[cgma-dev] r1981 - in cgm/trunk: . cgm_apps/examples/driverc++ cgm_apps/examples/facetdriver geom geom/ACIS_SRC geom/Cholla geom/OCC geom/facet geom/facetbool geom/parallel geom/virtual init itaps itaps/SIDL test util
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Jul 3 16:51:09 CDT 2008
Author: kraftche
Date: 2008-07-03 16:51:09 -0500 (Thu, 03 Jul 2008)
New Revision: 1981
Removed:
   cgm/trunk/itaps/iGeom-Defs.inc.in
Modified:
   cgm/trunk/Makefile.am
   cgm/trunk/cgm.make.in
   cgm/trunk/cgm_apps/examples/driverc++/Makefile.am
   cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am
   cgm/trunk/configure.in
   cgm/trunk/geom/ACIS_SRC/Makefile.am
   cgm/trunk/geom/Cholla/Makefile.am
   cgm/trunk/geom/Makefile.am
   cgm/trunk/geom/OCC/Makefile.am
   cgm/trunk/geom/facet/Makefile.am
   cgm/trunk/geom/facetbool/Makefile.am
   cgm/trunk/geom/parallel/Makefile.am
   cgm/trunk/geom/virtual/Makefile.am
   cgm/trunk/init/Makefile.am
   cgm/trunk/itaps/Makefile.am
   cgm/trunk/itaps/SIDL/Makefile.am
   cgm/trunk/test/Makefile.am
   cgm/trunk/util/Makefile.am
Log:
o Combine all compiled libraries (except SIDL stuff) into a single
  libcgm.a, and install only that library.
o Update all tests to reference libcgm.a.  This greatly simplifies
  build defintions for tests because libcgm automatically pulls
  in all conditional dependencies (including libcubiti19.so if
  we're not actually building CGM.)
o Greatly simplify makefile stubs by dropping support for using them
  before installing CGM.
Modified: cgm/trunk/Makefile.am
--- cgm/trunk/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -1,5 +1,5 @@
 AUTOMAKE_OPTIONS = foreign
-SUBDIRS = util geom init itaps test cgm_apps
+SUBDIRS = util geom init itaps . test cgm_apps
 # Automake doesn't seem to have a directory defined for
 # platform-dependent data (or include) files. So put
@@ -8,14 +8,71 @@
 cfgdir = $(libdir)
 cfg_DATA = cgm.make
+lib_LTLIBRARIES = libcgm.la
+EXT_LINK_FLAGS =
+EXT_LIBTOOL_FLAGS =
+EXT_LIBS =
+EXT_INCLUDE =
+if build_parallel
+  CGM_ll_LIB = geom/parallel/libcubit_parallel.la
+else
+  CGM_ll_LIB =
+endif
+if build_ACIS
+  CGM_ACIS_LIB = $(CGM_ll_LIB) geom/ACIS/libcubit_ACIS.la
+  EXT_LINK_FLAGS += -L$(ACIS_LIB_DIR)
+  EXT_LIBTOOL_FLAGS += -R$(ACIS_LIB_DIR)
+  EXT_LIBS += $(ACIS_LIBS)
+  EXT_INCLUDE += $(ACIS_INCLUDES) $(ACIS_DEFINES)
+else
+  CGM_ACIS_LIB =
+endif
+if WITH_OCC
+  CGM_OCC_LIB = geom/OCC/libcubit_OCC.la
+  EXT_LINK_FLAGS += -L$(OCC_LIB_DIR)
+  EXT_LIBTOOL_FLAGS += -R$(OCC_LIB_DIR)
+  EXT_LIBS += $(OCC_LIBS)
+  EXT_INCLUDE += $(OCC_INC_FLAG)
+else
+  CGM_OCC_LIB =
+endif
+if BUILD_CGM
+  CORE_CGM_LIBS = $(CGM_ACIS_LIB) \
+                  $(CGM_OCC_LIB) \
+                  $(CGM_ll_LIB) \
+                  geom/virtual/libcubit_virtual.la \
+                  geom/facet/libcubit_facet.la \
+		  geom/Cholla/libcholla.la \
+                  geom/facetbool/libcubit_facetbool.la \
+                  geom/libcubit_geom.la \
+                  util/libcubit_util.la
+else
+  CORE_CGM_LIBS = $(CUBIT_LTFLAGS) $(CUBIT_LDFLAGS) $(CUBIT_LIBS)
+endif
+libcgm_la_LIBADD = init/libcgma_init.la \
+                   itaps/libiGeom.la \
+                   $(CORE_CGM_LIBS) \
+                   $(EXT_LINK_FLAGS) \
+                   $(EXT_LIBS)
+libcgm_la_SOURCES =
 # By default, cmg.make will define these to $(srcdir).  We
 # want to override that during the INSTALL of the file so
 # that the correct values are set (e.g. if someone does
 # 'make prefix=/foo install', we don't know the correct install
 # directory until we're doing the install.
+CFG_FILE = $(DESTDIR)$(cfgdir)/cgm.make
 install-data-hook:
-	echo 'CGM_LIBS_LDFLAGS=$$(CGM_LIBS_LDFLAGS_INSTALLED)' >> $(DESTDIR)$(cfgdir)/cgm.make
-	echo 'CGMA_INIT_LDFLAGS=$$(CGMA_INIT_LDFLAGS_INSTALLED)' >> $(DESTDIR)$(cfgdir)/cgm.make
-	echo 'CGM_INCLUDES=$$(CGM_INC_CPPFLAGS_INSTALLED)' >> $(DESTDIR)$(cfgdir)/cgm.make
-	echo "CGM_LIBDIR=${libdir}" >> $(DESTDIR)$(cfgdir)/cgm.make
-	echo "CGM_INCLUDEDIR=${includedir}" >> $(DESTDIR)$(cfgdir)/cgm.make
+	echo "CGM_EXT_INCLUDE = $(EXT_INCLUDE)"       >> $(CFG_FILE)
+	echo "CGM_EXT_LIBS    = $(EXT_LIBS)"          >> $(CFG_FILE)
+	echo "CGM_EXT_LDFLAGS = $(EXT_LINK_FLAGS)"    >> $(CFG_FILE)
+	echo "CGM_EXT_LTFLAGS = $(EXT_LIBTOOL_FLAGS)" >> $(CFG_FILE)
+	echo "CGM_LIBDIR      = $(libdir)"            >> $(CFG_FILE)
+	echo "CGM_INCLUDEDIR  = $(includedir)"        >> $(CFG_FILE)
Modified: cgm/trunk/cgm.make.in
--- cgm/trunk/cgm.make.in	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/cgm.make.in	2008-07-03 21:51:09 UTC (rev 1981)
@@ -11,124 +11,24 @@
-CANT_USE_STD           = @CANT_USE_STD@
-CANT_USE_STD_IO        = @CANT_USE_STD_IO@
-TEMPLATE_DEFS_INCLUDED = @TEMPLATE_DEFS_INCLUDED@
+# The following variables are overridden when this file is installed
+CGM_EXT_INCLUDE =
+CGM_EXT_LIBS    =
+CGM_EXT_LDFLAGS =
+CGM_EXT_LTFLAGS =
+CGM_INCLUDEDIR  = .
+CGM_LIBDIR      = $(abs_buildidr)/.libs
-ACIS_DEFS            = @ACIS_DEFS@
-ACIS_DIR             = @ACIS_DIR@
-ACIS_LIB_DIR         = @ACIS_LIB_DIR@
-ACIS_LINK_FLAGS      = @ACIS_LINK_FLAGS@
-ACIS_VERSION         = @ACIS_VERSION@
-ACIS_HEALER          = @ACIS_HEALER@
-ACIS_PLATFORM        = @ACIS_PLATFORM@
-ACIS_STEP_TRANSLATOR = @ACIS_STEP_TRANSLATOR@
-ACIS_IGES_TRANSLATOR = @ACIS_IGES_TRANSLATOR@
-ACIS_LIBS            = @CGM_ACIS_LIBS@ @ACIS_LIBS@
-ACIS_INCLUDES        = @ACIS_INCLUDES@
+# Pre-processor flags
+CGM_DEFINES = @CANT_USE_STD@ @CANT_USE_STD_IO@ @TEMPLATE_DEFS_INCLUDED@
+CGM_INCLUDES = $(CGM_EXT_INCLUDE) -I$(CGM_INCLUDEDIR)
+CGM_CPPFLAGS = $(CGM_DEFINES) $(CGM_INCLUDES)
-OCC_INCLUDES	     = @OCC_INC_FLAG@
-OCC_LIB_DIR          = @OCC_LIB_DIR@
-OCC_LIB_FLAG	     = @OCC_LIB_FLAG@
-OCC_LIBS	     = @CUBIT_OCC_LIB@ @OCC_LIBS@
+# Link flags
+CGM_LDFLAGS = -L$(CGM_LIBDIR) $(CGM_EXT_LDFLAGS)
+CGM_LTFLAGS = -R$(CGM_LIBDIR) $(CGM_EXT_LTFLAGS)
+CGM_LIBS = -lcgm $(CGM_EXT_LIBS)
+CGM_LIBS_LINK = $(CGM_LDFLAGS) $(CGM_LIBS)
-CGM_PARALLEL_INCLUDE = @CGM_PARALLEL_INCLUDE@
-CGM_PARALLEL_LIB = @CGM_PARALLEL_LIB@
-CGM_PARALLEL_LIB_FILE = @CGM_PARALLEL_LIB_FILE@
-# These get redefined by a makefile target during *install*
-# by appending correct values to the end of the file.
-CGM_LIBDIR = @abs_builddir@
-CGM_INCLUDEDIR = @abs_srcdir@
+# Build-generated values appended after this line
-CGM_CXX = @CXX@
-CGM_CC = @CC@
-CGM_CPPFLAGS = @CUBIT_CGM@ @CANT_USE_STD@ @CANT_USE_STD_IO@ @TEMPLATE_DEFS_INCLUDED@ ${ACIS_DEFS}
-CGM_CXXFLAGS = @CXXFLAGS@
-CGM_CFLAGS = @CFLAGS@
-CGM_LDFLAGS = @LDFLAGS@
-CGM_INC_CPPFLAGS_COMMON = ${ACIS_INCLUDES} ${OCC_INCLUDES}
-CGM_INC_CPPFLAGS_UNINSTALLED = \
-               -I at abs_srcdir@/util \
-               -I at abs_builddir@/util \
-               -I at abs_srcdir@/init \
-               -I at abs_srcdir@/geom \
-               -I at abs_builddir@/geom \
-               -I at abs_srcdir@/itaps \
-               -I at abs_builddir@/itaps \
-               -I at abs_srcdir@/geom/ACIS \
-               -I at abs_srcdir@/geom/OCC \
-               $(CGM_PARALLEL_INCLUDE) \
-               $(CGM_INC_CPPFLAGS_COMMON)
-CGM_INC_CPPFLAGS_INSTALLED = \
-               -I$(CGM_INCLUDEDIR) \
-# will be overriden upon install
-CGM_INCLUDES = $(CGM_INC_CPPFLAGS_UNINSTALLED)
-CGM_LIBS_LDFLAGS_COMMON = $(ACIS_LINK_FLAGS) $(OCC_LIB_FLAG)
-CGM_LIBS_LDFLAGS_UNINSTALLED = \
-	-L at abs_builddir@/geom/virtual/.libs \
-        -L at abs_builddir@/geom/facetbool/.libs \
-        -L at abs_builddir@/geom/facet/.libs \
-	-L at abs_builddir@/geom/Cholla/.libs \
-        -L at abs_builddir@/geom/ACIS/.libs \
-        -L at abs_builddir@/geom/OCC/.libs \
-        -L at abs_builddir@/geom/.libs \
-        -L at abs_builddir@/util/.libs \
-	-L at abs_builddir@/geom/virtual \
-        -L at abs_builddir@/geom/facetbool \
-        -L at abs_builddir@/geom/facet \
-	-L at abs_builddir@/geom/Cholla \
-        -L at abs_builddir@/geom/ACIS \
-        -L at abs_builddir@/geom \
-        -L at abs_builddir@/util \
-        $(CGM_LIBS_LDFLAGS_COMMON)
-CGM_LIBS_LDFLAGS_INSTALLED = -L$(CGM_LIBDIR) $(CGM_LIBS_LDFLAGS_COMMON)
-CGM_LIBS_LIBRARIES = \
-        ${ACIS_LIBS} \
-        -lcubit_virtual \
-        -lcubit_facet \
-        -lcubit_facetbool \
-        -lcholla \
-        ${ACIS_LIBS} \
-        -lcubit_geom \
-        -lcubit_util \
-	${CGM_PARALLEL_LIB} \
-        ${OCC_LIBS}
-# Will be overridden upon install
-CGM_LIBS_LDFLAGS = $(CGM_LIBS_LDFLAGS_UNINSTALLED)
-CGM_LIBS_LINK_INTERNAL = $(LDFLAGS) $(CGM_LIBS_LDFLAGS) $(CGM_LIBS_LIBRARIES)
-CGMA_INIT_LDFLAGS_UNINSTALLED = -L at abs_builddir@/init -L at abs_builddir@/init/.libs
-CGMA_INIT_LDFLAGS_INSTALLED = -L$(CGM_LIBDIR)
-CGMA_INIT_LDFLAGS = $(CGMA_INIT_LDFLAGS_UNINSTALLED)
-CGM_LIBS_FILES_INTERNAL = \
-       $(CGM_LIBDIR)/libcgma_init.la \
-       $(CGM_LIBDIR)/libcubit_virtual.la \
-       $(CGM_LIBDIR)/libcubit_facetbool.la \
-       $(CGM_LIBDIR)/libcubit_facet.la \
-       $(CGM_LIBDIR)/libcholla.la \
-       $(CGM_LIBDIR)/libcubit_geom.la \
-       $(CGM_LIBDIR)/libcubit_util.la \
-       ${CGM_PARALLEL_LIB_FILE}
-CUBIT_LTFLAGS = @CUBIT_LTFLAGS@
-CUBIT_LDFLAGS = @CUBIT_LDFLAGS@
-CUBIT_LIBS = @CUBIT_LIBS@
-CUBIT_FILE = @CUBIT_FILE@
-# CGM_LIBS_LINK is set by configure script to be either
-# "$(CUBIT_LDFLAGS) $(CUBIT_LIBS)" or "$(CGM_LIBS_LINK_INTERNAL)"
-CGM_LIBS_LINK = $(CGMA_INIT_LDFLAGS) -lcgma_init @CGM_LIBS_LINK@
-CGM_LIBS_FILES = @CGM_LIBS_FILES@
-CGM_LIBS_LTFLAGS = @CGM_LIBS_LTFLAGS@
Modified: cgm/trunk/cgm_apps/examples/driverc++/Makefile.am
--- cgm/trunk/cgm_apps/examples/driverc++/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/cgm_apps/examples/driverc++/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -11,6 +11,5 @@
 mergechk_SOURCES = mergechk.cpp
-LDADD = ../../../geom/libcubit_geom.la \
-        ../../../geom/ACIS/libcubit_ACIS.la
+LDADD = ../../../libcgm.la
Modified: cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am
--- cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/cgm_apps/examples/facetdriver/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -10,5 +10,4 @@
                -I$(top_srcdir)/geom/Cholla \
                -I$(top_srcdir)/geom/facet
-        ../../../geom/facet/libcubit_facet.la
Modified: cgm/trunk/configure.in
--- cgm/trunk/configure.in	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/configure.in	2008-07-03 21:51:09 UTC (rev 1981)
@@ -337,9 +337,7 @@
            init/Makefile
            cgm.make
            itaps/Makefile
-           itaps/iGeom-Defs.inc
 	   itaps/SIDL/Makefile
-	   itaps/SIDL/iGeom-SIDL-Defs.inc
            test/Makefile
            cgm_apps/Makefile
            cgm_apps/examples/Makefile
Modified: cgm/trunk/geom/ACIS_SRC/Makefile.am
--- cgm/trunk/geom/ACIS_SRC/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/geom/ACIS_SRC/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -12,7 +12,7 @@
            -I$(ACIS_DIR)/include
 # The name of the library to build
-lib_LTLIBRARIES = libcubit_ACIS.la
+noinst_LTLIBRARIES = libcubit_ACIS.la
 # The directory where headers will be installed
 libcubit_ACIS_la_includedir = $(includedir)
@@ -80,6 +80,5 @@
     gtcAttrib/incl/attrib_name.h \
     gtcAttrib/incl/gtcAttrib_exConst.h
-libcubit_ACIS_la_LIBADD = -L$(ACIS_LIB_DIR) $(ACIS_LIBS) \
-                          ../libcubit_geom.la
+libcubit_ACIS_la_LIBADD = -L$(ACIS_LIB_DIR) $(ACIS_LIBS)
Modified: cgm/trunk/geom/Cholla/Makefile.am
--- cgm/trunk/geom/Cholla/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/geom/Cholla/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -6,13 +6,11 @@
 INCLUDES = -I$(top_srcdir)/util -I$(top_srcdir)/geom
-lib_LTLIBRARIES =
 if BUILD_CGM
-  lib_LTLIBRARIES += libcholla.la
+  noinst_LTLIBRARIES += libcholla.la
 endif
-libcholla_la_LIBADD = ../libcubit_geom.la
 libcholla_la_includedir = $(includedir)
Modified: cgm/trunk/geom/Makefile.am
--- cgm/trunk/geom/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/geom/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -20,13 +20,11 @@
 INCLUDES = -I$(top_srcdir)/util -I.
-lib_LTLIBRARIES =
 if BUILD_CGM
-  lib_LTLIBRARIES += libcubit_geom.la
+  noinst_LTLIBRARIES += libcubit_geom.la
 endif
-libcubit_geom_la_LIBADD = ../util/libcubit_util.la
 libcubit_geom_la_includedir = $(includedir)
Modified: cgm/trunk/geom/OCC/Makefile.am
--- cgm/trunk/geom/OCC/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/geom/OCC/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -11,19 +11,10 @@
            $(OCC_INC_FLAG)
-OCC_TARGET=
-if WITH_OCC
-  OCC_TARGET += libcubit_OCC.la
-endif
+noinst_LTLIBRARIES = libcubit_OCC.la
-lib_LTLIBRARIES =
-if BUILD_CGM
-  lib_LTLIBRARIES += $(OCC_TARGET)
-endif
+libcubit_OCC_la_LIBADD = -L$(OCC_LIB_DIR) $(OCC_LIBS)
-libcubit_OCC_la_LIBADD = $(OCC_LIB_FLAG) $(OCC_LIBS) \
 libcubit_OCC_la_includedir = $(includedir)
Modified: cgm/trunk/geom/facet/Makefile.am
--- cgm/trunk/geom/facet/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/geom/facet/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -9,15 +9,11 @@
            -I$(top_srcdir)/geom/facetbool
-lib_LTLIBRARIES =
 if BUILD_CGM
-  lib_LTLIBRARIES += libcubit_facet.la
+  noinst_LTLIBRARIES += libcubit_facet.la
 endif
-libcubit_facet_la_LIBADD = ../libcubit_geom.la \
-                           ../facetbool/libcubit_facetbool.la \
-                           ../Cholla/libcholla.la
 libcubit_facet_la_includedir = $(includedir)
Modified: cgm/trunk/geom/facetbool/Makefile.am
--- cgm/trunk/geom/facetbool/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/geom/facetbool/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -7,13 +7,11 @@
-lib_LTLIBRARIES =
 if BUILD_CGM
-  lib_LTLIBRARIES += libcubit_facetbool.la
+  noinst_LTLIBRARIES += libcubit_facetbool.la
 endif
-libcubit_facetbool_la_LIBADD= ../libcubit_geom.la
 libcubit_facetbool_la_includedir = $(includedir)
Modified: cgm/trunk/geom/parallel/Makefile.am
--- cgm/trunk/geom/parallel/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/geom/parallel/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -15,13 +15,11 @@
            $(MPI_INCLUDE)
-lib_LTLIBRARIES =
 if BUILD_CGM
-  lib_LTLIBRARIES += libcubit_parallel.la
+  noinst_LTLIBRARIES += libcubit_parallel.la
 endif
-libcubit_parallel_la_LIBADD = ../libcubit_geom.la ../ACIS/libcubit_ACIS.la
 libcubit_parallel_la_includedir = $(includedir)
Modified: cgm/trunk/geom/virtual/Makefile.am
--- cgm/trunk/geom/virtual/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/geom/virtual/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -9,13 +9,11 @@
-lib_LTLIBRARIES =
 if BUILD_CGM
-  lib_LTLIBRARIES += libcubit_virtual.la
+  noinst_LTLIBRARIES += libcubit_virtual.la
 endif
-libcubit_virtual_la_LIBADD = ../libcubit_geom.la
 libcubit_virtual_la_includedir = $(includedir)
Modified: cgm/trunk/init/Makefile.am
--- cgm/trunk/init/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/init/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -12,7 +12,7 @@
            -I$(top_srcdir)/geom/cholla \
            -I$(srcdir)
-lib_LTLIBRARIES = libcgma_init.la
+noinst_LTLIBRARIES = libcgma_init.la
 libcgma_init_la_includedir = $(includedir)
 libcgma_init_la_SOURCES = InitCGMA.cpp
 libcgma_init_la_include_HEADERS = InitCGMA.hpp
Modified: cgm/trunk/itaps/Makefile.am
--- cgm/trunk/itaps/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/itaps/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -10,42 +10,22 @@
 SUBDIRS = . $(SIDL_DIR)
-lib_LTLIBRARIES = libiGeom.la
+noinst_LTLIBRARIES = libiGeom.la
 if build_ACIS
-  TEST_ACISLIBS = $(top_builddir)/geom/ACIS/libcubit_ACIS.la
   TEST_ACISPATH = -R$(ACIS_LIB_DIR)
 else
-  TEST_ACISLIBS =
   TEST_ACISPATH =
 endif
-if BUILD_CGM
-  TEST_XLIBS = $(TEST_ACISLIBS) \
-               $(top_builddir)/geom/facet/libcubit_facet.la \
-               $(top_builddir)/geom/facetbool/libcubit_facetbool.la \
-               $(top_builddir)/geom/Cholla/libcholla.la \
-               $(top_builddir)/geom/virtual/libcubit_virtual.la \
-               $(top_builddir)/geom/libcubit_geom.la \
-               $(top_builddir)/util/libcubit_util.la
-else
-  TEST_XLDFLAGS = $(CUBIT_LDFLAGS) $(CUBIT_LTFLAGS)
-  TEST_XLIBS = $(CUBIT_LIBS)
-endif
-if build_ACIS
-  ACIS_CGM_INCLUDES = -I$(top_srcdir)/geom/ACIS
-else
-endif
 libiGeom_la_includedir = $(includedir)
-libiGeom_la_libadd = $(top_builddir)/init/libcgma_init.la $(TEST_XLIBS)
+libiGeom_la_libadd = $(top_builddir)/libcgm.la
 INCLUDES = -I$(top_srcdir)/util \
            -I$(top_srcdir)/geom \
 	   -I$(top_srcdir)/init \
+           -I$(top_srcdir)/geom/ACIS \
            -I.
 libiGeom_la_SOURCES = \
@@ -67,7 +47,7 @@
 check_PROGRAMS = $(TESTS)
 testgeom_SOURCES = testgeom.cc
-testgeom_LDADD = $(TEST_XLDFLAGS) libiGeom.la  ../init/libcgma_init.la $(TEST_XLIBS)
+testgeom_LDADD = ../libcgm.la
 testgeom_CPPFLAGS = $(CPPFLAGS) -DSRCDIR=$(srcdir)
 testgeom_LDFLAGS = $(TEST_ACISPATH)
@@ -83,11 +63,12 @@
-install-data-hook:
-	echo "iGeom_SRCDIR=${includedir}" >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
-	echo "iGeom_BLDDIR=${includedir}" >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
-	echo "iGeom_DIR=${cfgdir}" >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
-	echo "iGeom_LIBDIR=${libdir}" >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
-	echo "CGM_LDFLAGS=-L${libdir}" >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
-	echo "CGM_INCLUDEDIR=${includedir}" >> $(DESTDIR)$(cfgdir)/iGeom-Defs.inc
+iGeom-Defs.inc: Makefile.am
+	@echo "include $(cfgdir)/cgm.make"         > $@
+	@echo 'iGeom_LDFLAGS  = $$(CGM_LDFLAGS)'  >> $@
+	@echo 'iGeom_LTFLAGS  = $$(CGM_LTFLAGS)'  >> $@
+	@echo 'iGeom_LIBS     = $$(CGM_LIBS)'     >> $@
+	@echo 'iGeom_DEFINES  = $$(CGM_DEFINES)'  >> $@
+	@echo 'iGeom_INCLUDES = $$(CGM_INCLUDES)' >> $@
+	@echo 'iGeom_CPPFLAGS = $$(CGM_CPPFLAGS)' >> $@
Modified: cgm/trunk/itaps/SIDL/Makefile.am
--- cgm/trunk/itaps/SIDL/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/itaps/SIDL/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -143,10 +143,11 @@
-install-data-hook:
-	echo "iGeom_DIR=${cfgdir}" >> $(DESTDIR)$(cfgdir)/iGeom-SIDL-Defs.inc
-	echo "iGeom_SIDLLIBDIR=${libdir}" >> $(DESTDIR)$(cfgdir)/iGeom-SIDL-Defs.inc
-	echo "iGeom_SIDLINCLUDEDIR=${includedir}/SIDL" >> $(DESTDIR)$(cfgdir)/iGeom-SIDL-Defs.inc
-	(cd gserver; install -d ${includedir}/SIDL; install -t ${includedir}/SIDL ${SERVER_HDRS})
-#include make.dependencies
+iGeom-SIDL-Defs.inc:
+	@echo "include $(cfgdir)/iGeom-SIDL-Defs.inc" > $@
+	@echo 'iGeom_SIDL_INCLUDES = $$(iGeom_INCLUDES) -I$(BABEL_DIR)/include' >> $@
+	@echo 'iGeom_SIDL_CPPFLAGS = $$(iGeom_CPPFLAGS) -I$(BABEL_DIR)/include' >> $@
+	@echo 'iGeom_SIDL_DEFINES  = $$(iGeom_DEFINES)' >> $@
+	@echo 'iGeom_SIDL_LDFLAGS  = $$(iGeom_LDFLAGS) -L$(BABEL_DIR)/lib' >> $@
+	@echo 'iGeom_SIDL_LTFLAGS  = $$(iGeom_LDFLAGS) -R$(BABEL_DIR)/lib' >> $@
+	@echo 'iGeom_SIDL_LIBS     = $$(iGeom_LIBS) -lsidl -liGeomserver' >> $@
Deleted: cgm/trunk/itaps/iGeom-Defs.inc.in
--- cgm/trunk/itaps/iGeom-Defs.inc.in	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/itaps/iGeom-Defs.inc.in	2008-07-03 21:51:09 UTC (rev 1981)
@@ -1,48 +0,0 @@
-CGM_LIBS_LINK_INTERNAL =  \
-	$(CGM_LDFLAGS) \
-	${ACIS_LINK_FLAGS} \
-	${ACIS_LIBS} -lcubit_virtual -lcubit_facet -lcubit_facetbool -lcholla ${ACIS_LIBS} -lcubit_geom -lcubit_util \
-CUBIT_LINK = $(CUBIT_LDFLAGS) $(CUBIT_LIBS)
-CGM_LIBS_LINK = @CGM_LIBS_LINK@
-iGeom_INCLUDES = -I$(iGeom_SRCDIR) -I$(iGeom_BLDDIR)
-iGeom_LIBS = $(iGeom_LDFLAGS) \
-             -L${iGeom_LIBDIR} -liGeom \
-             $(CGM_LIBS_LINK)
-iGeom_SRCDIR = @abs_srcdir@
-iGeom_BLDDIR = @abs_builddir@
-iGeom_DIR = @abs_builddir@
-iGeom_LIBDIR = @abs_builddir@/.libs
-CGM_LDFLAGS = -L$(abs_topbuilddir)/geom/virtual/.libs \
-              -L$(abs_topbuilddir)/geom/virtual \
-              -L$(abs_topbuilddir)/geom/facetbool/.libs \
-              -L$(abs_topbuilddir)/geom/facetbool \
-              -L$(abs_topbuilddir)/geom/facet/.libs \
-              -L$(abs_topbuilddir)/geom/facet \
-              -L$(abs_topbuilddir)/geom/Cholla/.libs \
-              -L$(abs_topbuilddir)/geom/Cholla \
-              -L$(abs_topbuilddir)/geom/ACIS/.libs \
-              -L$(abs_topbuilddir)/geom/ACIS \
-              -L$(abs_topbuilddir)/geom/.libs \
-              -L$(abs_topbuilddir)/geom \
-              -L$(abs_topbuilddir)/util/.libs \
-              -L$(abs_topbuilddir)/util \
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/test/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -11,17 +11,14 @@
 	   -I$(srcdir) \
 	   $(OCC_INC_FLAG)
-ENGINE_LIBS =
 LINK_FLAGS =
 TESTS = sheet
 if build_ACIS
   TESTS += webcut
-  ENGINE_LIBS += ../geom/ACIS/libcubit_ACIS.la
   LINK_FLAGS += -R$(ACIS_LIB_DIR)
 endif
 if WITH_OCC
   TESTS += modify makept
-  ENGINE_LIBS += ../geom/OCC/libcubit_OCC.la
   LINK_FLAGS += -R$(OCC_LIB_DIR)
 endif
@@ -33,17 +30,12 @@
 makept_SOURCES = makept.cpp
 modify_SOURCES = modify.cpp
 sheet_SOURCES  = sheet.cpp
-LDADD = ../geom/virtual/libcubit_virtual.la \
-        ../geom/facetbool/libcubit_facetbool.la \
-        ../geom/Cholla/libcholla.la \
-        ../geom/facet/libcubit_facet.la \
-        ../geom/libcubit_geom.la \
-        ../util/libcubit_util.la
-webcut_LDFLAGS = $(LDFLAGS) -R$(ACIS_LIB_DIR)
+LDADD = ../libcgm.la
+webcut_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
 webcut_LDADD = ../geom/ACIS/libcubit_ACIS.la  $(LDADD)
-makept_LDFLAGS = $(LDFLAGS) -R$(OCC_LIB_DIR)
+makept_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
 makept_LDADD = ../geom/OCC/libcubit_OCC.la $(LDADD)
-modify_LDFLAGS = $(LDFLAGS) -R$(OCC_LIB_DIR)
+modify_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
 modify_LDADD = ../geom/OCC/libcubit_OCC.la $(LDADD)
 sheet_LDFLAGS = $(LDFLAGS) $(LINK_FLAGS)
-sheet_LDADD = $(ENGINE_LIBS) $(LDADD)
+sheet_LDADD = $(LDADD)
Modified: cgm/trunk/util/Makefile.am
--- cgm/trunk/util/Makefile.am	2008-07-03 19:04:25 UTC (rev 1980)
+++ cgm/trunk/util/Makefile.am	2008-07-03 21:51:09 UTC (rev 1981)
@@ -5,9 +5,9 @@
 DEFS = $(TEMPLATE_DEFS_INCLUDED) $(LITTLE_ENDIAN)
-lib_LTLIBRARIES =
 if BUILD_CGM
-  lib_LTLIBRARIES += libcubit_util.la
+  noinst_LTLIBRARIES += libcubit_util.la
 endif
More information about the cgma-dev mailing list
