[cgma-dev] r1872 - in cgm/trunk/itaps: . SIDL SIDL/gserver
    kraftche at mcs.anl.gov
    Wed Jun  4 13:31:30 CDT 2008
Author: kraftche
Date: 2008-06-04 13:31:30 -0500 (Wed, 04 Jun 2008)
New Revision: 1872
Modified:
   cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc
   cgm/trunk/itaps/SIDL/iGeom.sidl
   cgm/trunk/itaps/iGeom.h
   cgm/trunk/itaps/iGeom_CGMA.cc
Log:
add missing sphere create method
Modified: cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc
--- cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc	2008-06-04 13:33:47 UTC (rev 1871)
+++ cgm/trunk/itaps/SIDL/gserver/iGeom_SIDL_GeomSidl_Impl.cc	2008-06-04 18:31:30 UTC (rev 1872)
@@ -3977,6 +3977,23 @@
+ * Method:  Sphere[]
+void
+iGeom_SIDL::GeomSidl_impl::Sphere (
+  /* in */ double radius,
+  /* out */ void*& geom_entity )
+throw (
+  ::iBase::Error
+  // DO-NOT-DELETE splicer.begin(iGeom_SIDL.GeomSidl.Sphere)
+  // Insert-Code-Here {iGeom_SIDL.GeomSidl.Sphere} (Sphere method)
+  iGeom_Sphere(igeomInstance, radius, &geom_entity);
+  PROCESS_ERROR;
+  // DO-NOT-DELETE splicer.end(iGeom_SIDL.GeomSidl.Sphere)
  * Method:  Brick[]
 void
Modified: cgm/trunk/itaps/SIDL/iGeom.sidl
--- cgm/trunk/itaps/SIDL/iGeom.sidl	2008-06-04 13:33:47 UTC (rev 1871)
+++ cgm/trunk/itaps/SIDL/iGeom.sidl	2008-06-04 18:31:30 UTC (rev 1872)
@@ -989,6 +989,12 @@
   interface Primitives extends Modify
+//==========================Sphere=================
+        /* Construct a Sphere with specified radius. */
+      void Sphere(in double radius,
+                  out opaque geom_entity)
+        throws iBase.Error;
 //==========================Brick=================
         /* Construct a brick with specified dimensions.  If both y and z are
          * zero, a cube of dimension x is constructed.
Modified: cgm/trunk/itaps/iGeom.h
--- cgm/trunk/itaps/iGeom.h	2008-06-04 13:33:47 UTC (rev 1871)
+++ cgm/trunk/itaps/iGeom.h	2008-06-04 18:31:30 UTC (rev 1872)
@@ -2059,6 +2059,13 @@
                         iBase_EntityHandle,
                         int* err );
+    /**\brief Create a sphere centered on the origin
+  void iGeom_createSphere( iGeom_Instance,
+                           double radius,
+                           iBase_EntityHandle* sphere_handle_out,
+                           int* err );
 /**\brief
Modified: cgm/trunk/itaps/iGeom_CGMA.cc
--- cgm/trunk/itaps/iGeom_CGMA.cc	2008-06-04 13:33:47 UTC (rev 1871)
+++ cgm/trunk/itaps/iGeom_CGMA.cc	2008-06-04 18:31:30 UTC (rev 1872)
@@ -5135,6 +5135,22 @@
 void
+iGeom_createSphere( iGeom_Instance instance,
+                    double radius,
+                    iBase_EntityHandle *geom_entity,
+                    int* err )
+  if (radius <= 0.0) {
+    ERROR(iBase_INVALID_ARGUMENT, "Sphere radius must be must be positive.");
+  RefEntity* tmp_body = gmt->sphere( radius );
+  *geom_entity = tmp_body;
+  RETURN ((tmp_body ? iBase_SUCCESS : iBase_FAILURE));
+void
 iGeom_createBrick (iGeom_Instance instance,
                    /*in*/ double x,
                    /*in*/ double y,
More information about the cgma-dev
