[cgma-dev] r1636 - in cgm/trunk: geom/OCC test
janehu at mcs.anl.gov janehu at mcs.anl.gov
Wed Mar 5 14:12:56 CST 2008
Author: janehu
Date: 2008-03-05 14:12:56 -0600 (Wed, 05 Mar 2008)
New Revision: 1636
Modified:
   cgm/trunk/geom/OCC/OCCCurve.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.cpp
   cgm/trunk/geom/OCC/OCCModifyEngine.hpp
   cgm/trunk/test/makept.cpp
Log:
Added check for curve intersection before making surface from curve list; Added for point_containment for curve to distinguash inside and on boundary situations; Updated testcases.
Modified: cgm/trunk/geom/OCC/OCCCurve.cpp
--- cgm/trunk/geom/OCC/OCCCurve.cpp	2008-03-05 17:24:48 UTC (rev 1635)
+++ cgm/trunk/geom/OCC/OCCCurve.cpp	2008-03-05 20:12:56 UTC (rev 1636)
@@ -878,8 +878,19 @@
 CubitPointContainment OCCCurve::point_containment( const CubitVector &point )
    if (is_position_on(point) == CUBIT_TRUE)
+     DLIList<OCCPoint*> points;
+     get_points(points);
+     for (int i = 0; i < points.size(); i++)
+	OCCPoint* pnt = points.get_and_step();
+        CubitVector v = pnt->coordinates();
+        double d = v.distance_between(point);
+        if (d < GEOMETRY_RESABS)
+	  return CUBIT_PNT_BOUNDARY;
      return CUBIT_PNT_ON;
    return CUBIT_PNT_OFF;
@@ -1030,8 +1041,8 @@
         GCPnts_QuasiUniformAbscissa distribution1(acurve1, NbPoints);
         GCPnts_QuasiUniformAbscissa distribution2(acurve2, NbPoints);
         TColgp_Array1OfPnt points(1, 2*NbPoints-1);
-        int i = 1;
-        for (i; i <= NbPoints; i++)
+        int i;
+        for (i = 1; i <= NbPoints; i++)
            double u = distribution1.Parameter(i);
            gp_Pnt P = myCurve1->Value(u);
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-03-05 17:24:48 UTC (rev 1635)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp	2008-03-05 20:12:56 UTC (rev 1636)
@@ -662,8 +662,10 @@
   TopoDS_Edge* topo_edge = NULL;
   //check no intersections of the TopoDS_Edge's.
-  //need to check that no intersection in the middle of the curves not at
-  //vertices.
+  //need to check that no intersection in the middle of the curves, not at
+  //vertices or out of boundary.
+  int count = 0; //intersection point should be the same as curve_list size.
   for ( int i = 0 ; i < curve_list.size()-1 ; i++ )
      for(int j = i+1; j < curve_list.size(); j ++)
@@ -676,12 +678,45 @@
 				curve_list[j], intscts, bounded, closest);
         if(yes_int)
-	   PRINT_ERROR("In OCCModifyEngine::make_Surface\n"
+           //check intscts point should be vertex or outside boundary.
+ 	   if (intscts.size() > 2 )
+	     PRINT_ERROR("In OCCModifyEngine::make_Surface\n"
                  "       Cannot make Surface with intersecting curves.\n");
-           return (Surface *)NULL;
+             return (Surface *)NULL;
+           else
+             for(int k = 0; k < intscts.size(); k++)
+               CubitVector *v = intscts.get_and_step();
+	       CubitPointContainment is_on = CAST_TO(curve_list[i],OCCCurve)->
+					point_containment(*v);
+               if (is_on == CUBIT_PNT_BOUNDARY)
+	 	 is_on = CAST_TO(curve_list[j],OCCCurve)->
+                   count++;
+               else if(is_on == CUBIT_PNT_INSIDE)
+                 "       Cannot make Surface with intersecting curves.\n");
+  if (count > curve_list.size())
   //sort the curves so they are in order and make closed loop
   OCCPoint* start = NULL;
@@ -690,7 +725,7 @@
   double tol = OCCQueryEngine::instance()->get_sme_resabs_tolerance();
   CubitBoolean new_end = CUBIT_TRUE;
   int size = curve_list.size();
-  int count = 0;
+  count = 0;
   for ( int i = 0 ; i < size ; i++ )
      for(int j = 0; j < curve_list.size(); j ++)
@@ -871,7 +906,7 @@
           error = CUBIT_TRUE;
           break;
-        topo_face = &(made_face.Face());
+        topo_face = new TopoDS_Face(made_face.Face());
       else
@@ -884,7 +919,7 @@
           break;
     else
@@ -896,7 +931,8 @@
         break;
+      delete topo_face;
@@ -1156,7 +1192,7 @@
 BodySM* OCCModifyEngine::prism( double height, int sides, double major,
                                double minor) const
+  PRINT_ERROR("Option not supported for OCC based geometry.\n");
   return (BodySM*) NULL;
@@ -1170,7 +1206,7 @@
 BodySM* OCCModifyEngine::pyramid( double height, int sides, double major,
                                  double minor, double top) const
-  PRINT_ERROR("Option not supported for mesh based geometry.\n");
@@ -1192,7 +1228,7 @@
   TopoDS_Solid S;
-  if(r3 == 0)//elliptical cylinder
+  if(r3 == 0)//elliptical based cylinder
     gp_Pnt center(0.0, 0.0, 0.0);
     gp_Dir main_dir(0.0, 0.0, 1.0);
@@ -1225,7 +1261,11 @@
        CUBIT_TRUE);
   if (lump == NULL)
+    PRINT_ERROR("In OCCModifyEngine::cylinder\n"
+                "   Cannot create a cylinder for given radii.\n");
     return (BodySM*)NULL;
   return CAST_TO(lump, OCCLump)->body();
@@ -1248,7 +1288,11 @@
        CUBIT_TRUE);
   if (lump == NULL)
+    PRINT_ERROR("In OCCModifyEngine::torus\n"
+                "   Cannot create a torus for given radii.\n");
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.hpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-03-05 17:24:48 UTC (rev 1635)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.hpp	2008-03-05 20:12:56 UTC (rev 1636)
@@ -652,6 +652,7 @@
                                   DLIList<BodySM*> &new_bodies,
                                   DLIList<TopologyBridge*>*,
                                   DLIList<TopologyBridge*>* ) const;
 protected:
  const TopoDS_Face* make_TopoDS_Face( GeometryType surface_type,
Modified: cgm/trunk/test/makept.cpp
--- cgm/trunk/test/makept.cpp	2008-03-05 17:24:48 UTC (rev 1635)
+++ cgm/trunk/test/makept.cpp	2008-03-05 20:12:56 UTC (rev 1636)
@@ -109,7 +109,7 @@
   char *argv = "./66_shaver3.brep";
   CubitStatus status = read_geometry(1, &argv);
   if (status == CUBIT_FAILURE) exit(1);
   argv = "./62_shaver1.brep";
@@ -117,7 +117,33 @@
   argv = "./72_shaver6.brep";
+  // test create a Compound body.
+  DLIList<Body*> test_bodies;
+  gti->bodies(test_bodies);
+  DLIList<RefVolume*> ref_volume_list;
+  for(int i = 0; i < test_bodies.size(); i++)
+    test_bodies.get_and_step()->ref_volumes(ref_volume_list);
+  Body* CompBody = gmti->make_Body(ref_volume_list);
+  BodySM* CompBodySM = CompBody->get_body_sm_ptr();
+  OCCBody *occ_CompBody = CAST_TO(CompBodySM, OCCBody);
+  test_bodies.clean_out();
+  CubitVector vi, vii;
+  vi = CompBody->center_point();
+  CubitVector axis(10,0,0);
+  gti->translate(CompBody,axis);
+  // After parellel move, center point moved by x (10)
   CubitVector vector1(10,10,10);
   CubitVector vector2(10,-10,10);
   DLIList<RefEntity*> free_entities;
@@ -128,13 +154,6 @@
   gti->get_free_ref_entities(free_entities);
-  //translate the two vertice by (10,10,10) and (20,20,20)
-  for(int i = 1; i <= free_entities.size(); i++)
-     RefEntity * entity = free_entities.get_and_step();
-     gti->translate((BasicTopologyEntity*)entity, i*vector1);
   CubitStatus rsl = CUBIT_SUCCESS;
   DLIList<RefEntity*> ref_entity_list;
   int num_ents_exported=0;
@@ -160,11 +179,10 @@
 		about_spatially_equal(vertex1,vertex2);
   //vertex1,vertex2 are not spatially equal.
-  CubitVector vi, vii;
   double d;
   gti->entity_entity_distance(vertex1,vertex2,vi, vii,d);
   // distance (d) between vertex1,vertex2. vi (20, 20, 20) is vertex1
-  //translated by (10,10,10) and vii(35, 35, 35) is vertex2 translated
+  //translated by (10,10,10) and vii(30, 10, 30) is vertex2 translated
   //by 2*(10,10,10).
   //check for body
@@ -183,7 +201,6 @@
   BodySM* body = bodies.get()->get_body_sm_ptr();
   OCCBody* occ_body = CAST_TO(body, OCCBody);
-  CubitVector axis(10,0,0);
   gti->reflect(bodies, axis);
   vi = bodies.get()->center_point();
   // After reflection, only x value should change.
@@ -218,26 +235,35 @@
   DLIList<RefFace*> ref_faces;
   gti->ref_faces(ref_faces);
-  RefFace* ref_face = ref_faces.step_and_get();
+  //RefFace* ref_face = ref_faces.step_and_get();
+  RefFace* ref_face = ref_faces.get();
   //make a new refface out of existing refface.
-  CubitBoolean extended_from = CUBIT_FALSE;
+  CubitBoolean extended_from = CUBIT_TRUE;
   RefFace* new_face = gmti->make_RefFace(ref_face, extended_from);
+  rsl = gti->export_solid_model(ref_entity_list, filename, filetype,
+                                 num_ents_exported, cubit_version);
   DLIList<DLIList<RefEdge*>*> ref_edge_loops;
   new_face->ref_edge_loops(ref_edge_loops);
   DLIList<RefEdge*>* ref_edge_list;
   ref_edge_list = ref_edge_loops.get();
+  RefVertex* start = NULL;
+  RefVertex* end = NULL;
   for (int i = 0; i < ref_edge_list->size(); i++)
     RefEdge * edge = ref_edge_list->get_and_step();
     double d = edge->measure();
-    RefVertex* start = edge->start_vertex();
-    RefVertex* end = edge->end_vertex();
+    start = edge->start_vertex();
+    end = edge->end_vertex();
+  RefFace* new_face2 = gmti->make_RefFace(PLANE_SURFACE_TYPE,
+                         *ref_edge_list, ref_face, CUBIT_TRUE);
   bodies.clean_out();
   gti->bodies(bodies);
   //translate the new face by (40,40,40)
@@ -250,8 +276,12 @@
      gti->translate(entity, i*vector1);
-  vi = new_face->center_point();
-  //center point shout moved by (40,40,40) compared with the original one below
+  RefVolume* volume = NULL;
+  if ( new_face->get_surface_ptr()->is_closed_in_U())
+    volume = new_face->ref_volume();
+  else
+    vi = new_face->center_point();
+  //center point should moved by (40,40,40) compared with the original one below
   vi = ref_face->center_point();
   // center point
More information about the cgma-dev mailing list
