[cgma-dev] r1915 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Fri Jun 20 13:33:15 CDT 2008
Author: janehu
Date: 2008-06-20 13:33:15 -0500 (Fri, 20 Jun 2008)
New Revision: 1915
Modified:
cgm/trunk/geom/OCC/OCCModifyEngine.cpp
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
Log:
Added function to make thick solid.
Modified: cgm/trunk/geom/OCC/OCCModifyEngine.cpp
--- cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-06-19 17:33:03 UTC (rev 1914)
+++ cgm/trunk/geom/OCC/OCCModifyEngine.cpp 2008-06-20 18:33:15 UTC (rev 1915)
@@ -52,6 +52,7 @@
#include "BRepBuilderAPI_MakeEdge.hxx"
#include "BRepAdaptor_Surface.hxx"
#include "BRepBuilderAPI_MakeFace.hxx"
+#include "BRepOffsetAPI_MakeThickSolid.hxx"
#include "BRepBuilderAPI_Sewing.hxx"
#include "BRepBuilderAPI_Copy.hxx"
#include "LocOpe_SplitShape.hxx"
@@ -3583,18 +3584,89 @@
// Function : thicken
// Member Type: PUBLIC
-// Description:
-// Author : John Fowler
-// Date : 10/02
+// Description: Hollow existing solid body by remove one or several surfaces
+// Can only take one body at a time.
+// No both (side) option.
+// depth > 0, thick body going outside bodies
+// depth < 0, thick body going inside bodies
+// Author : Jane Hu
+// Date : 06/08
-CubitStatus OCCModifyEngine::thicken(DLIList<BodySM*>& /*bodies*/,
+CubitStatus OCCModifyEngine::thicken(DLIList<BodySM*>& bodies,
DLIList<Surface*>& surfs_to_remove,
- DLIList<BodySM*>& /*new_bodies*/,
- double /*depth*/,
- bool /*both*/) const
+ DLIList<BodySM*>& new_bodies,
+ double depth,
+ bool /*both*/) const
- PRINT_ERROR("Option not supported for mesh based geometry.\n");
- return CUBIT_FAILURE;
+ if(bodies.size() != 1 || surfs_to_remove.size() < 1)
+ PRINT_ERROR("Making thick solid in OCC will take one body and at least one surface at a time.\n");
+ return CUBIT_FAILURE;
+ DLIList<TopoDS_Shape*> shape_list;
+ DLIList<CubitBoolean> is_volume;
+ CubitStatus stat = get_shape_list(bodies, shape_list, is_volume, CUBIT_FALSE);
+ if(!stat)
+ return stat;
+ if(!is_volume.get())//sheet body
+ PRINT_ERROR("Making thick solid in OCC needs an initial solid body to hollow with.\n");
+ //make sure the body to be hollowed has only one lump
+ OCCBody* occ_body = CAST_TO(bodies.get(), OCCBody);
+ DLIList<Lump*> lumps;
+ lumps = occ_body->lumps();
+ if(lumps.size()!=1)
+ PRINT_ERROR("bodies with more than one lump can't be hollowed to make a thick body.\n");
+ //make sure surfs_to_remove are all in bodies
+ DLIList<OCCSurface*> surfaces;
+ TopTools_ListOfShape face_shapes;
+ occ_body->get_all_surfaces(surfaces);
+ for(int i = 0; i < surfs_to_remove.size(); i++)
+ OCCSurface* occ_surf = CAST_TO(surfs_to_remove.get(), OCCSurface);
+ if(!occ_surf)
+ continue;
+ if(!surfaces.is_in_list(occ_surf))
+ continue;
+ TopoDS_Face * face = occ_surf->get_TopoDS_Face();
+ face_shapes.Append(*face);
+ if(face_shapes.IsEmpty())
+ PRINT_ERROR("The surfaces provided should be from the body to be hollowed.\n");
+ double tol = 1.e-3; //hard coded for now, can be changed by application
+ TopoDS_Shape* solid = shape_list.get();
+ BRepOffsetAPI_MakeThickSolid hollower(*solid, face_shapes, depth, tol);
+ TopoDS_Shape new_shape = hollower.Shape();
+ TopoDS_Solid old_solid = TopoDS::Solid(*solid);
+ OCCLump::update_OCC_entity(old_solid , new_shape, &hollower);
+ //ok, we're done with all hollowing, construct new Body'
+ DLIList<TopologyBridge*> tbs;
+ tbs += OCCQueryEngine::instance()->populate_topology_bridge(new_shape);
+ for (int i = 0; i< tbs.size(); i++)
+ BodySM* bodysm = CAST_TO(tbs.get_and_step(), BodySM);
+ if (bodysm)
+ new_bodies.append(bodysm);
+ return CUBIT_SUCCESS;
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-06-19 17:33:03 UTC (rev 1914)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2008-06-20 18:33:15 UTC (rev 1915)
@@ -2,7 +2,7 @@
// Filename : OCCQueryEngine.cpp
// Purpose : Implementation of the OCCQueryEngine class.
-// This class provides facet-based implementations
+// This class provides OCC-based implementations
// of various virtual functions in the GeometryQueryEngine
// hierarchy.
@@ -2310,8 +2310,6 @@
return status;
-const char* fqe_xform_err = "Transform not implemented for OCC geometry.\n";
CubitStatus OCCQueryEngine::restore_transform( BodySM* body )
More information about the cgma-dev
