
-    populate_topology_bridge(TopoDS::Shell(Ex.Current()));
+    int k = OCCMap->Find(*posolid);
+    lump = (OCCLump*)(OccToCGM->find(k))->second;
   return lump;
@@ -1173,31 +1181,39 @@
   OCCShell *shell ;
   CubitBoolean build_body = CUBIT_FALSE;
   if (!OCCMap->IsBound(*poshell))
+    if(PRINT_RESULT)
+      PRINT_INFO("Adding shells.\n");
+    shell = new OCCShell(poshell);
+    OCCMap->Bind(*poshell, iTotalTBCreated);
+		       (TopologyBridge*)shell));
+    if(standalone)
-      if(PRINT_RESULT)
-	PRINT_INFO("Adding shells.\n");
-      shell = new OCCShell(poshell);
-      OCCMap->Bind(*poshell, iTotalTBCreated);
-			       (TopologyBridge*)shell));
+      OCCLump* lump = new OCCLump(NULL, NULL, shell);
+      OCCBody* body = new OCCBody(NULL, CUBIT_FALSE, NULL, shell);
+      shell->set_body(body);
+      shell->set_lump(lump);
+      //don't need to add body into BodyList.
+    for (Ex.Init(aShape, TopAbs_FACE); Ex.More(); Ex.Next())
+      Surface* face =
+        populate_topology_bridge(TopoDS::Face(Ex.Current()), build_body);
       if(standalone)
-        OCCLump* lump = new OCCLump(NULL, NULL, shell);
-        OCCBody* body = new OCCBody(NULL, CUBIT_FALSE, NULL, shell);
-        shell->set_body(body);
-        shell->set_lump(lump);
+        CAST_TO(face,OCCSurface)->set_shell(shell);
   else
-      int k = OCCMap->Find(*poshell);
-      shell = (OCCShell*)(OccToCGM->find(k))->second;
+    int k = OCCMap->Find(*poshell);
+    shell = (OCCShell*)(OccToCGM->find(k))->second;
-  for (Ex.Init(aShape, TopAbs_FACE); Ex.More(); Ex.Next())
-    populate_topology_bridge(TopoDS::Face(Ex.Current()), build_body);
   return shell;
@@ -1206,38 +1222,38 @@
   TopoDS_Face *poface = new TopoDS_Face;
   *poface = aShape;
-  OCCSurface *surface;
+  OCCSurface *surface = NULL;
   if (!OCCMap->IsBound(*poface))
-      surface = new OCCSurface(poface);
+    surface = new OCCSurface(poface);
-      if(PRINT_RESULT)
-        PRINT_INFO("Adding faces.\n");
-      OCCMap->Bind(*poface, iTotalTBCreated);
+    if(PRINT_RESULT)
+      PRINT_INFO("Adding faces.\n");
+    OCCMap->Bind(*poface, iTotalTBCreated);
                              (TopologyBridge*)surface));
-      SurfaceList->append(surface);
-  else
+    SurfaceList->append(surface);
+    if(build_body)
-      int k = OCCMap->Find(*poface);
-      surface = (OCCSurface*)(OccToCGM->find(k))->second;
-  if(build_body)
       OCCShell* shell = new OCCShell(NULL, surface);
       OCCLump* lump = new OCCLump(NULL, surface);
       OCCBody* body = new OCCBody(NULL, CUBIT_TRUE, surface);
       surface->set_body(body);
       surface->set_lump(lump);
       surface->set_shell(shell);
+      //Doesn't need to save sheet bodies.
+    for (Ex.Init(aShape, TopAbs_WIRE); Ex.More(); Ex.Next())
+      populate_topology_bridge(TopoDS::Wire(Ex.Current()));
-  for (Ex.Init(aShape, TopAbs_WIRE); Ex.More(); Ex.Next())
-    populate_topology_bridge(TopoDS::Wire(Ex.Current()));
+  else
+    int k = OCCMap->Find(*poface);
+    surface = (OCCSurface*)(OccToCGM->find(k))->second;
   return surface;
@@ -1259,6 +1275,19 @@
 			       (TopologyBridge*)loop));
       if(standalone)
 	WireList->append(loop);
+      BRepTools_WireExplorer Ex;
+      DLIList <OCCCoEdge*> coedges;
+      for (Ex.Init(aShape); Ex.More(); Ex.Next())
+          Curve* curve = populate_topology_bridge(Ex.Current());
+          OCCCurve *occ_curve = CAST_TO(curve, OCCCurve);
+          OCCCoEdge * coedge = new OCCCoEdge( curve, loop,
+            (Ex.Orientation() == TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
+          coedges.append(coedge);
+          occ_curve->add_loop(loop);
+      loop->coedges(coedges);
   else
@@ -1266,19 +1295,6 @@
       loop = (OCCLoop*)(OccToCGM->find(k))->second;
-  BRepTools_WireExplorer Ex;
-  DLIList <OCCCoEdge*> coedges;
-  for (Ex.Init(aShape); Ex.More(); Ex.Next())
-      Curve* curve = populate_topology_bridge(Ex.Current());
-      OCCCurve *occ_curve = CAST_TO(curve, OCCCurve);
-      OCCCoEdge * coedge = new OCCCoEdge( curve, loop,
-					  (Ex.Orientation()== TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
-      coedges.append(coedge);
-      occ_curve->add_loop(loop);
-  loop->coedges(coedges);
   return loop;
@@ -1297,6 +1313,10 @@
 			       (TopologyBridge*)curve));
       CurveList->append((OCCCurve*)curve);
+      for (Ex.Init(aShape, TopAbs_VERTEX); Ex.More(); Ex.Next())
+        populate_topology_bridge(TopoDS::Vertex(Ex.Current()));
   else
@@ -1304,9 +1324,6 @@
       curve = (OCCCurve*)(OccToCGM->find(i))->second;
-  for (Ex.Init(aShape, TopAbs_VERTEX); Ex.More(); Ex.Next())
-    populate_topology_bridge(TopoDS::Vertex(Ex.Current()));
   return curve;
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp	2008-03-13 19:27:31 UTC (rev 1648)
+++ cgm/trunk/geom/OCC/OCCShell.cpp	2008-03-13 19:31:27 UTC (rev 1649)
@@ -110,7 +110,7 @@
   if(mySheetSurface)
-    parents.append(mySheetSurface->my_lump());
+    parents.append(mySheetSurface->my_body());
     return;
Modified: cgm/trunk/geom/OCC/OCCSurface.cpp
--- cgm/trunk/geom/OCC/OCCSurface.cpp	2008-03-13 19:27:31 UTC (rev 1648)
+++ cgm/trunk/geom/OCC/OCCSurface.cpp	2008-03-13 19:31:27 UTC (rev 1649)
@@ -676,6 +676,12 @@
      return;
+  if(myShell) //shell body
+    parents.append(myShell);
+    return;
   OCCQueryEngine* oqe = (OCCQueryEngine*) get_geometry_query_engine();
   OCCBody * body = NULL;
   DLIList <OCCBody* > *bodies = oqe->BodyList;
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am	2008-03-13 19:27:31 UTC (rev 1648)
+++ cgm/trunk/test/Makefile.am	2008-03-13 19:31:27 UTC (rev 1649)
@@ -35,4 +35,5 @@
 webcut_LDADD = ../geom/ACIS/libcubit_ACIS.la  $(LDADD)
 makept_LDFLAGS = $(LDFLAGS) -R$(OCC_LIB_DIR)
 makept_LDADD = ../geom/OCC/libcubit_OCC.la $(LDADD)
+modify_LDFLAGS = $(LDFLAGS) -R$(OCC_LIB_DIR)
+modify_LDADD = ../geom/OCC/libcubit_OCC.la $(LDADD)
Modified: cgm/trunk/test/modify.cpp
--- cgm/trunk/test/modify.cpp	2008-03-13 19:27:31 UTC (rev 1648)
+++ cgm/trunk/test/modify.cpp	2008-03-13 19:31:27 UTC (rev 1649)
@@ -143,6 +143,16 @@
   CubitVector v = body2->center_point();
+  CubitStatus rsl = CUBIT_SUCCESS;
+  DLIList<RefEntity*> ref_entity_list;
+  int num_ents_exported=0;
+  const CubitString cubit_version="10.2";
+  const char * filename = "stitch.occ";
+  const char * filetype = "OCC";
+  rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
+                                 num_ents_exported, cubit_version);
   DLIList<Body*> bodies;
   DLIList<RefEntity*>  free_entities;
   gti->bodies(bodies);
@@ -155,5 +165,14 @@
       gti->delete_RefEntity( free_entities.get_and_step());
+  // Read in the geometry from files specified on the command line
+  char *argv = "./stitch.occ";
+  CubitStatus status = read_geometry(1, &argv);
+  if (status == CUBIT_FAILURE) exit(1);
+  bodies.clean_out();
+  free_entities.clean_out();
+  gti->bodies(bodies);
+  gti->get_free_ref_entities(free_entities);
   return stat;
More information about the cgma-dev mailing list
