[cgma-dev] r1638 - cgm/trunk/itaps
tautges at mcs.anl.gov
Fri Mar 7 13:12:40 CST 2008
Author: tautges
Date: 2008-03-07 13:12:39 -0600 (Fri, 07 Mar 2008)
New Revision: 1638
Modified:
cgm/trunk/itaps/iGeom.h
cgm/trunk/itaps/iGeom_CGMA.cc
Log:
Adding commented iGeom.h header. Changing slightly the call signature for getFaceType to match C-Fortran calling convention.
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h 2008-03-06 19:58:48 UTC (rev 1637)
+++ cgm/trunk/itaps/iGeom.h 2008-03-07 19:12:39 UTC (rev 1638)
@@ -1,6 +1,62 @@
#ifndef IGEOM_CBIND_H__
#define IGEOM_CBIND_H__
+ /** \mainpage The ITAPS Geometry Interface iGeom
+ * The ITAPS Geometry Interface iGeom provides a common interface for
+ * accessing geometry and data associated with a mesh. Applications written
+ * to use this interface can use a variety of implementations, choosing
+ * the one that best meets its needs. They can also use tools written
+ * to this interface.
+ * \section ITAPS Data Model
+ * The ITAPS interfaces use a data model composed of four basic data types:\n
+ * \em Entity: basic topological entities in a model, e.g. vertices,
+ * edges, faces, regions. \n
+ * \em Entity \em Set: arbitrary grouping of other entities and sets.
+ * Entity sets also support parent/child relations with other sets which
+ * are distinct from entities contained in those sets. Parent/child links
+ * can be used to embed graph relationships between sets, e.g. to
+ * represent topological relationships between the sets. \n
+ * \em Interface: the object with which model is associated and on which
+ * functions in iGeom are called. \n
+ * \em Tag: application data associated with objects of any of the other
+ * data types. Each tag has a designated name, size, and data type.
+ * \section JTAPS Entity Type
+ * Each entity has a specific Entity Type. The Entity
+ * Type is one of VERTEX, EDGE, FACE, and REGION, and is synonymous with
+ * the topological dimension of the entity. Entity Type is an enumerated
+ * type in the iBase_EntityType enumeration.
+ * \section KTAPS Entity-, Array-, and Iterator-Based Access
+ * The iGeom interface provides functions for accessing entities
+ * individually, as arrays of entities, or using iterators. These access
+ * methods have different memory versus execution time tradeoffs,
+ * depending on the implementation.
+ * \section LTAPS Lists Passed Through Interface
+ * Many of the functions in iGeom have arguments corresponding to lists of
+ * objects. In-type arguments for lists consist of a pointer to an array and
+ * a list size. Lists returned from functions are passed in three arguments,
+ * a pointer to the array representing the list, and pointers to the
+ * allocated and occupied lengths of the array. These three arguments are
+ * inout-type arguments, because they can be allocated by the application and
+ * passed into the interface to hold the results of the function. Lists
+ * which are pre-allocated must be large enough to hold the results of the
+ * function; if this is not the case, an error is generated. Otherwise, the
+ * occupied size is changed to the size output from the function. If a list
+ * argument is unallocated (the list pointer points to a NULL value) or if
+ * the incoming value of the allocated size is zero, the list storage will be
+ * allocated by the implementation. IN ALL CASES, MEMORY ALLOCATED BY ITAPS
+ * INTERFACE IMPLEMENTATIONS IS DONE USING THE C MALLOC FUNCTION, AND CAN BE
+ * DE-ALLOCATED USING THE C FREE FUNCTION.
#ifndef ITAPS
#define ITAPS
#endif
@@ -12,1406 +68,3117 @@
extern "C" {
#endif
-typedef void* iGeom_Instance;
-typedef void* iGeom_EntityIterator;
-typedef void* iGeom_EntityArrIterator;
+ /**\brief Type used to store iGeom interface handle
+ * Type used to store iGeom interface handle
+ typedef void* iGeom_Instance;
-void iGeom_getDescription( iGeom_Instance instance,
- char* descr,
- int* err,
- int descr_len );
+ /**\brief Type used to store an iterator returned by iGeom
+ * Type used to store an iterator returned by iGeom
+ typedef void* iGeom_EntityIterator;
-void iGeom_newGeom( char const* options,
- iGeom_Instance* instance_out,
- int* err,
- int options_len );
+ /**\brief Type used to store an array iterator returned by iGeom
+ * Type used to store an array iterator returned by iGeom
+ typedef void* iGeom_EntityArrIterator;
-void iGeom_dtor( iGeom_Instance instance, int* err );
+ /**\brief Get a description of the error returned from the last iGeom function
+ * Get a description of the error returned from the last iGeom function
+ * \param instance iGeom instance handle
+ * \param descr Pointer to a character string to be filled with a
+ * description of the error from the last iGeom function
+ * \param *err Pointer to error type returned from function
+ * \param descr_len Length of the character string pointed to by descr
+ void iGeom_getDescription( iGeom_Instance instance,
+ char* descr,
+ int* err,
+ int descr_len );
+ /**\brief Get the error type returned from the last iGeom function
+ * Get the error type returned from the last iGeom function. Value
+ * returned is a member of the iBase_ErrorType enumeration.
+ * \param *error_type Error type returned from last iGeom function
+ void iGeom_getErrorType(iGeom_Instance instance,
+ /*out*/ int *error_type,
+ int *err);
-void iGeom_load( iGeom_Instance,
- char const* name,
- char const* options,
- int* err,
- int name_len,
+ /**\brief Construct a new iGeom instance
+ * Construct a new iGeom instance, using implementation-specific
+ * options
+ * \param options Pointer to implementation-specific options string
+ * \param instance Pointer to iGeom instance handle returned from function
+ * \param options_len Length of the character string pointed to by options
+ void iGeom_newGeom( char const* options,
+ iGeom_Instance* instance_out,
+ int* err,
+ int options_len );
-void iGeom_save( iGeom_Instance,
- char const* name,
- int* err,
- int name_len,
+ /**\brief Destroy an iGeom instance
+ * Destroy an iGeom instance
+ * \param instance iGeom instance to be destroyed
+ void iGeom_dtor( iGeom_Instance instance, int* err );
-void iGeom_getRootSet( iGeom_Instance,
- iBase_EntitySetHandle* root_set,
- int* err );
-void iGeom_getBoundBox( iGeom_Instance,
- double* min_x,
- double* min_y,
- double* min_z,
- double* max_x,
- double* max_y,
- double* max_z,
- int* err );
+ /**\brief Load a geom from a file
+ * Load a geom from a file. If entity set is specified, loaded geom
+ * is added to that set; specify zero if that is not desired.
+ * \param entity_set_handle Set to which loaded geom will be added, zero
+ * if not desired
+ * \param name File name from which geom is to be loaded
+ * \param name_len Length of the file name character string
+ * \param options_len Length of the options character string
+ void iGeom_load( iGeom_Instance,
+ char const* name,
+ char const* options,
+ int* err,
+ int name_len,
-void iGeom_getEntities( iGeom_Instance instance,
- iBase_EntitySetHandle set_handle,
- int entity_type,
- iBase_EntityHandle** entity_handles,
- int* entity_handles_allococated,
- int* entity_handles_size,
- int* err );
+ /**\brief Save a geom to a file
+ * Save a geom to a file. If entity set is specified, save only the
+ * geom contained in that set.
+ * \param entity_set_handle Entity set being saved
+ * \param name File name to which geom is to be saved
+ void iGeom_save( iGeom_Instance,
+ char const* name,
+ int* err,
+ int name_len,
-void iGeom_getNumOfType( iGeom_Instance instance,
- int entity_type,
- int* num_out,
+ /**\brief Get handle of the root set for this instance
+ * Get handle of the root set for this instance. All geom in
+ * this instance can be accessed from this set.
+ * \param root_set Pointer to set handle returned from function
+ void iGeom_getRootSet( iGeom_Instance,
+ iBase_EntitySetHandle* root_set,
int* err );
-void iGeom_getArrType( iGeom_Instance instance,
- iBase_EntityHandle const* entity_handles,
- int entity_handles_size,
- int** type,
- int* type_allocated,
- int* type_size,
- int* err );
+/**\brief Get the bounding box of the entire model
+ * Get the bounding box of the entire model
+ * \param min_x Minimum coordinate of bounding box
+ * \param min_y Minimum coordinate of bounding box
+ * \param min_z Minimum coordinate of bounding box
+ * \param max_x Maximum coordinate of bounding box
+ * \param max_y Maximum coordinate of bounding box
+ * \param max_z Maximum coordinate of bounding box
+ void iGeom_getBoundBox( iGeom_Instance,
+ double* min_x,
+ double* min_y,
+ double* min_z,
+ double* max_x,
+ double* max_y,
+ double* max_z,
+ int* err );
-void iGeom_getEntAdj( iGeom_Instance instance,
- iBase_EntityHandle entity_handle,
- int to_dimension,
- iBase_EntityHandle** adj_entities,
- int* adj_entities_allocated,
- int* adj_entities_size,
- int* err );
+ /**\brief Get entities of specific type and/or topology in set or instance
+ * Get entities of specific type and/or topology in set or instance. All
+ * entities of a given type or topology are requested by specifying
+ * iBase_ALL_TOPOLOGIES or iBase_ALL_TYPES, respectively. Specified type
+ * or topology must be a value in the iBase_EntityType or iBase_EntityTopology
+ * enumeration, respectively.
+ * \param entity_set_handle Entity set being queried
+ * \param entity_type Type of entities being requested
+ * \param entity_topology Topology of entities being requested
+ * \param *entity_handles Pointer to array of entity handles returned
+ * from function
+ * \param *entity_handles_allocated Pointer to allocated size of
+ * entity_handles array
+ * \param *entity_handles_size Pointer to occupied size of entity_handles array
+ void iGeom_getEntities( iGeom_Instance instance,
+ iBase_EntitySetHandle set_handle,
+ int entity_type,
+ iBase_EntityHandle** entity_handles,
+ int* entity_handles_allococated,
+ int* entity_handles_size,
+ int* err );
-void iGeom_getArrAdj( iGeom_Instance instance,
- int requested_entity_type,
- iBase_EntityHandle** adj_entity_handles,
- int* adj_entity_handles_allocated,
- int* adj_entity_handles_size,
- int** offset,
- int* offset_allocated,
- int* offset_size,
- int* err );
+ /**\brief Get the number of entities with the specified type in the instance or set
+ * Get the number of entities with the specified type in the instance
+ * or set. If entity set handle is zero, return information for instance,
+ * otherwise for set. Value of entity type must be from the
+ * iBase_EntityType enumeration. If iBase_ALL_TYPES is specified,
+ * total number of entities (excluding entity sets) is returned.
+ * \param entity_type Type of entity requested
+ * \param num_type Pointer to number of entities, returned from function
+ void iGeom_getNumOfType( iGeom_Instance instance,
+ int entity_type,
+ int* num_out,
+ int* err );
-void iGeom_getEnt2ndAdj( iGeom_Instance instance,
- int bridge_dimension,
- int to_dimension,
- iBase_EntityHandle** adjacent_entities,
- int* adjacent_entities_allocated,
- int* adjacent_entities_size,
- int* err );
-void iGeom_getArr2ndAdj( iGeom_Instance instance,
+ /**\brief Get the entity type for the specified entities
+ * Get the entity type for the specified entities. Types
+ * returned are values in the iBase_EntityType enumeration.
+ * \param entity_handles Array of entity handles being queried
+ * \param entity_handles_size Number of entities in entity_handles array
+ * \param *type Pointer to array of types returned from function
+ * \param *type_allocated Pointer to allocated size of type array
+ * \param *type_size Pointer to occupied size of type array
+ void iGeom_getArrType( iGeom_Instance instance,
- int order_adjacent_key,
- int** offset,
- int* offset_size,
+ int** type,
+ int* type_allocated,
+ int* type_size,
int* err );
-void iGeom_isEntAdj( iGeom_Instance instance,
- iBase_EntityHandle entity_handle1,
- iBase_EntityHandle entity_handle2,
- int* are_adjacent,
- int* err );
+ /**\brief Get entities of specified type adjacent to an entity
+ * Get entities of specified type adjacent to an entity. Specified type
+ * must be value in the iBase_EntityType enumeration.
+ * \param entity_handle Entity handle being queried
+ * \param entity_type_requested Type of adjacent entities requested
+ * \param *adj_entity_handles Pointer to array of adjacent entities
+ * returned from function
+ * \param *adj_entity_handles_allocated Pointer to allocated size of
+ * adj_entity_handles array
+ * \param *adj_entity_handles_size Pointer to occupied size of
+ void iGeom_getEntAdj( iGeom_Instance instance,
+ iBase_EntityHandle entity_handle,
+ int to_dimension,
+ iBase_EntityHandle** adj_entities,
+ int* adj_entities_allocated,
+ int* adj_entities_size,
+ int* err );
-void iGeom_isArrAdj( iGeom_Instance instance,
- iBase_EntityHandle const* entity_handles_1,
- int entity_handles_1_size,
- iBase_EntityHandle const* entity_handles_2,
- int entity_handles_2_size,
- int** is_adjacent_info,
- int* is_adjacent_info_allocated,
- int* is_adjacent_info_size,
- int* err );
+ /**\brief Get entities of specified type adjacent to entities
+ * Get entities of specified type adjacent to entities. Specified type
+ * must be value in the iBase_EntityType enumeration. \em offset(i) is
+ * index of first entity in adjacentEntityHandles array adjacent to
+ * entity_handles[i].
+ * \param *adjacentEntityHandles Pointer to array of adjacentEntityHandles
+ * \param *adjacentEntityHandles_allocated Pointer to allocated size of
+ * adjacentEntityHandles array
+ * \param *offset Pointer to array of offsets returned from function
+ * \param *offset_allocated Pointer to allocated size of offset array
+ * \param *offset_size Pointer to occupied size of offset array
+ void iGeom_getArrAdj( iGeom_Instance instance,
+ iBase_EntityHandle const* entity_handles,
+ int entity_handles_size,
+ int requested_entity_type,
+ iBase_EntityHandle** adj_entity_handles,
+ int* adj_entity_handles_allocated,
+ int* adj_entity_handles_size,
+ int** offset,
+ int* offset_allocated,
+ int* offset_size,
+ int* err );
-void iGeom_getTopoLevel( iGeom_Instance instance,
- int* topo_level_out,
- int* err );
+/**\brief Get "2nd order" adjacencies to an entity
+ * Get "2nd order" adjacencies to an entity, that is, from an entity, through
+ * other entities of a specified "bridge" dimension, to other entities of another
+ * specified "to" dimension.
+ * \param entity_handle Entity from which adjacencies are requested
+ * \param bridge_dimension Bridge dimension for 2nd order adjacencies
+ * \param to_dimension Dimension of adjacent entities returned
+ * \param adjacent_entities Adjacent entities
+ * \param adjacent_entities_allocated Allocated size of returned array
+ * \param adjacent_entities_size Occupied size of returned array
+ * \param err
+ void iGeom_getEnt2ndAdj( iGeom_Instance instance,
+ int bridge_dimension,
+ int to_dimension,
+ iBase_EntityHandle** adjacent_entities,
+ int* adjacent_entities_allocated,
+ int* adjacent_entities_size,
+ int* err );
-void iGeom_getEntClosestPt( iGeom_Instance instance,
- double near_x,
- double near_y,
- double near_z,
- double* on_x,
- double* on_y,
- double* on_z,
- int* err );
+/**\brief Get "2nd order" adjacencies to an array of entities
+ * Get "2nd order" adjacencies to an array of entities, that is, from each entity, through
+ * \param entity_handles Entities from which adjacencies are requested
+ * \param entity_handles_size Number of entities whose adjacencies are requested
+ * \param adj_entity_handles Adjacent entities
+ * \param adj_entity_handles_allocated Allocated size of returned array
+ * \param adj_entity_handles_size Occupied size of returned array
+ * \param offset Offset[i] is offset into adj_entity_handles of 2nd order
+ * adjacencies of ith entity in entity_handles
+ * \param offset_allocated Allocated size of offset array
+ * \param offset_size Occupied size of offset array
+ * \param err
+ void iGeom_getArr2ndAdj( iGeom_Instance instance,
+ int order_adjacent_key,
+ int** offset,
+ int* offset_size,
+ int* err );
-void iGeom_getArrClosestPt( iGeom_Instance instance,
- int storage_order,
- double const* near_coordinates,
- int near_coordinates_size,
- double** on_coordinates,
- int* on_coordinates_allocated,
- int* on_coordinates_size,
- int* err );
+/**\brief Return whether two entities are adjacent
+ * Return whether two entities are adjacent.
+ * \param entity_handle1 First entity queried
+ * \param entity_handle2 Second entity queried
+ * \param are_adjacent If returned non-zero, entities are adjacent, otherwise
+ * they are not
+ * \param err
+ void iGeom_isEntAdj( iGeom_Instance instance,
+ iBase_EntityHandle entity_handle1,
+ iBase_EntityHandle entity_handle2,
+ int* are_adjacent,
+ int* err );
-void iGeom_getEntNrmlXYZ( iGeom_Instance,
- double x,
- double y,
- double z,
- double* nrml_i,
- double* nrml_j,
- double* nrml_k,
- int* err );
+/**\brief Return whether entity pairs are adjacent
+ * Return whether entity pairs are adjacent, i.e. if entity_handles_1[i] is
+ * adjacent to entity_handles_2[i]. This function requires entity_handles_1_size
+ * and entity_handles_2_size to be equal.
+ * \param entity_handles_1 First array of entities
+ * \param entity_handles_1_size Number of entities in first array
+ * \param entity_handles_2 Second array of entities
+ * \param entity_handles_2_size Number of entities in second array
+ * \param is_adjacent_info Array of flags returned from function
+ * \param is_adjacent_info_allocated Allocated size of flags array
+ * \param is_adjacent_info_size Occupied size of flags array
+ void iGeom_isArrAdj( iGeom_Instance instance,
+ iBase_EntityHandle const* entity_handles_1,
+ int entity_handles_1_size,
+ iBase_EntityHandle const* entity_handles_2,
+ int entity_handles_2_size,
+ int** is_adjacent_info,
+ int* is_adjacent_info_allocated,
+ int* is_adjacent_info_size,
+ int* err );
-void iGeom_getArrNrmlXYZ( iGeom_Instance,
- double const* coordinates,
- int coordinates_size,
- double** normals,
- int* normals_allocated,
- int* normals_size,
- int* err );
+/**\brief DON'T KNOW WHAT THIS FUNCTION IS
+ * \param topo_level_out
+ void iGeom_getTopoLevel( iGeom_Instance instance,
+ int* topo_level_out,
+ int* err );
-void iGeom_getEntNrmlPlXYZ( iGeom_Instance,
+/**\brief Get closest point to an entity
+ * Get closest point to a specified position on an entity
+ * \param entity_handle Entity being queried
+ * \param near_x Coordinates of starting point
+ * \param near_y Coordinates of starting point
+ * \param near_z Coordinates of starting point
+ * \param on_x Closest point on entity
+ * \param on_y Closest point on entity
+ * \param on_z Closest point on entity
+ void iGeom_getEntClosestPt( iGeom_Instance instance,
+ double near_x,
+ double near_y,
+ double near_z,
+ double* on_x,
+ double* on_y,
+ double* on_z,
+ int* err );
+/**\brief Get closest point for an array of entities and points
+ * Get closest point for an array of entities and points. If either the number
+ * of entities or number of coordinate triples is unity, then all points or
+ * entities are queried for that entity or point, respectively, otherwise each
+ * point corresponds to each entity. storage_order should be a value in
+ * the iBase_StorageOrder enum; if input as iBase_UNKNOWN, order is in native order
+ * with respect to implementation.
+ * \param entity_handles Entity(ies) being queried
+ * \param entity_handles_size Number of entities being queried
+ * \param storage_order Storage order of input points
+ * \param near_coordinates Coordinates of starting point(s)
+ * \param near_coordinates_size Number of values in near_coordinates array
+ * \param on_coordinates Coordinates of closest points
+ * \param on_coordinates_allocated Allocated size of closest point array
+ * \param on_coordinates_size Occupied size of closest point array
+ void iGeom_getArrClosestPt( iGeom_Instance instance,
+ int storage_order,
+ double const* near_coordinates,
+ int near_coordinates_size,
+ double** on_coordinates,
+ int* on_coordinates_allocated,
+ int* on_coordinates_size,
+ int* err );
+/**\brief Get the normal vector on an entity at the given position
+ * Get the normal vector on an entity at the given position.
+ * \param x Coordinates of starting point
+ * \param y Coordinates of starting point
+ * \param z Coordinates of starting point
+ * \param nrml_i Normal vector at starting point
+ * \param nrml_j Normal vector at starting point
+ * \param nrml_k Normal vector at starting point
+ void iGeom_getEntNrmlXYZ( iGeom_Instance,
double x,
double y,
double z,
- double* pt_x,
- double* pt_y,
- double* pt_z,
double* nrml_i,
double* nrml_j,
double* nrml_k,
int* err );
-void iGeom_getArrNrmlPlXYZ( iGeom_Instance,
+/**\brief Get the normal vector on an entity(ies) at given position(s)
+ * Get the normal vector on an entity(ies) at given position(s). If either the
+ * number of entities or number of coordinate triples is unity, then all points or
+ * \param storage_order Storage order of coordinates
+ * \param coordinates Starting coordinates
+ * \param coordinates_size Number of values in coordinates array
+ * \param normals Normal coordinates
+ * \param normals_allocated Allocated size of normals array
+ * \param normals_size Occupied size of normals array
+ void iGeom_getArrNrmlXYZ( iGeom_Instance,
int storage_order,
+ double const* coordinates,
+ int coordinates_size,
double** normals,
int* normals_size,
int* err );
-void iGeom_getEntTgntXYZ( iGeom_Instance,
- double x,
- double y,
- double z,
- double* tgnt_i,
- double* tgnt_j,
- double* tgnt_k,
- int* err );
+/**\brief Get the normal vector AND closest point on an entity at given position
+ * Get the normal vector AND closest point on an entity at a given position.
+ * \param x Starting coordinates
+ * \param y Starting coordinates
+ * \param z Starting coordinates
+ * \param pt_x Closest point
+ * \param pt_y Closest point
+ * \param pt_z Closest point
+ * \param nrml_i Normal at closest point
+ * \param nrml_j Normal at closest point
+ * \param nrml_k Normal at closest point
+ void iGeom_getEntNrmlPlXYZ( iGeom_Instance,
+ double x,
+ double y,
+ double z,
+ double* pt_x,
+ double* pt_y,
+ double* pt_z,
+ double* nrml_i,
+ double* nrml_j,
+ double* nrml_k,
+ int* err );
-void iGeom_getArrTgntXYZ( iGeom_Instance,
- double** tangents,
- int* tangents_allocated,
- int* tangents_size,
- int* err );
+/**\brief Get the normal vector AND closest point on an entity(ies) at given position(s)
+ * Get the normal vector AND closest point on an entity(ies) at given position(s). If either the
+ * \param entity_handles_size Number of entity(ies) being queried
+ * \param storage_order Storage order in near_coordinates array
+ * \param near_coordinates Starting coordinates
+ * \param on_coordinates Closest point array
+ * \param normals Normal array
+ * \param normals_allocated Allocated size of normal array
+ * \param normals_size Occupied size of normal array
+ void iGeom_getArrNrmlPlXYZ( iGeom_Instance,
+ double** normals,
+ int* normals_allocated,
+ int* normals_size,
+ int* err );
-void iGeom_getFcCvtrXYZ( iGeom_Instance,
- iBase_EntityHandle face_handle,
- double x,
- double y,
- double z,
- double* cvtr1_i,
- double* cvtr1_j,
- double* cvtr1_k,
- double* cvtr2_i,
- double* cvtr2_j,
- double* cvtr2_k,
- int* err );
+/**\brief Get the tangent vector on an entity at given position
+ * Get the tangent vector on an entity at a given position.
+ * \param tgnt_i Tangent at closest point
+ * \param tgnt_j Tangent at closest point
+ * \param tgnt_k Tangent at closest point
+ void iGeom_getEntTgntXYZ( iGeom_Instance,
+ double x,
+ double y,
+ double z,
+ double* tgnt_i,
+ double* tgnt_j,
+ double* tgnt_k,
+ int* err );
-void iGeom_getEgCvtrXYZ( iGeom_Instance,
- iBase_EntityHandle edge_handle,
- double x,
- double y,
- double z,
- double* cvtr_i,
- double* cvtr_j,
- double* cvtr_k,
- int* err );
+/**\brief Get the tangent vector on an entity(ies) at given position(s)
+ * Get the tangent vector on an entity(ies) at given position(s). If either the
+ * \param tangents Tangent coordinates
+ * \param tangents_allocated Allocated size of tangents array
+ * \param tangents_size Occupied size of tangents array
+ void iGeom_getArrTgntXYZ( iGeom_Instance,
+ double** tangents,
+ int* tangents_allocated,
+ int* tangents_size,
+ int* err );
-void iGeom_getEntArrCvtrXYZ( iGeom_Instance,
+/**\brief Get the two principle curvature vectors for a face at a point
+ * Get the two principle curvature vectors for a face at a point. Magnitudes of
+ * vectors are curvature, directions are directions of principal curvatures.
+ * \param face_handle Face being queried
+ * \param x Position being queried
+ * \param y Position being queried
+ * \param z Position being queried
+ * \param cvtr1_i Maximum curvature vector
+ * \param cvtr1_j Maximum curvature vector
+ * \param cvtr1_k Maximum curvature vector
+ * \param cvtr2_i Minimum curvature vector
+ * \param cvtr2_j Minimum curvature vector
+ * \param cvtr2_k Minimum curvature vector
+ void iGeom_getFcCvtrXYZ( iGeom_Instance,
+ iBase_EntityHandle face_handle,
+ double x,
+ double y,
+ double z,
+ double* cvtr1_i,
+ double* cvtr1_j,
+ double* cvtr1_k,
+ double* cvtr2_i,
+ double* cvtr2_j,
+ double* cvtr2_k,
+ int* err );
+/**\brief Get the principle curvature vector for an edge at a point
+ * Get the principle curvature vector for an edge at a point. Magnitude of
+ * vector is the curvature, direction is direction of principal curvature.
+ * \param edge_handle Edge being queried
+ * \param cvtr_i Maximum curvature vector
+ * \param cvtr_j Maximum curvature vector
+ * \param cvtr_k Maximum curvature vector
+ void iGeom_getEgCvtrXYZ( iGeom_Instance,
+ iBase_EntityHandle edge_handle,
+ double x,
+ double y,
+ double z,
+ double* cvtr_i,
+ double* cvtr_j,
+ double* cvtr_k,
+ int* err );
+/**\brief Get the curvature(s) on an entity(ies) at given position(s)
+ * Get the curvature(s) on an entity(ies) at given position(s). If either the
+ * \param coords Starting coordinates
+ * \param coords_size Number of values in coordinates array
+ * \param cvtr_1 First principal curvatures
+ * \param cvtr_1_allocated Allocated size of first curvature array
+ * \param cvtr_1_size Occupied size of first curvature array
+ * \param cvtr_2 Second principal curvatures
+ * \param cvtr_2_allocated Allocated size of second curvature array
+ * \param cvtr_2_size Occupied size of second curvature array
+ void iGeom_getEntArrCvtrXYZ( iGeom_Instance,
+ double const* coords,
+ int coords_size,
+ double** cvtr_1,
+ int* cvtr_1_allocated,
+ int* cvtr_1_size,
+ double** cvtr_2,
+ int* cvtr_2_allocated,
+ int* cvtr_2_size,
+ int* err );
+/**\brief Get closest point, tangent, and curvature of edge
+ * Get closest point, tangent, and curvature of edge.
+ * \param x Point at which entity is being queried
+ * \param y Point at which entity is being queried
+ * \param z Point at which entity is being queried
+ * \param on_x Closest point at point being queried
+ * \param on_y Closest point at point being queried
+ * \param on_z Closest point at point being queried
+ * \param tgnt_i Tangent at point being queried
+ * \param tgnt_j Tangent at point being queried
+ * \param tgnt_k Tangent at point being queried
+ * \param cvtr_i Curvature at point being queried
+ * \param cvtr_j Curvature at point being queried
+ * \param cvtr_k Curvature at point being queried
+ void iGeom_getEgEvalXYZ( iGeom_Instance,
+ double x,
+ double y,
+ double z,
+ double* on_x,
+ double* on_y,
+ double* on_z,
+ double* tgnt_i,
+ double* tgnt_j,
+ double* tgnt_k,
+ double* cvtr_i,
+ double* cvtr_j,
+ double* cvtr_k,
+ int* err );
+/**\brief Get closest point, tangent, and curvature of face
+ * Get closest point, tangent, and curvature of face. If any of input
+ * coordinate pointers are NULL, that value is not returned.
+ * \param nrml_i Normal at point being queried
+ * \param nrml_j Normal at point being queried
+ * \param nrml_k Normal at point being queried
+ * \param cvtr1_i First principal curvature at point being queried
+ * \param cvtr1_j First principal curvature at point being queried
+ * \param cvtr1_k First principal curvature at point being queried
+ * \param cvtr2_i Second principal curvature at point being queried
+ * \param cvtr2_j Second principal curvature at point being queried
+ * \param cvtr2_k Second principal curvature at point being queried
+ void iGeom_getFcEvalXYZ( iGeom_Instance,
+ double x,
+ double y,
+ double z,
+ double* on_x,
+ double* on_y,
+ double* on_z,
+ double* nrml_i,
+ double* nrml_j,
+ double* nrml_k,
+ double* cvtr1_i,
+ double* cvtr1_j,
+ double* cvtr1_k,
+ double* cvtr2_i,
+ double* cvtr2_j,
+ double* cvtr2_k,
+ int* err );
+/**\brief Get the closest point(s), tangent(s), and curvature(s) on an entity(ies) at given position(s)
+ * Get the closest point(s), tangent(s), and curvature(s) on an entity(ies) at given position(s).
+ * If either the number of entities or number of coordinate triples is unity, then all points or
+ * \param edge_handles Edge(s) being queried
+ * \param edge_handles_size Number of edges being queried
+ * \param on_coords Closest point array
+ * \param on_coords_allocated Allocated size of closest point array
+ * \param on_coords_size Occupied size of closest point array
+ * \param tangent Tangent array
+ * \param tangent_allocated Allocated size of tangent array
+ * \param tangent_size Occupied size of tangent array
+ * \param cvtr First principal curvatures
+ * \param cvtr_allocated Allocated size of first curvature array
+ * \param cvtr_size Occupied size of first curvature array
+ void iGeom_getArrEgEvalXYZ( iGeom_Instance,
+ iBase_EntityHandle const* edge_handles,
+ int edge_handles_size,
+ int coords_size,
+ double** on_coords,
+ int* on_coords_allocated,
+ int* on_coords_size,
+ double** tangent,
+ int* tangent_allocated,
+ int* tangent_size,
+ double** cvtr,
+ int* cvtr_allocated,
+ int* cvtr_size,
+ int* err );
+ * \param normal Normal array
+ * \param normal_allocated Allocated size of normal array
+ * \param normal_size Occupied size of normal array
+ void iGeom_getArrFcEvalXYZ( iGeom_Instance,
+ iBase_EntityHandle const* face_handles,
+ int face_handles_size,
+ int coords_size,
+ double** normal,
+ int* normal_allocated,
+ int* normal_size,
+ double** cvtr1,
+ int* cvtr1_allocated,
+ int* cvtr1_size,
+ double** cvtr2,
+ int* cvtr2_allocated,
+ int* cvtr2_size,
+ int* err );
+/**\brief Get the bounding box of the specified entity
+ * Get the bounding box of the specified entity
+ void iGeom_getEntBoundBox( iGeom_Instance,
+ double* min_x,
+ double* min_y,
+ double* min_z,
+ double* max_x,
+ double* max_y,
+ double* max_z,
+ int* err );
+/**\brief Get the bounding box of the specified entities
+ * Get the bounding box of the specified entities. Storage order passed back
+ * will be member of iBase_StorageOrder enum.
+ * \param entity_handles Entity handles being queried
+ * \param enttiy_handles_size Number of entities being queried
+ * \param storage_order Storage order of coordinates passed back
+ * \param min_corner Minimum coordinates of bounding boxes
+ * \param min_corner_allocated Allocated size of minimum coordinates array
+ * \param min_corner_size Occupied size of minimum coordinates array
+ * \param max_corner Maximum coordinates of bounding boxes
+ * \param max_corner_allocated Allocated size of maximum coordinates array
+ * \param max_corner_size Occupied size of maximum coordinates array
+ void iGeom_getArrBoundBox( iGeom_Instance,
- double const* coords,
- int coords_size,
- double** cvtr_1,
- int* cvtr_1_allocated,
- int* cvtr_1_size,
- double** cvtr_2,
- int* cvtr_2_allocated,
- int* cvtr_2_size,
+ int* storage_order,
+ double** min_corner,
+ int* min_corner_allocated,
+ int* min_corner_size,
+ double** max_corner,
+ int* max_corner_allocated,
+ int* max_corner_size,
int* err );
-void iGeom_getEgEvalXYZ( iGeom_Instance,
- double x,
- double y,
- double z,
- double* on_x,
- double* on_y,
- double* on_z,
- double* tgnt_i,
- double* tgnt_j,
- double* tgnt_k,
- double* cvtr_i,
- double* cvtr_j,
- double* cvtr_k,
- int* err );
+ /**\brief Get coordinates of specified vertex
+ * Get coordinates of specified vertex.
+ * \param vertex_handle Geom vertex being queried
+ * \param *x Pointer to x coordinate returned from function
+ * \param *y Pointer to y coordinate returned from function
+ * \param *z Pointer to z coordinate returned from function
+ void iGeom_getVtxCoord( iGeom_Instance,
+ iBase_EntityHandle vertex_handle,
+ double* x,
+ double* y,
+ double* z,
+ int* err );
-void iGeom_getFcEvalXYZ( iGeom_Instance,
+ /**\brief Get coordinates of specified vertices
+ * Get coordinates of specified vertices. If storage order is passed in
+ * with a value other than iBase_UNDETERMINED, coordinates are returned
+ * in the specified storage order, otherwise storage order is that native
+ * to the implementation. Storage order of returned coordinates is also
+ * returned.
+ * \param vertex_handles Array of geom vertex handles whose coordinates are
+ * being requested
+ * \param vertex_handles_size Number of vertices in vertex_handles array
+ * \param storage_order Pointer to storage order requested/returned from
+ * function
+ * \param *coords Pointer to array of coordinates returned from function
+ * \param *coords_allocated Pointer to allocated size of coords array
+ * \param *coords_size Pointer to occupied size of coords array
+ void iGeom_getVtxArrCoords( iGeom_Instance,
+ double** coordinates,
+ int* coordinates_allocated,
+ int* coordinates_size,
+ int* err );
+/**\brief Intersect a ray with the model
+ * Intersect a ray with the model. Storage orders passed back are members of the
+ * iBase_StorageOrder enumeration; if output is iBase_UNKNOWN, order is in native order
+ * \param x Point from which ray is fired
+ * \param y Point from which ray is fired
+ * \param z Point from which ray is fired
+ * \param dir_x Direction in which ray is fired
+ * \param dir_y Direction in which ray is fired
+ * \param dir_z Direction in which ray is fired
+ * \param intersect_entity_handles Entities intersected by ray
+ * \param intersect_entity_handles_allocated Allocated size of intersections array
+ * \param intersect_entity_hangles_size Occupied size of intersections array
+ * \param intersect_coords Coordinates of intersections
+ * \param intersect_coords_allocated Allocated size of coordinates array
+ * \param intersect_coords_size Occupied size of coordinates array
+ * \param param_coords Distances along ray of intersections
+ * \param param_coords_allocated Allocated size of param_coords array
+ * \param param_coords_size Occupied size of param_coords array
+ void iGeom_getPntRayIntsct( iGeom_Instance,
+ double x,
+ double y,
+ double z,
+ double dir_x,
+ double dir_y,
+ double dir_z,
+ iBase_EntityHandle** intersect_entity_handles,
+ int* intersect_entity_handles_allocated,
+ int* intersect_entity_hangles_size,
+ double** intersect_coords,
+ int* intersect_coords_allocated,
+ int* intersect_coords_size,
+ double** param_coords,
+ int* param_coords_allocated,
+ int* param_coords_size,
+ int* err );
+/**\brief Intersect an array of rays with the model
+ * Intersect an array of rays with the model. Storage orders passed back are members of the
+ * iBase_StorageOrder enumeration; if input/output is iBase_UNKNOWN, order is in native order
+ * \param storage_order Storage order of input coordinates
+ * \param coords Points from which rays are fired
+ * \param coords_size Number of points from which rays are fired
+ * \param directions Directions in which rays are fired
+ * \param directions_size Number of coordinates in directions array
+ * \param offset Offset[i] is offset into intersect_entity_handles of ith ray
+ void iGeom_getPntArrRayIntsct( iGeom_Instance,
+ const double* coords,
+ int coords_size,
+ const double* directions,
+ int directions_size,
+ int** offset,
+ int* offset_size,
+ int* err );
+/**\brief Get the entity on which a point is located
+ * Get the entity on which a point is located
+ * \param x Point being queried
+ * \param y Point being queried
+ * \param z Point being queried
+ * \param entity_handle Entity on which point is located
+ void iGeom_getPntClsf( iGeom_Instance,
double x,
double y,
double z,
- double* on_x,
- double* on_y,
- double* on_z,
- double* nrml_i,
- double* nrml_j,
- double* nrml_k,
- double* cvtr1_i,
- double* cvtr1_j,
- double* cvtr1_k,
- double* cvtr2_i,
- double* cvtr2_j,
- double* cvtr2_k,
+ iBase_EntityHandle* entity_handle,
int* err );
-void iGeom_getArrEgEvalXYZ( iGeom_Instance,
- iBase_EntityHandle const* edge_handles,
- int edge_handles_size,
+/**\brief Get the entities on which points are located
+ * Get the entities on which points are located. Storage orders should be members of the
+ * iBase_StorageOrder enumeration; if input is iBase_UNKNOWN, order is in native order
+ * \param storage_order Storage order of coordinates in coords
+ * \param coords Points being queried
+ * \param coords_size Number of entries in coords array
+ * \param entity_handles Entities on which points are located
+ * \param entity_handles_allocated Allocated size of entity_handles array
+ * \param entity_handles_size Occupied size of entity_handles array
+ void iGeom_getPntArrClsf( iGeom_Instance,
int storage_order,
int coords_size,
- double** on_coords,
- int* on_coords_allocated,
- int* on_coords_size,
- double** tangent,
- int* tangent_allocated,
- int* tangent_size,
- double** cvtr,
- int* cvtr_allocated,
- int* cvtr_size,
+ int* entity_handles_allocated,
int* err );
-void iGeom_getArrFcEvalXYZ( iGeom_Instance,
- iBase_EntityHandle const* face_handles,
- int face_handles_size,
- int coords_size,
- double** normal,
- int* normal_allocated,
- int* normal_size,
- double** cvtr1,
- int* cvtr1_allocated,
- int* cvtr1_size,
- double** cvtr2,
- int* cvtr2_allocated,
- int* cvtr2_size,
- int* err );
+/**\brief Get the sense of a face with respect to a region
+ * Get the sense of a face with respect to a region. Sense returned is -1, 0, or 1,
+ * representing "reversed", "both", or "forward". "both" sense indicates that face bounds
+ * the region once with each sense.
+ * \param face Face being queried
+ * \param region Region being queried
+ * \param sense_out Sense of face with respect to region
+ void iGeom_getEntNrmlSense( iGeom_Instance,
+ iBase_EntityHandle face,
+ iBase_EntityHandle region,
+ int* sense_out,
+ int* err );
-void iGeom_getEntBoundBox( iGeom_Instance,
- double* min_x,
- double* min_y,
- double* min_z,
- double* max_x,
- double* max_y,
- double* max_z,
- int* err );
+/**\brief Get the senses of an array of faces with respect to an array of regions
+ * Get the senses of an array of faces with respect to an array of regions. Sense returned
+ * is -1, 0, or 1, representing "reversed", "both", or "forward". "both" sense indicates
+ * that face bounds the region once with each sense.
+ * \param face_handles Faces being queried
+ * \param face_handles_size Size of face handles array
+ * \param region_handles Regions being queried
+ * \param region_handles_size Size of region handles array
+ * \param sense Senses of faces with respect to regions
+ * \param sense_allocated Allocated size of senses array
+ * \param sense_size Occupied size of senses array
+ void iGeom_getArrNrmlSense( iGeom_Instance,
+ iBase_EntityHandle const* region_handles,
+ int region_handles_size,
+ int** sense,
+ int* sense_allocated,
+ int* sense_size,
+ int* err );
-void iGeom_getArrBoundBox( iGeom_Instance,
- int* storage_order,
- double** min_corner,
- int* min_corner_allocated,
- int* min_corner_size,
- double** max_corner,
- int* max_corner_allocated,
- int* max_corner_size,
+/**\brief Get the sense of an edge with respect to a face
+ * Get the sense of an edge with respect to a face. Sense returned is -1, 0, or 1,
+ * representing "reversed", "both", or "forward". "both" sense indicates that edge bounds
+ * the face once with each sense.
+ * \param edge Edge being queried
+ * \param sense_out Sense of edge with respect to face
+ void iGeom_getEgFcSense( iGeom_Instance,
+ iBase_EntityHandle edge,
+ int* sense_out,
int* err );
-void iGeom_getVtxCoord( iGeom_Instance,
- iBase_EntityHandle vertex_handle,
- double* x,
- double* y,
- double* z,
- int* err );
+/**\brief Get the senses of an array of edges with respect to an array of faces
+ * Get the senses of an array of edges with respect to an array of faces. Sense returned
+ * that edge bounds the face once with each sense.
+ * \param edge_handles Edges being queried
+ * \param edge_handles_size Size of edge handles array
+ void iGeom_getEgFcArrSense( iGeom_Instance,
+ int** sense,
+ int* sense_size,
+ int* err );
-void iGeom_getVtxArrCoords( iGeom_Instance,
- double** coordinates,
- int* coordinates_allocated,
- int* coordinates_size,
+/**\brief Get the sense of a vertex pair with respect to an edge
+ * Get the sense of a vertex pair with respect to an edge. Sense returned is -1, 0, or 1,
+ * representing "reversed", "both", or "forward". "both" sense indicates that vertices
+ * are identical and that vertex bounds both sides of the edge
+ * \param vertex1 First vertex being queried
+ * \param vertex2 Second vertex being queried
+ * \param sense_out Sense of vertex pair with respect to edge
+ void iGeom_getEgVtxSense( iGeom_Instance,
+ iBase_EntityHandle vertex1,
+ iBase_EntityHandle vertex2,
+ int* sense_out,
int* err );
-void iGeom_getPntRayIntsct( iGeom_Instance,
- double x,
- double y,
- double z,
- double dir_x,
- double dir_y,
- double dir_z,
- iBase_EntityHandle** intersect_entity_handles,
- int* intersect_entity_handles_allocated,
- int* intersect_entity_hangles_size,
- double** intersect_coords,
- int* intersect_coords_allocated,
- int* intersect_coords_size,
- double** param_coords,
- int* param_coords_allocated,
- int* param_coords_size,
- int* err );
-void iGeom_getPntArrRayIntsct( iGeom_Instance,
- const double* coords,
- int coords_size,
- const double* directions,
- int directions_size,
- int** offset,
- int* offset_size,
+/**\brief Get the senses of vertex pair with respect to a edges
+ * Get the senses of vertex pairs with respect to edges. Sense returned is -1, 0, or 1,
+ * representing "reversed", "both", or "forward". "both" sense indicates that both vertices
+ * in pair are identical and that vertex bounds both sides of the edge
+ * \param vertex_handles_1 First vertex being queried
+ * \param vertex_handles_1_size Number of vertices in vertices array
+ * \param vertex_handles_2 Second vertex being queried
+ * \param vertex_handles_2_size Number of vertices in vertices array
+ * \param sense Sense of vertex pair with respect to edge
+ * \param sense_allocated Allocated size of sense array
+ * \param sense_size Occupied size of sense array
+ void iGeom_getEgVtxArrSense( iGeom_Instance,
+ iBase_EntityHandle const* vertex_handles_1,
+ int veretx_handles_1_size,
+ iBase_EntityHandle const* vertex_handles_2,
+ int vertex_handles_2_size,
+ int** sense,
+ int* sense_size,
int* err );
-void iGeom_getPntClsf( iGeom_Instance,
- double x,
- double y,
- double z,
- iBase_EntityHandle* entity_handle,
- int* err );
+/**\brief Return the measure (length, area, volume) of entities
+ * Return the measure (length, area, volume) of entities
+ * \param entity_handles Array of entities being queried
+ * \param entity_handles_size Number of entities in entity array
+ * \param measures Measures of entities being queried
+ * \param measures_allocated Allocated size of measures array
+ * \param measures_size Occupied size of measures array
+ void iGeom_measure( iGeom_Instance,
+ double** measures,
+ int* measures_allocated,
+ int* measures_size,
+ int* err );
-void iGeom_getPntArrClsf( iGeom_Instance,
- int coords_size,
- int* entity_handles_allocated,
- int* err );
+/**\brief Get the geometric type of an entity
+ * Get the geometric type of an entity. Specific types depend on implementation.
+ * \param face_type Face type
+ * \param face_type_length Length of face type string
+ void iGeom_getFaceType( iGeom_Instance,
+ char* face_type,
+ int* err,
+ int* face_type_length);
-void iGeom_getEntNrmlSense( iGeom_Instance,
- iBase_EntityHandle face,
- iBase_EntityHandle region,
- int* sense_out,
+/**\brief Return whether interface has information about parameterization
+ * Return whether an interface has information about parameterization (!=0) or not (0)
+ * \param is_parametric If non-zero, interface has information about parameterization
+ void iGeom_getParametric( iGeom_Instance,
+ int* is_parametric,
int* err );
-void iGeom_getArrNrmlSense( iGeom_Instance,
- iBase_EntityHandle const* region_handles,
- int region_handles_size,
- int** sense,
- int* sense_allocated,
- int* sense_size,
- int* err );
+/**\brief Return whether an entity has a parameterization
+ * Return whether an entity has a parameterization (!= 0) or not (=0)
+ * \param is_parametric Entity has a parameterization (!= 0) or not (=0)
+ void iGeom_isEntParametric( iGeom_Instance,
+ int* parametric,
+ int* err );
-void iGeom_getEgFcSense( iGeom_Instance,
- iBase_EntityHandle edge,
- int* sense_out,
- int* err );
+/**\brief Return whether entities have parameterizations
+ * Return whether entities have parameterizations (!= 0) or not (=0)
+ * \param entity_handles Entities being queried
+ * \param is_parametric entity_handles[i] has a parameterization (!= 0) or not (=0)
+ * \param is_parametric_allocated Allocated size of is_parametric array
+ * \param is_parametric_size Occupied size of is_parametric array
+ void iGeom_isArrParametric( iGeom_Instance,
+ int** is_parametric,
+ int* is_parametric_allocated,
+ int* is_parametric_size,
+ int* err );
-void iGeom_getEgFcArrSense( iGeom_Instance,
- int** sense,
- int* sense_size,
+/**\brief Return coordinate position at specified parametric position on entity
+ * Return coordinate position at specified parametric position on entity.
+ * \param u Parametric coordinate being queried
+ * \param v Parametric coordinate being queried
+ * \param x Spatial coordinate at parametric position being queried
+ * \param y Spatial coordinate at parametric position being queried
+ * \param z Spatial coordinate at parametric position being queried
+ void iGeom_getEntUVtoXYZ( iGeom_Instance,
+ double u,
+ double v,
+ double* x,
+ double* y,
+ double* z,
int* err );
-void iGeom_getEgVtxSense( iGeom_Instance,
- iBase_EntityHandle vertex1,
- iBase_EntityHandle vertex2,
- int* sense_out,
- int* err );
+/**\brief Return coordinate positions at specified parametric position(s) on entity(ies)
+ * Return coordinate positions at specified parametric position(s) on entity(ies).
+ * If either the number of entities or number of parametric coordinate pairs is unity, then
+ * all points or entities are queried for that entity or point, respectively, otherwise each
+ * \param storage_order Storage order of uv coordinates input
+ * \param uv Coordinates being queried
+ * \param uv_size Number of coordinates in array
+ * \param coordinates Coordinates of parametric positions
+ * \param coordinates_allocated Allocated size of coordinates array
+ * \param coordinates_size Occupied size of coordinates array
+ void iGeom_getArrUVtoXYZ( iGeom_Instance,
+ double const* uv,
+ int uv_size,
+ int* err );
-void iGeom_getEgVtxArrSense( iGeom_Instance,
- iBase_EntityHandle const* vertex_handles_1,
- int veretx_handles_1_size,
- iBase_EntityHandle const* vertex_handles_2,
- int vertex_handles_2_size,
- int** sense,
- int* sense_size,
- int* err );
+ void iGeom_getEntUtoXYZ( iGeom_Instance,
+ double u,
+ double* x,
+ double* y,
+ double* z,
+ int* err );
-void iGeom_measure( iGeom_Instance,
- double** measures,
- int* measures_allocated,
- int* measures_size,
- int* err );
+ void iGeom_getArrUtoXYZ( iGeom_Instance,
+ double const* u,
+ int u_size,
+ int* err );
-void iGeom_getFaceType( iGeom_Instance,
- char** face_type,
- int* face_type_allocated,
- int* face_type_size,
- int* err );
-void iGeom_getParametric( iGeom_Instance,
- int* parametric,
- int* err );
-void iGeom_isEntParametric( iGeom_Instance,
+/**\brief Return parametric position at specified spatial position on entity
+ * Return parametric position at specified spatial position on entity
+ * \param x Spatial coordinate being queried
+ * \param y Spatial coordinate being queried
+ * \param z Spatial coordinate being queried
+ * \param u Parametric coordinate at spatial position being queried
+ * \param v Parametric coordinate at spatial position being queried
+ void iGeom_getEntXYZtoUV( iGeom_Instance,
- int* parametric,
+ double x,
+ double y,
+ double z,
+ double* u,
+ double* v,
int* err );
-void iGeom_isArrParametric( iGeom_Instance,
+ void iGeom_getEntXYZtoU( iGeom_Instance,
+ double x,
+ double y,
+ double z,
+ double* u,
+ int* err );
+/**\brief Return parametric positions at specified spatial position(s) on entity(ies)
+ * Return parametric positions at specified spatial position(s) on entity(ies).
+ * If either the number of entities or number of spatial coordinate triples is unity, then
+ * \param storage_order Storage order of spatial coordinates input
+ * \param coordinates Coordinates being queried
+ * \param coordinates_size Number of coordinates in array
+ * \param uv Coordinates of parametric positions
+ * \param uv_allocated Allocated size of coordinates array
+ * \param uv_size Occupied size of coordinates array
+ void iGeom_getArrXYZtoUV( iGeom_Instance,
- int** is_parametric,
- int* is_parametric_allocated,
- int* is_parametric_size,
+ double** uv,
+ int* uv_allocated,
+ int* uv_size,
int* err );
-void iGeom_getEntUVtoXYZ( iGeom_Instance,
- double u,
- double v,
- double* x,
- double* y,
- double* z,
- int* err );
+/**\brief Return spatial positions at specified parametric position(s) on entity(ies)
+ * Return spatial positions at specified parametric position(s) on entity(ies).
+ * \param u Coordinates of parametric positions
+ * \param u_allocated Allocated size of coordinates array
+ * \param u_size Occupied size of coordinates array
+ void iGeom_getArrXYZtoU( iGeom_Instance,
+ double** u,
+ int* u_allocated,
+ int* u_size,
+ int* err );
-void iGeom_getArrUVtoXYZ( iGeom_Instance,
- double const* uv,
- int uv_size,
- int* err );
+/**\brief Return parametric position at specified spatial position on entity, based on parametric position hint
+ * Return parametric position at specified spatial position on entity, based on parametric
+ * position hint. For this function, u and v are input with parameters from which to start search.
+ * Typically this will reduce the search time for new parametric coordinates.
+ void iGeom_getEntXYZtoUVHint( iGeom_Instance,
+ double x,
+ double y,
+ double z,
+ double* u,
+ double* v,
+ int* err );
-void iGeom_getEntUtoXYZ( iGeom_Instance,
- double u,
- double* x,
- double* y,
- double* z,
- int* err );
+/**\brief Return parametric positions at specified spatial position(s) on entity(ies), based on parametric position hints
+ * Return parametric positions at specified spatial position(s) on entity(ies), based on
+ * parametric position hints. If either the number of entities or number of spatial
+ * coordinate triples is unity, then all points or entities are queried for that entity
+ * or point, respectively, otherwise each point corresponds to each entity. storage_order
+ * should be a value in the iBase_StorageOrder enum; if input as iBase_UNKNOWN, order is in
+ * native order with respect to implementation.
+ void iGeom_getArrXYZtoUVHint( iGeom_Instance,
+ int coords_size,
+ double** uv,
+ int* uv_size,
+ int* err );
-void iGeom_getArrUtoXYZ( iGeom_Instance,
- double const* u,
- int u_size,
- int* err );
+/**\brief Get parametric range of entity
+ * Get parametric range of entity
+ * \param u_min Minimum parametric coordinate for entity
+ * \param v_min Minimum parametric coordinate for entity
+ * \param u_max Maximum parametric coordinate for entity
+ * \param v_max Maximum parametric coordinate for entity
+ void iGeom_getEntUVRange( iGeom_Instance,
+ double* u_min,
+ double* v_min,
+ double* u_max,
+ double* v_max,
+ int* err );
-void iGeom_getEntXYZtoUV( iGeom_Instance,
- double x,
- double y,
- double z,
- double* u,
- double* v,
- int* err );
+ void iGeom_getEntURange( iGeom_Instance,
+ double* u_min,
+ double* u_max,
+ int* err );
-void iGeom_getEntXYZtoU( iGeom_Instance,
- double x,
- double y,
- double z,
- double* u,
- int* err );
+/**\brief Get parametric range of entities
+ * Get parametric range of entities
+ * \param storage_order Storage order of parametric coordinates being returned
+ * \param uv_min Minimum parametric coordinate for entities
+ * \param uv_min_allocated Allocated size of minimum parametric coordinate array
+ * \param uv_min_size Occupied size of minimum parametric coordinate array
+ * \param uv_max Maximum parametric coordinate for entities
+ * \param uv_max_allocated Allocated size of maximum parametric coordinate array
+ * \param uv_max_size Occupied size of maximum parametric coordinate array
+ void iGeom_getArrUVRange( iGeom_Instance,
+ double** uv_min,
+ int* uv_min_allocated,
+ int* uv_min_size,
+ double** uv_max,
+ int* uv_max_allocated,
+ int* uv_max_size,
+ int* err );
-void iGeom_getArrXYZtoUV( iGeom_Instance,
- double** uv,
- int* uv_allocated,
- int* uv_size,
- int* err );
+ * \param u_min Minimum parametric coordinate for entities
+ * \param u_min_allocated Allocated size of minimum parametric coordinate array
+ * \param u_min_size Occupied size of minimum parametric coordinate array
+ * \param u_max Maximum parametric coordinate for entities
+ * \param u_max_allocated Allocated size of maximum parametric coordinate array
+ * \param u_max_size Occupied size of maximum parametric coordinate array
+ void iGeom_getArrURange( iGeom_Instance,
+ double** u_min,
+ int* u_min_allocated,
+ int* u_min_size,
+ double** u_max,
+ int* u_max_allocated,
+ int* u_max_size,
+ int* err );
-void iGeom_getArrXYZtoU( iGeom_Instance,
- double** u,
- int* u_allocated,
- int* u_size,
- int* err );
-void iGeom_getEntXYZtoUVHint( iGeom_Instance,
- double x,
- double y,
- double z,
- double* u,
- double* v,
- int* err );
-void iGeom_getArrXYZtoUVHint( iGeom_Instance,
- int coords_size,
- double** uv,
- int* uv_size,
- int* err );
-void iGeom_getEntUVRange( iGeom_Instance,
- double* u_min,
- double* v_min,
- double* u_max,
- double* v_max,
+/**\brief Return the face parametric coordinates for a parametric position on a bounding edge
+ * Return the face parametric coordinates for a parametric position on a bounding edge
+ * \param in_u Parametric position on edge
+ * \param u Corresponding parametric position on face
+ * \param v Corresponding parametric position on face
+ void iGeom_getEntUtoUV( iGeom_Instance,
+ double in_u,
+ double* u,
+ double* v,
int* err );
-void iGeom_getEntURange( iGeom_Instance,
- double* u_min,
- double* u_max,
+/**\brief Return parametric coordinates on face of vertex position
+ * Return parametric coordinates on face of vertex position
+ * \param vertex_handle Vertex being queried
+ void iGeom_getVtxToUV( iGeom_Instance,
+ double* u,
+ double* v,
int* err );
-void iGeom_getArrUVRange( iGeom_Instance,
- double** uv_min,
- int* uv_min_allocated,
- int* uv_min_size,
- double** uv_max,
- int* uv_max_allocated,
- int* uv_max_size,
- int* err );
-void iGeom_getArrURange( iGeom_Instance,
- double** u_min,
- int* u_min_allocated,
- int* u_min_size,
- double** u_max,
- int* u_max_allocated,
- int* u_max_size,
- int* err );
-void iGeom_getEntUtoUV( iGeom_Instance,
+/**\brief Return parametric coordinates on edge of vertex position
+ * Return parametric coordinates on edge of vertex position
+ void iGeom_getVtxToU( iGeom_Instance,
- double in_u,
double* u,
- double* v,
int* err );
-void iGeom_getVtxToUV( iGeom_Instance,
- double* u,
- double* v,
- int* err );
-void iGeom_getVtxToU( iGeom_Instance,
- double* u,
- int* err );
-void iGeom_getArrUtoUV( iGeom_Instance,
- double const* u_in,
- int u_in_size,
- double** uv,
- int* uv_size,
- int* err );
-void iGeom_getVtxArrToUV( iGeom_Instance,
- iBase_EntityHandle const* vertex_handles,
- int vertex_handles_size,
+/**\brief Return the face parametric coordinates for a parametric position on bounding edges
+ * Return the face parametric coordinates for a parametric position on bounding edges
+ * \param face_handles_size Number of faces being queried
+ * \param u_in Parametric positions on edges
+ * \param u_in_size Number of parametric positions on edges
+ * \param storage_order Storage order of coordinates returned
+ * \param uv Corresponding parametric positions on faces
+ * \param uv_allocated Allocated size of parameter array
+ * \param uv_size Occupied size of parameter array
+ void iGeom_getArrUtoUV( iGeom_Instance,
+ double const* u_in,
+ int u_in_size,
int* storage_order,
double** uv,
int* uv_allocated,
int* uv_size,
int* err );
-void iGeom_getVtxArrToU( iGeom_Instance,
- double** u,
- int* u_allocated,
- int* u_size,
- int* err );
+/**\brief Return parametric coordinates on faces of vertex positions
+ * Return parametric coordinates on faces of vertex positions
+ * \param vertex_handles Vertices being queried
+ * \param vertex_handles_size Number of vertices being queried
+ * \param uv_allocated Allocated size of positions array
+ * \param uv_size Occupied size of positions array
+ void iGeom_getVtxArrToUV( iGeom_Instance,
+ iBase_EntityHandle const* vertex_handles,
+ int vertex_handles_size,
+ double** uv,
+ int* uv_size,
+ int* err );
-void iGeom_getEntNrmlUV( iGeom_Instance,
- double u,
- double v,
- double* nrml_i,
- double* nrml_j,
- double* nrml_k,
- int* err );
+/**\brief Return parametric coordinates on edges of vertex positions
+ * Return parametric coordinates on edges of vertex positions
+ * \param u Corresponding parametric positions on faces
+ * \param u_allocated Allocated size of positions array
+ * \param u_size Occupied size of positions array
+ void iGeom_getVtxArrToU( iGeom_Instance,
+ double** u,
+ int* u_allocated,
+ int* u_size,
+ int* err );
-void iGeom_getArrNrmlUV( iGeom_Instance,
- double const* parameters,
- int parameters_size,
- double** normals,
- int* err );
+/**\brief Return the normal at a specified parametric position
+ * Return the normal at a specified parametric position
+ * \param u Parametric position being queried
+ * \param v Parametric position being queried
+ * \param nrml_i Normal at specified position
+ * \param nrml_j Normal at specified position
+ * \param nrml_k Normal at specified position
+ void iGeom_getEntNrmlUV( iGeom_Instance,
+ double u,
+ double v,
+ double* nrml_i,
+ double* nrml_j,
+ double* nrml_k,
+ int* err );
-void iGeom_getEntTgntU( iGeom_Instance,
- double u,
- double* tgnt_i,
- double* tgnt_j,
- double* tgnt_k,
- int* err );
+/**\brief Return the normals at a specified parametric positions
+ * Return the normals at a specified parametric positions. If either the number of
+ * entities or number of spatial
+ void iGeom_getArrNrmlUV( iGeom_Instance,
+ double const* parameters,
+ int parameters_size,
+ double** normals,
+ int* err );
-void iGeom_getArrTgntU( iGeom_Instance,
- int* err );
-void iGeom_getEnt1stDrvt( iGeom_Instance,
+/**\brief
+ void iGeom_getEntTgntU( iGeom_Instance,
double u,
- double v,
- double** drvt_u,
- int* drvt_u_allocated,
- int* drvt_u_size,
- double** drvt_v,
- int* dvrt_v_allocated,
- int* dvrt_v_size,
+ double* tgnt_i,
+ double* tgnt_j,
+ double* tgnt_k,
int* err );
-void iGeom_getArr1stDrvt( iGeom_Instance,
+/**\brief
+ void iGeom_getArrTgntU( iGeom_Instance,
int storage_order,
- double const* uv,
- int uv_size,
- double** dvtr_u,
- int* dvrt_u_allocated,
- int* dvrt_u_size,
- int** u_offset,
- int* u_offset_allocated,
- int* u_offset_size,
- double** dvrt_v,
- int* dvrt_v_size,
- int** v_offset,
- int* v_offset_allocated,
- int* v_offset_size,
int* err );
-void iGeom_getEnt2ndDrvt( iGeom_Instance,
+/**\brief
+ void iGeom_getEnt1stDrvt( iGeom_Instance,
+ double u,
+ double v,
+ double** drvt_u,
+ int* drvt_u_allocated,
+ int* drvt_u_size,
+ double** drvt_v,
+ int* dvrt_v_allocated,
+ int* dvrt_v_size,
+ int* err );
+/**\brief
+ void iGeom_getArr1stDrvt( iGeom_Instance,
+ double const* uv,
+ int uv_size,
+ double** dvtr_u,
+ int* dvrt_u_allocated,
+ int* dvrt_u_size,
+ int** u_offset,
+ int* u_offset_allocated,
+ int* u_offset_size,
+ double** dvrt_v,
+ int* dvrt_v_size,
+ int** v_offset,
+ int* v_offset_allocated,
+ int* v_offset_size,
+ int* err );
+/**\brief
+ void iGeom_getEnt2ndDrvt( iGeom_Instance,
+ double u,
+ double v,
+ double** drvt_uu,
+ int* drvt_uu_allocated,
+ int* drvt_uu_size,
+ double** drvt_vv,
+ int* dvrt_vv_allocated,
+ int* dvrt_vv_size,
+ double** drvt_uv,
+ int* dvrt_uv_allocated,
+ int* dvrt_uv_size,
+ int* err );
+/**\brief
+ void iGeom_getArr2ndDrvt( iGeom_Instance,
+ double const* uv,
+ int uv_size,
+ double** dvtr_uu,
+ int* dvrt_uu_allocated,
+ int* dvrt_uu_size,
+ int** uu_offset,
+ int* uu_offset_allocated,
+ int* uu_offset_size,
+ double** dvtr_vv,
+ int** vv_offset,
+ int* vv_offset_allocated,
+ int* vv_offset_size,
+ double** dvrt_uv,
+ int** uv_offset,
+ int* uv_offset_allocated,
+ int* uv_offset_size,
+ int* err );
+/**\brief
+ void iGeom_getFcCvtrUV( iGeom_Instance,
double u,
double v,
- double** drvt_uu,
- int* drvt_uu_allocated,
- int* drvt_uu_size,
- double** drvt_vv,
- int* dvrt_vv_allocated,
- int* dvrt_vv_size,
- double** drvt_uv,
- int* dvrt_uv_allocated,
- int* dvrt_uv_size,
+ double* cvtr1_i,
+ double* cvtr1_j,
+ double* cvtr1_k,
+ double* cvtr2_i,
+ double* cvtr2_j,
+ double* cvtr2_k,
int* err );
-void iGeom_getArr2ndDrvt( iGeom_Instance,
- double const* uv,
- int uv_size,
- double** dvtr_uu,
- int* dvrt_uu_allocated,
- int* dvrt_uu_size,
- int** uu_offset,
- int* uu_offset_allocated,
- int* uu_offset_size,
- double** dvtr_vv,
- int** vv_offset,
- int* vv_offset_allocated,
- int* vv_offset_size,
- double** dvrt_uv,
- int** uv_offset,
- int* uv_offset_allocated,
- int* uv_offset_size,
- int* err );
+/**\brief
+ void iGeom_getFcArrCvtrUV( iGeom_Instance,
+ double const* uv,
+ int uv_size,
+ double** cvtr_1,
+ int* cvtr_1_size,
+ double** cvtr_2,
+ int* cvtr_2_size,
+ int* err );
-void iGeom_getFcCvtrUV( iGeom_Instance,
- double u,
- double v,
- double* cvtr1_i,
- double* cvtr1_j,
- double* cvtr1_k,
- double* cvtr2_i,
- double* cvtr2_j,
- double* cvtr2_k,
- int* err );
+/**\brief
+ void iGeom_isEntPeriodic( iGeom_Instance,
+ int* in_u,
+ int* in_v,
+ int* err );
-void iGeom_getFcArrCvtrUV( iGeom_Instance,
- double const* uv,
- int uv_size,
- double** cvtr_1,
- int* cvtr_1_size,
- double** cvtr_2,
- int* cvtr_2_size,
- int* err );
+/**\brief
+ void iGeom_isArrPeriodic( iGeom_Instance,
+ int** in_uv,
+ int* in_uv_allocated,
+ int* in_uv_size,
+ int* err );
-void iGeom_isEntPeriodic( iGeom_Instance,
- int* in_u,
- int* in_v,
- int* err );
+/**\brief
+ void iGeom_isFcDegenerate( iGeom_Instance,
+ int* is_degenerate,
+ int* err );
-void iGeom_isArrPeriodic( iGeom_Instance,
- int** in_uv,
- int* in_uv_allocated,
- int* in_uv_size,
- int* err );
+/**\brief
+ void iGeom_isFcArrDegenerate( iGeom_Instance,
+ int** degenerate,
+ int* degenerate_allocated,
+ int* degenerate_size,
+ int* err );
-void iGeom_isFcDegenerate( iGeom_Instance,
- int* is_degenerate,
+/**\brief
+ void iGeom_getTolerance( iGeom_Instance,
+ int* type,
+ double* tolerance,
int* err );
-void iGeom_isFcArrDegenerate( iGeom_Instance,
- int** degenerate,
- int* degenerate_allocated,
- int* degenerate_size,
+/**\brief
+ void iGeom_getEntTolerance( iGeom_Instance,
int* err );
-void iGeom_getTolerance( iGeom_Instance,
- int* type,
- double* tolerance,
- int* err );
+/**\brief
+ void iGeom_getArrTolerance( iGeom_Instance,
+ double** tolerances,
+ int* tolerances_allocated,
+ int* tolerances_size,
+ int* err );
-void iGeom_getEntTolerance( iGeom_Instance,
- int* err );
+ /**\brief Initialize an iterator over specified entity type, topology, and size
+ * Initialize an iterator over specified entity type, topology, and size,
+ * for a specified set or instance. Iterator returned can be used as input
+ * to functions returning the entity for the iterator. If all entities of
+ * a specified type and/or topology are to be iterated, specify
+ * iBase_ALL_TYPES or iGeom_ALL_TOPOLOGIES, respectively. Specified type
+ * iGeom_EntityTopology enumerations, respectively.
+ * \param entity_set_handle Entity set being iterated
+ * \param requested_entity_type Type of entity to iterate
+ * \param requested_entity_topology Topology of entity to iterate
+ * \param entity_iterator Pointer to iterator returned from function
+ void iGeom_initEntIter( iGeom_Instance,
+ iBase_EntitySetHandle entity_set_handle,
+ int entity_dimension,
+ iGeom_EntityIterator* entity_iterator,
+ int* err );
-void iGeom_getArrTolerance( iGeom_Instance,
- double** tolerances,
- int* tolerances_allocated,
- int* tolerances_size,
- int* err );
+ /**\brief Initialize an array iterator over specified entity type, topology, and
+ * size
+ * Initialize an array iterator over specified entity type, topology, and
+ * size, for a specified set or instance. Iterator returned can be used
+ * as input to functions returning entities for the iterator. If all
+ * entities of a specified type and/or topology are to be iterated,
+ * specify iBase_ALL_TYPES or iGeom_ALL_TOPOLOGIES, respectively.
+ * Specified type or topology must be a value in the iBase_EntityType or
+ * \param instance iGeom instance handle
+ * \param requested_array_size Size of chunks of handles returned for each
+ * value of the iterator
+ * \param entArr_iterator Pointer to iterator returned from function
+ * \param *err Pointer to error type returned from function
+ void iGeom_initEntArrIter( iGeom_Instance,
+ int requested_array_size,
+ iGeom_EntityArrIterator* entArr_iterator,
+ int* err );
-void iGeom_initEntIter( iGeom_Instance,
- iBase_EntitySetHandle entity_set_handle,
- int entity_dimension,
- iGeom_EntityIterator* entity_iterator,
- int* err );
+ /**\brief Get entity corresponding to an iterator and increment iterator
+ * Get the entity corresponding to an array iterator, and increment the
+ * iterator. Also return whether the next value of the iterator has
+ * an entity (if non-zero, next iterator value is the end of the
+ * iteration).
+ * \param entity_iterator Iterator being queried
+ * \param entity_handle Pointer to an entity handle corresponding to the
+ * current value of iterator
+ * \param has_data Pointer to flag; if returned non-zero, next iterator
+ * has an entity
+ void iGeom_getNextEntIter( iGeom_Instance,
+ iGeom_EntityIterator,
+ int* has_data,
+ int* err );
-void iGeom_initEntArrIter( iGeom_Instance,
- int requested_array_size,
- iGeom_EntityArrIterator* entArr_iterator,
- int* err );
+ /**\brief Get entities contained in array iterator and increment iterator
+ * Get the entities contained in an array iterator, and increment the
+ * any entities (if non-zero, next iterator value is the end of the
+ * iteration).
+ * \param entArr_iterator Iterator being queried
+ * \param *entity_handles Pointer to array of entity handles contained in
+ * array
+ * has a non-zero number of entities
+ void iGeom_getNextEntArrIter( iGeom_Instance,
+ iGeom_EntityArrIterator,
+ int* err );
-void iGeom_getNextEntIter( iGeom_Instance,
+ /**\brief Reset the iterator
+ * Reset the iterator
+ * \param entity_iterator Iterator to reset
+ void iGeom_resetEntIter( iGeom_Instance,
- int* has_data,
int* err );
-void iGeom_getNextEntArrIter( iGeom_Instance,
+ /**\brief Reset the array iterator
+ * Reset the array iterator
+ * \param entArr_iterator Iterator to reset
+ void iGeom_resetEntArrIter( iGeom_Instance,
- iBase_EntityHandle** entity_handles,
- int* entity_handles_size,
int* err );
-void iGeom_resetEntIter( iGeom_Instance,
- iGeom_EntityIterator,
- int* err );
+ /**\brief Destroy the specified iterator
+ * Destroy the specified iterator
+ * \param entity_iterator Iterator which gets destroyed
+ void iGeom_endEntIter( iGeom_Instance, iGeom_EntityIterator, int* err );
-void iGeom_resetEntArrIter( iGeom_Instance,
- iGeom_EntityArrIterator,
- int* err );
+ /**\brief Destroy the specified array iterator
+ * Destroy the specified array iterator
+ * \param entArr_iterator Iterator which gets destroyed
+ void iGeom_endEntArrIter( iGeom_Instance, iGeom_EntityArrIterator, int* err );
-void iGeom_endEntIter( iGeom_Instance, iGeom_EntityIterator, int* err );
-void iGeom_endEntArrIter( iGeom_Instance, iGeom_EntityArrIterator, int* err );
+/**\brief
+ void iGeom_copyEnt( iGeom_Instance,
+ iBase_EntityHandle source,
+ iBase_EntityHandle* copy,
+ int* err );
-void iGeom_copyEnt( iGeom_Instance,
- iBase_EntityHandle source,
- iBase_EntityHandle* copy,
- int* err );
+/**\brief
+ void iGeom_sweepEntAboutAxis( iGeom_Instance,
+ iBase_EntityHandle geom_entity,
+ double angle,
+ double axis_normal_x,
+ double axis_normal_y,
+ double axis_normal_z,
+ iBase_EntityHandle* geom_entity2,
+ int* err );
-void iGeom_sweepEntAboutAxis( iGeom_Instance,
- iBase_EntityHandle geom_entity,
- double angle,
- double axis_normal_x,
- double axis_normal_y,
- double axis_normal_z,
- iBase_EntityHandle* geom_entity2,
- int* err );
+ /**\brief Delete specified entity
+ * Delete specified entity
+ * \param entity_handle Entity to be deleted
+ void iGeom_deleteEnt( iGeom_Instance,
+ iBase_EntityHandle,
+ int* err );
-void iGeom_deleteEnt( iGeom_Instance,
- iBase_EntityHandle,
- int* err );
+/**\brief
+ void iGeom_createBrick( iGeom_Instance,
+ double x,
+ double y,
+ double z,
+ iBase_EntityHandle* geom_entity,
+ int* err );
-void iGeom_createBrick( iGeom_Instance,
- double x,
- double y,
- double z,
- iBase_EntityHandle* geom_entity,
- int* err );
+/**\brief
+ void iGeom_createCylinder( iGeom_Instance,
+ double height,
+ double major_rad,
+ double minor_rad,
+ int* err );
-void iGeom_createCylinder( iGeom_Instance,
- double height,
- double major_rad,
- double minor_rad,
- int* err );
+/**\brief
+ void iGeom_createTorus( iGeom_Instance,
+ double major_rad,
+ double minor_rad,
+ int* err );
-void iGeom_createTorus( iGeom_Instance,
- double major_rad,
- double minor_rad,
+/**\brief
+ void iGeom_moveEnt( iGeom_Instance,
+ double x,
+ double y,
+ double z,
+ int* err );
+/**\brief
+ void iGeom_rotateEnt( iGeom_Instance,
+ double angle,
int* err );
-void iGeom_moveEnt( iGeom_Instance,
- double x,
- double y,
- double z,
- int* err );
+/**\brief
+ void iGeom_reflectEnt( iGeom_Instance,
+ double plane_normal_x,
+ double plane_normal_y,
+ double plane_normal_z,
+ int* err );
-void iGeom_rotateEnt( iGeom_Instance,
- double angle,
- int* err );
-void iGeom_reflectEnt( iGeom_Instance,
+/**\brief
+ void iGeom_scaleEnt( iGeom_Instance,
- double plane_normal_x,
- double plane_normal_y,
- double plane_normal_z,
+ double scale_x,
+ double scale_y,
+ double scale_z,
int* err );
-void iGeom_scaleEnt( iGeom_Instance,
- double scale_x,
- double scale_y,
- double scale_z,
- int* err );
+/**\brief
+ void iGeom_uniteEnts( iGeom_Instance,
+ iBase_EntityHandle const* geom_entities,
+ int geom_entities_size,
+ int* err );
-void iGeom_uniteEnts( iGeom_Instance,
- iBase_EntityHandle const* geom_entities,
- int geom_entities_size,
- int* err );
+/**\brief
+ void iGeom_subtractEnts( iGeom_Instance,
+ iBase_EntityHandle blank,
+ iBase_EntityHandle tool,
+ int* err );
-void iGeom_subtractEnts( iGeom_Instance,
- iBase_EntityHandle blank,
- iBase_EntityHandle tool,
+/**\brief
+ void iGeom_sectionEnt( iGeom_Instance,
+ double offset,
+ int reverse,
int* err );
-void iGeom_sectionEnt( iGeom_Instance,
- double offset,
- int reverse,
- int* err );
+/**\brief
+ void iGeom_imprintEnts( iGeom_Instance,
+ int* err );
-void iGeom_imprintEnts( iGeom_Instance,
+/**\brief
+ void iGeom_mergeEnts( iGeom_Instance,
+ double tolerance,
int* err );
-void iGeom_mergeEnts( iGeom_Instance,
- double tolerance,
- int* err );
+ /**\brief Create an entity set
+ * Create an entity set, either ordered (isList=1) or unordered
+ * (isList=0). Unordered entity sets can contain a given entity or
+ * set only once.
+ * \param isList If non-zero, an ordered list is created, otherwise an
+ * unordered set is created.
+ * \param entity_set_created Entity set created by function
+ void iGeom_createEntSet(iGeom_Instance instance,
+ int isList,
+ iBase_EntitySetHandle* entity_set_created,
+ int *err);
-void iGeom_createEntSet(iGeom_Instance instance,
- int isList,
- iBase_EntitySetHandle* entity_set_created,
- int *err);
+ /**\brief Destroy an entity set
+ * Destroy an entity set
+ * \param entity_set Entity set to be destroyed
+ void iGeom_destroyEntSet(iGeom_Instance instance,
+ iBase_EntitySetHandle entity_set,
+ int *err);
-void iGeom_destroyEntSet(iGeom_Instance instance,
- iBase_EntitySetHandle entity_set,
- int *err);
+ /**\brief Return whether a specified set is ordered or unordered
+ * Return whether a specified set is ordered (*is_list=1) or
+ * unordered (*is_list=0)
+ * \param entity_set Entity set being queried
+ * \param is_list Pointer to flag returned from function
+ void iGeom_isList(iGeom_Instance instance,
+ int *is_list,
+ int *err);
-void iGeom_isList(iGeom_Instance instance,
- int *is_list,
- int *err);
+ /**\brief Get the number of entity sets contained in a set or interface
+ * Get the number of entity sets contained in a set or interface. If
+ * a set is input which is not the root set, num_hops indicates the
+ * maximum number of contained sets from entity_set_handle to one of the
+ * contained sets, inclusive of the contained set.
+ * \param entity_set_handle Entity set being queried
+ * \param num_hops Maximum hops from entity_set_handle to contained set,
+ * inclusive of the contained set
+ * \param num_sets Pointer to the number of sets returned from function
+ void iGeom_getNumEntSets(iGeom_Instance instance,
+ int num_hops,
+ int *num_sets,
+ int *err);
-void iGeom_getNumEntSets(iGeom_Instance instance,
- int num_hops,
- int *num_sets,
- int *err);
+ /**\brief Get the entity sets contained in a set or interface
+ * Get the entity sets contained in a set or interface. If
+ * \param *contained_set_handles Pointer to array of set handles returned
+ * from function
+ * \param contained_set_handles_allocated Pointer to allocated length of
+ * contained_set_handles array
+ * \param contained_set_handles_size Pointer to occupied length of
+ void iGeom_getEntSets(iGeom_Instance instance,
+ int num_hops,
+ iBase_EntitySetHandle** contained_set_handles,
+ int* contained_set_handles_allocated,
+ int* contained_set_handles_size,
+ int *err);
-void iGeom_getEntSets(iGeom_Instance instance,
- int num_hops,
- iBase_EntitySetHandle** contained_set_handles,
- int* contained_set_handles_allocated,
- int* contained_set_handles_size,
- int *err);
-void iGeom_addEntToSet(iGeom_Instance instance,
- iBase_EntityHandle entity_handle,
- iBase_EntitySetHandle* entity_set,
- int *err);
-void iGeom_rmvEntFromSet(iGeom_Instance instance,
+ /**\brief Add an entity to a set
+ * Add an entity to a set
+ * \param entity_handle The entity being added
+ * \param entity_set Pointer to the set being added to
+ void iGeom_addEntToSet(iGeom_Instance instance,
+ iBase_EntityHandle entity_handle,
+ iBase_EntitySetHandle* entity_set,
int *err);
+ /**\brief Remove an entity from a set
+ * Remove an entity from a set
+ * \param entity_handle The entity being removed
+ * \param entity_set Pointer to the set being removed from
+ void iGeom_rmvEntFromSet(iGeom_Instance instance,
+ int *err);
-void iGeom_addEntArrToSet(iGeom_Instance instance,
- const iBase_EntityHandle* entity_handles,
- int entity_handles_size,
- int *err);
-void iGeom_rmvEntArrFromSet(iGeom_Instance instance,
+ /**\brief Add an array of entities to a set
+ * Add an array of entities to a set
+ * \param entity_handles Array of entities being added
+ * \param entity_handles_size Number of entities in entity_handles array
+ void iGeom_addEntArrToSet(iGeom_Instance instance,
int *err);
-void iGeom_addEntSet(iGeom_Instance instance,
- iBase_EntityHandle entity_set_to_add,
- iBase_EntitySetHandle* entity_set_handle,
- int *err);
+ /**\brief Remove an array of entities from a set
+ * Remove an array of entities from a set
+ * \param entity_handles Array of entities being remove
+ void iGeom_rmvEntArrFromSet(iGeom_Instance instance,
+ const iBase_EntityHandle* entity_handles,
+ int entity_handles_size,
+ int *err);
-void iGeom_rmvEntSet(iGeom_Instance instance,
- iBase_EntitySetHandle entity_set_to_remove,
- int *err);
+ /**\brief Add an entity set to a set
+ * Add an entity set to a set
+ * \param entity_set_to_add The entity set being added
+ * \param entity_set_handle Pointer to the set being added to
+ void iGeom_addEntSet(iGeom_Instance instance,
+ iBase_EntityHandle entity_set_to_add,
+ iBase_EntitySetHandle* entity_set_handle,
+ int *err);
-void iGeom_isEntContained(iGeom_Instance instance,
- iBase_EntitySetHandle containing_entity_set,
- iBase_EntitySetHandle contained_entity,
- int *is_contained,
- int *err);
-void iGeom_isEntSetContained(iGeom_Instance instance,
- iBase_EntitySetHandle contained_entity_set,
- int *err);
-void iGeom_addPrntChld(iGeom_Instance instance,
- iBase_EntitySetHandle* parent_entity_set,
- iBase_EntitySetHandle* child_entity_set,
+ /**\brief Remove an entity set from a set
+ * Remove an entity set from a set
+ * \param entity_set_to_remove The entity set being removed
+ * \param entity_set_handle Pointer to the set being removed from
+ void iGeom_rmvEntSet(iGeom_Instance instance,
+ iBase_EntitySetHandle entity_set_to_remove,
int *err);
-void iGeom_rmvPrntChld(iGeom_Instance instance,
- int *err);
+ /**\brief Return whether an entity is contained in another set
+ * Return whether an entity is contained (*is_contained=1) or not
+ * contained (*is_contained=0) in another set
+ * \param containing_entity_set Entity set being queried
+ * \param contained_entity Entity potentially contained in
+ * containing_entity_set
+ * \param is_contained Pointer to flag returned from function
+ void iGeom_isEntContained(iGeom_Instance instance,
+ iBase_EntitySetHandle containing_entity_set,
+ iBase_EntitySetHandle contained_entity,
+ int *is_contained,
+ int *err);
-void iGeom_isChildOf(iGeom_Instance instance,
- iBase_EntitySetHandle parent_entity_set,
- iBase_EntitySetHandle child_entity_set,
- int *is_child,
- int *err);
+ /**\brief Return whether an entity set is contained in another set
+ * Return whether a set is contained (*is_contained=1) or not contained
+ * (*is_contained=0) in another set
+ * \param contained_entity_set Entity set potentially contained in
+ void iGeom_isEntSetContained(iGeom_Instance instance,
+ iBase_EntitySetHandle contained_entity_set,
+ int *err);
-void iGeom_getNumChld(iGeom_Instance instance,
- int num_hops,
- int *num_child,
- int *err);
+ /**\brief Add parent/child links between two sets
+ * Add parent/child links between two sets. Makes parent point to child
+ * and child point to parent.
+ * \param parent_entity_set Pointer to parent set
+ * \param child_entity_set Pointer to child set
+ void iGeom_addPrntChld(iGeom_Instance instance,
+ iBase_EntitySetHandle* parent_entity_set,
+ iBase_EntitySetHandle* child_entity_set,
+ int *err);
-void iGeom_getNumPrnt(iGeom_Instance instance,
- int num_hops,
- int *num_parent,
- int *err);
+ /**\brief Remove parent/child links between two sets
+ * Remove parent/child links between two sets.
+ void iGeom_rmvPrntChld(iGeom_Instance instance,
+ int *err);
-void iGeom_getChldn(iGeom_Instance instance,
- iBase_EntitySetHandle from_entity_set,
- int num_hops,
- iBase_EntitySetHandle** entity_set_handles,
- int* entity_set_handles_allocated,
- int* entity_set_handles_size,
- int *err);
+ /**\brief Return whether two sets are related by parent/child links
+ * Return whether two sets are related (*is_child=1) or not (*is_child=0)
+ * by parent/child links
+ * \param is_child Pointer to flag returned from function
+ void iGeom_isChildOf(iGeom_Instance instance,
+ iBase_EntitySetHandle parent_entity_set,
+ iBase_EntitySetHandle child_entity_set,
+ int *is_child,
+ int *err);
-void iGeom_getPrnts(iGeom_Instance instance,
- int num_hops,
- int *err);
+ /**\brief Get the number of child sets linked from a specified set
+ * Get the number of child sets linked from a specified set. If num_hops
+ * is non-zero, this represents the maximum hops from entity_set to any
+ * child in the count.
+ * \param num_hops Maximum hops from entity_set_handle to child set,
+ * inclusive of the child set
+ * \param num_child Pointer to number of children returned from function
+ void iGeom_getNumChld(iGeom_Instance instance,
+ int num_hops,
+ int *num_child,
+ int *err);
-void iGeom_createTag(iGeom_Instance instance,
- const char* tag_name,
- int tag_size,
- int tag_type,
- iBase_TagHandle* tag_handle,
- int *err,
- int tag_name_len );
+ /**\brief Get the number of parent sets linked from a specified set
+ * Get the number of parent sets linked from a specified set. If num_hops
+ * parent in the count.
+ * \param num_hops Maximum hops from entity_set_handle to parent set,
+ * inclusive of the parent set
+ * \param num_parent Pointer to number of parents returned from function
+ void iGeom_getNumPrnt(iGeom_Instance instance,
+ int num_hops,
+ int *num_parent,
+ int *err);
+ /**\brief Get the child sets linked from a specified set
+ * Get the child sets linked from a specified set. If num_hops
+ * child.
+ * \param from_entity_set Entity set being queried
+ * \param *entity_set_handles Pointer to array of child sets
+ * returned from function
+ * \param *entity_set_handles_allocated Pointer to allocated size of
+ * entity_set_handles array
+ * \param *entity_set_handles_size Pointer to occupied size of
+ void iGeom_getChldn(iGeom_Instance instance,
+ iBase_EntitySetHandle from_entity_set,
+ int num_hops,
+ iBase_EntitySetHandle** entity_set_handles,
+ int* entity_set_handles_allocated,
+ int* entity_set_handles_size,
+ int *err);
-void iGeom_destroyTag(iGeom_Instance instance,
- iBase_TagHandle tag_handle,
- int forced,
+ /**\brief Get the parent sets linked from a specified set
+ * Get the parent sets linked from a specified set. If num_hops
+ * parent.
+ * \param *entity_set_handles Pointer to array of parent sets
+ void iGeom_getPrnts(iGeom_Instance instance,
+ int num_hops,
int *err);
-void iGeom_getTagName(iGeom_Instance instance,
- char *name,
- int* err,
- int name_len);
+ /**\brief Create a tag with specified name, size, and type
+ * Create a tag with specified name, size, and type. Tag size is in
+ * units of size of tag_type data types. Value input for tag type must be
+ * value in iBase_TagType enumeration.
+ * \param tag_name Character string indicating tag name
+ * \param tag_size Size of each tag value, in units of number of tag_type
+ * entities
+ * \param tag_type Data type for data stored in this tag
+ * \param tag_handle Pointer to tag handle returned from function
+ * \param tag_name_len Length of tag name string
+ void iGeom_createTag(iGeom_Instance instance,
+ const char* tag_name,
+ int tag_size,
+ int tag_type,
+ iBase_TagHandle* tag_handle,
+ int *err,
+ int tag_name_len );
-void iGeom_getTagSizeValues(iGeom_Instance instance,
- int *tag_size,
- int *err);
-void iGeom_getTagSizeBytes(iGeom_Instance instance,
- int *tag_size,
- int *err);
+ /**\brief Destroy a tag
+ * Destroy a tag. If forced is non-zero and entities still have values
+ * set for this tag, tag is deleted anyway and those values disappear,
+ * otherwise tag is not deleted.
+ * \param tag_handle Handle of tag to be deleted
+ * \param forced If non-zero, delete the tag even if entities have values
+ * set for that tag
+ void iGeom_destroyTag(iGeom_Instance instance,
+ iBase_TagHandle tag_handle,
+ int forced,
+ int *err);
-void iGeom_getTagHandle(iGeom_Instance instance,
- iBase_TagHandle *tag_handle,
- int *err,
- int tag_name_len);
+ /**\brief Get the name for a given tag handle
+ * Get the name for a given tag handle
+ * \param tag_handle Tag handle being queried
+ * \param name Pointer to character string to store name returned from
+ * function
+ * \param name_len Length of character string input to function
+ void iGeom_getTagName(iGeom_Instance instance,
+ char *name,
+ int* err,
+ int name_len);
-void iGeom_getTagType(iGeom_Instance instance,
- int *tag_type,
- int *err);
+ /**\brief Get size of a tag in units of numbers of tag data type
+ * Get size of a tag in units of numbers of tag data type
+ * \param tag_handle Handle of tag being queried
+ * \param tag_size Pointer to tag size returned from function
+ void iGeom_getTagSizeValues(iGeom_Instance instance,
+ int *tag_size,
+ int *err);
+ /**\brief Get size of a tag in units of bytes
+ * Get size of a tag in units of bytes
+ void iGeom_getTagSizeBytes(iGeom_Instance instance,
+ int *tag_size,
+ int *err);
-void iGeom_setEntSetData(iGeom_Instance instance,
- const char* tag_value,
- int tag_value_size,
- int *err);
+ /**\brief Get a the handle of an existing tag with the specified name
+ * Get a the handle of an existing tag with the specified name
+ * \param tag_name Name of tag being queried
+ void iGeom_getTagHandle(iGeom_Instance instance,
+ iBase_TagHandle *tag_handle,
+ int *err,
+ int tag_name_len);
+ /**\brief Get the data type of the specified tag handle
+ * Get the data type of the specified tag handle. Tag type is a value in
+ * the iBase_TagType enumeration.
+ * \param tag_handle Handle for the tag being queried
+ * \param tag_type Pointer to tag type returned from function
+ void iGeom_getTagType(iGeom_Instance instance,
+ int *tag_type,
+ int *err);
-void iGeom_setEntSetIntData(iGeom_Instance instance,
- int tag_value,
- int *err);
+ /**\brief Set a tag value of arbitrary type on an entity set
+ * Set a tag value of arbitrary type on an entity set. Tag data is
+ * passed as char* type,
+ * but really represents pointer to arbitrary data.
+ * \param entity_set_handle Entity set on which tag is being set
+ * \param tag_handle Tag being set on an entity set
+ * \param tag_value Pointer to tag data being set on entity set
+ * \param tag_value_size Size in bytes of tag data
+ void iGeom_setEntSetData(iGeom_Instance instance,
+ const char* tag_value,
+ int tag_value_size,
+ int *err);
-void iGeom_setEntSetDblData(iGeom_Instance instance,
- double tag_value,
- int *err);
+ /**\brief Set a tag value of integer type on an entity set
+ * Set a tag value of integer type on an entity set.
+ * \param entity_set Entity set on which tag is being set
+ * \param tag_value Tag value being set on entity set
+ void iGeom_setEntSetIntData(iGeom_Instance instance,
+ int tag_value,
+ int *err);
-void iGeom_setEntSetEHData(iGeom_Instance instance,
- iBase_EntityHandle tag_value,
- int *err);
+ /**\brief Set a tag value of double type on an entity set
+ * Set a tag value of double type on an entity set.
+ void iGeom_setEntSetDblData(iGeom_Instance instance,
+ double tag_value,
+ int *err);
-void iGeom_getEntSetData(iGeom_Instance instance,
- char** tag_value,
- int* tag_value_allocated,
- int* tag_value_size,
- int *err);
-void iGeom_getEntSetIntData(iGeom_Instance instance,
- int *out_data,
- int *err);
+ /**\brief Set a tag value of entity handle type on an entity set
+ * Set a tag value of entity handle type on an entity set.
+ void iGeom_setEntSetEHData(iGeom_Instance instance,
+ iBase_EntityHandle tag_value,
+ int *err);
-void iGeom_getEntSetDblData(iGeom_Instance instance,
- double *out_data,
- int *err);
-void iGeom_getEntSetEHData(iGeom_Instance instance,
+ /**\brief Get the value of a tag of arbitrary type on an entity set
+ * Get the value of a tag of arbitrary type on an entity set. Tag data
+ * is passed back as char* type, but really represents arbitrary data.
+ * \param *tag_value Pointer to tag data array being queried
+ * \param *tag_value_allocated Pointer to tag data array allocated size
+ * \param *tag_value_size Pointer to tag data array occupied size
+ void iGeom_getEntSetData(iGeom_Instance instance,
- iBase_EntityHandle *out_data,
+ char** tag_value,
+ int* tag_value_allocated,
+ int* tag_value_size,
int *err);
-void iGeom_getAllEntSetTags(iGeom_Instance instance,
- iBase_TagHandle** tag_handles,
- int* tag_handles_allocated,
- int* tag_handles_size,
- int *err);
+ /**\brief Get the value of a tag of integer type on an entity set
+ * Get the value of a tag of integer type on an entity set.
+ * \param *out_data Pointer to tag value returned from function
+ void iGeom_getEntSetIntData(iGeom_Instance instance,
+ int *out_data,
+ int *err);
-void iGeom_rmvEntSetTag(iGeom_Instance instance,
- int *err);
+ /**\brief Get the value of a tag of double type on an entity set
+ * Get the value of a tag of double type on an entity set.
+ void iGeom_getEntSetDblData(iGeom_Instance instance,
+ double *out_data,
+ int *err);
+ /**\brief Get the value of a tag of entity handle type on an entity set
+ * Get the value of a tag of entity handle type on an entity set.
+ void iGeom_getEntSetEHData(iGeom_Instance instance,
+ iBase_EntityHandle *out_data,
+ int *err);
-void iGeom_getArrData(iGeom_Instance instance,
- char** tag_values,
- int* tag_values_allocated,
- int* tag_values_size,
- int *err);
+ /**\brief Get all the tags associated with a specified entity set
+ * Get all the tags associated with a specified entity set
+ * \param entity_set_handle Entity being queried
+ * \param *tag_handles Pointer to array of tag_handles returned from
+ * function
+ * \param *tag_handles_allocated Pointer to allocated size of tag_handles
+ * array
+ * \param *tag_handles_size Pointer to occupied size of tag_handles array
+ void iGeom_getAllEntSetTags(iGeom_Instance instance,
+ iBase_TagHandle** tag_handles,
+ int* tag_handles_allocated,
+ int* tag_handles_size,
+ int *err);
-void iGeom_getIntArrData(iGeom_Instance instance,
- int** tag_values,
- int *err);
+ /**\brief Remove a tag value from an entity set
+ * Remove a tag value from an entity set
+ * \param entity_set_handle Entity set from which tag is being removed
+ * \param tag_handle Tag handle of tag being removed
+ void iGeom_rmvEntSetTag(iGeom_Instance instance,
+ int *err);
-void iGeom_getDblArrData(iGeom_Instance instance,
- double** tag_values,
- int *err);
-void iGeom_getEHArrData(iGeom_Instance instance,
+ /**\brief Get tag values of arbitrary type for an array of entities
+ * Get tag values of arbitrary type for an array of entities. Tag data
+ * is returned as char* type, but really represents arbitrary data.
+ * \param entity_handles Entity array on which tag is being set
+ * \param entity_handles_size Number of entities in array
+ * \param *tag_values Pointer to tag data array being returned from
+ * function
+ * \param tag_values_allocated Pointer to allocated size of tag data array
+ * \param tag_values_size Pointer to occupied size of tag data array
+ void iGeom_getArrData(iGeom_Instance instance,
- iBase_EntityHandle** tag_value,
+ char** tag_values,
+ int* tag_values_allocated,
+ int* tag_values_size,
int *err);
-void iGeom_setArrData(iGeom_Instance instance,
- const char* tag_values,
- int tag_values_size,
- int *err);
+ /**\brief Get tag values of integer type for an array of entities
+ * Get tag values of integer type for an array of entities.
+ * function
+ void iGeom_getIntArrData(iGeom_Instance instance,
+ int** tag_values,
+ int *err);
-void iGeom_setIntArrData(iGeom_Instance instance,
- const int* tag_values,
- int *err);
+ /**\brief Get tag values of double type for an array of entities
+ * Get tag values of double type for an array of entities.
+ * function
+ void iGeom_getDblArrData(iGeom_Instance instance,
+ double** tag_values,
+ int *err);
-void iGeom_setDblArrData(iGeom_Instance instance,
- const double* tag_values,
- const int tag_values_size,
- int *err);
+ /**\brief Get tag values of entity handle type for an array of entities
+ * Get tag values of entity handle type for an array of entities.
+ * \param *tag_value Pointer to tag data array being returned from
+ * function
+ * \param tag_value_allocated Pointer to allocated size of tag data array
+ * \param tag_value_size Pointer to occupied size of tag data array
+ void iGeom_getEHArrData(iGeom_Instance instance,
+ iBase_EntityHandle** tag_value,
+ int *err);
-void iGeom_setEHArrData(iGeom_Instance instance,
+ /**\brief Set tag values of arbitrary type on an array of entities
+ * Set tag values of arbitrary type on an array of entities. Tag data is
+ * passed as char* type, but really represents pointer to arbitrary data.
+ * \param tag_values Pointer to tag data being set on entity
+ * \param tag_values_size Size in total bytes of tag data
+ void iGeom_setArrData(iGeom_Instance instance,
- const iBase_EntityHandle* tag_values,
+ const char* tag_values,
int *err);
-void iGeom_rmvArrTag(iGeom_Instance instance,
- int *err);
+ /**\brief Set tag values of integer type on an array of entities
+ * Set tag values of integer type on an array of entities.
+ * \param tag_values Pointer to tag data being set on entities
+ * \param tag_values_size Size in total number of integers of tag data
+ void iGeom_setIntArrData(iGeom_Instance instance,
+ const int* tag_values,
+ int tag_values_size,
+ int *err);
-void iGeom_getData(iGeom_Instance instance,
- char** tag_value,
- int *tag_value_allocated,
- int *tag_value_size,
- int *err);
+ /**\brief Set tag values of double type on an array of entities
+ * Set tag values of double type on an array of entities.
+ * \param tag_values_size Size in total number of doubles of tag data
+ void iGeom_setDblArrData(iGeom_Instance instance,
+ const double* tag_values,
+ const int tag_values_size,
+ int *err);
-void iGeom_getIntData(iGeom_Instance instance,
- int *out_data,
- int *err);
+ /**\brief Set tag values of entity handle type on an array of entities
+ * Set tag values of entity handle type on an array of entities.
+ * \param tag_values_size Size in total number of entity handles of tag
+ * data
+ void iGeom_setEHArrData(iGeom_Instance instance,
+ const iBase_EntityHandle* tag_values,
+ int *err);
-void iGeom_getDblData(iGeom_Instance instance,
- /*in*/ const iBase_EntityHandle entity_handle,
- /*in*/ const iBase_TagHandle tag_handle,
- double *out_data, int *err);
+ /**\brief Remove a tag value from an array of entities
+ * Remove a tag value from an array of entities
+ * \param entity_handles Entity from which tag is being removed
+ void iGeom_rmvArrTag(iGeom_Instance instance,
+ int *err);
-void iGeom_getEHData(iGeom_Instance instance,
+ * Get the value of a tag of arbitrary type on an entity. Tag data
+ * \param entity_handle Entity on which tag is being set
+ void iGeom_getData(iGeom_Instance instance,
+ char** tag_value,
+ int *tag_value_allocated,
+ int *tag_value_size,
int *err);
-void iGeom_setData(iGeom_Instance instance,
- int *err);
+ * Get the value of a tag of integer type on an entity.
+ void iGeom_getIntData(iGeom_Instance instance,
+ int *out_data,
+ int *err);
-void iGeom_setIntData(iGeom_Instance instance,
- int tag_value,
- int *err);
+ * Get the value of a tag of double type on an entity.
+ void iGeom_getDblData(iGeom_Instance instance,
+ /*in*/ const iBase_EntityHandle entity_handle,
+ /*in*/ const iBase_TagHandle tag_handle,
+ double *out_data, int *err);
-void iGeom_setDblData(iGeom_Instance instance,
- double tag_value,
- int *err);
+ * Get the value of a tag of entity handle type on an entity.
+ void iGeom_getEHData(iGeom_Instance instance,
+ int *err);
-void iGeom_setEHData(iGeom_Instance instance,
+ * Set a tag value of arbitrary type on an entity. Tag data is
+ void iGeom_setData(iGeom_Instance instance,
int *err);
-void iGeom_getAllTags(iGeom_Instance instance,
- int *err);
+ * Set a tag value of integer type on an entity.
+ void iGeom_setIntData(iGeom_Instance instance,
+ int tag_value,
+ int *err);
-void iGeom_rmvTag(iGeom_Instance instance,
- int *err);
+ * Set a tag value of double type on an entity.
+ void iGeom_setDblData(iGeom_Instance instance,
+ double tag_value,
+ int *err);
-void iGeom_subtract(iGeom_Instance instance,
- iBase_EntitySetHandle entity_set_1,
- iBase_EntitySetHandle entity_set_2,
- iBase_EntitySetHandle* result_entity_set,
+ * Set a tag value of entity handle type on an entity.
+ void iGeom_setEHData(iGeom_Instance instance,
+ int *err);
+ /**\brief Get all the tags associated with a specified entity handle
+ * Get all the tags associated with a specified entity handle
+ * \param entity_handle Entity being queried
+ * function
+ * array
+ void iGeom_getAllTags(iGeom_Instance instance,
+ int *err);
+ * \param entity_handle Entity from which tag is being removed
+ void iGeom_rmvTag(iGeom_Instance instance,
int *err);
-void iGeom_intersect(iGeom_Instance instance,
- int *err);
+ /**\brief Subtract contents of one entity set from another
+ * Subtract contents of one entity set from another
+ * \param entity_set_1 Entity set from which other set is being subtracted
+ * \param entity_set_2 Entity set being subtracted from other set
+ * \param result_entity_set Pointer to entity set returned from function
+ void iGeom_subtract(iGeom_Instance instance,
+ iBase_EntitySetHandle entity_set_1,
+ iBase_EntitySetHandle entity_set_2,
+ iBase_EntitySetHandle* result_entity_set,
+ int *err);
-void iGeom_unite(iGeom_Instance instance,
- int *err);
+ /**\brief Intersect contents of one entity set with another
+ * Intersect contents of one entity set with another
+ * \param entity_set_1 Entity set being intersected with another
+ * \param entity_set_2 Entity set being intersected with another
+ void iGeom_intersect(iGeom_Instance instance,
+ int *err);
+ /**\brief Unite contents of one entity set with another
+ * Unite contents of one entity set with another
+ * \param entity_set_1 Entity set being united with another
+ * \param entity_set_2 Entity set being united with another
+ void iGeom_unite(iGeom_Instance instance,
+ int *err);
#ifdef __cplusplus
} // extern "C"
#endif
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc 2008-03-06 19:58:48 UTC (rev 1637)
+++ cgm/trunk/itaps/iGeom_CGMA.cc 2008-03-07 19:12:39 UTC (rev 1638)
@@ -2739,10 +2739,9 @@
void
iGeom_getFaceType( iGeom_Instance instance,
/*in*/ iBase_EntityHandle gentity_handle,
- /*out*/ char **face_type,
- int* err)
+ /*out*/ char *face_type,
+ int* err,
+ int *face_type_length)
static const char *surf_types[] = {"cone", "plane", "sphere", "spline",
"torus", "best_fit", "facet", "undefined"};
@@ -2756,24 +2755,13 @@
const char* result = surf_types[this_type - CONE_SURFACE_TYPE];
const int len = strlen(result);
- // need to allocate space for string
- if (*face_type_allocated == 0 || !*face_type) {
- *face_type_allocated = len + 1;
- *face_type_size = len;
- *face_type = strdup( result );
+ if (len < *face_type_length) {
+ strcpy(face_type, result);
+ *face_type_length = len;
- // enough space for text, but not for null termination char
- else if (*face_type_allocated == len) {
- memcpy( *face_type, result, len );
- // enough space for null-terminated string
- else if (*face_type_allocated > len) {
- strcpy( *face_type, result );
- // already allocated w/ insuffucient space
else {
- RETURN (iBase_BAD_ARRAY_SIZE);
+ strncpy(face_type, result, *face_type_length-1);
+ face_type[*face_type_length] = '\0';
RETURN(iBase_SUCCESS);
More information about the cgma-dev
